Topic: Re-hung my 3" (Read 4730 times) previous topic - next topic
Re-hung my 3"
I had it hung low due to the original cross brace under the drive line, but it ended up dragging on a high curb driveway.  I just took the brace out and tucked it up higher and cut off that ~2" end of the adjustable hangar in the picture.  Any thoughts or tips?
84 TC -- https://imgur.com/a/CCLPLED
Bright Canyon Red TuTone, Desert Tan Interior; 1 of 7 in this combo in 1984 according to Marti.  1 of 13,361 TCs in 84.
   Rebuilt, 3-Angle Valve Job, SYB37 "OE" Cam, Full 3" Stinger Exhaust, RF-E6 Manifold
   Gnari FMIC, Remote-Mount TFI, PC1 and 35#, fully rebuilt Suspension, etc.
Re: Re-hung my 3"
I got rid of that brace a long time ago.
Looks like the main problem is that it's low up front. You could go up at least another inch and tuck it up tighter to the transmission X-member.Then you could make the whole thing tighter to the floorpan all the way back to the ler, and bring it up too.
Re: Re-hung my 3"
Here's a sound clip https://youtu.be/cQ18VmP3Lms
Re: Re-hung my 3"
Wow, thanks for the quick reply.
Ok I will keep that in mind for when I decide to adjust it again.  I was also considering adding a hangar from the original holes in the transmission mount that held the original cat converter.  With my tools and expertise I had a hard time tightening the down pipe, so I left it where it was for this re-attempt.
Re: Re-hung my 3"
Adding the additional hanger might not be much help if the downpipe is a touch long and just hangs lower. However, if the exhaust is just being held up by the downpipe  bolts and the ler hanger, you probably should add one for extra support.
You might be able to loosen the downpipe and separate the rest of the exhaust from the downpipe. Then put the DP where you want it to be (raise end up, etc) and support/secure it in place while you tighten the DP back down at the turbo. If you don't have an extra set of hands, use something as a spacer between the DP and the x-member and hold it in place with a bungy cord or something. Just an idea.
The end of the DP looks slightly angled down in the second pic, so some adjustment may be needed to get things higher.
Re: Re-hung my 3"
The more I stare at the pictures the more I see what you are saying, I think this was a result of having that cross brace in there when I aligned and tightened the down pipe.  I think it must be angled down a touch more than it could be.  Thanks.
I think I could rig up another support while I'm at it pretty easily too:
https://smile.amazon.com/gp/product/B001AX9WJ6/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
https://smile.amazon.com/gp/product/B000C8ZB18/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
Re: Re-hung my 3"
Obligatory sound clip  https://www.youtube.com/watch?v=cQ18VmP3Lms&feature=emb_logo
Re: Re-hung my 3"
I just came in here to say that I giggled when I saw the thread title.
It's Gumby's fault.
Re: Re-hung my 3"
Yep, real hung with all 3"!  Dangles just below the floor pan
