Technical => Audio & Other Aftermarket Electronics => Topic started by: Masejoer on December 16, 2005, 12:35:22 PM
Title: Door speaker size/dimensions
Post by: Masejoer on December 16, 2005, 12:35:22 PM
I just picked up some new 6.5's from the MB Quart DSE 216 package (LINK (http://"http://www.mbquart.de/en/produkte/car/discus/produkt.php?nr=dse_216")), but the things are too big to fit flush in the door. As you can see, the things are a bit bulky from the side. (http://home.comcast.net/~s.g.s/dse216.jpg)
I haven't measured, but placing the speaker in the stock hole, it sticks out probably around 1". What would be the best way to go about installing this thing in there? I can try just drilling new holes and mounting it with some type of spacers, but I don't think the door panel will go back on with the stock grill. I really don't want to cut up the door, making the speaker hole have jagged edges (compared to the folded over edge it has now). I have no problems modifying the stock grill, but from the look of it, the speaker will probably still hit the door panel.
I tried mounting it from the back, but it hits... ummm something... when its almost in position. Too dark out to see what it is, but it can't be moved.
Any tips?
Post by: nirvanagod on December 16, 2005, 01:18:37 PM
Make a spacer ring out of MDF, then mount the ring to the door and the speaker to the ring. As long as your have enough space between the front of the speaker and the speaker grill it should work fine.
Post by: Masejoer on December 16, 2005, 05:12:32 PM
I'm curious, how would you bolt or screw into mdf? It isn't that strong. I can see mounting it to either the speaker or the door, using bolts and nuts, but not both. That may be the way around for the next problem:
I got the speakers "mounted" with zip ties and although they push the door panel out a small amount, the screw in the lower corner helps hold the edges flat. It barely fits behind the panel, but it does. The problem? The drivers side is fine, but the passenger side has a buzzing sound from where the speaker meets the door. Obviously the zip ties aren't holding it snug enough, as pushing the speaker onto the door myself, the buzzing stops. I tried adding a 5th tie, and it seemed to hold well until after I got the entire door back together...and the buzzing continued. Not very bad, but its there when turned up. Making a custom spacer should fix this, and be a better install overall.
On another note, would installing the crossovers (that came with the 6.5's) right after the factory amp help move power to the door? As far as I know, all 6 speakers get the same frequencies. The 3.5's in the dash get bass, although they shouldn't (and they don't really try playing it). Would a noticeable amount of that low end power move to the doors if using the crossovers on the wiring running to the front speakers? I'm just curious if the 3.5's are eating up power they shouldn't although they don't tend to play bass.
They ARE 4 wires hooking into each front channel, right? I'm looking at http://www.foxthundercats.com/tech/wiringdiagrams/8588premiumweq.pdf . So it would be like this: http://home.comcast.net/~s.g.s/cross.jpg
Post by: Masejoer on December 16, 2005, 08:23:08 PM
Here's one for ANYONE who has seen the front speaker wiring. Where does the wiring split into two (4 wires)? I was hoping Ford ran individual wires from the trunk to each speaker, but thats not so. Can't even try out the crossovers if I can't find the split.
Post by: Masejoer on December 17, 2005, 11:01:19 AM
Come on someone, I want to get the cross overs installed before the step family comes later today, to do an early Christmas thing. Just need to know where the front wires split off.
Post by: Tbird232ci on December 17, 2005, 01:39:02 PM
dude, just run your own wiring, thats exactly what i did, i ran a wire through the door tubes, then i fed one down through the dash. Its not easy, its a PITA, but it works very well. My 3.8L bird has all new wiring in it, i didnt use a single bit of the radio harness.
Post by: Masejoer on December 17, 2005, 02:00:51 PM
If I wasn't planning on keeping the stock system, I would. I have no need for better sound in the car, thats what my home system's for. I just hate distortion from the dash speakers playing frequencies they can't handle. That and I don't know much about the impedance. With how Ford wired it up, that'd make the stock amp be pushing only 2 ohms, wouldn't it (all speakers are 4ohm)? Can't be too good for the thing when the stock speakers were a better fit. I figure the crossovers would keep the line 4 ohm, while discarding of the dash distortion.
