any one have pics for under the drivers side dash i removed a black box with with 9 pin wires need a picture of it
Can you take a pic of the box and post it so we can see?
i need the color codes on the wire
Pretty sure that is connected to the cruise control.
thats the seat belt, warning chime moduel..
If you could post a picture that clearly shows the Ford part number that would help immensely.
Darren
the part # is e7db-10d840-aa
Zenith was correct. I just googled the part number and it comes up as the seat belt warning chime module.
idid the same it fits f150 in the 90s
will my seat belt lock still our it wont work
It supposedly also fits a few other vehicles. I know from working on Fords over the years they would use the same part on several different models covering several years.
Yes your seat belt will still lock, you just wont have a warning light on the instrument cluster. The seat belt locking mechanism is built into the belt ratchet asy behind the B-pillar where the shoulder harness goes.
