Technical => Drivetrain Tech => Topic started by: QUICKSHIFT on April 03, 2016, 07:42:08 PM
Title: Fox Mustang vs Fox Cougar/Thunderbird quad shock axle bracket.
Post by: QUICKSHIFT on April 03, 2016, 07:42:08 PM
Is the axle bracket that the quad shocks bolt to any different between the Mustang and Cougar/Thunderbird axle? I thought I read somewhere that the Cougar/Thunderbird bracket is approx 2" taller. The reason I ask is ,I did the 7.5 to 8" swap using a Mustang rear along with the frame brackets for the quad shocks years ago and just wondering. In all reality, if there is a difference, the car is lowered approx 1 1/2" so it shouldn't make a difference.  :dunno:
Post by: Haystack on April 03, 2016, 09:46:55 PM
I know guys run  mustang axles with quad shocks all the time. I don't think there is anything different.
Post by: Beau on April 04, 2016, 02:06:08 AM
The bracket on the rear ends are the same, on the subframe of the cars themselves, they ARE different.
Post by: vinnietbird on April 04, 2016, 07:23:49 AM
Yep, as Beau said, they are different for the chassis mounts. I had bought a set of Stang mounts years ago planning on installing quad shocks.....nope. Had to search for the chassis mounts. Back then, parts were a LOT easier to find.
Post by: Aerocoupe on April 04, 2016, 10:18:57 AM
They are different but if you are concerned with performance the best thing to do it unbolt them and toss them in the recycle bin.  The quad shocks are a band aid for the poor control arm design on these cars.  Put a good set of control arms on the car and the need for them is eliminated.  Now if you are trying to keep the car stock then I completely understand keeping them.
Post by: V8Demon on April 04, 2016, 01:43:04 PM
http://www.foxtbirdcougarforums.com/showthread.php?21537-Quad-Shocks-for-a-7-5-quot&p=242302#post242302
E5SZ-4A490-A (driver side)
E5SZ-4A491-A (passenger side)
Post by: thunderjet302 on April 04, 2016, 01:53:02 PM
Quote from: QUICKSHIFT;454632
Does this picture help?
(http://i198.photobucket.com/albums/aa33/thunderjet302/Mobile%20Uploads/control%20arm%20driver%20_zpshxcszfil.jpg) (http://s198.photobucket.com/user/thunderjet302/media/Mobile%20Uploads/control%20arm%20driver%20_zpshxcszfil.jpg.html)
Post by: jpc647 on April 05, 2016, 11:28:28 AM
I've got a set of bird/cougar shock mounts, with shocks if needed for sale.
