Topic: no power?(solved) (Read 6932 times) previous topic - next topic
no power?(solved)
Reply #45
im starting to give up on this p.o.s. now no power to the fuel pump or starter .bought new starter new soleniod to starter cable.there are to soleniods that click one is under the hood the other is under the dash ,the soleniod under the hood is all black and on the pass. side the other is brown/black and on the pass. side it is from the under the hood harrness.
no power?(solved)
Reply #46
Are you battery connections clean and tight?
before we go any farther
no power?(solved)
Reply #47
yes they are checked that earlier.
no power?(solved)
Reply #48
I've not read this entire thread but did you replace the negative cable?  The fuel pump ground is right off of the negative cable.
no power?(solved)
Reply #49
ground was replaced before we started the sefi swap.
no power?(solved)
Reply #50
theres not any power to the solenoid tostarter side of the solenoid .thats with the key on.
no power?(solved)
Reply #51
its alive ! it runs now started it the other morning open exhaust.it runs a little rich but we'll fix that soon enough.
no power?(solved)
Reply #52
Quote from: superpinto;201718
sounds like your solenoid is operating as should with "key ON"
glad to hear you got it running.
no power?(solved)
Reply #53
no hooked it up to a push button the is also fuel pump is also on a switch but it runs! am i right
no power?(solved)
Reply #54
Ever find out what the burnt connectors were?
The one you described sounds like a fusible link...
no power?(solved)
Reply #55
the black one was like a position switch i think it was to the neutral safety switch the other was to the climate control.
no power?(solved)
Reply #56
it has a flowtech h pipe right now .sounds good with a open exhaust.
