Technical => Drivetrain Tech => Topic started by: flipnbird on September 22, 2016, 08:38:57 AM
Title: clutch pedal
Post by: flipnbird on September 22, 2016, 08:38:57 AM
Morning Guys,.....88 turbocoupe and would like to know if there is a way to change the height of the clutch pedal related to the brake pedal? The clutch pedal seems like almost an inch higher. Seems like I read a post a few years back about this but done a search and went through a couple hundred threads but no luck.
Thanks in advance, Joe
Title: clutch pedal
Post by: QUICKSHIFT on September 22, 2016, 09:51:05 AM
I did it the redneck way. I took off the pedal, put it in a vice, put a 2"pipe over the shaft and bent it to where I was happy with it. It took only one time.
Title: clutch pedal
Post by: Aerocoupe on September 23, 2016, 12:20:29 PM
This seems to work really well and I know a couple of guys that run it in racing conditions, only drawback is that you will need either an adjustable clutch cable and/or aftermarket clutch quadrant.  I have both of these on both of my cars along with the firewall adjuster.  For me they are necessary versus nice to have as the stock quadrant is junk and I like having the adjustability as the cables stretch over time and the clutch wears.
http://www.maximummotorsports.com/Clutch-Pedal-Height-Adjuster-1982-93-P501.aspx
Title: clutch pedal
Post by: QUICKSHIFT on September 24, 2016, 10:36:47 AM
Thanks, I forgot to add that. I run a quick release quadrant with a firewall adjuster and OEM cable. The thing to watch for is that you have to push the pedal further by just bending the arm which takes some getting use to.....unless you're over 6ft tall...lol.
Title: clutch pedal
Post by: BornInAFord on September 24, 2016, 03:42:17 PM
Would the adjustable quadrant be for a cable clutch?  The turbo coupe is hydraulic, so if for cable (like the Mustang), would it be worth swapping a working hydraulic clutch system for a cable clutch?  Just curious.
