There's a pair of stock, aluminum 5.0 valve covers I found that are in great shape, except the baffle is missing from under the filler neck. Are there any easy ways to put some kind of a baffle in there? The guy selling them doesn't have the baffle any more. I don't want to have oil in my intake, so I definitely want to have a baffle in there. Thanks for any help on this guys.
I had to remove the baffle and cut some of the mount to clear my roller rockers, never had a problem...
I agree with TC. I can look down into the filler and see my rockers. No problem yet.
I don't know guys. I've read a lot of guys say they didn't have any problems with oil being sucked into the TB, but I've also read where a lot of guys did have that problem. I don't suppose either of you still have your baffle and the screws that hold the baffle into the cover would you? I just found out about those screws. If I could get them and someone's unused baffle, I'd be good to go. Since I'm not using aftermarket roller rockers, I might as well use a baffle and know that I won't have any issues.
Get one of those metal "for sale" signs,and cut out a new baffle and use some small self tapping screws to install it.Shouldn't take more than 10 or 15 minutes to make one and drill 3 small holes for the screws.Very simple baffle.
ive got a set of stock valve covers they have the ford emblom stamped on em that ill sell ya for cheap,,,they are primered and ready for paint
I ran valve covers without a baffle for awhile and have not had an oil consumption issue.
I found out that my local Home Depot sells small sheets of aluminum Vinnie, so I'm gonna cut a baffle-sized piece out of one of those sheets and use self tapping screws like you suggested and call it a day. Thanks for the idea. :D
Thanks for the offer, but I want to use stock, aluminum 5.0 valve covers. I found a pair here in Columbus that I'm gonna go buy tomorrow.
You're welcome.I'm going to make one for my valve cover that I have on the new engine as well.I won't be using it,but someone will when I'm finished with the swap.Snap a pic.
I did what vinnie said-except I used a sode can. It's been on my Mustang about 5 years now like that.
I'm going to make one maybe tonight for mine.It'll give me something to do while I'm chillin'.
