Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: martin0660 on November 29, 2008, 01:02:51 PM
Title: Lots of misc parts (mostly Turbo related)
Post by: martin0660 on November 29, 2008, 01:02:51 PM
I have a bunch of misc parts I would like to move out to make room for more  Everything price OBO, let me know if you would like better pics of anything.
Hurst Tee shifter handle with button. Threads are for factory ford shifter. I used this on my car as a line lock control. Includes handle and lock nut. $30.00
Aftermarket (Turbonetics) dual port waste actuator with adjustable arm plus laser cut mounting bracket for T4 compressor. Never used, was bolted up to mock up and I'm going a different direction. $80.00
Aftermarket (Precision) single port waste gate actuator with adjustable arm. This one has a welded bracket set up for a T3 compressor housing. This will not work with the 2.3 standard manifold / turbo configuration as is (see third picture), would need modified, or great for custom set up. $50.00
Stock (Garrett) wastegate actuator for Ford / Garrett T3 turbo. This one still has a good heat shield (usually rotted off). $40.00 (I also have three others)
Stock T3 outlet elbow with internal wastegate puck (swing arm). This one has the studs removed for use of through bolts. I change mine to this way so I can drop the exhaust without getting under the car, plus it seals better this way (downpipe not included) This one was on my car until I installed the ATR big outlet this summer. $30.00
E6 turbo manifold for 2.3. When removed, two of the studs came out, one nut came off, and one stud broke (although it's long enough to get out with heat). Use this one to port while you are still driving your car  $40.00
IRCM (Intergrated Relay Control Module) and BAP from 87/88 TC. This is the module that houses the EEC relay, both fan relays, and fuel pump relay those TC's. Removed working from my car. $20.00
4 cylinder turbo fan from the early fox cars (early TC, SVO, Capri turbo GT turbo, etc) $20.00 (shipping will likely stink on this)
Finned turbo outlet pipe for non IC car (like the turbo coupe outley but has cooling fins, usually on Merkurs) $20.00
87/88 TC valvecovers. Both are the center dip style, on "stock" one was painted red but peeling. $20.00 each
87/88 TC intercoolers. Two avaialble $20.00 each
87/88 TC door hinges (both hinges, both sides. $20.00 or will seperate as needed.
87/88 TC mirror assemblies. At least two DS and two PS $10.00 each
87/88 2.3 stock throttle bodies. Like 5 avaialble, take your pick $10.00
Small bin that sits in the 87/88 TC console $5.00
87/88 TC snowflake centercaps. Many available, $5.00 each.
I also have lots of little misc TC parts around that either need to move or be thrown out. Make me an offer on this stuff, you might be suprised as it needs to go. Shipping extra on most parts, or make your offer "shipped".
Edit - Links did not work. Pictures of most everything are in this album, let me know what you are interested in and I will get you direct links, better pictures, or whatever you might want.
http://rides.webshots.com/album/568555834DEhuEx
Bob Myers
Post by: martin0660 on December 08, 2008, 09:08:34 PM
Make offers on this stuff guys, it needs to go.
Bob Myers
Post by: jangus on December 11, 2008, 10:43:51 PM
PM sent
Post by: SR71TC on December 13, 2008, 02:49:36 AM
tail lights or driver's side side lamp? bumpercover?