Post by: nirvanagod on December 17, 2005, 08:36:05 PM
In regards to the mdf spacer ring, it'll handle having speakers screwed into it. It's often what the pro's use when making custom surrounds and enclosures and such. I've even had a friend use it in his car due too the same reason of the speakers being to deep for the speaker wells.
Now as for the having to much distortion on the front speakers there's and easier fix than using the crossover boxes. Take a look around crutchfield.coms website for inline bass blockers. They'll do exactly what you want and are a heck of a lot easier to install. And if you can't afford or wait for them, they can be built very easily. Just takes a little bit of shopping for a few pieces parts at a radioshack.
Post by: Red_LX on December 17, 2005, 08:42:09 PM
You can run screws into MDF, it just helps to drill pilot holes first or the screws tend to split it.
Post by: Masejoer on December 17, 2005, 09:11:25 PM
Quote from: nirvanagod
That still wastes the power going to those speakers and doesn't fix the low ohm problem. I'm guessing no one knows exactly, off the top of their head, where the wires split. For all I know, they may be taped up where it happens. They're somewhere beyond the kick panels though - I looked.
Figured it'd be easier than this to get the crossovers installed, but I guess I was wrong. Even if I find where the wires split, there may be no room for the crossovers. I may still yet just run new wires, if I do pickup an Eclipse amp that is being sold locally. Then again, if the price goes up more than its currently at, it'd be more worthwhile just to throw a new deck in (same power but with more clarity).
Well if anyone knows where those wire connections are, it'd be good to know just for future reference, both for myself and the message board. Thanks for the help guys. ;)
Post by: Masejoer on December 18, 2005, 02:36:38 AM
I'll try to trace the wires on the passenger side tomorrow when it warms up above freezing. If I find it, I'll post my findings. Can never have too much information.
Post by: Masejoer on December 18, 2005, 09:41:32 PM
I tried...and had to stop once it started snowing out there. SO COLD.
The passenger side wiring seems to split off somewhere actually within the dash. Then again, there's 4 larger wires, both the same color, going into the dash speaker's connector. The doors have the dual wiring also, but they're different colors for the different harnesses, I believe. So either the dual harness wiring was done differently for the 2 different speakers, or the door wiring just connects to the dash speaker, which goes to the trunk.
I'm just going to run new wires and get a new receiver, since the amp I was looking at kept jumping in price near the end - more than I was willing to pay to amplify the stock system. 50w rms per channel (4) instead of the...20 or so receivers have. Oh well. Have my eyes on a nice Eclipse being sold 30 miles away. What a coincidence though, the amp was also Eclipse. They seem to make some good products - if going for sound quality.
edit:
Wow, this $300 receiver only puts out 13w rms(50 peak). An improvement over the stock amp, but still such low power
Post by: SLEEPER T-BIRD 87 on December 20, 2005, 10:50:11 PM
the door speaker harness branches off up into the dash speakers.
Post by: Haystack on December 21, 2005, 09:34:36 AM
I think there is a print out of the speaker wiring on thunderchickens site. Lemme check really quick
*edit*
looks to be more complete then last time I saw it
http://www.foxthundercats.com/samscars.htm
Post by: Masejoer on December 21, 2005, 12:13:33 PM
Either way, I got everything working with an Eclipse cd3434. Used a lot of insulated connection terminals and 14 gauge wire to easily add/take away wiring down the road if need be. Ran new wires to the dash speakers, from crossovers, and eventually found the non-premium wiring harness for the rest (which actually went to all 6 speakers, I thought it'd be only 4). It was a PITA to find though. Nowhere seen, but I eventually found 8 wires to follow, which enough yanking on it freed it up from the wire mesh it was caught in somewhere deep in the dash. Crossovers fit behind the heater/ac controls.
The weird thing is that at idle, there's 3.5ohm load on all 6 pairs now, but the crossover to headunit dips to 1.8ohm when its active, one of the rear speakers stays at 3.5ohm when active, and the other tests at 6.8 when active. Power wise, its barely an improvement over Premium, but it sounds clearer, and, well, its a cd/mp3 player instead of cassette. Not bad for $100
Now to find some piece to go around the receiver, to get rid of the gap below the unit and where the console cover starts.
