Technical => Body/Appearance/Interior => Topic started by: mywifeskitty on December 06, 2008, 05:38:42 PM
Title: headliner repair question
Post by: mywifeskitty on December 06, 2008, 05:38:42 PM
i just removed my headliner and found that all of my insulation was damaged..... where can i find replacement insulation or what kind of stuff can i put up there?
thnaks
Post by: vinnietbird on December 06, 2008, 06:46:53 PM
Dynomat (or equivalent).better than the factory stuff.I've seen similar products on Ebay pretty cheap.I'm installing it throughout the Sport.I was told by a local car builder to cover 60% of the area,every inch of coverage isn't necessary.
Post by: mywifeskitty on December 06, 2008, 06:57:16 PM
cool... you're always a big help vinnie :bowdown:
Post by: vinnietbird on December 06, 2008, 07:01:18 PM
Thanks a lot,and,you're welcome.That stuff is great for behind the door panels (on the door,not the panel),under the carpet,in the trunk and under the trunk carpet,and you'll be amazed at the difference in the leack of noise inside the car,and the insulating  abilities of this material.
