Topic: 88 Thunderbird LX V8 Rear End (Read 5169 times) previous topic - next topic
Does the 88 Thunderbird LX V8 with digital dash (not the Sport ) come with a 7.5 or 8.8 rear end?
1988 Black Turbo Coupe
1989 Fiji Blue Chrysler Conquest
1990 Silver Lincoln LSC MKVII
2003 Black Mercury Marauder - S/C
1967 Green Ford Fairlane
:burnout:
Quote from: vinnietbird;272420
7.5
That's not good news, will a complete 87 MKVII rear end bolt in?
:burnout:
a few '88 5.0 Birds had 8.8s just like the Cougars, you'll have to get under it and check....
Thanks, I've already decided not to pursue the purchase.
:burnout:
My '88 Sport only has a 7.5 in it, however it is a traction lock unit.  Go figure.
If you have the vin you should be able to check the axle code.
Quote from: Haystack;272575
There is not one s of info in a vehicles VIN number that pertains to axle type...
That info is on the data sticker on the door jam ONLY... Even then you'll only get ratio and whether it's Traction Lock or std... You wanna know the size, gotta crawl under it...
I agree with Tom....get the info from the tag on the rearend. That's the best way to do it.
What they said.Check the door or crawl under and check the tag and cover shape.None of my Traction Lok or whatever they call it diffs have had a tag to identify them a such.
  But they do all have a tag identifying the ratio.
Pimp smacking smart azzes on the streets since 1970
You can also check by rotating one side (A friend of mine told me this so I'm not 100%) if the other side rotates the same direction its a trac-lok if not its an open diff.
Quote from: Cat Daddy;272583
All the Traction Lock rears I've seen, have on the tag 3L25 for a 3.25(or what ever the ratio)... If its a peg leg, the letter will not be there...
Quote from: TurboCoupe50;272647
 You are correct!I did a little research and found out that an L in the code means locker.I believe non lockers have an S in the code.
  I am so used to seeing an additional tag requiring some sort of additive that I missed the letter in the tag.My bad:hick:
If you are familiar with the cover of the 7.5 and an 8.8 peek under and look at the cover of the rear end and you will know.
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
whats my car got in it? Its positive traction, 88 Sport model. Should be 8.8 correct? I havent got under it to look. (just had back surgery 2 months ago, still cant get under a car)
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
