Topic: Reuse steeringwheel bolt? (Read 2096 times) previous topic - next topic
Going to replace the cruise control switches on my 2001 GM steering wheel.
The shop manual says to remove and  discard the steering wheel bolt.
How important is this?
Re: Reuse steeringwheel bolt?
I have never replaced a steering wheel bolt or lock-nut... like ever.   :dunno:
If it has some thread locker on it, reapply fresh.
(Unless it's some weird TTY bolt, or the like, which would be odd for the application)
Thanks.
I found some pics and it looks like they have some locker pre-applied to them.
I guess that stuff is only single use.
I Checked the 84 shop manual and they say the same abount the steering wheel nut.Replace it.
If you decide to not get a new bolt, I would suggest cleaning the threaded shaft and nut threads with acetone or rubbing alcohol and let dry completely.  Then I would use Loctite 262 thread locker sparingly (on male thread only).  You may need to use a heat gun to remove.
Edit:  the prep of the threads (cleaning) is the most important part otherwise the Loctite does not work.
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
I have reused mine a few times. Zero issues.
I'm with the Vman, always re-used the bolts...no issues. Acetone and a dot of loctite (per the application), as mentioned prior. Good to go. When I put my Sport together a few years ago and then parted it out, I had to use an impact to get the bolt loose. So I'd say it's a non issue ;)
Yeah, I cleaned up the old bolt and put loctite on it.
But the '01 Merc GM uses a Torx bolt.I wasn't happy to see that.
I broke a few Torx sockets(Bits?) on the brake calipers on the '84 TBird.
