Topic: Type 6 (86+ 5.0) Poly Motor Mounts (Read 30214 times) previous topic - next topic
Reply #120
Quote from: 20thanniver-ls;346199
I'll have to take a peek at mine, and compare them, just figured you may have known off-hand.
I just can't recall any Mk7 guys picking them up.  I would think that yours would be the same as the 5.0 87 Tbird/Cougar.  If you can snap a quick pic or two from below, I could better help ID them.
Reply #121
OK, a quick part number search shows that for your '87, you would use the same mounts as an 87 Mustang.
If you want to snap a picture, I can verify it for you.
Reply #122
I got a few pictures, but I can't upload them, my sd card reader is missing.... I did a parts number search in relevance to the t-bird, and they were indeed different. I can try to grab some pics with my phone, but I have no flash so they may not be all that great.
FOXLESS!!
1994 Lincoln Mark VIII
Reply #123
Quote from: Chuck W;346272
Yep the Mark VIIs use the same mount as 5.0 Mustangs. I believe they actually used the Mustang convertible mounts which are some what different (not much) than the hard top mounts.
Reply #124
Hey Chuck do your mounts sit same as factory? or lower?  I have "altered" stock mounts a now my steering shaft ishiznitting the BBK longtubes. Mine are solid but I need some that sit the engine a tad lower? thanks
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Reply #125
no i am wrong motor need to go up a tad, mine are stocker drilled with a welded blolt through them. i think the lost some height
Reply #126
They sit normally at around the stock height.  You can space them up a slight bit (1/4-3/8") if needed with the stock hardware.
Reply #127
do you have any on hand? and if you do how much are they shipped to 61073. I just want the headers to clear
Reply #128
I just sent out the last set I had on hand, so I would need to weld up and coat more.
They run $175/shipped in the US.
Reply #129
I have a couple sets of my Type 6 motor mounts available at the moment. Coated black.
They will fit 5.0/5.8 motors into 86-97 TBirds/Cougars.
Also, please don't ask about shock mounts in this thread. IF I decide to do more, I will post up about it.
Email me please at cwarren@indy.net
Reply #130
One set still available
Reply #131
I really should get these.  monies
Reply #132
So, I've been talked into doing a few more mounts (Been trying to take a break from it). I'm going to have a couple sets of Type 6's available in this batch.
Pricing as usual, $175/shipped in the US. Black powdercoat.  Email me if you're interested at cwarren@indy.net.
(Sorry...no shock brackets will be happening)
Reply #133
OK, well I'm welding these up right now. Get 'em while you can!
Reply #134
I have 351w in my 83tb, with convertible mustang mounts, you have mounts for 351w?  benefit from the convertible style mounts?
