Technical => Drivetrain Tech => Topic started by: lowcat on November 21, 2004, 02:07:11 PM
Title: Doh!
Post by: lowcat on November 21, 2004, 02:07:11 PM
The other day my rear axle developed a whining sound. So I ask my Dad, who is a mechanic, what it could be since I do not know much about the rear axle except that it is a 7.5 inch ring gear and the ratio is 3.27. Anyway he determined that it was the carrier bearings that were making the noise. We started the teardown on Saturday morning and stopped when I had to go to work. So we went to finish it today and almost had the carrier housing back in when the carrier shim broke! :brick: . Now I have to wait until Monday so I can go to the Ford dealer to get a new shim. On top of that when we tried to remove the passenger side axle bearing it came apart and left the outer part stuck in the axle housing. But we eventually beat it out.  Not that long ago we replaced the u-joints and pinion seal. If one more thing breaks I'm gonna do this to my car :macgun:
Title: Re: Doh!
Post by: Ifixyawata on November 21, 2004, 06:15:10 PM
Mine has had a whine since I bought it.  I'm just holding out for an 8.8"
Title: Re: Doh!
Post by: Masejoer on November 21, 2004, 06:33:02 PM
Quote from: Ifixyawata
wait, it isn't supposed to? :giggle:
Title: Re: Doh!
Post by: Tbird232ci on November 21, 2004, 07:40:34 PM
mine whines too, i just say its the supercharger
Title: Re: Doh!
Post by: Ether947 on November 22, 2004, 12:41:31 AM
i thought rear-ends were supposed to whine a little bit? i used royal purple and it cut down the whine. My buddy's Mustang 8.8 whines a lot more than my 7.5... which didn't whine until i got traction lok. *shrugs* then again... i've never had quiet exhaust on this car either.
Title: Re: Doh!
Post by: Ifixyawata on November 22, 2004, 12:55:29 AM
My rear-end whines like droning... that's all you can hear-whine. It's the kind of whine that changes depending on which way you're turning. Plus it's got massive amounts of play-clunk. I could live with the whine (I can't even hear it over my exhaust anyway) if not for the large amounts of play. I just need an 8.8" really bad, that's all.  Traction-lok, 3.55 or so gears.
Title: Re: Doh!
Post by: lowcat on November 22, 2004, 10:51:39 AM
It never used to whine until about a week ago. At first you could bearly hear it then it got so bad that i had to turn up my radio halfway to drone it out.
Title: Re: Doh!
Post by: lowcat on November 22, 2004, 02:40:15 PM
So I go to the Ford Dealer today to see about the shim and they told me I need to measure it first and then they have to special order it. They wouldn't even measure it for me or look for the specifications. I am so tired of dealing with people. :flip: And the other day when I went to Advance auto to get an EGR vacuum solenoid they told my my car didn't have one. It even showed up on the computer screen but he was like they don't make one for your car. WTF! I wasn't going to argue with him because I wasn't too sure exactly what it was in the first place.
Title: Re: Doh!
Post by: MasterBlaster on November 23, 2004, 08:35:18 AM
What's the engine code in your VIN (digit #8?)?
Advance uses http://www.partsamerica.com for their online buying, and they show nothing for VIN 4, but 6 choices for VIN 3.
Title: Re: Doh!
Post by: lowcat on November 23, 2004, 10:34:19 AM
Its a 3. The guy probably selected the other choice for engines when he looked for the part. :slap:
Title: Re: Doh!
Post by: V8Demon on November 23, 2004, 12:41:44 PM
Lowcat,
Is it me or does your axle have a slight bend to it?  It looks that way inthe picture, however nothing looks like its cracked or wrinkled or anything like that
Title: Re: Doh!
Post by: lowcat on November 23, 2004, 05:30:46 PM
I think it is just the picture. I was laying on the creeper when I took it. I don't have any alignment problems or any vibrations. If it was bent I would imagine it would vibrate like crazy.
Title: Re: Doh!
Post by: lowcat on November 24, 2004, 05:34:01 PM
Well I got it all back together today and everything is in good working order. And no more whining sound! :banana: At least I got to drive my brothers 92 Cougar 3.8 while mine was being fixed. That extra 20 hp and 40 ft/lbs of torque really makes a difference. After driving that for a few days I realize that my car is the slowest thing I have ever driven. No wait I drove my friends 3 cyl geo metro once :slap:  but my car is definatly the second slowest car I have ever driven. :shakehead
