Topic: 86 mustang GT 8.8 rearend (Read 2660 times) previous topic - next topic
I found a 8.8 rearend from a 86 Musteng GT and would like to know from you guys,will this bolt up to my 83 T-Bird, without any problems?
It'll bolt in but it's like 3/4" naorrower on each end.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
i didnt think 8.8's were used till 87 in stangs
Currently Birdless but never Foxless
86 Mustang GT
Thank you.
dougy just FYI 86 was first year for SEFI, roller blocks and 8.8" rear in the 5.0 stang if i recall correctly
i knew it was for SEFI and roller, but was unsure on the 8.8
should have known though, i have a friend with an 86 and it has an 8.8
86 Mustang GT
Take the brakes/axles off your '83 Tbird rear end, and use them on the Mustang housing.
Quote from: Chuck W;297561
+1
Will work like a charm:D
So if I go get an 8.8 from the yard (lots of rustangs) I can swap my 4 lug axles from my 7.5 into the 8.8?  That sounds too easy.  I just got a 7.5" posi carrier from the yard too, dang it.
Quote from: danzajax;297600
No.
86-88 7.5 Tbird housing are different.
Been discussed, numerous times.
Chooglin's car is an '83.
Thanks for the tip Chuck...........that will save me some Money.
I have just one ? ,without going threw all of the 7.5 to 8.8 swap info again (I read that thread already)
will this 8.8 be the same width as my 7.5?
Ah.  I've read through the rear end threads but got confused.  I would like to go to an 8.8 locker but save the 4 lug. I will just suff the locker in there for now. Thanks for the heads up.
Quote from: Chooglin;297604
Yes.  Thus my suggestion to use your axles/brakes from your existing rear end on the new one.
I picked up the rear end and all looks good,but I need to know what the two brackets on the ends of the axle tubes are for.(maybe a stabilizer bar?)
That's the mount for the horizontal(quad) shocks...
