Technical => Audio & Other Aftermarket Electronics => Topic started by: mcb82gt on December 12, 2008, 08:05:37 AM
Title: stock equalizer question
Post by: mcb82gt on December 12, 2008, 08:05:37 AM
My car is factory premium sound- no EQ.
Are the plugs behind the storage panel to just plug in?
Or is it something harder?
Thanks
Post by: mcb82gt on December 16, 2008, 07:25:37 PM
Nobody has done or pondered this before?
Post by: Turbo 88 on December 16, 2008, 07:38:42 PM
I've pondered the question, but I'm really new to these and the TC is still on the lift with another car under it
Post by: Haystack on December 17, 2008, 10:34:17 PM
check this out.
http://www.foxthundercats.com/samscars.htm and go to the wiring diagrams.
Post by: Turbo 88 on December 18, 2008, 12:56:27 AM
definitely not the same
Post by: Lightningbird on December 27, 2008, 01:28:24 AM
The plugs are there, they are tied up. Make sure that you are looking in the correct place in the trunk behind the rear seat, drivers side.
Post by: mcb82gt on December 28, 2008, 05:33:14 AM
Im talking about hooking up a factory EQ in the factory location in the dash, of a car that didnt come stock with the EQ??
Post by: pro-five-oh on December 28, 2008, 04:04:33 PM
Mine has the EQ and I was under the impression that you need a non-EQ head unit to connect it up. That HU doesn't have a fader because the EQ does, and it comes with a specific  plug to work with the EQ.
Course it doesn't really matter, do a search here and you can see how to splice it into your system, plugs not needed. I got my EQ to work with aftermarket HU/AMP/Speakers, etc thanks to a few people here and I LOVE IT.
Title: Stock EQ
Post by: Greg Price on August 28, 2009, 07:52:55 PM
Did your ever find more information on adding a stock EQ?
I just got one a pick and pull today. I also got the stereo with it .
Post by: mcb82gt on August 28, 2009, 09:49:12 PM
No, I never messed with it any more, just plugged in a used Alpine 12 disc changer, Ive been happy with it for now.
Post by: mcb82gt on May 23, 2010, 01:07:50 PM
Quote from: Greg Price;288721
Did you ever try it??  :D
Post by: mcb82gt on May 23, 2010, 01:41:18 PM
It looks like the factory amps were different.  With the EQ it has all 6 speakers coming off the amp.  W/o EQ only the front and door speakers off the amp.
Do you have to swap the amp also?
Was the amp/w eq higher wattage??
