Technical => Body/Appearance/Interior => Topic started by: daminc on December 16, 2007, 08:03:13 PM
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on December 16, 2007, 08:03:13 PM
Well, It all begins this week. I had a couple hours today to do some work on my baby. Monday was going to be the official start of the car rebuilding but I couldn't wait until then. So here's a couple pre-project pics.
I figured there would have been more rust inside the frame. just some surface rust. so anyway, the floor is already bent up and ready to be cut to size. the inside rocker will be cut out where rotted. and a new piece welded along side the old one for added strength. everything will be blasted and encapsulated before and after the new pieces are welded in
I'm glad the pass. side is in a lot better shape
monday starts my 2 week car body rebuild. I should have new pics every evening. ---If everything goes well.
Post by: FLSTCI71 on December 16, 2007, 09:04:26 PM
You're the man!! Way to save a Fox instead of sping it. Of course, it's easy for me to say when you're the one doing all of the work. Anyway, I'll be looking forward to seeing the updates.
Post by: mercury-man on December 16, 2007, 09:12:21 PM
daminc , just one step at a time and you'll see your (Cougar LS) will be reborn again. lol :cougarsmily:
Post by: SLEEPER T-BIRD 87 on December 16, 2007, 11:18:00 PM
keep up the good work
Post by: 1WLD BRD on December 16, 2007, 11:41:08 PM
WOW, that makes my 85 Cougar look mint and not so bad of a restoration.... Maybe I should reconsider sping it.....
Post by: daminc on December 17, 2007, 08:00:23 AM
lets have a look.
It just takes a little patience. and a place to do it
We'll have to get together some day. we're only about 20 mins. from each other
Post by: 1WLD BRD on December 17, 2007, 10:20:12 AM
yeah I'd be up for that, but it is a little further then 20 minutes, I am about an hour away from the peace bridge.
I will get some pics today of the floor pan in mine, Mine is covered in rust but the holes are nowheres near that size..... I have almost all the good metal I need to weld it back up, except the floor pans, may just fabricate something like you are doing...
Keep up the good work, you have given me a renewed inspiration in my restoration.... Thanks.
Post by: Cougar8775 on December 17, 2007, 01:02:09 PM
WOW! that is ALOT worse than my 84. Now maybe i should save the 84. But also i know i have a new project on my hands. But yeah time and money is the key. Good luck and looks good so far.
Post by: daminc on December 17, 2007, 01:10:25 PM
I'm about 5 min from the Queenston/Lewiston bridge if thats closer and about 20 min from the peace bridge
Post by: 5.0willgo on December 17, 2007, 02:49:33 PM
Wow, good luck with the project. I give you a lot of credit for attacking this and you're doing a great job so far.
I had a '76 Camaro that rotted out much the same way on both the driver and passenger side. I wanted to save that car but every metal body panel was rotted through along with the dash and cowl so it was sold for parts :(
Title: Update Pics 12-17-07
Post by: daminc on December 17, 2007, 06:34:14 PM
***********Today's update********************
Today I spent a couple hrs. working on my baby. here's what I did ......
fitted and cut the floor pans I bent up the other day you can see the inner rocker repair in the 2nd pic
Here's a shot of a dry fit on the car over the existing one. I couldn't make the 1/4" step in the rocker so I ran a 1/4" bead down it where the step would be. I don't think anyone will notice.
I'll have to put the quarter on before the rocker. or at the same time. the quarter panels are from a TC (thanks to a friend with a last minute idea) so it has to be cut below the body line where the stripe is on my car. the door jamb will be replaced with the red one and spliced in next to the side window.The panel will have to be cut and spliced just behind my back lights because the cougars wrap around farther then the TC's. not my favorite thing to do, but you have to use what you can find, seeing birds are easier to find then cougars. esp. 87-88s
the panel will be separated from the well with some of the bracing. some will be cut out of my car to make it easier to replace. I'll post pics of that job. should be next on the list. this will give you an idea of what's in there
I guess, not a bad day for a couple hrs. I'm juggling my car rebuild with the last of the house remodeling. so it might take a few days longer on the car then i figured. I'll finish dry fitting and weld the patches including repair the pass. side floor before the quarters get cut off.
I know someone has to have a question after all that. lol
and yes I have pics of how i made the rocker if anyone wants to know how.---Its pretty easy
Post by: 1WLD BRD on December 17, 2007, 07:20:42 PM
Impressive bro, keep it up....
Post by: thunderjet302 on December 17, 2007, 07:33:07 PM
You my friend have some fine body skills. Keep up the good work:D .
Post by: SLEEPER T-BIRD 87 on December 17, 2007, 08:37:58 PM
Quote from: thunderjet302;193296
x2 im impressed with the metal working skill he has shown
Post by: ZondaC12 on December 17, 2007, 09:35:21 PM
WOW unbelievable. And I thought I had somethin, shovin sheetmetal under my car and kinda smackin it with a ball peen hammer to ROUGHLY make it fit the surface :hick: This is a freakin class a restoration we got here.
Title: Outer Rocker Panels
Post by: daminc on December 17, 2007, 11:17:47 PM
here's an easy way to make rocker panels.
I cheated and got sheet metal from Mill Supply because its a good quality and the panels are coated with weld thru primer to keep them from rusting. and they come 5' long which is a problem because of sheet size at some places.no sense in buying a whole sheet for an odd size repair the panels are 20ga. generic door bottoms with a pre bent edge and are 10" wide. all the work on my car and i'll only use 1 of those. but i got 3 in case i found something bad. the floor pan metal was bought at lowes as i was passing by
what you need to do is clamp the piece down to a work bench. you don't need a fancy brake to do this you can use a 4x4 thats straight. clamp it down about an inch back from the edge of the bench. then clamp a piece of 3/4" black pipe in front of that kinda like this you can see the pipe sitting on the brake the same place the 4x4 would be
all this does is hold your metal down to keep it from moving. Make sure it's tight. then clamp 1 board on top and 1 board on the bottom to keep things from warping when it gets bent. the full length is a real bear to bend using 20ga. a patch panel will be a lot easier. the more clamps the easier, for leverage then just wrap the metal around the pipe
I reversed the clamps after i got half way. it moves the leverage from lifting up to pushing forward.
thats how i made it curve the bend along the frame and floor panel i did by hand with a pair of hand brakes and flattened it with a hammer. you can buy cheap bead rollers at harbor freight for 100 bucks. they have all the rollers and sheet metal cutter wheels. not bad quality for harbor freight. if you just make a rocker patch , you probably don't need much fancy stuff to make it match.
just thought I would spread the knowledge. the bottoms of our car panels are all curved as they go under the car. fenders, rockers, and quarters. some are curved more then others
Post by: thunderjet302 on December 17, 2007, 11:32:57 PM
Wow :D
Title: Rocker Replacement
Post by: daminc on December 18, 2007, 05:04:33 PM
Today after spending the morning taking apart my powerbook, due to lack of it doing anything at all. I got another 2 hrs in.
Started with some grinding & blasting around the patches, so they can be welded. dove right into that rocker situation on the drivers side after the blasting. As I was trying to break the welds on the bottom of the panel it fell right off. I guess it was a little too far gone to save. So I said the hell with that and pulled out the nibbler.
and ended up with a lot of rust on the inner rocker. so again I said the hell with that. this time I took my sawzall and cut the entire bottom of the iner rocker off even with the floor.
Until tomorrow. same bat time same bat channel I think you have to be over 35 to get that one.:D
Post by: CougarSE on December 18, 2007, 05:47:08 PM
Wow this is amazing! I love threads like this. I hang out a lot on 67-72chevytrucks.com because they have massive threads with metal repair.
Your thread inspires me to work on my 88 Cougar. I was upset as it had a small hole in the frame rail.. and that is it.
Post by: gumby on December 18, 2007, 06:07:25 PM
Quote from: daminc;193427
T I think you have to be over 35 to get that one.:D
not quite. im only 28.
nice work on the car! :hick:
Post by: thunderjet302 on December 19, 2007, 12:25:34 AM
I may be looking at it wrong but in the last two pics it looks like the bottom of the fender sits lower than the rocker you made. I could be wrong though.
Post by: daminc on December 19, 2007, 08:22:04 AM
Thanks for your concern. It does look like that from the picture. the fender is just hanging there and sitting on top of the rocker because of the bracing behind the fender panel. once the rocker gets cut, the fender will be pushed in against the inner rocker lip. plus the fender needs to move up another 1/4". I couldn't hold it up and take the pic. lol
Your the first one that said something about that. I was wondering how long it would take.
I had also thought of custom making the rockers, so the car would look lowered. but i thought the stock look would be better in the long run 20 years from now, if I sold it.
I'll try to get a few more pics in before christmas. I'm not sure how much time i'll have. I have some estimates for work to do and we have christmas at our house every year, and a lot needs to be done for the day.
anyway the pics would be boring welding and priming pics of what I've prefabbed so far. and mabe the pass. side floor. If anyone wants to see the step by step on that, i'll post those also. If not I'll just show a couple finished pics of what i've got so far.
I also don't know how long it takes most of you to load this post because of all the pics. My internet is blazing fast. The cable guys can't believe how fast it is fast. (thats fast) If everyone is having to wait to long to load this post, PM me and please let me know so we don't make this this one longer, and i'll split things up in another post and link that one from here also. I think I'll call It................ Part II
jerry
Post by: thunderjet302 on December 19, 2007, 10:42:37 AM
Ah ok I though you had it hung correctly. Now that I know it was hanging I know why it sat lower :D . You're going nuts on the car which is great. It's nice to see someone save one instead of sing it. While you're doing all this work are you going to install frame ties aka subframe conectors? I figure you have the skills to do so and you have a bunch of metal around ;)
Post by: daminc on December 19, 2007, 11:02:07 AM
I'm probably going to do that. I like the way FASTCAT 5.8 did his frame by cutting the floor.It also looks like the most direct path to connect the 2 up, as long as I got the car that ripped apart. I'll wait until the front pans, rockers, and quarters are welded on before I cut the back floor pan. I may have to ask him for some tips, since he's already done it. my first task is getting rid of all the rust and put the car back together again
Post by: daminc on December 19, 2007, 05:00:42 PM
I didn't get much done today worth taking pictures of A lot of looking and planning for the quarters. a lot of shop cleaning also.
I got some pictures showing why the fender looked lower then the rocker panel.
As you can see the fender is just hanging in front of the rocker.
that looks better. The fender still has to move up another 1/4" Not to worry, I wouldn't let my baby out of the garage looking bad.
Post by: mywifeskitty on December 19, 2007, 06:29:57 PM
Quote from: daminc;193527
......but i thought the stock look would be better in the long run 20 years from now, if I sold it.
now that's optimism :burnout:
Post by: dominator on December 19, 2007, 07:05:48 PM
Hate to rain on your parade man but let me first say nice work. Now seeing as your car is one of the worst rust wise i have ever seen have you noticed that there is alot more rust in hidden unaccessable hard to repair structural places???? The front frame rails where the k member bolts up come to mind as well as the rear torque boxes and fuel tank mounts(they look very rusty from your one pic). Front fenders,flat floors and even rockers are not that bad to do but the structural parts i mentioned on our cars are very difficult to repair and require alot of measurements,bracing and dissasembly before repairs can begin. These are places often over looked by many do it yourself restorers. On my old 88(may she rest in pieces) which i thought was bad(was not as bad as yours evidentley)i removed the eng and trans to have the entire front frame rails fabricated and replaced by a bodyshop only to tear the torque boxes from the frame 1 week later due to being just as rusted as the front. Also my fuel tank mounts had to be replaced as my tank almost fell out of my car. After around 1000.00 of frame work i ended up stripping and sping the car anyways(waist of time and money). Just want you to make sure your not making the same mistake,have a good hard lengthly look at the places i mentioned and start stabbing at them with a screwdriver before you continue as all you have done may be in vane and it just may be better starting with a solid southern shell.
Post by: daminc on December 19, 2007, 08:21:47 PM
Believe it or not there's almost no rust past the floor in the rear of the car. I noticed the pictures make my car look a lot worse then it is. There's still is paint on parts of the floor and it still has the black under coating finish from the rear floor pans back to the bumper. and the frame is just surface rust as far as i see. I beat the piss out of it almost everywhere I could get to with a pick hammer, to see if it was rotted through anywhere way before I started. there's almost no rust anywhere around the motor. even under the battery tray. I figured that would have been gone
Im pretty sure most of my car rusted from the inside out because of the salt from the road getting on the boots and melting inside the car. and the drivers rocker from the salt slush between the lanes of the street The passenger side rocker has almost no rust on it because of this. If I do find any rotted frame I'll just replace it anyway. This is my way of relaxing and doing something fun. If it takes me 5 years or more to do it, that doesn't bother me If I was just looking to fix up something quick I would have dumped it 5 years ago and started over with something better. So it comes down to, just having some fun and fixing my car along the way. BTW.... this is also one of the better cars i've put back together. If you can believe that.
Post by: FLSTCI71 on December 20, 2007, 01:09:25 AM
Here's an important question that you obviously haven't thought of yet. You've been calling it the Flintstone car. The floor is almost fixed, so after it's taken care, then what will you call it?
Post by: daminc on December 20, 2007, 07:16:16 AM
Thats a good question. I have thought about that before and wrote *****Soon to not be the flintstone car**** in the sig. but thats as far as i got. Anyone have any ideas? It would have to show some sort of evolution from before, during and after.
Post by: 5.0willgo on December 20, 2007, 08:54:55 AM
Before: "The Flintstone car" During: "Project Bedrock" After: "Out of the Stone age"
You're doing an awesome job. I'm really looking forward to seeing the final product.
Post by: daminc on December 20, 2007, 04:14:57 PM
OK I did some poking and prodding around the motor today there is rust on the front frame. where the frame and k member bolt together. seems to be just heavy surface rust, no holes or denting when I hit it with a bar. Looks to be usable and able to be cleaned up by blasting. the wheel sides of the frames are already blasted and primed. I did pick them to see if they were rusted through after blasting.
By the looks of the color of rust being dark red. the moisture from the garage is still keeping the rust moist and alive. and it felt a little damp when i stuck my hand in there.
The rear end of the car is also has a little bit of heavy surface rust in a couple areas but not rotting through anywhere. the battery died on my camera while looking at the front.
The rear end seems to be ok structurally but it's gonna suck getting that undercoating off.
I guess I'll find out if there's anything bad hiding as I go.
Let me know what you think about the rust in the front I'm open to any thoughts.
I did see a product that will get rid of the rust by recirculating the liquid over the area.....and its non toxic. I'll try to find the link
Post by: daminc on December 20, 2007, 04:38:55 PM
found it It's called ----safest rust remover I didn't know if it was ok to put a link like that on our forum so i just put the name
Post by: V8Demon on December 20, 2007, 10:25:04 PM
A link for a product like that would be fine. I link stuff all the time. Fantastic progress you are making!
Post by: daminc on December 20, 2007, 10:54:23 PM
Here's the link for the rust removal stuff. from what I heard at the body shop forum It works quite well. there's also a video about it on the site
I did notice that we don't really have a body or metalworking area of our forum. could be useful for the do it yourselfers who want to share body working Products along withframe and panel repairs for our fox cars as we can't buy much in aftermarket panels. I notice it's pushed together with interior and appearance
If anyone else needs links to body work supplies and welding stuff let me know I may be able to help and pass on the info. -----------------------------------------------------------------------------
Thanks everyone for there input so far. Motivation is what keeps things going. If anybody sees anything in a pic that i may have overlooked let me know. I'm always up for suggestions or ideas. :cougarsmily:
Jerry
Post by: dominator on December 21, 2007, 09:04:20 AM
Yea those pics are kind of hard to see much jerry. There is definetley rust there but you need to see more of where the tower is welded to the rails as well as the inner ledge behind the front tires and just rearward of the tower to frame. The front sections are usually good. The ledge in the inner fender behind the tire allows all the road debri to sit and develop into a mud which rots it out. There is also a few factory punched holes in this location(their purpose still baffles me)that let water and mud into the rail itself rotting it from the inside as well. I ended up sealing those holes up so that it would stop that partcular problem(not that my car ever sees any rain or snow anyways lol).
Post by: FLSTCI71 on December 21, 2007, 11:20:49 PM
In other words, if your shock towers look like this, you may have a problem....
Post by: dominator on December 21, 2007, 11:54:04 PM
Exactly,even if they have a small hole,the rot came from inside out. See how the front of the rail still looks mint but it's toast all the way through right under the tower right through to the other side. This car was obviously a 2.3 turbo as it is the passenger side rail right near the turbo(excessive turbo heat tempered the metal causing even faster rot) but it happens to v6 as well as v8 cars. Also like i said,make sure those rear rails at the torque boxes and the boxes them selves are not rotted through as well as the pass side gas tank mount in the rear end valley(it's hard to see without the car being on a hoist but i bet there rotted. Even my 100k not winter driven TC has a little bit of rust on that mount(not through but still there)reminds me i gotta clean it up and coat it.
Post by: daminc on December 22, 2007, 09:12:01 AM
Thanks for the tips. I'll have my project manager look at it again now that I took more apart. If I do decide to get a different body to work with, Is there anyone here at a reasonable distance that could help me out. the body and interior don't have to be worth saving. but if I could find one with a fairly good running motor and frame I would feel better and I wouldn't mind swapping everything over. the transporting has always been my problem. It would have to be a 87-88 cougar or 87-88 TC (but i'm leaning more towards the cougar unless the motor in the TC is really good)
The more I get into it the more rust I'm finding. I'm all up for a good restore project. But I may be replacing to much of this car in the long run. It now looks as if its getting to be at the 40% mark between body, floor and surrounding sheet metal. It's not that I can't do it. but I don't want to find the parts that I haven't replaced rusting out in 5 years and trying to fix them the rest of my life. I really just want to do this 1 time.(until I get another one)
This has been my reason not to weld anything on the car yet. I've only got 12 hrs into this project since september, so I'm not in the position to have lost any time working on it. most of the time was removing the interior and the front end. It would have be done anyway if i got a car to swap with.
Let me hear your opinions and suggestions as I wont be working on the cougar until after the holidays.
Jerry
Post by: dominator on December 22, 2007, 09:35:37 AM
Jerry it's not that we don't appreciate the time and effort you're putting into your cat,it's the fact that you'll will be fighting structural problems very soon and your car is in really bad shape. I'd hate to see you do all the exterior work just to have the tank fall out or the rear end rip from it's perches(i know because it happened to me after waisting countless hours and 1000s of my own money which should have went into my TC instead of the rust bucket). Honestly you can find a nice TC or Cougar with low miles and virtually no rust for 3000.00 or so then you'll have a solid platform to work with. I found my TC up here for 2200 4 years ago. I know where a mint TC is up here for 2300 without an eng(but when i say mint i mean mint,you could eat off the floors)and a mint 88 cougar with a 2.3 turbo conversion for 3000.00. There are cheaper cars for less but you get what you pay for. Around here and where you are(the salt belt)you have to pay a bit more as these cars in good shape as they are getting harder to find for less than 3g's. If you want to travel to the southern states i'm sure they can be had for cheap with almost no rot but after transporting them back the dollar figure may be about the same.
Post by: 1WLD BRD on December 23, 2007, 12:37:01 AM
that Turbo Cat is gone Chris... I already called about it.... I was dreaming of it... HAHA, I even printed of a bunch of pics of it to show my parents, "my next project car" LOL
Post by: dominator on December 23, 2007, 01:07:02 AM
Good to know.
Post by: daminc on December 23, 2007, 08:56:25 AM
Keep your eyes open guys. Drivable would be a plus. I won't rule out a Canadian car. but the exchange isn't in my favor anymore. If I can find a drivable one, I'd consider a road trip as far down as alabama/ tennessee. but I would have to ask a favor of someone thats close to where the car was found. (to check it out). spring time Possibly would be the best time of year to find one. the roads would be clear.
Like I said We'll be cutting off some more panels to see what's going on in my car after the holidays Everything is replaceable, just a matter of how far do you want to go and how safe will it be when your done.
My father in law has replaced and repaired frames in cars before, so thats not a problem here. It would be the how much needs to be factor. which also goes for the sheet metal on the car.
If you don't hear from me ........ Have a Merry Christmas guys, and talk to you after tues. Jerry
Post by: ZondaC12 on December 23, 2007, 10:52:20 AM
I'll keep my eyes on the wantads/craigslist (not that I dont already :hick: ) I see stuff pop up every once in awhile. I know this is across the state but it sure would be closer than Alabama! :hick:
Post by: daminc on December 23, 2007, 11:00:32 AM
Yes it would. Thanks
Title: Update
Post by: daminc on December 27, 2007, 12:42:54 AM
This weeks progress report----------------
Hope everyone had a good Christmas. Mine was wonderful except for my powerbook dying. Must have cooked another logic board. so updates with pics will be a little slow until i get reorganized on my studio computer, until the powerbook gets fixed (again).
OK --I spent about 3 hrs today going over the frame and checking structural supports. There's a couple places that need a little repairing. very small, nothing that I cant repair In a couple hrs.
removed the back seat upper today (with a little heat. May need a new plastic seat belt retractor cover for one side. it melted a little. it will never be seen.)
Sheet metal is in great shape back there. just a little rusting around the rear wells. easy to fix
everything under the rear end is in good shape. some rust, some undercoating, and even paint. but no holes that I can find. some of one fuel tank bracket needs replacing but thats the worst of the rear end section. I believe someone mangled it about 10 or 15 years ago when they dropped the tank for replacement. Not a problem, I'll make a new one.
I may install extra bracing and reinforcement metal as I go. Still not sure what I'm planning to do with her. I may just restore her to her former glory and give her an easy life of cruising and showing off. I guess I'll decide as I'm working on it If the extra reinforcement is in the car, then I guess I don't have to worry If I want to upgrade anything in the future
So the project will continue with my car. and if 5.0willgo doesn't mind, I'll be using "PROJECT BEDROCK" until she gets put back together
And as they say---On with the Show
Post by: cougrrr302 on December 27, 2007, 02:43:40 AM
Make sure you fit everything up at once. The quarter, rocker, clamp them in place and make sure they fit well with each other. Then welding/glue bonding is next. I work in a Body Shop and am going to a Tech school for it. This is all I do anymore is resto. You do nice metal work. Looks like you know what you need and know how to bend and roll metal. Personally I like the idea you had about extending the rockers down to add a "lowered" feel to the car. If I find another fox to play with I might try that. How far were you thinking?
Post by: daminc on December 27, 2007, 08:42:27 AM
Thanks, you probably already noticed nothings welded yet. and the other reason the old door is still on is because it's keeping everything lined up. I've worked with aluminum for 20 years for my job, and have rebuilt a few cars and a van from the bottom up. I think I may try to bend up a pair of rocker covers when I'm done to give it the lowered look, they could be epoxied on.
If I didn't do what I do now for a living, this is what I'd probably would be doing. I may even try using lead on this project. --always wanted to. If you have any modern day tips on restoration send me a line. I'm pretty open about anything
Title: Rocker Covers
Post by: daminc on December 28, 2007, 10:05:10 AM
I was thinking just a little something to give it this sort of pulled out effect. Thats why i'm thinking a cover would be better and would blend better below the wheel flares that we have on our cars. It would have to go from wheel to wheel
Post by: daminc on January 13, 2008, 04:49:08 PM
Just to let everyone know, I'm not slackin.
Today started removing misc. items underneath the car. you know, e-brake cables and exhaust and brackets and things. I also sed off the scaled rust under there
I thought it would be pretty lame to post pics of that stuff. so we're pic-less for this post.
just getting things ready to blast. I'll post pic of the progress next time. I posted some pics of quarter panel rust here if anyone is interested. http://www.foxtbirdcougarforums.com/showthread.php?t=17568 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=17568")
I also cleaned up after seeing my garage in that "GARAGE" post last week. I can't believe no one said anything about that mess.
Post by: daminc on February 23, 2008, 06:07:47 PM
After a month or so of working 7 days a week I decided to do some work.
Here's a pic of lining up the new fender to position the rocker front. I used a bunch of rare earth magnets, from hard drives that I had laying around from back in my computer and electronic repair shop days (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3185.jpg)
Here's a shot from under the car. Yep, a paint stick makes a real good shim. lol (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3186.jpg)
Here's a shot of the inside rocker, tacked in place (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3187.jpg)
I've been dreading making this piece for months. I guess it's not bad for something that will never be seen again. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3188.jpg)
Post by: SLEEPER T-BIRD 87 on February 23, 2008, 08:57:30 PM
looking good.
Post by: thunderjet302 on February 23, 2008, 11:11:02 PM
You my friend are the man :D
Post by: 5.0 tbird on February 23, 2008, 11:17:37 PM
That looks great, nice work. :D
Post by: vinnietbird on February 24, 2008, 07:00:10 AM
You'll haver to keep this car forever.
Post by: *MAYHEM* on February 24, 2008, 07:00:40 AM
As I read through this thread I'm sitting here giggling because I remember so many of these guys telling you it wasn't worth saving.
You are doing fine work. When it's finished you'll know whether it was worth the effort or not. I'm looking forward to seeing the end result at CatJam and everyone drooling over it. :)
Post by: mercury-man on February 24, 2008, 08:02:49 AM
Jerry, your patience is a virtue with this project and thanks for the updates. ;)
Post by: FLSTCI71 on February 24, 2008, 12:03:53 PM
I have to agree with every single post on this page.
"Looking good."
"You, my friend, are the man."
"That looks great, nice work."
"You'll have to keep this car forever."
"You are doing fine work." I am not going to comment on the rest of Mayhem's post because I MAY have been one of those guys who told you it may not be worth saving. Hey, I've been wrong before and I'll be wrong again....
Last but not least,
"Jerry, your patience is a virtue with this project and thanks for the updates." x2
Post by: Chooglin on February 24, 2008, 12:08:42 PM
Quote from: FLSTCI71;205967
"Looking good."
Last but not least,
x 1,000
Post by: daminc on February 24, 2008, 04:51:10 PM
Thanks guys, I do plan on keeping this car forever. Why not, I've had it about 18 years. For some of you guys, thats already forever. lol Patience is easy when you don't need to use the car for anything.
I know you guys love a good project. Here's todays pics.
In this pic, you can see what I'm doing. I've cut out the floor between the frame rail to check for rust. To my surprise, only a little surface rust. I treated all the bare metal and any rust I couldn't get off with Pickelx. It turns rust into black oxide and protects new metal from rusting until its primed. (great stuff) I then coated the inside of the frame rail and any hard to reach places with encapsulator. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3189.jpg)
Here's the first piece tacked on the floor. Here's my handy dandy hole punch also. Everything is preped with pickelx. Its also a weld through primer. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3192.jpg)
Boy did I have a heck of a time tacking this. Reaching around the door jamb and trying to get close enough to see with my helmet fogging. But I did it. And I didn't start the car on fire either. lol (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3193.jpg)
Here's the floor patch tacked. Still needs a little more pounding and forming. It's not pretty yet. I'll do some more welding as I have time during the week. (mabe) Everything will be ground down and coated with zero rust, which is what the body shops are using nowadays to seal out moisture from rust. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3194.jpg)
Here's the cut I'll be making to replace the quarters. I can't wait to do that. I hate kneeling down to work. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3190.jpg)
Post by: daboss351 on February 24, 2008, 04:54:30 PM
go man go!!!
Post by: Cougar8775 on February 25, 2008, 12:14:23 PM
ive seen a few quarter panels replaced and everyone ive watched do it they used the body line to cut and hang it from. might be easier for ya. But good job! You enspire me to fix up my 84!
Post by: 5.0 tbird on February 25, 2008, 02:55:43 PM
Way to go man, keep it up!
Post by: ZondaC12 on February 25, 2008, 04:14:11 PM
WOW that's amazing what a talent to be able to work with metal like that....that's just so cool seeing those panels there looks SOO much better.
:bowdown: :bowdown: :bowdown: :bowdown:
Post by: daminc on February 25, 2008, 04:52:42 PM
Thanks guys, It's a start. I'm glad to not see the ground any more from inside the car. I still have a few more pieces that I need to cut out and replace on that side. Mainly around the e-brake posts. I can't believe how solid it got, and its only tacked. I also started welding the floor solid to the frame. I'll probably also weld the sub frame connectors on while I'm still on that side.
I'm still glad that the other side of the car is in better shape.
The problem with that is, I use the backing method for panel repair. It reinforces the metal, welds with less distortion, and stops blow through. It also makes the panel lay perfectly flat with the old panel.
You never want to replace a 50"panel on a body line, just in case it distorts. The rule of thumb for panel repairing is --- If you don't have a full replacement, then try to make the repair as small as possible. -- Less cutting-- less welding --less filling --less problems.
Although I have hung panels before. I would never do it that way again unless I had to.
This will now start, "Question and Answer Time" I know someone has to have a few. lol Jerry
Title: Links
Post by: daminc on February 26, 2008, 07:57:17 AM
Here's some links for the products that I use
Jerry
PICKELX (rust converter/ metal prep) http://www.orisonmarketing.com/picklex/picklex20.html (http://"http://www.orisonmarketing.com/picklex/picklex20.html")
ZERO RUST (encapsulator) http://www.zero-rust.com/ (http://"http://www.zero-rust.com/")
Fusor seam sealer (the cheapest price i've found) http://www.bestbuyautoequipment.com/Lord_Fusor_FUS_800EZ_p/fus-800ez.htm (http://"http://www.bestbuyautoequipment.com/Lord_Fusor_FUS_800EZ_p/fus-800ez.htm")
Pre-Bent Sheet Metal (great quality) http://www.millsupply.com/ (http://"http://www.millsupply.com/")
Cheapest price on welding equipment and supplies http://www.indianaoxygen.com/ (http://"http://www.indianaoxygen.com/")
Post by: daminc on February 26, 2008, 08:06:12 AM
I've also been logging my hours on my project. As of Sunday, I'm up to 30 hrs. from the first day pulling the interior and front end. That includes the 3-4 hrs checking the frame for rot during Christmas
Seems like longer when you can't work on it for a while. I may get e couple hrs in on sunday. I'll keep you posted.
Jerry
Post by: TurboCoupe50 on February 26, 2008, 09:59:51 AM
Truly impressive work...
With my dislike of rust, I'd have taken the easy out and bought another car... I've junked far better ones that yours...
Post by: CatCarMan2012 on February 27, 2008, 12:18:30 AM
I must commend you. I still have my 92 rustbelt SC that i can't let go (ive even got new rocker panels to replace the rotted out ones). I bought an auction 88 cougar down south (i moved here recently) and its 100% rust free. Its a still alot of work...but man, bolts can be removed, I'm not always picking rust out of my hair after working on it..etc.
Also, I love the use of Hard disk magnets.
Post by: daminc on March 02, 2008, 04:19:32 PM
Today I finished up some welding
Here's my patch over the subframe. It's not that pretty from the inside, but after the dynamat (or something along those lines) goes in, no one will ever see that patch. the underneath, only has 2 seam lines across it. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3218.jpg)
I welded the seams about every 1 1/2" on the front of the car. Its tough to see after I sealed it up. I figure its better then a couple spot welds. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3217.jpg)
They're a little hard to find after I quickly took the grinder to them. every place the metal was joined got welded. the seam across the top and across the side got end welded and ground down smooth. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3216.jpg)
A quick side shot of the lower rocker front that was made last week. also patched a hole about half way up. A little above the hood cable (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/IMG_3215.jpg)
Next week, I should be able to finish the floor repairs to the back floor and any other parts on the drivers side. after that, I'll seal everything I replaced, and then seam seal all the joints. after that sets, the entire side will be ready for a 2nd coat to permanently seal everything inside and out over the seam sealer. The 2nd coat will be black. It will also be the finish coat. Since I don't plan on driving it in bad weather ever again. I see no reason for undercoating it. The encapsulator is a satin black for frames and underbody, and also UV resistant.
edit: 32 hrs. into it
Post by: ZondaC12 on March 02, 2008, 04:53:23 PM
This is so freakin' cool! Lookin great. Love the floor, that looks so awesome, all clean welded up sheetmetal strewn about! :D You're really blastin' along. Like a peterbilt 379 through a 150 year old blown out barn.
Post by: Chooglin on March 02, 2008, 06:20:21 PM
Simply amazing what you are doing. you have more ambition than I do.
Post by: daminc on March 05, 2008, 11:30:07 PM
All pics taken to this point, are now on my cougar web site. (getting organized) Also started captions on pics on day 1 section.
http://www.daminc.myjalbum.net/ (http://"http://www.daminc.myjalbum.net/") Web site is also in my sig.
Jerry
Title: Project update
Post by: daminc on April 04, 2008, 01:50:44 PM
This has been a busy month for collecting parts.
Just got my SFC's and side rail material this morning. Waiting for my frame braces to arrive. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3314.jpg)
While I'm waiting for the braces, I'll be taking the parts that I need off this Bird. I'll also start fabricating my new frame rails. My car will now have cornering lamps and the full auto lighting package installed in it (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_3282.jpg)
The motor will be pulled when the weather gets a few degrees warmer, and sent to the machine shop. The C-6 thats in it. will also visit a shop as well (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_3287.jpg)
I hope to find the rest of my motor upgrade while I'm putting the body back on the car. I also hope to get everything together for this next coming winter so I can put the motor in during the long winter months.
I'll shoot some pics this weekend to keep everyone up to speed with the project
Post by: mercury-man on April 04, 2008, 02:17:12 PM
daminc, You'll like those corner lights... we have them on our cougar also...Thanks for all of your photos. :cool:
Post by: shorangerbird on April 04, 2008, 03:19:08 PM
-be sure to use that wing off the 'bird too....lol:hick:
Post by: daminc on April 04, 2008, 03:54:46 PM
Quote from: shorangerbird;212540
LOL The wing will be for sale soon
As of now, my car will no longer be "The Flintstone Car" Its about time. My feet are killing me.
Post by: vinnietbird on April 04, 2008, 04:26:38 PM
Great work !!! I wish I had time to work on my Sport.It's been the busiest 3 weeks I can remember having in a long time.BY THE WAY,your trim piece is in route.I hope to have the console,etc,next week if everything works out.
Post by: dominator on April 04, 2008, 11:07:25 PM
Great work man! Only thing i'm wondering is, where did you get a small block c6???? You sure it's not an aod or c4???????? I was pretty sure all c6's had big block bells??? Also make sure when you goto rebuild the SO 5.0L that you use all the HO parts.
Post by: daminc on April 04, 2008, 11:28:41 PM
Quote from: dominator;212593
Thanks Chris, I didn't get to jack it up, but the pan is the shape of a C-6, from what I can tell. (square pan with the side notched back in) definately not AOD. also had one in my 78 mercury. I'm pulling it in the garage tomorrow, I'll jack it up and get some pics of what I got for sure. The motor is going performance all the way around for sure. Like they say, do it right the first time
Post by: 1BadBird on April 05, 2008, 05:53:00 AM
Yes there were small block c-6s. I had 2 of them. One was in my 1/2 ton 4X4 behind a 302 and the other came from a van with the same engine. Nice and easy to modify for extra torque capacity :evilgrin:
Title: Drivers Side Floor Repair
Post by: daminc on April 06, 2008, 08:02:45 PM
As I said, I'll keep everyone updated this weekend. Today was a great day to work on the car. The sun was shining, the birds were singing. and there's nothing like the smell of burning metal in the morning. and to top it off, it was 62 degrees today.
I started today with 1 goal. Finish the drivers side floor.
Here's the rear floor on the drivers side. It's looking a little rough. I had a thought the other day. I would use the floor out of the bird to repair my car. But after I took the carpet out, I found that it was worse then mine. and that car was said to be from California originally.
this is the start of the cut out. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3317.jpg)
Nothing like feeling that your moving in a backwards direction (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3318.jpg)
Here's my piece for a template (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3319.jpg)
Piece cut out (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3322.jpg)
piece bent to fit (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3323.jpg)
Here's the official dry run pic (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3324.jpg)
and here's the official retpuppies pic (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3325.jpg)
Everything is treated with pickelX. including new metal (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3326.jpg)
the piece tacked in (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3328.jpg)
heres the pic of it done (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3329.jpg)
here's the floor all repaired, including the hole where the pan plug used to be. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3338.jpg)
Here's the floor with a quick grind down. I'm thinking It doesn't have to be 100% perfect. I'm just going to cover it with sound deadener again anyway. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3339.jpg)
And the finished product. This is the first coat. all the seams will be sealed before the second coat goes on. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3340.jpg)
Goal Reached!! I still have to finish welding the front and prime it. I should be able to finish the passenger side next week. There less to repair on that side. Then its on to the SFCs, seat braces, and jacking rails. It looks a lot less scary to see a solid floor now. The underside will be blasted and primed, when I do the frame work.
Thats my project for this weekend. Another 5-1/2 hrs. to get added to the time tracking.
TOTAL TIME: 37-1/2 hours
Post by: ZondaC12 on April 06, 2008, 08:42:54 PM
Looks great. I still can't believe how fast you're getting this done. That's dedication raht there I don't care who y'are!!! lol
I was goin nuts this weekend too finally ol' NY winter is going by the wayside. Roads are spotless (at least here anyway) and I been out cruisin' and just enjoying the fresh air. So much better to work on stuff in too. I'm sure the metal-burning experience is enhanced as well. :hick:
Post by: thundr306 on April 06, 2008, 08:42:56 PM
All I can say is that is total dedication to keeping your car. Jim
Post by: Thunder Chicken on April 06, 2008, 09:26:47 PM
This whole thing is incredible (this is the first time I'd seen the thread since getting high speed). Now I wish I hadn't junked that Turbo Coupe now - it was in much better shape, but the front frame rails were shot...
I think you may be the first one to do an actual restoration to one of these cars like somebody would do to, say, a '65 Mustang. Many of us have repaired 'em and refurbished 'em, but you're actually rebuilding yours. Kudos for saving it...
Post by: daminc on April 06, 2008, 10:45:53 PM
Quote from: Thunder Chicken;212883
I think you may be the first one to do an actual restoration to one of these cars like somebody would do to, say, a '85 Mustang. Many of us have repaired 'em and refurbished 'em, but you're actually rebuilding yours. Kudos for saving it...
I'm glad that you can finally get to see the pics. That would have been brutal over dialup. I may have been the first to restore one of these too. (I was 19) It was worse than my car (http://i233.photobucket.com/albums/ee79/daminc/my%20old%20cars/img001.jpg)
Post by: daminc on April 06, 2008, 10:52:53 PM
I also started to restore my moms Vista Cruiser. But she sold it before I finished it.
Post by: ZondaC12 on April 06, 2008, 10:58:14 PM
I remember you posting the pics of the van....but you were NINETEEN when you did that!!!!??? Wow members of the audience let's have a round of applause here! Sheesh. I'm 19 and I can't even imagine undertaking something like that.
Yep this is an in-depth restoration alright!
Post by: daminc on April 06, 2008, 11:13:17 PM
yep, 19 I didn't have a MIG so I got my friend to come by and give me a hand with the panels. (most of my friends worked at body shops) It took 2 of us to hold them up also. I think the one side panel was 9 foot long. I painted the van and painted my 78 mercury the same year.
Just get in there and start working. Thats how you learn.
Post by: ZondaC12 on April 06, 2008, 11:22:38 PM
Quote from: daminc;212908
Yes I'll drink to that alright! I would obviously much prefer to have my dad teaching me everything he was going to....but as it worked out I have his cars instead. :( But that's really what I have done, between getting the '38 on the road (coughf-inbrakescough) and the H.O. conversion in the cougar I've just kinda done stuff arguably on a whim, without too much advance planning. Mom sure hasn't been happy for probably EVERY project I've taken on (how the HELL do I break it to her...there's NO right way, the reaction is never good never never never :D )...but all have turned out okay *knock on wood*. Sure is good because there's no way I could afford to pay someone to do all I've done.
Post by: daminc on April 07, 2008, 07:53:01 AM
Hey, if you ever need help with anything, this is the place to be.
Post by: daminc on April 08, 2008, 08:27:49 PM
Today I got home, and seeing that it was a such a nice day, I figured I could finish the drivers side floor.
I'll skip right to good stuff. this is where I left off a few weeks ago (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/front%20floor/IMG_3341.jpg)
Heres the finished product (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/front%20floor/IMG_3342.jpg)
Its not as pretty as I hoped, It looks a lot better from underneath. Next on the list is a little repairing by the rear wheelwells. I'm also going to open up the floor between the rear frame and treat any rust. It's starting to look like a floor. 2 more hrs today
Post by: daboss351 on April 08, 2008, 08:30:52 PM
Nice!! Did better then me today! I only got half my h pipe fixed and reinstalled!
Post by: Chooglin on April 08, 2008, 08:34:31 PM
you go man...............awesome work you are doing.:bowdown:
Post by: ZondaC12 on April 08, 2008, 08:56:00 PM
Looks BETTER from underneath? Better than that? Wow. I'd love to see it because that looks awesome. Especially considering the sound mat and carpet will be over it, the attention to detail you've given that is remarkable.
Unbelievable.
Post by: daminc on April 08, 2008, 09:14:05 PM
Lol
I guess it's better then the first pic (http://i233.photobucket.com/albums/ee79/daminc/IMG_2972.jpg)
The problem with this side, was I didn't have anything to work from. I really didn't know what it was supposed to look like. the other side will be easier
Post by: ZondaC12 on April 08, 2008, 09:33:03 PM
Right riiiight I gotcha now. Yeah they gotta put all these weird patterns into the pan! Ugh couldnt it just be a flat plane? :hick:
So when do you think you'll have it done and ready to go? That would be sick if you could cruise around in the summer and bring it to cruise nites with a bigass photo album showin off all the hard work. :cool: :cool: :cool: :cool:
Post by: daminc on April 08, 2008, 09:59:37 PM
Now that the weather is getting warmer and the days are longer, I could work a couple hrs every day or so. I figure now that there's more time to work on it. I should be doing exterior body work on it at the end of june, beginning of july. The motor still needs to be pulled, and the engine compartment needs to be redone.
I'm not going to try to rush it. It takes as long as it takes sometimes
Post by: baxo on April 08, 2008, 10:02:26 PM
That's amazing stuff. Makes me wanna go check it out in person hah.
Post by: daminc on April 08, 2008, 10:10:15 PM
Quote from: baxo;213212
Let me know, your just right around the corner from me.
Post by: baxo on April 08, 2008, 10:11:40 PM
hah exaclty, I was right along the border even tonight, Took a nice stroll down by the gorge in Niagara On the Lake with my gf.
Post by: daminc on April 08, 2008, 10:19:20 PM
let me know when your in the area next time
Post by: daminc on April 09, 2008, 06:38:40 PM
I decided to cut open the rear frame to see how bad it was inside. the same amount that was in the front. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3344.jpg)
While I had it open, I coated it with encapsulator (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3345.jpg)
Cut a new piece to cover it up. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3347.jpg)
Welded it on (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3348.jpg)
I still have a little more to fix in this area. 4 more hrs today. 43-1/2 total, with yesterdays 2
Post by: mercury-man on April 09, 2008, 11:43:25 PM
Hey, Jerry do you ever feel like the (Energizer Bunny) because this project just keeps going going going....and it's also keeping us more anxious to see what the final outcome will look like. Just keep the pics a coming. lol :headbang: :grinno:
Post by: daminc on April 10, 2008, 09:19:11 PM
Todays project, Finish up the rest of the drivers side floor.
Last of the drivers side patching. there was a couple small holes around the wheelwell, so I patched the entire thing for reinforcement. Boy I love those hard drive magnets. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3349.jpg)
I remember taking more pics but there were only 2 on the camera when I uploaded them. (strange) So here's the finished product. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3350.jpg)
1-1/2 hrs today I only started 2 fires today. I forgot about the undercoating. lol Until tomorrow . . .
Post by: DerikWayne on April 10, 2008, 09:33:15 PM
I know you probably explained it, but what is that red stuff you're applying on everything after you're finished? What are the benefits of using it?
Post by: daboss351 on April 10, 2008, 09:41:28 PM
you have inspired me, so i went and bought 48 dollars worth of sand paper and fiberglass and got to work dont have a welder, or any cutting tools so I went for next best
Post by: daminc on April 10, 2008, 09:41:41 PM
The red stuff is encapsulator, I use it to prime/seal the new metal and seal in any rust on the old metal from the air. regular primer won't seal out the air, and it could rust again in the older parts of the car. the first coat I use is red, then I seam seal everything, then I use a black encapsulator for the finish coat to ensure that I cover over everything again.
Post by: daminc on April 10, 2008, 09:43:00 PM
Quote from: daboss351;213493
You go dude! Don't forget the pics
Post by: 1WLD BRD on April 11, 2008, 04:29:43 AM
X2 man,, though maybe I shouldn't might make me change my mind about srapping the '85....:hick:
Post by: baxo on April 11, 2008, 07:54:48 AM
Well RJ your 85 is in no worse condition then this so if he can do it, so can you, and then Niagara region FTW!
Post by: daminc on April 11, 2008, 08:05:50 AM
If you really want to keep it, and you can weld, It's the cheapest but longer way to go. You can also go through the whole car piece by piece and change anything also
Post by: daminc on April 11, 2008, 05:47:25 PM
Everyone has to be bored with this thread by now. LOL Well you better pay attention, because there will be a quiz at the end.
The last small piece to repair on the drivers side yes the car rusted underneath since the last time I worked under there. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/floor/IMG_3351.jpg)
Here's everything all ground down and ready to treat the rust (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/floor/IMG_3352.jpg)
I treated everything with PickelX wiped it down, let it dry, and started to do the nasty (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/floor/IMG_3354.jpg)
And todays good news is: I'll have time to work on my car this weekend. the better news is: My Monday job cancelled, and I'll have all week to work on my car. including next weekend.
Thats all for today my friends. Tomorrow's another day 3 hrs today
Post by: dominator on April 11, 2008, 06:51:25 PM
Good job man but OMG i have never seen so much rot on one vehicle. Dam,i sped my 88 for less.
Post by: daminc on April 11, 2008, 07:30:22 PM
When I was young, I would make models that had pieces missing and use extra parts from others.
This is just a larger scale. LOL
Post by: mercury-man on April 11, 2008, 09:06:52 PM
Yes, Jerry and those kits also came with a guide book that had (MAN'S) most feared words on there too. "SOME ASSEMBLY REQUIRED" :evilgrin:
Post by: daminc on April 12, 2008, 07:42:44 AM
It also keeps me off the streets. And my wife knows where I am LOL
Post by: daminc on April 13, 2008, 06:47:46 PM
here's today's little project I've got the frame connector in position to mark the floor to cut (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3382.jpg)
Here's the frame going through the floor that I just repaired (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3383.jpg)
Here's a shot of the frame and Chucks connector. It still needs to go up into the floor a little more (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3386.jpg)
heres another shot (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3387.jpg)
here's a pic of the frame with Chucks connector. saved me a bunch of time, Thanks Chuck (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3385.jpg)
I only had 2 hrs to work today. I drove with my wife to take another dog to their forever home this morning
I'll finish up this side tomorrow and start working on the jacking rails and cross-braces.
Post by: Chooglin on April 13, 2008, 08:13:42 PM
I just cant believe the passion,patience and skill you have. I never in my life ,could do what you have done here..............:bowdown:
Post by: 1WLD BRD on April 13, 2008, 08:35:56 PM
man... My '85 cougar didnt need half that work, and I sped it. I even replaced a front Pass. frame rail, font rad support, welded up all the swiss cheese in the engine bay, and other areas that needed patches I made up and welded up. Then one day I just said "screw it, it will never be worth what I am putting in it." and bought my '88 XR-7.. now the '85 is crushed and getting recycled.....
Post by: daboss351 on April 13, 2008, 09:14:21 PM
Now that makes me want to actually fix my mark, since your underside is about 75% worse then mine, mines pretty bad though....
Post by: thundr306 on April 13, 2008, 09:20:25 PM
Slow down, you are making me look bad!
Post by: daboss351 on April 13, 2008, 09:23:52 PM
Technacally hes making us all look bad fixing a fox thats worse then many we have junked or parted. Hell my 88 turbo coupe isnt as bad as that, needs a frame rail which I had, and rear quarters. The rest is solid.... but its been parted and is now a almost bare shell
Post by: daminc on April 13, 2008, 09:50:14 PM
To be honest, I probably wouldn't be doing this if Mike (FLSTCI71), didn't find me those full rust free quarter panels and fenders.
Post by: daminc on April 13, 2008, 09:53:09 PM
and wait till you see my next project.........................
Post by: ZondaC12 on April 13, 2008, 10:00:43 PM
HAHA oh no......oh jeebus I wonder if I WANT to see it lol
Post by: mercury-man on April 13, 2008, 10:22:39 PM
Jerry, are you going to restore a T-bird for your wife? Some curious minds would like to know. :dunno: ;)
Post by: daminc on April 13, 2008, 10:47:54 PM
Just to show everyone who has sped a car that was in better shape then mine. I also have sped cars that were in better condition. Here's the last one I sped. took these pics the day before it got picked up (http://i233.photobucket.com/albums/ee79/daminc/cadillac/113-1316_IMG.jpg)
Post by: V8Demon on April 13, 2008, 10:51:18 PM
Wow. What was wrong with it?
Post by: daminc on April 13, 2008, 10:56:27 PM
Its a caddy, warped the block they don't make replacements for it, and all the motors in the JY are probably the same. or going to be shortly
The motor was in the trunk in those pics
Post by: daminc on April 14, 2008, 06:50:52 PM
Alright, enough about the one that got away.
After working at my moms all day I came home and did some adjustments to the frame. I also clamped on the jacking rail and figured out the angles to cut the cross-braces from the frame to the rail (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3388.jpg)
I love those hard drive magnets (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3390.jpg)
the frame is lower then the rail so I have to cut compound miters on all the braces. I test fitted 1 in various places to be sure it fit correctly. now I just have to cut a bunch, tack them in, and pull everything out to weld it. Then try to get it all back in position. I do notice that my entire car lifts nice and easy on this side now, and nothing is welded yet. I also have to remember to leave enough room for the E-brake cable, when doing all this. It looks like it's going to be close (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3389.jpg)
I hope to get everything cut and welded together tomorrow (I hope) not much to talk about today my friends. just a couple pieces of metal.
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: mercury-man on April 14, 2008, 07:15:54 PM
Hey, Jerry it's the little things that count so just keep pluging away everything there looks great. :headbang:
Post by: thunderjet302 on April 14, 2008, 07:36:41 PM
Quote from: daminc;213857
Took it out and ready to be welded (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3395.jpg)
OK, I may be overdoing it a little
Post by: daboss351 on April 16, 2008, 12:42:58 PM
well now you have to put the 5.0 in and mod it. Hell I bet those will make that car stiff as hell! Should handle well, so yea, tell me what you bought for material and after cat jam, we can go to your garage and build me some!
Post by: daminc on April 16, 2008, 01:13:12 PM
Is the frame the same on a mark?
Post by: daboss351 on April 16, 2008, 01:22:48 PM
I wanna say yes, or its a little longer.
Post by: daminc on April 17, 2008, 07:01:33 PM
Been a VERY Happy Birthday working on the car, without interruptions. I welded the SFCs and rails this morning and cleaned them up (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3396.jpg)
I think it should paint up pretty nice. I have to weld the seat braces after I fit them again. the notch seems to be off a smidge
Next on the list is the rocker and quarter replacement. Here's how it ended up so far, before today (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3399.jpg)
Here is the cut to start the day got some rust there. LOL (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3400.jpg)
These may be from California, but there's still rust hiding in there (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3406.jpg)
Next, I have to piece in the door jamb and separate the rest of the quarter panel, before I can cut mine off.
Post by: Thunder Chicken on April 17, 2008, 08:20:48 PM
I was afraid that your rocker repairs would look good but leave the structure compromised. After looking at those subframe connectors it looks like that ain't gonna be an issue :hick:
Post by: daminc on April 17, 2008, 09:25:50 PM
Quote from: Thunder Chicken;214490
I did take into consideration the weakening of structural members on the car. originally I wasn't going to use them, but after cutting up the car, I figured it would be the best thing. thats the main reason for the rails. There's a couple more braces that are also going in, that are going to be welded to the floorpan. the seat braces are also going to be welded to the seat bolt frames and floor. There's a couple more things I'm going to brace on the car as I put it back together. If anyone has any recommendations for support, please let me know.
Post by: 1WLD BRD on April 18, 2008, 11:47:53 AM
I am VERY impressed by the subframe connectors.... Nice work!
Post by: daminc on April 18, 2008, 12:48:57 PM
Thank you, I think Its turned into a total restoration project now. not just repairs
Post by: mercury-man on April 18, 2008, 01:57:14 PM
Jerry, You can say that again dude only with alot of (pride and sweat) to go with what you've accomplished so far. :welder:
Post by: daboss351 on April 18, 2008, 02:26:48 PM
Not only a total restoration, more like a resto-mod! My jams look like that.... That scares me...... , I cant afford to go that far as what your doing.... I guess I NEED subframes now...
Post by: CatCarMan2012 on April 18, 2008, 04:15:55 PM
I feel that I should donate you my white 88. You would appreciate it more. I'm just slapping it together to flog on for a while and learn body work. I bought it down here at a police auction with 0 rust. :raspberry Let me know if you need some rust free parts though.
Post by: daminc on April 18, 2008, 05:23:01 PM
Here's my test fit after welding yesterday (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3421.jpg)
Heres a pic of it not fitting right (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3422.jpg)
Heres the reason. had to notch for a cross-brace (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3423.jpg)
Take 2! (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3424.jpg)
Thats what I'm talking about. Like a glove (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3425.jpg)
And the inside (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3427.jpg)
here's some reinforcing I did yesterday on the support posts inside the rocker (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3428.jpg)
spent some more time separating the quarter panel. its getting lighter and easier to move (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3432.jpg)
As I was moving things around today, I pulled out the new bumper cover for my car. Found my old bosch driving lights I had on my cougar, and what do you know. They fit (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3430.jpg)
Yesterday and today combined: Another 8 hrs. Total Hours: 65
Post by: Beau on April 18, 2008, 06:54:02 PM
i know it's not much, but all i can say is wow...
Post by: t3skidoo on April 18, 2008, 07:54:53 PM
Looks like that cat is going to be S-O-L-I-D.
I'd be interested in what the final weight ends up being.
What are your plans for paint?
Post by: daminc on April 18, 2008, 08:04:16 PM
Quote from: t3skidoo;214665
Color? or product
Post by: t3skidoo on April 18, 2008, 08:48:00 PM
Both, but more about 'when'. Are you going to paint as you progress, or is it getting done all at once?
Post by: daminc on April 18, 2008, 09:12:26 PM
I think I'm going Black or a dark charcoal for color. Probably base/clear. Although a good single stage with wet look hardener has a warmer feel to the paint. mine still shines like its wet. I'm going to paint the entire car at once. but I'll probably paint all the jambs first while I have the car apart. I'm going to strip the entire thing also. there's to much paint on the car now to do a repaint . I'll epoxy prime it first (mainly so it doesn't rust while I'm finishing the work on it), do any filling or dent repair. Hi-build prime it, then long block it until there's no waves left, before I paint it. then cut the color and buff. It should have a perfectly smooth mirror finish like my last car did
Post by: Haystack on April 18, 2008, 11:34:28 PM
check out the charcoal gray in the 86 cougars. Those are just plain shagy. I like you work. And you have those hard drive magnets everywhere!
Post by: daminc on April 19, 2008, 07:29:13 AM
Quote from: Haystack;214705
Thanks, I'm going to check the stock colors first. But I don't think It's going to be one.
Yes, there's hard drive magnets everywhere. I also have to keep them on the edge of the door, otherwise I have to try to pry them off with a screwdriver when I need one. there's about 12 -15 floating around the car somewhere. I'm sure I'll lose at least 1 in the car before I'm finished. LOL
Post by: DVP on April 19, 2008, 01:28:36 PM
Quote from: daminc;214738
The 06(I think) fusions had a really really nice charcol color. If i could decide on a two tone i would use that with black.
Post by: daminc on April 19, 2008, 01:43:03 PM
I'm thinking metallic charcoal thats almost black
Post by: daminc on April 19, 2008, 05:51:06 PM
Here's todays fun filled hour
I cut the quarter away to see how much rust was in the wheelwell (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3434.jpg)
After finding rust on the outer wells (like I didn't see that coming) I just cut them off. Its easier to put another one on, then to try to fix it. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3438.jpg)
I finished separating the new panel and cut it down to a more user friendly size, just keeping it a few inches bigger then the size I'll need. Here's a dry run with the panel on top of mine. I'll need to remove the bumper and cut away some more to make it fit correctly. It's hard to explain what will be cut, so i'll have to take some shots as I'm doing that next time (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3441.jpg)
So that was my hour of fun today. I hope you had fun checking out the pics. Anything is better then fixing floors. If anybody needs these parts to repair a damaged back end, let me know. I'll be putting them in storage for someone that needs them (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3445.jpg)
Thats all my friends, until tomorrow
Post by: DerikWayne on April 20, 2008, 02:31:23 PM
You are doing an absolute amazing job! I try to check this thread at least once a day to see how it's coming along. When this car is finished, I really want to see it in person one day. :)
Post by: DVP on April 20, 2008, 03:29:22 PM
THis is the color i was talking about. It looks amazing in the sun.
Post by: daminc on April 20, 2008, 04:10:09 PM
Quote from: DerikWayne;214898
Thanks, I'll let everyone see it when its finished. Probably Catjam Next year.
cougar86_89 ......I think that is the color that I've seen and liked. I didn't know what car I saw it on though, thanks
Post by: daminc on April 20, 2008, 04:29:53 PM
Todays 2 hour project consisted of removing the rear lights and bumper cover. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3448.jpg)
Then I moved on to, cutting down the new panel for my car (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3449.jpg)
Which was followed by tpuppies the panel s off my car for a better test run. There was a lot of measuring and remeasuring before I cut any of the panels this afternoon (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3450.jpg)
Heres another test of the panel on the car. got some of the rocker pieces screwed on for the moment. the quarter needs to raise up in the back about an inch. I still need to cut some more to fit it. but its looking good and tight (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3452.jpg)
Post by: mercury-man on April 20, 2008, 04:45:22 PM
Jerry if you use that black paint scheme plus the red interior it'll be the same color combo as ours too. :cool: :headbang:
Post by: CatCarMan2012 on April 20, 2008, 04:58:14 PM
Thats what I should have done (paste a new side on the car). Instead I spent uncountable hours bumping, sanding, filling, and sanding my rear quarter.
Oh, well, lesson learned.
Post by: daminc on April 20, 2008, 10:00:57 PM
Quote from: danzajax;214923
Thats also a lesson I've learned years ago. If it wasn't for my friend Mike and his quick thinking, I would have had to rebuild both quarters from scratch. Apparently, perfect rust-free full quarters (with wheel wells) are hard to come by. Unless they're still driving around on the back of a rust-free car. ******************************************************************************************
For this part of the job, I'd like to once again thank Mike (FLSTCI71), for all his help in getting me the parts needed to rebuild my car
The color is Charcoal Beige. Looks different colors in different light. From almost silver gray to black at night.
or just black. hmmm (http://i233.photobucket.com/albums/ee79/daminc/1ZVHT80NX85152917-1.jpg)
I think I like the fusion color better
Post by: daminc on April 25, 2008, 06:49:15 PM
It's been a few days since I worked on my car, and had 2 hrs to do some prep work for the big event.
I cut out the trunk well and fitted the panel to be marked and cut. Got the panel exactly where I needed it and used tape to mark the edge to cut. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3458.jpg)
here's a couple outer pics of the old and new well (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3459.jpg)
checked to make sure everything still lined up, before removing the panel (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3461.jpg)
here's the back end. needs a little fixin before the panel goes on (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3462.jpg)
Here's the part I'm going to repair before the panel goes on (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3465.jpg)
Everything marked and ready to cut (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3469.jpg)
Now, not a lot really freaks me out in life. But knowing that I only have pretty much 1 shot at doing this, kinda does. I have done this many times before, but it's pretty impossible to get these pretty cheap, if at all
so here's the cut. Not a lot left. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3470.jpg)
So this is where I'm at until tomorrow. I got a little jamb rebuilding and small back end repair to do. I'll tack the backing strips on tomorrow also so I can line up the rocker and jamb while I work on them.
Until Saturday my friends. OK 1 more. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3473.jpg)
Post by: daminc on April 25, 2008, 06:52:59 PM
Does anyone know if this thread can be saved pics and all?
Post by: Thunder Chicken on April 25, 2008, 08:09:31 PM
I think if you printed it to a PDF file it would save, but you'd have to do it page by page. Foxit makes a good free PDF reader/writer (MUCH less bloated than Adobe Acrobat)
Post by: vinnietbird on April 25, 2008, 08:42:39 PM
Amazing work.I wish I had a welder.......and knew how to use it.Once our daughter gets out of the house and into college next year (or later this year actually),I may just get one and take a few classes.
Post by: thunderjet302 on April 26, 2008, 12:00:04 AM
Quote from: daminc;214965
Hey leave my quarters alone (runs outside to check the garage).
Wow you're doing a great job. Are you going to clean up the rear frame rails while you have the quarter off?
Post by: daminc on April 26, 2008, 12:12:08 AM
Quote from: thunderjet302;215785
I'm going to clean up what I can get to, and coat what I can reach while I'm there. I'm going to strip the undercoating off too (yuk) (may just torch and se it)
Post by: 1WLD BRD on April 26, 2008, 07:53:25 AM
Holy I gotta stop reading this thread....
You are seriously making me regret sping my '85.... :(
Nice work on your car man...
Post by: daminc on April 26, 2008, 08:27:51 AM
Quote from: 1WLD BRD;215801
Thanks, In a few weeks I should be about 1/2 way done with the rebuild.
Like I said before, I wouldn't be doing this if I didn't stumble across all the parts that I needed in one convenient location. It would have been stripped, sped and put into another car, as much as I would have hated to do.
I also did price how much it would cost to ship a fender from Vinnie in Oklahoma to NY. 1 fender--$120 I couldn't imagine how much it would cost for the full quarter. I would guess $350 plus the price of the panel. ( I got 2)
On a side note, I was talking to my neighbor and found out, he has a 2-1/2" pipe bender. I'm thinking I could have some fun with that. And he said, he could repair any frame problem that I came across. He's done it professionally since the 50s. (The things you find out about someone after 10 years) LOL Also my father-in-law is getting gung-ho about the motor part of the project. He's built drag cars since the 60s, and hasn't had a project in quite a few years. This should start to get interesting as my car starts becoming whole again.
Well, off to work on the cougar. I'll post some more progress pics at dinner time like always.
Jerry
Post by: thunderjet302 on April 26, 2008, 10:57:01 AM
Just a question but what are you going to do about the side molding between the wheels? Do you have any of it in good shape or are you going to try to restore the old stuff?
Post by: daminc on April 26, 2008, 10:59:59 AM
Quote from: thunderjet302;215816
Parts car;)
Post by: *MAYHEM* on April 26, 2008, 04:36:47 PM
I'm glad you're documenting all of this, 'cause from what I see no one will believe what you started with when it's done. That's some fantastic work you've done.
BTW: We need a "standing ovation" smilie.
Post by: daminc on April 26, 2008, 06:09:54 PM
Quote from: *MAYHEM*;215849
Thank you sir. These are for you my good man. Sorry, no dip (http://i233.photobucket.com/albums/ee79/daminc/party%20snacks/lays-potato-chips-regular.jpg)
And back to the last question. All my side moulding is in great shape except for the pass. side door. It got a little wavy when I took it off. I'll replace it with the one from the bird, and grab the rest for extras.
I started out planning to work on the car all day, but you know how that goes. I did get all the outside lights changed over to the new ones today, and talked with my father-in-law about progress and future plans and upgrades for it.
So after all that, I got to work on my car. I started with putting it together. for another test fit. I also zip screwed the new door jamb parts together to be tack welded. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3476.jpg)
And then after the last check, and parts screwed together, it was time to take it apart and start welding the jamb. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3484.jpg)
and apparently other parts that were never welded. this post holds the front seat belt. glad I never had to trust my life with it. It would have peeled back like a can of spam. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3485.jpg)
this is where I left off today after 2 more hrs of work. I'm welding everything that I find in here too (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3486.jpg)
Until tomorrow. Now lets eat those chips :D
Post by: CatCarMan2012 on April 26, 2008, 10:59:15 PM
Beautiful fit. Wish I could help.
