When I bought my TC (BLKBRD) a couple of years ago it had a 3" crack that ran along the top of the cast-iron turbo exhaust elbow. Since the car already had a 3" down-pipe, and 2 1/2" dual catless exhaust to the rear bumper I wanted to do a more complete breathing fix when I repaired it.
I had a 3" steel tubing elbow fabricated and then a mechanic friend who is also a fabricator installed it. He cut pieces from a mandrel bent U and made two 45º bend pipes and used a flex pipe from Stinger to complete the installation. Below are the pics of the process:
Steel elbow & new oxygen sensor installed
(http://i1085.photobucket.com/albums/j430/ronelias/New3quotelbowcropped_zps574fbd14.jpg)
Flex pipe & first 45º piece installed
(http://i1085.photobucket.com/albums/j430/ronelias/Newelbowampflexpipecropped_zps273f0249.jpg)
Buttoned up tight with the second 45º piece & a Stinger Clamp
(http://i1085.photobucket.com/albums/j430/ronelias/Exhaust45ordmbendampclampcropped_zps5fcb8fe1.jpg)
Looks nice. Should flow pretty good.
Thats a good fab and should work just fine!!
For those interested, that IHI down elbow is a new build unit, not built using an old elbow. New laser cut , and aluminized mandrel bent elbow. Fabrication included the proper cut for the additional material to allow the flow from the wastegate port to enter the main tube. I wish I had remembered to take pics before I shipped it.
John, if I had known you wanted pics of it I could have snapped them prior to installation. It is a beautiful piece of work.......thanks
Ron
