I need a new motor for my Taurus 2 speed fan but do not know what year the fan is from. I remember there was a thread that has mentioned part numbers and years. I believe Vinnie had done the research. Can anyone help?
I went to Autozone and got a motor, but it wasn't the right one, so I took it back, and all of their motors were wrong. It ended up costing me less to just run to the salvage yard and get a whole assembly.
If your fan is a two speed unit...then its probably a 92-95 not sure if there is a difference between 3.0 or 3.8
Travis
2 speed fan and may be from 92. Here are the numbers off it:
Fan assy: F2DE-??607-AB drilled a mounting hole through the part number
Fan motor: F20U-8K621-BA Siemens FTS 1004 Q
Fan shroud: F1DE-8146-BA
Fan blade: F1DE-8600-BA
I haven't found a lot of info or replacement parts in my searching. Just put the car back on the road after being parked for 2 years. Fan went back just before being parked.