Post by: daboss351 on April 26, 2008, 11:05:39 PM
my mark needs that, BAD but O well
Post by: ZondaC12 on April 26, 2008, 11:15:20 PM
Holy shiznit that's so freakin' cool!!!!! It just all fits togther like a GLOVE. That's so cool-lookin. Awesome.
Are those magnets meant for panels like this? Or are they from hard drives they look just like hard drive magnets, which, would make great magnets for this, those suckers are BRUTAL!
Post by: daminc on April 26, 2008, 11:20:18 PM
LOL I love my hard drive magnets, I had a bunch of used drives left over from my store. I was going to toss them, so I decided to yank all the magnets first. Glad I did now.
Post by: ZondaC12 on April 27, 2008, 09:41:05 AM
Yeah I kinda figured you either built your own PC and were into that as a hobby too kinda or were in the business somehow. Cool. Can't argue with it, works great obviously!
Post by: daminc on April 27, 2008, 05:52:05 PM
Not a lot to take pictures of today. Just a lot of undercoating to get off. I did find some rust under the undercoating, but nothing to really worry about.
Here it is all bare, and a little burnt, (I used a torch) (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3491.jpg)
I blasted it and gave it a coat of encapsulator, just like everything else. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3492.jpg)
Not a lot of change, but equally important.
Post by: daboss351 on April 27, 2008, 05:53:43 PM
You can buy my mark for your next project as im prob never gonna be able to drive the thing....
Post by: daminc on April 27, 2008, 10:02:29 PM
Don't Talk like that. Never give in without a fight. A well thought out and cool, calm appearance, letting them know you knew it was a mistake before it even happened. can go a long way sometimes. Sometimes you just never know til you try.
Jerry
Post by: EricCoolCats on May 01, 2008, 12:58:41 PM
Me make thread 'sticky' now...it's important enough.
WOW, that's a lot of work...
Post by: daminc on May 01, 2008, 05:38:49 PM
Hey, this is easy to find now. I hope someone learns a little something out of all this, besides the importance of buying a car with a whole floor. LOL
I decided to weld the quarter on this weekend. So in order to do that, I decided to seal the seams I couldn't get to after the panel goes on. This is what I'll be using on the whole car, mainly because it doesn't harden and crack. Real good stuff. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3501.jpg)
This was my main reason for opening the tube. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3500.jpg)
and since it was open, I also decided to seal everything I could with the open tube. So here's a lesson in duplicating factory seams. First, You need a seam. Here's a nice one to show. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3493.jpg)
Next tape it off on both sides of the seam, and apply sealer (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3494.jpg)
Brush it in filling all the voids and leaving lines in it from side to side. should look like this when done. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3495.jpg)
Then pull the tape off before it starts to set. You now have a factory duplicated seam. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3497.jpg)
If your into show car restoration, this will look factory after it gets painted.
Now the bulk of the seams, which if you remember, were on the floor and inner rocker. I wasn't real fancy with the welding and grinding for this reason. after the floor gets sealed. Another coat of encapsulator gets put on. And then, if I decide to paint, the finish paint will go on. And then on top of that the sound and heat mat. Since I'm not painting it white again. black or a dark gray color will look good with the color I've chosen to paint the car. And I also don't need to finish paint the inside, because the next color of encapsulator is black. All the seams that were welded got sealed, just in case of a pinhole anywhere. we don't want it to rust after all that work. I brushed it on to smooth it out a little (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3502.jpg)
Here's a view I hope I never see again (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3506.jpg)
And a little sealer over the patch in the front (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3498.jpg)
Now, i'll just let that set and finish welding my door jamb, and get ready for the panel.
A little closer every day. 30 min today, but sealed forever. I know, that sounded stupid. but its my post. LOL
Post by: mercury-man on May 01, 2008, 09:58:42 PM
Hey,Jerry your Stoneage Bedrock Project has become a New Age Evolution Project with alot of sweat & growing pains to go with it also. Way to go dude :headbang: :cool:
Post by: dominator on May 01, 2008, 10:33:31 PM
What's with the frame hole???????
Post by: daminc on May 01, 2008, 10:37:20 PM
Frame hole? the one in the floor?
Post by: ZondaC12 on May 01, 2008, 11:34:27 PM
Nahh I think he means up front in your subframe in that last picture.
STICKY!!!! Woohooo now youre in the cool-peopls's club. All ya need now is a Members Only jacket!
Post by: daminc on May 01, 2008, 11:41:55 PM
Oh, behind the front tower I have to pull the motor for that one, its coming
Post by: vinnietbird on May 02, 2008, 08:33:02 AM
What is the look you'll be going for when it's finished?
Post by: daminc on May 02, 2008, 08:44:29 AM
Quote from: vinnietbird;216724
LOL.....Not rusted.........LOL
Post by: thunderjet302 on May 02, 2008, 11:15:49 AM
Wow that looks great. Do you have to replace the passenger side quarter as well?
Post by: daminc on May 02, 2008, 11:33:39 AM
Quote from: thunderjet302;216752
Yes, but I think less of it on that side. Less floor to repair, and I think the rocker is in good shape. But I probably may cut it open and replace it. It feels a little thin. It's rusting from the inside, I'm sure of it. I'll probably be close to starting the other side next week end. I'll do all the bodywork after the entire car gets put back together.
And as I said in one of the last couple posts, the motor will be coming out soon to work on the entire front end, as soon as it comes off the ramps. I'll need to take the front end apart . so off the ramps and on to the stands. But thats probably about a month away.
Post by: daminc on May 02, 2008, 05:20:38 PM
I did a little 2nd coating this morning (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3515.jpg)
After I ground the paint off I put Pickelx on to keep it from flash rusting over night. I would have taken more pics while I was working, but my battery was low. another 2-1/2 hrs. today. Tomorrow I'l finish the prep work and refill my gas bottle. drill a bunch of holes around the wheelwell for welding and do one last test fit before welding. tomorrows post should be a good one, if everything goes as planned
Post by: DVP on May 03, 2008, 12:06:31 PM
Quote from: ZondaC12;216707
:bowdown: You have now achived the Sticky Status.:bowdown:
Post by: daminc on May 03, 2008, 06:32:10 PM
hmmmm...Sticky status I guess that means I have to actually do a good job with the finish product. Oh the pressure. LOL... I thought I would work my way up to tacky first. (Drums.....tada dum)
Here's what you been waiting for.......................
I cut down some backing strips from the replacement quarter, so the curve of the panel matched the strips. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3523.jpg)
Ground the paint off (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3524.jpg)
And put them on the car for a dry fit. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3525.jpg)
Then used my hole punch to put holes every 1-1/2" (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3526.jpg)
Of course did a test run for welding and penetration (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3527.jpg)
Adjusted the settings some more (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3528.jpg)
And welded the backing strips on (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3529.jpg)
Then I had to do a little cleaning up on the new panel (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3533.jpg)
That is a lot of undercoating, wish my car had that much to start with. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3534.jpg)
Got the panel on the car again (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3535.jpg)
I coated it with pickelx to keep it from rusting until I do all the body work at one time. Next to finish the rocker and frame About 6 hrs between yesterday and today.
Post by: daboss351 on May 04, 2008, 05:44:33 PM
looks good!!
Post by: thunderjet302 on May 05, 2008, 09:42:42 AM
Looking great :D
You know if you really like doing this come to Chicago. I'm pretty sure I could find you an 88 XR-7 that's rusted just as bad, if not worse, than your car was for $200 :hick:
Post by: daminc on May 05, 2008, 10:18:43 AM
Quote from: thunderjet302;217278
Looking great :D
LOL.... NY has just as many, the 87 bird sitting in my driveway is about as bad. the back window leaked and the whole floor is rotted out, Makes mine look good. not to mention the trunk wells were filling up with water. I had to drill holes in them to drain the water.
If the cars were worth something, I would make some money off rebuilding them, mabe in another 20 years. But I would be to old to care then (my knees hurt now). I'll have to hand that job down to someone younger on the board. LOL.... You want it?
I'm looking for another project after this one. I already have one in mind if its still available when the time comes. Might be that 70 cougar, that cougar1car is selling. I'll have to see, although my wife wants a 67-68 cougar
Post by: cougarXLS on May 05, 2008, 12:49:41 PM
daminc, this is truely remarkable... thank-you for giving me hope for my Cougar X.
I must learn to weld :)
Post by: daminc on May 05, 2008, 01:26:14 PM
hope is the easy part, finding the rust-free panels are the hard part.
Welding is easy
Post by: *MAYHEM* on May 05, 2008, 09:00:40 PM
When you finish that, I have a real challenge for you:
Post by: dominator on May 05, 2008, 09:12:53 PM
Now,what kind of car was that?????????????????? Looks like it was sitting in what once was a river??????
Post by: daminc on May 05, 2008, 09:14:27 PM
LOL.. Well it looks like there's no rot, and all the pieces are there. Dude, I can fix it. My dad's got an awesome set of tools, he's a TV repairman.
You bring it over, and I'll see what I can do. LOL
Post by: ZondaC12 on May 05, 2008, 09:38:28 PM
I think that *was* a 1947-ish Buick. Definitely GM whatever it is.
Post by: ipsd on May 05, 2008, 10:04:26 PM
Quote from: daminc;217384
Sure thing Spicoli.
I wanna see that one. Your work looks great.
Post by: daminc on May 05, 2008, 10:40:29 PM
It's official, My wife and I will be going to Catjam. Fri-Sun morning. Made our reservations a few day ago. The bad news is, I will not be at the picnic until afternoon because we are also going to the dog rescue picnic 40 min. away in the morning. Hopefully I'll get to meet everyone at some point. I'll be easy to find. I'll be the one without a cougar. lol
Post by: *MAYHEM* on May 05, 2008, 11:18:38 PM
Thank you Mr Spiccoli. ;)
Post by: SR71TC on May 05, 2008, 11:30:38 PM
Hahaha...Love that movie.
Post by: daminc on May 08, 2008, 11:00:03 PM
So where did I leave off.... Frame rails and floor. I had to do some seam sealing under the car before I could install the frame. I also did some encapsulating and sealing before the frame too. otherwise I would never be able to get to some of these places in between the two. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3556.jpg)
There's no way to get a good pic of the underneath of this car, so I used a mirror I had kicking around. some are not the greatest of pics. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3557.jpg)
so there we have it. everything is ready to go back in. I'll test fit it again tomorrow and put one more coat under the car just in case. Sat. I should be ready to weld everything together. I also have the rocker ready to get welded after the frame gets welded to the rocker lip. Oh yea, I need to do a little last minute seam sealing at the back end of the rocker. I also see a lot of paint and undercoating flaking off the rest of the back end of the car past the floor. which is a good thing, Less heavy rest to deal with. looks more like surface rust then damaging rust, I'll try to get a pic of what I mean but thats going to be tough that close to it. but I'll try. until tomorrow.
Post by: daboss351 on May 08, 2008, 11:33:21 PM
what an improvement!!! thats gonna be something your gonna be able to be proud of for a long time!
Post by: daminc on May 09, 2008, 08:28:18 AM
It's actually starting to feel like I'm working on a car now, not some rusted can with paint on the edges. Its also a lot of work, but I figured that if I got another car, I would have stripped it and done most of the same work on it anyway, minus the metal replacing of course. And it does feel good to step back and see the progress I've made since the end of December.
Post by: mercury-man on May 09, 2008, 10:53:07 AM
Jerry, You've taken baby steps but the big picture is starting to look clearer...and somewhere down the line you will be a proud (PaPa) I mean Cougar owner again I'll bet. Way To Go Daminc !! :headbang: :cool:
Post by: daminc on May 10, 2008, 11:26:35 PM
So I've been having computer problems since Wed. when my powerbook cooked another logic board. Not sure if I'm going to get it repaired or get a new one. I at least have my studio computer to use. I don't like being on the net with it, but I have no choice at the moment.
Things are still happening, even though I haven't been on much, because this computer is on a different floor, and its tough to be with my wife and on the computer at the same time. But enough about the computers. I was sealing and coating the last couple days to prepare for the frame/rails. Its always in Gods hands when you have to let something dry, to move on to the next coat. so I ended up losing some time doing just that. remember, watched seam sealer won't cure. Here's my progress of the floor and frame/rails. this needs to be seam sealed and coated. and this side is officially done!!!!! (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3566.jpg)
Here's the frame tacked in place and ready to weld. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3567.jpg)
I found out that I can't lay on my bad shoulder and weld. Thats ok, I'll hit it with a grinder and it will get covered with the rocker, which will again be plug welded every 1" to the rail. You can also see that I step d the existing rocker instead of putting a backer piece on. the reason was, that I didn't have enough room to put it in because it's so close to the bend. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3573.jpg)
and speaking of rocker Here it is ready to go on (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3572.jpg)
Until the next time, Th Th Th That's all folks.
Post by: daboss351 on May 10, 2008, 11:49:34 PM
Looks freaking sweet!! You have inspired me to build something for my car. Dont have enough stock for SFC's, but I have enough thick square tubing to use to build a strut tower brace. Got an oxy torch at school to bend it, and a mig there so I can prob fab it up! I'm also getting a new set of rear control arms to put poly bushings in, and brace and box.
Post by: Bob on May 11, 2008, 01:06:36 AM
WOW! great work! I read all 24 pages tonight. I need more! whats next?
Post by: daminc on May 11, 2008, 08:15:55 AM
Quote from: Bob;218328
I didn't realize there were 24 pages. You must have been up for a while. LOL
I have a small rust spot on the trunk edge on that side, and then its on to the other side. but first I have to finish the rocker and seam seal the rest of the side. I should be done with it by next weekend.
Post by: DerikWayne on May 12, 2008, 05:17:39 PM
Quote from: daminc;218026
It's actually starting to feel like I'm working on a car now, not some rusted can with paint on the edges....
I can actually say I can relate to that feeling, lol. I had a Bronco that make me feel that way... and like most people, I gave up on it. Kinda makes me feel bad after seeing what you're doing to this car.
Post by: daminc on May 12, 2008, 06:09:31 PM
In case anyone is interested in the history part of the project. I found the bill of sale for the cougar. I paid $8,370.00 for it on October 12, 1989 and was paid off in November 4. 1992
Yep, I had it for a looooooooooong time
Post by: daminc on May 16, 2008, 05:25:42 PM
So keeping with the weekly update of the project, I got a couple pics of a little something I have done in between other things.
Here is the inside finished and seam sealed. just needs a little paint. That is the frame going through the floor, in case you just joined us. The black that I'm using has a great satin finish. That's what the underside of the car looks like now. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3579.jpg)
Here is the outer rocker, tacked and ready to be welded (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3580.jpg)
I'll have more this weekend guys, don't you worry.
Post by: daboss351 on May 16, 2008, 08:26:28 PM
now whats the rust killer you use? I said screw it, and started grinding out all the rest of the rust to stop it now. Now I need something to get inside the panels to stop the rust.
Post by: t3skidoo on May 16, 2008, 10:16:21 PM
Did you ever weigh those subframes you constructed. Any idea how much they weigh?
Post by: daminc on May 16, 2008, 11:33:21 PM
Mason, there are two thing that I use. Pickelx will convert rust and treat metal to keep it from rusting, and Zero-Rust is the cheapest priced encapsulator on the market. I think I got 2 quarts for about $25 shipped. 1 quart wil do almost 2 coats on the entire underside of a car. I use a small 3" paint roller for the floors and frames. it leaves a nice final finish, and is UV resistant and solvent resistant, almost like an epoxy paint. The red stuff I was using is Eastwood's encapsulator. Its about the same but costs more. POR 15 is a very expensive product that requires an additive and I guess stinks worse then a rotting skunk under your house.
You can use an undercoating gun, with a long extention wand on it to spray the Zero-rust inside rockers, frames, and panels. I've got a link to that if you need it. You just have to thin it down a bit to spray it in a gun
----------------------------------------------------------------- You know I never did weigh them. I thought about it and never did it. I still need to make the other side, so somebody please remind me before I put it in. If I had to guess, I would say 40 lbs or so per side. I'll check to see if the weight was on the invoice for material I used 5' 2x2 1/8'' tubing. I think it was (11ga.?) and 10' 1x1 1/8'' tubing per side I'm also thinking about front tower braces and some rear bracing. I'm also thinking about a roll cage. I can get my hands on a 2-1/2 bender if I need. I've got this fantasy of a dual turbo one day.
Post by: daminc on May 17, 2008, 05:04:36 PM
I got the bulk of this side done today after doing a little re-adjustment to the rocker. Seems there was a hump in the center of it when I tacked it on last. I took it off partially and reinstalled it straight this time.
my new rustfree rocker. :D the door needs to be raised in the back. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3582.jpg)
I'll put a nice factory looking strip of seam sealer along the rocker and side rail. It'll look like it came off the line like that (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3583.jpg)
I have to get my dremel out and grind down the hard to reach places and corners. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3584.jpg)
Here you go, one solid side of the car. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3585.jpg)
Tomorrow, I should be able to finish the little odds & ends stuff and seal the rest of the joints on this side.
Post by: Chooglin on May 17, 2008, 05:24:30 PM
I would love to see this car when it is finished.............CJ2009?
Post by: daboss351 on May 17, 2008, 11:34:57 PM
thanks!!
Post by: cougarXLS on May 18, 2008, 01:14:01 PM
Truely incredible daminc...!!!
I think I should take a welding course this summer or something.... you've definitly inspired at least a few of us!!
Post by: daboss351 on May 18, 2008, 01:21:02 PM
I wonder if yours will be done for catjam, and if mine will be done...
Post by: daminc on May 18, 2008, 06:06:37 PM
Mine may be done for Catjam 09. after I rebuild the car. I still need to rebuild the motor. Need another rear end. and I'll probably do the 5 lug swap. I have been accumulating parts for the full console swap, full digital cluster, full lighting package, and possibly a roll bar in the works. Then the body work needs to be done and paint. and finally the car needs to be put back together. did I mention the 5.0 upgrade. I'm sure there will be something else going in the car. but thats kind of a rough sketch of everything
I guess I have a bit of work ahead of me. most of the mechanical stuff I'll have a hand with. should speed things up a bit.
Post by: mercury-man on May 18, 2008, 06:29:36 PM
Hey, Jerry have you started a (scratch/check) off list in the Garage Yet? :popcorn:
Post by: daminc on May 18, 2008, 06:33:41 PM
This is the last of the drivers side rebuild. I finished up the welding and put the last piece on the rocker panel. Put a coat of Zero rust on everything and will finish the rest of the seam sealing and 2nd coat during the week.
I had to do a little aligning to finish the rocker bottom and weld it to the quarter panel (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3587.jpg)
Here's the last piece of the side being bent (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3588.jpg)
I'm going to miss those magnets one day (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3589.jpg)
I did some, "just in case" welding. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3590.jpg)
Did a quick patch in the back (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3591.jpg)
Started to coat a few things. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3592.jpg)
I'll put Pickelx on all the bare metal to keep it from rusting. seal and coat everything again then on to the other side of the car.
Post by: daminc on May 19, 2008, 07:42:33 AM
Yesterday, I've been part of the group here for one year. In that time, I've learned more than I could have imagined about our cars. I've met a lot of good friends also, in that time. So I just wanted to say, thanks for all the help to get my car this far. I couldn't have done it without the support of everyone, and of course the parts that everyone has helped to get for me. Thanks, Jerry
PS..... The project has evolved from the flintstone project as of now.
Post by: daminc on May 20, 2008, 07:11:33 PM
Today I seam sealed the rest of the drivers side. (http://i233.photobucket.com/albums/ee79/daminc/seam%20sealer/IMG_3613.jpg)
I'll paint it again with encapsulator, so I can try to get the car turned around for this weekend. I used 5 tubes of seam sealer on this side of the car so far. I worked about 8 hrs last weekend and today to get things finished up. This coming long weekend. SIDE 2 coming up
Post by: *MAYHEM* on May 20, 2008, 08:09:02 PM
When you get it road worthy, I know the perfect vanity plate for it:
PRIDE
It is rare these days to see someone who takes this kind of pride in their work and it is good to see. Most would have sped it as too far gone. I'm glad you didn't. This will be a project you can be proud of. "See this car? This is what it looked like when I started. Yeah, I did that."
I can't wait til you can bring it to Catjam and really show it off.
Post by: Thunder Chicken on May 20, 2008, 08:15:20 PM
A bird that rises from the ashes is called a phoenix. What would you call a cat that rises from a pile of rust?
Post by: daminc on May 21, 2008, 08:00:46 AM
Quote from: Thunder Chicken;219947
I've been searching for the right name for a while now. It's not Flintstone like anymore. (although I was talking to someone recently who may have the next flinstone project.) It has certainly evolved from the "rust with wheels under it" look. I researched cougars again last night, and found a "Cougar Spirit" from Native American folklore. Doesn't really have anything to do with this situation, but it was good reading if anyone was interested.
A new name will come when I least expect it. It always does.
Post by: daminc on May 21, 2008, 07:10:37 PM
This side is officially done and ready for bodywork. [SIZE="7"]NEXT!!![/SIZE]
Post by: DVP on May 22, 2008, 12:01:16 PM
AMAZING! that is the only word for that picture. hats off to you
Post by: daboss351 on May 22, 2008, 01:44:15 PM
good work man!
Post by: cougarXLS on May 22, 2008, 04:58:59 PM
At the risk of sounding [FONT='Times New Roman']repetitious.... [/FONT] WOW!
Post by: daminc on May 24, 2008, 06:43:12 PM
So, obviously I had to put the seat in to turn the car around. I just couldn't see out the window without it. and a drywall bucket seemed like I was asking for an accident. LOL (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3624.jpg)
A couple shots of getting it down (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3625.jpg)
Here's my jacking rail test [COLOR="DarkRed"][SIZE="5"]PASSED[/SIZE][/COLOR] (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3627.jpg)
So I have to charge the battery. I also have to rig a little something, because I don't have a battery for the car anymore. so far I have full power, but no power going to the starter when I turn the key. I'll have to do a little wire checking tomorrow. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3623.jpg)
I'll let everyone know how the car starting problem goes. Until tomorrow.
Post by: daminc on May 24, 2008, 06:51:03 PM
Oh, by the way. I weighed the tubing that I'm using for the other side of the car 1 10' 1x1 1 5' 2x2
32 pounds per side it comes to
Post by: ZondaC12 on May 24, 2008, 07:07:11 PM
Unbelieveable. That's just unreal seeing the whole side of the car solid clean metal. Awesome.:roxor:
Post by: SLEEPER T-BIRD 87 on May 24, 2008, 08:51:42 PM
looking good man!
Post by: daminc on May 25, 2008, 09:34:27 PM
Didn't get it started today. Only had a couple of minutes to check the wiring. It's probably the solenoid. I don't have power to the starter. got power to the coil. got power to the entire car. but still no turn over or even a click. Looks like I'll have some time to look at it tomorrow.
Title: Starting Problem Update
Post by: daminc on May 26, 2008, 07:40:37 PM
This needs to be connected in order for the car to start. It disconnects the neutral/park start switch.
I need to charge the battery again and get a battery cable. Then we should be seeing some outdoor pics before next weekend.
BTW. I noticed that I could see the connector hanging in the 2nd picture of the beginning of this thread on page 1. LOL
Post by: daminc on May 31, 2008, 12:44:59 PM
I got my car started this morning. The battery I was using, didn't have enough kick to start the car. I pulled the battery out of the bird, turned the key, and it started right up, like I just drove it the day before. Here are some outside pics. I know all of you are probably thinking that it has never run before, or has never left the garage in 10 years. so here it is, all proud in the sun.
Post by: daboss351 on May 31, 2008, 01:56:18 PM
good work! and I finally got a welder. a cheapo fluxcore mig, but it was free now if I have to, I can do sheetmetal repairs instead of fiberglass!! If I only had a garage... My little shed is to small for major work, adn is already packed with a 302, lawn mower, parts of my interior, tools, and a partly striped motorcycle haha.
Post by: Chooglin on May 31, 2008, 01:58:27 PM
looking good Daminc !!!!
I hope you dont get burned out on this project,I would really like to see this one completed.you have done a tremendous amount of work on that car................thumbs up.
Post by: daminc on May 31, 2008, 03:35:52 PM
Quote from: Chooglin;221439
Thanks, I'm trying for CatJam 09. Not to worry, I've never not finished a project in my life. This side of the car needs a lot less work, and I'm not rebuilding the door bottoms. I've got another pair in the works, along with some HO motor parts and some interior upgrades. Things are gonna fly after this side gets rebuilt.
Post by: DerikWayne on June 02, 2008, 04:17:11 PM
All this time I completely forgot about the "other" side, lol. I would never be able to keep my focus on one project for as long as you have. My hats off to you man.
Post by: daminc on June 02, 2008, 07:31:31 PM
Quote from: DerikWayne;221658
LOL... Yes, the other side. And then there's the front end after the motor comes out, and the back end.
So, 1/4 done rebuilding. mabe a little more, the sides are longer then the front and back. Don't forget the bodywork after all that. LOL
At least my wife knows where I am, If I'm not in the house
And now I have to repair her car after a billion year old lady hit the back of her car (http://i233.photobucket.com/albums/ee79/daminc/Monte%20damage/IMG_3577.jpg)
Post by: mercury-man on June 02, 2008, 08:19:02 PM
Hey, Jerry at least there isn't any rust to repair on it.
Post by: 1WLD BRD on June 02, 2008, 08:28:40 PM
Quote from: mercury-man;221686
give it a year, it is a chevy...:shakeass:
LOL
Post by: daminc on June 02, 2008, 08:38:50 PM
It's an 03 and there's already rust around the windows.
Post by: daboss351 on June 02, 2008, 08:59:25 PM
yep chebby products..... I swear there WAS a 03 chevy van around here body was in worse shape then your cougar floors and frame rails rotted right out of the thing it was horrible cause it was newer.
Post by: daminc on June 02, 2008, 10:57:50 PM
The only reason we still have it is, well, it's pretty quick
Post by: theredlineboss on June 07, 2008, 08:37:18 AM
Now that I'm advancing beyond lurker status...I just wanted to say: WOW! The work that you have done for this car is beyond awesome. Like others have mentioned, up until now, this level of work has been unheard of for fox cougars.
I'm going to need to take some welding lessons myself; I've got a lot of rot in my car, as well as a few plugged holes (from the antennae and lightbar).
-Rob
Post by: thunderjet302 on June 07, 2008, 04:40:55 PM
So after it's all done are you going to run around with a 5.0 HO and wire wheels? It would be funny to see you burn the tires if you keep the wire hubcaps :D
Post by: daminc on June 07, 2008, 07:29:28 PM
Quote from: thunderjet302;222510
LOL I may even keep the whitewalls. Who would expect a HO in it. :evilgrin:
Post by: daminc on June 07, 2008, 07:44:35 PM
Quote from: theredlineboss;222473
-Rob
It's just a Mustang thats a little longer. I never thought it was odd to want to rebuild it. I thought everyone else on the board was doing stuff like this when I joined. I didn't know you could still buy one in one piece out west. :hick:
Post by: 1WLD BRD on June 08, 2008, 08:44:03 AM
Quote from: daminc;222525
and ALOT less power...
Post by: HAVI on June 08, 2008, 05:16:58 PM
Jerry, count me in as one of those "everyone" guys,lol. You'll be finished before me, though.
Post by: daminc on June 08, 2008, 08:53:29 PM
Quote from: HAVI;222629
We'll see what you think after you see this side of the car. LOL Scott, I have some side moulding you can have. (front Quarter panel moulding)
Well, Its time to get the other side going. I got it back up to work on this side. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/IMG_3684.jpg)
The rocker on this side is in pretty good shape. The front part is un-rusted as is the rest of the panel until it gets to the quarter panel seam. The bottom seems a little thin, and I'll probably cut it out and replace the flat section that gets welded to the floor pan underneath (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/IMG_3691.jpg)
Looking at this side, I see that it's a lot better then the other side. Here's a pic of the condition of the rubber on the windows of the car. I hear a lot of talk about everyone needing new 1/4 windows and dew strips. Its about the only thing I don't need on the exterior of my car. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/IMG_3701.jpg)
This side will get the same treatment as the other. Just a bit less in the panel replacing. The quarter panel will get cut, much like the other side. I'm still undecided about where I'm going to cut the panel where it meets the door (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/IMG_3703.jpg)
The inside jamb and the rocker will get replaced like the other side (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/IMG_3704.jpg)
Well, thats all I got to show. Now it's time to do it. Until next Time.
Post by: daboss351 on June 08, 2008, 09:35:46 PM
god nn
Post by: HAVI on June 08, 2008, 09:52:51 PM
In light of post #280, it'll be close, lol.
Post by: Carpimp1987 on June 08, 2008, 11:56:34 PM
That was a lot of rust but Great work so far man.
Post by: daminc on June 10, 2008, 05:49:35 PM
I started the pass. side this afternoon. I cut out the bad spots (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3706.jpg)
You can see, the rocker front doesn't need to be repaired on this side. I pulled the plug out and stuck my finger in there. I didn't feel any rust at all inside there. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3707.jpg)
Started pre-bending everything, so I could weld it up at one time (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3708.jpg)
another gorgeous day in Buffalo, NY (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3710.jpg)
Here's a little more pre-fab work. Everything marked (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3711.jpg)
And as they say on the cooking show, BAM!!! (You gotta have the lines in the floor.) (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3712.jpg)
On to the back. I'm skipping some pics, because it's mainly a replay of the other side. there's also less to repair, as you can see by the way it's moving along. This all happened in about 2 hrs. time
Here is the back of the pan cut out, like the other side. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3713.jpg)
here is everything ready to be welded. just need a few more pieces to finish it up. I'll also fill the hole from the plug. It's easier to cut the floor for the frame, when it's solid. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3714.jpg)
Of course, everything will be treated with pickelx, before welding. I'll open up the frame to treat the inside of them too. (I feel like I've done this before) Thats all for today my friends.
Post by: CougarSE on June 10, 2008, 07:32:30 PM
Your Monte Carlo has a 100000 mile warranty against rust.
Post by: daminc on June 10, 2008, 07:54:46 PM
Quote from: CougarSE;222945
Thanks, I guess it has a 6 year/ 100,000 mile corrosion warranty. Were going to look into it.
Post by: daminc on June 14, 2008, 06:37:10 PM
Today's events... I cut open the floor to check the frame. not bad for 21 years in Buffalo (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3716.jpg)
while I was waiting for the work I had done to the floor to dry, I coated and punched all the panels for welding (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3717.jpg)
Here is the first piece. you can see I ground down, then coated inside the frame and the hidden part of the lap seam. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3718.jpg)
more pieces (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3719.jpg)
my handy work up close (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3720.jpg)
back seat time (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3721.jpg)
I'll finish welding the rest of the floor pieces and move on to the upper part of the rear floor/wheel well area. the floor should be done after another day of work. then on to the rocker.
Post by: chas jr on June 14, 2008, 07:07:30 PM
AWESOME WORK. It just keeps getting better and better very time you post. Great job:D :D :D
Post by: mercury-man on June 14, 2008, 08:46:31 PM
Hey dude all I would like to say is way to go: :jerry: :jerry: :jerry: :jerry: very :cool:
Post by: Chooglin on June 14, 2008, 09:28:54 PM
Ummmm,I think he could build an entire car if he wanted to.
you do some awesome work !!!!!!!!!!!!................I love this thread.
Post by: *MAYHEM* on June 15, 2008, 10:50:48 AM
I'm thinkin' if you give him 3500 lbs of steel wool he could build a new cat in less than a year. :D
Post by: daboss351 on June 15, 2008, 11:19:36 AM
hahahah well Im finally getting the welder, and im gonna try and get some patch panels off a mark i found at a local yard!! gonna try and be like you hahaha looks great man!!
Post by: cougarXLS on June 15, 2008, 11:38:29 AM
daminc, two questions... what guage of metal is that and how did you actually bend it so beautifully to the contours in the floor?
Post by: daminc on June 15, 2008, 02:42:16 PM
Quote from: cougarXLS;223631
0000 steel wool and my wife's knitting needles --lol--J/K
Ok, for real. I use 20 ga. and my brake. It's not made for steel so I have to use clamps to hold the locking bar down. It's a 10' aluminum brake, but I can get away with bending approx. 5-6 feet of 20 ga. without blowing apart the gate. For smaller stuff, I have a bead roller, with all the diff. rollers When I did the center one that didn't go all the way through, I let it hang out of the end of the brake, when I bent it. I've had a lot of practice bending. been doing it since I was 18, and now I'm 40 something. LOL People have said, I can bend up a pretzel out of metal. LOL (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3727.jpg)
Chooglin, I'm not sure about a whole car, this is more then enough for me. LOL
daboss351, Thats great, you can get some good practice with your car. LOL If you got any ?s, just give a shout, I'll help any way I can
*MAYHEM* --LOL --Who writes your material, He's good
Post by: daminc on June 15, 2008, 02:54:17 PM
I did a little playing around today. I've got no ambition, and it's Fathers Day. Yes, it's just like my birthday, I GET PRESENTS today. LOL I cleaned up around the wheelwell. there was some rust in the seam, so I treated it and decided to reinforce it, just in case it keeps rusting. I took my sawsall to the floor and opened up the frame, so I could coat it also. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3731.jpg)
And I put a coat on the front. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3730.jpg)
Thats all for today HAPPY FATHERS DAY
Post by: cougarXLS on June 16, 2008, 10:03:01 AM
Quote from: daminc;223652
Thanks.... this is why I love this site... I learn something new everyday. :bowdown:
Post by: daminc on June 28, 2008, 04:45:52 PM
A little more work on the pass. side floor (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3760.jpg)
Post by: HAVI on June 28, 2008, 04:55:00 PM
Ya know, Jerry, some people would look at that and think yer crazy, lol.
Post by: Cougar8775 on June 28, 2008, 05:03:55 PM
!! thats alot of rot!
Post by: daminc on June 28, 2008, 08:25:51 PM
Quote from: HAVI;225052
I don't feel crazy. :hick:
Cougar8775 !! thats alot of rot!
It's actually easier to repair if it's gone. That pesky rust doesn't get in the way
But you can't see the ground anymore, can you. LOL
Post by: Cougar8775 on June 28, 2008, 08:28:14 PM
no but your car is in alot better shape than the 86 tbird i junked. i swear the car woulded of folded up under a stiff breze(sp). i mean there was more metal missing than what was there.
Post by: daminc on June 28, 2008, 08:44:09 PM
Quote from: Cougar8775;225088
I guess it's all relative to what you compare it too At least this side is better then the other.
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on June 29, 2008, 03:59:09 PM
The last of the floor repair on the entire car. Thank God, It's got to be the most awkward position to work in.
I made sure I had enough to weld the patches to the frame, before I covered it up. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3781.jpg)
the entire side still needs to be seam sealed and primed again. I'll do that after the SFC gets cut through the floor.
Up next! cutting off the lip from the lower rocker, where it meets the floor. Also, cutting off the bottom of the rocker and replacing it with new metal, so the jacking rail has something strong to hold on to.
after the new lip is replaced, I'll make the SFC for the pass. side, and get rid of the rest of the rust underneath the car.
We are now officially "Flintstone" Free
Post by: hirax on June 30, 2008, 04:04:15 AM
What is Your plan with those exessive parts of old floor ? There is rather big gap between sheets. Only sealing, weld edges from underneath and sealing or cut exessive part and sealing ? Without seam sealing rust will come inside from here.
Post by: daminc on June 30, 2008, 07:29:31 AM
They will be tightened up and seam sealed after the rust is treated and coated. I couldn't find a good pic, because it's hard to take one under there. Here is what the underneath of the drivers side looks like. I would say 25-30% of this side was repaired the same way (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3557.jpg)
and then after this goes on, its tough to see where the repairs were. (http://i233.photobucket.com/albums/ee79/daminc/frame%20rails%20and%20connectors/IMG_3568.jpg)
I'm also not worried about rusting, as this car will never be out in bad weather. It will never see salt again and will be checked over every spring before it leaves it's auto copuppies. It will also be trailered for long distance travel.
Post by: daminc on June 30, 2008, 05:45:29 PM
Started cleaning up the rust underneath the car Used pickelx and a wire brush, cleans it up to metal again. Then I just wiped off the rust and did it again. and then a coat of encapsulator. I was going to cut the bottom lip off the rocker, but I need to think about where I'm going to put the E-brake brackets that are welded to the rocker lip right now. (can be seen in second pic)
Notice the front frame still has paint on it (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_3784.jpg)
Post by: daminc on July 06, 2008, 07:29:40 PM
This is the part where I cut up what actually looks good. Is it wrong that I enjoy doing this. LOL
Now you see it. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3823.jpg)
Now you don't that's the lip from the inner and outer rocker. excuse me, that WAS the lip (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3824.jpg)
Here it is cut off flush with the floor. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3825.jpg)
I knew the rocker was rusted badly, even though it looked good (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3826.jpg)
again, I cut out the supports that were rusted. and I will reinforce them like the other side. you can see the extra welds I did on the existing panels a lot better from here. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3827.jpg)
Here's the new inner lip ready to be welded to the inner rocker. You can also see the support that needs to be repaired a lot better also another good shot of the extra welds that I did inside the car. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3828.jpg)
another view (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3829.jpg)
I probably won't be working on it for a couple weeks. I need the pass side door on, before I can go any farther on this side. There's just too much of my door missing to try to put the quarter and door jamb together.
I may take the doors off to get rid of any rust before the replacements arrive in 2 weeks. and of course I won't be working on it next weekend, because I'll be attending Catjam 08.
I'll be uploading pics from Catjam from Fri - Sun, so if you not able to make it, you can see what I saw that weekend.
So, I'll see some of you this coming weekend. I should be easy to find, I have no cat, but now I have a Panther (The New Blues Mobile).
I'll be back with more updates in 2 weeks. See you then Jerry
Post by: daminc on July 19, 2008, 06:57:26 PM
Inner, inner rocker tacked to floor, which will also be welded to the jacking rail (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3927.jpg)
It's not pretty, but it's really strong (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_3925.jpg)
I'm just finishing up where I left off 2 weeks ago. I'll finish welding everything tomorrow Hopefully I can remember what I planned to do next. It's been a while. I think it was SFC's on this side and then the quarter panel.
Post by: cougarXLS on July 20, 2008, 07:54:05 AM
"Anything built by man can be fixed by man"
I don't know who first said it, it has sparked many a debate. Jerry seems to be living proof that it is indeed true. T'is wonderful. :bowdown:
This will keep me subscribed to any updates eh? :hick:
Post by: daminc on July 20, 2008, 05:08:22 PM
Spent an hour on the car today. Started cutting the frame and the floor.
Here's the before I took a sawzall to it shot (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3930.jpg)
A few "as I go" pics (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3931.jpg)
Here's a shot of the dry fit to mark the floor to cut. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3934.jpg)
another shot (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3935.jpg)
Here's a shot of the floor cut out and ready to test the SFC (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3936.jpg)
Here it is in place (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_3937.jpg)
Next I'll be working on the jacking rails and cross braces. (The fun stuff)
The parts train came through Grand Island today. And guess what, I got a delivery from kitzdnm as he was passing through on his way to Canada. here's some new stuff for my project. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_3939.jpg)
I also got a TC front bumper cover with almost no scuffs on it with the chrome strip around it. (I love my chrome) and a dual power seat switchplate for a full console
Until next time
Post by: daboss351 on July 21, 2008, 12:30:48 PM
NICE!! want heads next??
Post by: daminc on July 21, 2008, 07:35:43 PM
What you got?
Post by: 88TurboCoupeman01 on July 25, 2008, 09:35:04 PM
Wow thats a lot of Rust but great job rebuiling it not crushing many props.
Post by: daboss351 on July 25, 2008, 10:58:04 PM
i got e7's and ill send you a pm about what else
Post by: Kitz Kat on July 26, 2008, 07:27:54 AM
Hey ic,so thats where my egr spacer is.Thats a 70mm one. I was wondering where I put that.
Post by: daminc on July 26, 2008, 08:04:19 AM
Need it back? I'll send it.
Post by: Kitz Kat on July 26, 2008, 08:09:13 AM
I have no use for it.I was just wondering the other day where I put it.put it to good use.
Post by: daminc on July 26, 2008, 08:10:48 AM
Thanks, I'll treat it like gold. LOL
Post by: Kitz Kat on July 26, 2008, 09:27:53 AM
I have new gaskets for it somewhere,I'll mail them to you when I find them.
Post by: daminc on July 26, 2008, 09:46:37 AM
Thanks, kitz
Just to put it out there: I'll be looking for a decent set of heads in the fall or early winter. (Pref. GT40s) and some other misc. HO upgrade parts. (need to find out what I have collected first) got to space these things out to buy them. Getting a set of Chucks motor mounts this weekend first.
Post by: Kitz Kat on July 26, 2008, 10:02:10 AM
The cw mounts are nice.
Post by: HAVI on July 26, 2008, 10:59:45 AM
got mine. I think they'll hold up pretty well. I got mine with the hard rubber.
Post by: daminc on July 26, 2008, 05:52:49 PM
Todays adventure is all about doors. I took off my old doors and got the new doors ready to go on. Here's one of the new doors all cleaned up and ready to be encapsulated. I stripped the old seam sealer and cleaned off the surface rust. Then treated it with pickelx. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3951.jpg)
then the painting. After this dries, I'll put on the new seam sealer, then coat it again. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3952.jpg)
So, I'm taking the doors off. Pulling wires, unpluging connectors, pulling out the door lock poppers, when it hit me. My hands aren't getting dirty. After all that work with my hands inside the door, you would think they would be black from undercoating and rustproofing inside the panels. I figured out why my car rusted out. Here's a pic of the inside of my door. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3956.jpg)
Then it got me thinking. I don't remember seeing any rustproofong in the rockers either. or in the front of the quarter panels, right next to the door. !! The car was never rustproofed! Not that its a bad thing. BUT I LIVE IN BUFFALO!! I can't believe the first owner didn't have it rustproofed. Oh well, things you wished you knew. LOL
So, here is my car the way it sits waiting for the doors to be put on. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3955.jpg)
That's all for today my friends. ;)
Post by: Thunder Chicken on July 26, 2008, 06:11:47 PM
Aren't the frickin' doors heavy! I had 'em both off my car during the body work and couldn't believe what they weighed! It's no wonder these things weigh upwards of 3500 pounds...
Post by: vinnietbird on July 26, 2008, 06:45:20 PM
I HATE adjusting the doors to fit right.
Post by: daminc on July 26, 2008, 09:42:40 PM
Quote from: Thunder Chicken;229222
I had my son help to unload them when kitz came over. He thought I was crazy that I asked him to help with the doors. Then he picked up one end with me and his eyes got real big and he said he couldn't believe they were that heavy. LOL
I remember the doors on my 78 monarch were a 3 person install.
I'm going to weigh one tomorrow. Any bets on the weight?
Post by: booksix on July 26, 2008, 10:39:00 PM
Ok, I forget... when did you say you were coming to CA to do 'all of the above' on my car? LOL
Truly amazing work! I hope one day I am good enough to do this to a car and still have it look like a car! :hick:
Post by: daminc on July 27, 2008, 07:23:34 AM
I'll be there when the ground stops moving. LOL
Post by: Kitz Kat on July 27, 2008, 08:49:41 AM
87.5lb's
Post by: daminc on July 27, 2008, 04:09:50 PM
First, I'll start with a few pics of the old doors. Sure I could have fixed them, but doors are easy to change. Yea, yea, I know I could have done that with the whole car right from the start. LOL (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3957.jpg)
here's a couple pics of the seam sealer on the new doors. Gotta make it look nice.
Taping it off (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3962.jpg)
seam sealer on (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3963.jpg)
Tape off (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3964.jpg)
and here's the other door (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3968.jpg)
While the doors are setting up, I took the time to get rid of any rust in the door jambs and around any joints. as you can see, there's a little in the hinge area. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3969.jpg)
Got out my trusty sand blaster, and went to town. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3970.jpg)
And by now, you know what I'm going to say next..... after blasting, I treated the bare metal with pickelx to keep it from rusting.
So another fun day with doors. (more like an hour) but still fun. I'll put another coat on the bottom of the doors, before I put them on. I'm only putting them on right now, to finish the metal work. I'll be taking them off again when I strip the paint off the car to epoxy prime it. the doors will also be easier to work on off the car. and the jambs will be stripped the rest of the way. I didn't have to blast the rust off the jambs right now, but I wanted to see how well they would clean up.
Until next time boys and girls, (you know who you are) See you next week.
Post by: daminc on July 28, 2008, 12:49:35 PM
Got the doors on this morning, by myself Here's some pics. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3975.jpg)
Just though I would share. The rest of the frame is next
Post by: Kitz Kat on July 28, 2008, 03:37:24 PM
The pinstripe doesn't match.I guess its still to early to see if the electrics work.
Post by: daboss351 on July 28, 2008, 04:06:00 PM
bad ass
Post by: daminc on July 28, 2008, 05:42:04 PM
Quote from: kitzdnm;229488
I just have to plug them in, and toss the battery in. Everything is run through but not clipped in. Mabe tomorrow
I've been looking at the door with the blacked out trim. And I'm thinking, mabe not putting the chrome on around the windows.
Post by: cougarXLS on July 28, 2008, 08:37:58 PM
IMHO, I'd suggest chroming around the windows... but it really depends on your paint scheme. I say this because... if you're chroming, say, the mirrors, and a few other spots, I think t'would complement the car.
Cougar A & B are chromed around the windows, their mirrors, the door handles, etc., but X is not. I just couldn't picture X with chrome around the windows.
But hey, just a thought.
Just out of curiosity, what colour/paint scheme are you planning on for your finished project?
Post by: daminc on July 28, 2008, 08:56:14 PM
Quote from: cougarXLS;229541
Either black or this color. it's almost black. Can't remember what it's called at the moment. It's a charcoal color
Post by: cougarXLS on July 28, 2008, 09:00:13 PM
Then I'd definitly reccomend the chrome. :)
Post by: theredlineboss on July 28, 2008, 11:33:22 PM
Once again, great work! And I would vote for the charcoal (I **think** it is called "Dark Shadow Gray Metallic").
-Rob
Post by: DerikWayne on July 29, 2008, 12:21:18 AM
I don't know why, but I keep forgetting that this car needs repair on both sides for some reason.
Post by: DVP on July 29, 2008, 02:10:59 AM
Quote from: theredlineboss;229580
-Rob
Believe you are righ on the name. If I could come up with a two tone I liked I that would be the other color along with black.
Post by: daminc on July 29, 2008, 02:03:18 PM
Quote from: DerikWayne;229587
You don't need to remember anymore, this is the other side. And it will be together in a couple weekends.
Post by: daminc on July 29, 2008, 02:09:58 PM
Got the windows up. everything seems to work fine. and if not, I have 2 extra sets of door parts now. The tint on these windows are unbelievable. Like new glass also. the buckle up stickers on the glass look brand new.
Kitz, How long were these stored away, again?
Now that I have my doors on, I'll finish up the frame during the week. (I hope)
Post by: Kitz Kat on July 29, 2008, 04:36:45 PM
From what I know 8yrs,3 with me.
Post by: daminc on July 29, 2008, 05:31:47 PM
I think I'm going to leave the chrome just around the windows, and black out everything else. And leave the chrome on the body moulding and paint the mirrors with the car. Then I'll have enough chrome to go with my wheel covers. Oh yea, you heard me right. wheel covers and whitewalls
Look how yellow my headlights got (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3992.jpg)
It's not a good shot. I was trying to keep my reflection out of the shot. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3993.jpg)
Post by: thunderjet302 on July 29, 2008, 07:41:23 PM
Was the sticker on your windows worn off? Mine look nice like the one in the pic.
Post by: daminc on July 29, 2008, 07:45:43 PM
It was faded out or something. or the tint on these windows is a bit darker which makes them stand out more. I can barely see inside the car now.
Look how light the tint is in my sig. compared to the pic above
Post by: daminc on August 10, 2008, 03:10:40 PM
No car work this weekend, Had to build a handicapped ramp for someone instead. Don't you hate when work gets in the way.
I'm still collecting parts though. got these and the whole header panel yesterday from Cougar8775 as he was passing through from Niagara Falls. For being nowhere near anyone, I see a lot of members here. LOL Thanks, John and Nicole. It was good to meet both of you
Post by: Cougar8775 on August 10, 2008, 05:09:32 PM
Not a problem. Glad to help. And we had a good time. And great meeting another person saving these cars.
Post by: Thunder Chicken on August 10, 2008, 09:59:35 PM
You're installing satellite TV in your Cougar???
:hick:
Post by: daminc on August 10, 2008, 10:07:12 PM
Quote from: Thunder Chicken;231495
:hick:
LOL, Free To Air
Going to bolt it on the roof. :D
Post by: daminc on August 17, 2008, 10:26:36 PM
Here's a free gift for everyone that liked my SFCs. Have Fun!! :D (http://i233.photobucket.com/albums/ee79/daminc/secret%20plans/IMG_3944-1.jpg)
Post by: daminc on August 18, 2008, 07:08:42 PM
I'm back!!! Made the SFCs for the pass. side today. Those plans work well. Right on the money. I made these off the plans. the seat brace cut is not on the plans. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4079.jpg)
Post by: daminc on August 20, 2008, 06:42:06 PM
Todays progress report. Test fit the frame that I welded up yesterday (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4083.jpg)
Seam sealed underneath the car (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4085.jpg)
Made it look pretty (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4084.jpg)
and put a coat of paint on it (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4087.jpg)
I'll put a couple coats of paint on the frame and the floor during the next few days. Then it's time to put it in.
and some more stuff I've collected. I can now replace my consolette. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4088.jpg)
Post by: vinnietbird on August 20, 2008, 07:16:52 PM
Digi gauges and 65mm t-body coming soon to a Daminc near you.LOL.
Post by: daminc on August 21, 2008, 05:58:56 PM
2nd coat of paint (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4092.jpg)
Post by: DVP on August 21, 2008, 06:35:19 PM
What cam is that?
Post by: daminc on August 21, 2008, 06:52:45 PM
They're all stock HO and Mass Air parts that I've been collecting.
Post by: cougarman on August 22, 2008, 02:50:41 AM
Did you get the emblems yet? :burnout:
Title: A++ for cougarman
Post by: daminc on August 22, 2008, 07:21:02 AM
Oh , Sorry. I forgot to get back with you. Yes, I got them. We had a lot going on that week Everything is great
Post by: cougarman on August 22, 2008, 07:26:23 AM
Oh that's ok, lol, just wanted to make sure you liked them.:D :burnout:
Post by: daminc on August 22, 2008, 05:58:46 PM
Fitted the frame and welded it in. Had to stop half way through, when I pushed on a brake line and it kinked and started leaking. I'll finish welding tomorrow after I replace the brake line.
Here's the frame right before I started welding (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4095.jpg)
Post by: daminc on August 23, 2008, 06:05:26 PM
After messing with the brake line this morning, I took some parts off the bird, and got to work on my car here's the finished frame. Welded it and seam sealed it. All good to go. I can check that off the list.
here's a bunch of pics from diff. angles. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4097.jpg)
Pass side from the front. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4101.jpg)
Here's the drivers side from the front (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4102.jpg)
And here's the inside all finished and sealed. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4096.jpg)
Lined up and adjusted the doors so the quarter panel can be installed. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4106.jpg)
Nice, the old doors never fit this good (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4105.jpg)
Now I can start disassembly of the new quarter panels. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4107.jpg)
and a little measuring for the cut (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4126.jpg)
Post by: vinnietbird on August 24, 2008, 07:34:01 PM
Uber Sweet.Great work.I myself have to install new doors (well,I don't HAVE to,but they are mint,so I'm going to).How hard was it to do and to get the door's alignment right?I think I'm going to hate it,but,it's gonna be done whether I like it or not.Just do it and get it over with.LOL.
Post by: daminc on August 24, 2008, 08:02:52 PM
I have no front fenders on, it took about 10 min a door. getting them on and wired is the hardest part. take the lock poppers out to get to the connector. its the only way to get to it. There's a little plastic retainer clip holding it to the rod. the rest of the wires and connectors are within reach
Post by: vinnietbird on August 24, 2008, 08:07:44 PM
I may splice a wire or two for the hard to reach ones.I'm not apposed to making the job somewhat easier.How did you support the doors for the installation?
Post by: daminc on August 24, 2008, 08:24:14 PM
Quote from: vinnietbird;233484
Takes 10 sec. to get them out. I'll show you the clips on them tomorrow.
I put the doors on my bench. it was the right height with the car on ramps. (http://i233.photobucket.com/albums/ee79/daminc/Doors/IMG_3975.jpg)
used my bar clamps to keep the door upright. and 2 words for ease of installing. not the ones your thinking of. LOL AIR RATCHET....
Post by: vinnietbird on August 24, 2008, 11:46:00 PM
No air ratchet....I don't think.I have a compressor that I've had for a year and it's still in the big box,and air tools that are still in the plastic box.Perhaps I should get them out and actually use them.LOL.
Post by: daminc on August 25, 2008, 07:50:44 AM
Quote from: vinnietbird;233530
Are you kidding? LOL and you just did all that swapping and upgrading? Break that baby out, and fire it up. It'll look more impressive out of the box. It's OK to get the new tools dirty. LOL
Post by: booksix on August 25, 2008, 10:39:47 AM
Holy Vinn! You gotta bust that stuff out! Nothin' makes you feel more manly (and on those needed occasions - more like a real mechanic :hick: ) than air tools blasting everything apart! If nothing else, do it for me... and take pictures!! :D I just moved from a huge house with 3 car garage to a 2 bdrm condo with a one car garage 3 stories below... a garage that doesn't fit my car! It SUCKS!! Last week I put my car up on ramps in the underground parking garage. And this is a "everyone acts like they make more money than you but really they can't even afford there Mercedes car payment" area so I got some weird looks! I'm suffering! :punchballs:
Post by: vinnietbird on August 25, 2008, 02:06:26 PM
Well,I have been pretty manly without the air tools,BUT,with suspension rebuild getting ready to happen,things are gonna change.LOL.
Post by: massCougarxr7 on August 25, 2008, 05:39:40 PM
so why is it called project evolution anyway???? bet it has todo with that secret stuff coming huh? loooks like a lot of work,, and that cat definately makes my 88 look ike gold! my entire undercarrage is still factory sealed red... p.s. mighty fine metal fab work!
Post by: daboss351 on August 25, 2008, 05:50:02 PM
looks awesome!! do mine next!
Post by: daminc on August 25, 2008, 06:31:08 PM
Quote from: massCougarxr7;233603
Thanks for the compliment. The "Project Evolution" came about, after I finished the floors and couldn't see the concrete floor anymore. It started out as "The Flintstone car" (which people still refer to it as) because of the lack of floor. Then changed briefly to "Project Bedrock", which in turn evolved to "Project Evolution"
The secret stuff has nothing to do with the project at the moment. There are 3 people on the forum that know what it is, and will probably be helping out in one way or another. I can't say any more about it, because it's still in the drafting stage right now. But when the time is right, I'll let everyone know. :evilgrin:
Mason, You got the frame plans and a welder now. You just need to stretch it out a little for yours. According to my plans, the cars should be the same except for length
Post by: Cougar8775 on August 26, 2008, 03:14:22 PM
yes and those plans would be fun to drive!!
Post by: daminc on August 26, 2008, 05:36:34 PM
Quote from: Cougar8775;233702
LOL. oops. Mabe 4 people
Post by: daboss351 on August 26, 2008, 08:41:53 PM
i ment all my body work hahah but I have other problems....
Post by: daminc on August 26, 2008, 10:18:32 PM
Quote from: daboss351;233742
You don't need me, your doing it yourself already.
Post by: daboss351 on August 26, 2008, 10:28:37 PM
lol would be nice to have some metal patches hahah
Post by: daminc on August 26, 2008, 10:47:48 PM
You have a great car to learn panel repairing. any car after this one will be cake. hands on learning, is great knowledge
Post by: Cougar8775 on August 27, 2008, 03:45:23 PM
"Quote: Originally Posted by Cougar8775 yes and those plans would be fun to drive!!
LOL. oops. Mabe 4 people"
You really don't remember mutch bout that day huh or what we talked bout.
Post by: Cougar8775 on August 27, 2008, 03:45:27 PM
double post.
Post by: daminc on August 27, 2008, 06:58:49 PM
Quote from: Cougar8775;233861
LOL Dude, remember I said I played in a metal band in the 80s. Lets just say, I'm surprised to still be alive after all that and hanging out with Cannibal Corpse for 12 years.
I remember most of that night. Sometimes I need a refresher. LOL Sucks when you start to fee old.
Post by: vinnietbird on August 27, 2008, 11:24:33 PM
Sorry I forgot to get pics.Gayle is still sick.The chrome trim does look good,though.No damage I can see at all.The doors are close to mint.
Post by: shame302 on August 28, 2008, 01:36:44 PM
wow man, intense project. you certainly took the road less travaled with this one. very impressive!
Post by: daminc on August 28, 2008, 06:01:29 PM
Quote from: shame302;233984
Thanks, I've always taken the path less traveled. It drove my parents crazy when I was a kid.
Today's quick update.
I guess this is where I'm cutting the quarters. no turning back from this one. LOL (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4161.jpg)
Post by: Kitz Kat on August 28, 2008, 08:17:25 PM
Dude, You know your insane!!
Post by: daminc on August 28, 2008, 08:21:01 PM
Quote from: kitzdnm;234027
Just wait, It's only going to crazier. If you can believe that.
Post by: Thunder Chicken on August 28, 2008, 08:25:54 PM
Shoulda kept the tail light portion of the quarters, then you coulda used the cooler T-Bird tail lights and made it a real Thundercat :hick:
*dons flame suit*
Post by: daminc on August 28, 2008, 08:34:25 PM
Quote from: Thunder Chicken;234034
*dons flame suit*
I've tried to get that idea to work, but I would have to rebuild the entire backend of the car and custom make a trunk lid that would work with the back window of a cougar and the sloped trunk of a bird. :hick: Not saying it couldn't be done, but I'll be just as happy with a 90+% rustfree car. Mabe the next one.
Post by: Kitz Kat on August 28, 2008, 08:41:17 PM
shiznit,Aint nuttin like a cat in your rear lights.!!! Thats the way it is.
Post by: daminc on August 28, 2008, 09:13:44 PM
Wow, we hit page 40 today
Post by: vinnietbird on August 28, 2008, 09:50:10 PM
There''s a fine line between sane and insane.Maybe he's walking the line.LOL.
Post by: vinnietbird on August 28, 2008, 09:51:05 PM
Only page 40.We still have a ways to go.
Post by: ZondaC12 on August 28, 2008, 10:48:59 PM
Im on page 10 :D
Post by: thunderjet302 on August 29, 2008, 12:15:01 AM
*dons flame suit*
We all know T-bird>Cougar anyways ;)
Post by: daminc on August 29, 2008, 06:30:49 PM
OK, I had to do it. Needs another coat. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/Floor%20repair/IMG_4200.jpg)
I had planned on saving the quarters for a wheelwell fix how-to. but in this case, there's no fixing this. Only replacing. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4239.jpg)
They pretty much fell apart. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4240.jpg)
I guess I have a little rust on this side. LOL fortunately I have extra parts. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4243.jpg)
So I did a little more chopping and cutting, and this is what I come up with.I think it's going to be all right. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4248.jpg)
Post by: Kitz Kat on August 31, 2008, 06:00:23 PM
The pinstripe still doesn't match!!
Post by: daminc on August 31, 2008, 06:26:34 PM
Quote from: kitzdnm;234360
LOL No it really doesn't does it. But amazingly, the stripe lines up prefect. I could never do that again. When I striped the car, I looked at it and said "Here looks good"
Post by: Kitz Kat on August 31, 2008, 06:46:35 PM
That is amazing I thought it was a factory stripe.
Post by: daminc on September 01, 2008, 04:51:00 PM
So I decided to cut out a little more, because of the rust. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4271.jpg)
Put it in place and tacked it together. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4275.jpg)
Also ended up cutting more out of the front too. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4274.jpg)
Next is to weld the patches before the quarter goes on. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4277.jpg)
That's all for today. Just getting ready for the panel.
Post by: HAVI on September 01, 2008, 05:12:40 PM
Mini tub! Mini tub! Mini tub!
Post by: daminc on September 01, 2008, 05:16:43 PM
I've got better plans.
Post by: DerikWayne on September 03, 2008, 10:48:38 PM
That poor car, lol
Post by: jcassity on September 10, 2008, 01:31:27 AM
I look forward to this thread everytime i check in and I admire your sticking with it. I do have to say it though like we do down here,,,,,,,,
"We aint never seen no shiznit like this before!!"
You set the marker pretty high to be topped, lots of lookers out there including myself.:bowdown: :bowdown:
thank you for making my lower radiator support on the white coug look purdy simple.
Post by: daminc on September 10, 2008, 09:11:27 AM
Thanks, Its everyones support that keeps me going. It really wasn't supposed to be this big of a project when I started, but one thing always leads to another. Now I'm kinda glad I spent all those years hanging out at car restoration sites. It's really come in handy during all this.
I hope to have the entire body welded on in the next 2 weeks. Then I'm going to drop the tank and blast the entire ass end and seal/paint it so I can turn it around again and pull the motor.
Post by: 1WLD BRD on September 10, 2008, 09:46:28 PM
Quote from: jcassity;235642
LMAO!!!:rollin:
yeah I replaced my entire front clip on my cougar, (rad support and inner fenders and part of the frame.. and gave up, LOL)
Post by: jcassity on September 11, 2008, 12:39:59 AM
Im itching to see your eventual perfectionist work of the front strut tower/frame area. I have a couple of thoughts on how i would handle it since the s yard is not an option, I await more porn shots of this in days or weeks to come.
your use of the magnets is pretty slick there mister, i wont forget it when i need to make sure two eventually adjoining flat surfaces need to be on the same plane. How well do the magnets hold up to the effects of the electrical disturbance from welding? are they getting weaker?
Also, Are you using one of those clamp type spot welders 120/240 in addition to your mig?
Also,, i suppose your drilling out the holes for spare part removeal makes means that you simply fill back in the holes while welding and then grind off the excess slag/metal,, correct? I just happened across one pic that showed the backing plate for a rear qtr and then it all clicked how you were going to attach the new part to the body. Prior to all that, i thought you were going to seam weld which would put too much heat on such a small guage metal.
Also... when your welding,, are you welding holes full but jumping around as to spread out the heat staying far from the previous spot that was heated?
sorry,, too many question or curiosities.
Post by: daminc on September 11, 2008, 03:46:00 AM
Quote from: jcassity;235783
The front is going to be easy for me, because I have an extra car I can clip the front off of. Both sides if needed. So far I only see holes in the sheetmetal behind the shock towers which are easy to fix. but we'll see after the motor comes out.
I still need pliers to get the magnets off, so I haven't really noticed them weakening yet.
I'm just using a mig for welding. but plug welding with the help of my hole punch. I'll usually seam weld after the plug weld.
I weld a backing plate where I drill out the welds, and fill the holes in. I tried with out the backing, using a copper plate behind. but it's a pain, and the backing does just as well as long as I seam seal it so moisture doesn't get trapped between the metal.
When I weld the panel on, I skip around while I plug weld the backing strip. Then I hit the plug welds with a grinder so the magnets sit flush when the panel goes on. then I skip spot weld the panel. It doesn't have to be a solid weld when done. It will be epoxy primed first then filled with waterproof filler. The backing strip also acts as a heat sink which will be seam sealed on the back side too.
I also use a higher power setting for a shorter time welding sheetmetal (just preference) and 023 wire. the shorter weld time lets me tack stuff with out wearing a helmet cause it only takes a blink of an eye so to speak. you just need to time it right (and do it a lot) as long as were on the welder. It's a lincoln 140C gas and gasless with continuous adjustment and also has a cold tip and setup for a spot timer add on. I also use 12 lbs spools of .023 wire for sheetmetal with the argon mix. I also use a miller auto sensing proline helmet. (its real fast).
Questions are never a problem,
Post by: cougarXLS on September 12, 2008, 11:10:51 AM
wow! You're da man :bowdown: !!
