Technical => Suspension/Steering => Topic started by: 20thanvcat on April 04, 2017, 09:41:06 PM
Title: performance steering gear
Post by: 20thanvcat on April 04, 2017, 09:41:06 PM
Has anyone swapped a stock rack and pinion with performance rack and pinion - i think the tbird package "FILA" had a performance gear (tighter turning faster responce) ?
Post by: Loaded87IROC on April 04, 2017, 10:58:39 PM
It's a pretty common swap.  I've done it.
http://www.coolcats.net/modifying/steeringrack.html
Post by: thunderjet302 on April 06, 2017, 12:35:31 PM
87-93 Mustang GT rack works fine (that's what I've got in my Thunderbird). I reused the stock pump without issue.
Post by: Aerocoupe on April 06, 2017, 04:09:23 PM
SN95 rack, Fox inner and outer tie-rods, and Maximum Motorsports hybrid steering shaft with the stock pump.  I have this setup on both the Coupe and the Bird and the steering response is much better than the over boosted Fox rack.  Not cheap but I was tired of the lack of feed back from the over boosted Fox system.
Post by: Haystack on April 08, 2017, 06:34:59 PM
Fila this were nothing fancy. Basically equivalent to an lx model, which could be optioned any number of ways.
