Technical => Body/Appearance/Interior => Topic started by: TheCowboyKiller on November 27, 2014, 10:34:18 AM
Title: Swapping faces
Post by: TheCowboyKiller on November 27, 2014, 10:34:18 AM
Hey guys,
I'm interested in swapping the aero face on my 87 to the 83-86 four eye face. I already have an 85 as a donor. Is this a straight forward procedure?
Thanks and happy thanksgiving!
Post by: Haystack on November 27, 2014, 12:29:12 PM
The actual headlight wiring is different. I believe the switch and inside wiring is the same. I haven't done this myself, but i would assume you just splice the 4eyed headlights harness into your existing one.
A relay mod for the headlights will help your switch work longer. The headlights power runs through the ignition switch and headlights switch.
Post by: Aerocoupe on November 27, 2014, 02:37:48 PM
Here is how one member did it:
http://www.foxtbirdcougarforums.com/showthread.php?29366-The-CP-autox-bird
Darren