Post by: jcassity on September 27, 2008, 05:20:04 AM
i jinxed the whole thread. I told you i check in about daily to see progress and nothing since.
need some more porn shots of the progress, hope all is going well.
Post by: daminc on September 27, 2008, 10:58:17 AM
No, You didn't jinx it. Life got a little in the way since I got back from my honeymoon (14 yrs. late).
Spent my usual fall cleaning and storage routine. (closing pool, cleaning carpets, putting away yard stuff, etc) But I did get some porn shots of some things I've been doing.
I ran out of tool storage room, so sears had a 50% of sale last weekend. So I bought this for $289. The sale may still be going. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4435.jpg)
Here's what I've been thinking for brackets and things under the car and inside the engine bay. Let me know what you think. I'm looking for a color to offset the satin black. and the silver Turbines I'm going to put on the car. I like the hammered metal look. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4436.jpg)
Also making sure the panel is lining up before I cut and piece the door jamb. Can't just cut it anywhere. these bird parts are stamped a little crisper then the cougar parts. just doing a lot of double checking. it's a one shot deal. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4437.jpg)
Also put another finished coat on the pass. side and started putting wires back in the correct holes if they're still there. otherwise I have to drill new ones. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4438.jpg)
And in between it all, I have to make another batch of doors and drawer fronts for our kitchen. 48 more to be exact. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4439.jpg)
So as of now, this is how she sits until I'm sure of where I'm cutting. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4444.jpg)
I'm also looking for a set of HO heads that won't cost more to ship then to actually buy. If anyone is close to Buffalo let me know. E-7s would be fine
Post by: daboss351 on September 29, 2008, 12:22:40 PM
dont worry ill hook u up with the heads. Ive been busy with stuff lately thats all(see my new thread...) Ill get the weight and get a quote asap. To ship a t-5 trans it cost me around 80
Post by: daminc on September 29, 2008, 06:42:13 PM
Well, I also don't want to spend $200 for a pair of used E-7 heads either. We'll have to see
Post by: daboss351 on September 29, 2008, 07:42:12 PM
i told you ill give you them for 80 bucks rockers and pushrods or something like that I just want them gone they in my way lol how bout this Ill take the hit on the shipping if its more then I figure
145 shipped they yours
Post by: Bob on September 30, 2008, 08:05:45 AM
Quote from: daminc;237698
If your looking for a nice upgrade over stock without breaking the bank than go with the explorer/mountaineer gt-40p heads and get the explorer intake too, you'll thank me later.
Post by: daminc on September 30, 2008, 08:43:03 AM
I've thought about it. Hard to find parts out this way cheap. Most places here will only sell the whole motor. and not anything decent for cheap. I think I've got the parts situation covered as of this morning, also.
I'm putting the 302 in from the bird, and doing a stock HO upgrade, this time around. It will be a drastic change from the 3.8. And right now, the price is right for what I need to do. I plan on taking my time building another motor while I can still drive the cougar. I'm sure I'm going to have some setbacks and reworking as I'm swapping everything, but It will be all taken care of, and all the bugs will be worked out for this motor. Besides, Catjam keeps getting closer every day. LOL
Post by: Bob on September 30, 2008, 11:56:41 AM
I hear you about CJ09 getting closer and closer. I thought I was going to have my car running to go last year (I even had a room booked). Here I am months later and I still haven't started it LOL...
Like the others have said, I enjoy reading your thread as well keep up the good work!
Post by: daminc on September 30, 2008, 02:47:57 PM
Thanks, I've been watching your project as well. It's Looking real nice. Mabe I'll see you there next year.
Post by: daminc on October 18, 2008, 07:58:14 PM
So, after my little vacation, I'm back to rebuilding the cougar. But first things first. Even though I havn't been hands on working on the car, I still use the time to find the rest of the parts needed to put it together.
I got a full digital cluster for my upgrade. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4461.jpg)
And I got a handful of these. Are they any good for my project? (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4458.jpg)
Thats all I'm going to show you for now. :D
so back to the rebuild I had to do a little repair work before the actual panels go on (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4462.jpg)
then to keep them from rusting.... you guessed it. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4469.jpg)
while that was drying, I started taking the rocker off the quarter panel. First I had to get rid of the seam sealer, then drill out the welds. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4471.jpg)
And it comes apart. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4472.jpg)
And now for the fun part. The hacking, cutting and fitting. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4473.jpg)
A little more cutting and fitting.... (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4474.jpg)
And a little more fitting... (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4475.jpg)
Thats all for today. I'm glad to be back.
Post by: cougarXLS on October 18, 2008, 08:52:44 PM
Well, it's probably been said, but man, you're an inspiration to us all.
Glad your back :)
Oh, and I love those rims ;)
Post by: daboss351 on October 18, 2008, 11:51:14 PM
looking good!!
Post by: daminc on October 20, 2008, 07:14:54 PM
Todays adventure is getting the rocker ready for welding. First, I have to fill in all the holes from drilling out the spot welds. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4507.jpg)
Then the holes in the door jamb. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4509.jpg)
I decided to weld the holes without a backing metal. just clamp a piece of copper behind the hole, and weld it full I made this copper spoon out of 1/2" tubing. the angle and round come in handy for a variety of applications. I patched a lot of holes in the floor using this baby. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4510.jpg)
here you can see it's tight with the back of the metal (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4511.jpg)
then weld it closed. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4513.jpg)
then I ground down all the welds. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4514.jpg)
the next step is to secure it with screws until it's ready to weld. this part will need to be done before I weld the rocker. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4520.jpg)
Here's what it looks like after today. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4521.jpg)
Post by: dominator on October 20, 2008, 08:28:21 PM
Dam jerry,you are the man.
Post by: daminc on October 20, 2008, 11:25:17 PM
Oh man, after that ride in your car yesterday, I'd say "your the man" Holy , that thing moves.
Post by: DVP on October 21, 2008, 12:50:05 AM
Ge some dust guards for those rims. They will be so much easier to keep clean.
Post by: Kitz Kat on October 21, 2008, 11:55:41 AM
I learned something today don't load this from the begining.That takes some time. Oh yeh nice wheels,I had some just like that.
Post by: daminc on October 21, 2008, 06:44:36 PM
So here's where I decided to cut the jamb. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4523.jpg)
So much for rust free. LOL (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4526.jpg)
Apparently these are stamped a little different too. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4528.jpg)
Here I am making it work on my portable home made anvil. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4527.jpg)
Another angle (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4529.jpg)
Here is everything screwed together. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4530.jpg)
This isn't as easy as it may look from the pics. Here you can see several problems that I also ran into on the other side. This will probably be a couple hrs. to make everything line up correctly. (I hope) This door was aligned perfectly with the old panels before I started. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4531.jpg)
(http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4540.jpg) Well, not bad for an hour of work. It should be perfect by the time I'm done playing with it. ;)
A shot of the panel back on the car. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4541.jpg)
That's all I got today. We'll see what tomorrow may bring
Post by: mercury-man on October 21, 2008, 08:23:46 PM
Jerry, Thanks for the updated photos just remember there's an end to this project somewhere dude. LOL ;)
Post by: HAVI on October 21, 2008, 08:37:55 PM
Not that anyone would know or care, but Jerry, your progress is making me look really bad, lol. Keep it up!!
Post by: dominator on October 21, 2008, 10:04:19 PM
Thanks man,yea she's a handfull LOL.
Post by: vinnietbird on October 22, 2008, 07:00:19 AM
Awesome work my friend !!!!! When you're finished,you need to put the car in a big glass box for display only.You'll die if some nut t-bones the Cat.LOL.
Post by: daminc on October 22, 2008, 08:28:54 AM
You know if that happened, I would try to fix it, Right? They would also have to bend my frame. I still need to tie them both together.
Post by: ZondaC12 on October 22, 2008, 08:47:15 AM
Well I would hope with that mack truck frame--I mean subframe connectors that it oughta be about indestructible LOL.
Post by: Cougar8775 on October 22, 2008, 10:26:57 AM
its comming along jerry. man like stated before your making even me look bad since my cougar is just sitting in my driveway collecting dust dirt and now snow lol. I know too early to say that word.
Post by: daminc on October 22, 2008, 05:37:02 PM
In Buffalo, snow is an everyday word. And yes, I did see snow yesterday and today.
Got to do some aligning today. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4542.jpg)
This will move over when I get the screws out from under the lip. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4544.jpg)
So with everything in the right place now. All I have to do is mark the panel and cut it. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4547.jpg)
This is where we are today. The magnets are holding the panel. Here you can see the space between the door and 1/4 panel (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4559.jpg)
This weekend, I'll weld the rocker and jamb. Next is getting ready to weld the 1/4 panel. Then my car will have almost 100% rust free body panels. :D
Post by: Kitz Kat on October 23, 2008, 03:29:34 AM
Can't be to much left of the donor car.Your getting there.
Post by: daminc on October 23, 2008, 07:31:36 AM
Quote from: kitzdnm;240176
I haven't touched the parts bird yet. So far, everyone has used more parts from it then me. LOL I got the quarters from FLSTCI71 last november during his Cleveland parts run. If I didn't have to replace so much of the car, (which I didn't expect :hick: ) They would have been on before this past summer. I'm going to get the panel welded on this side, then probably pull the motor for the winter. Fixing the front frame and working on the 302 from the bird will give me something to do during the winter.
Post by: jcassity on October 23, 2008, 09:52:30 AM
i tell all my car buddies about this thread,,, most replies are "that guy is insane". We pulled up your thread on my laptop while I was down in Az doing a solar project,, it was a lunch break conversation with comcast. The whole bunch of us was in a big huddle in the shade under a tree so we could see the pics,,, amazing.
one thing we all have in common though is we realize not to complain about projects anymore!:bowdown: It doesnt get any more trying than this.
Post by: ZondaC12 on October 23, 2008, 11:44:37 AM
It really puts things very much in perspective. There's always a car better than you, there's always one worse......and there's always some guy that will jump right OVER you as they restore their vehicle :rollin:
Post by: thunderjet302 on October 23, 2008, 05:03:12 PM
You know by this time you could have just made it a vert ;)
Post by: jcassity on October 23, 2008, 11:14:00 PM
Quote from: thunderjet302;240224
if anyone could,, id hand pick this man!!
Post by: baxo on October 24, 2008, 07:04:10 AM
Man.. Having this progress up close in person.. on the other side the rear quarter that he's already done, if you run your hand across it, you can't even tell there's been a new piece welded on.. Never mind Jerry making his own convertible.. he should come across the falls more often and help me work on mine!
Post by: daminc on October 24, 2008, 07:54:41 AM
Thanks for the compliments guys, But it would be near impossible and very costly to make it into a convertible. I would pretty much need another cougar convertible to get all the custom made parts from. and there aren't exactly a bunch of them rolling around North America any more.
Alex, if you get a garage that has a little more room in it, I'll give you a hand. But I may be lost on that one, you have no rust. LOL
Post by: daminc on October 24, 2008, 05:43:56 PM
Today I started to weld the jamb and rocker Here's a couple as I went sorta shots. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4560.jpg)
Put this part back on and tacked it to check the alignment. Here you can see the previous weld ground down (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4562.jpg)
I guess it's time to do more door adjusting again. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4564.jpg)
For some reason, these doors have a different shape on the top. I'm kinda wondering if the doors are slightly different between the birds and the cats. I put a straight edge on my old doors and they are straight all the way along the glass trim to the top. These are angled about a 1/4" at the top of the door frame. Hmmmmm.... (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4568.jpg)
Another day, another problem to overcome. Mabe I'm just being to pickey.
Until tomorrow
Post by: Cougar8775 on October 24, 2008, 05:50:12 PM
hey jerry what gage are you using for sheet metal. Cuz i need to get a price for mine. I looked into the rockers and on the drivers side some of the inner structure is missing. So i have alot of work on my hands. Plus im going to relocate the body drain tubes since ford just slapped em in there and enclosed the rocker panel around them.
Post by: daminc on October 24, 2008, 06:23:00 PM
20 ga. for the body. although I think they skimped, and made it a little shy of 20. mine feel thicker then the ford panels.
Post by: wnt2gofst on October 24, 2008, 10:05:39 PM
this is a cool project, im going to college now for the same kind of stuff you are doing, i love it, cant wait to see the finished car, good luck
Post by: daminc on October 24, 2008, 10:44:16 PM
Quote from: Cougar8775;240302
I was just re-reading this. What drain tubes are in the rockers? Do you have a moonroof? relocate the tubes like they did on the Marks. They go through the wheelwell just behind, and in front of the rockers. They're the same way on my wife's Lincoln.
Did you ever get the rockers?
Post by: daminc on October 24, 2008, 11:30:02 PM
Quote from: wnt2gofst;240320
You mean there's a school for this? LOL And I had to learn the hard way. :hick: I'm glad you like the show. It's really about the tools when you do stuff like this. I also pick up cool shortcuts and tips watching Overhaulin and American Chopper.
Post by: Cougar8775 on October 25, 2008, 01:21:25 PM
not yet living off unemployment sucks. But yeah i have the moonroof. and when i redo the rockers i will relocate the drain tubes so all my hard work does't go for not. But i know i have a ton of work ahead.
Post by: Kitz Kat on October 25, 2008, 01:43:06 PM
Yo ,ic,I see a future for you ,teacher of body rebuilding. Lol.
Post by: daminc on October 25, 2008, 06:18:03 PM
Quote from: kitzdnm;240357
I'll keep that in mind if this career doesn't pan out. LOL
Today I welded the jamb and started getting ready for the quarter panel
Here's the welded jamb. Still needs to be ground down. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4569.jpg)
Here's a shot of the 1/4. ground off the paint. and put pickelx on it to keep it from rusting. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4570.jpg)
Did the same to the backing strips. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4571.jpg)
Punched holes in the quarters to plug weld the backing strips on. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4572.jpg)
Backing strip, test fit (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4573.jpg)
Next is to weld the backing strips on, grind the paint off the rocker panel and test fit everything again. And I almost forgot..... Everything that I can't get to ever again, needs to be seam sealed. Very soon, the car will be whole again. that's all for today my friends.
Post by: jcassity on October 25, 2008, 11:41:37 PM
that door issue you have there would have me buggin. I would have to know the answer to what you suspect. You need a close up pic of a bird door in the area in quesiton. Ill bet your right.
im interested in that hole puch tool you have there,
Post by: daminc on October 26, 2008, 12:16:25 AM
Quote from: jcassity;240390
I got a bird in my driveway. Was going to put a straight edge on it but it's been pouring out since yesterday. I may have an answer on that tomorrow. I'm welding a piece on the top of the door to remedy that problem no matter what.
The hole punch / r tool is from Harbor freight. I think it was $20. The die kept moving on it, so I set it to a piece of 18 ga. metal, and put a tack weld on it. problem solved.
Post by: jcassity on October 26, 2008, 09:55:39 AM
gotta love harbor freight, they have all those odd ball tools in a price range within reach of us diy folks.
Post by: vinnietbird on October 26, 2008, 10:08:22 AM
I need one of their catalogs.
Post by: jcassity on October 26, 2008, 10:21:21 AM
Quote from: vinnietbird;240417
once you get one,, you will never stop getting them.
if you pay for the "inside track" membership, the prices are a little lower plus you qualify for lower shipping deals and such. you also have access to things they have over stock of that are not listed in the regular catalogs.
to be honest, i am happy with all my purchases from them. thier power tools are really good also. I havent had to deal with any failures that put me into a return policy either.
If you look on line, you can find a harbor frieght store near by as well. we have one in Salem Va near me.
Post by: vinnietbird on October 26, 2008, 11:23:19 AM
I'm on it.
Post by: daminc on October 26, 2008, 05:12:20 PM
Vinnie, if you buy tools from there, you have to take them out of the box and use them. LOL
Today is another day to move things along.
Like I said, I need to seam seal where my hand won't reach. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4575-1.jpg)
Here are some pics of the backing strip being welded on. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4577-1.jpg)
Next is to fit the 1/4 panel and check the alignment. When everything looks good. It'll get welded.
Until next time.
Post by: vinnietbird on October 26, 2008, 06:52:51 PM
I have to use the tools if I buy them? !!!!!......That ruins everything. I STILL have to use the air tools and compressor I bought in June of '07 (still in the boxes). I haven't even removed the door panels and window trim I got from you from their boxes yet. I figure they'll be safer there until paint.
Post by: daminc on October 26, 2008, 10:27:11 PM
Quote from: vinnietbird;240462
I get the impression that everything in your house is still in it's original packaging. LOL Do you have plastic on your sofa?
Post by: vinnietbird on October 27, 2008, 10:10:06 AM
Nope,everything in the house is actually used.LOL.In the garage,that's a different story.I'll get the compressor out soon.I need to replace my strut bushings.I haven't even see the compressor yet,just the big box that it's in.LOL.
Post by: daminc on October 27, 2008, 06:26:12 PM
So I got things ready today, ground down some welds, and did some behind the scenes sorta stuff inside the wheel well for welding.
Here's the panel for it's last test run. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4580.jpg)
I had it on and off about 5 times, grinding and fitting the panel. Mabe 1 or 2 times after this pic. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4581.jpg)
the back end is even. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4582.jpg)
Well, it's official. It's now part of the car. Here it is tacked on. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4583.jpg)
I can actually say that I put the car back together in less then a year. Feels good to get that out of the way. It still needs to be welded, inside and out. But I won't be tripping over that thing anymore. LOL It takes up a lot of space.
Another thing to remember when welding..... don't drop your gauges on the floor when swapping gas cylinders.
These are usually at 0 when not connected. oops... I wanted a nicer set anyway. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4587.jpg)
That's all today :D .....................
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on October 27, 2008, 06:30:50 PM
And for those who didn't see my video rebuild tour..... http://www.foxtbirdcougarforums.com/showthread.php?t=21417 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=21417")
Post by: Kitz Kat on October 27, 2008, 06:33:07 PM
Seen the last pic, been there sucks. The stripe lines up better though!!
Post by: daminc on October 27, 2008, 10:06:44 PM
More stuff,
Got these parts for my car, when I met up with baxo and dominator. Had a great time that day. We'll have to do that again. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4505.jpg)
I also finished more doors for my house today too. I'm up past 100 so far. :hick: (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4590.jpg)
and base board (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4591.jpg)
Here's a shot of the size difference in panels between the cougar and bird. The lips, and some other frustrating areas are not the same. I also believe that the quarter panel has a different shape to it past the wheel well. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4592.jpg)
here's the inside view. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4593.jpg)
Everything ground down and pretty looking (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4594.jpg)
A little welding and grinding in the door jamb. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4597.jpg)
Here's how the door lines up after everything is together. just needs a little adjustment now. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4600.jpg)
So talking with my neighbor, and looking at my frame in the front of the car, he says that It can just be fixed, and made stronger then the original frame. Come to find out that he also used to add reinforcing to dump truck frames for a company, on top of repairing them. No worries now. My car will be built like a dump truck. LOL
That's all for today. Until next time......
Post by: thunderjet302 on October 28, 2008, 07:17:37 PM
Hmm I would have thought that the quarters were the same except for the original parts that you left on the car. Do you think that they could have warped after they were removed?
Post by: daminc on October 28, 2008, 07:41:48 PM
Quote from: thunderjet302;240764
There really wasn't anything that would make them warp. I used the nippers that cut out the center piece. the other side was the same way along the vertical seam and didn't quite match along the lower joint under the moulding. I can only assume a difference in panel shape right now. but remember, the trunk lid on a bird is tapered in width from window to latch. Cougars are straight. I'm guessing the quarter must have a bit more taper to it too.
Post by: FLSTCI71 on October 28, 2008, 07:58:23 PM
Hey, I'll vouch for the quarters. They may have warped somehow after they were removed, but I know they were taken off with loving care! :D
Post by: daminc on October 28, 2008, 09:41:28 PM
You did a great job with the quarters Mike, There's no way they warped the way that they're out of whack. I think I know what the problem is now. The inside welding s of my cougar, and the s of the bird couldn't be totally separated from their original welds. They seem to be rotary welded around the entire , so the end result is 2 extra thicknesses of 20 ga. sheet metal sandwiched in between my wheel well. (Approx. .0718" ) and with any gaps between the 2 different panels, I can see where I could gain an adittional 1/8 that the panel is off. Problem solved. long story short......It just needs a little filler. LOL
Post by: thunderjet302 on October 28, 2008, 11:54:42 PM
Quote from: FLSTCI71;240769
I don't think you screwed up taking them off:D I was guessing that maybe heat, storage, or something else caused them to warp not you.
Quote from: daminc;240778
Well hell it wasn't anyone's fault :D
Post by: FLSTCI71 on October 29, 2008, 12:11:53 AM
I know the warping wasn't anyone's fault. As Barney Fife would say, I was just being "obtuse". :hick:
Jerry (daminc), I hope you can get everything lined up, although I think you've already proven that you can.... and more!
Lou, (thunderjet302), it's been nice seeing you on my trips to Chicago the last couple of times. If you ever make it up to Minnesota, you're welcome to swing by here. Bring a pickup though, there's another guy in Chicago who wants some Turbo Coupe seats hauled back for him. :D
Post by: thunderjet302 on October 29, 2008, 12:18:30 AM
It's been nice seeing you too. If you swing through again let me know :D I just put the 88 away for the winter though. I put it away before the snow even thought about flying. It's too shiney and clean to be out in the salt ;)
I don't know when I'd be up in Minnesota but I'd have to rent a pick up as all I have to drive is T-birds;) You're north of the Twin Cities right? I might be up there in a year or so to see the new Twins ball park, and watch the Sox beat 'em again:rollin:
Post by: FLSTCI71 on October 29, 2008, 12:44:39 AM
Quote from: thunderjet302;240816
Nope, we're 100 miles south of the cities. The last Twins game I went to, they actually did play the Sox. And they lost. :mad:
Post by: daminc on October 29, 2008, 08:19:27 AM
Quote from: thunderjet302;240810
I guess technically it's my fault. I just didn't think about it until it happened on this side too. Other then the less then 1/8" difference on the back end of the panels, (why only there I don't know) the rest of everything came out perfect.
Fortunately it created a low spot in the panel seam. :D
I'll get some pics later to show
Post by: daminc on October 29, 2008, 06:23:37 PM
So here's the weird dip in the panel. Not sure how or why it did that. but at least it's in and not popping out. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4602.jpg)
here's the seam near the top. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4603.jpg)
I guess I'm going to roll with that and fill it. It's more then I usually like to fill, but I guess it could be worse.
Here's the work from today. I found that a socket fits perfect in the holes to line up the panels. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4604.jpg)
Got that welded up (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4608.jpg)
welded the trunk well. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4605.jpg)
See, I told everyone there's some paint under the back end. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4606.jpg)
started welding the inside of the wheel well. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4612.jpg)
All that needs to be done to finish the quarter panel is finish welding the wheel s, weld the quarter to the rocker inside the car. and put some extra welds inside the well joint. then it can be seam sealed and primed. The body part of the show is coming to an end. After the 1/4 panel, I can close up the underside of the rocker That's today for you. see you next time.
Post by: ZondaC12 on October 29, 2008, 07:04:54 PM
Wow cool that was an exciting episode. Ugh now theres nothing on TV nothing but infomercials. Oh well LOL new episode will be here before too long! :hick:
Post by: daminc on October 29, 2008, 09:22:57 PM
You need to learn to hack into the satellites for TV. That'll keep you busy for a while
Post by: ZondaC12 on October 29, 2008, 10:17:01 PM
Yea in all seriousness I have way too much time on my hands. With summer gone and all the shows and cruises done and even the late night weekend lot hangout withering on the vine...
Post by: daminc on October 29, 2008, 10:32:45 PM
Come down and finish my car. It's only a 9 hr drive. LOL
Post by: hirax on October 30, 2008, 07:29:17 PM
Quote from: daminc;240912
I guess it maybe caused by heating stress of welding. Maybe you did your weldings too long distance continuously and metal was overheated. But strange thing is that usually sheet will expand outward. Maybe this caused because you use backing strip to weld panels. When it cools down after welding it will constringe and bends sheet down. Of course now is too late and I am sorry if you already know this and did it this way, but I would like quote Randy Ferguson (http://www.fergusoncoachbuilding.com/):
You have to weld thin gauge sheetmetal much differently than you would heavier plate, even in the 1/8" range. You must weld a series of spot welds, with each one overlapping the last. I try to overlap by a 1/3 to 1/2 on each successive weld. You will also need to stop at regular intervals (not more than an inch) and stretch that area out before moving on, otherwise, it will have more distortion than you care to deal with. You start by placing tack welds at 1" intervals to keep the two pieces in good alignment. (I'm only assuming you're butt welding, at this point.) You can then start the welding process. I prefer to start in the center of the seam and work out both directions toward the edge. You must stop and work the weld as you go though. To best do this, a 1/16" cut-off wheel works great for knocking down the proud weld bead. You want to leave just a tiny amount of weld above the surface, because you're going to work this down some as you hammer the weld to stretch the metal back out. You only work within the Heat Affected Zone or HAZ as we often refer to. This is the blued area around the weld. Do not leave the area when stretching a weld. Even though the surrounding area is distorted, it is still unharmed. It's just sucked in down some when the metal shrunk along the HAZ. It will pop right back into place when you stretch the weld seam. You stretch it by hammering on dolly, in other words, you place a dolly on the backside of your weld and hit it with a hammer, making sure your hammer blows are against the dolly (or post dolly if you have one) This will rapidly stretch the area drawn in by the heat and relieve the panel of the stress caused by the heat, removing the warpage. You can now add another series of adjoining spots and continue the process, jumping back and forth from side to side, working ever closer to the edges of the panel until finished. Once you've gotten the weld completed, you can go back and fine tune the weld seam work the panel with a slapper and dolly, producing a very smooth panel. I prefer to use a file to work down the final few thousandths of proud weld, rather than a grinder that will remove too much material. A shrinking disc will come in real handy too, to shrink any areas that you overstretch.
Post by: daminc on October 31, 2008, 06:38:10 AM
I believe it's the problem of having to many panels sandwiched together. It was taking that shape before it was welded. I also had it pushed out with some supports. If you remember way back in this thread, I think I mentioned that the panels were stamped with crisper body lines then mine, and they also measured slightly different between the 2 panels. So I"m going to sum it up with.... You can only do so much, when you have 2 panels that don't match exactly.
Post by: Kitz Kat on October 31, 2008, 07:57:11 AM
You can probably get a brand new panel for the car and it wouldn't match. It's just the way it is.
Post by: daminc on October 31, 2008, 01:05:54 PM
That's true, You could get an entire replacement panel, and it probably wouldn't line up exactly like the old one. Don't forget these new doors lined up different then my old ones too, even before I cut the quarter off. I can't wait to see the problems with the fenders and new hood.
Hey Vinnie, Did your doors and fenders fit and line up like the old ones did?
Post by: Kitz Kat on October 31, 2008, 04:22:42 PM
I know your a perfectionist, but you can only work with what you got. Your beyond what I just said.It will work out.
Post by: daboss351 on November 02, 2008, 12:53:30 PM
I wish you could help me out... I need a rear quarter for my new mark, and im dreading it, but I think its gonna end up fiberglass again just because I dont have the tools or adequate welder. looking great!!
Post by: Thunder Chicken on November 02, 2008, 03:59:05 PM
Quote from: daminc;241086
I dunno about Vinnie, but I replaced almost everything forward of the windshield on my car, and it took quite a bit of work to get the 87 TC fender and 88 T-Bird door to line up. The fender off the 87 TC parts car actually had a different curve to it (it bowed out more). After bolting it on and removing it a few times (no amount of adjusting or shims made a difference - I'd hold it in place, tighten the bolts, and as soon as I let go it'd spring back to the wrong shape) I ended up permanently un-bowing it the simplest way I could think of. I sat on it. I took it off the car, sat it on the shop floor, and sat on it, right at the top of the wheel opening. I obviously didn't put my whole weight on it (it would have flattened), but it worked.
The header panel-to-fender fitment was similar (remarkable, since the fender and header panel came from the same car), but there were enough bolt holes that I managed to "force" the fender to take the correct shape.
After all that, the hood actually went on easily. I only had to adjust fore/aft a bit, and I had to adjust the height at the rear using the stops on the hinges.
Post by: daminc on November 02, 2008, 04:24:57 PM
Quote from: daboss351;241285
I wish I could help you out. Take some good close ups and we'll see the best way to fix what you got. I thought you had a welder now?
Post by: daminc on November 02, 2008, 04:36:03 PM
Quote from: Thunder Chicken;241314
I'm glad to see that I'm not the only one with panel issues. (Not that I'm glad you had a problem... You know what I mean.) I always hear about everyone else putting different parts on there cars, but no one has ever said if the parts lined up correctly, of if they had any problems with them.
Does anyone know where the panels where actually stamped, or how many different places made them? Now I'm just curious as to why the panels have different shapes, because now I'm pretty sure that was my problem.
Post by: daminc on November 02, 2008, 04:52:08 PM
Project update: I didn't finish the welding on the quarter panel. The weather was nice so I decided to epoxy paint the floor in the middle bay. I'm not going through the wet concrete floor problem anymore. Tomorrow I'll put a second coat on it. (pics of it tomorrow) Meanwhile, The rest of the week I'm going to get the car ready to pull the motor on this coming Saturday. It's the only weekend I'll have enough time to do it for a couple of months, and it needs to be done to keep the project going. The car will be moved into the middle bay that I just epoxied when the motor comes out. So not a lot to show right now. but there should be some spectacular pics next week. Probably of more rust. LOL I'm sure everyone is sick to death by now of the quarter panel/ rocker episode. I know I am. LOL
I'll keep everyone updated as the week goes on.
Post by: vinnietbird on November 02, 2008, 06:07:37 PM
Hey Vinnie, Did your doors and fenders fit and line up like the old ones did?[/QUOTE]
I have doors and front fenders from an '88 LX,header panel from an '87 TC,front bumper cover from an '88 TC,rear bumper cover from an '87 TC.Everything lined up great.No issues.The body lines are nice and matching up fine,the fenders were super easy to line up,although I did have to use a couple of extra spacers that the Sport didn't use with it's own fenders.No big deal.I hate filling and sanding it all though.That sucks.
Post by: daboss351 on November 02, 2008, 08:50:24 PM
Quote from: daminc;241317
I do but it blows through sheet metal like no tomorrow
Post by: daminc on November 03, 2008, 07:15:48 PM
Quote from: daboss351;241360
Even on the lowest setting? Try plugging it into a long ext. cord to cut down the power.
I finished up the welding on the quarter panel today. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4622.jpg)
Here's the outside of the wheel well (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4624.jpg)
Here's looking down into the 1/4 panel where it meets the rocker. Talk about welding blind. I had to feel for the holes with the wire to start the weld. I guess I need to clean that out a little better. LOL (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/rockers%20and%20quarters/IMG_4627.jpg)
And as I promised, the garage floor epoxy. 1 section down, 2 to go. Thinking about painting a big cougar (like my emblems) in the center, in light gray. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4623.jpg)
All that's left on this side is, welding on a new rocker bottom. That'll probably have to be done after the motor comes out this weekend. Until next time
Post by: mercury-man on November 03, 2008, 07:20:14 PM
Jerry, You have enough space there to paint the Word "Cougar" also. :poke:
Post by: ZondaC12 on November 03, 2008, 07:46:41 PM
Quote from: daminc;241504
First of all...looks great!!! Gotta love spills comin right up :D
this would have been very useful for a large bulk of your welds i would think and would'nt it reduce clean up on the burnt metal as well?
Post by: daminc on November 04, 2008, 12:06:37 AM
They're great for smaller projects and a lot of flat work. I used to use one in high school metal shop (a long, long time ago) making tool boxes. I could have used one for parts of my car too. It would have worked great on the bottom 1/4 panel lip of my trunk well, and also the inside wheel well s that I just welded. Mabe the next car. I believe a company also makes an arc welded attachment. here's one from Eastwood. (not sure how well these work though) http://www.eastwoodco.com/jump.jsp?itemID=1227&itemType=PRODUCT (http://"http://www.eastwoodco.com/jump.jsp?itemID=1227&itemType=PRODUCT")
Post by: HAVI on November 04, 2008, 08:34:53 PM
I've been looking at that welder as well. But I'm still holding out for a 2 probe resistance welder. 2 welds at a time and anywhere you can fit your hands....yea.
Post by: jcassity on November 04, 2008, 09:07:59 PM
Quote from: daminc;241568
whooo,, now i like that and 60A is well within range of back to back sheet metal. The welder i posted is purdy darn big. The pic is misleading cause it looks like a bear to handle. It does do the job though.
Post by: daminc on November 04, 2008, 09:21:12 PM
If I had an arc welder, I would have bought one. I guess it's another reason to buy another welder.
Post by: massCougarxr7 on November 04, 2008, 09:58:02 PM
I was never a fan of those spot welders.... id rather plugweld it like youve been doing... personally i feel that they are stronger, but slightly heavier obviously... cars coming along great! cant wait to see this secret stuff... Oh I came up with a name for my cougar project..... It will be callled........ THUNDERCAT ELIMINATOR XR7.5.. Instead of the normal cougar logos and emblems.. it will have the cartoon version of the cat symbol airbrushed on there...
Post by: HAVI on November 04, 2008, 10:19:42 PM
2 probe welder, was what I said, but I meant a Panel Spotter. Lencospot Mark II is one example. They also work like a stud gun, but are more capable of fitting into tight spots. There's really no excess weld to grind down like a MIG welder will leave behind. Not for structural panels, but as a compliment to any arc and MIG welder it sure would be nice to have. Oh, and they also have a rivet tip for putting on those molding rivets for trim. http://www.sjdiscounttools.com/lnxl4000.html
Post by: daminc on November 04, 2008, 10:20:27 PM
Ahh yes, the secret stuff..... Some of it is still in the blueprint stages right now.
Post by: daminc on November 04, 2008, 10:40:58 PM
Quote from: HAVI;241703
Those are still a little pricey. (for just a hobby) ;)
I have found that if you get a mig at a hot enough setting, you can blow a hole through the first layer of sheetmetal and it will weld to the next if you pull back. but it's easier to punch holes first.
Post by: baxo on November 04, 2008, 10:42:10 PM
Oh no another person with a secret.. the best secret kept are the ones where people aren't even aware of the idea of a secret, so you might as well just tell us what it is ;)
Post by: daminc on November 04, 2008, 10:49:44 PM
You'd like that, wouldn't you. I need to locate a part first. It's coming
Post by: daminc on November 08, 2008, 05:39:00 PM
So after a long week of working, it was time to do the nasty. Here's some random before pics. I just cut the exhaust off. Don't need it anymore. (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4632.jpg)
Quick view of where the new frame meets and can be welded with everything out of the way. The white spots are salt. (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4633.jpg)
A shot before the drive shaft was removed. (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4634.jpg)
The car coming down. (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4635.jpg)
This needs to be replaced. (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4646.jpg)
That's all for today. Now the fun can start. :D
Post by: thunderjet302 on November 08, 2008, 09:48:13 PM
Well it looks better than I thought it would up front:hick: I'm suprised that there are no holes in the frame rails. Looks like the fun can start now ;)
Post by: jcassity on November 08, 2008, 10:40:29 PM
do yourself a favor and replace the rack as well as hoses. Napa carries the high and low pres lines. The inner nuckle is adjustable as well,,wrote about the two different knuckles i have found in my diy link.
Post by: daminc on November 08, 2008, 10:59:34 PM
I plan on re-doing everything I can. The hoses are all cut off. I did save all the wiring harnesses in case someone needs them. Also goes for any parts off the motor itself. If someone needs anything for a T-bodied 3.8. let me know. The AOD is mine
You can also see that I cut the crossmember too it was rotted and I'm probably going to make my own
Post by: daminc on November 09, 2008, 05:19:07 PM
So I moved the car over today and started getting it ready for media blasting and paint removal. I put it on the other side because the lighting is better.
First things first. Need to protect the glass (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4661.jpg)
Removed the bumper, it wasn't pretty. I'll be needing new bolts and clips there. this entire back area will be blasted. The underneath will also be blasted as soon as the tank comes down. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4650.jpg)
Here's some more shots of the condition of the front end. Here's the holes on both sides, above the frame. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4660.jpg)
Here's some pics of the tunnel, and where the floor was repaired from the inside. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4658.jpg)
This side still needs to be finished (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4657.jpg)
A shot of where finished meet unfinished. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4653.jpg)
Here's an upward view. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4652.jpg)
I have to be honest. I was really worried about the condition of the front end, until the motor came out. I think it's going to be OK. It looks as though the hard part of the project is now done.
Post by: SR71TC on November 09, 2008, 06:30:20 PM
IMO, I would blast each suspension part including the K member and POR-15 all of it. Then install new bushings and hardware.
Jason
Post by: daminc on November 10, 2008, 07:26:12 AM
Quote from: SR71TC;242348
Jason
It's like you read my mind, except for the Por-15. ;)
Post by: thunderjet302 on November 10, 2008, 05:40:25 PM
Ah so you did have strut tower holes. Figures :hick:
Just make sure you pull the wifes Town Car out before you blast the Cougar ;)
Post by: daminc on November 10, 2008, 06:04:24 PM
I would actually call them holes behind the towers. the tower themselves are fine.
Someone did a little repair, I guess you can call it. many years ago, around 95, I had my tank replaced. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4665.jpg)
So I made myself a little blasting room. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4666.jpg)
And then stopped slackin and went to work.. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4667.jpg)
That's it for today.
Post by: Kitz Kat on November 11, 2008, 05:28:08 PM
Nows a good time to take care of the brake lines to. Was your firt born created in that car or something? that your goin through all this.
Post by: vinnietbird on November 11, 2008, 08:50:36 PM
Wow,that's insane.You'll have to keep this car FOREVER.I thought I put a ton of work into my Sport.Nothing compared to yours.You RAWK !!!! I spent about an hour sanding and applying a little filler on the Sport.More tomorrow after work.I really need to post pics.You're doing great Jeddy.
Post by: daminc on November 11, 2008, 09:16:41 PM
Vinnie, I honestly don't spend a lot of time on the car. yesterday was only an hour at most. most of the work I do is usually and hour after I work. Pull out those air tools you'll do a lot of work in a very short time.
kitz, I plan on doing all the lines that need it front to back, including E-brake. And no, no one was created in the car, (not that I know about) The 80s were a wild time for me.
Post by: jcassity on November 11, 2008, 09:23:36 PM
how's it feel to find out what you paid for years ago was repaired like that and you wasnt told,,ie-gas tank.
Hows that blasting working out in your opinion? Also, are you using a gun that shoots any media? Ive often thought about doing drop plastic like that and when I run out of media, i can just bunch up the plastic on the floor to collect it all back up again for reuse.
Nice work, it becomes a part of your life after doing it as long as you have. Ive never taken a car to parade rest like this, lucky for you its just another ride in the park. For me, i would be insane trying to get too much done too quickly.
Post by: daminc on November 11, 2008, 09:48:19 PM
Quote from: jcassity;242639
I kinda expected that. The same guy turned up my idle instead of replacing the TPS, and in turn overheated my car which in turn caused head gasket failure and a blown radiator, All because I didn't have time to fix the TPS myself.
The blasting is great, I'm using black beauty slag at the moment. I noticed it doesn't get into the pitting as good as aluminum oxide. I may have to change back, although the slag is a lot cheaper. I also collect it up and sift it through a screen. It lasts a long time doing it like that. I've got a $18 bucket blaster and a gravity feed siphon blaster, they both use any media, and they both work about equal in comparison
Post by: vinnietbird on November 11, 2008, 10:09:05 PM
Air tools..............aaaaaaah yes....I keep for getting about those.You'll be happy to know that they will be out soon so I can install my new strut bushing assemblies,and install the spare differential soon as well.Pics of that stuff when it happens.I am like you as far as spending time with the sport,an hour here,an hour there.I figure every hour I'm sanding or whatever is still an hour closer to finishing.
Post by: jcassity on November 11, 2008, 10:17:46 PM
Well, just my opinion but from what I noticed, play sand works in the pits. the regular pool or beach sand is a little too big where as the play sand is super tiny particles.
I dont know much about sand but ill bet its graded like gravel sizes and such.
Post by: daminc on November 11, 2008, 10:27:16 PM
If you use play sand, you need to use a supplied breathing system. That silica dust will take 20-30 years off your life.
Post by: daminc on November 11, 2008, 11:15:47 PM
Quote from: vinnietbird;242649
Yep, sometimes I get a lot of hours free being self employed. Sometimes I don't get any for a month or 2. Fortunately winter time has more hours free then summer.
Post by: jcassity on November 12, 2008, 12:22:54 AM
yeah, i wouldnt blast without a 3m mask.
Post by: jcassity on November 12, 2008, 12:25:37 AM
Holly ,, i just remembered.
Product sold at lowes in the paint department. Its a spray on paint remover made by "Jasco". I gotta dig up one of my old threads where i used it.
I found out by accident that not only did it remove paint but it also removed corrosion. In place of the corroded area, it left behind black discoloration where it ate away the rust. I was totally amazed at its perfromance. To beat all, its fast acting.
ahh,,, here is the link. http://www.foxtbirdcougarforums.com/showthread.php?t=8960&page=2&highlight=jasco I gotta see if i have a pic of the product in my engine swap thread.
Post by: ipsd on November 12, 2008, 02:02:17 AM
Quote from: jcassity;242661
You had better read the back of the package the mask came in not very many protect you from silica.
Post by: vinnietbird on November 12, 2008, 06:39:44 AM
We have particulate masks at work that protect you from the tiniest trash.I'll see if I can grab you a box Jeddy.
Post by: daminc on November 12, 2008, 07:26:38 AM
Quote from: vinnietbird;242675
Cool, although I don't use actual sand for blasting and I always use a mask under my hood. There's also dust around doing bodywork, grinding and sanding that I'm going to do a lot of right now.
Post by: daminc on November 13, 2008, 06:56:25 PM
Small update today Started to get rid of the rust and paint on the back end today.
Post by: daminc on November 14, 2008, 08:04:22 AM
Here are some pics I found on the first day that I decided to fix my car. I'm not sure what I was thinking. but it should have been "RUN NOW". That was one year ago today Here's what I saw after I took it apart. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/1st%20day/IMG_2845.jpg)
This is one of the first pics I ever posted (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/1st%20day/IMG_2846.jpg)
This may be the only pic that I have of my car before it became the Flintstone car. This is right before the interior came out. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/1st%20day/IMG_2844.jpg)
And it just got worse from the start (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/1st%20day/IMG_2850.jpg)
I think that's all the pics that I have of the car before it became what it is now. Still looking for the original pics of her when I first brought it home, but I think they're long gone.
Enjoy
Post by: jcassity on November 14, 2008, 08:50:37 AM
pop those filter screens out of the cowl near the wiper arms ,check and see if you have a water leak in there. that one pic of the driver floor board seems to show a corrosion path up over the trans tunnel / fire wall weld.
Post by: baxo on November 14, 2008, 10:22:35 AM
Wow man you have come a long way in a year! it's awesome to see the progress on pics, but even more awesome to see in person! Keep it up man
Post by: daminc on November 14, 2008, 01:32:46 PM
Quote from: jcassity;243034
I've noticed that before. It's on my things to do list when I blast the front. ;)
Post by: vinnietbird on November 14, 2008, 06:06:13 PM
Post by: daminc on November 15, 2008, 08:52:11 AM
Quote from: baxo;243044
If you keep coming over to see it, I'll have to put some tools in your hands and you can help. LOL
Post by: daminc on November 15, 2008, 08:55:09 AM
Quote from: vinnietbird;243066
Wow.......I'm impressed !!!!
I'll bet I was more impressed with myself actually remembering something from 1968. LOL
Post by: vinnietbird on November 15, 2008, 09:04:31 AM
Aaaaaah the good old days.I'm not old,but I'm not as young as I used to be.Luckily,I still have my real hair and all my teeth (minus two wisdom teeth),and can still run circles around any of our kids.I'd like to go back to the early 80's knowing what I know now.CHA-CHING !!!!!!!!!
Post by: thunderjet302 on November 15, 2008, 09:08:47 PM
Wow a year already? You need to hurry up ;)
Post by: vinnietbird on November 16, 2008, 10:01:03 AM
How's it going? Any progress gonna happen today? I'm going out in an hour or so to get crack-a-lackin' on the Sport.
Post by: daminc on November 16, 2008, 10:17:58 AM
There's always progress, but sometimes it's not noticable in pics, until something looks totally different. It's probably going to be that way for a while. I'm not sure anyone want's to see a pic of 6 more inches of paint removed from a panel. It'll pretty much look like the last pic, just a little less paint. LOL
If everyone is into the step by step pics, I'll gladly post them as I strip the car. But I don't want to bore anyone either. It's up to everyone on that. Let me know if I should or not, because I do have some after the last batch
Post by: Kitz Kat on November 16, 2008, 10:26:55 AM
I just want see it done, I'm sure you would to.
Post by: vinnietbird on November 16, 2008, 10:30:27 AM
I love this thread.It makes me see how puny my car's bodywork needs really are. LOL.
Post by: daboss351 on November 16, 2008, 05:21:00 PM
looking great man!! Makes me almost wanna tackle my body work now... Nahhhhhh
Post by: daboss351 on November 16, 2008, 05:21:29 PM
Post by: daminc on November 16, 2008, 06:09:12 PM
Well, I didn't get any reaction from the earlier post, so I guess I'll keep updating as I go. Heres another pic like the last, with less paint on it. LOL Makes that seam a litter harder to see with no paint around it. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4675.jpg)
I thought I would have time today but ended up painting the house before the holidays. There wasn't much progress in the last pics. I was testing out my bodywork tools that I've had since I was 18. Looks like everything is still in working order. also had to relocate my water separator farther from the compressor. Let the stripping begin
Post by: jcassity on November 16, 2008, 08:20:49 PM
no reaction my ass,, Me and the boys look forward to this thread.
Post by: massCougarxr7 on November 16, 2008, 08:37:16 PM
I look forward to looking in this thread too! I cant belive the spots that you have rust in........especially that one area above the taillight in the above pic... looks rough..
Post by: thunderjet302 on November 18, 2008, 09:08:35 PM
Looks like you're missing part of the rear quarter near the deck lid;)
Post by: daminc on November 19, 2008, 05:26:26 PM
I'm cutting it off and welding a new section on. The back tip is the same on birds, so I'll use the rest of the quarter panel for that. I can just imagine the rust I'm going to find under the paint. I found a little so far.
Post by: daminc on November 20, 2008, 07:46:33 AM
Here it is. the very back end is the same if you tip it. If it doesn't work, I'll just make my own. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3445.jpg)
Post by: thunderjet302 on November 20, 2008, 03:01:45 PM
I bet you're going to have to make your own. ;) You can handle it though. How's the rest of the under body looking as far as panel replacement goes?
Post by: daminc on November 20, 2008, 05:54:57 PM
Quote from: thunderjet302;244021
The rest is looking great. I started blasting the first scaly rust layer off. Here's some pics after an hour and a half of blasting. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4678.jpg)
I'll be cutting off the tank brackets and make new ones. there's a little swiss cheese around the brackets that also needs fixing. so I'll weld on new metal so the brackets are nice and strong. other than that, there's nothing to serious to fix under here. The next pass should get rid of the rust.
Post by: daboss351 on November 20, 2008, 08:58:06 PM
o mine next mine next!
Post by: daboss351 on November 20, 2008, 08:59:31 PM
do you need a brand new gas tank and straps?? I need cash like no tomorrow, and have a new tank/straps under the blue car...(same as bird cougar)
Post by: daminc on November 20, 2008, 09:29:47 PM
My tank is good and I was going to make new straps, sorry
Post by: daminc on November 21, 2008, 05:01:28 PM
, looks like I need another pass (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4689.jpg)
Post by: vinnietbird on November 21, 2008, 05:36:57 PM
Oh well,you have plenty of time.The masks are going out Monday.I have been so distracted by body work (I'm actually enjoying it) that I forgot to mail them,and 4 Ebay packages.I hope I don't get negative feedback from those folks.Good work on the Cat so far.
Post by: daminc on November 22, 2008, 08:52:42 AM
Yea I know, I have all winter. BUT, It would be great to have the bodywork done, and everything ready to paint come early spring. This part, up in and around the trunk well, is probably the worst and hardest part to get to. Lots of small spaces.
Thanks for the masks, I'll look for there arrival around the holiday
Post by: daboss351 on November 22, 2008, 04:10:36 PM
Eh its not a problem I figured id offer to you, other wise its gonna go in my new mark with a bigger pump
Post by: daminc on November 22, 2008, 05:49:04 PM
So I blasted for a better part of the day. I and it just isn't looking any better. Most of the areas, I can't get close enough to get the rust off. and the rest, It just won't come off any more then it already has. Looks like I'm gonna have to convert the rest of the rust, and seal it with rust coating. Here's what I ended up with. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4694.jpg)
And for those of you who require a little progress in their pics............. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4702.jpg)
Post by: BEARMAX on November 22, 2008, 05:56:57 PM
yea looks alot like what i did with the vert it is hard to get i some areas...so thats what i did was use aspho to netrulize the rust i then coated it with pour 15 and then i rino lined every thing...turned out great
Post by: baxo on November 22, 2008, 08:31:38 PM
Hmm.. that's a lot of exposed metal, hopefully you coated it :D
Post by: daminc on November 22, 2008, 10:13:22 PM
Quote from: baxo;244342
Coated it?
LOL
Post by: jcassity on November 22, 2008, 10:58:54 PM
I use the 3m (chemical / biological) filters on my mask. Im not sure why everyone siad the 3m masks were not good enough, i have lots of sealed filters that you screw on each side of the mask. Maybe you guys thought I was talking about dust masks. I like this kind of work you doing. The blasting part is where all the good detailed quality comes in so the primer has its fullest effect.
thanks for the latest porn,, :D
Post by: daminc on November 23, 2008, 08:01:45 AM
I use the same filtered masks for the bad stuff, and the lighter duty face masks for the body work.
That rust treatment paint (zero rust in my case) will grab onto just about anything that doesn't flake off. I treated everything yesterday with picklex. Bare metal and anything that still has some surface rust. That quarter panel will stay looking like that for a long time without rusting. (about a year) I just need to scuff it before I prime it or do filling.
Post by: jcassity on November 24, 2008, 02:16:30 AM
That Picklex stuff is good, I just google'd it. Never knew it was enviro friendly although you probably said so somewhere.
cost? found at?
Post by: daminc on November 24, 2008, 07:55:22 AM
Quote from: jcassity;244517
cost? found at?
Here's where I usually buy most of my stuff. Sometimes I can find better deals elsewhere, but this is almost always the cheapest place. I also belong to this forum too. As they say, it's my home away from home. I always double check with the collision pros before I rip into anything. ;)
Picklex is very good and safe to use. It's a little pricey at $32 a pint, but I just started using my 2nd pint the other day on the body panels. A couple small spritz's and a scuff pad did the entire quarter. Just work it in, and wipe the extra residue off with a paper towel. One pint would probably do a normal job though http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC (http://"http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC") It will convert rust, and keep bare metal from flash rusting from moisture in the air. But it will rust if it's in contact with rain and snow.
Zero-Rust is on the same page. Definitely the cheapest place to find it to. I did find it cheaper by $2 once, but that place is gone now. But $52 for a gallon of black is well worth what the product does. Right now I have used just under 2 quarts on my car. It's sprayable, brushable, and paint roller friendly. doesn't need to be activated and doesn't stink to high hell.
Post by: ZondaC12 on November 24, 2008, 09:36:15 AM
Yeah I mean that all looks good really. All the loose is gone...looks good and solid anyway...I mean if blasting wont rip it off...lol aint goin anywhere so that encapsulator stuff oughta be great.
And that shot of the back corner looks nice...mmm fresh steel :cool:
Post by: daboss351 on November 24, 2008, 12:34:50 PM
wanna fix my car? I need a plate for my upper front bag mount... its rusted out
Post by: daminc on November 24, 2008, 05:50:01 PM
Quote from: daboss351;244565
Sorry, there's already someone in front of you. :D
A little progress today. Things are still moving along (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4706.jpg)
and just in case you were wondering how those silly cap strips came off. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4710.jpg)
Post by: Kitz Kat on November 24, 2008, 06:05:25 PM
You know you can barely see where you welded the 1/4 on, but I felt it!! it's good.
Post by: vinnietbird on November 24, 2008, 06:46:57 PM
Sweet work.I had those cap strips off of the blue car.It took me a little while to figure that out.I thought they were stuck on.I wish they were.
Post by: daminc on November 25, 2008, 08:04:58 AM
Quote from: Kitz Kat;244586
It looks a lot better without all the colors around the seam high lighting it. It's hardly noticable when you run your hand over it after I stripped all the coats of paint off. I'll probably only need a quart of filler on the entire car.
So the plan is.. To strip the entire car, do my filling, then epoxy all the body panels. Then I'll start blocking the car flat and smooth. I'm also going to finish the blasting from back to front, replacing and repairing whatever I find along the way. This should keep me out of trouble for the winter.
Post by: daminc on November 25, 2008, 05:54:48 PM
So I decided to keep on stripping the car, and this is what I found. hmmmmmmm..... (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4731.jpg)
So I thought it was just a small bit of filling around the handle...... (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4735.jpg)
Guessing the doors were stripped, skimmed, and blocked at one point. I thought The doors had a little wave to them in the shop lights. And also sounded a little dead when I tapped on them. The big question now, is leave it, or strip it bare again.
Checked the other door to make sure it wasn't just on one door. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4733.jpg)
Post by: vinnietbird on November 25, 2008, 06:11:30 PM
My doors were like that as well when I was sanding them.I'm guessing that was from the factory.You're really doing great.For a while,it started feeling like a dreaded job-now I'm excited and enjoying every minute of it.I think after nearly two years,I was getting a little burnt out.I have my second wind.I'm working on the Sport tomorrow.It should be ready by tomorrow after lunch,before supper.Now,I need $200.00 more for the paint job.I had to spend a little of the paint funds.No big deal.I'll sell some more parts and my Cobra Mustang computer (which will bring a few bucks I hope).As far as filler,I don't think I used but about half a quart on the car,if that.I didn't have a bunch of welded panels either,though.Keep it up Jeddy.
Post by: baxo on November 25, 2008, 09:02:17 PM
Oh shiznit man that's not a good surprise :( .. I would strip it.. see how bad it is and maybe find another door.. You've been doing such a good job with this, i doubt you'd feel right having so much filler on your car that you didn't put there.
Post by: HAVI on November 25, 2008, 09:04:57 PM
and on top of that, how old is the filler already? older filler will be destined to crack before the rest of the car is ready to be put down.
Post by: daminc on November 25, 2008, 09:18:34 PM
I know the doors were in storage for about 6 years
Post by: FLSTCI71 on November 25, 2008, 09:24:02 PM
What about Vinnie's comment, that the filler may be from the factory? Either way, I think you're doing the right thing by stripping the doors. You need to have them bare and see what you're up against.
Post by: daminc on November 25, 2008, 09:37:56 PM
I can't see ford going through all that on a set of doors unless they got damaged after they left the factory. there's small spots of dark gray primer under the fill. they were definitely stripped and redone at some point. there are no dents or creases looking on the inside of the panel. they were also undercoated inside the doors Either way, it's got to go.
Post by: daminc on November 26, 2008, 10:25:31 PM
I'm definitely going to strip it down to bare metal. As far as I know, there may not be any filling except for that handle area. The yellow, I was told is probably Dupont URO prime. A high build primer/filler. So It's out of here, and I'll cross my fingers that the doors are OK. I should be able to attack that this weekend to find out. Just thought I would update my plans for the doors.
Post by: vinnietbird on November 26, 2008, 11:16:33 PM
As I stated,both of my replacement doors were the same way.They were original paint.......for now.
Post by: daminc on November 27, 2008, 08:05:33 AM
Quote from: vinnietbird;244902
Let's see... I thought mine had original paint too.
Post by: Kitz Kat on November 27, 2008, 08:50:24 AM
Iv'e seen that yellow coating on a few 80's ford panels, I'm pretty sure thats a factory thing. If its only a little putty may of been damaged in delivery or on the lot, seen that a few times.
Post by: daboss351 on November 27, 2008, 03:08:45 PM
my 88 linc had that as well on some panels
Post by: jcassity on November 27, 2008, 08:53:27 PM
Quote from: baxo;244758
No,, leave it go.
As you move down on the lower part of the door , the rock guard layer will get more thick.
Its been on 4 doors that ive cut on and from the inside, they have never had signs of collision or rust. I would surface sand and work from there. Your just tearing down an already good layer of metal protection as it is.
Post by: daminc on November 27, 2008, 09:12:51 PM
Well I already found filler and traces of dark grey primer under the coating. there is no chip guard on the door and I would feel better knowing what's under all that. if nothing, It's going to get coated with high build primer again with the rest of the car anyway.
Post by: jcassity on November 27, 2008, 09:39:39 PM
you found nothing of a thicker nature on the lower part of the door below the molding?
Post by: daminc on November 27, 2008, 09:49:45 PM
Nope, no chip guard on the doors, and a bunch of filler around the handle, so far.
Post by: daminc on November 28, 2008, 05:41:15 PM
It's not original paint. I took my DA to it, and what do you know, another layer of blue paint with red primer like the rest of the car. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4755.jpg)
So I stripped it off, because there would be way to much paint on the doors after I got done painting it again. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4756.jpg)
So after all that, there's only a couple little door dings. Not bad for 20 year old doors. I'll keep stripping the car as time allows.
Post by: baxo on November 28, 2008, 07:01:37 PM
.. haha that turned out better under there than I expected. You lucked out!
Post by: daminc on November 28, 2008, 07:45:54 PM
LOL I didn't see anything bad on the backside before I started. I figured there were just a couple dings.
So now I'm looking at the door wondering if I want to keep the handles. Anybody know of a good shaved handle kit at a fairly cheap price?
Post by: vinnietbird on November 28, 2008, 08:03:13 PM
How about door handles from a newer car?More flush mount.
Post by: daminc on November 28, 2008, 08:19:55 PM
Like the newer Lincoln handles?
Post by: vinnietbird on November 28, 2008, 08:27:28 PM
Lincoln,Honda,whatever.Just something smooth and flush.I personally have always thought that smoothed doors (No handles at all) took away from the "details" of the car.Too much flat space with nothing there.My own opinion of course.My taste differs from others.....a lot !!!
Post by: daminc on November 29, 2008, 05:24:59 PM
I'm thinking I'll keep the handles. Mabe not the original type of handles, but there will be handles.
Took some more apart today, and packaged everything up so it won't get damaged. Removed the rest of the pass. side glass and weather stripping. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4763.jpg)
and trunk lid and back window moulding (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4762.jpg)
It's going to need a little work. Looks like I may have to rebuild the rebuild. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4761.jpg)
Post by: HAVI on November 29, 2008, 05:34:22 PM
Jerry, I prefer to keep door handles myself, but with the Fox style handles these cars have, I've had no luck in keeping them from breaking all the time. So you may be right in your thinking. Keep up the good work!!!
Post by: DerikWayne on November 29, 2008, 08:06:52 PM
This car (and project) should be featured in a magazine! Great work, man!
Post by: daminc on November 29, 2008, 09:40:33 PM
Thanks, but I don't know if I would go that far. And I hope the end product will be worth it.
Post by: jcassity on November 29, 2008, 10:00:43 PM
your trunk is in awsome shape,, where we all normally see rust you have none as in where the hinge is.
Post by: daminc on November 29, 2008, 10:05:36 PM
I rebuilt the entire back from the bodyline down and the inside. If you look close, it doesn't look the same inside to the lip as everyone elses
Post by: daminc on November 30, 2008, 03:45:01 PM
It just sunk in The trunks rust at the hinges?
I removed a little more paint today. And Yes, there was chip guard under all that. Now I need to realign the doors again. I took more than an 1/8" of fill and chip guard off the bottom of the door panel. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4769.jpg)
Here's the trunk lid (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4768.jpg)
Here's an old repair. Time to do it the right way (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4770.jpg)
Time to move to the other side.
Post by: DerikWayne on December 01, 2008, 01:09:22 AM
Amazing what you find under paint sometimes.
Post by: daboss351 on December 01, 2008, 09:35:30 AM
so thats the repair you told me about thats not bad at all!
Post by: daboss351 on December 01, 2008, 09:40:38 AM
O and btw your subframe connectors will fit a mark VII, no mods, since griggs racing tbird subframes fit right in. Build me a set to buy haha
Post by: daminc on December 01, 2008, 01:16:57 PM
Quote from: daboss351;245582
You have the plans. ;) I'm sure shipping would be outrageous. Chuck told me it wasn't pretty to ship those types of things If you were in driving range it would work.
Yes, that's the quick repair I did 10 years ago. did it in an afternoon. It was the only part of the car that had rust on it. Who knew my car was a rust time bomb waiting to explode.
Post by: Kitz Kat on December 01, 2008, 03:28:53 PM
About shaving, If you do shave something at least do the trunk lock. That way it don't get scratched opening it.
Post by: vinnietbird on December 01, 2008, 05:48:05 PM
The trunk lock is the one lock I'd get rid of if I welded....which I don't.I can always use the power release.After paint,and with my NOS locks going on,I need rubber keys.LOL.
Post by: daminc on December 01, 2008, 05:54:02 PM
I was looking at that lock and thinking the same thing yesterday.
Couple more pics today I finished up around the hard to reach areas. Mainly around the windows and upper body line (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4771.jpg)
And started on this (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4772.jpg)
Post by: daminc on December 01, 2008, 05:57:35 PM
I got one of these to sell if anyone is interested (http://i233.photobucket.com/albums/ee79/daminc/parts%20to%20sell/IMG_4774.jpg)
Post by: daboss351 on December 01, 2008, 06:00:06 PM
idk i got a h pipe shipped to me for 40 bucks... if they were in peices and I welded them might be cheaper. If I make them im sure ill screw up
Post by: Kitz Kat on December 01, 2008, 06:09:45 PM
Bubba!! you need a dust evacuation system!!!
Post by: daminc on December 01, 2008, 06:35:05 PM
Quote from: daboss351;245671
I could send you a pattern made out of light wood.
Post by: daboss351 on December 02, 2008, 10:13:50 AM
Quote from: daminc;245683
Let me know how much youd want for it and do it up!
Post by: daminc on December 02, 2008, 10:58:17 AM
Quote from: daboss351;245777
Just shipping. I'll put it together with screws, and cut it in half for shipping. I'll make it so you can put it together full length when you get it.
This way, it there's a slight diff. in frame, you can adjust it to fit yours.
How does that sound?
Post by: freddk13@yahoo.ca on December 02, 2008, 11:01:43 AM
Dumb question. How are you removing the paint?
Post by: daminc on December 02, 2008, 11:14:57 AM
40 grit disk on a grinder @ about 1000 RPM. It won't heat the metal up and distort at that speed. Pretty much the easiest and cheapest way to remove the paint. Are you from the autobody forum? Your name sounds familiar.
Post by: Kitz Kat on December 02, 2008, 04:28:01 PM
I don't know about easy, but aircraft stripper would be. Then you can see whats tuffer the new floor or the cat. I'm an A$$, I know!!.
Post by: freddk13 on December 02, 2008, 05:49:36 PM
Quote from: daminc;245790
Yes, I am. I am using that site and this thread to try to learn enough to complete my own restoration. (And this thread for inspiration! - Thanks for that!)
Post by: daminc on December 02, 2008, 05:56:02 PM
LOL OK, I'm just plain cheap. cost about $2 for disks and a total of mabe 2 hrs to strip the hood and coat it.
Here's the rest of it done. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4782.jpg)
Here's a little surprise I found on the hood. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4778.jpg)
So I got done with that and on to this. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4779.jpg)
Here I just wedged it on for a look to see if it was going to work. It appears to be the same. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4783.jpg)
I'll bolt the trunk lid back on, and work on the corner and the trunk fix next. And probably the tank brackets, so I can paint the underneath. Until next time..
Post by: daminc on December 02, 2008, 06:04:06 PM
Quote from: freddk13;245844
Glad I can help, You never did post pics of the car, did you?
Post by: daboss351 on December 03, 2008, 10:26:51 AM
Quote from: daminc;245786
sounds amazing Id owe you big time!
