Technical => Engine Tech => Topic started by: jcassity on August 29, 2013, 10:06:25 PM
Title: explorer coolant tube lines along intake vs fox coolant lines
Post by: jcassity on August 29, 2013, 10:06:25 PM
very compatable if you ask me,, alternate resource would be the explorer if required.
not really sure how laying the coolant temp sensor horizontal would effect our dizzy though, it should clear fine.
Post by: jcassity on August 30, 2013, 10:28:13 AM
i also like how the explorer lines sweep at the rear, makes for a much simpler interface to the heater core.,, none of those "S" shaped hoses
Post by: Dougy_Fresh on August 30, 2013, 05:05:17 PM
temp sensor being like that would also make it easier to hide the wires if you were doing a wire tuck
Post by: beast50 on August 31, 2013, 05:20:06 AM
I would think if you use the explorer heater hose rail that you would have to use the explorer fuel supply lines with it.  That sensor dips down close to where you hook up the supply and returns on the foxbody fuel rail, doesn't it?
Post by: jcassity on August 31, 2013, 10:50:18 AM
the fox fuel supply and return are above the heater tubing and connections.
