Dont want to sell but need the room for other cars .
1987 Ford Thunderbird with a 460 . Runs 11.50's at the track and is street legal , Bird has power windows power mirrors power moon roof
power drivers seat and power locks . Has about 1400 miles on her since built . I need to make room for my other cars that is why I am selling it .
there is nothing wrong with it . This car is very fast and is built with the best of everything one head turner . Car has no heat no ac and no radio .
$13500 OBO NO TRADES only CASH OFFERS
call Bob at 240-329-7835 serious inquieries only please
There is over $25000 in her build and I have almost all of the reicipts
sold as is with no warranty
>>>Engine: Over $12,000 invested.
>>> 460ci block bored .030 over Cast crank cut 10/10.
>>> TRW-Power Forged Pistons part # L2443NF30 .030 over bore .400 dome
>>> removed, balanced. Compression about 11.5:1
>>> Eagle H-Beam 4340 steel rods, length is 6.605 weight 840g x-rayed,
>>> sonic tested, magnafluxed with ARP 7-16" cap screw bolts.
>>> Floating wrist pin
>>> Hamburg Rollmaster Adjustable Timing Chain Set: CNC machined high
>>> tensile steel sprocket. Double roller adjustable in 2degree
>>> increments from Zero to 8degrees for both advance & retard.
>>> Manley: High volume oil pump
>>> All ARP Bolts.
>>> Ford Motorsports Hydraulic Cam Shaft: Part #M-6250-C460. Lift: int.
>>> 595 exh.621 Duration: intake 310 exhaust 320
>>> Ford Cobra Jet Aluminum Cylinder Heads: #M6049A429
>>> the older style. Ford motorsports: Aluminum 1.73:1 stud mounted
>>> needle roller bearings rocker arm. Hardened rockerarm studs &
>>> guide plates. Hardened pushrods. Double valve springs w/damper.
>>> Steel retainer 10deg. 11/32 valve locks 10deg. Teflon valve stem
>>> seals 11/32.
>>> Manley Severe duty 1.76" exhaust valve.
>>> Manley Severe duty 2.25 Intake valve.
>>> Holley 4500 Dominator 1050 cfm Carburator. Built and calibrated by
>>> "PRO SYSTEMS"
>>> Weiand Aluminum Water pump.
>>> ATI Super Damper.
>>> Ford Power Parts Cobra Jet Aluminum Intake & valve covers.
>>> MSD Ford Billet Distributor # 8580 Adjustable mechanical advance'
>>> MSD 6AL Ignition.
>>> MSD Blaster 2 Iginiton Coil.
>>> MSD 8mm Super Conductor Wires.
>>> Moroso Crankcase Evac System.
>>> March Performance Aluminum Pullies:Waterpump, Crank,& Alternator.
>>> Blue Powdercoated.
>>> Total Performance: Headers, jethot coated. Multi piece headers.
>>> 3/8" Aluminum polished engine plate with welded in brackets.
>>> Canton 7qt. oil pan.
>>> K&N Air Filter
>>> Ford Motorsport: Hightork Mini Starter.
>>> BODY EQUIPMENT: All Aeroquip fuel & brake lines.
>>> Steel Braided Fuel lines: -10 from tank to filter to pump, -8 line
>>> to regulator, -6 to carb, & -10 from regulator back to tank.
>>> Custom 8 point roll cage & welded in custom subframe connectors.
>>> Custom Fiberglass 2 1/4" Cowl induction Hood. With hood scoops.
>>> Hooker reducers 3 /12"-3"
>>> Custom Aluminized 3" exhaust w/chrome exhaust tips.
>>> Flowmaster lers.
>>> 15 gallon aluminum fuel cell w/sump.
>>> Mallory 140 series electric fuel pump with return style regulator.
>>> New 1999 Mustang 8.8 housing.
>>> Moser: 31 spline axles w/c-clip eliminator w/long wheel
>>> studs,spool rearend, 356T6 aluminum rearend cover w/load bolts.
>>> Ford Motorsports: 4:10 ring gear & pinion set.
>>> Ford Motorsports Aluminum Drive Shaft W/Spicer U-Joints.
>>> Maximum Motor Sport lower rear adjustavle control arms.
>>> HPM Performance Products mega-bite upper rear control arms.
>>> Maximum Motor Sport Caster/Camber plates.
>>> Flaming River Manual Steering Rack.
>>> BBK Poly rear axle bushings & front and rear spring isolator kit.
>>> Lakewood Drag Struts & Shocks 90/10
>>> Eibach Drag Launch Spring Kit.
>>> Driveshaft Safety Loop.
>>> Hurst Roll Control.
>>> B&M Quick Silver Shifter.
>>> BE Cool Aluminum Radiator and twin fan kit. Cools up to 700hp.
>>> Evans Waterless Cooling Fluid System.
>>> Moroso Sealed Battery Box: Trunk mounted
>>> Optima Deep Cycle Battery.
>>> External battery disconnect switch.
>>> Weld Racing wheels series 90 Draglite Polished:Front 15x4 Rear 15x8
>>> M/T ET Street Radial Rear tires 27560R15
>>> Auto Meter Pro Comp Gages: Fluid filled-oil pressure,water temp,
>>> fuel pressure, & brake pressure.
>>> Electric & or mechanical Pro Comp gages-MPH, RPM, Fuel lever,
>>> Voltmeter, & trans temp.
>>> TRANSMISSION: C6
>>> Art Carr Tork Converter, 3,500 RPM stall.
>>> Cheeta Reverse pattern manual valve body.
>>> B&M Trans cooler W/Fan part #70297
>>> Aluminum Deep dish Trans Pan
More pictures can be sent if needed
This is one bad a$$ ride
Call Bob at 240-329-7835
click the link to see a pass at the strip
http://smg.photobucket.com/albums/v7...obDragLg-1.mp4
(http://[IMG]http://img.photobucket.com/albums/v732/Siggy1265/IMG_9584.jpg)[/IMG]
(http://[IMG]http://img.photobucket.com/albums/v732/Siggy1265/tbirdmotor.jpg)[/IMG]
(http://[IMG]http://img.photobucket.com/albums/v732/Siggy1265/100_2640-1.jpg)[/IMG]
dude, that makes me ill. Wish i had that kinda cash. Good luck though.
Yeah Thanks Man , there is over $25000 in the car , I need to make room for my other cars .
I need room too... But the mustang going first! LOL Love your Bird!!
Thanks Man , other cars have more sentimental value to me and my wife !
I think i'm going to cry....... I love that green thing
Yeah 347 I am gonna cry when it goes to !
That's a bummer man! You're going to make someone a happy person. I've had my Bird for 21 years now and I plan to keep it until I die.
Yeah it is a bummer but I have other rides that mean alot more to me . My Montego I have had for 26 years and the Matador X has been in the family since brand new in 74 .