Post by: daminc on December 03, 2008, 01:24:09 PM
Quote from: daboss351;245932
PM sent
Post by: daminc on December 03, 2008, 05:37:28 PM
Did some fiddling with this back corner today don't ask about the pic, I don't know what happened there. LOL (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/MVI_4788.jpg)
found a better one. I put the lid back on to do some aligning to that piece. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4789.jpg)
Also had to put the lights back on to make sure everything was right. I'll bet you didn't even know I had lights. lol (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4790.jpg)
So everything looks Ok there, I'll weld it up when I do the tank supports. that's next.
I also did some sealing and cleaning up in the trunk. I also removed almost all the seam sealer in here (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4793.jpg)
Here's pics of the inside of the quarter panel repairs. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4795.jpg)
And I found this floating around in my tool cabinet. I should make it into a keychain. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4797.jpg)
Look at me go! :D LOL
until next time
Post by: vinnietbird on December 03, 2008, 06:06:14 PM
It looks like the corner piece needs to come down just a tiny bit more,but,I've only got the pics to look at.It may be different in person.Still,nice work.
Post by: daminc on December 03, 2008, 06:31:33 PM
It may have moved a little before the pic was taken. I had the trunk open and closed a bunch of times. I'll do better next time.
Post by: vinnietbird on December 03, 2008, 06:52:21 PM
No worries.You're rockin' right along.Awesome.
Post by: Kitz Kat on December 03, 2008, 07:12:24 PM
I want to know of the weight of this when its done. Have you thought about puttin tracks on it yet?
Post by: daminc on December 03, 2008, 07:22:00 PM
I don't think it's going to be any different in weight, other then the SFCs which is about 60lbs total.
Tracks?
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: Thunder Chicken on December 03, 2008, 09:22:09 PM
I think he meant Tank tracks, as in "It's built like a tank" ;)
I still say you shoulda installed T-Bird tail lights :D
Post by: daminc on December 03, 2008, 09:46:10 PM
I found these. What size should I use? (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/radmeister_rubber_tracks.jpg)
Post by: vinnietbird on December 03, 2008, 10:10:03 PM
If you use a nice aftermarket exhaust,it'll offset the 60 lbs you speak of easily.I am curious of the weight myself.
Post by: daminc on December 03, 2008, 10:24:58 PM
Do you think it's going to weigh a lot? More than an XR7?
Post by: jcassity on December 04, 2008, 01:44:14 AM
sheshhh,, you had a nice bumper there and i missed out!!!:mad:
Post by: vinnietbird on December 04, 2008, 06:54:27 AM
With all of the options you're adding,I bet it'll weigh in like any normal,un-modified ,well optioned Bird or Cat.
Post by: daminc on December 04, 2008, 07:15:48 AM
Quote from: jcassity;246084
bumper?
Post by: daminc on December 04, 2008, 07:20:55 AM
Quote from: vinnietbird;246098
This is what I figure too. It'll have most options minus moon roof and a few other things. That leather weighs more then cloth too, you know. LOL
Post by: vinnietbird on December 04, 2008, 05:06:24 PM
My Sport is light already.I don't really care much about a hundred pounds either way.I'll be having black leather seats.If it was an all out drag car,sure,weight would be a factor,but,since it's a daily driver,a fun car,I want comfort and really cool looking as well.If it costs a few pounds,so be it.I'll be happy.The Sport hasn't been complaining (because she knows paint is coming soon).
Post by: daminc on December 04, 2008, 06:54:05 PM
today's pics. I put a quick coat of paint in the trunk like the floor. I also have a couple small holes along side of the supports that support something under the car. I have yet to see a real need for them, other then a place to collect like the tank supports, and rust. I may just seam seal those couple holes. after all, look at all the holes in the car with plugs in them. Anyway they're blasted, treated and encapsulated. how much more could they rust. I did a few random pin holes that way on the floor too (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4802.jpg)
I welded the corner on. Needs a little tapping here and there, but it's a good fit. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4803.jpg)
And what would this tread be without a request. This could work if I cut the back down a little bit. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4798.jpg)
That todays excitement.
Post by: 50tbrd88 on December 04, 2008, 07:18:29 PM
That is coming a long way man! Keep the pics coming its amazing what you are getting done there.
Post by: jcassity on December 04, 2008, 09:45:17 PM
FULL STOP!!!!
this is when you go back to the trunk and let the light come back on in that brilliant mind of yours!!!
stare directly in the trunk dead center of its floor and to the right slightly about 10''.
see any mods you think would be useful? hint,, post #526
also,, about the bumper,, I meant the bumper cover.
Post by: baxo on December 04, 2008, 09:53:33 PM
Wow great work man keep it up!!
Post by: HAVI on December 04, 2008, 10:39:30 PM
I agree with post #526. Shoulda been a factory option in the first place, lol.
Post by: DerikWayne on December 04, 2008, 11:13:41 PM
Nice looking hood! Nice find
Post by: vinnietbird on December 04, 2008, 11:33:20 PM
Sweetness.Keep the Cougar lights.It's the right thing to do.
Post by: daboss351 on December 05, 2008, 10:33:58 AM
looking good!
Post by: Kitz Kat on December 05, 2008, 02:14:08 PM
Quote from: daminc;246050
You may have to do some custom interior work to fit them. but yeh thats what I ment.
Post by: thunderjet302 on December 05, 2008, 02:54:07 PM
Quote from: jcassity;246207
FULL STOP!!!!
Oh you mean to cut a hole in the floor above the fuel pump to make replacement easier? Why would he want to do that? Wreastling the thing out with a half tank of gas is great fun! :hick:
Post by: Kitz Kat on December 05, 2008, 03:34:52 PM
He won't have to the new pump he puts in will last him 30 yrs.
Post by: daminc on December 05, 2008, 04:41:45 PM
kitz does have a point, unless I get a dud. or I want to change it for some reason. I also have access to a fork lift from my neighbor. The amount of gas in the tank wouldn't be a problem.
Post by: daminc on December 06, 2008, 05:51:01 PM
Took care of some loose ends today. Got my tank out and pulled the pump and sender out. Well, at least something under my car had paint on it. (http://i233.photobucket.com/albums/ee79/daminc/Tank%20and%20supports/IMG_4805.jpg)
Here's removing the pump and sender (http://i233.photobucket.com/albums/ee79/daminc/Tank%20and%20supports/IMG_4808.jpg)
Look what I found. the guy that caulked the connector on the tank left me a surprise. (http://i233.photobucket.com/albums/ee79/daminc/Tank%20and%20supports/IMG_4810.jpg)
Here it is next to the old one (http://i233.photobucket.com/albums/ee79/daminc/Tank%20and%20supports/IMG_4834.jpg)
I just need to weld a couple more welding s on, and weld a bolt onto the supports for mounting the straps. (dominator gave me the bolt idea) (http://i233.photobucket.com/albums/ee79/daminc/Tank%20and%20supports/IMG_4835.jpg)
That's today's fuel tank adventure. :D
Post by: mywifeskitty on December 06, 2008, 05:59:21 PM
i love when people with skills use them :) it's going to be a brand new car when you're done....
on a different note, how do you post so many pics and put words between them in the same post (i'm not one of those with skills :))
Post by: cougarXLS on December 06, 2008, 06:16:38 PM
:jerry:
Wow, and a bunch of pages later, I am back up to date. Just amazing daminc!
Keep the pics flowing, no matter how small :) !
:bowdown:
Post by: cougarXLS on December 06, 2008, 06:20:59 PM
Oh, and a question:
Would you be interested in fabricating up a duplicate set of those mounts for the fuel tank? I'd be interested. You remember, I did after-all, drop my pocket (http://www.foxtbirdcougarforums.com/showthread.php?t=17634). LOL
Post by: daminc on December 06, 2008, 11:31:19 PM
Quote from: cougarXLS;246511
Oh, and a question:
I thought you fixed your tank problem?
Post by: daminc on December 06, 2008, 11:41:06 PM
Quote from: mywifeskitty;246499
I guess there's enough new parts going on to say that it'll be kinda new.
Post by: vinnietbird on December 07, 2008, 12:21:15 AM
Every time I see the pics of your car,it makes me really glad that my Sport has zero rust,and that the top of my fuel tank and the chassis still looks nearly new.....although it's 22 years old.Thanks for going through all the hard work to make me feel good.
Post by: jcassity on December 07, 2008, 02:05:34 AM
!!!!!!!!!!!!FINALLY!!!!!!!!!!!!!!!!! i get a picture of a sending unit!
Years ago i changed the fuel pump and pulled the sender also just so i could see how it worked. I went into the house to refill the coffee and there sits my two rug rats busting on eachother fighting and tugging on my sender!!!!!!! I had to guess how to bend the rod and trust me i was dead wrong.
That pic helps a whole lot!!!
right click,,file save as!!!
Post by: jcassity on December 07, 2008, 02:14:25 AM
you need to use a hole saw and cut out large 1'' holes in the lowest point on each one of those fuel tank mounts or they will become buckets of water over time. That probably what rusted them out in the first place.
Makes me want to check mine out.
Post by: daminc on December 07, 2008, 09:14:21 AM
Quote from: jcassity;246586
Yea, I still have a couple things to do. Drain holes, couple more weld s, bolting system that won't rust. For the most part, they're done and I can get rid of the rust under the old brackets, and coat the entire back end, and then seam seal it. I bought a gallon of Zero-Rust. Should be here next week. Until then, I'll redo the trunk lid, and work my way around the car removing paint.
Post by: ZondaC12 on December 07, 2008, 09:22:02 AM
You soooooo need a rotisserie LOL so you'd have a much easier time getting all the off the bottom that you really wanted to.
Post by: daminc on December 07, 2008, 09:36:47 AM
Next car
Post by: HAVI on December 07, 2008, 10:46:57 AM
You aren't leaving me much of an excuse not to work on my car's underside, lol. I've put it off til the Rotisserie is done...which is put off til the price of steel comes down. Keep up the good work!
Post by: daminc on December 08, 2008, 06:21:16 PM
Quote from: HAVI;246605
It all happens when the time is right. I've been planning this since about 2003. ;)
Post by: daminc on December 08, 2008, 06:35:01 PM
Today I decided to rebuild the trunk lid. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4850.jpg)
Drilled out the old rivets and yanked it off. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4851.jpg)
Did a little measuring, and did some cutting (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4852.jpg)
Then a little fitting (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4853.jpg)
Then a little more fitting (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4854.jpg)
And this is what we end up with Curve and all (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4855.jpg)
Next is to rebuild the inside again. I hope for the last time (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4857.jpg)
Before I redo the inside, I'll cut the outer panel and put a backing strip on so the replacement skin is in the correct place to match up. When I replace the inside, the panel should both line up with the outer one. We'll see how that goes. LOL
Post by: Beau on December 08, 2008, 07:23:47 PM
Jerry, after reading this thread time and again, and seeing the pics of the progress thus far, I'm absolutely convinced you could build a car from scratch with your bare hands!
It's amazing!:bowdown:
Post by: thunderjet302 on December 08, 2008, 07:31:24 PM
Just a thought but on the passenger side you may want to make the tank bracket smaller if you're going to run 2.5" dual exhaust under the car. The top of the passenger side tail pipe will hit it if you use any of the pre bent Mustang tail pipes. Trust me I know ;)
Post by: DerikWayne on December 09, 2008, 12:42:22 AM
You realize that when you're finished with this car, you would have touched every single inch of it!
Post by: daminc on December 09, 2008, 05:51:19 PM
Quote from: thunderjet302;246792
Not sure about the smaller part, as I don't know where it would actually hit without having the pipes installed. I'll deal with that problem as it comes. I also know where to get a 2 1/2" pipe bender just in case.
DerikWayne
You realize that when you're finished with this car, you would have touched every single inch of it!;)
I'm sure there must be some part that I won't touch.
I cut some parts off the trunk today (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4860.jpg)
Oh well, I guess I've seen worse. This pretty much said it all.
But on the lighter side of today. I ended up making a pattern of my SFCs to send to someone, so they can copy them for their car. It's got to be the strangest thing I've ever made in all my 25 years in building. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4859.jpg)
Looks like SFCs for a stagecoach. LOL
Post by: TheMeaningOfLife on December 09, 2008, 10:55:09 PM
Amish SFCs!!
Great work by the way! I know ill never have half that skill!
Post by: HAVI on December 09, 2008, 11:38:07 PM
:hick: Could use those SFC's here:
Post by: 347Thunder on December 09, 2008, 11:45:50 PM
All I have to say is, you are out of your brilliant mind! lol
Post by: Haystack on December 10, 2008, 05:06:02 AM
I have a friend with 2 87 cougars. One is a two tone blue v-6 with a good trunk lid. He is going to have to get rid of them by the end of the year. I'll bet I could get you a pretty good deal on them. I'll be going to his house this weekend, and I could get a couple of pics for you then.
Post by: daminc on December 10, 2008, 07:29:01 AM
Quote from: Haystack;247025
I don't see shipping as being user friendly. Especially from out that way. I'm kinda in a bad area to get too, seeing that I'm right between Lake Erie and Lake Ontario with Canada on another side only 7 min. away.
You could see about a price to 14072, But I may have it finished by the weekend.
Post by: daboss351 on December 10, 2008, 11:02:18 AM
Sweet!! I owe u big time!
Post by: daminc on December 10, 2008, 06:53:28 PM
OK, I decided to rebuild the trunk by memory. But seeing that I don't trust my memory, this is what I came up with. The last repair had a straight bend in it, and I noticed it was holding moisture. This time I decided to bend it on a curve, so moisture can travel to the weep holes.
this was a before. Here you can see the straight bend that wasn't letting the water to the weep holes. (http://i233.photobucket.com/albums/ee79/daminc/IMG_3279.jpg)
A great afternoon fix, but a bad design on my part.
Here's the start of the curved piece that will let water get out when the lid is closed. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4870.jpg)
It's tough to tell in this pic, but there's a compound curve in it. Unfortunately, the only thing I don't own is a shrinker/stretcher. So I had to pound it out by hand, which really sucks. A little more fine tuning, and it'll be good. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_4871.jpg)
Also got some of my stuff for surfacing the panels. This will ensure that the car doesn't have any waves in it when I'm done. ;) Now you know why I stripped it. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4872.jpg)
That's all for today my friends.........
Post by: andrew beedle on December 10, 2008, 07:13:58 PM
I see lots of block sanding in your future. Could you not use a high build urethane primer instead. Maybe save a little block sanding time?
Post by: daminc on December 10, 2008, 07:44:33 PM
The car needs to be blocked no matter how I look at it. This will do a better job before the epoxy primer goes on. Especially on the panels that got welded.
Post by: DerikWayne on December 10, 2008, 08:33:01 PM
Most of us would have purchased another trunk lid... but nooooooo, not you!
Just kidding. I bow down to your greatness, lol.
Post by: thundr306 on December 10, 2008, 08:38:09 PM
I give you alot of credit for going out there on a consistent basis and working on your car. I know I can't do that.
Post by: DVP on December 10, 2008, 08:43:05 PM
Quote from: DerikWayne;247143
Most of us would have gotten a new car! LOL.
Jerry I have a question for you. since you brought up the subject of the underside of my SHO. What would you recommend "winterizing" it with? I'm on a budget so I need the cheap route.
As much as I would like to seal/undercoat it I dont think I can afford it right now.
Post by: daminc on December 10, 2008, 08:56:03 PM
Quote from: thundr306;247146
Thanks, Being a contractor usually gives me a bunch of free time from Thanksgiving till the end of January (tax return time). When work start up again, it'll be hit and miss like during the summer.
Post by: daminc on December 10, 2008, 09:40:23 PM
Quote from: DVP;247147
If I had got another car, I still would have taken it apart and stripped it to the point this one is. This car cost me very little money to keep and rebuild compared to finding one and getting it back to Buffalo. If I didn't upgrade and add anything extra, It only cost me about $500 to fix it with all the panels and materials I got into it.
As far as undercoating, The spray can stuff would be the cheapest and easiest. I don't know what the underneath looks like right now but if there's rust already, it's gonna keep rusting until you get rid of it. I may just say that if you have a lot of rust, then don't undercoat it until you can treat it or blast it. undercoating it will make a big mess that you'll have to clean off before you can treat or paint with encapsulator. A gallon of Zero Rust is only $52. You can do the entire underside of your car 2X and it would be rustproofed almost forever. then you could undercoat it if you wanted.
Hows that?
Post by: vinnietbird on December 10, 2008, 11:33:04 PM
Undercoating?We don't need no steenking undercoating here !!! LOL.
Post by: daboss351 on December 11, 2008, 09:48:46 AM
I wish I had the time to do this to my car and tools and space
Post by: Kitz Kat on December 11, 2008, 07:26:08 PM
Quote from: 347Thunder;247007
My headache's gettin bigger.
Post by: HAVI on December 11, 2008, 07:27:33 PM
Quote from: daboss351;247215
And money.
But, having time to do all of this is what makes it worthwhile. IMO, the best bodymen are the ones who have done it over and over and over and over again.
Post by: 347Thunder on December 11, 2008, 08:17:31 PM
But when you are a bodyman you never want to come home to work on your own. I only finished my car because I stopped doing it for a living.LOL
Post by: daminc on December 11, 2008, 11:41:45 PM
Project is temporarily on hold, due to my dad passing away unexpectedly.
Post by: DVP on December 11, 2008, 11:48:08 PM
Im glad you didnt buy another car. Its fun to see the insides of our cars. Plus Im learning ALOT. Will the Zero Rust stop the rust? Its not bad but if I keep it I would like it to not get worse.
Post by: daminc on December 11, 2008, 11:56:50 PM
Quote from: DVP;247297
If you se the scaled rust off and coat it good, it will stop it from rusting any more.
Post by: vinnietbird on December 12, 2008, 12:10:40 AM
Quote from: daminc;247296
What ??????
Post by: mjbtbrd on December 12, 2008, 01:20:43 AM
My condolences
Post by: mercury-man on December 12, 2008, 04:52:21 AM
Jerry, Our Thoughts and Prayers are with you in this time of sorrow my Condolences to you & your Family. God Bless !!! :(
Post by: Kitz Kat on December 12, 2008, 05:13:49 AM
Sorry for your loss.
Post by: vinnietbird on December 12, 2008, 08:20:12 AM
My family will keep you and yours in our prayers.
Post by: daboss351 on December 12, 2008, 10:34:18 AM
I wish the best for you man. I am truely sorry to hear about your loss.
Post by: V8Demon on December 12, 2008, 11:10:23 AM
My condolences to you and your family, Jerry...
Post by: 347Thunder on December 12, 2008, 11:35:16 AM
X2
Post by: DerikWayne on December 12, 2008, 12:48:29 PM
I am extremely sorry to hear about the loss of your father. I'll keep you in my thoughts and prayers!
Post by: Cougar8775 on December 12, 2008, 02:06:57 PM
Im sorry for your loss jerry,i can only imagine how you feel right now.
Post by: thunderjet302 on December 12, 2008, 02:25:51 PM
Sorry for your loss. Family is more important than cars ever will be. Come back to the car when you're ready. It will still be there.
Post by: massCougarxr7 on December 12, 2008, 03:24:12 PM
sorry to hear about your loss.... my prayers are with you
Post by: ZondaC12 on December 12, 2008, 03:48:32 PM
In my thoughts and prayers man...
Post by: Chooglin on December 12, 2008, 04:05:10 PM
sorry to hear this.
Post by: HAVI on December 12, 2008, 05:12:49 PM
Jerry, My heartfelt condolences. The car can wait. Take care, and Merry Christmas if I don't see ya on here til after.
Post by: Haystack on December 12, 2008, 09:12:42 PM
Sorry.. Keep your chin up...
Post by: thundr306 on December 12, 2008, 09:46:12 PM
Very sorry to hear of this.
Post by: daminc on December 13, 2008, 07:31:45 AM
Thank you everyone for your kind words. Been a little busy Taking care of things, plus my 90 year old grandmother is in a nursing home for rehab after a hip replacement, and my 90 year old grandfather is overwelmed by both situations. I'll still be popping in briefly from time to time, to make sure you guys aren't getting into trouble. LOL
Thanks again Jerry
Post by: Kitz Kat on December 13, 2008, 01:02:42 PM
I hope you do, I need this post for stress relief! Hang in there bubba, and again sorry for your loss.
Post by: vinnietbird on December 13, 2008, 05:09:07 PM
Quote from: Kitz Kat;247421
Me too.It's like my daily hit of the news that I need.
Post by: HAVI on December 13, 2008, 06:07:00 PM
+3
Post by: daminc on December 13, 2008, 06:40:44 PM
Thanks, I may unwind from the week and putter with it tomorrow. I'll see how things go.
Post by: dominator on December 13, 2008, 08:14:25 PM
Sorry to hear jerry. My condolenses.
Post by: daminc on December 13, 2008, 11:07:23 PM
Thanks Chris
Post by: DVP on December 14, 2008, 03:29:53 AM
Sorry to hear that Jerry. I feel like an ass now, I was the first one to post after the sad news and I had no idea until now. My condolences
Post by: daminc on December 14, 2008, 07:37:04 AM
Quote from: DVP;247507
Don't worry about it, I know that posts sneak in while typing sometimes.
Post by: Beau on December 15, 2008, 02:20:55 PM
Condolences to your family from mine in a time of sorrow. Our thoughts are with your family
Post by: cougarXLS on December 24, 2008, 05:19:07 PM
Jerry, I am so sorry to hear that. My condolences and best wishes to you and your family. :(
Quote from: daminc;246557
Well, I did. I just didn't weld. I bolted. I kinda made more holes. Now that I have a camera, I should load up those pics... it was kinda cool from a newbie's point of view. But your's are cooler. :D
Merry Christmas and all the best,
Kevin
Post by: massCougarxr7 on December 24, 2008, 09:07:43 PM
Merry christmas Daminc, keep that chin up and think of the cougar...
Post by: daminc on December 28, 2008, 05:25:05 PM
I hope everyone had a great Christmas. I did a little painting today. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4890.jpg)
That's all for today. Thank you everyone for your kind words and support. On with the project.
Post by: massCougarxr7 on December 28, 2008, 08:32:40 PM
Great to see that your back Jerry!!!!!!!!!!Now on with the show!!!!!!!!;)
Post by: vinnietbird on December 29, 2008, 10:45:55 AM
WOO-HOO !!!!!!!!!! What are you planning today with the Cougar?It's supposed be nearly 70 here.If so,I'm painting the trim on the Bird.
Post by: daminc on December 29, 2008, 05:46:24 PM
Sorry, no fun with the Cougar today, Had to work. Next I'll just be putting another coat of paint on, and mabe the tank supports. Then I'll be working my way down to the front.
Post by: daminc on December 29, 2008, 09:39:30 PM
In all the excitement and confusion, I forgot that it was the one year mark for my project. A lot has changed since I began one year ago ,and it looks like the hard part is finally done. Thanks for sticking around, and we'll be seeing some crazy stuff from this point forward.
Post by: Kitz Kat on December 30, 2008, 06:31:09 AM
How much more crazy can it get, It's past crazy!!
Post by: Cougar8775 on December 30, 2008, 12:46:16 PM
how bout wild! But its some awsome work. And i know you have givin me confidence in doing my own rust repair. I know im going to be consulting you here soon enough.
Post by: baxo on December 30, 2008, 01:27:02 PM
Wow good to see you back in the game man! Expect a visit from me pretty soon after I return from Hungary.
Post by: daminc on December 30, 2008, 06:32:26 PM
Quote from: Cougar8775;249444
Still need to replace your rockers? Have you found any?
Post by: daminc on December 30, 2008, 06:35:03 PM
Quote from: baxo;249446
Cool, It'll get done quicker if you help. :D
Post by: daminc on December 30, 2008, 06:37:14 PM
Quote from: Kitz Kat;249419
LOL Where exactly did I pass crazy? I must have missed it.
Post by: Kitz Kat on December 30, 2008, 07:17:27 PM
Quote from: daminc;249481
The day you said I'm goin to do this. I am trying to get you there. I am impressed. Really don't mean much though.
Post by: 347Thunder on December 30, 2008, 08:02:41 PM
come to think of it I started mine on Dec. 6, 2007 the day after I raced my car and ran a 12 flat. I think I did pretty well considering the car was in the same primer for 7 years lol
Post by: Cougar8775 on December 31, 2008, 11:26:47 AM
well on my drivers side it goes alot farther than just the rockers. The inner structure needs reparing as well. same with the passenger side. And im still on the hunt with no luck. And tax time just around the corner when i will have the cash to get everything to make my cougar beautiful again. And remember how you thought i had a possible bent crankshaft to be breaking ballencers... Well that checked out to be within tollarence issued by ford.
Post by: jpc647 on December 31, 2008, 01:03:46 PM
Your not the only one!! :)
Post by: daminc on January 04, 2009, 04:17:24 PM
Quote from: Cougar8775;249585
I think it's time to make it a Supercharged V8 :D
Post by: daminc on January 04, 2009, 04:51:57 PM
Yea, I know. I haven't been updating. I decided to take the week off from everything.
Today I seam sealed the back end. Sometime next week I'll put the 2nd coat on the back, so I can move on towards the front. (http://i233.photobucket.com/albums/ee79/daminc/media%20blasting%20and%20paint%20removal/IMG_4902.jpg)
Post by: vinnietbird on January 04, 2009, 11:24:59 PM
You really know how to seal up a back end.LOL.
Post by: Kitz Kat on January 05, 2009, 04:48:51 PM
Even with all the steel you added, I think it would float in a lake.
Post by: daminc on January 05, 2009, 05:39:39 PM
Were a bunch of comedians now, are we?
LOL
Post by: vinnietbird on January 05, 2009, 06:04:14 PM
Well,what do you expect for free.LOL.When you're finished,it will be the same if you'd just swapped the VIN tag onto another car body.None of your original car will be left.LOL.
Post by: HAVI on January 05, 2009, 06:19:02 PM
Quote from: daminc;250329
LOL
It sure seams that way. :hick:
Post by: daminc on January 11, 2009, 03:23:21 PM
I removed the rear end today. Things look real good under there.(considering the condition of the rest of the car) I'll start blasting this week. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4932.jpg)
(http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4939.jpg) Here's a good view of the trunk that I just did (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4940.jpg)
And here's what I end up with. A rusted rear....... (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4942.jpg)
And a broken spring.. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4943.jpg)
And here's my token stupid trick of the day. LOL (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4944.jpg) It's just sitting there.
And ready for blasting. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4946.jpg)
Post by: Thunder Chicken on January 11, 2009, 04:49:32 PM
Bottom pic looks like a Delorean :hick:
Did you have any trouble with the rear control arm bolts? I had one that wouldn't come out and had to cut the control arm - not a biggie since I was installing CHE arms anyway. Also, are you upgrading the control arms? I couldn't believe how flexible the stock ones were when I took 'em out, especially the uppers...
Post by: baxo on January 11, 2009, 04:54:57 PM
Quote from: Thunder Chicken;251227
LOL my thoughts exactly!
Post by: daminc on January 11, 2009, 05:00:56 PM
LOL, yes I do have a bolt that won't come out. in the 3rd pic, the lower arm is still on the car. I'll probably have to cut the bolt on both sides of the arm. I think it's rusted to the inner sleeve. I didn't plan on upgrading right now, but I may be now that I have a bolt stuck in the arm. :hick:
Post by: daminc on January 11, 2009, 05:06:08 PM
You know, every time I go in there, I think the same thing. I wish I could just buff it up and clear coat it. LOL
Does anybody have an extra flux capacitor?
Post by: Thunder Chicken on January 11, 2009, 05:14:17 PM
Take one of the control arms and clamp one end in a vice, then stick a screwdriver through the other end and twist the control arm. When you see how easy they are to twist you'll really want to upgrade, if not at least box 'em. I couldn't believe the lack of torsional strength in the stock arms. I think with the uppers you probably wouldn't need a vice to twist it, you could probably twist it by wringing it like an old rag...
Post by: HAVI on January 11, 2009, 05:23:05 PM
I seen a flux-capacitor on epay last week, got out bid by some crazy scientist guy.
Post by: Thunder Chicken on January 11, 2009, 07:48:30 PM
You'd never have won anyway. If you outbid him he'd just go back in time and outbid you anyway :hick:
Post by: daminc on January 11, 2009, 07:52:49 PM
I think i'm going too blast and toss the old ones back in with the old rear, until I find a TC rear end. then I'll change everything. it can be done anytime after the car is done.
Post by: dominator on January 11, 2009, 08:34:27 PM
Do the upgrade jerry,got my che non adjustable ones for about 215.00cdn shipped (uppers and lowers) when i bought them a few years ago. Super nice quality and they come with all new hardware. Plus the ride and stability is much improved with them.
Post by: daminc on January 11, 2009, 08:56:32 PM
I was just looking at that set. I'll probably get them. I also got my upper and lower t-box kit on the way. should be here by the time i'm done blasting. I think I'm going to cut the other spring to match the broken one. the car always sat to high anyway.
Post by: thunderjet302 on January 11, 2009, 11:05:21 PM
Quote from: Thunder Chicken;251239
This probably explains why the ass end of my T-bird hops all around when I stomp on it from a stop :hick:
Post by: Kitz Kat on January 12, 2009, 06:22:07 AM
Quote from: daminc;251236
I know a guy that collects delorens, he got 3 of them one is gold plated.
Post by: Kitz Kat on January 12, 2009, 02:46:45 PM
Buy the lowers, I'll give you a deal on the uppers.
Post by: daminc on January 12, 2009, 04:42:18 PM
Quote from: Kitz Kat;251386
I feel my wallet getting lighter, LOL PM me when you get a chance.
Post by: daminc on January 12, 2009, 04:49:32 PM
Today's update consists of me sing the loose rust off the rest of the back end, and making another plastic blast booth. I thought about taking a pic of it again, but after seeing it before, I'm sure you get the idea this time around. It's ready to blast. Mabe tomorrow afternoon.
Post by: Kitz Kat on January 12, 2009, 05:08:24 PM
Not lighter. Flames not good lol,
Post by: daminc on January 14, 2009, 05:30:15 PM
got this today. I also see that I have to do a little modifying to make them work. they're close though. I have to do a little lengthening on the 2 on the top left, and a little modifying on the 2 on the bottom right. :D (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4947.jpg)
I also started blasting the rest of the underside. No pics on that. to dusty for the camera. Last time I took pics after that. the lens wouldn't close. I'll wait till I get done with that, and get a coat of paint under there.
Post by: vinnietbird on January 14, 2009, 06:07:26 PM
Try putting the camera in a zip loc bag to take the pics,or wrap a piece of saran wrap around it.Worked for me.
Post by: andrew beedle on January 14, 2009, 09:00:31 PM
How are you going to clean up the inside of the rear subframe rails?
Post by: daminc on January 14, 2009, 09:35:54 PM
believe it or not, I see paint in there. I'm as going to spray the insides. Remember I cut the floor open inside behind the back seat....
Post by: daminc on January 14, 2009, 09:44:44 PM
the rest i'll clean out, and treat it using a flexible undercoating gun and wand with zero-rust. Here you can see that there's just surface rust, and no major scaling or rotting. (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20rebuild/rear%20floor/IMG_3344.jpg)
Post by: dominator on January 14, 2009, 09:58:51 PM
Weird how the battle boxes for the stang don't line up at the control arm holes eh??? I had enough material on mine that i just redrilled the holes lower down and bolted them in. Didn't get a set of uppers though.
Post by: daminc on January 14, 2009, 11:58:58 PM
Quote from: dominator;251694
Yea, what's up with that . LOL the uppers need about an inch added to them, and then a hole drilled for the arm.
Post by: Kitz Kat on January 15, 2009, 03:25:24 PM
Like I said before, CRAZY!!
Post by: 347Thunder on January 15, 2009, 03:51:05 PM
I Concur
Post by: V8Demon on January 15, 2009, 03:52:56 PM
Quote from: vinnietbird;251654
Jerry, what kind of camera? Basic P & S or SLR?
Post by: daminc on January 15, 2009, 04:29:39 PM
It's an old canon Powershot S200 .......2 whole mega pixels. It's my work camera. I'd take a pic of it, but well... I'd need another camera. LOL
Post by: daminc on January 15, 2009, 04:30:23 PM
And I swear, I'm not crazy
Post by: Kitz Kat on January 15, 2009, 04:44:19 PM
Quote from: daminc;251842
You do know crazy people don't admit they got a problem.
Post by: daminc on January 15, 2009, 04:53:05 PM
Here's a couple pics of a quick go over with the blaster. It seems I have to do this, or else I get surrounded by a dense rust fog, and have to stop because I can't see. You can also see the back end of my SFCs. The insides still need to be welded to the subframe. (other side is welded already) (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4952.jpg)
(http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4950.jpg) This one I started to blast for real. It's starting to clean up nice. I only spent about 10 min. on this part (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4949.jpg)
I'm sure you already figured this, so I'll just confirm that I ordered the upper and lower arms last night. I got the Cougar/tbird set from CHE. They look pretty nice. ;)
That's all for today I'll be blasting tomorrow. Stay tuned
Post by: andrew beedle on January 15, 2009, 05:26:23 PM
Im suprised you have not build your own Rotisserie to put your car on.
Post by: daminc on January 15, 2009, 05:32:18 PM
I'll have one for the next car.
Post by: Kitz Kat on January 15, 2009, 05:38:36 PM
I got to ask how many hours do you have in to this? Bubba you crazy.
Post by: daminc on January 15, 2009, 05:50:54 PM
I stopped counting during the summer. I figured every time I posted progress, I was only working on it for 1-1/2 hrs. on an average. sometimes it's only a 1/2 hour. I really don't spend a lot of time on it. Removing the rear was the longest I worked on it since summer. about 2-1/2 hrs.
Post by: cougarXLS on January 15, 2009, 06:46:11 PM
:jerry: :jerry:
Quote from: Kitz Kat;251813
You not crazy, you insane!!! And we love you for it.
Post by: 347Thunder on January 15, 2009, 07:02:53 PM
Quote from: Kitz Kat;251867
I think that question is way out of line LOL:punchballs:
Post by: daminc on January 16, 2009, 04:49:49 PM
I decided to start blasting, but didn't get very far. I couldn't keep much heat in the place and vent the dust from the blasting. I did this much and said I'm way to cold to do this today. only made it to 9 deg. today. It's still progress. I hear it's supposed to be a little warmer next week anyway (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4955.jpg)
Post by: thunderjet302 on January 17, 2009, 10:50:59 AM
It's looking good :D It was warm by you yesterday. We only made it to -1* in Chicago Friday:mad:
Post by: rancheronut on January 17, 2009, 12:57:45 PM
Quote from: daminc;251870
yep i feeling your pain! i know how what your going through. my 86 mustang drag car was in my shop on the 4 post hoist for 4 years after i pulled it into the shop just to service it. for the up coming race season of 2002. casper been on the the same hoist now going on now for 7 months and all i have done is pulled the255v-8 and tranny. but couple months ago,i put the new long block 1987 302 roller and tranny. i have the dual 2 1/2 inch exhaust sitting on the floor for a month now. the 8.8 in next bay waiting for me to finish welding the new lower brackets on for about 4 months.
it suck when you have a bad lower back and you can only play on the good days! (http://www.supermotors.net/getfile/650008/fullsize/dcp02274.jpg)
Post by: daminc on January 23, 2009, 05:53:51 PM
I'll start off today with some new parts. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4956.jpg)
and gently glide into this. I got a 1st coat on. I've been busy as you can see. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4957.jpg)
Next is another coat of paint, encapsulating inside the frame, torque box and upper spring mounts. Then installing the battle boxes, before the rear gets installed.
Now it's starting to look like something. :D
Post by: HAVI on January 23, 2009, 06:00:45 PM
:shakehead I see they shipped the CHE's to the wrong address again.
JK, I can't wait to get mine....hopefully this summer.
Post by: vinnietbird on January 23, 2009, 08:31:48 PM
Nice work my friend.I can't wait to order my control arms........when I get more cash for the Sport........
Post by: Kitz Kat on January 23, 2009, 10:02:27 PM
The bushings on the rear are good to.
Post by: rancheronut on January 23, 2009, 10:16:37 PM
hey daminc. this might sound dum but what are you using as paint the under side? this blonde would like to know.
Post by: daminc on January 23, 2009, 10:25:54 PM
Quote from: rancheronut;253240
Zero-Rust Rust encapsolator It's about $50 gallon
Post by: rancheronut on January 23, 2009, 10:50:52 PM
ok where can i get some from?
Post by: daminc on January 23, 2009, 11:10:23 PM
Here you go. It's the cheapest place I can find it most of the time. The PickelX that I use is there also. http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC (http://"http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC")
Post by: jcassity on January 23, 2009, 11:35:27 PM
that looks like muddy water your putting on there. Any other color opitons? Picky picky me,, paint over it i suppose.
On a side note and this day will come for you sooner than later ................. when you finally get around to wiring, make sure you remove paint for your grounds. Use No-ox-ide compound on the ground connections. Prevents water intrusion plus it conducts.
Ill mail you some , pm me
Post by: daminc on January 23, 2009, 11:46:26 PM
Quote from: jcassity;253262
And I thought black was stylish. Don't worry, the silver rear will break that up Thanks , but I have the compound already. (bet you didn't expect that)
Post by: FLSTCI71 on January 24, 2009, 11:16:10 AM
At this rate, you won't even have to paint the body. When you park the car somewhere, everyone will be looking underneath it anyway! :D
Post by: daminc on January 24, 2009, 11:38:34 AM
Quote from: FLSTCI71;253333
That's so funny, I was thinking the same thing as I was painting it, and it was looking so good under there.
Post by: 5.0 tbird on January 24, 2009, 01:58:16 PM
Nice job, this car is gonna be amazing when it's done I can tell.
Post by: Kitz Kat on January 24, 2009, 02:12:07 PM
"Priceless", yes amazing.
Post by: daminc on January 27, 2009, 05:47:57 PM
today I got some upgrade parts. got this and my rear spring isolators so far this week. just waiting on the springs, and I'll have everything to put it back together.
I found my little Ranger to be most useful so far. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4962.jpg)
A little blasting and some paint, It'll be like new again.
OK, I really didn't have any exciting pictures today, unless you think spring isolators are exciting. :hick:
not a lot happening on the car since friday, but I just ran the gas line today to connect the furnace in the garage this week. I'll be wearing shorts to work on the car now. LOL ;)
Post by: vinnietbird on January 27, 2009, 06:19:09 PM
Hey Jerry,you have a really nice rear end there.
Post by: Kitz Kat on January 27, 2009, 06:24:36 PM
You can have the straps to.
Post by: daminc on January 27, 2009, 06:34:00 PM
I was going to sent them back to you too
Post by: HAVI on January 27, 2009, 08:19:51 PM
Quote from: daminc;253924
I find disc brake rears exciting, does that count? Keep it up! :jerry:
Post by: 347Thunder on January 27, 2009, 08:39:51 PM
better then a leaky rear :shakeass: :toilet:
Post by: vinnietbird on January 28, 2009, 08:52:16 AM
What's all of that brown stuff all over your rear?You're going to have to wipe all of that off.
Post by: Kitz Kat on January 28, 2009, 02:52:36 PM
I was wondering the same thing!! It wasn't there when it left. I even pessure washed it. Plus it was draining for days. Did you spill coffe on it?
Post by: daminc on January 28, 2009, 03:46:58 PM
You guys are a riot.
Post by: vinnietbird on January 28, 2009, 05:38:33 PM
A riot?No way,we're serious..................maybe not.LOL.
Have you cleaned your rear yet?
Post by: Haystack on January 29, 2009, 09:34:36 PM
Quote from: vinnietbird;254157
I've cleaned my rear several times a day.
When I was taking auto in school, I spent about a week and a couple of hours just cleaning a rear with a wire brush. It was a long week.
Post by: daminc on February 01, 2009, 03:06:43 PM
Small update today. Did a little more painting. mainly inside the upper spring, and torque boxes. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4966.jpg)
I'll probably put another coat on everything under the back end tomorrow, and start working on the new rear. So yes, things have slowed down on the car progress, but I have an excuse. I ran gas line, and installed a furnace last week. I hate being cold when I work. Not bad for free. ;) (Need to do more cleaning too) (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4969.jpg)
Post by: Kitz Kat on February 03, 2009, 03:59:38 PM
Wheres the heat come in ? I see circles are they all open?. Did you here gas went up!. Not that there not much more of an option.
Post by: DVP on February 03, 2009, 05:10:39 PM
Are we there yet.....?
I can honestly say that after this project I will never see any reason to s my car.:bowdown: It would literally have the front bumper touching the rear. Even then I think it would be a cool lawn ornament.... Yeah so what if my family was from Arkansas.....:mullet:
Post by: daminc on February 03, 2009, 06:01:36 PM
Quote from: Kitz Kat;255094
the circles are open. I didn't put any diffusers on them. I'll eventually put some runs to the other side before it gets insulated better and drywalled.
did some seam sealing before the finish coat goes on. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4972.jpg)
Yes, I'm working my way to the front (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4973.jpg)
painted the rear today also... Like my little cart? and............. this thing is heavy!!!!! (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4970.jpg)
Post by: DVP on February 03, 2009, 06:36:58 PM
That silver would look real nice under a black car.....
Post by: Kitz Kat on February 03, 2009, 07:06:53 PM
You know you have to put new lines on it? That looks good silver. You changing axels there still rusty? I'm messin with you.
Post by: daminc on February 03, 2009, 07:19:00 PM
Quote from: Kitz Kat;255129
Yea, I was keeping the lines on until I get the new ones, so I can follow the bends. Not changing axles, I'm just getting to them.
Post by: Kitz Kat on February 03, 2009, 07:30:14 PM
Ok, lookin good.
Title: I got a question?
Post by: daminc on February 03, 2009, 10:48:32 PM
I got a stupid question? will my 14" rims fit on this TC rear? or will the calipershiznit? It's just temporary to roll it around.
Post by: DVP on February 03, 2009, 11:03:02 PM
They should. Knew a guy running 14" slicks on a TC rear
Post by: Quietleaf on February 03, 2009, 11:40:44 PM
Iffy. When I bought Jim's TC wheel up at Reading I gave him my factory-original 14" full spare since he needed it to be able to send the car to the JY. The wheel wouldn't go on without pulling the caliper. It was a front wheel, but I figure it shouldn't matter.
(Since I was going to 11" brakes I needed a spare that would fit over them, and his TC wheel fit the bill).
Post by: Kitz Kat on February 04, 2009, 04:19:26 AM
Thats not a stupid ?, I know the front with 11" brakes won't, don't know about the rear.
Post by: vinnietbird on February 04, 2009, 06:55:17 AM
That's some nice work.Making more progress is always good.I know it's been covered,but your car is gonna be 4000 pounds.LOL..I made brake lines for mine some time ago with "sticks" of tubing from Autozone.Turned out really nice,and the tubing was uber cheap.
Post by: daminc on February 04, 2009, 05:18:47 PM
Quote from: vinnietbird;255186
I don't see how it could weigh that much, but you never know. I was thinking the same with the lines. My father in law has the flaring tools and bender for them
Post by: thunderjet302 on February 04, 2009, 07:24:57 PM
Quote from: daminc;255163
I think that it will hit it.
Post by: daminc on February 04, 2009, 07:41:43 PM
I'll just leave the calipers off for now. It's not like I'm driving it around.
Post by: thunderjet302 on February 04, 2009, 07:48:58 PM
Just don't step on the brakes :hick:
Post by: HAVI on February 04, 2009, 08:13:21 PM
:hick: No more putting the feet through the floor to stop either
Post by: Haystack on February 04, 2009, 10:00:44 PM
I think the front are a true 11", and require a 15 inch rim. The stock 15" rims came on mustangs, including gt's. The gt's are where we get 11" brakes, so yeah.
I don't think the rears are any bigger then a 10" brake drum, so I would think it would fit, but I'm not totally sure. I had 10" drums with a 14" rim, but drums don't have calipers.
Post by: daminc on February 05, 2009, 04:08:18 PM
Survey Says YES 14s fit on a 8.8 with a 1/2" to spare. (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4985.jpg)
Did a bunch of pounding on the dust shields to make them look normal again. They were pretty mangled (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4989.jpg) I'll probably get to put a 2nd coat of paint on everything tomorrow. And mabe install the battle boxes if things go good.
Post by: Kitz Kat on February 06, 2009, 04:57:23 PM
Sorry, they were that way. They look good now!
Post by: daminc on February 07, 2009, 08:20:12 AM
Quote from: Kitz Kat;255581
Wasn't worried about them, there's no way to put that thing down, and not mangle them without taking them off anyway. Those shields are built for a tank. never seen anything so thick before. I'm also kinda digging the 2 tone paint. I wasn't sure about it when I did it.
Post by: Kitz Kat on February 07, 2009, 10:12:59 AM
It will look good under the car with all the new parts. I was happy when mine went in.
Post by: daminc on February 07, 2009, 07:52:24 PM
Battle box time BTW.... they suck to put in
this is where the hole should be (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4993.jpg)
so I had to add a little (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4994.jpg)
then painted them (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5002.jpg)
While those were drying, I had to do a little modifying on these (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5003.jpg)
Then had 1 hell of a time installing them (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5004.jpg)
Here's where the new hole is now (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5005.jpg)
This was before the new hole was drilled (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_4999.jpg)
Here's an inside view of the backing plates (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5006.jpg)
I don't recommend installing these unless you can do some modifying and welding
Post by: Clayton on February 07, 2009, 08:39:57 PM
you can bend brakeline with your hands man. those tools are garbage. flaring tools are good, but the bending tools are junk... I'd rather use a bix end wrench and my hands :D
Post by: HAVI on February 07, 2009, 08:47:19 PM
where were those bought from?
Post by: daminc on February 07, 2009, 09:24:05 PM
They're wild rides Battle boxes.. for a mustang I battled all day with those things. I guess it could have been worse.
Post by: HAVI on February 07, 2009, 09:44:57 PM
Could you say we'd be better off making our own instead?
Post by: daminc on February 07, 2009, 10:24:00 PM
The entire kit cost $60 bolts and all. probably be worth while to mod the kit. the lowers have an angle on them that fit perfectly on ours. Just needed to add an inch to the bottoms. a little grinding on the upper plates and some hammer smashing to make them fit better. Seems the upper section of floor has more curve on a mustang. nothing a little more hammering didn't solve for the inside upper plates. also... the bolts just made it on the uppers. had to leave the locking washers off to get the nuts to thread. I may tack weld them to keep them from loosening. I also had to redrill a couple new holes through the upper boxes to get the kit to line up. 1 hole, through about 4 thicknesses of metal
to sum it up......... knowing this info, it would be easy with the kit. Going in blind not knowing any of this probably added 4-5 hrs to my install. the 2nd side went a lot faster then the first. mabe less then half the time
Post by: HAVI on February 07, 2009, 11:05:40 PM
OK, that makes sense. I was under the impression they were more expensive. thanks.
Post by: daminc on February 08, 2009, 02:43:27 PM
Today I finished up the battle boxes. I'm not planning on racing, but for the amount of rust that was on my car, and all the floor replacing, I decided it was best to put these in. You never know........ (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5009.jpg)
The area where the strap fastens to the bracket isn't on yet. I have an idea about that, and I'm going to wait until I put the tank up to make sure they're in the correct place on the bracket.
That's all for today... Installing the rear should be the next project. The springs are on the way. Of course I have to put another coat of paint under there first.
Post by: Kitz Kat on February 08, 2009, 02:48:04 PM
There's a couple of hours of light left, don't quit yet! I can say I touched that car!. I think I'm special!.
Post by: dominator on February 08, 2009, 05:41:23 PM
Frickin sweet jerry,you again are da MAN..
Post by: daboss351 on February 09, 2009, 12:28:41 PM
Sweet man!!! I need to do a set of those battle boxes, I think one of mines bent from my accident....
Post by: EricCoolCats on February 09, 2009, 12:46:00 PM
LOL All that welding and you left the seat belts in. You're either that skilled at welding or very brave. ;)
Post by: DVP on February 09, 2009, 12:59:14 PM
Amazing! Just like every time I look at it.
Post by: ZondaC12 on February 09, 2009, 01:08:10 PM
Yeah what a job this thing's gonna be just bombproof when it's done. If it ever even develops a SPECK of rust IM gonna be pissed nevermind you jerry :rollin:
Post by: daminc on February 09, 2009, 01:09:10 PM
LOL Eric, I couldn't get those bolts to budge, so I said forget it. I can't believe I didn't start anything on fire either. The package tray carpet and the headliner are still in too. Not to mention the drivers seat was still in while I did the entire passenger side.
Post by: daminc on February 09, 2009, 01:24:37 PM
And to answer the question. "Lucky" is the word were looking for. :D
Post by: EricCoolCats on February 09, 2009, 01:33:36 PM
What's funny is that all you need to do is heat up the bolts from underneath the car with a torch, while someone else is inside the car cranking away with the Torx bit. Bolts will come right out then.
Unless the seat belts catch on fire first...
Post by: DVP on February 09, 2009, 01:34:08 PM
YES!
I cant find the "track" comment in here but Im sure most of you remember someone suggested tank tracks.
I have the solution to everything! Oddly enough it comes from a post of Jerry's
Post by: daminc on February 09, 2009, 03:51:16 PM
I heated the outer bolts up to get them out, but I got some warpage and melting on the belt plastic covers, so I didn't chance melting the inners. I wasn't replacing anything around there anyway.
Post by: daminc on February 09, 2009, 05:19:49 PM
Today's update finished painting today. Just need to replace the lines and take the rest of the driveshaft off. Also need new lug bolts. I wire wheeled the end of the shaft, and used pickelx to protect it from rusting (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5019.jpg)
So now that I took the time to remove and paint the sway bar, I got to ask............... Will it fit using CHE arms? Or do I need to make something to connect them together? (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5020.jpg)
Post by: Kitz Kat on February 09, 2009, 06:11:09 PM
It will bolt right up.
Post by: thunderjet302 on February 09, 2009, 06:48:39 PM
Quote from: daminc;255945
Is it possible to make the passenger side tank bracket smaller (ie like the driver's side bracket)? The reason I ask is because a 2.5" diameter tail pipe is a tough fit around the stock bracket. Ask me how I know :hick:
Post by: daminc on February 09, 2009, 07:09:10 PM
How much? It's about an inch over from where the old one was. As far as I can tell
Post by: dominator on February 09, 2009, 08:08:58 PM
Rear sway bolts right up with a nut and bolt.
Post by: daminc on February 09, 2009, 08:58:49 PM
Cool, thanks guys
Post by: thunderjet302 on February 09, 2009, 09:27:05 PM
Quote from: daminc;256133
That *may* be ok then. Being that the passenger side bracket is wider I had to put a 3/8" dimple in the top of the exhaust pipe. I'm trying to remember where the tank strap bolts on the bracket. The last time I messed with the tank was almost 2 years ago when I changed the fuel pump and I did the exhaust last year. I may have to crawl under the car and take a look for you. It may also depend on what brand of tail pipes you get. I used 2.5" mandral bent tail pipes from Dynomax because, well, they were the cheapest ones I could get :hick:
Oh and since you're putting a 5.0 HO in the car you did remember to get a new (at least 110 lph) fuel pump for it right?
Post by: daminc on February 09, 2009, 09:32:20 PM
I may be bending my own pipes.
I got a pump and SD computer too
Post by: daminc on February 10, 2009, 06:56:02 PM
And some springs.... (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5021.jpg)
Post by: vinnietbird on February 10, 2009, 08:47:56 PM
HEY !!! Are those the springs I sent?Man,they look great.LOL.And just think,untouched and 22 years old.Those Oklahoma parts look pretty good,huh?Front springs and quads coming to you.
Post by: daminc on February 10, 2009, 08:52:32 PM
You the man, Vinnie
Post by: vinnietbird on February 10, 2009, 08:53:26 PM
You only say that because it's true.LOL.LOL.
Post by: Kitz Kat on February 13, 2009, 04:50:36 PM
Quote from: vinnietbird;256269
OK I just puked!!, Wheres the pics, its been 3 days. I need my fix.
Post by: daminc on February 13, 2009, 05:31:11 PM
Settle down, settle down. Here they are................... Did anyone ever think the underneath of my car would look like this? (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5029.jpg)
Post by: Kitz Kat on February 13, 2009, 05:48:49 PM
Relief! thanks. Lookin good with the che's
Post by: vinnietbird on February 13, 2009, 06:58:09 PM
Those control arms actually look like under there.I expected a lot more from you.I'll go ahead and give you half what you paid for them just to help you out.I'm cool like that.Other than that,awesome.
Post by: baxo on February 13, 2009, 08:17:14 PM
man you did a hell of a job under there!
Post by: dominator on February 13, 2009, 08:29:46 PM
Jerry the question is, did you ever think the underside of your car would look like that??? LOL.
Post by: 1WLD BRD on February 13, 2009, 08:46:24 PM
Quote from: thunderjet302;256160
.... It may also depend on what brand of tail pipes you get. I used 2.5" mandral bent tail pipes from Dynomax because, well, they were the cheapest ones I could get :hick:
that is correct, it has to do with brand too... I am running 2.5" Flowmaster tips with no issues. and believe it or not.... I am using the stock 302SO fuel pump.... BUT i do recommend swapping a bigger pump... I just cant be bothered to drop the tank till I am ready to fix my tank mounts properly....:D :hick:
I am occasionally getting a lean backfire after winding out first a bit then hitting the throttle in second, so I am thinking it is getting close to time for the tank to drop...
Sorry for the Hijack Jerry, car looks great, keep it up.
Post by: daminc on February 13, 2009, 09:36:53 PM
Quote from: dominator;256672
I really didn't expect it to look like that.
Post by: DVP on February 14, 2009, 03:25:44 AM
When I said that rear would look good under a black car I meant my car.... But it looks amazing under there. This is a thread that we are going to see on other forums eventually. After they see what you did it will spread like wildfire.
Post by: daminc on February 14, 2009, 05:28:38 PM
Quote from: DVP;256739
LoL, The places I go to, this is nothing for them... Not so sure about the wildfire thing... but it's nice to be noticed. ;) Thanks for the compliments.
[SIZE="5"]Eric, I sent you an important PM[/SIZE]
LOL Today I got the wheels back on. Does this look freakishly low to anyone? (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/IMG_5034.jpg)
Post by: daminc on February 15, 2009, 08:34:06 AM
Quote from: Kitz Kat;256901
Should of got the che ajustable's could put it where you want. Did you put the isolators in?
yep they're in one of the previous pics (they're Red)
these springs are 1 coil shorter then the old ones I took out
Post by: 50tbrd88 on February 15, 2009, 09:10:07 AM
I can't wait to see this thing done. Its amazing what you have accomplished thus far...
Post by: Kitz Kat on February 15, 2009, 09:27:15 AM
Quote from: daminc;256903
It's easy enough to change the springs if they drop to much when loaded.
Post by: daminc on February 15, 2009, 09:46:17 AM
Quote from: Kitz Kat;256907
My thoughts exactly.
Post by: Kitz Kat on February 15, 2009, 09:50:29 AM
The comparison pic, is that before or after the tank frame install? lol
Post by: daminc on February 15, 2009, 10:48:21 AM
after
Post by: daminc on February 15, 2009, 02:49:22 PM
I did the flip today. Time to start the front. And Springs are not my big worry right now anyway. They can always be changed. The front should go a lot better. There's not a lot of underside like the back end. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5037.jpg)
Post by: vinnietbird on February 15, 2009, 04:39:06 PM
Springs for the front and quads on the way !!!
Post by: Clayton on February 15, 2009, 11:09:38 PM
you choose a color for her yet?
Post by: daminc on February 15, 2009, 11:58:39 PM
Black
Post by: DVP on February 16, 2009, 03:40:26 AM
Quote from: daminc;257045
Black
Great choice. So I guess that rear IS going to look good under a black car even if it isnt mine lol.
Post by: Clayton on February 16, 2009, 10:48:16 PM
any complimentry things like pintripes in mind?
its gonna look dead shagy.
Post by: ZondaC12 on February 16, 2009, 10:56:01 PM
Hey jerry what gears does that rear have in it?
Post by: daminc on February 17, 2009, 07:30:56 AM
I believe it has 3.73 gears in it, KItz could probably verify that. (if he remembers. LOL)
Post by: daminc on February 17, 2009, 07:39:57 AM
Oh, and no stripe. or side moulding in the middle. Matching painted mirrors and most of the chrome will be blacked out, except for around the windows.
here's a close example..... just add silver turbines under it. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/pics012Small.jpg)
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: ZondaC12 on February 17, 2009, 10:02:31 AM
Quote from: daminc;257226
Oh wow sick cause I know you're putting an H.O. in it that things gonna be funnnn :D
Post by: 86XR7project on February 17, 2009, 10:31:40 AM
Makes me wanna start tearing into mine....
Post by: Kitz Kat on February 17, 2009, 03:35:45 PM
That black cat looks familiar. the turbines will fill the wheel well better than that pic, They were little 17". Yeh its 373 gears.
Post by: vinnietbird on February 17, 2009, 05:25:30 PM
Jerry,are you excited to see tha paint applied?Are you doing it or having it done?
Post by: daminc on February 17, 2009, 05:36:49 PM
I'll paint it myself. It'll be the 2nd time for that car. (that's why I have to strip it) For a while there I was painting 1 or 2 a year for my father-in-law. LOL He would buyem, fixem, and sellem.
And honestly, seeing paint under my car got me excited
Post by: Kitz Kat on February 17, 2009, 05:44:34 PM
Your still insane.lol
Post by: daminc on February 17, 2009, 05:53:59 PM
Quote from: Kitz Kat;257324
But in a good way
LOL
Post by: mercury-man on February 17, 2009, 06:26:30 PM
Jerry, Is the black paint gonna look something like our Cougar had painted on it ??
Post by: daminc on February 17, 2009, 06:36:00 PM
yep. I'm also going to cut/ buff it like my last car to get that nice mirror finish
Post by: mercury-man on February 17, 2009, 06:40:40 PM
Jerry, Good Luck and keep up the great work. :headbang:
Post by: Rcarder407 on February 17, 2009, 06:56:01 PM
Jerry, its looking good, keep it up. After you get done your Cougar Ill send you my sport to work on. All it needs is the new quarter panel I have put on. lol
Post by: daminc on February 17, 2009, 07:09:41 PM
I already have a waiting list for projects, but I can add you too. ;)
Post by: Rcarder407 on February 17, 2009, 07:13:56 PM
Im going do it myself as soon as spring comes and I find a better welder. Have you ever tried that metal to metal bonding glue? I thought about trying it out if I cant find a good welder.
Post by: daminc on February 17, 2009, 07:20:07 PM
I hear it works great, but sometimes you get a line where the seam isn't hidden. Only in certain lights I guess. and you can't use it on structural stress points on a panel either.
Post by: Kitz Kat on February 17, 2009, 07:39:00 PM
Quote from: Rcarder407;257352
I've been messin with a cheap 110v lincoln wire feeder, I'm impressed what it can do.
Post by: Rcarder407 on February 17, 2009, 07:57:00 PM
I have an old wire feed welder but even on the lower setting and moving fast it still burns through sheet metal. :mad: Im trying to find someone around me with a TIG welder.
Post by: daminc on February 17, 2009, 07:57:18 PM
Quote from: Kitz Kat;257359
I've got a 110v lincoln. works great with the gas mix
Post by: vinnietbird on February 17, 2009, 08:31:33 PM
On my lower rear passenger side 1/4 panel,it had a crease in from the wheelwell to the lower corner of the car near the bumper.I got a "new" panel,cut off the unnecessary metal,made a "skin" out of it,and used body panel adhesive to attach it to the car over the damaged area..It's solid,and is never coming off.The body lines are just right,and it didn't stick out past the bumper cover.No-one that has seen the car up close can tell I did that work,even after I tell them.GOOD stuff.
Post by: Kitz Kat on February 19, 2009, 02:28:29 PM
I Need A Fix!! Help me out brother.
Post by: ~AC on February 19, 2009, 03:43:11 PM
daminic.. since your going with a black paint job.. if it does, infact, come out like glass over that drivers side quarter panel.. MUCH RESPECT. body work + black paint = TRICKY.
Post by: Kitz Kat on February 19, 2009, 04:06:27 PM
Quote from: ~AC;257691
I have seen the 1/4's on and felt them, and I was impressed with no distortions, I do believe he will make it look fine.
Post by: daminc on February 19, 2009, 06:43:07 PM
Yea, the quarters came out almost perfectly straight here's a shot with the light on it. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3549.jpg)
and when the filling is done this will fill the imperfections when blocked flat. this stuff can add an 1/8" of fill in a couple coats if needed. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/IMG_4872.jpg)
Post by: pegasus on February 19, 2009, 06:50:48 PM
hey hey hey
3 There will be absolutely no nudity tolerated in any image, whether it is hosted on your server or ours. Our web host has a strict no-nudes policy and we honour it. Scantily-clad women in your avatars are included in the ban if they are offensive
get some paint on that quick:D
Post by: Cougar8775 on February 20, 2009, 11:43:28 AM
i also touched the drivers side 1/4. and i also can voutch for its straightness. and i have a 88 TC model at home that is flat black with black interior and ironicly is almost what jerry is doing to his.
Post by: daminc on February 20, 2009, 08:15:55 PM
Here's a better view. the distortion is minimal along the weld, as you can see here. (http://i233.photobucket.com/albums/ee79/daminc/Rockers%20and%20quarters/IMG_3539.jpg)
Post by: vinnietbird on February 20, 2009, 08:44:53 PM
Project "Evolution Rrrrrrevolution".Nice welding my friend.I have no doubt that the Cougar will be almost as cool my Sport.LOL.LOL.
Post by: ~AC on February 21, 2009, 05:20:28 AM
ah i see.. i was worried when i saw the picture where the 1/4 is down to metal completely. you can see the weld line, but instead of distortion like i thought i saw, it looks good enough that you wont use much filler. you defiantly have my respect!!
Post by: daminc on February 21, 2009, 04:55:11 PM
I did some blasting today, after I removed the wiring (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5043.jpg)
I guess I also need to fix this (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5048.jpg)
It's not as bad as I figured. I'll be welding new metal for extra support, and smoothing everything out.
Today's big question......... Where do I disconnect the lower line for the air conditioning that goes through the firewall?
Post by: daminc on February 21, 2009, 05:12:46 PM
Quote from: baxo;257990
It would be the same distance for eu to the peace bridge. It's 30 mind to my house from where he is.
LOL Is the question sealed inside a mayonnaise jar?
Post by: baxo on February 21, 2009, 05:16:57 PM
Haha freaking iPhone and its auto complete.
Post by: Thunder Chicken on February 21, 2009, 05:27:42 PM
The lower A/C line disconnects right at the firewall. That big "ring" shaped thing is the connection. You need a special A/C line disconnect tool. Stick the tool into the ring to spread the spring inside it, then pull the line away. IIRC the spring is on the side facing the firewal, so you have to stick the tool in from that side.
Post by: daminc on February 21, 2009, 05:33:44 PM
Thanks, I'll se if I can borrow one
Post by: HAVI on February 21, 2009, 05:33:37 PM
And if you don't have the tool, buy the plastic assortment of sizes ones from the part store. They seem to work better than the two sided metal ones. Snap the plastic one on, put a bigger open end wrench next to it, and give the wrench a whack with a hammer. Should pop right in.
Post by: FLSTCI71 on February 22, 2009, 11:44:40 AM
Quote from: Cougar8775;257840
Rather than people having to drive to NY to pay homage to Project Evolution, I think Jerry should travel to our houses and share his magic touch. He could make stops across the country and "lay his hand" on our cars. "I am daminc, I command you to cast out the evil that is rust and replace it with the wholesome goodness that is shiny paint!!"
Post by: Kitz Kat on February 22, 2009, 12:00:04 PM
Quote from: daminc;257997
How did you disconnect your fuel lines? The plastic disconnect tool pack is cheap and handy to have.
Post by: daminc on February 22, 2009, 02:35:38 PM
Quote from: Kitz Kat;258092
the fuel lines had a locking tab on them. I just pulled it out to disconnect them. where do i get this connector tool?
Post by: Kitz Kat on February 22, 2009, 02:58:07 PM
Just about any parts store.
