Re: Holy body roll batman!! Reply #15 – March 25, 2005, 04:34:24 PM Bird351..make sure you don't get endlinks for as Mustang...they're too long....measure the ones on your car to be certain which ones you need. (I might have an extra set...)The Tbirds/Cougars to not have upper strut mounts like the Mustangs. Stock the "bushings" are not servicable or replaceable like on the 83-04 Mustangs with the "cup" style mounts. You can buy replacement upper mounts from Moog or TRW that have the cup that you can put the poly bushing in.... Quote Selected
Re: Holy body roll batman!! Reply #16 – March 25, 2005, 04:51:01 PM , that might ruin the possibility of ordering from CHE like I was planning on. AutoHole has E-S end links listed for T-birds specifically, CHE does not. On the bushings, AutoHole's E-S bushings are special order.. so I figure I'd have had to wait for them either way. In that case, (and there not being much of a price difference either way) I had planned on going with CHE for the order. Maybe I better contact him and specifically request T-bird end links.If you do have them, and I strike out elsewhere, I may have to get back to you on that possible extra set. (if you find 'em and they're up for sale) Hoping I can get at least a little business going this guy's way, though.. for hooking the board up on the adjustables.Thanks. Going to go measure 'em right now before it threatens to rain again. (just threatening, and a few drops.. annoying as hell)EDIT: 9 inches from the top of the end link to the very bottom. 7 inches of that from the top of the end link to the top of the A arm. The other two inches are apparently all threaded. When she's sittin' on the lawn and you have fire ants around, you try not to lay down there any longer than you have to. :p Quote Selected
Re: Holy body roll batman!! Reply #17 – March 25, 2005, 06:18:10 PM Quote from: Chuck WBird351..make sure you don't get endlinks for as Mustang...they're too long....measure the ones on your car to be certain which ones you need. (I might have an extra set...)so that's why they're crooked :disappoin I got the mustang end links, dunno if it's cuz they're too long or the bar is narrower or what, but they were a PITA to get in and they're kinda crooked. does this just mean they'll be more likely to break or wear out or?and the package says to measure from one of the inner washers to the other, with the car on the ground and the control arm and sway bar parallel. the part# I got was 9.8121G, which is 4.5". I'm thinking I shoulda got the 9.8149 (4.25")edit: well I measured the stock endlink, and it's 4.5" Quote Selected
Re: Holy body roll batman!! Reply #18 – March 25, 2005, 06:34:31 PM Distance between the insides (opposing faces) of the two washers was like 4 1/2" to 4 5/8". Quote Selected
Re: Holy body roll batman!! Reply #19 – March 25, 2005, 06:37:44 PM according to the package, 4.5" is the longest they have maybe the mustang sway bar is narrower? Quote Selected
Re: Holy body roll batman!! Reply #20 – March 25, 2005, 06:55:06 PM Or perhaps I have the wrong ones, installed by someone doing a repair for the past owner? Quote Selected
Re: Holy body roll batman!! Reply #21 – March 25, 2005, 07:07:54 PM Quote from: Bird351I think he means Passenger Side and Driver Side. PS/DS.oh. :disappoin MM has endlinks for TBirds. says 4 3/4. just thought i'd toss that out there. Quote Selected
Re: Holy body roll batman!! Reply #22 – March 25, 2005, 10:19:34 PM the mustang GT bar is the same bar as the TC bar, so it being narrow is out Quote Selected
Re: Holy body roll batman!! Reply #23 – March 26, 2005, 12:45:55 AM That might be why on hard turns that I rub the sway bar with the big ol' tires, because the links are to long. Found a set of Mustang bars on Evil Bay for $250, 1' 3/8" front and 1' rear. that combo should help in flaten my car out during an autocross. Quote Selected
Re: Holy body roll batman!! Reply #24 – March 26, 2005, 03:26:21 AM Quote from: Tbird232cithe mustang GT bar is the same bar as the TC bar, so it being narrow is outwell I don't have a TC bar stock :dunno: Quote Selected
Re: Holy body roll batman!! Reply #25 – March 26, 2005, 03:27:17 AM Quote from: darkthunderoh. :disappoin MM has endlinks for TBirds. says 4 3/4. just thought i'd toss that out there. I don't see how another 1/4" would fit in there, the end links were already at an angle and a PITA to get in Quote Selected
Re: Holy body roll batman!! Reply #26 – March 26, 2005, 08:25:27 AM Which brackets did you use to install the front bar to the chassis?I'll climb under my Tbird and measure mine here at some point this weekend. Quote Selected
Re: Holy body roll batman!! Reply #28 – March 27, 2005, 08:32:58 PM Well, I'm not sure then. I checked mine this afternoon. Mustang 33mm bar, Tbird chassis mount brackets and the shorter endlinks (length of spacer in the middle is 3 3/8"). Car is lowered about 1.5" or there abouts. The sway bar is parallel to the arm and the endlink is pretty vertical. Quote Selected
Re: Holy body roll batman!! Reply #29 – March 28, 2005, 01:21:03 PM So do we have a consensus on what the exact length of the end links should be ? I'm looking into getting some new ones myself and wouldn't mind knowing the exact length they need to be. Quote Selected
