Ive noticed that all BBK long tubes for the fox body with a 351w swap are for "T-5 manual trans only"
Im guessing this is because the headers dont clear the trans kick-down and column shift linkage?
So does anyone know if they will work with my C-4 auto since i dont have any of the trans kick down linkage and have converted it to a floor shift with a hurst cable shifter?
Its probably more related to the AOD wider bell housing. You might be OK with you basic Mustang setup. I would ask on a mustang forum....
Good luck,
Travis