Post by: Jim_Miller on February 22, 2009, 03:14:47 PM
And I hope you have better luck than I did... there are several differant styles out there.. Google "A/C Line Quick Disconnect Tool"
I have tried http://www.hermanscentral.com/product/otc-6538-4-pc-ac-line-quick-disconnect-tool-set-17532.cfm
and
http://www.mytoolstore.com/kd/kdengi04.html 3290 — Ford Air Conditioning and Fuel Line Spring Lock Coupling Tool
Here is a sweet Video showing the simple plastic ones http://www.ehow.com/video_2327788_ford-explorer-mercury-mountaineer-disconnecting.html
Now when I had to do mine however... after 4 hours fighting All the above tools and the thing still not coming apart... I ended up using This tool.. http://www.jamestowndistributors.com/userportal/show_product.do?pid=3627&BASE
worked great.. few secounds and it was off..
Post by: vinnietbird on February 22, 2009, 05:03:15 PM
I went to Autozone and bought mine for $9.00.they have them just hanging on the shelf.
Post by: Haystack on February 22, 2009, 05:05:50 PM
I've used the last one on the ac lines. I got a small plastic tool. It looks like a flat circle with a small raised ridge in the center around the hole. It worked really well on both ac and fuel lines. I think it may have came with the first one in your post, jim.
Post by: daminc on February 22, 2009, 11:37:35 PM
Thanks guys, I'll be getting one tomorrow.
Post by: daminc on February 23, 2009, 06:14:03 PM
Got me some of those plastic locking ring dis-connector thingys for thr ac lines......... worked great. just clip it around the tubing. push it into the connector. (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5049.jpg)
and pull it apart. (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5050.jpg)
and oh , a hole (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5051.jpg)
so I decided to pull the bumper shocks off to. What the heck. Why not. Looks like were into a full rebuild of the car anyway. And that radiator support isn't looking very good either. (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5053.jpg)
Looks like I have to either replace, or rebuild this one. (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5054.jpg)
Well I didn't do much today, but as always, I had fun. I tried to find some spring compressors that would work on the front end, but didn't have any luck. I'm thinking about making one out of threaded rod and some steel plates to remove the front springs. I don't know it I have enough balls to lower the arm to get them out without something going through the center of the spring in case it launches. Mabe 25 years ago I would've, but not anymore. That's all for today.
Post by: DVP on February 23, 2009, 06:24:04 PM
It looks like it was starting to buckle. I forgot you still had the front to do. Almost there. Almost to 100 pages too
Post by: daminc on February 23, 2009, 06:46:06 PM
Quote from: DVP;258288
Rad support?
Post by: Kitz Kat on February 23, 2009, 06:47:17 PM
Nice gloves,lol no wonder your hands look so pretty. I know you play the strings. Do you want my spring comp. send it back when your done with it.
Post by: Thunder Chicken on February 23, 2009, 06:51:17 PM
If the springs are anything like the springs on 99% of the other Fox cars out there you don't have to worry about them flying out anyway - the bottom coil will be broken off :hick:
I didn't use a spring compressor when I did mine. I bought one, but it didn't fit the car, so I didn't use it. The Mach 1 springs went in easily without a compressor, too (but the TC springs I had in before 'em were a bitch)
Post by: daminc on February 23, 2009, 06:52:09 PM
Quote from: Kitz Kat;258295
OK, It's a deal. send it on over. I didn't have the heat on when I opened up the AC lines. It was about 20 deg in there today. Usually I wear the rubber gloves. ;)
Post by: Kitz Kat on February 23, 2009, 07:05:24 PM
cooch,Lol, I can get it out to you tomorrow, no hurry to send it back. I rip them out bye hand.lol.
Post by: HAVI on February 23, 2009, 07:13:41 PM
Quote from: Kitz Kat;258303
cooch, LoL, I use my teeth! :hick: <---SEE
Post by: Kitz Kat on February 23, 2009, 07:16:21 PM
Your more of man than me! Get it to you bubba.
Post by: vinnietbird on February 23, 2009, 08:33:50 PM
Broken springs?We don't get those in Oklahoma.Even after 20 years,they look great.
Post by: daminc on February 23, 2009, 08:36:21 PM
Quote from: vinnietbird;258321
Show off
Post by: DVP on February 23, 2009, 11:18:20 PM
Quote from: daminc;258294
Rad support?
Yeah, if you draw a line straight down from the bend on the sway bar on the pass side in the pic. It looks like right in the middle of the big rust spot (sure that helped).
Post by: daminc on February 23, 2009, 11:39:25 PM
Quote from: DVP;258344
LOL I pushed it with my boot before I took the pic..
Post by: vinnietbird on February 24, 2009, 06:58:49 AM
Quote from: daminc;258323
Show off
Hey Buddy,you're gettin' some of that spring action !!! LOL.
Post by: daminc on February 24, 2009, 05:33:09 PM
Quote from: vinnietbird;258372
LOL Your right. I got some stuff today. A little front spring action, and a little fuel tank strap action. :D (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_5055.jpg)
Post by: vinnietbird on February 24, 2009, 05:58:24 PM
Woo-Hoo !!!! Springage !!!!
Post by: daminc on February 24, 2009, 06:53:21 PM
Thanks Vinnie
Post by: Thunder Chicken on February 24, 2009, 07:44:02 PM
So THAT'S what springs that haven't been exposed to 20 years of Nova Scotia salt look like...
Post by: daminc on February 24, 2009, 10:43:12 PM
I had no idea either. LOL
Post by: daminc on February 26, 2009, 05:39:20 PM
more blasting today (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5056.jpg)
Post by: DVP on February 26, 2009, 06:08:37 PM
Good time to drop in a tubular K. Buddy just got one for his drag mustang. They are crazy light.
Post by: vinnietbird on February 26, 2009, 06:19:06 PM
Nice blastin'.
I've thought of installing a tubular K-Member,but after the 5 speed and everything else installed or removed,it raised my car like I was going off road.I'm stayin' where I am.BUT,if you're planning on it eventually,DVP is right,now's the time.
Post by: daminc on February 26, 2009, 06:21:13 PM
What kind? What type? My birthday is coming soon. ;)
Post by: DVP on February 26, 2009, 06:30:05 PM
Quote from: daminc;258730
Think he went UPR. I know his control arms were UPR
Post by: daminc on February 26, 2009, 07:39:57 PM
What year swaps with my 87? or would I have to swap everything down to the rotors?
Post by: DVP on February 26, 2009, 09:17:36 PM
Quote from: daminc;258748
There is a little work that needs to be done to make it fit. There should be some old threads around. There is one about having a run of them made for our cars that have alot of info IIRC. You sould be able to re use all your stock parts but I am not totally sure.
You will have to go to Mustang motor mount I bet.
Your motor should also sit lower. The stock Mustang K sets the motor lower from what I have heard so so should this one. Lower center of gravity, thats a plus
Post by: 347Thunder on February 26, 2009, 11:08:07 PM
Quote from: DVP;258759
on my year it raised it 1" another reason I had to get the cowl hood
Post by: DVP on February 27, 2009, 12:11:15 AM
Quote from: 347Thunder;258779
Really? I am not totally sure about the whole dropping thing. It is hearsay from here though. I am going to find those old threads so I dont look so crazy
Here is a list of options too. Im sure prices have changed but still a good source of info.
Post by: 347Thunder on February 27, 2009, 06:53:49 AM
Quote from: DVP;258793
all I know is my hood closed before and after the k member it did not :D
Post by: daminc on February 27, 2009, 08:45:55 AM
hmmmm... I'm thinking it's probably not worth the time and expense right now for something that I may only put 500 miles on in a year. (if that) I'll just use the stock parts and new bolts and sleeves and stuff to put it back together. Someday if I do it, it'll make things easier for the swap. I really don't want to turn the front end into a major project. I really want to repair it to get it back together quickly. There's still a lot to do and Catjam gets closer everyday.
Post by: DVP on February 27, 2009, 10:24:13 AM
Quote from: 347Thunder;258809
I think it depends on which one you get. I could still be wrong on that though. I read that some of them even move the front wheels forward.
Post by: Kitz Kat on February 27, 2009, 01:16:09 PM
Jerry, no need now to do it. Maybe when you build the other motor for it Then yeh go for it.
Post by: daminc on February 27, 2009, 01:52:19 PM
Quote from: Kitz Kat;258833
Good idea, I didn't think of that.
Post by: Kitz Kat on February 27, 2009, 01:56:27 PM
With what you got goin on its not hard to forget where your at.
Post by: daminc on February 27, 2009, 05:37:59 PM
Started to do the nasty, Here's just some random pics and things that need to be repaired while I was working today. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5062.jpg)
I should be able to finish taking everything apart sometime this weekend if evertthing goes good
Post by: dominator on February 27, 2009, 08:44:51 PM
You taking the k member off jerry????? Was thinking since you've gone this far...... might as well do everything. Replace or at least check and clean up the k-member bolts and rust proof the frame rail where it rests up on the k-memeber.
Post by: daminc on February 27, 2009, 09:05:02 PM
Quote from: dominator;258867
Yep, Everything's coming apart and off. New bolts, sleeves, and added reinforcing where all the weld joints, and stress points are. And of course repairing the holes. ;)
Post by: vinnietbird on February 27, 2009, 10:30:24 PM
I'm so proud of you (get's all teary eyed).
Post by: daminc on February 27, 2009, 10:42:47 PM
LOL, I'm gonna rebuild it Oklahoma style. (rust free)
Post by: vinnietbird on February 27, 2009, 10:50:03 PM
Yeeeeee-Haaaaaaaw !!!!!!!! LOL.Seriously,I think you've done a great job on a car that most others would have discarded.I feel the same about my Sport.It was a salvage yard geting ready for the crusher.Now,by no means was it in the condition yours was,but,it did need a ton of work.You gotta love 'em.
Post by: daminc on February 28, 2009, 03:17:39 PM
Got some more apart today I tried the spring compressor, but the springs had so many breaks in them and so compressed that there was almost no space on the insides of the springs to get the compressor on. So I did it the manly way. Yep, you guessed it. I used the floor jack. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5077.jpg)
And here's the aftermath (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5078.jpg)
and the other side (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5080.jpg)
I finally got to use my lug wrench after 20 years. I used it to pry the springs out. LOL (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5081.jpg)
Here's how much shorter the springs are after they broke. This explains so many weird crunching noises up front. LOL (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5082.jpg)
a couple random pics of todays work (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5083.jpg)
I can't believe there's still paint in there (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5087.jpg)
So I ended up cutting the top nuts off the struts to get the springs out. I figured it was time to replace them. after all they were still factory. Next is to remove the arms and blast the rest of the front end. Then start the metal work and get it ready for paint.
Post by: vinnietbird on February 28, 2009, 03:29:58 PM
Wow.................just wow.I've never sen a rusted broken spring before.That's crazy.As far as the car as a whole,would you say the hardest part is over,and now it's the little stuff?
Post by: daminc on February 28, 2009, 04:04:21 PM
The floor and the trunk were the hardest part of the car. Hunting for parts and panels and doors was the 2nd hardest part of all this. This part of the project is where you start to see that little flicker of light in the tunnel, and know that's the way to head to get to the end. There's not a lot of repairing on the front end, and it's not in an awkward upside down position either. And I still have enough sheetmetal left over to do the repairs also. the rest of the repairs should be a breeze, and the body work and painting is what I'm really good at, so things should start to fly shortly.
Post by: jcassity on March 01, 2009, 02:09:25 AM
this view will come in handy when doing the v8 fuel lines. those are the lines running from left under the skirt to the right up into the engine bay.
Post by: Kitz Kat on March 01, 2009, 07:18:55 AM
You sure those are stang springs? they look bigger in the pic. Good job with man handling the springs.
Post by: vinnietbird on March 01, 2009, 08:36:18 AM
I pulled those springs out of the Stang (which was a be-yotch).They didn't have the help to lift the car,so,I had to scrounge around for some scissor jacks (odd,most were gone),and drop the a-frames and yank them out.'99 Stang.I'm installing the same ones in the Sport when weather warms up a little.I'm going to take a couple of extra days off work to mess with the car.Probably next week.
Post by: daminc on March 01, 2009, 08:39:39 AM
don't forget that my spring was broken 3 times and came out of a v-6 car
Post by: Kitz Kat on March 01, 2009, 10:42:45 AM
Ok I see 99 stang.
Post by: daminc on March 01, 2009, 01:14:15 PM
What would be the difference between them and stock springs in my car? anyone know? Raise it? lower it?
Post by: vinnietbird on March 01, 2009, 01:29:20 PM
I heard about a 1.5 inch drop.
Post by: vinnietbird on March 01, 2009, 01:30:00 PM
Oh,if you end up wanting stock springs,mine will be free as soon as I can get a warm day to swap mine out.Yours if you want them.
Post by: Kitz Kat on March 01, 2009, 01:32:27 PM
Not sure exactly what you have, if there 99 gt they should be about 400 lb, are's are around 600 lb. I would think it would lower it. If you remember I went thru this before and I didn't do well with mine. I do think it may drop more than you want, I'm not sure though.
Post by: Kitz Kat on March 01, 2009, 01:35:17 PM
Whats the overall length of them?
Post by: daminc on March 01, 2009, 04:37:13 PM
14 1/2"
Post by: daminc on March 01, 2009, 04:57:56 PM
Again, some random pic of removing the rest of the front end. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5088.jpg)
It's a lot better then I expected. I thought the entire bottom of the frame would have been gone. I guess it's time to take a little trip to the metal supermarket and get some metal for my frame repair. It's a little hard to explain how I'm going to repair it, so Everyone will have to wait for the next step in the project. so don't anyone worry. I can rebuild it. ;)
Post by: vinnietbird on March 01, 2009, 05:11:28 PM
FRom what I've read,the V-6 and GT Mustangs used the same front springs,and if they can hold the weight of the GT alright,then it should work for our cars.
Post by: Kitz Kat on March 01, 2009, 07:49:10 PM
Quote from: vinnietbird;259095
Vinnie, we don't have a stang.
Post by: vinnietbird on March 01, 2009, 08:26:44 PM
I understand that,but,the weight is pretty close between the two (I'd bet the Stang is a little heavier).One of the members used them on his 5.0 Bird and they worked great.
Post by: Haystack on March 01, 2009, 09:07:37 PM
v6 cougars and v-8's have the same part number but there different.
Post by: 88fiveo on March 02, 2009, 08:27:48 PM
If someone has watched 101 pages of your work and has ANY doubt you can rebuild it, they need more help than 10 PhD.'s could give them. I have NO doubt you could rebuild a paperclip into a 747...:D
Post by: Haystack on March 02, 2009, 09:21:46 PM
26 pages for me ;)
Post by: Kitz Kat on March 05, 2009, 05:56:23 PM
Quote from: Haystack;259292
26 pages for me ;)
And I need a new fix!! I'm gettin the shakes not seeing an update.
Post by: daminc on March 05, 2009, 06:09:02 PM
LOL Settle down, I bought some metal today. I'm planning my attack and need to borrow my neighbors plasma cutter this weekend. Crazy stuff is happening, don't you worry.
Post by: jcassity on March 06, 2009, 03:37:55 AM
i smell the sent of some 2''x 4'' tube steel.
Post by: daminc on March 06, 2009, 07:49:22 AM
Quote from: jcassity;259826
your sniffer must be a little off today. :D
Post by: vinnietbird on March 06, 2009, 08:41:30 AM
Armor plating?Bullet proof really is the way to go these days.LOL.
Post by: Kitz Kat on March 06, 2009, 03:24:25 PM
What kind of paint are you going to do on it?
Post by: daminc on March 06, 2009, 05:32:51 PM
Paint? which part?
Post by: vinnietbird on March 06, 2009, 07:39:33 PM
Just have truck bed liner sprayed all over it instead of painting it.With all of the chassis work,and rubber paint,you'd be unstoppable !!!!
Post by: daminc on March 06, 2009, 07:50:55 PM
Rubber would be cool, It would save time in the waxing dept. It would be like driving a giant super ball.
Post by: 86XR7project on March 06, 2009, 08:24:01 PM
I went back and looked at the beginning of your project and your car has come a loooooooong way. Keep it up, it make me excited to start mine.
Post by: daminc on March 06, 2009, 08:31:32 PM
Quote from: 86XR7project;259946
I bet that was a long read. Thanks, I'm glad my little project helps motivate others. Wait till you see the next one after this.
Post by: mercury-man on March 06, 2009, 09:14:59 PM
Jerry, On that next project you need to have a film crew on hand to tape it because you never know who's gonna watch this dude. :poke:
Post by: Kitz Kat on March 07, 2009, 05:33:09 AM
Maybe I should of said what type system are you going with.like base and clear or something no ones ever heard of!!
Post by: daminc on March 07, 2009, 07:23:34 AM
ahh, I see. I'm probably going to use BC/CC. I'm going to start with the engine compartment when I'm done fixing it, so the motor can go back in, and I can finish the rest of the body work.
Post by: Kitz Kat on March 08, 2009, 08:54:58 AM
Took me 2 years to put my sub frames in yesterday, only melted 1 fuel evap line, but there finally in.A far cry from what your doing or did.
Post by: vinnietbird on March 08, 2009, 06:28:49 PM
It should be drivable by next week then,right?
Post by: daminc on March 08, 2009, 10:12:30 PM
Quote from: Kitz Kat;260106
And I bet you didn't take a picture..............
A couple of pics today. Here's the passenger side frame repair. So far the other side seems to be Ok. This side had a little rot underneath the frame, so i decided to cut out the entire end for replacement. my plan is to replace the frame first, then rebuild the tower and surrounding metal (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5144.jpg)
I also had my work inspected today, Seems the back end passes with flying colors, and the front is coming along great. baxo say's 2 thumbs up (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5151.jpg)
Post by: 347Thunder on March 08, 2009, 10:22:24 PM
Quote from: daminc;260206
I also had my work inspected today, [COLOR="Magenta"]Seems the back end passes [/COLOR][COLOR="Magenta"]with flying colors[/COLOR], and the front is coming along great. baxo say's 2 thumbs up (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5151.jpg)
TMI gross:shakeass:
Post by: daminc on March 08, 2009, 10:43:00 PM
Oh, you guys.... Back end of the car. LOL
Post by: DVP on March 09, 2009, 12:56:32 AM
Seems the back end passes with flying colors.
Atleast you didnt say my. that would have been a sig quote.
Post by: Kitz Kat on March 09, 2009, 05:47:17 AM
No pics of mine, pretty boring stuff, just 2 bars and chuck's seat bracket. I'll leave the serious pics to you.
Post by: EricCoolCats on March 09, 2009, 09:20:00 AM
Jerry, keep an eye on those Canuckistanis. There's a reason why they call it "back bacon". ;)
Post by: 86XR7project on March 09, 2009, 09:27:02 AM
:nannerbang: :nannerbang: :disappoin
Post by: daminc on March 09, 2009, 10:18:22 AM
OK guys, let keep it on track with the project. It gets a lot of views from other people on the net besides us.
Post by: baxo on March 09, 2009, 10:47:46 AM
Yeah all joking aside the progress on it is fenominal, considering all the other crazy stuff Jerry gets accomplished during any particular week!
Post by: 86XR7project on March 09, 2009, 12:29:55 PM
Oh yeah. I was saying just the other day its crazy all he has gotten done. I am completely amazed.
Post by: daminc on March 13, 2009, 05:47:53 PM
just to keep everyone up to date..... I've been remodeling the basp00get this week. Making a media room, recording studio, and another kitchen/craft room. so here's a small update. Since the weather was so cold, I didn't bother to try to heat the garage, and I knew the weather would warm up this weekend. So this is all I did. you can kinda get the idea of what I'm doing here. It was real hard to find the size tubing that I needed that would slip around the original frame and extend up to the sheet metal on the towers, so I have to do a little welding to make it look like the original. Got everything tacked and ready to go. It's hard to get a good shot of all the angles on the piece. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5153.jpg)
Post by: 50tbrd88 on March 13, 2009, 06:07:14 PM
Wow, thats nuts! This car will be really something when its done. Freakin' awesome fabrication skills man.
Post by: Kitz Kat on March 13, 2009, 06:12:06 PM
About time, I was goin to belly ache you for pics. Your going to need cargo springs at this rate.lol
Post by: vinnietbird on March 13, 2009, 06:49:45 PM
Forget springs,just weld the a-frames and rear end stationary.Who needs cushion?
Post by: Kitz Kat on March 13, 2009, 06:56:47 PM
Might as well, I doubt there will be any twist in that car. Wait is there a big block in the future.
Post by: daminc on March 13, 2009, 08:58:39 PM
It should be a bit stronger then the old one. I figured, no sense going all the way, the frame past the wheels pretty much only holds the bumper on. It's 1/8" steel. the original frame only seems to be about 16 ga. ----mabe 15 ga.
Post by: jcassity on March 14, 2009, 02:34:18 AM
i noticed earlier you kept the metal part on the car that gave you the original orientation of the K member bolt locaitons.
to drill the holes out on the bottom of the angle and find the right spot, i would insert a magnetic parts pick up tool down through the upper hole and let it stick to the angle iron down inside. next i would get me a small round refridgerator magnet and attach it to the bottom of the angle iron. it will center itself on the other magnet. Now you could trace around the refridgerator magnet for the hole location on the bottom and drill straight up.
you gonna reuse the old collers that were inside there or just some other round stock?
Post by: daminc on March 14, 2009, 07:36:11 AM
in the 2nd pic, you can see the lines in the metal for the lower holes, they're just centered on the bottom rail and will be easy to locate. I think I'll be making new sleeves for the inside. here's some of the old one (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5143.jpg)
Post by: dominator on March 14, 2009, 08:01:51 AM
Nice work jerry. I was wondering though,since the metal your installing is over the original frame metal,is it not going to add to your original ride height and make your front end sit higher????? I know not by much but it is still going to change it. When i had my old 88 the bodyshop where i had the front frame rails replaced at made the pieces the same size as the original rails and welded them up against instead of over top,would that not be a better way to do it???? Not knocking you jerry,just askin.
Post by: daminc on March 14, 2009, 08:46:38 AM
Chris, I've also been tossing that idea around for a while. I thought about recessing the bottom of the frame so it would be flush with the original. And then I think, it's only an 1/8" or so and I have these mustang springs that will possibly lower it an 1-1/2, so I've been going back and forth on the frame location. I also went around the old frame for 1 main reason. The sides match up flush with the lower frame section, and I only need to weld new gusset plates over both sides of the frame for strength between the old and new frame. the height can really be anywhere I guess, but what I do to one side, I must also do to the other so it matches. (if I even need to repair the other side) So I guess the answer would be, I'm not really sure what I'm doing yet, so I will consider any comments or suggestions about this.
Post by: Kitz Kat on March 14, 2009, 08:54:51 AM
I don't think an 1/8" will matter much. I don't think any of our cars are the same height from side to side, I know I'm a 1/2' difference.
Post by: daminc on March 14, 2009, 09:04:08 AM
Quote from: Kitz Kat;261525
That's a good point. I now for a fact that 1 side of my car is about 1/2" lower then the other in the front when it sits on stands on the original frame. you can also see the space difference where the front frame rail was welded to the lower subframe on each side. I'll see if I can get a pic of that amazing Ford quality control. LOL
Post by: dominator on March 14, 2009, 09:42:18 AM
It is true about the fox body lean but i think that should more be fixed with adjustable rear control arms not raising the frame on one side and not the other. Not really sure we should mess with ford's design and try to straighten the frame(even if it is a bit off) as it was factory built as it may cause alignment issues and suspension geometery problems that may be unforseen. True if you have lowering springs it may not be at all noticeable. Definetly understandable about the frame strengthening and a good idea as added strength can never hurt a 20yr old frame. Either way jerry it will work, i was more concerned about the ride height and installed spring height. It is much more of a pita to make and weld the rails in as factory and probably not as strong. I definetley know you can do it lol. It would just be alot more work and what you have looks pretty good already.
Post by: HAVI on March 14, 2009, 09:45:00 AM
FWIW, when I removed the suspensions from my car and set it on jackstands, I learned two things: My garage floor is really uneven, and to get the bottom of the car level and straight is near impossible. I may invest in a frame rack/puller/straightener.
Post by: daminc on March 14, 2009, 09:53:36 AM
yea, I'm just going with the flow of how it was originally made. that's probably the reason why the drivers door gap was about 1/2" at the rocker, and the passenger side gap was about 1/8". :hick:
Post by: massCougarxr7 on March 14, 2009, 10:32:29 AM
So jerry, what happend to the SECRET STUFF!!!!! did i miss some spectacular secrets revealed thread or somthing? lol jk, looks good, cant wait to see the engine bay all smoothed in, and clean looking!!!!and i dont think the 1/8 difference will do anything noticeable.
Post by: daminc on March 14, 2009, 10:39:03 AM
Everyone will see the secret stuff on the grand unveiling of the car when it's complete. otherwise it's not secret stuff.
Post by: thunderjet302 on March 14, 2009, 11:03:38 AM
Quote from: daminc;261542
Hey my driver's door has a 1/8" bigger gap by the rocker than the passenger side. I'm not the only one :hick: Great quality control eh?
The Cougar is looking good. I think that engine bay needs a 460 ;)
Post by: daminc on March 14, 2009, 11:09:20 AM
I also had about a 1/2" of shims on the top side of one fender. now I know why
Post by: massCougarxr7 on March 14, 2009, 11:47:53 AM
ahhh i see...... so no pics when that stuff is going on........
Post by: daminc on March 14, 2009, 01:01:26 PM
Quote from: massCougarxr7;261564
Sorry, only when completed. Then I'll post the pics of when I was doing it. But they may sneak in without me realizing it.
Post by: daminc on March 18, 2009, 07:25:48 PM
So I guess before I can repair the frame, I have to repair the firewall. (http://i233.photobucket.com/albums/ee79/daminc/engine%20compartment/IMG_5182.jpg)
so it's tacked in place for now. I'll finish welding it tomorrow. And just in case you ever thought, "gee, does my head fit up under the dash?"..... The answer is yes. After your car starts on fire from a straggler piece of sound deadener that you thought had removed. you'll find a way to get your head in there to see if you put it out. :hick:
all is well in the fire area. just a little smoldering. That's all for today
Post by: Chooglin on March 18, 2009, 07:59:19 PM
coming along nicely!..............good thing the whole car didnt burn up :D
Post by: Haystack on March 18, 2009, 08:13:13 PM
two words. Acess hole for heater core. Well I guess thats more then two but yeah.
Post by: Clayton on March 18, 2009, 10:23:26 PM
tank. this car is going to be a tank
good old project ressurection. ;)
Post by: HAVI on March 18, 2009, 11:03:17 PM
Quote from: 87thunderbirdBlackJack;262464
Nice thing is, alot of this applies to any old car and rebuilding. My old Mercury is gonna require a whole bunch of custom sheet metal. Referencing this thread will prove that body work and sheet metal replacement is not limited to only classic cars. ;) and should be a confidence builder for anyone thinking they can't try it. Jerry for inspiration. :jerry:
Post by: vinnietbird on March 19, 2009, 12:59:00 AM
Jerry,I think you've worked miracles.Perhaps you should get an honorary doctor's M.D. certification.
Post by: FLSTCI71 on March 19, 2009, 08:36:40 AM
Quote from: vinnietbird;262500
"Hi, my name is Jerry, I'm an M.D. The M.D. is for 'Metal Doctor'."
Post by: vinnietbird on March 19, 2009, 09:14:12 AM
Hey Doc,I can't wait to see this thing ready for an engine and some paint.It's like watching one of those long mini-series on TV.This is way better than those American Chopper type shows.All the cool work without a dumb-A$$ yelling all the time......at least not where we can hear it.LOL.
Post by: daminc on March 19, 2009, 09:28:47 AM
No yelling, just a lot of cutting and welding on this car. I'm planning to also do a video series on my next project When that happens (they always do ;) ). That should be as much work as the car work.
Post by: vinnietbird on March 19, 2009, 09:52:30 AM
Camera,tri-pod,a couple of extra hands on occassion,and a hot chick (remember Tool time?).You are right though,filming would take a lot of extra time,but well worth it.
Post by: 86XR7project on March 19, 2009, 10:18:59 AM
I'm always speechless when i take the time to skim through your progress. , I wish I knew how to do all that sort of stuff. I know in theory but I doubt i could make it look as nice.
Post by: daminc on March 19, 2009, 06:41:56 PM
today's progress I finished welding the firewall (without fire) and started on the frame this will explain it all (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5192.jpg)
Post by: massCougarxr7 on March 19, 2009, 08:14:19 PM
Now jerry,.......im probobly dumb for asking this but, are you going to make sure every inch of your car is as perfect as the rest? Im thinking your car is going to be like showroom status........
Post by: 20thanniver-ls on March 19, 2009, 08:23:38 PM
Lookin good , as usual
Post by: vinnietbird on March 19, 2009, 08:28:16 PM
What's up,Doc? Get it...."Doc"?LOL.LOL. I'm going to try and make that your new name.
Post by: massCougarxr7 on March 19, 2009, 08:36:33 PM
It Daminc,.....Dr.,,, Daminc.......how can i help you?.........<(thats you with a james bond type of accent..)
Post by: 86XR7project on March 19, 2009, 08:38:59 PM
Looking good Doc.........The car, not you.........no wait..........I'm gonna shut up now.
Post by: daminc on March 19, 2009, 08:41:42 PM
When i was in a band 15 or so, years ago, they called me "Dr. D"
If that helps any. :D
Post by: jcassity on March 20, 2009, 02:17:43 AM
Humm Dr Jerry does have a jingle.
New forum sub catagory under "body/appearance/interior" request.................
"Ask Dr Jerry":bowdown:
Post by: Kitz Kat on March 20, 2009, 05:55:44 AM
Dear DR. D, in the spring my car gets pollen on it, Is there a way to stop this from happening?
Post by: daminc on March 20, 2009, 07:29:25 AM
Dear pollen hater, It would be best to keep your car in the garage all spring. Or start a bee farm to keep it under control. Dr. D
Post by: massCougarxr7 on March 20, 2009, 07:53:21 AM
[SIZE="7"]LMFAO!!!!!![/SIZE] you guys crack me up!!!!!!!!
Post by: massCougarxr7 on March 20, 2009, 07:58:46 AM
Dear DR.D, i just stopped breathing after smacking my face off the computer desk, from LMFAO, at these posts, what should i do????
Post by: vinnietbird on March 20, 2009, 09:23:07 AM
Dr.Jerry,I'll have pics posted soon of the port so you can see the small drop.Nice look,and I can still take a speed bump without sing the bottom of the car.
Post by: 86XR7project on March 20, 2009, 09:36:24 AM
I may have some rust spots to show you to ask for some helpful ideas if you're up to it.
Post by: daminc on March 20, 2009, 10:12:46 AM
Quote from: vinnietbird;262753
oh cool, Mine can use a little lowering
Post by: daminc on March 20, 2009, 10:13:42 AM
Quote from: 86XR7project;262759
sure, bring it on
Post by: 86XR7project on March 20, 2009, 11:08:31 AM
Okay doc, when I got my car it had little bits of surface rust which was taken care of easily but these holes (See below) see to be more serious. I worked at a machine shop a while back and was given I want to say something like 14 Ga. steel? is this too heavy and should I be tpuppies the hole more? I know it will have to be welded (Duh) but it there anything to keep this from occurring in the future?
I know how to do body work in theory, but I can't say I've put it into practice.
Post by: Kitz Kat on March 20, 2009, 07:14:40 PM
Doctor, Doctor give me the news, I got a bad case of Respect for you!!. I'm done.
Post by: Haystack on March 20, 2009, 11:51:40 PM
watch out for the holes in the fenders around the wheel well. If there is a hole, I'd bet the whole inside is rotted out.
Post by: daminc on March 21, 2009, 08:22:57 AM
86XR7project, It's really hard to tell what's rusted under the primer. It looks as though there's rust spots under it to. The lip on the wheel well is going to be your biggest problem. once it starts rusting between the inner and outer metal, you won't be able to stop the rusting unless you separate the metal and remove the rust or treat it.
Sorry it took so long to get back to you, I'm out of the US this weekend and checking up on messages. If you have more pics of the rust, post them and I'll check them out. Try to get some inside and underside pics if you can.
If it looks as bad as the pics look around the well, you may have to replace more then you realize.
Post by: 86XR7project on March 21, 2009, 09:27:21 AM
Wonderful, thats what I was afraid of....
Post by: daminc on March 22, 2009, 02:12:43 PM
Quote from: 86XR7project;263000
It's totally fixable. You just won't know how bad it is until you get into it.
Post by: 86XR7project on March 22, 2009, 02:43:48 PM
Oh, its bad but not terrible. Its got lots of surface spots that have been grounded down and fixed. Where would be a good place to get some steel from? I'd go through my ex-boss but he's not a fan of me since I quit.
Post by: daminc on March 22, 2009, 02:58:13 PM
Well, depending on how much you need and the size, You can get smaller sized pieces at Home Depot and Lowes. I get it there in a pinch after hrs if i need some. your looking at 20-22 gauge for panel repairs. You can get away using either for smaller repairs. the metal on our cars seems to be about 21 Ga.I haven't actually mic'd it but 20 seems too heavy in parts, and 22 seems a bit thiner. also, the front fenders have the same shape as the back. They could also be used with some inner lip modding for patch repairs on the back.
Oh yea, I'm back home again. ;)
Post by: 86XR7project on March 22, 2009, 03:07:23 PM
Quote from: daminc;263239
Awesome! Doc, as usual you are a life saver. That helped alot. I'm up for some extra body work.
Post by: daminc on March 22, 2009, 03:11:01 PM
Cool, I hope you have a mig welder
Post by: 86XR7project on March 22, 2009, 03:39:17 PM
A friend does so its all good.
Post by: Chooglin on March 24, 2009, 06:09:53 PM
Daminc,I hope you dont mind me using one of your pics.
I would like to know what the purpose of this vacuum ball is for,Is it a resivior? and can it be removed without any issues?
Post by: daminc on March 24, 2009, 06:35:07 PM
I have to be honest, I have no clue what it does or why it's there. Or even if they exist on V8 cars. I only know that it connects off a T at the end of the vac. line. Maybe someone else knows what it does. There's supposed to be a vac canister for the heater controls, but I don't think that's it.
Post by: ZondaC12 on March 24, 2009, 06:39:09 PM
NOOOOO dont take it off!!! It just like the orange ones on the power lines! You dont want planes to fly too low and hit your thunderbird!!!!! :hick: LOL
Post by: shorangerbird on March 25, 2009, 09:58:33 AM
-a/c vacume resv....
Post by: Chooglin on March 25, 2009, 03:07:18 PM
Quote from: shorangerbird;263822
since my AC has been removed,I no longer need this?
Post by: Cougar8775 on March 25, 2009, 03:17:23 PM
i think it runs the cruse.
Post by: HAVI on March 25, 2009, 04:40:46 PM
When you turn the engine off or in shifting whereas the vacuum fluctuates, and/or the vacuum disappears. That reservoir acts as a last second source for AC controls, brakes, etc... In short, it provides a steady supply of vacuum at all times....not a bad thing to have.
Post by: Haystack on March 26, 2009, 10:19:18 PM
So when do we get an update? I need a fix...
Post by: daminc on March 26, 2009, 11:08:03 PM
Quote from: Haystack;264163
OK... I actually coated the inside of the old frame with zero-rust so I can weld the new parts on...... Mmmmm maybe some pics and welding tomorrow, I'll se what the day is like. I was building a media room in my basp00get this week. :D (http://i233.photobucket.com/albums/ee79/daminc/our%20house/Basp00get/IMG_5208.jpg)
Post by: jcassity on March 27, 2009, 02:36:22 AM
Quote from: Chooglin;263671
also ties in the hvav. Trace out the tiny black vac line that penetrates the fire wall near the heater core and you find this little hose also leads to the vac ball thing a ma bob. I would think it helps move the various flaps and doors inside your dash when you select various hvac / blower directions.
Post by: CougarSE on March 27, 2009, 05:02:31 PM
Quote from: jcassity;264207
Sorry to continue the derailment Daminc, but I figure I'll set this strait. Its sole purpose is to keep the blower position door in the driver specified location in low vacuum situations. It has a check valve that isolates it and the blower door actuator from the rest of the vacuum lines during low vacuum situations. If this reservoir is removed your blower door will move from any selection (floor, vent) to defrost when you enter a low vac situation, I.E. full throttle or climbing a steep grade. ATC cars don't have the resevour as the blower door is electronically controlled.
Looking good Daminc, are you on AVSforums yet?
Post by: daminc on March 27, 2009, 06:07:11 PM
Quote from: CougarSE;264331
I'm really not into all that stuff. I used to be, but the older I get, the less effort i want to put into watching tv. I just need a large tv to watch. and a place to keep it.;)
Post by: daminc on March 27, 2009, 06:14:47 PM
Here's some pics guys...... I started the welding. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5214.jpg)
Post by: Kitz Kat on March 28, 2009, 04:52:52 AM
Quote from: daminc;264339
You need to put it in the garage, then you can work and play!
Post by: daminc on March 28, 2009, 06:23:03 PM
More welding (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5218.jpg)
I guess it's time to finish one of the last places that need rebuilding. Hopfully I can score a lower rad support to replace mine so I don't have to make one. And then that's it...... Time to do some body work so it can be painted.
next project (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5234.jpg)
Post by: HAVI on March 29, 2009, 05:13:14 PM
Maybe I missed it, but why does everything look orange? Is that a rust converter color? most I've seen is darker red or black.
Post by: daminc on March 29, 2009, 05:30:01 PM
Scott, look at the first pic of the first page. That's the color it started. It has no UV protection and it fades pretty fast. It's Eastwood's rust encapulator.
Post by: HAVI on March 29, 2009, 05:47:04 PM
OK, it looked lighter than Eastwood's red. Maybe it's the lighting as well.
Post by: Chooglin on March 29, 2009, 07:36:37 PM
It is just insane what you are capable of doing.
are you going to be spraying the car yourself, or have it done?
Post by: daminc on March 29, 2009, 07:55:23 PM
I'll be painting it myself
Post by: 86XR7project on March 29, 2009, 08:23:25 PM
I'm just in awe. Wow.
Post by: jcassity on March 29, 2009, 08:25:16 PM
I was actually going to ask you if you were going to do it,,, but you did in post 1122!!!!
That will be the best thing you ever did. That galley in there holds a lot of and promotes corrosion. My 3.8 headlamp harness ran under my battery in that area and a leaky battery didnt do good things to the wiring under the battery.
scott
Post by: daminc on March 30, 2009, 06:12:32 PM
Quote from: jcassity;264699
scott
The front part of the frame didn't have much rust on the top. I used to vacuum it out all the time when I would clean the car. Isn't that the silliest thing you ever heard? :rollin:
Post by: ZondaC12 on March 30, 2009, 06:15:19 PM
No it's not, because I do the exact same thing!!!!! And if I can't, I get out the air compressor and use that to blast out all the ! :rollin:
Post by: jcassity on March 30, 2009, 09:17:32 PM
I have a hole in that area,, often wondered how fruitless my trying to fix it would be when knowing all too well that the corrosion is up in the tunnel and i couldnt get to it unless i cut the top out.
Post by: daminc on March 30, 2009, 10:56:47 PM
Quote from: jcassity;264954
Well, when you get it into the garage. I'm sure it will be on the "To Do" list
Post by: cougarXLS on March 31, 2009, 10:06:53 AM
Up to 57 pages for me... now I'm caught up. :D
:jerry::jerry::jerry:
Post by: thunderjet302 on March 31, 2009, 10:44:06 AM
Wow great work:D
Wanna come over and fill all the holes in my engine bay? ;)
Post by: daminc on March 31, 2009, 09:55:32 PM
Quote from: thunderjet302;265037
Wow great work:D
Send them to me. I'll fill them and send them back. :hick:
Post by: thunderjet302 on April 01, 2009, 08:46:40 PM
Ok let me go pull them out and box 'em up :hick:
Post by: daminc on April 01, 2009, 10:55:41 PM
:hick: If they get here before Sat, I can get them sent back out by Monday. :hick:
Post by: daminc on April 11, 2009, 05:43:40 PM
got a few pics today.... here's my in between project. I finished our media room yesterday (http://i233.photobucket.com/albums/ee79/daminc/our%20house/Basp00get/IMG_5267.jpg)
Post by: jcassity on April 11, 2009, 07:20:02 PM
thats what grippes my ass about the front frame. That hollow tube holds a lot of secrets. I wish they were C channel or I beam in design on the light guage.
Nice media room,, looks great and looks easy to clean. Is that the floating floor stuff?
Post by: HAVI on April 11, 2009, 09:57:13 PM
Rust just won't give up on that car will it?
Post by: daminc on April 11, 2009, 10:22:34 PM
Post by: DerikWayne on April 13, 2009, 07:46:10 AM
Quote from: daminc;266953
Fortunately I'm more stubborn then rust.
I think we've all figured that out, LOL
Post by: daminc on April 14, 2009, 06:52:20 PM
Did a little more today. A couple more pieces, and I can put the front end back together, and hunt for my rad support. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5287.jpg)
There wasn't really anything wrong with the frame on this side, but I decided to weld a sleeve on it anyway to match the other end. The towers were repaired using 16 ga sheet metal. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5295.jpg)
got it all sealed up so I can cover it up. I also filled all the holes (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5297.jpg)
Still have to make the outer frame top pieces where the bolts go through the frame, I got some tubing to put in there to keep the frame from crushing after it gets bolted, although I don't know how much 1/8 steel will crush. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5299.jpg)
Hopefully I can get the front wheels back on soon
Post by: Kitz Kat on April 21, 2009, 03:21:01 PM
The rad. support was delivered at 1:30 is it in yet?
Post by: DVP on April 21, 2009, 04:05:03 PM
Ok so here is my question of ignorance to body work.
When you are welding new metal over the old rusted stuff couldnt that lead to rust continuing to spread onto the back of the new metal? I understand that it is not as exposed as before but it seems like there is still opportunities for water/air to reach it.
Also if it isnt too much trouble could you grab some close up pics of the steering shaft for me? At the joints, were it attaches to itself and at the rag joint and the face of the rag joint? My motor is kinda in my way.
Post by: Kitz Kat on April 21, 2009, 04:32:26 PM
Quote from: DVP;268461
Jerry got special stuff!!!
Post by: daminc on April 21, 2009, 06:51:59 PM
Quote from: Kitz Kat;268452
Got it, and everything looks great. Thanks again.
No, I had to tune up my other car today. the weekend is coming though and I also don't have much work the rest of the week. so it could happen before then
Post by: daminc on April 21, 2009, 07:09:58 PM
I ground the rust of the best I could and then treated it. then welded the new metal then encapsulated everything, then I'm going to seam seal all the joints then encapsulate it again. then finally comes the paint. plus the metal I'm using has a coating on it to keep it from rusting. So basically in a nutshell, It will take at least another 25 years to rust out again, if I drove it all year long in Buffalo. This car will almost never see moisture again, and with all the extra metal I'm putting in, it's really going to have to be really abused to get to the same point that it was when I started.
I got this.......... I can take some pics tomorrow (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5071.jpg)
Post by: daminc on April 21, 2009, 10:06:42 PM
I was just looking back at the pics. It looks like I welded that piece on rust. That was just a pic of the piece that was going to get welded. There were a lot of steps and grinding between that pic and the last one in primer. Also.... You have to kinda look at a lot of this stuff, as a before and after view. And remember.... it's real tough to weld to rust. ;)
Post by: daminc on April 22, 2009, 06:51:04 PM
The before, during and after This took about 15 min from start, to get it tacked welded. I'll finish welding it tomorrow. ;) (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5300.jpg)
Next is media blasting, some grinding, and a little more welding. Were a little closer to seeing the front wheels again. here's another cool pic looking through the rabbit hole. :D (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5305.jpg)
Post by: thunderjet302 on April 22, 2009, 06:58:16 PM
I like the idea of boxing the top of the frame rails in the front. I always thought that *gully* looked goofy under the battery tray.
Post by: Kitz Kat on April 23, 2009, 06:20:15 PM
Thats right where I cut it to. Love cordless sawz all's.
Post by: DVP on April 23, 2009, 06:27:55 PM
Thank you sir!
That makes more sense. I didnt think of it as before and after with the middle steps missing. Now it all comes together. I think your car might be one of the last of these around in the end.
Post by: baxo on April 28, 2009, 07:57:45 AM
UMM.. Jerry my man.. I believe you have some explaining to do:
Correct me if my spidey senses are wrong, but it looks like you have another cougar in that garage!
Post by: massCougarxr7 on April 28, 2009, 08:52:18 AM
It does kinda reswmble an 86 style,....... front is too flat to be 88
Post by: 1WLD BRD on April 28, 2009, 10:49:11 AM
Kinda Looks like bearmax' vert too, LOL Look at the top right through that hole... and looks like Cobra rims.... HMMM...... LOL are we just imagining things?
Post by: baxo on April 28, 2009, 12:35:59 PM
Wtf, i dont' think bear ended up selling his vert though.
Post by: DVP on April 28, 2009, 01:09:55 PM
Thats Bears for sure. You can see the black top, Cobra rims, so what happened to the black one on eBay....?
Post by: daminc on April 28, 2009, 01:14:37 PM
So since Project Evolution is taking so long with the upgrading of everything I seem to touch. LOL I decided to get myself a summer ride while I work on my baby. It'll get me around when I need, and I can have some fun driving a Cougar again.
I bought this back in Feb. It's an 85 Cougar with 85,000 miles on it. Do you guys think this will work for me until I finish my project? . . . . . . . . . .
And Yes, it was previously Bearmax's vert from Florida. I promised him would take good care of her and restore her back to showroom condition. It needs a little body work and a full strip and repaint. So there will be another project after my 87 is done. [SIZE="5"]Project E-2.0[/SIZE] will be coming soon to a forum near you (The 2nd release is always better) LOL
Post by: Beau on April 28, 2009, 03:31:16 PM
Quote from: daminc;269516
Project E-2.0 will be coming soon to a forum near you (The 2nd release is always better) LOL
F*ckin' Sweet! I love me a good sequel! :D
Post by: thunderjet302 on April 28, 2009, 03:40:11 PM
When do we get to see the T-bird version? ;)
So with two Cougars what happens when they are both finished? Which one do you drive in the summer?
Post by: V8Demon on April 28, 2009, 05:34:40 PM
Quote from: thunderjet302;269531
Both, silly! :burnout:
Post by: mercury-man on April 28, 2009, 05:42:34 PM
Hey Jerry was that (Vert) your Birthday Present to yourself friend ? :poke:
Post by: daminc on April 28, 2009, 05:55:07 PM
LOL Paul had the answer....... I'd drive the vert on the sunny days and the 87 on the humid overcast days with the air on
Post by: daminc on April 28, 2009, 05:59:31 PM
Quote from: mercury-man;269539
I actually bought it for Sheila. She wanted a 67 Cougar vert but I couldn't find one I liked. We went cruising last sunday afternoon. She said it's a keeper.
Post by: thunderjet302 on April 28, 2009, 06:18:02 PM
Quote from: V8Demon;269538
Quote from: daminc;269540
Geesh you must have a lot of time to drive in the summer. I barely have time to drive my one summer car :D
Post by: baxo on April 28, 2009, 06:29:49 PM
So Jerry, I think the big question is. How the hell did you get that thing up here from Florida? ;)
Post by: daminc on April 28, 2009, 06:36:56 PM
Quote from: baxo;269546
There's this guy from Welland, Ontario that was willing to fly down and drive it back for me. And I hear it was one hell of a trip...
Post by: daminc on April 28, 2009, 06:38:23 PM
Quote from: thunderjet302;269544
I have all the time I want.... I own the company I work for. ;)
Post by: baxo on April 28, 2009, 06:40:21 PM
Quote from: daminc;269547
It sure was :burnout:
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: CatCarMan2012 on April 28, 2009, 06:43:08 PM
You like pain don't you?
Post by: daminc on April 28, 2009, 06:43:14 PM
I'm sure Eric would agree
Post by: dominator on April 28, 2009, 07:18:25 PM
Cool,how long did it take ya to get back to jerry's house from florida Alex????
Post by: baxo on April 28, 2009, 07:27:41 PM
Including breaking down and Eric's heroic rescue to get it fixed, 22 hours. Woulda taken about 16-18 hours otherwise.
Post by: 86XR7project on April 28, 2009, 07:38:09 PM
Nice. Good to see you are sticking with the Cougars. Looks like we will get to see some more neat things happen from your shop.
Post by: mercury-man on April 28, 2009, 07:47:24 PM
:bowdown:Jerry, Thanks for keeping the Vert here on this forum man. ;)
Post by: HAVI on April 28, 2009, 08:01:11 PM
Well you've done yourself in. Now you have to get the Cougar done before winter, lol.
Post by: daminc on April 28, 2009, 08:11:16 PM
Quote from: HAVI;269562
Why is that?
Post by: EricCoolCats on April 28, 2009, 08:19:53 PM
(http://www.coolcats.net/ximages/jerryvert01.jpg)
"Heroic"? Mmmm...that's a little dramatic. All we had to do was fix the negative battery cable, fix the driver's side window motor, and attach the kickdown rod with homemade parts. No big deal. ;)
Post by: daminc on April 28, 2009, 08:25:57 PM
And I appreciate you pulling the stuff off your own car
Post by: HAVI on April 28, 2009, 08:27:30 PM
Quote from: daminc;269564
Why is that?
With a Cougar vert, who wants to put the top up? :hick:
Post by: daminc on April 28, 2009, 08:38:06 PM
Quote from: HAVI;269568
yea, I'm adding another 2 bays on the garage so I don't have to put the top up. :D
Post by: massCougarxr7 on April 28, 2009, 08:49:31 PM
Thats awesome great score!!!!!
Post by: Haystack on April 29, 2009, 03:19:50 PM
You better finish up the first car!
Post by: Kitz Kat on April 29, 2009, 03:54:08 PM
Was this a secret? You may need more than 2 bays added.
Post by: cougarXLS on April 29, 2009, 06:32:31 PM
lol, missed another bunch of pages. *[insert bookmark here]
Congrats on the vert... GO: :jerry:
Post by: daminc on April 29, 2009, 08:12:11 PM
Don't worry, I plan on finishing the first project before I start the next. Kitz, it was a temporary secret until I got it inspected and replaced a bunch of things. and I think 5 bays total will be enough. ;)
And here we are back to the first project. finished up the drivers side today It's getting there....... (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5323.jpg)
Post by: dominator on April 29, 2009, 08:23:31 PM
Looks pretty solid now Jerry,keep it up!!
Post by: thunderjet302 on April 29, 2009, 08:53:59 PM
Are you going to keep it black underhood or paint it body color?
Post by: daminc on April 29, 2009, 09:05:10 PM
Quote from: thunderjet302;269768
Yes
Post by: BEARMAX on April 30, 2009, 08:01:36 AM
o so the cats out the bag ha....awwww imiss her so much
Post by: baxo on April 30, 2009, 12:10:08 PM
Quote from: BEARMAX;269807
yeah it was tough seeing a grown bear cry. :(
Post by: DVP on April 30, 2009, 01:10:28 PM
One sale you will regret. Good news is you know where it went and that it will be taken care of.
Post by: daminc on April 30, 2009, 06:35:48 PM
So back to the grind so to speak
Got some stuff today... struts for the 87 and rear air shocks for the vert. (I keep rubber buffin the wheel wells) (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5329.jpg)
removing the old struts (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5330.jpg)
De-greasing everything to media blast tomorrow (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5331.jpg)
I can't believe there's still paint on this thing. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5333.jpg)
Just keeping the dream alive. I guess, now a have even more motivation to finish this car. ;) That's all for today my friends.
Post by: massCougarxr7 on May 01, 2009, 11:55:13 AM
wow!!! Hey ya know if i had time like you id be more than merry to come help you with youre build,..... Im sure a couple extra hands couldnt hurt anything......So if the 87 is done this summer you gonna start the vert this winter????? Or you going to give yourself som " drive around and enjoy it time"????
Post by: DVP on May 01, 2009, 12:02:28 PM
Bet the oil was the only thing that kept the paint on. I assume you are pulling it all apart then blasting, but it doesnt look to be in that bad of shape as far as rust goes.
Post by: Kitz Kat on May 01, 2009, 02:33:34 PM
Hey DR. D are you doin the ball joints and bushings? Why did you need a spring compressor? dude you keep getting deeper and deeper.
Post by: V8Demon on May 01, 2009, 02:37:18 PM
Keeping the stock k-member in your situation?
Post by: Kitz Kat on May 01, 2009, 02:50:02 PM
Quote from: V8Demon;270058
I wonder about what he's thinking, I'm sure plenty!! He's being a little more secretive lately!!
Post by: vinnietbird on May 01, 2009, 05:10:29 PM
I was lucky enough to be able to install the springs (and remove the fronts) without a compressor.Jeddy,you are really rockin' on the Cat !! I say that out of jealousy since the Sport is so close to death after the extreme damage yesterday and will probably end up being parted out (I was embellishing the truth there for a more dramatic feeling).
Post by: daminc on May 01, 2009, 06:08:31 PM
Ok, I need some input from everyone.. I was planing on reusing the entire front end. (the entire sha-bang) But now that I try to take the arms off, the bolts are rusted to the sleeves. Which means I have to start cutting and replacing parts, bolts, bushings, etc. If you were in my position what would you do? just replace the rusted parts, replace the arms, or just go for the gold and get a tubular front end. or is there a way of upgrading that i'm not seeing right now? I don't have a problem with "better" as far as parts go. On another side note..... I have an entire replacement in my parts bird that looks in better shape then mine. but I still need to remove the motor. I was planning on getting the front wheels back on and do the body work and also work on the motor in my spare time. or do I just put my front end back on to do the body work so I can move the car around and paint it, then swap the front end out again before I put the motor in.....hmmmmm my brain is spinning right now, not knowing which would make more sense...
Post by: Kitz Kat on May 01, 2009, 06:43:40 PM
I really don't want to be the first to answer, You might want to consider it the K mem. Jerry I don't have the answer. Use your judgment.
Post by: chas jr on May 01, 2009, 07:25:43 PM
Jerry, Can you get a measurement on how far the rack sleeves stick out on th K member?? I am going to have to fabricate some as I checked with Ford and there are no kits or parts avaiable. Thanks in advance and your are doing an awesome job. Keep it up.
Post by: dominator on May 01, 2009, 07:32:01 PM
If you can afford it jerry the tubular would be the way to go(you,ve come this far and have a tubular rear). They do make tubular front arms with the spring perch's so you can still use your springs and struts and if you want in the future,replace the arms and go coil over. Your arms will require replacement if you cut the bolts of as getting out the rotted parts will be near impossible. Plus the car will be faster due to the weight savings ++.
Post by: Clayton on May 01, 2009, 10:18:02 PM
Post by: daminc on May 01, 2009, 11:12:51 PM
Quote from: chas jr;270096
Thanks, I'll get it tomorrow for you
Post by: daminc on May 01, 2009, 11:28:09 PM
I guess to answer the keeping of the k-member question.. I want to keep it stock for right now if I can. and put the motor from the bird in. I was planning on getting a crate motor in a couple years to replace the one I'm putting in now, so I was planning on changing everything over to tube when I did that. So now I think I'm going to stick with my original plan, and toss this one back in for now to get the wheels back on and the motor in. I'll slap a quick coat of paint on it for the time being. If need be, I can change the bushings and arms If I run into a problem down the road, as I'm keeping most of the front end parts from the bird just in case.
I guess I just needed to think through a plan to keep the project going
Post by: vinnietbird on May 02, 2009, 10:29:27 AM
Take the K-member from the Bird.and block up the front end of the Bird.A roll back truck won't care if it has wheels on it or not when it's towed away.Or,just cut the a-frames from the rusty bolt k-member and swap the a-frames only from the Bird.My own opinion.I am SOOOOOO glad we don't have to deal with rust here.My lower a-frames (when I swapped them) came off like a charm,no rust at all.I sometimes appreciate Oklahoma weather.
Post by: thunderjet302 on May 02, 2009, 10:48:09 AM
If the K member is good I'd just get a set of arms from FRPP and put FOX balljoints in them. If you pull the arms from the T-bird you're going to have to replace the balljoints and bushings any way. Plus why not get brand new parts? :hick:
Post by: daminc on May 02, 2009, 06:05:57 PM
The sleeves come out 2-3/8" the bolt comes out a total of 4"
Post by: daminc on May 02, 2009, 06:11:59 PM
So I decided to paint up the original and if I need to replace something, then I'll deal with that when the time comes. It needs another coat of paint still (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5338.jpg)
Post by: chas jr on May 02, 2009, 06:27:16 PM
Thanks Jerry. I will figure the rest out. I started in the back today and as I suspected I have to manufacture fuel tank strap supports. One good and one gone. Just going to fig for both. My K member I took it completely apart and put in all new bushings and ball joints. I have the K member put back on the car but still need to get all the other parts on. I have a post I started but have not updated as progress is very very slow going. I will try to get some pics and get them on.
Post by: daminc on May 05, 2009, 09:02:17 PM
Todays progress I think you'll get the idea by looking at the pics (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5348.jpg)
Post by: vinnietbird on May 05, 2009, 09:14:55 PM
Are those the factory spindles,or are you going up tp the 11 inch brakes?Nice work so far.I'm proud for you.As soon as I get rotors and a few other pieces,I'm upgrading my front brakes.Right now,after paying Kacie's (our daughter) tuition,money is just an urban legend.LOL.
Post by: daminc on May 05, 2009, 09:37:12 PM
Everything's still factory. I'll do the upgrade when i'm looking for something to do in the future.
Post by: mattg on May 06, 2009, 09:20:33 AM
what paint product did you use on the k member and engine bay area?
Post by: massCougarxr7 on May 06, 2009, 09:40:45 AM
Lookin good jerry!!!!
Post by: daminc on May 06, 2009, 02:18:05 PM
everything I painted so far has been zero-rust. the only 2 things I painted diff on the car were the rear end and the k member. I used rustoleum hammered metal for rusted metal paint. (because of the rust pitting) So far it seems real tough and grabs the rust like zero-rust.
The engine compartment will be painted the same color as the car. Black.
Post by: mattg on May 06, 2009, 03:29:47 PM
i don't mean to hijack and turn this into a paint over rust discussion / debate. if i may- just one quick question for my own edification. as far as your comments on the rustoleum- did you mean you wanted to HIDE the pits with the rustoleum? or did you mean that the rustoleum was CHEMICALLY a better product to use on the pitted metal? thanks for this thread. I find myself studying at least some part of it just about everyday lately.
Post by: daminc on May 06, 2009, 04:32:41 PM
I used it because it's supposed to be like a rust encapulator. and it hides the pitted metal with the hammered texture. of course I got the rust off and then treated it with pickelx. At least all the rust that I could get to with it being bolted together. Like I said earlier, I'm going to put a tubular front end on in the near future, so I wasn't going to spend as much effort on the k member.
Post by: daminc on May 06, 2009, 06:50:23 PM
Here's the stuff (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5357.jpg)
which brings me to todays progress (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5358.jpg)
the lower support all degreased and welded on (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5359.jpg)
and painted (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5365.jpg)
Next is welding the brackets in the towers and some hole drilling. I'm going to get new bolts tomorrow so I can hopefully put it back together this weekend, or mabe even Friday.
Post by: daminc on May 07, 2009, 08:30:26 AM
LOL.... The scroll broke on my mouse too.....
I always wanted to build a "Mad Max" car. That would be fun (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/O1.jpg)
Post by: thunderjet302 on May 07, 2009, 12:27:37 PM
Looking good as always. Is that the stock front sway bar or a TC one?
Post by: baxo on May 07, 2009, 12:48:52 PM
Jerry, there's actually a mad max car in the Niagara Region, I used see it at cruize nights in niagara falls on sundays all the time when i went. The steering wheel is even on the right hand side and everything.
Post by: daminc on May 07, 2009, 06:34:40 PM
Quote from: baxo;271071
That's too funny
thunderjet302 Is that the stock front sway bar or a TC one?
Everything up front is still stock except for the springs that Vinnie sent me.
Todays fun time to drill the upper holes and weld it together (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5368.jpg)
I put wires through the frame to keep the sleeves in place. it would suck if they moved while pounding on the other side. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5370.jpg)
the other side will be next, and some more painting. the bolts for the front won't be in till monday, so I'll have time to finish painting the hard to reach places, clean up the steering rack and shaft and start looking for the parts that I took off a while back, and bolting things back on
Post by: Kitz Kat on May 07, 2009, 06:50:24 PM
Man, you got all kinds of stuff welded on, You got to way it when your done. before you decide to change it.
Post by: daminc on May 07, 2009, 07:48:24 PM
where do you get a car weighed?
Post by: 347Thunder on May 07, 2009, 08:23:14 PM
dump or race track
Post by: vinnietbird on May 07, 2009, 08:58:03 PM
Quote from: daminc;271041
The most bad ass car ever !!!! There's one of those about an hour south of here.Man,I want one of those.
Onto the Cougar,great work.I really am amazed at the time you've applied to this project.True love.It's these builds,on these cars,that make us SO much cooler than Stang guys.I've said it before,anyone can build a Stang,it takes someone special to build one of our cars.
Post by: vinnietbird on May 07, 2009, 08:59:52 PM
I took the Sport to the metal s yard to weigh it.I need to that again.They didn't even charge me.
Post by: DVP on May 07, 2009, 09:29:46 PM
Weight station if they are cool enough and slow.
Post by: wnt2gofst on May 07, 2009, 10:04:38 PM
http://www.youtube.com/watch?v=nzO9t7ibHgQ
Post by: Haystack on May 08, 2009, 01:20:13 AM
No one really wants a mad max car, they just want the austrailian fords.
Post by: daminc on May 08, 2009, 07:00:40 PM
And here's the other side done. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5372.jpg)
Everything seems to be lining up good. next is a little more painting and making sure everything is ready to bolt up on Monday. I also bought a gallon of epoxy primer and 2 gallons of black paint for the car today. :D
Post by: NoReflection on May 08, 2009, 11:37:57 PM
Wow looks like it might actually be back on the road soon then huh? Well maybe not... what do you have planed for the engine? I worked a little more on mine, Nothing worth taking pictures of though I will be getting a sandblaster this weekend from my dad .... stay tuned
Is this car intended for just a cruiser? Do you have plans to ever take it to the track?
Post by: Haystack on May 09, 2009, 12:23:22 AM
Don't you hate it when you get done putting the car together, and you have a bucket of bolts left? I could only imagine how big your bucket is;).
Good work on the car. I would really like to see what it looks like with paint.
Post by: daminc on May 09, 2009, 12:25:13 AM
My original plans were to make it a cruiser, but now I have the vert for that, so anything's possible for this one now. I got a 5.0 in the parts bird and everything for a HO conversion right now,and Mass air If I choose in the future.
I guess I must be planning something in the future. with all the mods and upgrades I did to it.
Post by: daminc on May 09, 2009, 12:28:16 AM
Quote from: Haystack;271374
LOL.. Actually, I'm short bolts, because I just cut most of them right off.
I'm kinda interested to see what it looks like all one color. It's been a while.
Post by: daminc on May 09, 2009, 05:16:49 PM
UPDATE
Today I finished painting the hard to reach areas, welded the SFCs where the front inside pieces come together, and seam sealed where any moisture will get in. The bolts will be in on Monday, so everything is set to go back together.
Body work and some random fixing here and there are next on the list. While that's going on, I'm going to start stripping the parts bird an pull the motor. If anyone needs anything off the car, and I'm not going to use it, let me know as I'm taking the parts off. I'll be removing everything that is usable no mater what it is, and cutting the rest of the car up and hauling it to the s yard. I'll post it for everyone while I'm doing it.
Sorry, no pics today. There wasn't anything to really take a pic of
Post by: Haystack on May 10, 2009, 11:36:28 PM
what color is the car? I have been playing around with the idea of getting rid of the ATC in my car.
Post by: daminc on May 11, 2009, 07:46:45 AM
Quote from: Haystack;271609
The parts car?
Post by: Haystack on May 11, 2009, 04:35:32 PM
yes.
