Marketplace => Miscellaneous For Sale/Wanted => Topic started by: SLEEPER T-BIRD 87 on April 25, 2006, 03:14:45 AM
Title: Fast 87 coupe street race car
Post by: SLEEPER T-BIRD 87 on April 25, 2006, 03:14:45 AM
[Motor]
87 302 cu in , ported e7's , mystery cam,headman equal leanths, motorsport a/c delete, hold decent oil pressure 45-50 cold 15-20 at idle 30-45 at cruise hot, no noise/smoke/rattles runs happy on 87 octane fuel and gets 18-20 mpg. 650 double pumper. msd ignition.
[trans]
4cyl t-5 in good working order fresh fluid change and seals
motorsport clutch ,aluminum quadrant,adjustable cable
[rear end ]
8.8 with 4.10 gear and tight trac lock no leaks leaves two nice even marks
[exhaust]
12"-16" of 3" pipe to 40 series flows and dumps.
[body]
fresh black topcoat base/clear ,blue is in good shape has some small chips and dings. worst spot is some flaking on back bumper were it has been bumped no damage to cover though just topcoat. no real damage.
HARWOOD 6" cowl
lift off hood has 4 hood pins
ROLL UP WINDOWS! wich is pretty rare
car was a 4 cyl conversion done right has 5 spd pedal assembly in it
has weld in subframes with seat braces done by prospeed in atl.
wheel well lips removed by previous owner
has a real carburated pick up in the tank {not just some rigged mess like i see on alot)
5/16th line
aeromotive pump
holley regulator
perf products gauge
has good brakes at all 4 corners. 70% or better
I have 11" to swap on the front but it stops good so i never changed them. can include if wanted.
no sway bar on front to help transfer
v-8 rear swaybar
turbo coupe quad shocks
new v-8 front springs and 86 gt rear springs
never been wrecked and has a clean carfax
[Tires And Wheels]
15x4 and 15x8.5 convo pro's
165's on the front and 245/60/15's on the rear. a couple have some curb rash by previous owner i feel no wobbles in the steering wheel
[GLASS]
needs windsheild < have new one that needs installed
rest is in good shape and tinted about 20%
[interior]
base 4 cyl rear seat ,
87-88 checker board front seats with some pretty good wear
90-93 dash,steering colum and console < ? done by previous owner missing colum shroud about 5.00 at salvage yard
has blue manual window door panels
carpet needs shampoo'd everything is grey except door panels a quick dye job on them woukld fix that though
generally not real bad for age but needs some work
[sound system]
has jvc kammilion cd head unit
sony xplode door speakers
rockford fosgate deck speakers
[Gauges]
auto meter monster tach w/shift light
sunpro white face gauges in pillar pod
factory tach/water/oil gauges are non functional
speedo need new cable it was missing when purchased.
$6,500.00 obo no low ball offers please
to ad it has a new affco aluminum radiator and 180* thermostat, hoses etc... new battery new plug wires,plugs, nos cheater kit with big selonoids jetted at 175 h/p. etc.... race or drive your choice!
for an extra 150.00 i will throw in two almost brand new 28/9/15's on nice 10 holes
Post by: P71 on April 25, 2006, 03:43:46 AM
Wasn't the 429 in that car???
Post by: SLEEPER T-BIRD 87 on April 25, 2006, 04:07:42 AM
Quote from: Aerobird Motorsports
yup for 2 weeks, swapped back out due to fuel cost's
Post by: P71 on April 25, 2006, 10:00:50 AM
So now the 'Bird is the 429 again? Man you work too FAST.
Post by: SLEEPER T-BIRD 87 on April 25, 2006, 06:05:19 PM
I work fast:D
Post by: Ether947 on April 25, 2006, 07:41:22 PM
that 429's a w! lol.
i believe you are living up to your name sleeper... how can anyone know what you got under the hood if you keep changing engines? totally unfairs. :D
Post by: P71 on April 25, 2006, 08:21:04 PM
Is it the 302 or his 429??? I don't know? He wants to race for pinks! Oh man, why does he swap engines every random 3rd day???  that Sleeper!
:D:D:D:D
Post by: SLEEPER T-BIRD 87 on April 25, 2006, 11:03:26 PM
Quote from: darkthunder
:D :D :D
Post by: SLEEPER T-BIRD 87 on April 25, 2006, 11:13:04 PM
:D:D:D:D
:hick:
Post by: DakotaEpic on April 26, 2006, 11:11:02 PM
No offense to this car, but I'm glad to see you selling it over the Bird.
Post by: SLEEPER T-BIRD 87 on April 27, 2006, 12:57:34 AM
Quote from: DakotaEpic
:tg:
Post by: SLEEPER T-BIRD 87 on April 27, 2006, 07:38:14 PM
new windshield and seal installed today, window trim reinstalled, Fresh oil change& filter and fittings lubed, Power steering flushed and synthetic fluid added.
TTT
Post by: SLEEPER T-BIRD 87 on May 01, 2006, 12:42:45 AM
new pedal covers added, paint chips repaired , etc
Post by: SLEEPER T-BIRD 87 on May 05, 2006, 08:57:09 PM
rear bumper repainted, new belt added some other small work done
6,000.00 or partial trade towards a running t/c parts car
Post by: SLEEPER T-BIRD 87 on May 11, 2006, 12:41:39 AM
no longer for sale~!!!
