Topic: oil pressure gauges (Read 1038 times) previous topic - next topic
oil pressure gauges
have 87 thunderbird 3.8 putting a oil p auge on it can figure out were it goes help please
oil pressure gauges
Look around the engine near the oil filter and around the front and sides of the block. I have never been up close and personal with a 3.8 but generally you'll find a threaded plug in the above-mentioned areas on most engines, remove the plug and screw in your pressure gauge fittings or sending unit. If it's a sending unit go real light on the thread sealer/tape as the sender grounds through the metal it's installed in.
oil pressure gauges
I roll with a 3.8 in my Bird. We installed an oil pressure guage when dropping in the new 3.8.  On the front of the block, there is a small, tight area for the fitting to screw into.
Drop me a private message on here if you'd like with your email address and I can email you images of the motor that may help you.
Check out my cardomain page - I might have one or two on there.
Chris
oil pressure gauges
looking directly at the oil filter,,,,,,
oil presure switch is at your 2 o'clock.
Your 3.8 has an external pump as well.
Also, within the timing cover just behind the gear set is a proportion valve that consists of a freeze plug, spring and one proportioning valve.  If the valve has burred the cover , then it will not slide left to right completely and cause incorrect readings / improper oil circulation.  bad design but it is what it is.