Post by: Kitz Kat on May 11, 2009, 04:49:52 PM
He had to mean the parts car, we all Know the other one is stainless steel.lol
Post by: daminc on May 11, 2009, 07:23:24 PM
here's the parts car (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5179.jpg)
And thanks to kitz, I could actually get the springs seated using his compressor (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5381.jpg)
Post by: mercury-man on May 11, 2009, 09:02:04 PM
Looking good Jerry and thanks for the pics friend. ;)
Post by: dominator on May 11, 2009, 10:08:03 PM
Looks like your gettin her done jerry,nice work man. Just noticed something,your parts car has auto lamps yes?? Do you know if it works??? The blue light sensor(in the center of the dash under a cover)went bad a few years back and hasn't worked since. Any chance you'd let that one go to me for cheap???
Post by: daminc on May 11, 2009, 11:09:53 PM
Sorry Chris, I'm swapping all that into my car, along with the lighted door locks and cornering lamps
Post by: EricCoolCats on May 11, 2009, 11:15:32 PM
Hmmm...if the parts car has non-metallic paint, that's Smoke (1K), a pretty uncommon exterior color for 1987-88. I've always thought it looked like a really dirty white, but it's cool, I dig it man.
Nothing else to report. Just thought I'd throw that out there. :)
Post by: daminc on May 11, 2009, 11:28:48 PM
It's a metallic 2 stage repaint. Looks like it could have been in certain places and jambs
Post by: DVP on May 11, 2009, 11:39:01 PM
That compressor would have shaved atleast a day and a half off doing my front end stuff. Both the ones I used were too close to the spring and bolts were too long.
So now major repairs are done? Getting real close.
Post by: daminc on May 11, 2009, 11:48:42 PM
the compressor was great. Took mabe 20 min per side, for the spring and strut. The rest of the front end will be tomorrow. Then the body work can be started. My paint and primer is on it's way as of today. and the bird will be in the garage to be stripped in about a week. My father-in-law will be doing the rebuild work on the motor from the bird, while the body work gets done.
Post by: Kitz Kat on May 12, 2009, 03:47:03 AM
Moving right along now.
Post by: vinnietbird on May 12, 2009, 07:14:55 AM
You'll be done before I am.I still haven't completed but about 1/2 my list of things to do.You RAWK !!!!
Post by: dominator on May 12, 2009, 09:43:40 AM
Np man just figured i'd ask.
Post by: thunderjet302 on May 12, 2009, 12:42:36 PM
How's the trim/molding on the parts car? I'd like some spares if you're not going to use it ;)
Post by: daminc on May 12, 2009, 07:10:04 PM
Quote from: thunderjet302;271849
They're pretty cooked . :flame:
Post by: Ifixyawata on May 12, 2009, 07:12:37 PM
Now THAT would've been a helluva better spring compressor to use than the inside-type that I got from AZ. How much did that thing cost?
Post by: daminc on May 12, 2009, 07:16:16 PM
done with the front end. (http://i233.photobucket.com/albums/ee79/daminc/front%20end/IMG_5409.jpg)
Time for a beer this weekend, and get ready for the next project.
Post by: massCougarxr7 on May 12, 2009, 08:02:52 PM
SWEEET!!!! it looks soooo clean!!!!!
Post by: 86XR7project on May 12, 2009, 08:07:10 PM
I assume your going to go 5.0 EFI AOD? Or are you doing something different?
Post by: daminc on May 12, 2009, 08:28:48 PM
Here it is (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_3287.jpg)
It has a C6 behind it. but I may use my AOD from my 3.8
Post by: 86XR7project on May 12, 2009, 08:38:17 PM
Awesome, I really can't wait to see it finished!
Post by: daminc on May 12, 2009, 08:39:22 PM
Quote from: Ifixyawata;271907
I borrowed it from kitz.. It looks expensive though. It also weighs a ton. Looks like something he uses on dump trucks.
Post by: thundr306 on May 12, 2009, 08:42:22 PM
This thread makes me sick with all the work you are doing in such short time. I would be in retirement before I got all that done. Good job!
Post by: Ifixyawata on May 12, 2009, 09:06:25 PM
Quote from: daminc;271936
So Kitz.... how much did that big cost you?
Post by: NoReflection on May 12, 2009, 10:35:59 PM
That's looking real good. That one pic of the engine bay, looks like the steering shaft (its in that area) seems a little rusty...now with all that work your not going to let a little rusty thing inside your engine bay are ya? :)
Post by: Ifixyawata on May 12, 2009, 10:43:31 PM
Oh yeah.... shift linkage might look a little rusty too.... hah! Sorry I'm not nitpicking!
Post by: DVP on May 13, 2009, 12:47:56 AM
Those arent worth a on our cars. If I ever do springs again I am getting one like Kitz's. Ended up compressing mine, chaining it then shoving it in the car. Bad plan, but it worked.
Post by: Kitz Kat on May 13, 2009, 03:43:23 AM
Quote from: Ifixyawata;271943
I don't remember, but seen some on ebay for $40, they look the same. http://cgi.ebay.com/ebaymotors/MCPHERSON-STRUT-COIL-SPRING-CLAM-COMPRESSOR-MACPHERSON_W0QQitemZ190306395951QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item2c4f25272f&_trksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12|39%3A1|240%3A1318
Post by: daminc on May 13, 2009, 07:28:07 AM
The only problem with this compressor is that you can only compress the spring enough to get it seated in the arm and get a little pressure under it to hold it in. If you compress it to much, you can't get the thing off the spring because it won't slip back through the coils. and you can't use it with the strut still connected either. There's not enough room for both because of it's size.
So it did help me to the point of getting the spring seated, and keep it from popping back out.
Post by: Kitz Kat on May 13, 2009, 10:00:27 AM
I thought about modding it a little, but I don't use it much.
Post by: thunderjet302 on May 13, 2009, 11:00:34 AM
Quote from: daminc;271905
So they're not worth it :hick: What about the grill how's that?
Post by: daminc on May 13, 2009, 04:27:13 PM
Quote from: thunderjet302;272017
The entire header panel is gone as of last week. What else you need?
Post by: thunderjet302 on May 13, 2009, 05:29:30 PM
Nuts :hick: I don't need anything I just like having spare parts just incase. Could I have the engine block? ;)
Post by: daminc on May 13, 2009, 06:24:10 PM
haha
Post by: thunderjet302 on May 13, 2009, 08:57:53 PM
Quote from: daminc;272106
haha
What are you going to use it or something? ;)
Post by: chas jr on May 13, 2009, 09:59:20 PM
Jerry, Where did you get the coil spring dampners?? I.E. The red rubber pieces at the top and bottom of coils.
Post by: daminc on May 13, 2009, 10:26:33 PM
I got the spring isolators at summit, I think
Post by: daminc on May 13, 2009, 10:28:28 PM
Quote from: Ifixyawata;271956
Shift linkage, not staying..... :D
Post by: Haystack on May 13, 2009, 10:34:46 PM
stick or floor shifter, judging by the parts car and how you said you might keep the aod from the 3.8, I would assume floor shifter.
Post by: daminc on May 13, 2009, 10:56:25 PM
Yep, I got a full length console and a complete stock floor shifter and bracket. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4088.jpg)
Post by: jcassity on May 14, 2009, 12:58:06 AM
Quote from: daminc;271995
and then there is this
Post by: daminc on May 14, 2009, 07:48:04 AM
The only problem I can see is, that I needed to compress mine just to get them on the arm. I don't have stock springs in the front, and with the new isolators, it made everything about 1 1/2 longer then the space I had. In fact, with no engine weight, the wife and I had to stand on the rad support to try to compress the springs enough to get the struts bolted on.
Vinnie, did you have the same problem with yours? Aren't they the same springs? Am I going to be high riding? will I need to weld more steel on the front of my car to add weight? LOL
Post by: vinnietbird on May 14, 2009, 08:26:25 AM
Exact same springs I'm using.I pulled my front springs out (the factory Sport springs),replaced the a-frames,ball joints,and strut mounts,inserted the new springs into the perches on the a-frames and pushed the tops in with my foot,bolted the struts up to the spindles,and then,I used my two ton floor jack to lift the a-frame while I guided the strut into the mount and just kept lifting until the strut was in the mount and the spring was compressed.It took me as long to type this as it did to do the actual work on the Sport.LOL.BUT,I had the engine and all in the car.A few hundred pounds makes a big difference.The car sitss about an inch and a half lower than before,feels great on the road,and actually takes corners a little better.The ride is still smooth as before.You won't need to modify anything at all.Too bad you don't have a tie down in your floor.You could chain the car to the floor so it doesn't lift when you compress the springs.I'm going to see my grandmother,so,I'll be back this evening.If I can answer any more questions,let me know.Peace brutha.
Post by: cougarXLS on May 14, 2009, 09:41:59 AM
I can't wait to see this finished car! CJ10?!?! :jerry:
Post by: daminc on May 14, 2009, 12:35:36 PM
I thought about bolting something to the floor to pull the car down.
cougarXLS I can't wait to see this finished car! CJ10?!?!
depends on how much more upgrading I do as I go
Post by: DVP on May 14, 2009, 04:26:07 PM
Quote from: vinnietbird;272232
I wish I would have replaced my arms at the same time. You had the right idea. Sing the stock isolator out was a PITA, and I wish I would have done my arm bushing then too, would have been so much easier later. I think my car rides better over most bumps. The big ones are still a hard ride.
Vinnie did you use the "spacers/stops", the things that go inside of the spring? I forgot to put the first one in and I cut the second one out so I could use the spring compressor. I dont plan on jumping the car so I dont think it will matter much, plus I take dips and inclines very cautiously as it is. There isnt much left in the spring before it is maxed out as it is.
Any info on using and not using them?
Quote from: daminc;272283
Jerry your going to need to get a at least a double car trailer.
Post by: daminc on May 14, 2009, 07:04:09 PM
So now we've come to the point in the show where we install all the panels, and fit them for body work and paint. It would really suck to find out that the panels won't fit right after they get painted. So we must do a dress rehearsal so to speak.
I cleaned all the dust and off the car today and found the hood. I'll start to put the fenders and bumpers back on this weekend to make sure everything fits. (After I find them) lol Here's where I start to do what I'm good at.
here's the hood just sitting on the car. I already cleaned the hinges down to the original primer. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5420.jpg)
While that's happening, I'm soaking the calipers to get the rust off. I think they're still the originals. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5424.jpg)
That's all for today. And today also starts the next phase of Project Evolution. "Body and Paint"
Post by: DVP on May 14, 2009, 08:19:24 PM
Reman calipers are only like 12-15 bucks at O'Reilly's. Just make sure they are the correct ones. Cardone seems to have a problem with our calipers and making them right.
Post by: daminc on May 14, 2009, 08:26:16 PM
Quote from: DVP;272351
But mine still work
Post by: 86XR7project on May 14, 2009, 09:07:32 PM
Can't you rebuild them too?
Post by: DVP on May 14, 2009, 09:26:36 PM
Quote from: 86XR7project;272358
You could. For the price I rather get ones already done with a warranty.
Post by: baxo on May 14, 2009, 10:13:15 PM
Wow, you'll be cruising around in it by the end of summer!
Post by: BEARMAX on May 15, 2009, 12:11:30 AM
nice bro looks great makes me want to hit the CAPS BUTTON ......hehehehehe
Post by: DVP on May 15, 2009, 12:12:41 AM
Quote from: bearmax;272408
nice bro looks great makes me want to hit the caps button ......hehehehehe
lol
Post by: HAVI on May 15, 2009, 08:40:40 AM
Not to stray OT, but the vert in the background has the top up! Every vert on here, I don't recall seeing a pic with the top up. Kinda gives me the visual for a hardtop that I've been looking for. BTW, I completely understand losing fenders and bumpers, lol. :hick:
:jerry::jerry:
Post by: daminc on May 15, 2009, 05:47:53 PM
Ok, I think I found all the parts to the car. LOL
I will now display them for all to see. LOL (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5439.jpg)
I'm still up in the air about what front bumper to put on. One of these, or the TC Bumper. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5444.jpg)
more parts used from the parts bird (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5445.jpg)
Looks like I need to drill some holes in my new frame. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5446.jpg)
A couple more pics of the car. It's weird seeing fenders and things on it again. LOL I just stood there for about 15 minutes and stared at it today. that cardboard box that's always leaning against the car has all my window moulding and door stuff (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5448.jpg)
I guess i have some cleaning to do. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5452.jpg)
anyone need a computer from a 87 3.8? brand new, only about 200 miles of use on it back in 2003 I also have the NAPA code reference card for it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5453.jpg)
Looks like I'll be bolting things and cleaning things tomorrow. :D
Post by: thunderjet302 on May 15, 2009, 06:08:14 PM
I'd stick the Cougar front that originally came on the car back on it but that's just me ;)
It's nice to see it back in more or less 1 piece :D
Post by: Thunder Chicken on May 15, 2009, 07:03:13 PM
I can relate to losing parts, it took me a while to find all my window trim. I hid it away so it wouldn't get stepped on or get overspray on it, but forgot where I hid it :hick: I never did find the door insulation...
As for bumper covers, I'd go with the TC one for the fog light cutouts. I'm saying that without having to actually do it myself, though, since the grille would have to be modified
Post by: Kitz Kat on May 15, 2009, 07:58:04 PM
Hey there was a pic of a blue front end, kinda looked familiar!!
Post by: Kitz Kat on May 15, 2009, 08:02:02 PM
That front license tag on the one is a keeper.
Post by: daminc on May 15, 2009, 10:31:48 PM
Yea, I got a lot of good blue parts. (thanks) I also have a red TC bumper with a red stripe moulding
Post by: shorangerbird on May 16, 2009, 08:29:42 AM
Quote from: daminc;272572
Yea, I got a lot of good blue parts. I also have a red TC bumper with a red stripe moulding
-hmmmmmm reminds me of a Johnny Cash song...??!!!:hick:
Post by: daminc on May 16, 2009, 04:37:16 PM
today I started bolting things together for a test run. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5454.jpg)
Then I put the original front end back on . (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5458.jpg)
I'm not sure which one to use. :hick:
Post by: vinnietbird on May 16, 2009, 04:42:44 PM
I like the TC bumper cover,but on a T-Bird.On a Cougar,I never thought they looked wuite right.I have wondered,if,one could cut the foglight openings from the TC bumper and graft them into the Cougar bumper cover.It would be one of a kind,and I think it would look great.They have adhesives made for that kind of work.
Post by: mercury-man on May 16, 2009, 04:45:23 PM
Jerry, Your original 1 looks alot better friend. ;)
Post by: 86XR7project on May 16, 2009, 05:01:44 PM
Cougar bumper FTW!
Post by: Clayton on May 16, 2009, 06:06:00 PM
turbocoupe + cat grille.
shag.
Post by: cougarman on May 16, 2009, 06:19:48 PM
TC bumper cover, with Cougar header panel and grille.
Post by: 86XR7project on May 16, 2009, 06:24:24 PM
What did you do to make the grille fit? I just think it looks odd with the TC bumper bc its so pointy.
Post by: vinnietbird on May 16, 2009, 07:25:26 PM
Quote from: 86XR7project;272707
Very true.The T-Bird bumper cover is pointy,but it was made to match the angles of the TC header panel as well.Again,graft in the TC fog light openings and mount some lights.....sweeeeeeeeeeet !!!!
Post by: cougarman on May 16, 2009, 09:14:50 PM
I sectioned the cover on each side of the grille, so the grille could fit down in there.:burnout: (now back to your original program, already in progress)
Post by: daminc on May 16, 2009, 10:42:45 PM
Man, the more I look at those pics the more I think I'll use the original Cougar front bumper. the TC just looks to pointy. For 2 years I had planned on using the TC bumper. But after Putting it on the car, it seems to long in front, and I'm not really liking it. Now I wonder if I shouldn't use the TC hood, and put my old one back on..... !
Post by: FLSTCI71 on May 16, 2009, 11:08:37 PM
Quote from: daminc;272732
Obviously, it's up to you, but.... I like the TC hood. I think the scoops kind of "class" it up a little. After seeing TC hoods on cars, the original flat hoods seem a little boring. Just my $.02 worth.
Post by: baxo on May 17, 2009, 12:00:06 AM
find another cougar bumper and mix and match. Cut out the fog light area and graft it on the cougar, then you get best of both worlds. and yeah i would say keep the TC hood, unless you really don't wanna use it.. then i'll gladly take it off your hands ;)
Post by: vinnietbird on May 17, 2009, 07:22:13 AM
The hood....YES.The bumper cover....NO.The integrated TC fog lights would be cool (My 3rd hint...LOL).
Post by: daminc on May 17, 2009, 07:51:52 AM
LOL... ok guys, I got the hint....LOL
Post by: baxo on May 17, 2009, 09:43:15 AM
Vinnie how about we do it one more time..
Jerry, you know what WOULD be cool? intergrated TC foglights :P
Post by: 1WLD BRD on May 17, 2009, 09:59:57 AM
Quote from: baxo;272741
I gotta spare TC hood laying around if he doesnt sell his to ya.:mullet:
Post by: cougarXLS on May 17, 2009, 10:03:51 AM
!wow!
Definitly stick with the TC hood.... either bumber looks pretty good IMHO.
Post by: BEARMAX on May 17, 2009, 04:07:12 PM
my face is on the floor
Post by: daminc on May 17, 2009, 04:38:06 PM
Quote from: BEARMAX;272830
Was it the wing sauce?
Post by: V8Demon on May 17, 2009, 04:39:28 PM
Keep the TC hood ;)
Post by: daminc on May 17, 2009, 04:57:18 PM
Looking at V8Demon's car, I'll keep the TC hood and use my front. Mabe the fog lights will be a rainy day project. I decided to start cleaning up the inside a little. here's where I ended up last winter. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5459.jpg)
and for those new guys that didn't see the torque box plates from the inside. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5460.jpg)
I got it cleaned up real good and decided to paint the whole inside. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5461.jpg)
while that was drying I put the back bumper on the car. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5463.jpg)
Then while I was resting, I put a set of shocks on the back of the car. Here's pics of the rear end of the car in case your new to the group and didn't want to read through 1331 posts.
That's all for today, we'll see what happens tomorrow
Post by: vinnietbird on May 17, 2009, 05:46:25 PM
Quote from: baxo;272767
Hey,you know,if you integrated the fog light holes from the TC bumper cover,that would really rawk !!!! I mean,I don't want to be pushy or anything.BUT,it IS a great idea.
Post by: daminc on May 17, 2009, 07:50:05 PM
Quote from: vinnietbird;272842
Yea, I'm gonna do it. I just need another Cougar cover to do it with. I'll put her together with mine. I got 2 gallons of paint coming tomorrow, so repainting another one down the road won't be a problem.
Post by: jcassity on May 17, 2009, 10:27:12 PM
it looks so nice under there!!
Post by: Clayton on May 17, 2009, 11:54:53 PM
are you leaving the inside red??
Post by: daminc on May 18, 2009, 07:44:08 AM
Quote from: 87thunderbirdBlackJack;272880
Oh yea, It's impossible to find an interior in the same perfect condition as mine. There's a small cig burn in the back seat. (long story), but it's another one of those reasons that I kept the car.
For those that never saw or don't remember...... Pics of my interior that needs a little cleaning. (http://i233.photobucket.com/albums/ee79/daminc/cougar%20before/IMG_2835.jpg)
Even the trunk looks new. (also needs cleaning) (http://i233.photobucket.com/albums/ee79/daminc/cougar%20before/IMG_2841.jpg)
If everything goes well, the interior should be back in by the end of June. With the upgrades of course..:D
Post by: cougarXLS on May 18, 2009, 09:36:33 AM
:jerry:
Post by: massCougarxr7 on May 18, 2009, 04:33:19 PM
the only things that my interior needs are a dash cover and the drivers hanle scoop... been searching forever.....
Post by: thunderjet302 on May 18, 2009, 06:08:26 PM
I'm glad you're going witht eh Cougar front. I think it looks best on the car :D
I know you're putting in the full length console but are you putting in a floor shifter as well?
Post by: daminc on May 18, 2009, 06:44:19 PM
Yes, I have to put in the shifter because I guess there's a header clearance problem with the column shift linkage. And why not. It's just plain cool. LOL I got the entire shot, all stock. Not sure where it is though.
Today I started cleaning up little Odds-N-Ends type of things. I drilled the seat bolts and put larger bolts and washers in, and through Chucks seat brackets. I just need to enlarge the hole on the seat bracket. It just seemed like that little thin bolt was a weak link in the whole situation.
And inside. I got the nut on to keep from losing it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5468.jpg)
This week there will be a lot of small things that will get finished to get ready for the body work. It's better to do them now, then after the car is painted.
I'll also be ordering the mat for the inside this week. I was looking at this. http://www.secondskinaudio.com/products/vibration-mat-damplifier-lite.php (http://"http://www.secondskinaudio.com/products/vibration-mat-damplifier-lite.php")
Post by: daminc on May 19, 2009, 07:18:37 PM
Started grinding down the last minute welds and rust that I come across. All ready for filling. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5474.jpg)
Cleaned it up and treated it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5480.jpg)
So now I'm thinking.........Hey, I have talents. Why can't I make my own sound deadener and radiant barrier. LOL
I use these products all the time building houses, why not in a car...
here's some stuff I always have on hand. I got rolls of this stuff. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5482.jpg)
And I use this stuff all the time. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5483.jpg)
Post by: vinnietbird on May 19, 2009, 07:36:01 PM
Man,I have got to say,I am impressed.It never ceases to amaze me.Good work my friend.I still have a ways to go.You may end up getting finished before me.LOL.
Post by: daminc on May 19, 2009, 08:32:02 PM
I got a long way too. On another update, I got my paint yesterday. they messed up the order and gave me 3 gallons of black paint. instead of 2 paint and 1 primer. I'm going to keep it because of the price difference and get another gal. of epoxy primer. They did send the hardener for the primer though, so I'm ahead of the game and now have a load of paint for my car. Mabe the vert will get a free black paint job. :D
Post by: baxo on May 19, 2009, 09:23:41 PM
Quote from: daminc;273184
Or Mine..you know i plan on making mine black/orange :D
Post by: thunderjet302 on May 20, 2009, 02:54:54 PM
You know with all the extra metal plus that sound deadening/heat shield your car is going to be heavy ;) Might want to stick a stroked and poked 351W in just incase :evilgrin:
Post by: daminc on May 20, 2009, 10:15:49 PM
I don't think it's going to be as heavy as everyone thinks.
Post by: BEARMAX on May 20, 2009, 10:52:59 PM
boats and hoes
Post by: thunderjet302 on May 21, 2009, 11:41:52 AM
Quote from: daminc;273398
That's ok who doesn't want a 408W? Come on it'll be fast ;)
Post by: daminc on May 21, 2009, 06:50:45 PM
Post by: Haystack on May 21, 2009, 07:12:51 PM
Nice. I would like to see how all the sound deadener stuff works out for you.
Post by: daminc on May 21, 2009, 08:47:11 PM
It seems to be pretty dead sounding when I rap on the underside of the floor. the first layer is butyl. 2nd is rubberized/asphalt layer (basically torch down roofing). 3rd layer is the aluminum insulation/ radiant barrier. it also has an R-13 insulation value. The padding under the carpet will be the 4th layer in the entire mix, follower by the carpet.
Post by: Kitz Kat on May 22, 2009, 03:42:10 AM
Quote from: daminc;273593
Leave some room for the gas pedal to move. I have a hard time shifting mine with the floor mat in.
Post by: daminc on May 22, 2009, 07:24:34 AM
Quote from: Kitz Kat;273647
Not a problem. With everything I'm putting in, it's still thinner then the original sound deadener that a sed out.
Post by: vinnietbird on May 22, 2009, 08:09:09 AM
Same here.
Post by: DVP on May 23, 2009, 04:15:21 AM
So whats the cost of the supplies to make your sound deadener/ insulation?
Right now my car has front seats, seat belts, dash, and a dome light. Everything else is out to be cleaned and fit my floor rust.
Im know you said in here someplace where to get the POR-15 but I can never find what Im looking for. Where should I get it from and how much will it take to do the floors, and what all would I need to do your insulation method?
Post by: daminc on May 23, 2009, 07:34:24 AM
I would have to price out what I used. Unfortunately I buy in bulk for a job, which means you would probably pay more then just buying dynamat, and would have a load left over for the small amount that you would need for your car compared to what you would buy. I figure what I'm putting into the car would be around the $250-$300 range. Mabe more because I'm also doing all the interior quarter panels, trunk, door,and probably the roof. I guess My actual cost to to this is $0, because it's left over
The zero-rust you can score here. it's about $19 a quart and $60 a gallon. if your just doing the inside floor, you will only need a quart. if your doing the underside too. I would just get a gallon for the $60. Just brush and roll it with a small 3" roller.
they also have the pickelx here to if you want to convert the rust as a 1st step. http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=6RCC (http://"http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=6RCC")
Post by: DVP on May 23, 2009, 01:05:30 PM
So Zero-Rust not POR-15, and the pickelx should be done to do it right huh? Think Ill go a gallon since Ill probably end up doing the underside where the undercoating has come off and rust is starting. Trunk wouldnt hurt either.
Did you have any rust on the inside of the roof? I have some at the front center an on one of the sides. Thought it was a little odd.
Thanks
Post by: daminc on May 23, 2009, 02:54:20 PM
I haven't taken the head liner out, so I don't know if there's any rust up there. I hope not.
Post by: daminc on May 25, 2009, 07:06:02 PM
Today was a good day. I finished up the floor today (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5509.jpg)
and dug out some goodies. It feels like Christmas today (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5510.jpg)
I still need to cut the carpet and mount some things, but it's starting to not look so scary anymore
here's the back (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5523.jpg)
That's all for today. ;)
Post by: Haystack on May 25, 2009, 07:51:15 PM
sweet. Its really starting to look like a car now.
Post by: dominator on May 25, 2009, 09:08:35 PM
Nice man,gettin it done. Either picklex or por-15 will work. Jerry uses pickelx i use por-15,they both work very well. I have personal experience with por and it works very very well,at least it has on my sc over the winter(no rust). I also put some on a buddy at works 89 z24 that is all rotted out and the rust never came through even with all the salt up here and that thing is rotten,probably worse than jerry's ride although.......lol.
Post by: baxo on May 25, 2009, 09:09:56 PM
Wow nice work! Although I would have thought you'd paint it black inside there before you started putting the interior back in, or at least paint the door jambs.
Post by: daminc on May 25, 2009, 09:20:14 PM
The painting has nothing to do with the interior. There's a greater chance of me scratching something putting the interior back in. Those seats are pretty heavy with the motors. This way it's pretty much all set after the painting. It'll all get covered and sealed up whether the interior is in or not.
Post by: massCougarxr7 on May 25, 2009, 09:41:00 PM
Jerry, things are really moving along huh???? its a good thing the dash wasnt out....my dash was half taken out by some shmuck, who was supposed to do the heater core(before i found this site), and now i cant listen to the radio, cause every time i go over a bump, the dash bounces, and causes a really annoying crackel/short in the speakers,...... all i have are some metal mounts, and a glove box full of screws..:punchballs: i cant figure out where they go,.... and im itching to listen to my complete pioneer sound system....(4 6 1/2 dual cone speakers... and two 10 inch subs with a 1000 watt amp... yeah it should roar..but the whole dash yhing is a HUGE headache.........ugh... it depresses me......
But anywy .......LOOKS GREAT!!!!!!
Post by: DerikWayne on May 26, 2009, 09:53:28 AM
Post by: massCougarxr7 on May 26, 2009, 10:35:26 AM
yeah thats what i say evry day..... its depressing
Post by: thunderjet302 on May 26, 2009, 11:36:33 AM
Looking good:D
Pretty soon you can sit in it and pretend to drive ;)
Post by: bike70ride on May 26, 2009, 02:27:02 PM
Quote from: dominator;274328
Good to hear about the POR-15. I'm trying it out for the first time on my Cougar. Seems to be quite the product so far :) DEFINITELY glossy!!! Hope I can top coat it as shiny!
Post by: daminc on May 26, 2009, 07:21:10 PM
more progress today uncovered my seats today (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5524.jpg)
then proceeded to do the nasty (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5525.jpg)
now to see how everything is going together Looks like I'll be spraying the center console to match the interior color (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5537.jpg)
Post by: baxo on May 26, 2009, 10:18:44 PM
wow, that stuff definitely is good for everything after this you should become a spokesperson for it!
Post by: thunderjet302 on May 27, 2009, 11:12:24 AM
So are you putting the digi gauges in from the T-bird?
Post by: daminc on May 27, 2009, 11:28:46 AM
Quote from: thunderjet302;274587
I already have them
Post by: daminc on May 28, 2009, 04:03:45 PM
Started filling and scuffing for paint....Maybe this weekend, we'll have to see. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5550.jpg)
Post by: croga001 on May 29, 2009, 01:16:47 AM
very nice
Post by: Ifixyawata on May 29, 2009, 04:12:19 AM
yay! scotch-brite!
Post by: daminc on May 29, 2009, 07:57:31 AM
You know what's funny, after all the work I did on this car, no one will ever see what I did, because it's all covered up with something. This thread is the only proof that shows it was done, and how it was done.
Post by: 1Bad88tbird on May 29, 2009, 08:16:02 AM
Great job!! I admire your determination!!
Post by: ZondaC12 on May 29, 2009, 11:05:54 AM
Quote from: daminc;274850
Well then this thread needs it's own server with eleventy-billion levels of security and quadruple redundancy across the board. And that includes four mouses keyboards and screens for the terminal, just to be an a-hole. :hick:
Post by: Kitz Kat on May 29, 2009, 12:20:27 PM
After everything you did and are doing, I'd be afraid to take it out of the garage when it's done. I don't want to curse you to say why.
Post by: daminc on May 29, 2009, 10:18:20 PM
Quote from: Kitz Kat;274899
I couldn't even imagine what evil is lurking in your mind about my car
anyhow............ I did some more scuffing and priming. Just about ready to paint. I'll see what the weather is like tomorrow and if I have time.
All ready to go, just have to finish a couple last minute details and finish masking and covering the rest (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5553.jpg)
Post by: dominator on May 30, 2009, 07:28:49 AM
Hey jerry,why not just take the master off???? It's only two bolts and is super easy without the lines on there.
Post by: daminc on May 30, 2009, 07:52:46 AM
LOL You know, I thought about that last night after I looked at the pics. I also have to remove the shift linkage and a couple other things first, so I probably will. That's why I take so many pics. It's easy to get overwhelmed by a project this size. It's easier to stand back and take a look at what others see with the pics I take.
Post by: dominator on May 30, 2009, 09:45:25 AM
LOL true enough,sometimes we car guys do things the hard way!
Post by: massCougarxr7 on May 30, 2009, 11:33:48 AM
looking good jerry!!!!!!! So hows the motor coming????????
Post by: daminc on May 30, 2009, 02:45:25 PM
Quote from: massCougarxr7;275103
Oh , I knew I forgot something....:hick:
Post by: vinnietbird on May 30, 2009, 04:52:09 PM
I am SO proud of you dear.Lovely,just lovely.
Post by: daminc on May 30, 2009, 06:03:40 PM
Quote from: vinnietbird;275129
Oh Vincent, you say the sweetest things. :hick:
Post by: daminc on May 30, 2009, 06:14:02 PM
Todays progress.... Yep you guessed it. Paint!!! Here we are after the 2nd coat It's still a little hazy in there (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5558.jpg)
after the 3rd coat (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5563.jpg)
I guess it's time for the rest of the body work now. :D
Post by: mercury-man on May 30, 2009, 06:34:26 PM
That is gonna look real good Jerry when it's all finished friend. :poke:
Post by: dominator on May 30, 2009, 07:21:14 PM
Shiny!!! Is that base clear jerry or just enamel. I guess she's going black.
Post by: daminc on May 30, 2009, 07:54:00 PM
Single stage acrylic urethane. No need for bb/cc with a solid color. ;)
oh yea, it's going to be very black and bad ass looking
Post by: Chooglin on May 30, 2009, 08:38:36 PM
looks super!!!!! that car has come a lonnnnnnnng way.have you chosen a color for the car yet?.
Post by: daminc on May 30, 2009, 09:23:14 PM
Yep, that was it. :D
Post by: 1WLD BRD on May 31, 2009, 11:34:31 AM
thats the only problem with black.. takes shiznitty pics... cant see nothing in those engine bay pics. LOL. looking good man. cant wait to see the car painted.
Post by: HAVI on May 31, 2009, 11:47:08 AM
Looks great, Jerry! BTW, what rusty wheels are on there now?
Post by: jcassity on May 31, 2009, 12:03:41 PM
tis the time to make new brake lines,,, its something you will thank yourself later for.
why not now, all the lines can be gotten to now a lot easier.
looking great man,, thanks for keeping this thread going with plenty of porn to stare at:D
Post by: daminc on May 31, 2009, 01:57:31 PM
Quote from: HAVI;275235
The stock steel rims for the spoke wheel covers
1WLD BRD thats the only problem with black.. takes shiznitty pics... cant see nothing in those engine bay pics. LOL. looking good man. cant wait to see the car painted.
It's no better to see in person, the glare is tremendous off that paint. That's the shiniest black I've ever seen, or painted.
jcassity tis the time to make new brake lines,,, its something you will thank yourself later for.
That's the plan
Post by: vinnietbird on May 31, 2009, 04:52:03 PM
Oooooooooooh.....I wanna touch it.....your paint that is.LOL.
Post by: cougarXLS on June 01, 2009, 11:17:06 AM
wow, coming right along. Nice, very nice. :jerry:
Post by: thunderjet302 on June 03, 2009, 06:16:24 PM
Shiney :D
Post by: FLSTCI71 on June 03, 2009, 07:37:55 PM
Quote from: daminc;275148
The engine compartment looks awesome!! I think a single stage in there is just fine too, but why not a bc/cc for the exterior? We painted my son's TC a solid color (black) and we used bc/cc on that. We plan on doing the same with our current project TC when we paint that.
Post by: daminc on June 03, 2009, 08:50:01 PM
Quote from: FLSTCI71;275758
It's actually the same thing as the clear coat in a bc/cc paint job. Just eliminating the base stage. It also has a warmer deeper finish with a solid color. I can put more coats on and not worry about breaking through the finish when I sand and buff, like with a clear. The only way to describe it is.... it has that old school lacquer feel about it compared to a bc/cc paint. If I did a 2 tone or a metallic, I would have used base and clear.
The other problem with bc/cc, is if there's a problem that you don't see, like a scratch. The clear will magnify it with every coat that is applied . Less noticable with a solid color paint, because it will keep filling a scrarch, and be gone (or almost) after you sand, and buff it smooth. Single stage has a lot of advantages if you know how to work it. And it's all preference I guess. ;) Not saying any one is better, just the look i'm going for.
Post by: Kitz Kat on June 04, 2009, 07:48:47 PM
This is not the time to slow down, I need a fix!!
Post by: daminc on June 04, 2009, 07:56:56 PM
I was working on the shifter and center console. It still looks the same. although the fenders and bumper are back on. New pics tomorrow kitz
Post by: Cougar8775 on June 05, 2009, 12:26:43 PM
sorry to hijack but with the base/clear all in one what kind of prep work is needed? I know you still have to block the entire car but does it need primer or can just spots of primer where there was some work done be ok? Plus im going from a light color to a somewhat darker color will that effect it in anyway?
Post by: daminc on June 05, 2009, 09:17:08 PM
Quote from: Cougar8775;276021
John As with any painting, It's not really necessary to prime the whole car. But if you changing a color, It's usually best to prime or seal the entire care with the same 1 color. this way you won't get tint variations where the primer was compared to the old paint. It will also depend on the color of your primer too. I like to use a dark gray or black primer under dark colors. and light under light colors. it helps on the paint coverage and bleed through of a contrasting primer color. I'm using a black epoxy primer under my black paint. Are you painting your car? or having it done?
Post by: Cougar8775 on June 05, 2009, 09:25:17 PM
im thinking of tackeling this myself. once the rockers are in place that is. So basically id have to seal it even though its white? Also the color im thinking about using is about 2 or 3 shades darker the paint color is called titanium grey. and id like to seal it up anyway so its protected from any moisture and rust.
Post by: daminc on June 05, 2009, 09:29:02 PM
This weeks picture show. not really much, due to the pool rebuilding I'm doing (http://i233.photobucket.com/albums/ee79/daminc/interior/IMG_5582.jpg)
And of course the pool I reconstructed the shape and now I'm stripping the old paint off the coping, so it can be repainted. (http://i233.photobucket.com/albums/ee79/daminc/our%20house/Pool%202009/IMG_5578.jpg)
Post by: daminc on June 05, 2009, 09:33:07 PM
Quote from: Cougar8775;276108
Then go with a light gray primer. You can use epoxy on the repaired sections, and use the same epoxy as a sealer. you just need to thin it down more to use as a sealer.
Post by: thunderjet302 on June 07, 2009, 12:54:17 PM
Did you weld in a re-enforcement plate for the shifter?
Post by: Kitz Kat on June 07, 2009, 05:56:51 PM
Seen this at carlisle , now that's what you needed.
Post by: mercury-man on June 07, 2009, 06:18:31 PM
Quote from: Kitz Kat;276319
If anybody can rebuild that stang then (Dr D) would be who I'd call upon. :poke: :evilgrin:
Post by: daminc on June 07, 2009, 11:40:36 PM
Quote from: thunderjet302;276292
No I didn't, seeing that I didn't know where the shifter was actually going to be. I can always bolt a reinforcement plate into the floor and shifter bolts if needed.
Kitz, I wish I had one for this car. Mabe the next project.
So in between stripping and re-spraying the aluminum coping for the pool. I degreased and got the bird out. pulling the motor is next on the list. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5643.jpg)
Does anyone know if this tag has any information about the motor or the car it's self? Just curious, didn't know if the tag was of any importance, or if it was a part # or something, (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5646.jpg)
Post by: Haystack on June 08, 2009, 02:08:52 AM
The E7SE is a part number. E7 I do belive is a newer 90's part number. I know the E6 heads that are on the stock cougar/tbird are E6...
I would bet the valve covers were replaced at some point. Are you going full H.O.?
Post by: 1Bad88tbird on June 08, 2009, 07:45:41 AM
Are you planning on taking the air intake silencer off? Now would be the time with the fenders off. I took mine with the fender on, what a job!
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on June 08, 2009, 07:50:41 AM
Yes, I'm going stock HO for now.
And I'm sure other things will be coming off and upgraded
It's definitely a part # for something. Just wondering what? I'm gonna see what the sticker underneath says, if I can get this one off of it.
When I bought the car, the rumor was that the motor was replaced at some time in the 90s. But there's no sign of any bolts, fenders, or hood ever being removed.
Post by: Thunder Chicken on June 08, 2009, 08:50:03 AM
The sticker is a calibration number (it even says so on the sticker), not a part number. Ford engines have had those stickers since the 70's and still have them to this day (some have a bar code).
Here's a breakdown of what the label means. Yours doesn't have the bar code, but it does have the info in the top left portion of this example. There may be another sticker on the engine with the bar codes
Post by: daminc on June 08, 2009, 08:55:48 AM
what is it a calibration for? If I may ask?
I think there was a long thin sticker on the other side that got destroyed when I cleaned it. It could have been the bar code
Post by: shorangerbird on June 08, 2009, 12:26:27 PM
-you need the calibration # for when buying parts(at least Ford ones) as they are cataloged by the calibration #s. all engines use specific parts (think mostly emissions) for the specific calibration of the engine. for example, a California car would use a different calibration code from those in the rest of the USA, or Canada for that matter...so if you buy your emissions parts from Ford you will need that #.(EGR valve, DPFE, DPFE solenoid, TAB-TAD solenoids, etc...)
Post by: Thunder Chicken on June 08, 2009, 01:33:57 PM
Might also just be an assembly line code, so that the proper engine with the proper emissions equipment gets installed in the proper car. There's also a calibration label inside the driver's door jamb, but I don't know if it matches the one on the engine (and since I've changed my valve covers I can't check)...
Post by: daminc on June 08, 2009, 01:58:29 PM
Interesting, I'll check for the other label. The car was also said to originally from California, and brought to PA.
Post by: daminc on June 08, 2009, 09:45:31 PM
So it looks as though they put a newer calibration sticker over the older one. I guess it could've been built, and modified before it went to California. No other stickers were on the car. That's pretty much all I have to say about that. LOL
So today I started strippin the bird. If it unbolts, unscrews, or unclips, it's going into storage in case I need a replacement of almost anything. Including bolts, clips, and screws. also checked the car for codes before I started. the infamous EGR code was all that came up. Just working my way to remove the motor. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5651.jpg)
Post by: daminc on June 14, 2009, 05:49:06 PM
Not a lot of exciting progress like everyone's used to, but exiting for me I guess. I did some refinishing to see if I like my idea. Here's an idea of what I'm doing. I re-sprayed all the trim, wiper arms, etc. There's a lot of clean up and re painting of various parts , brackets, screws, and bolts. Very time consuming. I took pics at diff angles. I also decided to black out the window trim to match everything. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5656.jpg)
So that's it while I'm working, rebuilding the pool and getting ready to pull the motor from the bird. I also need to clean the rubber hoses and hood seals.
Post by: baxo on June 14, 2009, 06:06:29 PM
I think it looks awesome. But it makes your wiper blades look like shiznit. LOL
Post by: thundr306 on June 14, 2009, 06:15:05 PM
Looks good. Your car has been off the road as long as mine. 9/03 inspection?
Post by: daminc on June 14, 2009, 06:18:19 PM
Hey, those wiper blades are from the 80s man. They're classics J/K
I had to put something on in case they got turned on by accident at some point. Still need to do something to those rubber hoses. mabe a little armor all will make them look a little better.
Post by: daminc on June 14, 2009, 06:20:05 PM
Quote from: thundr306;277728
Yea, It's been a while. I took a couple years off to let it rust. :hick:
Post by: ZondaC12 on June 14, 2009, 11:16:35 PM
Hey dude...I was at least as excited this spring when I painted the trim around my windshield etc. Made it look soooo much better. Amazing what a difference little things like that make. Gottta have it, if its not there it makes you :screwy:
Post by: Watchdevil on June 14, 2009, 11:25:59 PM
It's pretty cool following the work on your car while I have just started mine.
Post by: thunderjet302 on June 15, 2009, 07:14:51 PM
Quote from: daminc;276407
You can get a 5.0 in and out of these cars with the hood on and with out having to remove any body panels. Trust me I did it :D
Post by: daminc on June 15, 2009, 09:46:16 PM
That's very interesting, I wonder if there's a way to tell if it had been replaced at some point? although I think it says 87 on the original calibration sticker.. It could've been replaced with another 87 motor though. I guess we'll never really know will we.
Post by: vinnietbird on June 16, 2009, 07:24:32 AM
The engine could've been replaced,but everything that bolts to it was original.Valve covers,accessories,etc.
Post by: Haystack on June 16, 2009, 09:18:44 PM
You can pull the tranny and engine out together from the front of the car if your not worried about scratching your header panel. If you are, you need another person or a leveler.
Post by: daminc on June 16, 2009, 09:57:47 PM
Quote from: Haystack;278165
I'll take everybody's word on the motor pulling, but I'm not going to test that theory with any on mine. ;)
Post by: thunderjet302 on June 17, 2009, 01:55:58 AM
I just pulled the engine out without the trans. You can get the engine out with out scratching anything by going up and forward with an engine hoist, slowly and carefully ;)
What are you using for mounts? Are you using ChuckW's engine mounts or the factory ones? If you're not using the factory ones could I buy them? I like spares and/or incase I ever find a V6 car that needs a 5.0 ;)
Post by: daminc on June 17, 2009, 07:33:36 AM
Quote from: thunderjet302;278240
I got a set from Chuck. I don't know what the condition of the existing mounts will be like after I try to pull this thing. I had to actually sawzall the ones off my 3.8. it fact, the top half of the mounts are still attached to the motor. :hick:
Post by: thunderjet302 on June 17, 2009, 10:45:08 AM
Quote from: daminc;278258
I just wanted the top and bottom metal parts of the mounts. The rubber parts of the mounts are easy to fine. If you can get the metal parts off intact I'm interested in them :D
Post by: Kitz Kat on June 17, 2009, 04:09:48 PM
Quote from: daminc;278181
I thought you took yours out that way?
Post by: vinnietbird on June 17, 2009, 07:06:31 PM
Everything out the front,no worries.Easy stuff.I didn't even remove my header panel.C'mon,live on the edge.LOL.
Post by: daminc on June 17, 2009, 07:24:53 PM
this is what was left on the car when i pulled it out. no nothing in my way (http://i233.photobucket.com/albums/ee79/daminc/motor%20removal/IMG_4641.jpg)
Post by: thundr306 on June 20, 2009, 05:39:14 PM
That donor car had some rust too!
Post by: daminc on June 20, 2009, 05:55:29 PM
Yea, makes me feel better about sping it now
Post by: daminc on June 21, 2009, 04:24:55 PM
Spaghetti for 2 anyone? Got the wiring harness out of the bird, going to degrease it, and were ready to start some serious rewiring here. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5679.jpg)
And yes, I will be installing mass air wiring. If I use it, it'll already be there.
Post by: dominator on June 21, 2009, 09:24:36 PM
Wiring and beer,hmmmmmmmmmmmm. My experiences don't work well when these two mix lol.
Post by: daminc on June 21, 2009, 10:01:30 PM
LOL That was my reward after wrestling the wires out of the bird. It just wouldn't let go.
Post by: thunderjet302 on June 22, 2009, 07:11:46 PM
The 5.0 leaked a little didn't it? ;)
Post by: daminc on June 22, 2009, 07:31:21 PM
ok, just got done washing the wiring harness. next is to inspect all the connectors and wires for damage and the infamous shrinking wire casing at the connectors.
thunderjet302:" The 5.0 leaked a little didn't it?
Lets just say that the bolts are not hard to remove anywhere on the front of that car.
Post by: thunderjet302 on June 22, 2009, 07:52:51 PM
Quote from: daminc;279217
Some times oil leaks are a good thing;)
You know now is the best time for the MAF conversion (which you are doing). You should try it with the harness in the car :hick:
Post by: daminc on June 30, 2009, 06:50:39 PM
Things are still moving along, but I'm to a point where pics won't show much progress.
Wiring has been checked and repaired. waiting for the mass air kit. Everything is just hanging around to be installed. Probably install the lighting harness and swap what I need from the bird this weekend (http://i233.photobucket.com/albums/ee79/daminc/misc%20car%20parts/IMG_5703.jpg)
In the meantime, I'm stripping down the bird and pulling out the wiring I need for the lighting package that it has and putting away any usable parts that I remove. (http://i233.photobucket.com/albums/ee79/daminc/misc%20car%20parts/IMG_5706.jpg)
Also got a Full center console that is the right color for my 87. The other one will go in the vert since it matches perfect in color. (http://i233.photobucket.com/albums/ee79/daminc/misc%20car%20parts/IMG_5705.jpg)
Also got this for my 87. Time to start polishing. (http://i233.photobucket.com/albums/ee79/daminc/misc%20car%20parts/IMG_5701.jpg)
I guess that's all that happened this week, besides the work on the pool. until next time
Post by: ProTouring442 on June 30, 2009, 08:19:24 PM
Holy corrosion Batman! I didn't know there were any Fords on the Andria Doria!
Shiny Side Up! Bill
Post by: HAVI on June 30, 2009, 11:58:03 PM
Looks like it could use a molasses bath.
Post by: Kitz Kat on July 01, 2009, 05:40:00 AM
We use a acid cleaner on the alum. wheels at work. I think it's called trailer bright. It would give you a big head start.
Post by: daminc on July 01, 2009, 07:29:00 AM
believe it or not. orange cleaner/degreaser will take a ton of that off too. It worked on my MC when I was cleaning the engine compartment. (came our shiny), but I'll probably use something Like trailer bright for aluminum.
Post by: thunderjet302 on July 01, 2009, 01:17:57 PM
I cleaned mine and painted it. A polished EFI intake is a PITA to keep clean;)
Post by: mercury-man on July 01, 2009, 01:18:00 PM
Jerry, Are you talking about the Orange Blast degreaser stuff ? Because It does clean up aluminum really nice man. :poke: :headbang:
Post by: daminc on July 01, 2009, 08:36:57 PM
Quote from: thunderjet302;280444
I'm thinking brushed and some polished areas
Quote from: mercury-man
The Zep orange cleaner from Home depot. the purple stuff will work too. Had it disintegrate the paint right of the hood hinges, down to the epoxy primer. Strong stuff....
Post by: CougarSE on July 01, 2009, 09:37:45 PM
Nice 83 console, hard to find item.
Post by: DVP on July 01, 2009, 10:43:05 PM
How did the intake box hold up?
Post by: daminc on July 04, 2009, 12:28:27 AM
Quote from: DVP;280521
Everything held up great, Thanks
Post by: jcassity on July 04, 2009, 12:44:41 AM
if you were smart, you'd not forget to c00ch up a bag full of those slip on screw clips. i woud kill for a couple of them several times a year on a lot of things not even car related.
i have to make on everytime out of a piece of sheet metal bent 180 and then make a hole with a punch.
Post by: daminc on July 05, 2009, 06:31:46 PM
Quote from: jcassity;280934
Don't you worry, After stripping the bird, I think I have about 20 lbs. of extra bolts, screws, clips, spring nuts, washers, plates, shims, regular nuts, bulbs,and various interior and exterior trim screws and fasteners, not to mention brake pedal, E-brake pedal, hood release, interior wiring, switches, lighting, sensors, mirrors, and entire interior wiring harness.(from front to back)
[SIZE="4"]********Update************[/SIZE]
The bird is getting pretty well stripped as of today. There's not much left on it. after I remove the doors fuel tank, fuel lines, E-brake cables and a few misc items, the car will be ready to get cut up. everything is down to a bare shell with suspension. All wiring is removed, along with the dash.I'll try to remove the windshield for baxo this week. Got 1 side free already.
I know this isn't progress on my car, but in a way, it's part of the entire project. So here's some pics of what's left of the parts car. A few more hrs. and I can send it to the big car lot in the sky, unless someone needs body parts from it. Somewhere along the way, I'll sell (or give away) what I don't need.
Anyway, that's this weeks progress until my mass air wiring comes. Then it's time to put her together again. hopefully I can get this bird out of here by the next weekend.
Post by: daminc on July 05, 2009, 07:13:17 PM
Almost forgot.... This months vert pic. (http://i233.photobucket.com/albums/ee79/daminc/85%20Vert/IMG_5716.jpg)
Anyone have the front piece of moulding for the fender?
Post by: mercury-man on July 05, 2009, 08:37:17 PM
Jerry , Does that mean you are leaving the side moulding trim off of your Vert ? Besides the fender sections.... :poke:
Post by: BEARMAX on July 05, 2009, 10:11:32 PM
yea jerry i have the wide trim..that tbird doesnt have any?
Post by: daminc on July 05, 2009, 10:15:38 PM
Quote from: BEARMAX;281099
the moulding is different
Post by: jcassity on July 05, 2009, 11:24:56 PM
see if you have the ford blue oval on the carpet trim along the doors. if you do, can you pm me,,, that is is your willing to let them go.
Post by: daminc on July 06, 2009, 09:25:54 AM
No Ford ovals, just blank spots where they go.
Post by: daminc on July 06, 2009, 06:34:22 PM
today I got my mass air kit. No stopping me now. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_5718.jpg)
finished stripping the bird today. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5719.jpg)
apparently the entire pass side 1/4 panel and the rear bumper was replaced at one time. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5730.jpg)
Musta got some used parts for the rebuild. the bumper supports are red, and the cover is an aftermarket part. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5720.jpg)
My biggest find of the day........ A virgin window moulding clip dropped in the car during assembly. It's like finding a dinosaur fossil. LOL (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5732.jpg)
All that's left is removing the E-brake lines and brackets, and that back seat that's rusted on by the seatbelt bolts.
I removed the fuel lines........ Is this front part of metal line replaceable? (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5728.jpg)
Post by: hirax on July 07, 2009, 10:44:46 AM
For lifting and installing the engine, I recommend to build the "adjustable engine load leveler". It will make the work much easier, especially when you work alone. Easy to build and here is mine.
(http://img189.imageshack.us/img189/7453/pink053.jpg) More levelers (http://"http://www.thefind.com/query.php?query=Adjustable+Engine+Load+Leveler")
Post by: Thunder Chicken on July 07, 2009, 03:36:21 PM
You can still buy the clips like those (windshield clips). It's the rear ones that are obsolete.
Post by: Chuck W on July 07, 2009, 03:44:59 PM
Quote from: Thunder Chicken;281321
Are the later rear ones the same as the 83-86 ones? I had to get some when I was putting the car back together. They are not as "tall" as those on the front.
I did find some though. Dorman had them.
Post by: daminc on July 08, 2009, 07:19:02 PM
That's right, the narrow clips. And I thought I found gold. LOL ########################################
Alex, you need to come over and claim you prize.....(before it breaks)
I got your windshield out without breaking it. ;)
You owe me 2 sets of guitar strings. LOL (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5733.jpg)
Here it is almost out. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5734.jpg)
I need you to come over and help get it off the car, and you can take it home with you. (http://i233.photobucket.com/albums/ee79/daminc/parts%20bird/IMG_5735.jpg)
Post by: daminc on July 08, 2009, 07:22:14 PM
So, anyone close to me need that rear window? Dan?
Post by: 86XR7project on July 08, 2009, 07:36:51 PM
Oh no! You never waste an unused guitar string!!!
Post by: baxo on July 08, 2009, 08:06:49 PM
Awesome!!! Umm I can go right now LOL. Or tomorrow after work. But I need you to come to my house too there are a few things I need you to look at and get your opinion on.
Post by: daminc on July 08, 2009, 09:00:41 PM
Hows Friday? I'll stop by tomorrow
Post by: baxo on July 08, 2009, 09:11:44 PM
that sounds good to me
Post by: Thunder Chicken on July 09, 2009, 08:09:58 AM
Quote from: Chuck W;281323
I don't know what the 83-86 clips look like. The 87-88 clips look like those in this post:
Ironically, the clips in this post came from the very Thunderbird that daminc stripped :D
Post by: daminc on July 14, 2009, 06:51:47 PM
I'm back to work on this baby after stripping and chopping up the parts bird. Started the wiring today. ... also remembered I needed to change the cable that runs from the cruise servo. the V8 cable is longer then the V6. (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5764.jpg)
Post by: thunderjet302 on July 15, 2009, 09:56:57 AM
Looks like fun :D. I remember whan I did the MAF conversion on mine it was a PITA to get the EEC harness plug out of the fire wall to pass the MAF wires through. Being that you don't have a bunch of things in your way it should go much smoother.;)
BTW why are the nuts on one strut tower silver and the other one black?
Post by: daminc on July 15, 2009, 03:23:35 PM
Quote from: thunderjet302;282273
I didn't paint the drivers side yet. ...... and stop looking at my nuts.....LOL
Post by: thunderjet302 on July 15, 2009, 03:30:28 PM
I can't admire you nuts? Mine are covered. :rollin:
Post by: daminc on July 15, 2009, 07:15:23 PM
My nuts are now equal (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5767.jpg)
And yes, everything is going to de detailed and matching under the hood. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5770.jpg)
So anyway, I started repainting various brackets and things today. (no, I didn't spray it on the back of the vert) (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5773.jpg)
also swapped the center console with the other red one. Things match like there supposed too now. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5771.jpg)
and the new addition for the vert. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5772.jpg)
Also looks like I have to hack the nubbins off the bottom of the battery tray, to bolt it into the space that I covered over. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5774.jpg)
Also have to clean that rusty bracket up and paint it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5775.jpg)
Post by: 88turbo on July 15, 2009, 07:43:05 PM
arent those "nubbins" drain holes for the battery tray? you might want to put them back in just in case your battery leaks in the future.
Post by: daminc on July 15, 2009, 11:00:46 PM
I thought they were there to sit in the frame rail. They gotta go anyway
Post by: 1WLD BRD on July 16, 2009, 08:57:57 AM
Relocated the battery to the trunk.....
Post by: daminc on July 16, 2009, 05:15:57 PM
So I cut them off. They do nothing except sit in the frame rail and make it rust. (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5776.jpg)
Got all the wiring back in the car. Brake and fuel lines are next. ............ And a whole lot of body work.
Post by: vinnietbird on July 16, 2009, 06:47:56 PM
Jerry,sorry for the delay,funds and traveling have slowed my car stuff down a lot.package coming next week.
On another subject,congrats on all the progress.It's been a long road.
Post by: Chooglin on July 16, 2009, 07:32:07 PM
Looking real good Jerry,keep up the progress.
Post by: thunderjet302 on July 16, 2009, 10:30:17 PM
Some one stole your fenders ;)
Post by: daminc on July 16, 2009, 10:44:26 PM
Thanks guys, It has been a long road to get to this point. It's finally going back together instead of getting taken apart. This part of the project is a lot more fun then the first part. I'm thinking it's time for the bodywork this weekend. :D
Post by: daminc on July 16, 2009, 10:45:42 PM
And Yes, I change those fenders as much as my underwear. LOL
Post by: Haystack on July 17, 2009, 12:25:24 AM
Once a week? Its really starting to come together. I almost don't want to imagine body work after seeing what you've already done.
Post by: thunderjet302 on July 17, 2009, 01:00:22 PM
Here's a tip for you: while the fenders are off clean/Meguiar's PlasticX the washer fluid tank. I really, really want to clean mine (it's yellowed like yours) but I have to remove the fender to do so. I'm lazy and I don't want to re-align the fender unless I'm having the car painted ;)
Post by: daminc on July 17, 2009, 04:59:56 PM
it really doesn't look yellow in person. I got another one too.
Post by: thunderjet302 on July 17, 2009, 05:05:12 PM
Quote from: daminc;282579
I'll take the one you have sitting around if it's clear ;)
Post by: daminc on July 17, 2009, 05:09:39 PM
Sorry, not selling the back up. I have to have certain extras for 2 cars now. Just in case you know..
Post by: daminc on July 18, 2009, 06:16:09 PM
Apparently, there's no trunk lids to be found in the world. LOL so here's the rebuild.
First, here my painted gas tank (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5782.jpg)
And here's the trunk lid rebuild (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5783.jpg)
And then after that, I had to put the tail lights in to make sure everything is going to line up (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5804.jpg)
and then I had to do some pounding to make it fit better (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5806.jpg)
here's how it ended up at the end of the project. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5807.jpg)
not only does it curve across the back, it also curves top to bottom. :hick: (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5808.jpg)
then I ground down the rest of the welds. Filler is the next step. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5809.jpg)
Next up........... finishing the passenger side rocker panel after this intermission ..........
I noticed my neighbor coming home from a car show in the distance. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5810.jpg)
Now back to our project.............. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5811.jpg)
It always amazes me when I look under my car..... I had to take a pic or 2 (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5814.jpg)
I never finished the bottom of the rocker when I put the quarter panel on. Can't remember the reason, but it's the last piece on the entire car that needs to be welded before the body work can start.
here's a couple of pics of that project (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5817.jpg)
also painted the hood hinges today. (http://i233.photobucket.com/albums/ee79/daminc/trunk%20lid/IMG_5819.jpg)
Next stop.... Filling, priming, and painting
Post by: dominator on July 19, 2009, 08:38:33 PM
You painting the car before the engine goes in jerry???? I'd say put it in first get it running then paint the body. Saves you possibly scratching the paint.
Post by: daminc on July 19, 2009, 08:50:42 PM
It'll be ok. The fenders won't go on until it's running. All the edges will be taped and protected as it goes back together...(painting it all separate) I'd like to have it painted soon, so I could put it outside temporarily if I needed.
Post by: HAVI on July 19, 2009, 09:00:43 PM
Ever talk to that neighbor?
Post by: daminc on July 19, 2009, 09:11:52 PM
why of course I do. and it's a Z-28 with a 302.. If that's what your getting at. LOL He bought it new when he was 18. only like 20,000 miles on it
Post by: HAVI on July 19, 2009, 09:18:03 PM
Have to race him, lol.
Post by: Cougar8775 on July 19, 2009, 09:56:57 PM
lol. my father in law is building a 68 camaro and itd going to have a 427 bored 30 over so its going to be a 433 and he is hoping it carrys the frount wheeles a good distance.
Post by: thunderjet302 on July 21, 2009, 03:53:16 PM
Nice work:D. I'm suprised you couldn't find a trunk lid.
Post by: daminc on July 21, 2009, 07:36:20 PM
todays update I cleaned the outer candy shell of the gas tank. (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5821.jpg)
Thinking this wasn't really the color I was going for when I started this project............... (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5823.jpg)
And pondering what I should do about the transmission situation. C6 from the bird? (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5825.jpg)
Or AOD from the 3.8? If I use the AOD, I read that the 3.8 DS wont fit with the 5.0 But I do have a DS for the C6. Which I didn't realize was so much shorter. (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5824.jpg)
I'm thinking there must already be a shift kit in the C6, seeing that it had a ratchet shifter in it. Hmmmmmmm. OK guys, I need some feedback on this.
Post by: cougarman on July 21, 2009, 07:58:53 PM
If it was me, I would use the C6 and the ratchet shifter, but what do I know. :hick::hick:
Post by: vinnietbird on July 21, 2009, 08:20:11 PM
If it's for cruising,I like an AOD for the extra gear.
Post by: daminc on July 21, 2009, 08:57:54 PM
The vert will now be for cruising.. I don't think I really need OD in the 87. It won't be a cruising car anymore.
Post by: 50tbrd88 on July 21, 2009, 09:15:19 PM
How is the car going to be geared? Overdrive sure is beneficial with any highway driving if running lower rearend gears...
Post by: Thunder Chicken on July 21, 2009, 09:27:01 PM
Take the convertible out on the highway and shift out of OD into D and drive for a bit. If you think you can live with that, go with the C6 :hick:
Post by: daminc on July 21, 2009, 09:27:58 PM
It's got a 8.8 w/3.73
If I cruise it around the Island, I never really drive faster then 45. the vert made it to OD 2x since I've been driving it. Don't think highway driving will be an issue with this car
Post by: dominator on July 21, 2009, 10:09:48 PM
C6 with 3.73s mmmmmmmmmmmmm, i've done a C6 with 3.70s in my old 75 cougar. Revved around 32-3500rpm at 120k,kinda high in my opinion. Get an aod out of an SC(preferably) or mustang(should be pretty cheap). I have a rebuilt one out of an SC jerry but i just don't think i want to part with it(good spare since both my car's have aod's). Look over on sccoa, you may find one fairly close for cheap.
Post by: jcassity on July 22, 2009, 12:39:13 AM
best advise of the day! hardened input shaft as well on the sc aod......per tom.,, he should know. next up would be valve bodies with a letter grade or stamp of "A" or something along those lines. all of this gets you the best trans pretty cheap.
pm tom,,
Post by: ZondaC12 on July 22, 2009, 01:00:03 AM
Yes the SC aod has the A overdrive servo as well as a wider and stronger overdrive band.
Post by: thunderjet302 on July 22, 2009, 02:16:30 AM
AOD, AOD, AOD:D. Are you sure the shaft from the 3.8 won't work?
Post by: daminc on July 22, 2009, 07:30:10 AM
Quote from: thunderjet302;283229
I was reading this the other day. I'm not quite sure if the difference is just with an 88, or all 3.8s. Or for that matter, if there will be a difference that I'll run into. I'm just be overly cautious and doing my research now before I get to that project.
A T5 shaft is close to the same length of a 5.0 AOD Bird and will interchange... A TC A4LD auto shaft is approx 5" shorter than a AOD shaft... A 3.8 AOD D/S is apparently a different length(see link)...
So, does anyone have the exact length of a DS for a 5.0 with a 8.8 rear?
Is that the correct length of the DS, in that link?
Did anyone ever use the DS from the 3.8 in there 5.0 swap?
Post by: jcassity on July 22, 2009, 09:11:57 AM
On topic, aerostar D/S 's are aluminum. You have to transfer your yoke. The gain is weight loss.
Post by: DVP on July 22, 2009, 09:33:19 AM
Quote from: jcassity;283263
SC AOD. Aerostar WELDED, not stamped shaft.
Jerry there is an 87-88 out at the yard. I didnt look at the lid though. Just had to back track about 10 pages.
Post by: thunderjet302 on July 22, 2009, 10:49:00 AM
What about a Crown Vic Police Interceptor aluminium drive shaft cut down and balanced?
Post by: vinnietbird on July 22, 2009, 03:44:51 PM
Quote from: thunderjet302;283278
I've been thinking about that.
