Technical => Drivetrain Tech => Topic started by: 4EyedCoug on September 28, 2013, 09:09:09 AM
Title: Column to floor shifter
Post by: 4EyedCoug on September 28, 2013, 09:09:09 AM
Hey guys. I plan on doing a column to floor shifter swap on my 86 Cougar but don't really know how I would go about doing it. What would be the easiest and less pricey way of doing this? Thanks!
Post by: vinnietbird on September 28, 2013, 09:45:31 AM
You really need to find somebody here using the classifieds that has the unique parts needed to do it right.....
-console (with associated mounting hardware, shifter bezel, control panel0
-shifter assembly and cable (unique to these cars)
-cable mount bracket (goes on transmission)
-transmission shifter arm
These came stock on the Sport model Birds and some V-8 Cougars as well.
You see them pop up from time to time.
Another option is always something like a B&M ratchet shifter if you like a big ass ugly shifter bolted to your floor.
Post by: 4EyedCoug on September 28, 2013, 10:29:20 AM
Lets say I was to go with an aftermarket shifter. What all would I need then? My car has a full console it just has a tray to hold stuff where the shifter would be.
Post by: vinnietbird on September 28, 2013, 10:58:28 AM
Well, it's hard to fit an aftermarket in that small area. I'd recommend being patient and getting stock pieces. You will have a to cut a hole on the floor, then a factory shifter bezel will swap right on to the console. The Turbo Coupe shifter won't work. They are different although they look about the same.
Post by: 4EyedCoug on September 28, 2013, 10:06:54 PM
If I was to find a mustang at the local junkyard could I get all that i need from right there, besides the shifter bezel?
Post by: Haystack on September 28, 2013, 11:28:03 PM
mustang ones are different.
Post by: vinnietbird on September 29, 2013, 12:09:42 AM
Yep. Our cars require specific parts.
Post by: cougarman on September 29, 2013, 08:10:36 AM
Do you have an aod or a c4 trans?  If you go with a b&m shifter get one for a mustang with the same trans you have. If you have an aod they have a lever kit you have to get also.
Post by: 4EyedCoug on September 29, 2013, 08:32:17 AM
So you're telling me that if I buy a aftermarket shifter like the B&M ratchet one Ill have all the parts to do the install except the bezel?
Post by: cougarman on September 29, 2013, 08:36:08 AM
yes, they do come with a universal bezal but just so you know, you will have to modify your console for it to fit. usually you end up losing the ashtray in the console.
Post by: 4EyedCoug on September 29, 2013, 08:41:22 AM
Who uses the ash tray anyway? So a kit like this will work? http://bmracing.com/?wpsc-product=console-hammer-87-93-mustang-console-with-aod
Post by: cougarman on September 29, 2013, 08:42:03 AM
http://www.summitracing.com/parts/bmm-81002/overview/year/1993/make/ford/model/mustang
Post by: 4EyedCoug on September 29, 2013, 08:44:11 AM
Sweet. Thank you!
Post by: cougarman on September 29, 2013, 08:49:40 AM
welcome
