Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1482468 times) previous topic - next topic
Reply #3045
Whats up! To busy to work on it?
Reply #3046
Quote from: Kitz Kat;366537
Unfortunately... going to try for the long weekend starting tomorrow....I can't believe how close it is too, It's really killing me here
Reply #3047
Good luck Jerry. If you do anything at all, at least that's something. I'm keeping my fingers crossed for you....well, mentally anyway. I need my hands for work.
Reply #3048
I suppose I could be out there instead of typing this...lol I'm going out there now...I blew a flex brake line last week.....installing the new one and bleeding brakes in a bit
Reply #3049
I took Gayle to lunch....other than that, nothing. Just don't feel like another day in the over 104 degree weather. Maybe this weekend after work. Gonna re-clock the drive shaft,change the front brakes.and install my O2 sensors. All of that MIGHT take an hour or hour and a half at the most. Just not today,. Good luck on the Cougar.
Reply #3050
finally had a few hrs to catch up on some stuff
I got front brakes.. will fix the rear brake problem as I finish things.
got the shifter moved again...and bolted down. I think this will work out with the boot.
a couple random shots
started the wiring for mass air, will probably finish that tomorrow.
after the computer wiring.. the starter needs to be wired, the radiator filled, and the battery put in..... and I think I can turn the key.
oh yea... I blew out my gerbil balls.....dammit
Reply #3051
Poor Gerbil ......... lol
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #3052
I see you're using an A9L computer. I think there is an issue with the neutral safety switch wiring between an auto and manual trans car where the A9L can get fried. I'll see if I can find the info. I could be wrong though.
Reply #3053
Mass air wiring done...... starter wires, and battery..... that's all that's left
Reply #3054
Woot!:D
Reply #3055
I just wanted to add I still think you are crazy.
Reply #3056
Quote from: DVP;369241
why is that?
Reply #3057
ok, starter is wired, and battery is charging.... fire extinguisher is in close reach...lol
I won't be able to get to it until Saturday...I'll put the battery in, and if there's no fire, I'll see if I have interior lights, and probably do a keyon test first.....
Then it's in Gods hands if it sees all the sensors, and the fuel pump primes......phew...what a head rush... lol
Reply #3058
Go for it.....
Reply #3059
Finally, the moment we've all been waiting for. lol! Good luck I hope it fires on the first try.
