Technical => Body/Appearance/Interior => Topic started by: thunderjet302 on February 26, 2017, 04:12:09 PM
Title: Mark VII headliner, fit an 87-88 Thunderbird?
Post by: thunderjet302 on February 26, 2017, 04:12:09 PM
Does anyone happen to know if a Mark VII headliner will fit in an 87-88 Thunderbird? I have a plan to eventually install a Mark VII overhead console into my Thunderbird. I'd like to swap the Mark VII headliner in instead of cutting the stock Thunderbird headliner up to accommodate the Mark VII overhead console.
Post by: thunderjet302 on February 27, 2017, 02:05:29 PM
Apparently I should have measured the Mark VII I owned before I sold it :hick:.
Post by: TurboCoupe50 on February 27, 2017, 04:10:47 PM
The MK VII is around three inches longer than a T-Bird with at least part of that being added leg room for rear passengers... I'd say chances the headliner would swap are practically zero...
Post by: thunderjet302 on February 27, 2017, 04:53:38 PM
I figured as much. I'll probably have to try and find an 87-88 Thunderbird headliner and modify it.
