To Silicone or Not to Silicone February 26, 2010, 09:07:18 PM When rebuilding or replacing the timing cover or water pump how many people use silicone or equivalent along with the gaskets Quote Selected
To Silicone or Not to Silicone Reply #1 – February 26, 2010, 09:16:31 PM I use the gasket and put a small bead arround both the coolant ports on both the cover side and the engine side. Quote Selected
To Silicone or Not to Silicone Reply #2 – February 26, 2010, 10:39:54 PM agreed, I do the same thing to ensure a good seal. Quote Selected
To Silicone or Not to Silicone Reply #3 – February 27, 2010, 06:23:33 AM I base my method on the condition of the parts. If they're pitted or if there was a leak I use silicone. If they look like new I just use the gaskets. They almost never look like new though... Quote Selected
To Silicone or Not to Silicone Reply #4 – March 01, 2010, 04:43:53 PM I just put a small bead of RTV on both sides of the gasket and bolt the parts together. I've never had a water pump leak doing that. Quote Selected
To Silicone or Not to Silicone Reply #5 – March 01, 2010, 08:14:37 PM I'm a big fan of Hylomar, but it's not always available any more. Quote Selected
To Silicone or Not to Silicone Reply #6 – March 02, 2010, 02:54:47 PM I use Hylomar on Harley engine cases and cylinder base gaskets, and on car engines in place of permatex. It was developed by Rolls Royse for use in the aerospace industry. It don't harden and dry out, impervious to gas and oil, and it wont plug an oil hole and cause a spun bearing like silicone can. It can be found cheap at any Harbor Freight.http://www.hylomarblue.com/ Quote Selected
To Silicone or Not to Silicone Reply #7 – March 02, 2010, 03:33:29 PM FANTASTIC! Thanks for the Harbor Freight tip Tbone.Time to stock up again, I was on my last tube. Quote Selected
To Silicone or Not to Silicone Reply #8 – March 03, 2010, 02:02:32 AM Thanks for the headsup on the Hylomar. Sounds like some good stuff!! Quote Selected
