Technical => Drivetrain Tech => Topic started by: wayfastwhitey87 on March 19, 2005, 09:51:32 PM
Title: Trans brake
Post by: wayfastwhitey87 on March 19, 2005, 09:51:32 PM
what exactly is the difference in a trans brake and a line lock.  and what will do better at the track.
Title: Re: Trans brake
Post by: zpyro on March 20, 2005, 12:29:52 AM
I asked this too
http://www.foxtbirdcougarforums.com/showthread.php?t=1931
trans brake apparently holds the tranny in 1st and reverse at the same time, while a line lock holds the front (or rear) brakes. trans brake is more expensive than line lock. line lock can be used to launch or to do better burnouts without wearing the rear brakes (as opposed to power braking it)
Post by: shame302 on March 20, 2005, 10:31:45 AM
trans brake will retain more torque. better for actually launching the car.
Post by: Fred on March 26, 2005, 02:39:42 PM
A trans brake in conjunction with a high stall convertor will allow you to lanch at a higher RPM.  Used alone a trans brake is of little or no use.  The object is to raise the RPM's to get the engine torque output to accel the mass (CAR) faster.  It will also shorten the life of your trans.  If in raising the RPM's, you overcome the service brakes, then a trans brake in used to control the launch.  IMHO don't waste money on it for street use.  Fred