Post by: 347Thunder on July 22, 2009, 05:11:16 PM
Do the aod I have one out of a 91' 5.0 stang with a trans-go kit and a B&M 3000 holeshot converter and I run high 11's with no problems, it just gets hot on the highway because I was too cheap to buy a lock-up converter
Post by: daminc on July 22, 2009, 08:16:31 PM
Yea, I'll probably use my AOD... I'll deal with the DS after the motor is back in I guess
Post by: 50tbrd88 on July 22, 2009, 10:05:35 PM
Quote from: daminc;283364
A wise choice.;)
Post by: Kitz Kat on July 23, 2009, 08:52:40 AM
Jerry, I can get the size for you after work.I think it's 57" from end to end of the shaft,not including the yoke. We compared the size before, I'm not positive on that number though.
Post by: daminc on July 23, 2009, 09:17:58 AM
Quote from: Kitz Kat;283405
Thanks kitz, I was going to ask you if you still had the DS length. :D
Post by: Kitz Kat on July 23, 2009, 10:53:55 AM
I wrote it down so I would remember it, but , I don't know where I put it.lol
Post by: daminc on July 23, 2009, 06:38:07 PM
So, since I changed my underwear, I had to put the fenders back on. LOL
and the hood..... Final dry run with the panels before I remove the front fenders and hood. I'll adjust the hood hinges, and leave them on the car permanently.
test run with the gas tank. I need a little adjusting with the drivers side bracket that I made. but other then that, every-things looking great under there. (http://i233.photobucket.com/albums/ee79/daminc/putting%20it%20back%20together/IMG_5836.jpg)
here's the DS sizes from my car. If anyone else would like to check there's along with kitz, it would help confirm the correct DS sizes between a 3.8 and a 5.0. It's kinda cartoon like, but it gets the point across. LOL
Post by: 1Bad88tbird on July 23, 2009, 06:53:13 PM
It's nice seeing this car come together like this. Like I said before, you defenately have talents!!
Post by: Kitz Kat on July 24, 2009, 04:13:17 AM
Quote from: 1Bad88tbird;283482
Maybe not in drawing though!! but it does get to the point. Thunder chicken had some sizes a little back, but I couldn't find them thru search.
Post by: 1WLD BRD on July 24, 2009, 09:04:40 AM
The ds are the same. I reused mine when i swapped my 3.8L C5 in my '85 to a 302 AOD...
Post by: thunderjet302 on July 24, 2009, 11:51:20 AM
Quote from: daminc;283477
Still needs some work, but it's a start. Hopefully I'll have a few more hrs. to do more tomorrow.
Post by: massCougarxr7 on July 25, 2009, 08:54:03 PM
So whats your guess on An ETA on paint????
Post by: daminc on July 26, 2009, 08:12:53 AM
I don't really have a set plan for the painting, It'll get done before winter though. I'm still working on other parts too, like the fuel and gas lines, E-brake, misc interior stuff.....
I suppose if had to, I could have it painted in about 2 weeks time. But there's no real reason to rush, since the motor is on a stand, and I haven't even started to take it apart. (and Catjam is still a year away) :D
Post by: blu84302 on July 26, 2009, 09:47:27 AM
Are you using magnets to hold the trunk lid level?
Post by: daminc on July 26, 2009, 10:00:28 AM
Quote from: blu84302;283842
Maybe...... LOL
Post by: CatCarMan2012 on July 26, 2009, 10:14:09 AM
What type of filler are you using? I could never get mine to lay down that smooth.
Post by: daminc on July 26, 2009, 10:42:25 AM
I always use a short strand waterproof filler for along the weld lines, and then a light weight filler on top of that. I usually use duraglass. and was looking for some EverCoat Rage. But I couldn't find anything smaller then a gallon. the whole car will take about a quart of filler, so I ended up getting the Napa brand (Martin Seymour). It smooths out pretty nice, and sands quick. I guess I'll see how the durability will be in the long run.
Post by: daminc on July 26, 2009, 03:32:26 PM
I stripped the paint off the rest of the car today. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5844.jpg)
And started a little filler on this side. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5846.jpg)
Still needs some filling, but It's a start. If you think about it, there's not really a lot of filler going on this car. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5850.jpg)
That's all for today. Tomorrows another day
Post by: massCougarxr7 on July 26, 2009, 07:45:56 PM
OOOOOO ahHHHHHHHHhh,... i love seeing cars with bare metal all over..... makes them look brand new.... Welll at least till it rusts!!!!!
Post by: daminc on July 26, 2009, 09:43:57 PM
Rusts???????.............. Not on my watch............ Never again..... LOL
Post by: baxo on July 26, 2009, 09:55:50 PM
thats awesome work man!
Post by: daminc on July 26, 2009, 10:27:59 PM
Quote from: baxo;283971
Thanks, Just wait, it,s gonna get awsomer before the end of the week. :D
Post by: mercury-man on July 26, 2009, 11:19:16 PM
Here's all I got to say :jerry: :jerry: :jerry: is Da Man !!
Post by: thunderjet302 on July 27, 2009, 05:15:27 PM
Looking good :D
Post by: daminc on July 27, 2009, 06:37:56 PM
Since I stripped all the paint off the car, I started getting some rust on it. So I decided to get rid of any new rust, and spray some slick sand on the bare metal, to protect it while I finish the body work.
I hope to spray the hood tomorrow, and move to the drivers side by the end of the week. That side is starting to surface rust too in spots.
In case your wondering, Slick Sand is a high build polyester, used to smooth out panels and get the surface flat. Basically it's a spray-able body filler.
Don't judge the body work by this picture. The 1/4 still has to be filled. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5857.jpg)
Post by: massCougarxr7 on July 27, 2009, 06:39:25 PM
that car will be mint forever..... Nice family heirlumb... or however you spell it.....
Post by: massCougarxr7 on July 27, 2009, 06:40:41 PM
LMFAO!!!!!!! I love the way it looks now too!!!!!! hahahaha...
Post by: BEARMAX on July 27, 2009, 08:02:59 PM
slick sand must be the same as k2 just a diferent color.that what my car is in right now
Post by: daminc on July 27, 2009, 08:22:18 PM
Quote from: BEARMAX;284128
Almost, It's not a primer, just a filler. I'll epoxy it after I board it, and flatten it. This stuff is a little easier to sand then a high build primer.
Post by: 1Bad88tbird on July 27, 2009, 10:14:43 PM
With you getting it in primer we can't tell how many cars went into the build. Lookin good!
Post by: HAVI on July 27, 2009, 10:24:18 PM
Jerry, this slick sand, who makes it? I've really only dealt with PPG, and K36 primer surfacer. So is it a temporary coating that you sand off as you smooth? like maybe a 480 grit DA? I'm curious, as I'm looking to soda blast my car, neutralize it, then want to cover it with something, before doing body work and epoxy.
Can you tell I've been out of the bodywork loop for awhile? lol
Post by: daminc on July 28, 2009, 07:54:15 AM
Quote from: 1Bad88tbird;284150
Thats a good thing.;)
HAVI Jerry, this slick sand, who makes it? I've really only dealt with PPG, and K36 primer surfacer. So is it a temporary coating that you sand off as you smooth? like maybe a 480 grit DA? I'm curious, as I'm looking to soda blast my car, neutralize it, then want to cover it with something, before doing body work and epoxy.
I was out of the loop too. LOL
Evercoat makes Slick Sand, and Rage filler which is supposed to be the best to work with. http://www.evercoat.com/productCategory.aspx?cat=2 (http://"http://www.evercoat.com/productCategory.aspx?cat=2") http://www.evercoat.com/productDetail.aspx?pID=28 (http://"http://www.evercoat.com/productDetail.aspx?pID=28")
It's mainly a leveler/primer so to speak. They say it grabs the best on bare metal scratched with 80 grit, and over epoxy. If you don't have a lot of welding and are just surfacing the car, I would just epoxy it as soon as your done blasting it. The epoxy will seal the metal better then slick sand if your not going to work on it for a long while. Then if you have to do any body work, you can grind the epoxy off where you need to. I did the SS first because I'm so close to priming it, and the SS will need to be epoxied or sealed before the paint goes on anyway. That's why I cut out the epoxy on bare metal step.
The other way. is to blast it and use picklex on the bare metal, but it needs to stay dry and also needs to be in primer within a few months or it will start rusting again from the humidity in the air. (like mine)
Post by: Kitz Kat on July 28, 2009, 03:59:08 PM
Looks done to me. It's getting there now.
Post by: HAVI on July 28, 2009, 04:51:14 PM
I'm used to applying epoxy primer first, now I see. Makes sense in your case.
Post by: daminc on July 28, 2009, 08:54:00 PM
Got out the long board. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5859.jpg)
Post by: 1Bad88tbird on July 28, 2009, 09:13:05 PM
We're getting to the exciting part!!
Post by: daminc on July 29, 2009, 07:38:54 AM
And I thought the metal work was the exciting part..........LOL
Post by: CatCarMan2012 on July 29, 2009, 09:19:58 AM
Man I wish I could lay down mud like you. I can't count how many layers I laid down, then sanded off trying to get my panel perfect. It never did come out perfect by the way.
Post by: daminc on July 29, 2009, 10:46:57 PM
sometimes less is more. ;)
Post by: FLSTCI71 on July 29, 2009, 10:52:28 PM
Quote from: daminc;284457
:bowdown:
Post by: daminc on August 02, 2009, 05:28:53 PM
started the guide coat, and leveling today. Now we can see where all the low, and high spots are on the panels. ;) (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5869.jpg)
The dark shadows are the low spots in the panels. silver spots are the high spots in the panels (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5868.jpg)
Post by: CatCarMan2012 on August 03, 2009, 10:48:09 AM
Would you mind showing me what you use for sanding? I did most of my work with a D/A, and a 8" board. I needed to buy a flex long-board but never got one. Its been my experience that there is a "sweet set" of tools that will do 99.9% of the work that needs to be done. You don't seem to be the type to waste $$.
Your causing me flashbacks. (http://carphotos.cardomain.com/ride_images/3/2023/4641/30057320029_large.jpg)
-DZ
Post by: massCougarxr7 on August 03, 2009, 12:53:47 PM
it dissapoints me to see this thread at 75% completion............. But then again,.......next up is the VERT!!!!!!
Post by: Haystack on August 03, 2009, 07:44:05 PM
take off all the paint and clear coat it.
Post by: daminc on August 03, 2009, 10:15:17 PM
Quote from: danzajax;285075
Post by: daminc on August 03, 2009, 10:17:45 PM
Quote from: massCougarxr7;285087
Don't worry, I could stretch it out for another year if I needed
Post by: CatCarMan2012 on August 03, 2009, 11:06:21 PM
What do you sand the contours with then? I used a piece of garden hose wrapped in paper.
Post by: daminc on August 04, 2009, 08:21:55 AM
I still use the same board. I just follow through from the flat surface into the contoured area with the long edge of the board. It takes a lot of practice, but it wont create low spots coming off the flats. If you use a straight line sander like I'm doing, it's easy to keep the curves and lines all straight and flat, because it's 17" long and will always stay on top of all the high spots when you sand. You also need to use a guide coat when sanding a panel, or you'll never know if it's really flat or wavy
It might be time for me to make a video of some of this finishing work as I progress. The other 1/4 panel, door, and both fenders still need to be done
This was after 5 min of sanding. you can immediately see where all the lows are once you drag the sander across the panel. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5872.jpg)
same panel after leveling. The dark spots need filling, because I'm down to bare metal on the edges. You can see dark areas near the mirror area, around the handle area, and in the curve of the door near the fender (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5873.jpg)
The 1/4 obviously needs filling. if I used a shorter sander or something flexible here, you would see a wave in the paint when it was in the sun. If you use a hose with paper on it for some sanding, make sure it's stiff enough to work with. You probably won't need to use it much. Maybe a couple small trouble areas that the board can't get into You just need to remember that smooth isn't the same thing as flat. If I sanded this out (and the door) without more filling, it would look like a fun house mirror after it was painted. :hick: Just keep in mind that mine has a little more leveling involved, because of the welding, and the 2 panels that are matched up back here. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5874.jpg)
Post by: thunderjet302 on August 04, 2009, 03:24:51 PM
When ya going to come over and do my T-bird. It doesn't have any rust. It just needs to be striped, smoothed, sanded, and painted ;)
Post by: CatCarMan2012 on August 04, 2009, 05:47:29 PM
Thanks for the pointers. Now just give me your cell phone number so I have someone to call when I start the body work on the Rabbit.
Post by: ProTouring442 on August 04, 2009, 07:07:22 PM
One caution about the sander pictured. The paper tends to get pulled into the low spots and remove the guide coat leading you to believe that the surface is perfectly level when in fact it is not. The same sanding board, but made to utilize PSA paper, a sticky backed sanding paper (PSA: Pressure Sensitive Adhesive) works much better as the adhesive keeps the paper adhered to the board and thus not down in the low spots.
Shiny Side Up! Bill
Post by: daminc on August 04, 2009, 07:36:31 PM
Quote from: ProTouring442;285258
Shiny Side Up! Bill
I will agree with that. The press on sander paper is better. I'm still stuck in the old school way of doing certain things.
Post by: SLEEPER T-BIRD 87 on August 04, 2009, 09:20:46 PM
that what i used on my mav the first few times i primed and blocked it with 80 grit
Post by: jcassity on August 05, 2009, 12:19:35 AM
Shiny Side Up! Bill
you made a summary of the novel i was about to type,,, x2 on sticky back sand paper. it will also stretch an sag into the low areas if non sticky back is used.
Post by: jcassity on August 05, 2009, 12:24:34 AM
how are you taking care of the high spots?
I have always had problems dealing with outward dings and higher surfaces. Am i correct to flat hammer the areas down, then fill/sand on the larger ones while the lower high spots i would count on the primer and paint to build up around and hide.
Post by: daminc on August 05, 2009, 07:49:04 AM
Yes, the high spots will be hit down and filled where needed. unless I can spray another coat over everything and it'll flatten out. Don't forget it still needs to be primed next. Gonna try to get back to work on it again before the weekend. I'll also try to get a new update and some pics. This side came out a little worse then the drivers side during the panel welding too.
I'll get some sticky paper... Now watch me mess it up. LOL
Post by: Kitz Kat on August 05, 2009, 04:58:17 PM
Your doing fine. I was watching. I have faith in you and the old way's.
Post by: jcassity on August 07, 2009, 12:26:41 AM
hmm make the last thread stop of page 199 making it the 199speedo mod post.
looks like a good end to a great story.
Post by: Haystack on August 07, 2009, 03:34:11 PM
I see it as page 40?
Post by: DVP on August 14, 2009, 11:10:55 PM
Period of absence catch up complete.
I will miss the progress when it is complete.
Post by: daminc on August 14, 2009, 11:17:24 PM
Don't worry, I have another.
Post by: blain_gatterdam on August 15, 2009, 02:04:07 AM
hey youre not supposed to let me run out of pages to click!
lol, this thing is pretty awesome, cant wait to get 20 pages behind again :P
Post by: DVP on August 15, 2009, 12:32:34 PM
Quote from: daminc;286729
Just not the same, just not the same....;)
Post by: daminc on August 15, 2009, 02:06:58 PM
It just might be,,,,,,,, depending on how much rust I find on it, and what I do to it.
Post by: daminc on August 19, 2009, 07:22:34 PM
yea, I know....I got a little busy building the shop, and there really weren't any pictures that showed any new progress on the car.
first things first just need siding and doors (http://i233.photobucket.com/albums/ee79/daminc/our%20house/Garage%20addition/IMG_5908.jpg)
next up.... the elusive black spotted cougar. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5909.jpg)
Post by: thunderjet302 on August 24, 2009, 09:06:03 PM
Mint cow? ;)
Post by: Sleeper on August 25, 2009, 06:16:45 PM
Hey all. I'm new to the forum and this is my first post. If anyone cares to offer any advice on getting around here I would welcome it! Now to my post. I have an '85 T-Coupe that I am basically turning into a (borderline) street legal racer. I am gutting the interior and am looking to sell/trade, whatever internal parts I have. All is in good overall condition, including the instrument cluster itself.
I go by sleeper because externally I intend to keep the car as original as possible. I am installing a 351W w/Roush-World heads, 10:1 comp, roller valvetrain, etc.... I have the engine built and am starting on the small block C6 after I get the paint on the car this fall. One quick, and I'm sure stupid question - how do I start a thread? Thanks for any and all responses
Sleeper
Post by: 50tbrd88 on August 25, 2009, 06:30:24 PM
Quote from: Sleeper;288232
Sleeper
Welcome to the forum. Best advice I can give is to start your own thread by going to say the user rides section and click "new thread" on the top left corner. Right now you are kind of hijacking daminc's thread...
Sounds like you have a hell of a motor going in there! This is a great forum so stick around and you will learn a ton.
Post by: daminc on August 25, 2009, 08:34:08 PM
Quote from: 50tbrd88;288237
NP, I like a good hijack.
Welcome aboard Sleeper
Post by: 88turbo on August 26, 2009, 02:40:42 AM
MORE!!!!! I need MORE!!!! :D
Post by: daminc on August 26, 2009, 07:09:09 PM
Here's more (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5923.jpg)
Post by: Chooglin on August 26, 2009, 07:55:06 PM
Wooo Hooo !!!! its getting close to paint time.
Looking good :bowdown:
Post by: 50tbrd88 on August 26, 2009, 11:24:52 PM
Sweet. You're gettin' there!!
Post by: Haystack on August 27, 2009, 12:38:36 AM
It really is a shame that you have to cover all of that up. It looks good to me.
Post by: daminc on August 27, 2009, 07:31:32 AM
I have to flatten this side with the board, and I also have to strip the fenders and do those. then I can prime the car and paint it. Although, I also have to see what I'm doing with the roof. not sure if I'm stripping it down or just surfacing it. I'll think about that when I'm on vacation in Cape Cod making time lapse videos. LOL
Post by: baxo on August 27, 2009, 07:42:32 AM
LOL have fun at cape cod, and remember to let me know when you're primeing!
Post by: daminc on August 27, 2009, 07:50:59 AM
I think I'm going to plan for a total prime and paint, back to back. I ordered garage doors yesterday, so I have to wait until they go on the shop so I can clear out all the to paint. We'll plan a weekend to paint it. I have to paint the backs of everything too.
Post by: baxo on August 27, 2009, 09:19:57 AM
sounds good to me, just let me know whenever.
Post by: daminc on August 28, 2009, 06:15:19 PM
Had a few minutes to do some sanding. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5929.jpg)
Post by: 1Bad88tbird on August 28, 2009, 08:11:23 PM
Looking good! You got your camera lens wet, didn't you?
Post by: daminc on August 28, 2009, 08:14:20 PM
LOL, that was the flash reflecting off dust in the air.
Post by: 1Bad88tbird on August 28, 2009, 08:23:49 PM
Haha!! Okay that explains it.
Post by: FLSTCI71 on August 28, 2009, 08:59:13 PM
Looking great!! Are you using plastic to cover things temporary and then using paper for the final tape off? I am asking because I found out the hard way - If you get overspray on the plastic and then flex it during painting, the overspray will flake off and stick all over the car. It can get really nasty in a big hurry. Not trying to be a know-it-all, just sharing some of my (bad) experience.
Post by: daminc on August 28, 2009, 09:06:19 PM
I use plastic for a quick cover. I also found out the hard way when I was 18. I covered the wheels with plastic trash bags for the primer, but didn't change them when I did the final paint. LOL If you could imagine gloss black, with flecks of light grey primer on it.....oooops
Post by: mcford on August 29, 2009, 08:24:56 PM
WOW! Nice work and incredible project!! when dose it get color? and what color will it be?
Post by: daminc on August 29, 2009, 11:35:39 PM
Thanks, I'll be getting it ready for paint when I come back from Cape Cod in a couple of weeks. I'm going for black this time. this same black (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5767.jpg)
and the trim is getting blacked out like this. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5659.jpg)
Post by: Kitz Kat on August 31, 2009, 06:02:27 PM
Don't go finding a new putty cat this year. You should of stayed and finished it before you take a vacation!!, Have some fun!
Post by: daminc on August 31, 2009, 07:37:42 PM
I don't have a problem finding them, as long as someone else buys them.
Todays progress pic. Slow but sure (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_5945.jpg)
Post by: daminc on September 15, 2009, 08:09:17 PM
Progress report................ This just in...................... Still sanding the drivers side. That is all.................... Have a good day.
Post by: 1Bad88tbird on September 15, 2009, 10:11:41 PM
Haha!! Short and sweet!
Post by: Masejoer on September 15, 2009, 10:24:44 PM
I hope your paint goes better than mine did. I have to start over and pull it all off again. Urethane 1 - heavily modified garage paint booth 0. It just may have been the cleaning chemicals though. 6 months later it was still pushing out on the hood. It was a nightmare after seeing the paint go on perfect and staying perfect until leaving the booth, only to come back with texture everywhere.
Post by: thunderjet302 on September 16, 2009, 04:16:41 PM
Come on hurry up and finish it's almost winter ;)
Post by: daminc on September 16, 2009, 06:30:34 PM
Quote from: Seek;291396
I hate that. That usually happens with to little flash time, and to heavy of a coat. Had that happen to a $3000 guitar I custom painted for someone.
Did it have a cracked looking effect on it?
Post by: Precipus on October 08, 2009, 10:16:05 PM
WHOA! Dunno if you remember my name. I am the guy with the Black Magic over @ FEP. We swapped some info on sub-frame connectors and I finally found your project over here, and boy howdy and I am glad I did! Besides the insanity part of recovering this rust bucket you have done a bang up job on every step!
Anyways I registered here just to comment on this I was so floored! I am about half way through with my custom sub-frame connectors based off of your idea, and I must say I am very pleased with them, however I am not impressed with my abilities to weld this micro thin floor pans..YUK! Amazing work you have done here and what i would say is a relatively short time.
quick question. I realize I need to bring something over from my connectors to the second bolt spot for the seats, but sort of stumped on how this should be accomplished....if ya get a sec hop back over there and take a gander would ya?
Post by: Chooglin on November 13, 2009, 04:15:24 PM
this thread has been idle for to long.
Post by: daminc on November 14, 2009, 12:24:36 AM
So I guess I'll give everybody an update on the lack of progress.............
I've worked out a deal for another rust-free trunk lid, and possibly some fenders for the vert. Since labor day, things got really busy at work. In that time, my grandfather passed away at the young age of 90, and I have been repairing things around the house for my grandmother since then. (also 90) And then people started calling me for more work on top of what I had already. it's been a busy 2 months with everything that has happened, on top of finishing the new shop. (insulation and drywall are this weekend). But all is not lost. I'm waiting for my brand new p heads to get shipped, and a few more tidbits for the rest of the car. also got quads for the rear. (Both cars) I probably won't be working on the car until December. The work and painting isn't a worry since the shop is heated.
I also got misc. replacement parts for the vert..... trim, mouldings, Chrome...... that sort of thing.
I'm also going to be in search of a cam in a few weeks. Not sure which one I'm going with yet, but possibly a stage I and some forged pistons.
So that's what has been happening since labor day. Oh yea, I went to Cape Cod for 9 days too. I'll post some pics of the shop after the drywall is up tomorrow.
Jerry
Post by: ZondaC12 on November 14, 2009, 12:44:04 AM
Sounds good man! Except for the loss, sorry to hear that! But other than that you got everything squared away anyway, nothin but a matter of time. Gonna be a helluva day when that thing rolls out all revamped....
Post by: croga001 on November 14, 2009, 04:00:22 AM
yea i have been following and cant wait to see it painted. sorry about your loss my thoughts are with you and your family
Post by: 1Bad88tbird on November 14, 2009, 07:52:33 AM
Sorry for your loss. Glad to see your shop is comming along, it's nice you have a heated garage to work in.
Post by: Chooglin on November 14, 2009, 04:12:48 PM
Also sorry for your loss.
I was just curious as to where this project was at.I always look forward to coming home from work and checking up on your progress.
Post by: daminc on November 14, 2009, 09:36:24 PM
Thanks guys
Here's some of the new shop. New breaker box. Bigger is always better. ;) (http://i233.photobucket.com/albums/ee79/daminc/our%20house/Garage%20addition/IMG_6043.jpg)
Post by: Chooglin on November 15, 2009, 05:19:55 PM
ok,thats better.......lol.
Post by: daminc on November 15, 2009, 05:22:07 PM
The walls were taller the 8'. It's easier to finish the drywall in the center, then the top or bottom.
Post by: Chooglin on November 15, 2009, 08:57:52 PM
gotcha.............that makes sense.
Post by: baxo on November 16, 2009, 08:12:16 AM
Lookin' good dude! lookin' reaal good!
Post by: 88CougarGT on November 16, 2009, 09:40:27 AM
drool.. Everyday I dream about building a shop like that. I'm so sick of suburbia and need to move back to rural Michigan. Awesome shop...can I just come visit and just daydream in it?
Post by: HAVI on November 16, 2009, 11:07:47 AM
Is that foil faced hard insulation in the ceiling? How was it laying it out? Did you cut it out around each rafter?
BTW, sorry about your grandfather....I lost mine recently, too.
Post by: daminc on November 16, 2009, 06:07:07 PM
Quote from: HAVI;299072
Thanks Scott,
No, I put plywood on top of the ceiling joists for storage, but before I did that, I put a foil radiant barrier on the underside of the plywood. I have to finish the ends still, and there will be an insulated suspended ceiling about an inch below the joists to cover everything.
Post by: Kitz Kat on November 20, 2009, 01:50:35 PM
Looking good, is one goin to be a spray booth ? If so I'm taking time off this winter with the cat to visit.
Post by: daminc on November 20, 2009, 07:37:40 PM
I'm going to make it so I can divide 1 bay with a movable plastic wall and movable wall lighting, and I scored a nice exhaust fan with an exterior motor on a pulley. You may want to visit it. lol
Post by: Cougar8775 on November 20, 2009, 11:20:23 PM
hell i may just visit it next weekend if you are not buisy jerry.
Post by: daminc on November 22, 2009, 09:33:03 AM
I'll be working on it. gotta get the heat runs in. Stop by and get your snow tires if your going to your parents for Thanksgiving.
Post by: daminc on November 22, 2009, 05:29:16 PM
So I pulled out another stock hood today. I think I'm going to make myself a custom hood this winter. but not sure what kind yet. And I'm not sure what car it's going on either.
Post by: Cougar8775 on November 23, 2009, 12:25:53 AM
yeah i plan on it. got my new dd up and running again. (replaced trans) but i will be up there on friday so if i stay pver i can come up sat to get those and help ya out if ya need it.
Post by: daminc on November 29, 2009, 11:22:07 PM
did some putting away. One step closer to getting back to work on the car. Here I pushed the vert next to the wall so I can get the Lincoln in for the winter. I'll probably pull it out again to drive it before it gets put away until spring. Thinking about putting some plastic down on the floor when I do. I'll paint the entire floor next summer. Can't believe how big it is in there when it's empty. (http://i233.photobucket.com/albums/ee79/daminc/85%20Vert/IMG_6084.jpg)
And while I had the 87 pushed to the other side of the garage, I decided to take a pic of it. I never really could step back and look at this side while working on it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6085.jpg)
So I figure 1, maybe 2 weekends at the most before I can resume what I had started. And yes, It's really clean in there now. All the stuff for work is now gone, and now the garage is just for cars. I can get all 3 in, and I still have an entire cabinet shop on the new side. That's my update. Also have some new presents for my car for Christmas. I'll share as they arrive. :D
Post by: thunderjet302 on November 30, 2009, 07:00:30 PM
I need a bigger garage :D
Post by: Thunder Chicken on November 30, 2009, 07:41:08 PM
Jerry, that's some cowl hood on that '87...
Post by: ZondaC12 on November 30, 2009, 09:33:20 PM
Yea seriously!! You'd better be putting a tunnel ram'd 514 in there or something....:rollin:
Post by: daminc on November 30, 2009, 10:12:16 PM
I guess we'll just have to see what's going in there now. ;)
Post by: ProTouring442 on December 01, 2009, 06:59:08 AM
I'm jealous! I've been cleaning in the garage too, but for a very different reason. We've been cleaning and packing all of our "extra" stuff to ready the house to go on the market in January.
Shiny Side Up! Bill
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: HAVI on December 01, 2009, 09:45:46 AM
Jerry, anytime you want to come over and build a garage for me, I'll make sure to keep it clean. Then I can play this "see what's going in there" game, too. LOL. BTW, I cleared a spot for it already.
Post by: Kitz Kat on December 01, 2009, 04:25:59 PM
I'm jealous, and you got heat.
Post by: daminc on December 01, 2009, 06:36:55 PM
I've been working 25 years to get to his point.. and finally made it to a heated shop. Now it's gonna take another 25 years to pay it off. lol
So anyway... I got some stuff for my 87 today. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_6096.jpg).
You guessed it. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_6097.jpg)
My Christmas present to my car. Just thought I would share
Post by: mercury-man on December 01, 2009, 08:25:58 PM
Sweet Jerry !!!
Post by: vinnietbird on December 01, 2009, 08:58:43 PM
Sweet A$$ Sweet !!!!! Parts are on the way to you.All you need are valves now.Unless you're going with roller rockers,yours from the current heads will work fine.Once I get my engine installed,I'll let you know about plug wire and header fitment.My GT40P heads looked that clean when I took the engine apart.The vehicle had 30,xxx miles,but I truly believe the engine was a new replacement.
Those heads are so nice I had to go back and look at the pics three times.Maybe for after I post this.LOL.Congrats !!!!! If you need anything,I'll do my best for you per our contract agreement.LOL.
Post by: Cougar8775 on December 03, 2009, 12:16:17 PM
hey now whats that dart gonna be used for? :hick:
But nice heads! LOL
Post by: daminc on December 03, 2009, 04:50:33 PM
LOL. that's all that caught your eye wasn't it. If you came over, we could've had a beer and tossed some darts in the shop. It's not all about work in there. It's more like a resort now. just wait until the shuffleboard area gets going. :D
Post by: Cougar8775 on December 04, 2009, 01:29:04 PM
yeah ill shoot for when im up there again.
Post by: Kitz Kat on December 04, 2009, 03:05:21 PM
Why new bareless p's?
Post by: thunderjet302 on December 04, 2009, 04:05:18 PM
I was going to run iron GT40s on my combo but I got a sweet deal on a set of brand new GT40Ps just like you have. They set me back a whole $250:D
Post by: 347Thunder on December 04, 2009, 05:40:05 PM
would you finish this darn car you topic w!!!:shakeass::punchballs::mullet: looking good;)
Post by: daminc on December 04, 2009, 05:50:26 PM
Quote from: Kitz Kat;301147
Couldn't pass up $200 for them.
Post by: daminc on December 06, 2009, 04:08:27 PM
Next weekend I'll be back to working on the car. Been a long time since I touched it. (week before labor day)
Here's the last of the shop pics that I've been working on. I just need to make doors for the cabinets, and a roll-able cabinet for my CNC. But that will happen as it happens.
Here's the plan for next week. I need to work on the door jambs, the lower quarters, and the rockers. As you remember, I did a lot of welding in this area, and it needs to look perfect when you open the doors.
I did some filling, but it needs a little more before primer (http://i233.photobucket.com/albums/ee79/daminc/our%20house/shop/IMG_6116.jpg)
The lower quarters need flattening too. they're almost there now. (http://i233.photobucket.com/albums/ee79/daminc/our%20house/shop/IMG_6115.jpg)
Now that the bulk of the filling and straightening is done, I can start the guide coat and the finish flattening. I'll try to take pics, but I don't think you will really see a difference from 1 pic to the other until the primer goes on. I'll see everyone next weekend.
Post by: thunderjet302 on December 07, 2009, 11:31:45 AM
My you have a big garage:D
Post by: daboss351 on December 07, 2009, 11:55:43 AM
WOW this thread has GROWN since ive been gone!! Glad to see your still going on this thing!!! and I like the 85 vert, nice buy!! I still got the jig for the subframes, im making a set for my dads tbird!
Post by: daminc on December 07, 2009, 08:14:51 PM
Holy , I thought you fell off the map.
You missed a lot since you left. stick around and see the end of the project...... and the start of the next....... ;)
Post by: daboss351 on December 08, 2009, 07:22:40 AM
I did fall. I fell from RI to PA haha. And hell yea I'm glad your still going!! I want that vert though thats not fair!
Post by: daminc on December 10, 2009, 07:00:04 PM
So here's the last piece of my Cougar. finally, after 2 years of searching, I got my trunk lid. and some extra fenders for the vert.
I know that I already repaired the old lid for my car. but I have an idea for a cool mod that I want to do. I also want the original look of my car, so that's the reason for getting another lid. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_6124.jpg)
And the extra fenders for the vert. the pass. side of the car is pushed in where the door and fender meet. This will make the repair a lot easier when I do that car.
I originally thought I would be able to work on the car all weekend, but a good friend of the family lost his battle with cancer this week. The funeral is Saturday, so it looks as though I'll be down to working on it on sunday only. I'll keep everyone updated with the progress report on Sunday night.
And another thanks to Haystack who found me some fenders to send along with the trunk lid.
Post by: daboss351 on December 11, 2009, 01:34:48 PM
I know the feeling. I just lost my great grandmother, and to top it off I cant attend the funeral cause ill miss class and get kicked out. Isn't that a kicker?? 3rd relative in the 3 months ive been here to pass away, 2nd funeral I have to miss because of school...
Glad your getting close to the car you want out of that thing man!!
Post by: daminc on December 12, 2009, 06:12:31 PM
Did some work this afternoon Also found another use for the hard drive magnets. lol (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6128.jpg)
Not sure if it will look like any progress in these pics, but here they are in order of my day. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6130.jpg)
Post by: Beau on December 12, 2009, 06:45:20 PM
Lookin' good :D
Wish I had a heated shop with a concrete floor...some day...;)
Post by: daminc on December 13, 2009, 05:31:51 PM
Today's progress....... got the drivers side and trunk lid in epoxy primer. There's a bit of a mist in the shop when I took the pics, but you get the idea. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6154-1.jpg)
Post by: Chooglin on December 13, 2009, 05:34:28 PM
Now that has to excite you,it does me............looks great
Post by: daboss351 on December 13, 2009, 05:37:27 PM
F****** looks awesome!!! You wanna do my dads birds quarters?
Post by: daminc on December 13, 2009, 10:47:40 PM
Thanks, I primed it with black, to see the flatness of the panels. next they have to be 2k primed, and blocked again before paint....... but I have to tell you, up close they look pretty close to perfect already.. they just need a little here and there.
Post by: daminc on December 13, 2009, 10:51:40 PM
Quote from: daboss351;302375
The price of repairing 2 quarters would probably exceed the price of another rust-free bird. unless you did it yourself. then it would be close to the same price.
Post by: daboss351 on December 13, 2009, 10:53:32 PM
they are NOT bad at all, only right along the bottom edge is bad, and idk i its even all the way through they seem solid
Post by: vinnietbird on December 13, 2009, 10:57:44 PM
She live....sheeee liiiiiives !!!!!!!!!!!!!!!!!!!!!!!
Post by: daminc on December 13, 2009, 10:57:48 PM
I bet they're rusting from the inside out, between the inner and outer wheel wells, or inner and outer 1/4 panels.
Post by: daminc on December 13, 2009, 10:59:03 PM
Quote from: vinnietbird;302433
Idk.... Looks funny all 1 color.
Post by: daboss351 on December 13, 2009, 11:04:07 PM
i agree it looks weird one color!! and idk ill find out, im getting it fix pretty much for freeeee gotta love tech college!
Post by: vinnietbird on December 13, 2009, 11:50:57 PM
Quote from: daminc;302435
That's what I thought after the Sport was green,red,blue,gray,white,and gold for nearly 2 years.I've learned to live with one color.LOL.It did take a while,and to be honest,I missed it the "Old" way for a while.
Post by: 50tbrd88 on December 14, 2009, 08:36:02 AM
Lookin' good! You are gettin there!
Post by: thunderjet302 on December 15, 2009, 11:02:11 AM
It's looking good.
It's going to look kick ass when you get the wire wheel covers on it! ;)
Post by: Chuck W on December 15, 2009, 11:13:04 AM
Everytime I see that 'Vert with the Cobra wheels on it...I have to readjust myself.
Glad to see the '87 coming along so nicely.
Post by: daboss351 on December 15, 2009, 12:31:42 PM
Quote from: Chuck W;302670
I have to agree!
Post by: V8Demon on December 15, 2009, 01:07:09 PM
There is no better Ford made wheel for these cars.
Post by: Kitz Kat on December 15, 2009, 04:43:07 PM
You painting black over black shiny primer? Never seen primer that shiny.
Post by: daminc on December 15, 2009, 06:36:58 PM
Quote from: Kitz Kat;302698
It has to be either painted within the 48 hr window for a chemical bond, or it has to be sanded with 180 after the 48 hr window for a mechanical bond.
It was still wet when I took the pic. I't's more of a semi-gloss now. and feels like liquid steel.
The 2k primer that goes on next also has to be blocked flat before the paint. I'll do that after New Years.. Going to get the hood and pass side epoxied this weekend hopefully. I had to do this, because every time I sand the car. I keep going down to the metal in huge areas, and have to keep priming it so it won't flash rust. So I said hell with that, and put the epoxy on it. It's almost perfectly flat now anyway.
Post by: daminc on December 15, 2009, 06:41:28 PM
Quote from: V8Demon;302684
I have to agree. Every time I go in the garage and see them, I actually stop for a minute and stare at them on the car. I hope the turbines I have for the 87 don't look like next to these. :hick:
Post by: 50tbrd88 on December 15, 2009, 06:52:07 PM
Quote from: daminc;302707
I doubt it...turbines looks good too. Its just a different kinda good. Like a "hey I'm from the 80's and proud of it" good. :D
Post by: croga001 on December 16, 2009, 11:53:09 PM
one color! im jelous now. its going to be a long time before my bird leaves the garage again and now my dad has one too. its cool to see two birds in the garage. idk if he likes his truck living outside with the snow and all but i think in the end it will be worth it. keep it up!
Post by: daminc on December 17, 2009, 07:58:47 AM
Ok, I have to admit that it was weird seeing it one color all of a sudden, and black on top of it all. Took a few days to adjust to the color change since I only saw the car white for the last 20 years. The freaking out about the body work being good enough for black paint is also over too. That has been on my mind since I cut the first quarter panel off and welded a 40" seam across the side of it, in plain sight. :hick:
So now the push is on. I plan on getting the rest of the car primed by Monday. Then I need to work on the fenders, and prime them.
Post by: daminc on December 18, 2009, 05:41:10 PM
Today's progress. Worked on this for a bit today. (http://i233.photobucket.com/albums/ee79/daminc/fenders/IMG_6183.jpg)
I ground the rust off the back side and forgot to get a pic. then I started removing the paint and large patch of filler that didn't seem to be needed at all. figured I had an hour to kill and attacked the fender. Tomorrow, I'll be doing another pass on the passenger side of the car with 180 grit, to get it ready for a coat of primer.
Post by: dominator on December 18, 2009, 11:27:05 PM
Jerry,remove the lower section of that brace on the mid part of the fender(the one that's all rusted) and leave it off. Did that to my two fenders years ago. It's where all the dirt collects over the years and then turns to mud which rotts out the fender from the inside. You won't be able to clean out the rust undernieth it if you don't and i'd hate to see it rot through after the car is painted. Just a word of thought for ya.
Post by: daminc on December 19, 2009, 08:03:08 AM
Thanks, I was actually thinking the same thing. you wouldn't believe the that came out of there. well, maybe you would. That's exactly where all the fenders rot out. And also where the mud flaps are screwed on. I was also going to cut the end brace at the bottom too, and get some rust treatment in there. But as with all my cars, past and present, I always keep extra panels around. I got extra fenders, doors, hoods, header panels, and 1 trunk lid for this car. Along with the entire car wiring front to back, and heating and cooling box behind the dash. steering column, and dash parts too. This car will live on forever. lol
Post by: vinnietbird on December 19, 2009, 08:33:01 AM
When I installed me replacement front fenders,they were also loaded with years of collected dirt and misc. .No rust though.Finding front fenders with no bends and dents was the hard part.Luckily a guy with a complete parts car told me that I could have anything I wanted off of it if I would swap the heater core in his Stang.Not a problem.I made out like a bandit on that deal.That was over a year ago.I need another deal like that.
Jerry,nice work.Maybe you can have the car painted by the time you go to bed tonight.
By the way,look at us "old guys".Up before the butt crack of dawn,and to me I slept late.LOL.
Post by: daminc on December 19, 2009, 05:49:58 PM
todays fun. boarding before the primer. lots of fun (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6190.jpg) and my cool CNC cart (http://i233.photobucket.com/albums/ee79/daminc/our%20house/shop/IMG_6187.jpg)
and more shop lights. (http://i233.photobucket.com/albums/ee79/daminc/our%20house/shop/IMG_6188.jpg)
Post by: daminc on December 19, 2009, 05:55:07 PM
also took a pic of the engine compartment without the glare blinding flash of the camera. there's some dust on it though. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6192.jpg)
Post by: vinnietbird on December 19, 2009, 07:26:02 PM
Do I see a Mass Air plug?
Post by: daminc on December 19, 2009, 09:18:16 PM
Quote from: vinnietbird;303195
maybe.........
I'll put it on after the motor is running and going good. I still don't have a computer for it yet
Post by: dominator on December 20, 2009, 12:12:31 AM
Believe me, i know the that lurks behind that upper brace lol. I cut mine off about 4-5" from the fender lip with a dremel and removed the piece as it is only held on with foamy glue/1 spot weld.
Post by: daminc on December 20, 2009, 07:01:27 PM
Had some fun today. Primed the other side, and hood. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6210.jpg)
next up.... are the front fenders. Then everything will be at the same stage of the project.
Post by: Chooglin on December 20, 2009, 07:11:58 PM
looking good Jerry!!!!
It's nice to see the wife get involved in this.
Post by: daminc on December 20, 2009, 07:59:24 PM
I'm pleased to say, that this thread has just passed 40,000 views.
Post by: daminc on December 20, 2009, 08:57:25 PM
Also hit the 2 year rebuild mark this week
Post by: vinnietbird on December 20, 2009, 09:10:36 PM
Be careful when you're priming.You're going to mess up those fine looking wheels and tires.LOL.
Post by: daminc on December 20, 2009, 09:17:50 PM
There's only 5,000 miles on those tires. unfortunately I bought them in 94
Post by: Beau on December 21, 2009, 03:18:39 AM
Very very nice man. :D
Someday, it'd be really neat to come up your way, stop by for a visit, maybe even a beer or two...but I want to sleep in your garage. I can provide my own cot and blanket. lol :rollin:
I really wish I had the skills to do that kind of work to my car..;)
Post by: 1WLD BRD on December 21, 2009, 08:17:32 AM
WOW... looking good buddy. very cool that the wife has a hand in it too.
Post by: baxo on December 21, 2009, 08:38:14 AM
That's awesome man!
Post by: Cougar8775 on December 21, 2009, 09:56:47 AM
hey look a pic of you doing the work. lol but its comming together nicely. wish mine would.
Post by: daminc on December 21, 2009, 10:23:45 AM
See, it's really me doing the work.
Post by: thunderjet302 on December 21, 2009, 12:00:23 PM
Looking good.
Maybe you'll get to drive it this summer ;)
Post by: 1Bad88tbird on December 21, 2009, 12:17:00 PM
This things come a long way! I can't wait to see pics of it shining out in the sun!!!
Post by: maandy on December 21, 2009, 12:22:30 PM
So good to look that somebody´s project is movin on. That´s a really nice job you have done there. I´m happy for you cause I think if my project is so far someday I will sit in the garage with cup of coffe in my hand and just watch how nice the car is and think what I will do tomorrow. :D ok, was it too much carguy talk or what ?
Post by: daminc on December 21, 2009, 12:24:21 PM
I sit and look at it too. :D
Post by: baxo on December 21, 2009, 12:33:09 PM
I think everyone does that, whoever is proud of their work. Whether it's a car or not. You've got do be proud of your accomplishments!
Post by: maandy on December 21, 2009, 12:35:11 PM
atleast I´m not the only one who thinks that way :D deem I wanna sit and look too so I´m going to drag my ass to the garage more often :D
Post by: Kitz Kat on December 21, 2009, 03:11:33 PM
Quote from: FordTruckFreeek;303373
He didn't even offer me a beer when I went there!! lol.
Post by: daminc on December 21, 2009, 04:17:51 PM
Quote from: Kitz Kat;303437
You were on your way to Canada. Didn't want them to have a reason to strip search you. lol
Post by: Kitz Kat on December 21, 2009, 04:33:47 PM
That border is a little messed up, Like it cost me how much to make a y-turn, without ID.
Post by: daminc on December 21, 2009, 04:43:03 PM
$4.50 I think
Post by: Kitz Kat on December 21, 2009, 04:52:29 PM
I really don't remember, , But I switched country's in a hurry. By the way I did get searched coming back in. I really don't think the border guards from both sides get along.
Post by: daminc on December 21, 2009, 05:05:16 PM
No, not at all from what I've seen. I can ask someone I know though
Post by: PJsKitty on December 21, 2009, 09:35:02 PM
You make me want to restore mine, it looks great compared to yours, only I don't have the know how. I would have to pay someone that is my problem.
Post by: daminc on December 21, 2009, 10:19:51 PM
No one has the "know how" until they know how. (My words of wisdom for the year. lol) The first car I did, I researched and asked people, then dove right in. Today with the knowledge on the internet, you could learn how to spit atoms if you wanted. Your car would take very little time to fix up even not knowing how to do them from the start. That's why were all here. to learn and help each other. If you have the ambition to learn to do it. it will happen
Post by: 1WLD BRD on December 22, 2009, 02:45:26 AM
Quote from: baxo;303421
so get off yer ass and get to work on the Vert..... :D
Post by: vinnietbird on December 22, 2009, 07:03:50 AM
I agree.After I wash the Sport,I like to just sit back and look at it,and I always think to myself "I built that myself",then I think about all of the thought and effort that went into it.It feels really good.And to think,it was two days from the crusher.
Post by: daminc on December 22, 2009, 08:51:49 AM
Well said.
Post by: baxo on December 22, 2009, 09:56:35 AM
Quote from: 1WLD BRD;303518
Oh trust me, I would love to, I'm dying to! But I have a house to finish first haha.
Post by: HAVI on December 22, 2009, 12:03:03 PM
Yeah, I mean, why does a house have to get in the way of important projects?
Post by: baxo on December 22, 2009, 02:07:56 PM
Haha well it had important reasons but those reasons no longer exist but since I'm not a quitter i decided to finish the house.
Post by: Chooglin on December 22, 2009, 04:34:10 PM
Quote from: daminc;303500
who "SPITS" atoms,I have heard of splitting atoms,but never spitting them............................lol.
Post by: daminc on December 22, 2009, 04:44:12 PM
Quote from: Chooglin;303578
I guess spellchecker doesn't correct stupidity, just spelling.... :rollin:
Post by: daminc on December 22, 2009, 05:45:12 PM
Ok, I had to put them back on. Looks a lot better now. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6240.jpg)
Post by: 50tbrd88 on December 22, 2009, 07:16:12 PM
Oh OK, that's how you get the energy to keep pluggin away on this thing...lots of PEPSI!!! lol. So you are going with turbines for wheels right?
Post by: Blck85TBirdV8 on December 29, 2009, 12:51:41 AM
You should submit this into a magazine when it's all completed. Very good work so far. Keep it up!
Post by: Cougar8775 on December 29, 2009, 11:17:45 AM
so have you asked for the cars forgiveness for cutting it up and replacing almost every square inch of metal?
Post by: daminc on December 29, 2009, 04:42:45 PM
No, I figured I gave it a 2nd chance in life
Post by: daminc on December 29, 2009, 05:39:07 PM
Dropped the heads off at the machine shop today. next week the motor will get torn down. seems to be a block from a truck with standard output stuff on it. possibly from a van. I just noticed that the oil dip stick is facing sideways pointing towards the front of the motor.
Post by: vinnietbird on December 29, 2009, 06:05:35 PM
Pic of the dip stick.They are supposed to be curved towards the front.
Post by: daminc on December 29, 2009, 06:18:46 PM
The one on the 85 doesn't have that much forward bend to it. I remember my 88 E-250 pulled out forward like that
Nope that's factory on 5.0 EFI T-birds and Cougars. Mine looks just like that but bent slightly to clear the GT40P headers.
Post by: daminc on December 29, 2009, 06:39:36 PM
Wow, thats just crazy then. lol
Post by: vinnietbird on December 29, 2009, 06:45:15 PM
It could've been swapped from the old engine as well.
Post by: Kitz Kat on December 31, 2009, 11:48:33 AM
May have missed it, but is it a roller block?
Post by: daminc on December 31, 2009, 11:54:05 AM
That will be next weeks surprise. We should place bets
Post by: vinnietbird on December 31, 2009, 12:43:42 PM
I'll bet a dollar it IS a roller engine.Now,no more delays,pull the intake !!!! It'll take you 5 minutes.C'mon,you know you are curious as well Jerry.
Post by: daminc on December 31, 2009, 01:00:55 PM
I am, really...... But 'm taking from today till Monday off to do nothing. I haven't had 5 min to do nothing since labor day. I'm just watching TV and surfing the net. (and snacking) I even got a new set of duro-blocks for the sanding on the car, but it will wait until next week.
I vote........ That I don't really know what a roller engine is.....lol
Post by: vinnietbird on December 31, 2009, 01:54:12 PM
OOOOOH,I see how it is.It's ALLLLLL about you.O.K.....Alright....Yeah...I see......"Jerry needs "me time"....O.K......LOL.LOL.
Seriously though...A roller engine will have roller lifters when you pull the intake.You'll know immediately when you see the retainer bolted (two 10mm bolts) in the center of the valley holding down 8 "dog bones" which keep the lifters from turning,because the lifter's wheels have to stay in line with the cam.If you pull the intake and see nothing but block,no roller.Yes parts bolted down...roller.
Post by: daminc on December 31, 2009, 02:36:49 PM
Ok, I'll have to learn how to take the intake off first. I'm not the one taking it apart or putting it back together anyway.... Aren't you glad.. lol
Post by: Cougar8775 on January 01, 2010, 12:38:57 PM
lol looks like im gonna have to make a trip up to rebuild your engine huh lol
Post by: vinnietbird on January 01, 2010, 04:38:59 PM
Taking it apart is easy.If you see a fastener,remove it.Keep repeating that process until there are no more fasteners.
Post by: daminc on January 01, 2010, 05:09:31 PM
I'll give that a try on monday. I have a wrench
Post by: vinnietbird on January 01, 2010, 05:30:40 PM
Those are the easiest instructions I could give.LOL.I always bag and tag everything.Are you using the Explorer intake?What headers and other bits are planned?
Post by: daminc on January 01, 2010, 05:36:17 PM
Depends on the bits you have for me. lol
Yes explorer intake. Not sure if the headers I have will work yet, but that's not a big deal right now.
Post by: vinnietbird on January 01, 2010, 05:40:21 PM
Which headers do you have?
Post by: daminc on January 01, 2010, 06:52:33 PM
no Idea
Post by: Kitz Kat on January 02, 2010, 09:49:05 AM
I still have the engine from mine if you need it. It's missing the cam and lifters, sold to somebody here. It ran great 111,000 miles on it, but it is an SO.
Post by: jcassity on January 02, 2010, 11:51:38 AM
my spell checker has never worked on here says i need to download iespell checker.
Post by: daminc on January 02, 2010, 12:29:01 PM
Quote from: Kitz Kat;304837
I'm forging ahead with this one, We'll see if the shop say's it checks out good for a rebuild. if it doesn't. I'll be over to get it. ;) who knows. Maybe I'll rebuild it for the vert so I don't have to be without a motor in it. still have a set of E-7s and a stock HO intake and cam. We'll have to talk about that.
Post by: daminc on January 02, 2010, 12:30:41 PM
Quote from: jcassity;304844
Mine is built into my Mac. :D works in any app, all the time.
Post by: daminc on January 05, 2010, 02:56:33 PM
Today's fun. If you don't take something apart, you can't put it together. (more words of wisdom. lol)
Post by: EricCoolCats on January 05, 2010, 03:04:07 PM
Mmmm...it looks all...engine-y...
Post by: Beau on January 05, 2010, 03:08:18 PM
All hail the engine-ness!
Looks pretty good, is that the original from the '87?
Post by: daminc on January 05, 2010, 03:10:38 PM
Don't really know, I can't locate the Ser.#s on it.
Post by: vinnietbird on January 05, 2010, 04:58:05 PM
XXX block.Like mine (current engine and the one in the garage).Nice roller motor.Good to go.
Post by: Kitz Kat on January 05, 2010, 05:22:16 PM
Oh boy a real flat top. But a roller. Save that pic so everyone knows what a flat top is.
Post by: Kitz Kat on January 05, 2010, 05:50:39 PM
You can tell it was sitting for a while. You really love the old stuff! lol
Post by: daminc on January 05, 2010, 07:19:39 PM
Yea, it didn't get a lot of use for the last year, did it.. And my stuff is as old as everyone else's stuff. :D
And yes, they are pretty flat on top. lol
So not to be a dumb ass.... What makes this a roller block? I searched for pictures all over the net to show me the difference, And I didn't find one pic that showed anything. A lot of talk about them but, no pics.
I'm also going to take as many pics as I can while it's going back together, to help anyone that needs to see what goes into rebuilding a motor.
Post by: V8Demon on January 06, 2010, 12:27:58 AM
The spider hold down in the valley is the #1 indicator along with the "XXX" stamping. That appears to be the original block to the car. The lifter dogbones are a dead giveaway as well.
Looks like you got yourself two boat anchor E6 heads as well. :hick:
Post by: daminc on January 06, 2010, 08:09:52 AM
I read somewhere that the xxx is the location where they were manufactured, as some people said they had non-roller blocks and the xxx on it. YYY blocks were said to be manufactured in Mexico with a higher iron content compared to the XXX blocks. I don't know if there's any real truth to that though. I'm going to keep searching for the real answer, be it location, or block type. I notice there's a lot of bad information out there about Mustangs, motors and modding. It's tough to know what to believe sometimes.
Does anyone have a pic of a non-roller motor? It would go good in this section of the project thread, as a comparison of the 2
Post by: daminc on January 06, 2010, 08:12:24 AM
Quote from: V8Demon;305281
I was just looking for a door stop too.
Post by: 88CougarGT on January 06, 2010, 09:41:36 AM
Left is a roller lifter - which makes it a roller block. Right is a flat tappet lifter - which would make it a non-roller block.
Roller blocks typically have the top of the lifter bores machined flat for the dogbones to sit. The dogbones and the spider keep the roller lifters in alignment with the cam.
Post by: daminc on January 06, 2010, 09:58:00 AM
Does anyone have a pic of the non-roller block?
Post by: Kitz Kat on January 06, 2010, 05:11:35 PM
Quote from: daminc;305300
Not on hand with an intake off, but like said the the dog bones are on it ,that makes it a roller. There would be less lifter bore on a non roller. Just build it, Quit stalling!!
Post by: 88CougarGT on January 06, 2010, 06:16:49 PM
A quick googling and presto:
Post by: daminc on January 06, 2010, 09:25:41 PM
Cool, thanks.. I've been googling that for about 5 days now with no picture results. .......On with the project.
Post by: thunderjet302 on January 07, 2010, 12:08:05 AM
Good it's a roller. Just bore it .030 over, stick some good pistons in, and you'll be good to go:D
Post by: Kitz Kat on January 10, 2010, 12:58:42 PM
You need this.Sell the rest. http://www.foxtbirdcougarforums.com/showthread.php?t=26107
Post by: daminc on January 10, 2010, 04:22:25 PM
Update I've been degunking the motor.. That's all I got (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6330.jpg)
I tried to get a pic of the crosshatch in the cylinders. but my camera really sucks. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6333.jpg)
Post by: dominator on January 10, 2010, 08:18:55 PM
You know what, they all seem to have that regardless of the mileage,don't know why.
Post by: 1Bad88tbird on January 10, 2010, 10:17:53 PM
I would imagine they would be the same as the big three cylinder air compressure motors from locomotives I used to tear down. But I think the cross hatching is a factory marking from them being machined. I know if a cylinder had it it was still in good shape. But if it was worn off it usually ment the piston or ring detoriated and sed them off. So I would think you'd want to see that on them. I'm not a mechanic or a machinist but I kinda learned that from experience.
Post by: Beau on January 10, 2010, 11:36:07 PM
Looks fit for another 100,000 miles to me ;)
Post by: vinnietbird on January 11, 2010, 06:54:45 AM
Looks good !!!
Post by: daminc on January 11, 2010, 08:32:49 AM
Does anyone know where to find the stamped ID # on a block?
Post by: el_cherenco on January 11, 2010, 10:07:57 PM
Hey very good !! well well well I'm also repairing my car, a bit of metal work until at last able to paint it
Good luck with your work. Greetings to all
Post by: daminc on January 11, 2010, 10:12:42 PM
Welcome, I feel privileged that this was your 1st post.
Post up some pics of your car
Post by: massCougarxr7 on January 13, 2010, 12:54:02 PM
better be careful jerry, that primer will grow on ya,......lol jk ,. lookin goood man,, thought itd be done by the time i got back on here!!
Post by: daminc on January 13, 2010, 05:45:19 PM
The vert, and building a shop slowed me down a little bit. but I'm in no hurry now that I have another cougar to drive around. It takes the pressure of wanting to cut corners to finish it.
Post by: daminc on January 14, 2010, 06:11:01 PM
Todays update Got the heads back from the shop today (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6337.jpg)
Post by: 88CougarGT on January 14, 2010, 06:38:36 PM
There's some serious stretch going on in your timing chain. Good thing your tearing it down, you would have had a hell of a time timing the engine.
Post by: daminc on January 14, 2010, 08:26:22 PM
Quote from: 88CougarGT;306306
I'll say..... I can almost take the chain of the gear without pulling anything apart. :hick: No wonder this thing was running like a scared rabbit.
Post by: vinnietbird on January 14, 2010, 10:51:26 PM
So,what are the plans for the intake?
Post by: daminc on January 14, 2010, 10:55:25 PM
what do you mean?
Post by: vinnietbird on January 15, 2010, 01:17:09 AM
are you painting or polishing it?
Post by: daminc on January 15, 2010, 07:37:36 AM
Neither, I'm keeping it a satin finish. Then I'll satin clear coat it. All the aluminum will be done the same to match the silver paint that is under the hood. the motor will be black, and valve covers will either be stock covers painted black, or eventually I'll get some finned to match the intake. the grooves of the upper will be satin black to match the motor and the accessory brackets, hood hinges, and stuff like that. the top cover plate, depending on what I put on there will also be silver satin and black. which reminds me.... I need to find another one of those. this intake only has 2 holes for the cover to attach. The search for parts never ends..
Post by: vinnietbird on January 15, 2010, 08:05:24 AM
I made my own intake plate from a piece of s aluminum.It's smooth and polished.I like the look.I like your ideas for the engine.You should have it done by next Friday shouldn't you?LOL.
Here's mine.I have "Cobra" valve covers on it now (the new engine won't).Also,the small area where you can tell I cut off the little cable appendage on the finned part of the intake will be gone.I'll "re-fin" those little spots.The intake plate is somewhat visible.It took about 15 minutes to make,and about 30 minutes or so to polish.
Post by: daminc on January 15, 2010, 08:06:48 AM
depends on the chain cover. ;)
Post by: 1WLD BRD on January 15, 2010, 09:41:19 AM
Get an Explorer cover for it, I have one and loved it
Post by: vinnietbird on January 15, 2010, 10:18:24 AM
An Explorer timing cover will work?I didn't know that.Will a standard 5.0 water pump work or is it different for the Explorer.I didn't pay any attention when I pulled my Explorer engine apart.I MAY have an Explorer timing cover in the garage.
Post by: daminc on January 15, 2010, 10:20:26 AM
think he meant the intake cover....BTW I got the stud out of the chain cover. now I need to find some new ones.... Any ideas where to find some?
Post by: daminc on January 15, 2010, 10:21:49 AM
BTW. I'm typing this from the new shop... Now I need to set up the "Evolution Cam"
Post by: vinnietbird on January 15, 2010, 10:22:57 AM
What do you mean by "stud"?Is it a bolt with a built in nut and more threads for a nut to hold a bracket?
Post by: daminc on January 15, 2010, 10:37:45 AM
yes
Post by: vinnietbird on January 15, 2010, 10:41:21 AM
I have a few new ones (and a couple of nice used ones).I'll bag 'em and ship them to you along with the extra seals and gaskets I have from my Explorer engine assembly.
Post by: daminc on January 15, 2010, 11:59:22 AM
You the man
Post by: vinnietbird on January 15, 2010, 12:03:13 PM
I try to keep my end of the "agreement".LOL.
I'll let you know what I have in a little while so you don't buy things you may not need.
Post by: vinnietbird on January 15, 2010, 01:14:32 PM
I have the following to send you...
water pump gaskets the long water pump bolts you need (new) timing cover front seal
That's it so far.I've got to do some more looking around out there.
Post by: daminc on January 15, 2010, 05:16:35 PM
Today''s adventure started cleaning everything from the motor. first off, this is the long bolt. The other one snapped. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6349.jpg)
2nd...... since I'm not a redneck. this is my Polish parts washer. A left over laundry tub, a submersible pump, and a section of hose. it drains into a 5 gal bucket, and recirculates. enjoy (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6352.jpg)
and all my squeaky clean parts. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6353.jpg)
I seem to have a little rust on the oil pan. I thought it was all oil and gunk. guess not. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6355.jpg)
and the rest of the stuff that made it's way into my Polish parts washer. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6357.jpg)
and the rest of the parts to clean up. (http://i233.photobucket.com/albums/ee79/daminc/motor%20rebuild/IMG_6358.jpg)
Post by: vinnietbird on January 15, 2010, 05:50:23 PM
Nice start on the engine project.Remove that seal from the front cover.I'll be sending you a brand new one.Are you even cleaning all of the parts that you won't be using?Media blast....prime and paint...
On another note,I saw the starter in the bucket.Get a smaller high torque starter.They rock.I got a "new" reman starter off of an Explorer 5.0 and it has been great.Super easy to wire (just add one wire),and there you go.It also relieves the car of a lot of weight.
Post by: 88CougarGT on January 15, 2010, 06:08:26 PM
Being a fellow Pole, I'm interested in your parts washer. What pump did you use for the washer?
Iv'e been thinking of doing the same thing myself. I have a spare dishwasher pump that should work. Also, I planned to use a "clay sink" design. Basically a bucket within a bucket. The silt and junk drains into the inner bucket, then the water runs out over the top into the outer bucket. The pump sources from the bottom of the outer bucket. This way the heavy grime sinks to the bottom of the inner bucket helping to prolong the life of the pump.
Brake-clean has ruined about every pair of jeans I have.
Post by: daminc on January 15, 2010, 08:36:19 PM
Quote from: vinnietbird;306429
Just doing the parts I'm reusing. The starter is out of here. I can barely lift the stupid thing. lol
Post by: daminc on January 15, 2010, 08:39:52 PM
Quote from: 88CougarGT;306431
I used an extra pump I had for draining the pool cover in the old days. any submersible,or piped pump should work fine. your setup should work good.
Post by: ZondaC12 on January 15, 2010, 09:10:56 PM
Love the grocery store shelves. :rollin:
Post by: daminc on January 15, 2010, 09:40:01 PM
I got tons of them for nothing. They work great in a shop and you can easily change the shelf spacing. plus they hold several hundred lbs. a piece. they're a temporary thing while I'm working on the car. when it's all over, you will probably find them in baxo's garage.
Post by: thunderjet302 on January 15, 2010, 10:18:44 PM
Hey I'm part Polish and I...........would do the same thing;)
For the intake cover just use a 4 screw hole plate. Take the two extra screws, cut the threads off so you just have the top, and glue the tops onto the plate. Vola no one knows you are only holding the plate down with two screws.
BTW you should paint your engine and intake Ford blue;) (http://i198.photobucket.com/albums/aa33/thunderjet302/cantigny%202009/DSCN0984.jpg)
Post by: 88turbo on January 15, 2010, 10:34:55 PM
what are people using to attach their TV cables to the 65mm explorer Throttle bodies? I seem to be confused when it comes to that...
