Technical => Engine Tech => Topic started by: 87tbird302 on November 30, 2004, 04:40:06 PM
Title: valve covers?
Post by: 87tbird302 on November 30, 2004, 04:40:06 PM
What aftermarket valve covers will fit? I just got some moroso ones, the driver side fit fine, but the passenger side washiznitting the throttle bracket, and it wouldn't fit, so I took them back because I think they were for CFI engines. What valve covers will fit on an EFI? What size will fit? Does anyone have any aftermarket ones?
Thanks.
Title: Re: valve covers?
Post by: zpyro on November 30, 2004, 04:45:38 PM
I'm guessing any fox mustang ones will fit. I got some chrome ones off of ebay, both of them have holes for a filler/breather. I found some low-profile caps for them at autozone, but I have yet to put them in. they look low enough to fit.
but I'm sure any FRPP covers would fit, as well as any made to fit 5.0 fox stangs
Post by: cougarman on November 30, 2004, 05:07:47 PM
You need a phenolic spacer to space your upper intake up, then you can use just about any covers.  Mustang Gt covers fit without a spacer.  :ies:
Post by: 87tbird302 on November 30, 2004, 08:14:20 PM
Yea, it said it would fit 289-351 ford smallblock. Yea, I also thought of that spacer for the upper intake, I wasn't sure if it would work or not, good thing I got one at the swap meet. Also my other question is, will the bolt be long enough or will I need longer bolts?
Thanks
Post by: cougarman on November 30, 2004, 08:38:41 PM
You will need longer bolts. :ies:
Post by: zpyro on November 30, 2004, 11:09:30 PM
when they say it'd fit 289-351, it probably means the older, carbed ones.
Post by: Nate on December 01, 2004, 01:26:52 AM
they all fit the cylinder heads, but most were designed for the old school carb guys:p sence nobody uses cfi for proformance :P (at least ford saw the error of its cfi ways and changed to efi, unlike some other car brands) anyway, i have a 1/2 or 3/8 heat spacer on my car and the chrome ford racing valve covers i have off a carbed 302 still dont look like they will fit. maybe i'd go with the 1" ebay has em cheap, like 40 bux and it comes with gaskets and hardware.
p.s.
i know my spelling sux :p
Post by: crystal on December 01, 2004, 10:59:35 AM
Or you could pull one of these for a breather setup:
(http://www.ferdbird.com/87sport/images/engine1.jpg)
And yes, I've cleaned up my engine a lot since then
Post by: cougarman on December 01, 2004, 11:05:07 AM
Here's some pics of my intake with a 1" spacer, clearing the tall valve covers. :ies:  :ies:
Post by: softtouch on December 01, 2004, 04:55:26 PM
Crystal:
Your 7 and 8 plug wires should not be next to each other in the wire separator. One should be in the first slot and the other in the fourth.
These need to be separated as much as possible because in the firing order, 8 fires immediately after 7. If the wires are close and parallel for a long run, the magnetic field around the 7 wire affects the timing of the 8 plug.
