Could I use a Stang 5.0 harness in my '88 Tbird, if I changed the connectors and repinned the wiring?
If so, I've got one located...
You should be able to. At least I hope so. I'm about to put a 5.o from a 89 Mustang LX with wiring harness if it works. Let me know what happens.
Vinnie might chime in on this?
http://www.foxtbirdcougarforums.com/showthread.php?t=15764&highlight=mass+air+harness
I have the engine harness out of an 88 mustang 5.0.. Its bulkhead connectors are the same as the 88 Tbird. There are other differences though.
I tried it,it needed more effort than I was willing to do,so,I found another T-Bird 5.0 harness and ended up good.
