General => General Fox T-Bird/Cougar Discussion => Topic started by: tbirdscott on April 14, 2013, 08:59:21 PM
Title: Ignition switch removal 88 TC
Post by: tbirdscott on April 14, 2013, 08:59:21 PM
So say a guy ends up with an 88 TC with half a key. can I get one made from the door lock or do I have to take the whole steering column in to the locksmith. Also how would a person forcibly remove the switch without a key. Can I just drill out the locking pin and remove it? Would really like to try and start it today.
Scott
Post by: TurboCoupe50 on April 14, 2013, 10:33:34 PM
The lock(not switch, that's the  rectangular part with wires on it down on the column) must be in the on or acc(I forget which) position to remove... If you can't move it from the lock position, AFAIK you'll have to drill it out... Meaning drill down through the key opening till the tumblers are destroyed and it can be unlocked... There is a locking plate that the assembly fits through that makes the lock impossible to remove unless it's in the on or in acc position(again I forget which)...
Your only choice is take the whole column to a locksmith or have them make a service call...
BTW can't make a key from door as those locks don't have as many tumblers in them as the ign lock...
Post by: tbirdscott on April 14, 2013, 10:58:31 PM
Thats what I figured about the door lock. Guess I will pull the column.
Where is the fuel pump relay located? I want to power it up and see what happens.
Post by: Haystack on April 14, 2013, 11:35:42 PM
its behind the back seat near the trunk hinge area passenger side.
pull the Colum and take it to the lock smith. I did this with a junkyars colum sans key, $20, bitterly seconds and it was done.
