Technical => Electrical Tech => Topic started by: dc95xr7 on February 21, 2010, 09:18:30 PM
Title: trip meter and odometer not working
Post by: dc95xr7 on February 21, 2010, 09:18:30 PM
my 95 cougars trip meter and odometer stopped working a while ago so i replaced the gauge with one i had picked up at pick n pull but still no luck.the speedo still works but they wont.is there a sensor at the tranny that went bad that i can replace or is it in the tranny.thanks
Post by: jcassity on February 21, 2010, 10:09:48 PM
not sure where /who here supports the MN12 models.
I dont.
Post by: dc95xr7 on February 21, 2010, 10:52:29 PM
used to be quite a few on here
Post by: 88CougarGT on February 22, 2010, 12:12:17 AM
The Speed sender on the trans is easy to swap (just did it this weekend.  It sticks out the tailhousing on the driver side.  Above and behind the transmission crossmember.  Its held in by a large clip and one 10mm or 11mm bolt.  Just un-clip the connector, unbolt, and remove.
X
Post by: dc95xr7 on February 22, 2010, 12:41:31 AM
thanks alot and thanks for the pic
Title: wasn't an electric issue after all
Post by: dc95xr7 on February 27, 2010, 11:16:12 AM
turns out it was a gear issue after all.found a site that actually machines stronger gears that aren't brittle.a little pricey but what isn't these days.here's the site if anyone has the same issue.http://www.speedometergears.com/
