Technical => Drivetrain Tech => Topic started by: 87tbird_org_owner on November 10, 2015, 02:28:06 AM
Title: Left Rear Tire Traction Problem
Post by: 87tbird_org_owner on November 10, 2015, 02:28:06 AM
There is a problem with the left rear tire loosing traction when making a left turn with my 87 T-Bird. The tires 215/70/14 are new and the car has the trac-lok differential. There is no traction loss when making right turns. Where should I start looking to correct this problem?
Post by: TurboCoupe50 on November 10, 2015, 08:50:19 AM
Quote from: 87tbird_org_owner;452139
Inside the differential...
Post by: thunderjet302 on November 10, 2015, 12:20:57 PM
What exactly do you mean by "loosing traction"? A non-functioning Traction-Lok should work just like an open differential.
Post by: 87tbird_org_owner on November 10, 2015, 04:22:35 PM
Quote from: thunderjet302;452148
On any pavement surface I can here the left tire start to spin mid-way thru a left turn for a few seconds. Then as I straighten the car out in to the roadway lanes the tire traction returns. Something else I remember, the left tire will also spin for a few seconds at the start of a hard straight line launch. This is the totally stock V8 engine and rear end.
Post by: mo2872 on November 10, 2015, 05:07:19 PM
How's the tread on the left rear tire..........?
Post by: vinnietbird on November 10, 2015, 06:31:35 PM
Yeah, I was going to ask about tread as well. I'm pretty sure it's not a "too much power" issue.
Is it a Sport model> Floor shifted 5.0? Does it have 4 rear shocks, 2 up and down, and two front to back? If so, it may be a 7.5 traction lock rear (2.73 gears)....perhaps something is wrong with it. Otherwise.....I'm not sure yet.
Post by: 87tbird_org_owner on November 10, 2015, 10:37:45 PM
Just purchased Hankook tires in September 2015. Yes the Sport model came stock with the Quad Shock setup like the Mustang but with the 2.73 ratio.
Post by: mo2872 on November 11, 2015, 09:13:03 AM
Whoops, missed the "tires are new" part.  Reading comprehension 101, here I come........again......LOL.
Post by: CoogarXR on November 11, 2015, 11:23:33 AM
In a left turn, centrifical force causes the weight to shift outward (to the right). If this is excessive, it can take much of the weight off the left-rear. So how's the ol' suspension? Got a lot of body roll, saggy front suspension, etc?
I used to exploit this when I was a teenager and had cars that were too weak to do burnouts. Slam on the brakes so the front end would dip, taking the weight off the rear, then mash the gas. Or, if it was a one-wheel peeler, cut a hard right corner so the weight would come off the right-rear, lol.
Post by: thunderjet302 on November 11, 2015, 12:00:39 PM
Well depending on how much throttle you're giving the engine you may just be breaking the left tire loose because it has less traction. A worn out Traction-Lok will work just like an open differential letting the tire with less traction spin.
As a side note when my Thunderbird was completely stock with a 2.73 open rear it would spin the tire pretty easily. Yes just one tire....
Post by: TurboCoupe50 on November 12, 2015, 10:56:07 AM
See my 1st post... Not much doubt, the T-L unit is worn out...
Post by: Kitz Kat on November 15, 2015, 10:25:22 AM
Quote from: TurboCoupe50;452186
A pretty easy fix, lots of write ups on it.
