Topic: My GTbird build (Read 50600 times) previous topic - next topic
My GTbird build
Reply #150
I like it! It turned out beautifully! I also like the chrome anniversaries on it..
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
My GTbird build
Reply #151
What a transformation.    I think the Chrome wheels are a great finishing touch.
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
My GTbird build
Reply #152
Chrome wheels definateley made it pop, I had the exact black on my hood but in vinyl.....
88 sport,TW heads, comp xe270hr, cobra u/Tmoss ported lower, 65 mm throttle body, under drives,smog delete,
1.7 roller rockers, cai, k&n, bbk adj regulator, 76mm Pro-m,all MSD ign. MSD dist,18° base timing, 3g alt.1 5/8 ceramic headers, 255lph walbro, 2.5" h-pipe, flowmasters, silverfox valvebody, 3.73 gear,
http://i216.photobucket.com/albums/cc154/flipnbird/DSCF0185.jpg ( RIP : ( )
My GTbird build
Reply #153
Well I went and did a thing....
Its Vortech V2 sq and my plan is to pulley it for only 8psi , throw some 42lb injectors in it then make a very soft timing map to hopefully keep the power down to around 400-425 at the wheels. Then pray the T5 will be ok. Im also going to swap in a 3.27 gear and go enjoy it!
Brian R.
88 2.3t Ranger
My GTbird build
Reply #154
Boost is a hell of a drug....
My GTbird build
Reply #155
Quote from: thunderjet302;458686
lol I forget a lot of you guys here dont know me very well yet.
My last toy was my 88 Ranger with a 2.3, Holset HX35 and a c4. It made 392 rwhp and ran 11.20s in True Street trim.
The one Im building now is another 88 Ranger but it has a 2.6 tall deck, PT 6266 and Im shooting for 600+
Brian R.
88 2.3t Ranger
My GTbird build
Reply #156
Well I went and got the car out of storage yesterday and she is now home!  Dam what a fun drive it was coming home! Just love how this car runs and drives.
Looks like first on my list today is to recover the headliner and get that installed. That will officially make the interior finished.
And you can call this the "before" shot of the motor. Big changes on the way!
Brian R.
88 2.3t Ranger
My GTbird build
Reply #157
Looks great!
My GTbird build
Reply #158
Looking good.
I see you have one of them fancy heat shields next to the air cleaner ;)
My GTbird build
Reply #159
Laid some vinyl on the roof today. I love it! Car is getting closer to my original vision stored in my head months ago....
Still need to tint the back glass and the Plastidip on hood will be coming off soon for my final design in vinyl.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #160
Amazing transformation on this car. Can't wait to see what you do next.
87 Tbird LX w/Factory floor shifter:D   3G upgrade. Tinted Windows...85 Mustang GT steering wheel(non-cruise) 17'' Saleen SC style wheels,Front/Rear TC sway bars/poly bushings & Mustang GT steering rack...'05 Mustang V6 springs...93 Cobra MC & booster, MM adjustable C/C plates,  Work  In  Progress.......  ( On The Shelf---HO computer, 19lb injectors, HO cam, BBK headers, Explorer Intake, Cold Air Intake ,Phantom Gauges, Stinger stainless exhaust pipes )
 S O L D
My GTbird build
Reply #161
Oh I forgot, a couple weeks ago I finally recovered the headliner and chose to delete the visors since they were trashed anyway.
I picked up an old pump assembly and took it apart to clean up the bracket,paint and resealed the reservoir with a new o-ring. Then I installed it on a new A/C delete bracket kit.
I had to move my rad overflow tank since it was in the way of the new pump so I moved it to the front side of the core support.
I welded two -10 bungs to the valve covers for my new remote breather tank setup. I plugged the hole in the lower intake for the PCV. I was shocked how much oil film was in the intake runners with the factory PCV setup. Motor only has 1100 miles on it so this would of turned into a real problem fast once I add boost.
So I found that the lower crank pulley for the blower wont clear the electric fan in its current puller setup so Ill be swapping to a pusher fan and moving it to the front side of the rad.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #162
Once you go above stock HO power levels the factory PCV location tends to suck more oil, even N/A. Something about the air flow increase. A real Motorcraft PCV helps but a catch can/oil separator is better.
What radiator are you running with your setup?
My GTbird build
Reply #163
Its a huge Griffen
Brian R.
88 2.3t Ranger
My GTbird build
Reply #164
Was that a glimpse of your car on the last episode of Detroit Steel? :burnout:
1984 Cougar Convertible
1988 Cougar XR-7
