General => Lounge => Topic started by: Moonmount on August 10, 2017, 03:24:34 PM
Title: Weighed my car
Post by: Moonmount on August 10, 2017, 03:24:34 PM
It weighs 3,285 no driver and 5 gallons of gas 5.0 car no smog no trunk interior full dual exhaust
Post by: grutinator on August 10, 2017, 08:19:02 PM
wow, that seems really light! what year car? is it low optioned?
Post by: Moonmount on August 11, 2017, 03:24:58 AM
Quote from: grutinator;462113
1988 cougar 262A package with keyless entry, 5.0, and dual exhaust even down to the color options is exactly how i would have optioned the car if i was around in 1988
Post by: thunderjet302 on August 11, 2017, 10:19:39 AM
Seems pretty light. My 88 Thunderbird LX with every option but a sunroof, full tank of gas, aluminum headed 5.0, aluminum driveshaft, and 8.8 rear axle comes in around 3550lbs.
Dual power seats are heavy :hick:
Post by: Moonmount on August 11, 2017, 10:47:58 AM
Quote from: thunderjet302;462118
you had about 109 pounds of gas more in your tank dont feel too bad ;)
Post by: thunderjet302 on August 11, 2017, 10:50:50 AM
Yeah but still 165lbs more stuff. With iron heads and a steel driveshaft it would be even more.
On the other hand with me in the car it's about 3710lbs, so about what a Coyote Mustang weighs.
Post by: deathbypsi on August 11, 2017, 01:41:24 PM
my 83 is 3288 before i get in it.
Post by: Loaded87IROC on August 11, 2017, 10:36:27 PM
My 86 weighs 2920 but I've done some weight reduction.
Post by: Moonmount on August 12, 2017, 03:13:05 AM
It surprises me how comparably light these cars are
Post by: Moonmount on August 12, 2017, 03:15:26 AM
Quote from: thunderjet302;462121
How much do power seats weigh in these cars?
Post by: Haystack on August 13, 2017, 03:35:34 AM
A ton... the doors are super heavy too.
Post by: Cougar5.0 on August 13, 2017, 02:03:47 PM
Mine is 3630 with me in it (180). I need to reduce weight cuz it's gonna be a drag-race car once I drop in the 427W I'm finishing up. Does anybody know the weight of the power leather/suede seats in the 20th Anny? I know I could barely lift one out of the car. :hick:
Post by: thunderjet302 on August 14, 2017, 03:49:54 PM
Quote from: Cougar5.0;462161
Was that with a TKO? Our cars are equipped pretty much the same from the factory and mine is 3710 with me (160lbs). So subtract 180 for you and your 20th is 3450lbs, my LX is 3550. maybe the AOD adds 100lbs?
Post by: Moonmount on August 14, 2017, 04:11:45 PM
Quote from: thunderjet302;462176
aod weighs about 160lbs dry and a t5 weighs 72lbs dry add about 24lb of fluid for the aod and about 6lbs of fluid for a t5
Post by: Cougar5.0 on August 14, 2017, 04:52:59 PM
I know the AOD is heavy, but not 100lb more than TKO500. I have eliminated all AC components, not much else though.
Post by: Moonmount on August 14, 2017, 04:57:56 PM
Quote from: Cougar5.0;462182
TKO500 weighs 105lbs dry and with fluid 112lbs. The AOD with fluid probably weighs about 75lbs more.
Post by: thunderjet302 on August 14, 2017, 07:57:15 PM
Well AOD + A/C might explain the 100lb difference.
Post by: Cougar5.0 on August 30, 2017, 10:54:03 PM
Quote from: Moonmount;462138
I weighed a power drivers seat this weekend - 66 lbs!
So dual power seats total about 130 lbs. And mine don't even work properly.
Post by: Haystack on August 31, 2017, 03:19:11 AM
I know i could easily lift the t-5 over my head if i had to, my aod i could hardly to mcdonalds dumpster by myself.
Post by: Moonmount on September 21, 2017, 10:12:50 PM
Quote from: Cougar5.0;462460
jeez 66lbs each man i wish i had a manual drivers seat
Post by: Cougar5.0 on September 22, 2017, 09:40:41 AM
Quote from: Moonmount;462852
I have dual power seats ~4% of the car's weight is in the seats!
Post by: thunderjet302 on September 22, 2017, 04:32:14 PM
That should be with power recline as well. My Thunderbird (and I assume your 20th) has power recline, which adds a bit more weight.
At least my car's seats work...makes it worth the weight penalty.
Post by: Cougar5.0 on September 22, 2017, 07:23:31 PM
Quote from: thunderjet302;462872
Yes, power everything, including recline. Memory function and the seat is also heated. Yeah, of course the passenger works fine cuz it's never been used, the driver's side need coaching to move the seat forward/back and up/down in front or back, I forget.
Post by: thunderjet302 on September 22, 2017, 07:34:15 PM
I do have a spare functional power seat track for the driver side. It's heavy, so it would probably cost $$$ to ship.
Post by: Cougar5.0 on September 22, 2017, 07:54:52 PM
Quote from: thunderjet302;462881
Thanks. I actually have a spare set of 20th seats in the garage. At this point I'm looking to lose weight for drag racing, might look at the spares for ideas to make them lighter.
Post by: thunderjet302 on September 23, 2017, 10:53:56 PM
Just checking. Good luck on making them lighter.
Post by: Haystack on September 24, 2017, 04:45:49 AM
Manual seat track would be a good start.