Post by: Masejoer on December 21, 2005, 12:28:34 PM
Can't figure out how to activate ESN...found instructions on how to DEACTIVATE, with the key cd, if need be, but its not on it currently anyways. No reason to let the feature go unused
Post by: ipsd on December 21, 2005, 09:15:18 PM
Sounds to me like you have a Eclipse head unit. As far as I know the ESN is there version of sercurity. Like the removable face plate. Is should always be on. The way it works is when power is lost to the unit you must insert the KEY CD to get the player up and running. That way if you stole it it won't work. So it should be active all times.
Post by: ipsd on December 21, 2005, 09:21:01 PM
Also about the door speakers. You could make your own mounts out of masonite, styrofoam, fiberglass, & you choice of covering. use the wood for the solid mount and the foam to add contour. Next cover the whole thing in fiberglass the kind with the fiber in it. then cover it how ever you want. I built mine in about 2 hours not including the dry time. Here is pic without the grill on there. http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=4749&stc=1&d=1133630840
Post by: Masejoer on December 22, 2005, 01:07:30 AM
oh, I know what ESN does, just not how to enable it. Its some button combination, but I don't know which. Can't find anything on ANY of their decks, on enabling it.
Post by: Masejoer on December 22, 2005, 02:22:41 PM
How to program CD:
1. Make sure power is off
2. Press and hold button [6], then the [FUNC] button- hold both for 1 sec
A [SEC] MESSAGE APPEARS, THEN IN 2 SECS it will change to [DISC]
The front panel opens: its ready to receive your key CD
3. Insert Key CD
Front panel closes
A [SEC] message appears, front panel opens, and KEY CD is ejected
How to cancel the Key CD:
1. Turn OFF the power
2. Press and hold button [6], then the [FUNC] button, and hold both for more than one second.
A [SEC] message appears, then it two seconds it will change to [DISC]
The front panel opens; the cd8051 is now ready to accept your Key CD in the CD slot.
3. Insert your Key CD into the slot.
The front panel closes.
A [CANCEL] message appears, the front panel opens, then the key CD is ejected.
The Key CD is cancelled.
*ATTENTION*
- This process cancels the protection for the ESN deck.
- If power to the ESN deck is disconnected, then reconnected, a Key CD will not need to be inserted in order to return the unit to normal operation.
-Inserting a CD other than the Key CD will not cancel the protection. Instead, the display will show [ERR] for two seconds, then the normal CD playback mode will activate."
Eclipse 800 # is 800-233-2216
Tested it and it works
Post by: CougarSE on December 24, 2005, 10:54:30 PM
Wow good info there.  Like Shawn I ran my own wires in my car.  The inbread sob that had my car before me cut the wires in the dash as well as the wires on the rear deck, and my car doesn't have premium sound or an EQ!  I go the factory repair harness from best buy and hooked the power side back up like it was soposed to be but on the speaker side instead of routing back to the factory harness I ran all new 12 gauge wire to all the speakers.  So If I wan't I can plug a factory stereo back in and it will work like it should.  Sounds very nice like this.
Post by: firefighter25550 on February 16, 2006, 09:14:23 PM
When I changed my door speakers I used 6" x 8" Pioneer speakers. They mounted in place of the originals w/ no mods needed....or at least they did on my Cougar. You didn't even know the new speakers were there until the music started. Hope this helps you some.
Post by: Masejoer on February 21, 2006, 11:40:43 AM
6x8's in the doors? I wish. My Component MBQuart 6.5's don't really fit in the stock holes. Either way, I found that 6.5 is too small (in open air) to be effective in the lower doors - in comparision to what the rear deck can do with Infinity 6x9's. I had to adjust the crossover to prevent them from playing deep bass since they'd distort at higher volume levels...after a certain point, the magnet would be overwhelmed and the driver would fly outward extremely far before bouncing back.
Post by: MFrank on February 23, 2006, 02:34:07 AM
What is the stock door speaker size?
