Morning,
Does anyone know where can I get the correct mirror for the drivers side of an 84 Thunderbird?
The mustang mirrors look the same not sure if they fit though.This is the second one I have to replace , first time I got lucky and found one used (after several attempts at "new"on line purchases, they were not even close to being correct)
thanks for your help
Sounds like you just need the mirror glass, not the whole assembly?
If so maybe this will work. http://burcoinc.com/redi-cuts-catalog/
I use this site at the shop to look up mirrors and purchase them.
The mustang mirrors do not fit. You might be able to make them, but the bolt holes are different.
A bunch of people use to do the tempo mirrors using the write up on coolcats.net, but I'll bet tempos are getting kinda rare now too.
If you really need them, I can get a used set. The 87- 88 mirrors are also the same, they just have a "w8nd splitter" on them. There are also chrome or body colored mirrors, depending on the year.
Thanks... I need the whole assembly. I was away for the weekend to come home to the mirror hanging by the wire. Either hit and run or some kid might of just kicked it or something
You can use car-part.com and start calling up junkyards its what i do to get parts for these cars
