Technical => Engine Tech => Topic started by: supercharged88 on December 10, 2008, 06:52:07 PM
Title: cougar runs lean and idles crazy HELP!!!!
Post by: supercharged88 on December 10, 2008, 06:52:07 PM
hey i put a 5.0 ho in my 88 cougar but since then it runs lean and i dont know what it is.  also it idles like crazy it surges then goes to normal surges then normal over and over HELP!!!!
Post by: V8Demon on December 10, 2008, 08:12:15 PM
Run codes yet?
What size injectors?
SD or mass air?
Did you upgrade the fuel pump?
Post by: mywifeskitty on December 10, 2008, 09:30:53 PM
sounds like a map sensor or vacuum leak, but if thr rpm's rhythmically go up and down while idling it's usually map related (if you have a speed density setup... i think :))
Post by: 5.8fastcat on December 10, 2008, 09:33:51 PM
Check your TPS voltage.(should be between .85-1.0 volts) on the
green wire with the key  on engine off.
How are you checking the A/F??? ( wideband or noise)
Post by: thunderjet302 on December 12, 2008, 02:41:44 PM
If it's SD what cam is in it?
