Technical => Engine Tech => Topic started by: tbirdera on August 27, 2006, 04:07:01 AM
Title: Good Aod Torque Converter
Post by: tbirdera on August 27, 2006, 04:07:01 AM
hey wats a good aod torque converter for about 400 hp ??? with a lockup
Post by: Tbird232ci on August 27, 2006, 10:50:39 AM
The real question is how are you going to make 400hp? Definatly not with a trick flow kit.
Post by: sum_weirdo on August 27, 2006, 11:40:51 AM
I think most of us are partial to B&M converters.  They're Torkmaster series is fairly cheap and I've heard they'll hold up fairly well on the street.  A Holeshot series like mine ran me like $400 CAD but I'm sure it'll take whatever I throw at it.  I think they come in stall speeds of 2000, 2400, and 3000...probably higher.  If you're actually going to make 400 horsepower you'd probably want a 2400 or 3000 stall.  Just don't overkill with the stall speed or you may have to floor it just to get the car moving :P  And you'll need a transmission cooler.
Post by: Kitz Kat on August 27, 2006, 12:10:28 PM
stay away from b+m,Igot less than 1000 miles on it,stall is unpradictable on them.
Post by: tbirdera on August 27, 2006, 01:31:44 PM
is a tci torque converter any good
