Technical => Body/Appearance/Interior => Topic started by: fordman3 on June 05, 2018, 11:50:01 PM
Title: Power Antenna
Post by: fordman3 on June 05, 2018, 11:50:01 PM
I found a power antenna in the shed I forgot I had.  If I installed it, is the wiring in the dash to hook it up, if I also installed the switch?  Anybody have a power antenna switch for sale?  Thanks.
Post by: 50RACER on June 06, 2018, 06:00:30 PM
The switch has the wiring for the antenna attached to it. I have some of the switches as well. I'll ship you one for $40.
Post by: fordman3 on June 06, 2018, 06:49:01 PM
50RACER,
Where does the switch get its power from?  Is the connection for it already there in the dash?  Thanks for your offer.  I'll let you know when I might be able to buy it.  Thanks.
Post by: 50RACER on June 06, 2018, 10:35:17 PM
X  The red and green wire that are together go to the antenna. The two black wires that are in the same connector, I believe, are the ones that power the switch and they plug into  another connector in the area around the back of the radio that is part of the much larger dash / fuse panel harness. You probably have to pull out the radio to locate it.
Post by: softtouch on June 07, 2018, 11:31:31 AM
In the 86 EVTM, looks like the yellow/black stripe and black wires in connector C303 are the power and ground to the switch.
