Delete A/C. TAD/TAB solinoids
I did the engine swap in my bird and I removed the a/c compressor, lines, condensor and acumulator. I have to pull the heater plenum to replaced the heater core so i figured I would pull the a/c core too and block off the holes. But I was going to ask about the a/c vacuum line. If i disconnect that and cap it of what will happen?
Also I am running no emmissions system on my car and I have no cats. So can I remove the TAB TAD solinoids? Also ther is a third solinoid in the same area of the passenger strut tower. What is that for?
Thanks guys
