Topic: Aftermarket head unit with stock premium sound amp and eq? (Read 8536 times) previous topic - next topic
Indeed it does.  Thank you....
Quote from: BCA;467766
If it helps, here is the pdf file from the first post.
Always coming out of left field with the good tech.
It's Gumby's fault.
Yup that's the diagram I used to wire the head unit to the factory system.
