Topic: Type 6 (86+ 5.0) Poly Motor Mounts (Read 28464 times) previous topic - next topic
Reply #135
The 83-85s are going to use Mustang mounts. My 5.0 mounts cover 86+.
Reply #136
OK. I have two sets of the Type 6's left.  Once they are gone, that's it. I'm not planning on making any more.
Get 'em while you can.
Reply #137
These are it. When they're gone, they're gone.
Reply #138
One set left.
Reply #139
AAANNNNNDD gone.
Reply #140
So are you done (as in never again) making any kind of motor mounts or shock adapters?
Reply #141
Quote from: Aerocoupe;455900
Right now I have no plans to get back to this. Too busy.
Re: Type 6 (86+ 5.0) Poly Motor Mounts
Reply #142
Not sure if anyone is reading this but I’ll give it a a try.  I bought a set of your mounts probably 10+ years ago.  Started the car today and found a pile of dried out bushings underneath.  Jacked the car up and the bushings in the mounts crumbled.  How can I get replacements? I’m in a bind.
Thx
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
Reply #143
Thx
Hi.
Typical failure of the 2nd-source poly bushings I tried for a while.
Energy Suspension 9.4102's are the replacements (and the original bushings I used when I started all of this).
They run around $30-35/set everywhere online.