Post by: vinnietbird on January 16, 2010, 07:07:18 AM
The cables hook up exactly like the regular T-Bird/Stang throttle body. When installing an Explorer t-body,you remove the "lever" from the t-body shaft and replace it with the lever from the stock t-body.Everything hooks up the right way,and you have a bigger t-body.The EGR /t-body spacer needs to be opened up to 65mm as well,otherwise,what's the point?
Post by: daminc on January 16, 2010, 08:29:34 AM
Quote from: thunderjet302;306467
As much as I like the old Ford blue, I doesn't look right to me in the newer cars. If I had something a lot older that you could actually see the motor, I would. Black and silver is my theme for this car. mabe the next project will get the Ford blue treatment. I can actually see one side of the motor in the vert. ;) As for the intake and all the aluminum under the hood, I'm sticking with the natural color of the parts. Like the color of the timing chain cover. It's staying the color that it is.....just clean.
Post by: thunderjet302 on January 16, 2010, 12:37:42 PM
Have you thought about clear coating the natural aluminum to make it easier to clean? That would keep it from staining as easy.
Post by: thunderjet302 on January 16, 2010, 12:39:05 PM
Quote from: 88turbo;306469
I've got an Edelbrock 65mm TB since my intake didn't have a TB when I bought it.
Post by: Cougar8775 on January 16, 2010, 01:13:39 PM
ive found out that if you powder coat your parts its easier to clean. just hose em off and your done. Thats what im gonna do with mine. Also my engine block is ford blue :D
Post by: vinnietbird on January 16, 2010, 04:22:21 PM
My engine is the darker blue.I like it.It's all about what we want on our own cars.It's a reflection of ourselves.
I really didn't mean for that to sound so gay.
Post by: daminc on January 16, 2010, 07:57:25 PM
And here's the finished product. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6381.jpg)
Both fenders were stripped, and are ready for filling, sanding, and priming, (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6383.jpg)
Post by: 1Bad88tbird on January 16, 2010, 08:26:49 PM
I know I keep repeating myself but man you do great work!!!
Post by: 1WLD BRD on January 16, 2010, 11:07:07 PM
very nice work man! keep going....
Put a scoop in the fenders..... lol
Post by: daminc on January 17, 2010, 01:05:18 PM
Thanks guys...... Sorry, no scoop today... lol Today I sprayed the fenders. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6386.jpg)
Now I can have more fun sanding, and filling. I'm hoping the fenders will be at the same stage as the rest of the car by next weekend.
Post by: vinnietbird on January 17, 2010, 04:27:08 PM
I remember spending a lot of time on the front fenders for the Sport.They sucked.When I was almost done,I ended up a a pair of near perfect fenders.The sad ones went to the s pile.Good work Jerry.Is the engine almost together?LOL.
Post by: daminc on January 18, 2010, 07:45:18 AM
Quote from: vinnietbird;306666
Is the engine almost together? LOL.
Yes, it's all sitting together on a shelf, talking about the good old days. :D No, I haven't bought anything to start putting it back together. I'm going to collect what I need, while I finish the bodywork and paint.
Post by: Kitz Kat on January 18, 2010, 03:22:22 PM
I got a set of finned covers, I got from Vinnie, if you interested. I couldn't use them on my setup.
Post by: vinnietbird on January 18, 2010, 04:38:37 PM
Every little thing you do is one step closer to getting it all together.I'm getting close,just no friggin' time.
Post by: daminc on January 18, 2010, 05:52:35 PM
Quote from: Kitz Kat;306806
which covers are they? I'm sure I probably saw them before you got them.
Post by: vinnietbird on January 18, 2010, 06:15:32 PM
Here they are on the engine before I installed the COBRA covers....
Post by: daminc on January 18, 2010, 06:17:28 PM
I guess they would match the intake.. Why couldn't you use them, kitz?
Post by: vinnietbird on January 18, 2010, 06:25:28 PM
I'd take them back if the price was right........super cheap.LOL.
Post by: Kitz Kat on January 19, 2010, 03:42:31 AM
To much lift in my valve train, a few rockers were tapping them. I didn't feel like clearing them at the time, so I just put my chrome one's back on. Vinnie's pick are them.
Post by: vinnietbird on January 19, 2010, 08:56:45 AM
I actually like those better than my Cobra covers.
Post by: Kitz Kat on January 19, 2010, 02:09:03 PM
I liked them to, but I didn't want to butcher them up, I'll use them somewhere, but if Jerry could use them at least I know they will go to a good home.lol
Post by: vinnietbird on January 19, 2010, 05:24:09 PM
I do think they would look good with what you have planned,Jerry.If you're going natural aluminum (clear coated natural),you could always bead blast the covers and clear them to match.
Post by: daminc on January 19, 2010, 06:36:22 PM
Ok, kitz.... Hit me with the price... (You can PM me if you want)
Post by: vinnietbird on January 19, 2010, 08:52:46 PM
Quote from: daminc;307018
Wow,when I read that,I had an '80's flash of Pat Benatar singing "Hit me with your best shot".......Blast from the past.LOL.
Post by: daminc on January 19, 2010, 10:18:48 PM
Sorry Vinnie, I didn't mean to have that happen. lol ... And hell is for children....
Post by: vinnietbird on January 19, 2010, 10:23:51 PM
.....and love is a battlefield......
Post by: hellsing73 on January 19, 2010, 11:44:17 PM
ok i seen the xxx on the block and would like to know what that means. when i had to replace my gasget their i seen mine had y's their. and what do they mean?
Post by: daminc on January 20, 2010, 07:32:56 AM
There are a lot of theories about it on the web, but I haven't found anything that is a definite answer about it.
Post by: vinnietbird on January 20, 2010, 08:07:45 AM
From all I have read,YYY and XXX are roller blocks.
Post by: daminc on January 20, 2010, 08:19:03 AM
People also have claimed to not have roller blocks too...
Post by: vinnietbird on January 20, 2010, 08:25:11 AM
Well,just because it's a roller block,doesn't mean it has roller parts inside.I've seen some trucks with flat tappet lifters,inside a roller block.The mounting bosses for the roller lifter "spider" were there.
Any plans today for the Cougar,Jerry?I'm hoping to swap out the motor mounts....and maybe the tranny mount if it looks bad.I'll check it while I'm under there.
Post by: daminc on January 20, 2010, 06:20:02 PM
Nope, had to work to make money to fund this multi-million dollar project I started 2 years ago. LOL
and the XXX YYY is still a mystery. I read tons of ideas on why they are there.
Post by: Kitz Kat on January 20, 2010, 07:50:33 PM
You all worry to much!! Getter done.
Post by: vinnietbird on January 20, 2010, 11:16:37 PM
No worries here.Just working on the Sport.Do the same Jerry.Rock on !!!
Post by: thunderjet302 on January 21, 2010, 12:06:00 AM
Nice fenders.:D
Is that appropriate to say?
Post by: daminc on January 22, 2010, 06:03:10 PM
Today I sanded the fenders and did a little filling.
To start off... I broke out the new supply of Dura-Blocks (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6415.jpg)
next is the sanding and filling (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6418.jpg)
So tomorrow, I have to bolt the entire car back together to make sure everything still lines up. then it will be time for the 2K primer, and a whole lot of blocking until it's ready to paint. Hopefully the priming will happen on Sunday
Here's where we ended up today (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6421.jpg)
Finally.... The car is going back together. I've been waiting 2 years for this day, even though it will have to come apart 1 more time for the finish paint. I can see a light at the end of a long dark tunnel.:D
Post by: hellsing73 on January 22, 2010, 06:19:51 PM
ok guys thanks for the info and the car is looking realy good. i hope when i start mine it comes out as good as yours is
Post by: Kitz Kat on January 22, 2010, 06:54:47 PM
That car looks so shagy, with them wheels!! Black with turbines will look bad ass. can't wait to see what going in to it under the hood! I know I had some part in it. Good Job Bubba!
Post by: vinnietbird on January 22, 2010, 07:27:39 PM
WOO-HOO.......Awesomeness !!!!! You should be ready for paint real soon.I'm proud for you.
Post by: Kitz Kat on January 22, 2010, 07:36:19 PM
Ah Vinnie fix your vibes,lol
Post by: daminc on January 22, 2010, 07:43:29 PM
Thanks, It won't be anything awesome under the hood. Just a H.O. motor.
Post by: Kitz Kat on January 22, 2010, 07:54:45 PM
Can I change your mind? I'll be close to you in 2 weeks?
Post by: Kitz Kat on January 22, 2010, 07:56:44 PM
They want to send me to school in Buffalo, Of course I picked that school to be close to you!!
Post by: daminc on January 22, 2010, 07:59:17 PM
really?
Post by: Kitz Kat on January 22, 2010, 07:59:25 PM
No joke , I can pick my spring thingy up.
Post by: daminc on January 22, 2010, 08:01:09 PM
Quote from: Kitz Kat;307480
What you have in mind?
Post by: Kitz Kat on January 22, 2010, 08:04:15 PM
My companionship!!
Post by: Kitz Kat on January 22, 2010, 08:05:28 PM
And to see you and your great new shop.
Post by: daminc on January 22, 2010, 08:08:08 PM
you just want to sit in the Vert. lol
Post by: Kitz Kat on January 22, 2010, 08:24:06 PM
You just made me go to the next page!! we need 100 post to change a page! But It's worth it for you.
Post by: daminc on January 22, 2010, 08:27:56 PM
Mines set for 10 per page. I've seen 2 pages of this conversation, and 189 pages of progress. lol
Post by: Kitz Kat on January 22, 2010, 08:40:55 PM
I pme'd you again, but it does come up quicker now , I'm on page 48.
Post by: vinnietbird on January 23, 2010, 12:16:52 AM
Quote from: Kitz Kat;307475
I was trying to forget about it for a while....APPARENTLY you won't let me...LOL.LOL. You've tortured me forever !!!!!!
Post by: 1Bad88tbird on January 23, 2010, 09:04:58 AM
Quote from: vinnietbird;307534
Hahahaha! That's what friends are for!
Post by: daminc on January 23, 2010, 06:01:14 PM
today was a good day......
To start off, I had to do some repair work to the front metal supports under the bumper cover. Had a bit of a bolt snapping problem 2 years ago when I was taking the car apart. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6424.jpg)
So I pounded out the old bolts and replaced them with new ones. (I buy them by the 100's)
I also cleaned up the rust. treated it, and painted them (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6429.jpg)
and I also cleaned up the rust and painted it too. Project 2 completed.... (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6440.jpg)
then I started putting the car together, and adjusted everything. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6441.jpg)
It was really nice to use new bolts on everything. Now I know how Vinnie feels when working on a car... No rust! Had to do a lot of adjusting , and re- adjusting to get the hood, fenders, and doors to line up. It went along pretty nice all day. Took my time, and finished bolting everything together. Here it is. Ready for primer and blocking. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6448.jpg)
Also took a pic of my grille. Probably the nicest part of the entire car. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6447.jpg)
And a complimentary Vert pic. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6457.jpg)
Tomorrow I'm getting ready to prime.
Post by: 1Bad88tbird on January 23, 2010, 06:38:49 PM
I bet you're happy to finally see it all in one piece. I know I sure would be!
Post by: Chuck W on January 23, 2010, 08:12:18 PM
Excellent!
Post by: vinnietbird on January 23, 2010, 08:48:45 PM
I'm getting a little tear in my eye........in a manly,car guy sort of way.
Post by: daminc on January 23, 2010, 08:50:34 PM
Quote from: vinnietbird;307650
LOL, I'm sure it's just allergies or something like that.
Post by: vinnietbird on January 23, 2010, 09:09:46 PM
Yeah !!! Allergies....that's right .....That's what I meant to say....yeah,THAT'S the ticket.....
Post by: Kitz Kat on January 24, 2010, 09:34:03 AM
Are you putting the motor in before or after paint?
Post by: daminc on January 24, 2010, 09:48:07 AM
after. the car is getting painted in pieces anyway. (fenders, doors hood, trunk)
I have to prime it and block it while everything is installed, so I know that it is all flat and matching when you look at the car. (mainly down the side) Then I'll take it all apart again, paint the car, jambs, and roof, then move on to the backsides of the trunk lid, hood, and doors. I'm going to hang the doors before I spray the outsides of them, just in case. By then the motor should be about ready to put in. I can paint and install the rest after.
Post by: 50tbrd88 on January 24, 2010, 11:38:36 AM
Looking good!
Post by: daminc on January 24, 2010, 04:42:20 PM
Today was very very dusty. Almost ready for the next primer coat. It's amazing what you find, when you use top of the line sanding blocks over others. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6468.jpg)
Post by: Cougar8775 on January 24, 2010, 10:28:31 PM
wow you had alot of high spots on there. but its looking good.
Post by: Watchdevil on January 24, 2010, 11:12:32 PM
Quote from: Cougar8775;307799
Wish I could do all the work like this on my own. Hey the Turbo hood is going to look great on that car.
I have been working on interior stuff with the cold damp weather I have had here lately. I really need to progress to the mechanical stuff. I have so much to do. Body and paint work will be last.
Post by: daminc on January 25, 2010, 04:20:52 PM
Primed again! It's grainy because I have to shut the flash off, or the car glares to much and you can't see it. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6473.jpg)
Post by: vinnietbird on January 25, 2010, 04:48:41 PM
Uber sweet.Jerry,I can speak from experience,it's been a long road.I remember how I felt when I was FINALLY at a point where I actually did FEEL that I was really getting somewhere. Even though I had done a ton of work,it just didn't feel like I was moving forward.Once I drove up and saw the Sport sitting outside with fresh paint,it was as if the clouds parted,the sun was shining and the angels were singing.I'm proud for you.Keep it going.
Post by: baxo on January 25, 2010, 05:00:41 PM
Holy ! NICE!
Post by: EricCoolCats on January 25, 2010, 06:37:51 PM
Are you sure about black for the color? A dark maroon or blue would really look appealing on that car... ;)
Post by: daminc on January 25, 2010, 06:44:52 PM
Quote from: EricCoolCats;307884
that red interior for making the exterior hard to match.... I was thinking about maybe a pearl on the black. Then I could get a maroon tint on it. (or something out of the ordinary)
Post by: 88FoxBird on January 25, 2010, 08:16:08 PM
Looking good. Makes me wish I had a heated garage so I could get my Cougar all purdied up and ready for paint.
Post by: dominator on January 25, 2010, 09:48:20 PM
Remember how ya said my cars interior reminded you of yours Jerry. Black exterior and red interior is the way to go man. Black will look a mile deep when finished, a deep red pearl in the clear would be sick though. Ford has a color on the Harley f150,s called lava, might want to check it out at the dealer,it's a sick color.
Post by: Chooglin on January 25, 2010, 10:06:35 PM
looking great !!!! I am still amazed at how much patience and skill you have,to be able to do this and not get burned out.
I am curious about the hours you have in this...........any idea?
Post by: daminc on January 25, 2010, 10:31:28 PM
Quote from: Chooglin;307918
I stopped keeping track of my hrs last year when I got the rear end for the car. That's when I knew that it was going to go way past what I originally had planned for the car. If you remember....I was just going to fix the rust. LOL
I think that the hrs up till then was something like a month and a half of working. Something like 250 hrs. Since then, I figured I probably passed that amount this year. So, if I was actually paying to have this done.. I would be in the neighborhood of about $25,000 for labor alone. Add another 3 grand for supplies, parts, tools, and gas, and electric to do the job.
I figure the total restoration for a shop would be almost $40,000. If anyone want's to buy it, I will take $35,000 for it. :hick: Anyone?
And to answer the burned out question... I have fun doing this, so I don't really get burned out doing it. It's actually relaxing.
Post by: daminc on January 25, 2010, 10:39:10 PM
Quote from: dominator;307917
That's why I wanted to go black this time around. My last car (before this one) was a 78 Monarch, black with red interior. I put a couple of months into that paint job, and it was a flawless black mirror finish. I'm hoping this car will be better then that. Still thinking about a pearl though. I need to find some different samples though.
Post by: ZondaC12 on January 25, 2010, 11:36:12 PM
Quote from: daminc;307920
Sounds about right to me man...for how rotted away it was. Surely old cars rusted even further have been repaired throughout the years, I've seen before and after pics of muscle car restorations etc and similar figures quoted. Definitely a big deal...a testament to the magnitude of this project!!!
Are you even going to drive this thing a lot? I think I'd be scared shiznitless. If anything happened......what a shame that would be. Just to think that all that work could be mangled in an instant. I try to NOT be a cynical person most of the time like that, I'm really not. But sometimes I can't help it. *Harrison Ford as angry Indiana Jones* "It belongs in a museum!!!!!!" :rollin:
Post by: 88turbo on January 26, 2010, 12:16:11 AM
will you take a check? :rollin:
Post by: Crusher on January 26, 2010, 12:23:44 AM
I can't believe u r still working on this wow... Keep it up! and Lucky.. I wanted black ext and red int.. when I had my cougar lol. :-p
Post by: vinnietbird on January 26, 2010, 06:56:37 AM
A really dark burgundy wine color with metal flake? Dark enough that in the sunlight,it looks burgundy,at night it looks black.My blue Bird was like that.Dark and different.
Post by: dominator on January 26, 2010, 08:04:04 AM
I'm tellin ya man ,look up ford's LAVA for the Harley f150. You'll love it,it looks black but in the sunlight it has a deep deep burgandy effect. .
Post by: 88CougarGT on January 26, 2010, 09:37:49 AM
Lava....I dig the lava. Maybe this will be the color for my mustang. (http://www.pickupsplus.com/wp-content/gallery/2010-harley-f150/Ford-F-150_Harley-Davidson_2010_800x600_zoom.jpg)
Post by: Chuck W on January 26, 2010, 10:00:38 AM
Looks really good Jerry.
I wish I had the room to get into something like this myself. Then again, who's to say I won't within the next couple years. I'm planning on painting the XR-7 myself eventually, so we'll see.
I agree on perhaps some pearl or something in the black.
Post by: 88CougarGT on January 26, 2010, 10:18:32 AM
Are you certain it needs to be black? I tried to add some big metal flake (BMF ftw!).
Post by: maandy on January 26, 2010, 12:03:48 PM
Looks REALLY good !!! wow what a job you have done there. Wish to work with my own car too but can´t do it right now. It´s -12F Outside and garage was 3F. :D
Post by: V8Demon on January 26, 2010, 12:50:58 PM
Post by: daminc on January 26, 2010, 01:11:24 PM
I think I'm going with a pearl on top of the black. I already have the black urethane, so I can easily add a pearl mid coat and then clear it.
Post by: Kitz Kat on January 26, 2010, 04:16:39 PM
Do something different, already got black with red interior, It's nice, But. This is the only chance to make it unique.
Post by: Kitz Kat on January 26, 2010, 04:29:18 PM
That Harley color on red, was I thought for mine a while back, also the dark black cherry from mopar. Black and red always go together though. That black Cat I gave to my buddy that you have the pics of , that thing is still beautiful. Just wish it didn't have the six.
Post by: daddybair7 on January 26, 2010, 05:54:41 PM
Jerry, the work u have done is just amazing! No matter what color u chose the cat is going to look great and the fact that u did it all is something most guys and gals can't claim. Great work . Now whats going to be ur next prodject after a well deserved break. Maybe something for the D.R.N.A give those little dogs a cool ride. lol
Post by: daminc on January 26, 2010, 07:11:00 PM
Well, we're not done yet... The vert is going to be the next project.......
High build primer today (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6487.jpg)
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: vinnietbird on January 26, 2010, 09:06:16 PM
Are you starting to get that goose bumply,tingly feeling yet?I did when paint time was near.
Post by: 50tbrd88 on January 26, 2010, 09:33:17 PM
I'm excited for ya. Lots of blood, sweat, and tears are about to come to fruition. Keep the pics coming!
Post by: Davemutt on January 27, 2010, 04:38:29 PM
Looks like you're on the homestretch now. I can't wait to see it done.
Thanks for all the updates!
Post by: 347Thunder on January 27, 2010, 08:33:28 PM
oh, do I remember the days.
Post by: daminc on January 27, 2010, 08:48:40 PM
Oh yea, a lot of sanding started today. My elbow is killing me.
Post by: vinnietbird on January 28, 2010, 07:03:28 AM
Jerry,what's the ETA on the paint application?
Post by: daminc on January 28, 2010, 07:35:00 AM
Hard to say right now since I'm doing this between jobs. I may have it flattened by this weekend, so I can spray it with primer again, then start blocking it with 500-600, but it will need to be re-sprayed and flattened again first . Then it comes apart again.... I'll seal it with another coat of epoxy right before it gets paint. I'll be painting it in 2 stages. the back sides of the hood, trunk, and doors will be painted along with the remaining body, roof, and door jambs. then the doors will go back on, and they will get painted along with the outsides of the fenders, trunk, and hood. It may be another month of blocking before it gets paint.... It has to be better then perfect for black paint. I'm still finding a few high and low spots on the passenger side of the hood, and a couple on the trunk lid so far. the roof is great, but I'll finish the rest of the car, so I know where I have to spray more high build, and sand it again.
Post by: daminc on January 28, 2010, 05:52:48 PM
A couple progress pics. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6494.jpg)
Post by: vinnietbird on January 28, 2010, 06:24:57 PM
How long til paint?
Post by: daminc on January 28, 2010, 06:27:14 PM
Quote from: vinnietbird;308232
How long til paint?
LOL.... refer to a couple posts back
Post by: vinnietbird on January 28, 2010, 06:58:32 PM
My bad.I wasn't paying close atention.I've been really distracted lately.....more than usual.Uncommon for me.
Post by: 1WLD BRD on January 28, 2010, 07:14:11 PM
you got more patients then I do bro, I would say good enough and paint it white LMAO....
Cant wait to see this thing...
I wont be going that extreme when I paint the '96, (which I may do soon now that I am back to work sometime this month)
Post by: daminc on January 28, 2010, 08:51:58 PM
After all the work I put into it. It would be silly not to go through all this to make it perfect. I Would go through all this, no matter what color I painted it.
Post by: daminc on January 29, 2010, 05:54:39 PM
It's getting a lot flatter... One more blast of primer should do the trick. The highs, and lows are almost gone. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6498.jpg)
Post by: thunderjet302 on January 29, 2010, 09:15:06 PM
Looking good:D
Are you doing any repair work to the bumpers or are they ok?
Post by: daminc on January 29, 2010, 09:44:09 PM
Quote from: thunderjet302;308390
Looking good:D
The bumpers are fine, and ready to paint the way they are
Post by: DerikWayne on January 30, 2010, 08:32:12 PM
man, this is exciting stuff!
Post by: vinnietbird on January 30, 2010, 09:16:06 PM
Jerry,are you adding the flex additive to the paint for the bumper covers?
Post by: daminc on January 30, 2010, 09:35:38 PM
yes I am Vinnie
Post by: vinnietbird on January 31, 2010, 08:03:45 AM
That make me happy.LOL.
Post by: jason on February 07, 2010, 09:30:19 PM
i just went through 195 pages.great work....i 'm going to get rest now.
Post by: SSX on February 10, 2010, 05:53:45 PM
After having been away from the forum for close to a year, I had to catch up on this project. I'm still amazed and the finished project should be awesome. I can't wait to see what you have in store for the 'vert. I never was a huge convertible fan...until I bought one. :)
Post by: daminc on February 10, 2010, 06:16:18 PM
Quote from: jason;309566
lol
Post by: daminc on February 10, 2010, 06:18:01 PM
Quote from: SSX;309850
I got some ideas... The verts actually do grow on you. Doesn't matter what kind they are.
Post by: vinnietbird on February 10, 2010, 06:36:04 PM
Hey,there's worse things that could grow on you.LOL.
Post by: ZondaC12 on February 10, 2010, 08:58:15 PM
Vinnie......*sigh* nothing is sacred with you. Nothing! :hick:
Post by: vinnietbird on February 10, 2010, 11:56:21 PM
Weeeellllll,there is ONE thing that's pretty sacred with me....................
Post by: jcassity on February 11, 2010, 02:36:46 AM
this line is something i have never really liked about our cars. that metal piece seems to be some odd ball after thought. why not fill it in?
on the rear where the window trim meets the line, i filled will clear silicone so the rain water does not get underneath the window trim.
those of us white paint hate the black runs that result from a fresh cleaning,, use to piss me off.
project coming a long good man, i look and learn ,,, then look back and understand what i did wrong.
this whole prime process has learned me a thing or two. the stages of prime / sand is complicated to plan.
at any rate, from what i see here,,, i would have been ready to shoot paint,, and yet there is more sanding and priming to do. what a freaking project !!!! never been done here like this before, lessons for everyone.
Post by: daminc on February 11, 2010, 07:28:34 AM
It's close to paint. I got a few low spots here and there that I will shoot with primer and re-sand flat. then I can re-prime the entire car and jump to blocking it with 400 grit, then 600 grit. then it will be ready for paint.
for an update........ I have been blocking the car using 180 grit to flatten all the panels.. I haven't been taking any pics because they look the same as the last ones I took. I'll post more when this step is finished. I got a few more areas to do. They should be done today and ready to spray the lows again. there are probably only about 10 small spots that need re-blocking before I re-prime the car.
Post by: SLEEPER T-BIRD 87 on February 11, 2010, 01:28:21 PM
Quote from: daminc;309886
These are the steps where all that hard work pays off,If you have any doubts that something isn't perfect keep working it till it is as a mistake here will stand out like a sore thumb.
I cant wait to see this car in paint.:bowdown:
Post by: vinnietbird on February 11, 2010, 01:42:45 PM
Jeddy,I think I may get a little emotional when it's all painted and assembled.I remember when mine was painted a year ago,after driving it and working on it for so long,it was beautiful,but almost "not right".I've adjusted well,though.
Post by: daminc on February 11, 2010, 04:43:16 PM
Post by: vinnietbird on February 11, 2010, 05:42:00 PM
Jerry,did you see the NOS red headliner in red in the classifieds?NEW !!!
Post by: daminc on February 11, 2010, 05:45:40 PM
Mine is as perfect as the day the car was built. Like the rest of my interior. Could you imagine the money I could make if I sold it.
I'm sure no one remembers what the inside looked like. Here's a refresher... it needed a little vacuuming. (http://i233.photobucket.com/albums/ee79/daminc/cougar%20before/IMG_2833.jpg)
And the trunk (http://i233.photobucket.com/albums/ee79/daminc/cougar%20before/IMG_2841.jpg)
Post by: vinnietbird on February 11, 2010, 06:01:47 PM
If it was Black I'd buy your interior.......even if you didn't want to sell it.
Post by: Watchdevil on February 11, 2010, 07:07:24 PM
You Cougar is certainly coming along... It gives me hope my Bird will finally get to that stage!
Post by: dominator on February 11, 2010, 07:37:51 PM
Gonna pick up some TC Interior door panels jerry????
Post by: daminc on February 11, 2010, 07:54:31 PM
Quote from: dominator;309951
Nope, I'm keeping these on this car. I can at least say that the interior is all original. ( well mostly. I put a floor shifter and full console in) lol.... Got to keep something from the original car. I'm changing the panels on the vert. I already have them ready to install
Post by: thunderjet302 on February 11, 2010, 09:11:16 PM
Are you going to run a full digital dash?
Post by: daminc on February 11, 2010, 09:13:23 PM
Quote from: thunderjet302;309967
I got one I can put in
Post by: thunderjet302 on February 11, 2010, 09:34:36 PM
Quote from: daminc;309968
I'd do it. I love mine. It gives the car a high tech 80's feel:D
Post by: vinnietbird on February 12, 2010, 12:06:44 AM
I have thought about a full digi dash,but have no idea how to do it.
Post by: daminc on February 12, 2010, 07:24:51 AM
here's the wiring for it. you also need a digi sender. I also believe through testing, that you can wire the regular sender backwards, and it will read in the correct direction instead of backwards, there's a thread about that.
Post by: 88CougarGT on February 12, 2010, 09:37:18 AM
I really hate the tach on my full digi-dash. You can't set idle by it. Whenever I stomp on it, my brain takes too long searching the cluster to find out I've just buried into the red. I have a sport cluster I am waiting to install.
Also, periodically my gas gauge will blink E. But only on rare occasions. The sounds it makes are nice .
Post by: daminc on February 16, 2010, 05:47:22 PM
more of the same stuff. sanding and priming... This should be the last of the flattening. After this(again, because I was paranoid it wasn''t flat enough), I will be priming a couple more coats, and on to the wet sanding. The last step before the finish paint. Well, it still needs to be sealed with epoxy again, before the paint,, but it's considered part of the finish painting. (I'm rambling, just look at the pics. lol)
here we are again, another coat of primer (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6516.jpg)
Can't forget the little stuff (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6526.jpg)
guide coat. I don't think I showed this step in the priming stage yet. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6527.jpg)
Post by: Kitz Kat on February 21, 2010, 02:03:46 PM
I'll probably start sanding mine next month. It's gunna hurt to put the sander to it at first, but then I will be dedicated. I was hoping to have it done last year.
Post by: daminc on February 21, 2010, 02:09:52 PM
it's always tough to start. I felt the same way when I started cutting entire sections off the car. There's no turning back from that.
Post by: Kitz Kat on February 21, 2010, 02:14:51 PM
Not when you cut them off there's not.
Post by: thunderjet302 on February 21, 2010, 11:02:18 PM
You're going to kill me but looking at the pictures of the car in primer makes me think it would look great in white :D
Post by: daminc on February 21, 2010, 11:10:25 PM
Been there, done that. I've always hated it white since day one. The vert will also not be white
Post by: thunderjet302 on February 21, 2010, 11:18:38 PM
I'm kinda partial to charcoal gray on these cars. I think it brings out the lines of the car.
Post by: croga001 on February 22, 2010, 01:03:51 AM
man, i cant wait to see some paint on the car. i feel the need to check up on your thread daily to see whats new its like an addiction.
Post by: vinnietbird on February 22, 2010, 08:16:18 AM
WOO-HOO !!!! Paint by Friday !!!!!!!!!
Probably not.LOL.
Post by: daminc on February 22, 2010, 08:17:37 AM
maybe the final primer by friday... hows that.
Post by: vinnietbird on February 22, 2010, 08:20:51 AM
I'll take what I can get.LOL
I'm hoping to repaint mine in 2011 (towards the end of the year).More stuff will be happening with the Bird,so,new paint as well.
Post by: daminc on February 22, 2010, 09:17:07 AM
Quote from: vinnietbird;311072
wings all over it? I can see that. :rollin:
Post by: vinnietbird on February 22, 2010, 10:08:20 AM
I'm going to paint it and put Mustang emblems on it and tell people it's a Stang with a body kit.
Post by: 1Bad88tbird on February 22, 2010, 10:13:38 AM
Haha, why not? They have a kit that makes a Mustang look like a T-Bird.
Post by: vinnietbird on February 22, 2010, 10:24:45 AM
A Cougar is just an ugly Thunderbird.LOL
JUST KIDDING !!!!!!!
Post by: daminc on February 22, 2010, 10:33:56 AM
No, it just a t-bird with more class. :D:rollin:
Post by: vinnietbird on February 22, 2010, 10:50:58 AM
I kind of knew something like that was coming.LOL.
Post by: daminc on February 22, 2010, 05:51:33 PM
I knew, you knew, I knew.
Post by: vinnietbird on February 22, 2010, 06:05:54 PM
I know.
Post by: 50tbrd88 on February 22, 2010, 06:37:50 PM
Quote from: thunderjet302;311036
I totally agree. Charcoal grey is manly. lol.
Post by: thunderjet302 on February 22, 2010, 10:01:07 PM
Quote from: 50tbrd88;311146
Tue-tone silver over charcoal gray is even more manly:D
Post by: daminc on March 08, 2010, 09:20:08 PM
Update...... Everything is flat and sanded. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6596.jpg)
Post by: daminc on March 08, 2010, 09:29:11 PM
Then I pulled the vert out and went for a cruise.... Glad the heat works really good. Actually drove it with the top down. It was about 40 deg today. (http://i233.photobucket.com/albums/ee79/daminc/85%20Vert/IMG_6616.jpg)
Post by: daminc on March 09, 2010, 11:14:24 PM
I'm going to start re-masking the car for paint tomorrow.... maybe prime on Friday
Post by: Watchdevil on March 09, 2010, 11:27:54 PM
Quote from: daminc;313440
I am totally diggin' the w red interior! It's going to look sweet with gray exterior paint. My favorite shade of gray is the Mustang Alloy Gray.. Very dark!
Post by: Whiteboy on March 10, 2010, 01:18:06 PM
lol man this thing has came a long way. Im glad u did this cuz its fun watching
Post by: daminc on March 10, 2010, 02:09:08 PM
Quote from: Watchdevil;313443
Gray?
Post by: jkirchman on March 10, 2010, 03:05:11 PM
I'm going to come and steal your front seat belt buckles when you aren't looking. Mine are toast. Just letting you know.
Post by: 1Bad88tbird on March 10, 2010, 04:09:43 PM
I thought you where painting it black?
Post by: Cougar8775 on March 10, 2010, 04:32:03 PM
he is. and jkirchman and how are you gonna take them if i beat ya to it? mine are toast too.
Post by: hellsing73 on March 10, 2010, 06:21:21 PM
Quote from: jkirchman;313516
hell who needs seat belts lol :burnout:
Post by: daminc on March 10, 2010, 07:59:50 PM
My entire interior is in the same condition as the day I bought it. And....keep your hands off my seatbelts. lol
Post by: daminc on March 10, 2010, 08:00:50 PM
Quote from: 1Bad88tbird;313522
Yes, It's going to be black
Post by: daminc on March 16, 2010, 07:18:39 PM
Last time for primer (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6658.jpg)
Post by: vinnietbird on March 16, 2010, 07:31:44 PM
I suppose it's alright.......I mean....I expected so much MORE.LOL.LOL. Good work Jeddy.I hope to see it black by Friday night.
Post by: daminc on March 17, 2010, 08:04:34 AM
Doesn't look like it will be black by Friday. I have a ton of wet sanding to do first. maybe next Friday. if I had help, it would be ready to paint on Sat, but with that stupid job and an extra EPA certification class on Friday, It'll have to get done when it gets done. This is the longest part of the project. Then I can start finding everything, and put it back together once and for all. The boxes of parts all over the place are killing me. I even have tons of stuff up in the attic in the house.
Post by: Cougar8775 on March 17, 2010, 10:49:16 AM
i told ya jerry i would give ya a hand just if we both could find time ya know lol.
Post by: vinnietbird on March 17, 2010, 04:56:35 PM
wish I was there.I'd love to help.
Post by: daminc on March 17, 2010, 07:14:56 PM
Post by: thunderjet302 on March 17, 2010, 07:18:57 PM
Nice starter motor :pbb:
The car is comming along nicely :D
Post by: dominator on March 17, 2010, 11:43:00 PM
Dam that starter looks 100 years old.
Post by: jrad235 on March 18, 2010, 01:04:07 AM
I think that starter qualifies as F**ked!
Time for a high torque!
Post by: Cougar8775 on March 18, 2010, 01:26:24 AM
did you find that starter at the bottom of lake ontario or lake erie?
Post by: Whiteboy on March 18, 2010, 02:01:37 AM
Hahahah having problems huh? You mean like it not starting? That looks to be the problem hahahha
Post by: vinnietbird on March 18, 2010, 07:06:51 AM
Nice starter.Holy .I really just can't believe the rust and corrossion you guys have to watch out for.It still just amazes me.
Post by: daminc on March 18, 2010, 07:28:29 AM
What's funny is.... it still started the car the very last time I had it out side to spin it around. Damp days were a problem. lol
Niagara River would be the correct answer for the starter. lol
It's amazing what 20 years of salt will do to something.
Post by: 88CougarGT on March 18, 2010, 09:09:58 AM
Are you planning to use that rusty old lump to power your shiny new rebuilt car? It deserves something better....MMMMMM DOHC.
Post by: daddybair7 on March 18, 2010, 09:17:28 PM
i say put that starter in a case and when u take that cougar to some car shows display it. That way people would know how bad that car was and how far u went to save it. Ofcourse u will have a photo album with the resto pics too.:bowdown:
Post by: daminc on March 18, 2010, 09:53:48 PM
Quote from: 88CougarGT;314807
What rusty old lump are you referring to?
Post by: thunderjet302 on March 18, 2010, 10:18:18 PM
Quote from: daminc;314795
23 years;)
Post by: daminc on March 18, 2010, 10:20:27 PM
Quote from: thunderjet302;314885
23 years;)
Only saw salt for 20. :D
Post by: thunderjet302 on March 18, 2010, 10:22:29 PM
Oh. If it had 3 more years it would have been dust:hick:
Post by: CoogarXR on March 18, 2010, 10:40:39 PM
Quote from: daminc;314883
I think he was referring to the ol' 3.8L.
So yeah, what are the drivetrain plans?
Post by: daminc on March 18, 2010, 10:41:59 PM
The 5.0 is at the machine shop.
Post by: Whiteboy on March 18, 2010, 11:20:52 PM
Quote from: daddybair7;314877
Lol thats not a bad idea
Post by: Kitz Kat on March 19, 2010, 04:16:54 PM
I wouldn't even let that cancer piece of shiznit near my car!!!
Post by: hellsing73 on March 19, 2010, 04:47:32 PM
lol who in the hell would use a dohc motor in these cars lol
Post by: vinnietbird on March 19, 2010, 04:58:41 PM
Quote from: hellsing73;314970
I would love to have a supercharged Shelby or Cobra engine if I had the cash,and someone else to do all the work.....but I don't.....so.....
Post by: Kitz Kat on March 19, 2010, 04:59:40 PM
If I had the time and space and a few other delicacies I would.
Post by: 88CougarGT on March 19, 2010, 05:01:27 PM
Seen too many 5.0/5.8 Swaps. I really want to do a DOHC swap with a megasquirt efi into a classic mustang.
Post by: 50tbrd88 on March 23, 2010, 07:26:16 PM
I can hardly contain my excitement for ya! Its gonna be a proud moment for the whole fox tbird/cougar forum community when you lay the paint on that bad boy!!
Post by: 347Thunder on March 23, 2010, 07:30:46 PM
wow it almost looks flat......
LOL looking good I did the same thing with my hood!
Post by: daminc on March 23, 2010, 08:37:35 PM
Yep, it's pretty freakin flat.... Using an 11" block and 400 grit on the flats. I think we all need to get some champagne, and have a party after the paint is on.
Post by: daminc on March 23, 2010, 08:38:31 PM
........and then figure out where I put all the parts for the car. lol
Post by: vinnietbird on March 23, 2010, 09:04:38 PM
...and how to reassemble everything.LOL.I have to say,it's been a great ride so far with the Cougar.There's a few more chapters left in the story though.Can't wait to see how the story ends.I know there's a sequel....I saw the other thread.LOL.
Post by: daminc on March 23, 2010, 09:22:02 PM
yea, I may be asking a lot of stupid reassembly questions. It's been over 2 years since I saw most of parts of the car, let alone where they go. :hick:
Post by: vinnietbird on March 23, 2010, 09:23:38 PM
You know where to find me.I got your back.......in a brotherly way, not a prison kind of way.LOL.
Post by: daminc on March 23, 2010, 09:24:33 PM
Quote from: vinnietbird;315507
The sequel is going to make this one look like childs play.
Post by: Quietleaf on March 23, 2010, 10:29:20 PM
We need to do whatever it takes to have CJ in 2011 so we can see it up close!
Post by: daminc on March 23, 2010, 10:32:31 PM
Quote from: Quietleaf;315533
Is it going to be in Buffalo next year? :rollin:
Post by: TheEskimo on March 24, 2010, 01:14:48 AM
Looking great, I love this build thread. Can't wait to see it in paint.
Post by: Cougar8775 on March 24, 2010, 02:45:06 AM
lol i think we need to do that jerry. But i can help out putting it back together for ya when you need it.
Post by: baxo on March 24, 2010, 07:59:22 AM
Yeah I can definitely help with assembly too.. let me know!
Post by: vinnietbird on March 24, 2010, 08:51:56 AM
I can't wait to see the convertible done in 2020.That should be awesome !!!!
Post by: daminc on March 24, 2010, 08:56:56 AM
I have to get it done before Dec 2012, when the world ends.. :hick:
Post by: vinnietbird on March 24, 2010, 09:08:33 AM
Good point. I forgot about the end of the world coming.I'd better get the a/c going strong in the Sport and make sure the tank is full of good gas.
Post by: daddybair7 on March 24, 2010, 07:11:15 PM
Every cougar owner get your camras and start taking pics of ur cars and email them to jerry lol. Can't wait till paint is done. :bowdown:
Post by: daminc on March 24, 2010, 09:44:03 PM
Quote from: baxo;315573
You know your gonna be here for that. I can't lift those doors and hood myself with out scratching them.
Post by: daminc on March 25, 2010, 08:34:13 PM
more done today. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6729.jpg)
Post by: vinnietbird on March 25, 2010, 08:54:08 PM
I had to use a floor jack and a towel to install my doors.The hood was a different story.Gayle actually helped me with that,bless here tiny,short little self.
Post by: daminc on March 25, 2010, 08:59:10 PM
I got baxo coming over on Saturday to help me take the doors, and hood off.
Post by: vinnietbird on March 25, 2010, 09:31:04 PM
2 extra hands make all the difference in the world.Wish i was there.I love this stuff.
Post by: daminc on March 25, 2010, 09:33:05 PM
We can put you on video chat Vinnie. Find that camera yet?
Post by: vinnietbird on March 25, 2010, 09:39:21 PM
Oh man,the video computer camera thing is probably in storage somewhere.I have no idea whaere that thing is.We got it as a gift and Gayle didn't like it.I never used it,and when i thought about it,she did something with it.
Post by: 347Thunder on March 25, 2010, 09:42:33 PM
what grit are you using 400? I remember this like it was yesterday..... Thank God it is over lol.
Post by: daminc on March 25, 2010, 09:50:25 PM
Yes, 400 grit. I'll be saying that soon too.
Post by: Kitz Kat on March 26, 2010, 05:41:53 AM
I remember hauling them doors! they definably got some weight to them. Oh yeh thanks for the card.lol
Post by: Kitz Kat on March 26, 2010, 05:53:53 AM
Did you figure the flywheel out yet? You can have the one I have if you need it I got 2 of them.
Post by: vinnietbird on March 26, 2010, 06:51:23 AM
I'm sending Jerry the flywheel and block plate.
Post by: daminc on March 26, 2010, 07:25:18 AM
yes, Vinnie was sending some other things, and had a few extra too. The AOD situation seems to be solved. Now I just need another stall converter in the 2400 and up range. I'll talk with the guy at the machine shop,and see what he recommends based on the work that will be done..
Does anyone know for sure that I can use my Drive old Drive shaft? Its a big rusted piece of , but it will only be used until I find an aluminum shaft to have shortened. It still seems to fall in the length that was discussed in the DS tread. seemed to remember everyone saying it would work, just dbl checking before I cross that of my list.
Post by: daminc on March 26, 2010, 07:26:41 AM
Quote from: Kitz Kat;315932
Happy Easter Kitz. :D
Post by: thunderjet302 on March 26, 2010, 09:43:20 AM
You should be able to use the drive shaft that was in the Cougar with the 5.0 AOD combo. I'm 99% certain that the 3.8 and 5.0 cars with AODs used the same length drive shaft.
Post by: daminc on March 26, 2010, 11:17:40 AM
Quote from: thunderjet302;315950
I never had that combo, so I'll try with the 3.8/ AOD combo. I'm pretty sure it won't be a problem.
Post by: Cougar8775 on March 26, 2010, 12:20:01 PM
i know there was a chart of the variouse drive shaft leingths years ago but im not sure where to find it now. It had a combo on 3.8-c6 then 3.8-AOD and 5.0-AOD.
Post by: Kitz Kat on March 26, 2010, 03:35:05 PM
I'm pretty sure you can, because the trans mount still bolts to the same spot. The aod is no different externally!
Post by: vinnietbird on March 26, 2010, 04:46:17 PM
Quote from: Kitz Kat;315972
X2.But,get a Crown Vic shaft and have it shortened before you need the driveshaft,Just start out with the aluminum one.They can be found wicked cheap at the yards,and well,you know the rest of the shortening story.;
Post by: daminc on March 26, 2010, 06:58:34 PM
you have to remember.... up here, good parts are expensive. not like where you live Vinnie
Post by: daminc on March 26, 2010, 07:02:54 PM
Post by: vinnietbird on March 26, 2010, 07:24:25 PM
I didn't know they cost a lot there.I actually thought they were cheaper. I did know they were rusty though.LOL.
Post by: cougarXLS on March 26, 2010, 07:44:58 PM
Wow... Wow..
WOW
Post by: daminc on March 26, 2010, 09:28:03 PM
Quote from: vinnietbird;316017
Actually it's everything here is expensive from taxes, to gas, to food. Gotta go out west to the mts of New Mexico
Post by: daminc on March 26, 2010, 09:32:26 PM
And, I know the pics are a bit blurry. The flash was glaring of the car, and I had to shut the it off. Unfortunately, I didn't hold the camera steady long enough for the pics.
Post by: vinnietbird on March 26, 2010, 10:09:15 PM
Out here,it's free to go into the yards,and when the guy says "$10.00",then it's $10.00....not "plus tax,etc.".Usually,I can fill a large duffel bag (I use it to tote parts at the yards) with a bunch of small parts and he'll ask for $20-25.00.
Post by: Quietleaf on March 27, 2010, 01:52:19 AM
The passenger door looks a little misaligned...or is the fender?
Post by: daminc on March 27, 2010, 08:26:17 AM
Quote from: Quietleaf;316048
looks fine in the last pic. Unless I'm not seeing something.
Post by: daminc on March 27, 2010, 08:29:45 AM
also, the doors are not closed. could be what your seeing. I spent 8 hrs aligning the entire front of the car one Saturday
Post by: daminc on March 27, 2010, 08:36:27 AM
todays pre-update.
Taking the front of the car apart to get it ready for paint. Doors, fenders, hood, header, and bumpers. everything needs to be prepped for paint on the insides, and undersides.
Pics to follow later this evening.
( Yes, everything will have to be aligned again)
Post by: maandy on March 27, 2010, 12:06:35 PM
oo .. really good job ! I´m speakless.. but I have the feeling that this is going to be sharpest cat we all have ever seen. When your cat is ready you really can say you have brand new car. :D
Post by: daminc on March 27, 2010, 07:18:26 PM
Recruited some help today (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6740.jpg) The sun coming through the windows was really messing with my camera today. It hasn't really worked right since I dropped it 2 weeks ago. Looks like it's time for another. Bare with the grainy pics today....... Ok, it's all apart again. Next time it gets put together, it will be painted. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6743.jpg)
I'll take better ones tomorrow to replace these. These are not "Evolution Quality" pics
Post by: jkirchman on March 28, 2010, 02:51:18 AM
That poor car is like, "YAAAY I'm all together again!! Wait...what are you doing?!? Don't take that off again! NOOOO!! Just drive me already you buttstuff retentive jerk!"
LOL Just kidding man. All of our cars should be so lucky. This has truly been a labor of love and I'm thankful you've shared it all with us here.
Post by: baxo on March 28, 2010, 07:56:30 AM
Jerry isn't the buttstuff retentive jerk. I am. I went there yesterday to check it out. And I was like "no no no! This is all wrong!" so I took it apart. Gonna make jerry redo it. Consider mr the Chef Ramsey of body work. There can only be perfection in Hell's Garage!
Just kidding!
But seriously. All the sanding and priming paid off. All the panels are straight as an arrow and smoother than a babys bottom!
Post by: thunderjet302 on March 28, 2010, 03:44:28 PM
You forgot to take off the quarters;)
Post by: hellsing73 on March 28, 2010, 04:10:53 PM
how much to paint my car when im done with it lol
Post by: daminc on March 28, 2010, 04:38:42 PM
My quality, about $7,500 without body work
Post by: daminc on March 28, 2010, 04:40:07 PM
Quote from: thunderjet302;316258
I did that once....... and only once. lol
Post by: Kitz Kat on March 30, 2010, 03:17:23 PM
Quit messing around with it. let's see some color!, I may have mine sprayed before you, and I didn't even start yet. I will start on mine on good Friday, just the exhaust for that day. Then the sand paper, hopefully will spray memorial weekend.
Post by: daminc on March 30, 2010, 03:26:55 PM
Are you spraying the jambs and changing the color?
Post by: Kitz Kat on March 30, 2010, 03:46:34 PM
Of course, I hope it's darker with a little more metallic in it.
Post by: daminc on March 30, 2010, 07:01:18 PM
Darker will look better.
Post by: daminc on March 31, 2010, 06:40:11 PM
Yesterday & today's work. the passenger side is done, including jambs (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6774.jpg)
still need to do the back sides of these. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6775.jpg)
need to do the jamb and underside of the trunk lid. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6776.jpg)
The only outer panels left to do, along with the jamb. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6778.jpg)
Post by: 50tbrd88 on March 31, 2010, 08:58:47 PM
Man its gonna take a TON of tire shine to get those tires black again, lol. :poke:
Looking great!
Post by: daminc on March 31, 2010, 09:50:38 PM
Quote from: 50tbrd88;316664
Looking great!
I'll just paint them while I'm doing the car. :rollin:
Post by: daminc on April 01, 2010, 07:17:47 PM
all that's left are the jambs on this side, and the undersides of the hood, trunk lid, and doors. (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6791.jpg)
Post by: Kitz Kat on April 01, 2010, 07:57:24 PM
What do you mean that's all ?
Post by: daminc on April 01, 2010, 07:59:41 PM
yep, that's all....... then paint.
Post by: vinnietbird on April 01, 2010, 08:12:34 PM
Oh boy....oh boy....oh boy !!!!!!
Post by: daminc on April 01, 2010, 08:41:03 PM
I may paint it for my birthday, if it's ready by then. It's on a weekend and everything.
Easy Vinnie.... deep breaths....In..............out.............in.....................
Post by: daminc on April 01, 2010, 08:42:32 PM
and out out out.... sorry, I forgot to finish that last sentence
Post by: vinnietbird on April 01, 2010, 08:42:58 PM
Thanks for finishing......I was turning blue.LOL.
Post by: Kitz Kat on April 01, 2010, 09:01:31 PM
Breath dammit!
Post by: vinnietbird on April 01, 2010, 09:07:40 PM
Breathing freely now......and drinking sweet tea.LOL......and watching NCIS....and surfing the net.......and thinking about installing the trip minder.....and the power passenger seat stuff....and wanting some ice cream.....and looking at my chica.....and now,thinking about things with my chica.........
Post by: jkirchman on April 01, 2010, 09:25:53 PM
TMI, Vinnie. TMI. ;)
Post by: daminc on April 01, 2010, 09:34:24 PM
Quote from: vinnietbird;316770
Your not going to post pics, are you? :hick:
Post by: HAVI on April 01, 2010, 09:46:32 PM
You're not going to post pics, are you? :ttiwwp:
Post by: daminc on April 01, 2010, 09:55:29 PM
Pretty sure I don't want to see Vinnie in an action shot. :nannerbang:
Post by: vinnietbird on April 02, 2010, 06:48:40 AM
No pics.I have to live with her forever.....which would be cut short if pics are taken.No pics.....NO PICS !!!
Post by: HAVI on April 02, 2010, 06:37:20 PM
Agreed, some things are better left undocumented, lol.
Post by: hellsing73 on April 02, 2010, 07:15:19 PM
are you painting the engine bay the same color as the car is going to be? and just want to see how you guys think about the engin bay being black and the rest of the car being a diff color?
Post by: daminc on April 02, 2010, 07:35:43 PM
The bay is already painted black to match the rest of the car. I myself never liked the engine compartment painted black as compared to the rest of the car being another color. but mine just worked out that way. You could probably see it's painted in some of the pics. I painted it last spring and usually keep it covered.
Post by: HAVI on April 02, 2010, 07:42:57 PM
I'm one to agree seeing the engine bay the same color as the rest of the car. My stock '62 Fairlane has a black engine bay, and black engine block. I will be changing that, lol. However, if the engine bay is black, don't over chrome the parts. All my opinion, so do what you feel looks good.
Post by: daminc on April 02, 2010, 07:47:55 PM
I agree on the over chroming . That's why I decided with the silver/ brushed aluminum look with mine
Post by: daminc on April 03, 2010, 06:31:41 PM
Finished with the entire car and jambs. backs and underside of doors are now done, and is the underside of the hood. All that's left to sand is the header and the underside of the trunk lid. After that, then I have a couple places to seam seal....... I see paint in the near future. most likely the weekend of the 17th.
This is as clean as I can get the underside of the hood. lol (http://i233.photobucket.com/albums/ee79/daminc/paint%20and%20body/IMG_6794.jpg)
Post by: Quietleaf on April 03, 2010, 08:21:09 PM
Oxygen for Vinnie, STAT! :D
Post by: Watchdevil on April 03, 2010, 11:32:06 PM
Love the bordello red interior!
Post by: vinnietbird on April 04, 2010, 07:49:43 AM
It's going to be beautiful Jerry.Are you tinting the windows as well for that truly sinister look?Also,after paint,are you pin striping or something else.I got my pinstripes from a body shop supply place here in town.They are by 3M,and the are thinner,and better quality than the Autozone (and other parts stores) stripes they sell.
Post by: 1Bad88tbird on April 04, 2010, 08:23:41 AM
I think a thin red stripe would look great on it.
Post by: daminc on April 04, 2010, 08:53:15 AM
I'll play it by ear after it gets painted, the door glass I have on the new doors, seems to have a way darker tint then the original doors I had. I may not stripe anything, I got a guy that does vinyl graphics stuff. I may do something out of the ordinary on the lower part of the car instead. I have to see the car painted first to decide if anything will be done.
Post by: daminc on April 07, 2010, 09:32:55 PM
Update.... Seam sealed the rockers, trunk areas, and trunk lid....... the next pics should have a car with paint........ I'll be setting up the shop with side lights, and getting the car prepped for paint.
Post by: vinnietbird on April 07, 2010, 10:32:12 PM
Gulp...................I think I can handle it........but maybe not.......Too much pressure.....
Post by: daminc on April 07, 2010, 10:48:50 PM
Keep that paper bag handy. It'll be ok... We'll get through this.
Post by: vinnietbird on April 07, 2010, 10:52:46 PM
It'll just make me want to have the Sport repainted (already planned for 2011 thankyou very much).I am excited and ready to see it.Are you nervous?
Post by: daminc on April 07, 2010, 10:55:38 PM
Nervous??? your talking to the guy that cut 50" of quarter panel off his car, (both sides)
hell yea I am.. lol
Post by: vinnietbird on April 07, 2010, 11:27:35 PM
No matter what I do,or have done to the Sport,there are just some tasks that never get any easier.
Post by: Whiteboy on April 07, 2010, 11:38:15 PM
hahaha
Post by: vinnietbird on April 07, 2010, 11:50:37 PM
Only the unibody,windshield,and rear window is left from my Sport that it rolled out the assembly plant with.I've replaced everything else.
On Jerry's car (Daminc),the only thing left from his car is the VIN plate.
Post by: daminc on April 08, 2010, 07:55:26 AM
Quote from: vinnietbird;317440
Also the front, and rear glass. :D Lets just say, I built a car around an interior. lol
Post by: vinnietbird on April 08, 2010, 08:52:39 AM
That's like building a house around a cabinet door.LOL.
Post by: daddybair7 on April 08, 2010, 08:39:33 PM
Quote from: vinnietbird;317454
But more enjoyable
Post by: 88turbo on April 08, 2010, 09:58:25 PM
Quote from: daddybair7;317516
But more enjoyable
and more people interested ;)
Post by: vinnietbird on April 09, 2010, 09:21:27 AM
Jerry...................Jerrrrrrrryyyyyy...............I need to see some newly painted body panels.........
Post by: daminc on April 10, 2010, 04:20:17 PM
Got it epoxy sealed today. next is...........................Well, you know what's next. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/87%20cougar%20paint/IMG_6840.jpg)
Post by: vinnietbird on April 10, 2010, 05:34:49 PM
Oh man !!! Soooo close.You'll be waxing it by Monday....riiiiiiight? Maybe not.
Post by: daminc on April 10, 2010, 07:34:54 PM
I'll take a day off and then wax it. lol
Paint will happen tomorrow, I didn't want to paint it to quick and have solvent pop in the paint. I had that happen once. it wasn't pretty, and had to repaint a few panels on my previous car. I'll also check it over for debris and runs in the sealer before I paint. So far is looks awesome. When it was wet, it looked incredible in the lights.
Post by: 1Bad88tbird on April 10, 2010, 10:19:09 PM
That great man! You've got to be getting excited.
Post by: Watchdevil on April 10, 2010, 10:28:31 PM
It's coming alive! Very exciting man!
Post by: 50tbrd88 on April 10, 2010, 10:40:20 PM
Hope to see it in paint soon! Great work so far...
Post by: daminc on April 11, 2010, 03:32:42 PM
Post by: Thunder Chicken on April 11, 2010, 07:18:27 PM
ooooh, pretty! I imagine your heart didn't beat while you were spraying, in fear something bad would happen :hick:
Post by: ZondaC12 on April 11, 2010, 07:58:42 PM
Amazing.
Post by: 1Bad88tbird on April 11, 2010, 08:54:50 PM
Sweet!! Congrats!!!
Post by: daddybair7 on April 11, 2010, 09:15:01 PM
WOW Cleaning up droll and going to take a cold shower :catbang:
Post by: 50tbrd88 on April 11, 2010, 09:34:44 PM
Black was the perfect choice now that you see the contrast with the red interior. Looks awesome.
Post by: Cougar8775 on April 11, 2010, 09:54:24 PM
WOW!! want to help me paint mine lol.
Post by: mercury-man on April 11, 2010, 11:10:13 PM
Very Nice Jerry and Good Job dude !!! :headbang: :grinno:
D[SIZE="1"]an[/SIZE] & P[SIZE="1"]aula[/SIZE]
Post by: vinnietbird on April 12, 2010, 06:56:46 AM
I can't talk....I'm too choked up.Beautiful....just beautiful.
Post by: daminc on April 12, 2010, 07:44:03 AM
Thanks everyone....It took 2 1/2 years to get here. I still have to spray the doors ,trunk lid, hood, header panel and bumpers. So looks like maybe next weekend will be a busy one again. I looked at it again last night....I think it got shinier. lol
Post by: 88CougarGT on April 12, 2010, 09:23:05 AM
Man, I couldn't wait to see the car painted. Now I can't wait to see it all put together!
Post by: thunderjet302 on April 12, 2010, 10:36:36 AM
Those wire hubcaps need to go back on:D
Looks great!
Post by: Watchdevil on April 12, 2010, 01:11:26 PM
Me likes the w red interior with the black for sure!
Post by: EricCoolCats on April 12, 2010, 02:05:21 PM
Meh...needs more cowbell. :headbang:
Post by: 88CougarGT on April 12, 2010, 02:33:48 PM
How many coats of clear. You're the kind of guy who would wet sand the entire car for that mirror finish.
Post by: Chooglin on April 12, 2010, 04:19:02 PM
looks great Jerry...............never thought this day would ever come. :D:bowdown:
Post by: 50tbrd88 on April 12, 2010, 04:51:47 PM
I may have missed this, but what are the plans as far as wheels/tires?
Post by: daminc on April 12, 2010, 07:17:11 PM
I will put the wire covers back on after I clean them up.....
Eric, I do have a cowbell I can toss in to the works if needed..
There's no clear on the car.... It's straight black High gloss urethane. It will be sanded and buffed to a mirror, And I didn't want to be sanding through a clear coat to achieve it. The base /clear would be a waste of time since it's black, and clear coat is also urethane. I also sanded the epoxy with 400 grit right before I painted it, between the chemical bond and the scratch of the 400, the paint should be pretty permanent. lol
here's a couple more after I hung the fenders on, and removed the tape from the tags in the door jambs (http://i784.photobucket.com/albums/yy121/daminc-pics/87%20cougar%20paint/IMG_6878.jpg)
And here's the wheels that are going on (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_4458.jpg)
Post by: daddybair7 on April 12, 2010, 07:28:59 PM
Jerry, are u going to paint the wheels between the spokes black too. It helps with the brake dust. By the way u going to have a police escort everywhere u go in that car to protect it lol.
Post by: 50tbrd88 on April 12, 2010, 07:49:18 PM
Mmmm...I wish I could find a nice set of turbines. I am ready to put some better riding springs on and go with some 15's or 16's soon and get a change from 17's.
Post by: croga001 on April 13, 2010, 03:25:13 AM
plain old AWESOME! looks great. i have been waiting for this day!
Post by: daminc on April 13, 2010, 07:21:32 AM
Quote from: daddybair7;317955
Probably not. You have to drive the car for brake dust to happen. It'll probably get driven less then the vert. I put less then 300 miles on the vert in a year.
Post by: DVP on April 14, 2010, 12:51:53 AM
Quote from: EricCoolCats;317927
http://www.youtube.com/watch?v=_Mie9hhQTUM
Post by: Kitz Kat on April 14, 2010, 04:13:43 AM
I don't know how I missed the paint job till now, Looks good.
Post by: 1WLD BRD on April 14, 2010, 04:30:15 AM
looking good man, cant wait to see it completed. I started the body work on the '96 yesterday.doing a colour change but not going to the extreme you did LOL.
already have all the paint and I need, just got to get at it and get it done. hopefully by the weekend mine will be a new colour.
Post by: daminc on April 14, 2010, 07:27:41 AM
LOL, we actually had a cowbell experience like that once. My cousin is the drummer for Cannibal Corpse, and about 20 years ago....our bands practiced in the same building... so one day, his band was hanging out at one of our practices, when all of a sudden I hear, "Let me see your drums" (me also being a drummer). So we give our instruments to Cannibal Corpse, and they bang out one of their death metal songs using the cowbell that I have for those old rock songs we would play once in a while... Long story short..... Got to be one of the funniest moment I ever witnessed. we were all laughing so hard that they couldn't even finish the song...... anyway picture this song with a cowbell, you'll understand Parental Advisory required http://www.youtube.com/watch?v=G8RnqT3dJEw (http://"http://www.youtube.com/watch?v=G8RnqT3dJEw")
Post by: daminc on April 14, 2010, 07:31:21 AM
Kitz, you must have been busy sanding your own car.... Now you'll really have to stop down one day to see it.
RJ, You better be taking pics as you go.... And your welcome to stop over to check it out too.
Post by: daminc on April 14, 2010, 07:35:43 AM
And yes, the drummer is really my cousin... I also taught him how to play the drums, and turned down the job as sound tech for the band. (things you regret looking back in life. ;))
Post by: EricCoolCats on April 14, 2010, 09:35:13 AM
Whoa, that is AWESOME Jerry! They were in one of my all-time favorite movies, too: "Ace Ventura: Pet Detective". The band got some pretty good camera time, two different scenes IIRC. That's a great story!
BTW, had you been the sound guy for CC you'd have lost your hearing by now...
Post by: Watchdevil on April 14, 2010, 10:31:48 AM
I love the fresh set of turbines!
Post by: andrew beedle on April 14, 2010, 11:18:51 PM
Did you just spray it out in the open like that? What about dust in the paint?
Post by: vinnietbird on April 14, 2010, 11:29:55 PM
I LOVE dust in the paint.When your hand itches,you can just rub the car.....all better.LOL.
Post by: 1WLD BRD on April 15, 2010, 06:40:24 AM
Quote from: daminc;318167
yeah I am taking pics, but nobody cares about it here LMAO. the guys on TCCOA are fairly interested in it though. As soon as I get my Passport I plan to make a trip over there buddy.:D
as for the dust concern, i doubt there is much concern.... I painted my '88 Bird in my backyard, under trees and didnt get one thing in the paint amazingly.... used the wrong reducer and too low of pressure on my HVLP gun and ended up with orange peel though LOL
Post by: daminc on April 15, 2010, 07:15:50 AM
It doesn't really matter if there's anything in the paint. It's going to get sanded again, then buffed. There's a couple things that got in there, but they will be gone after it's finished.
Post by: Kitz Kat on April 15, 2010, 04:12:40 PM
Did you redo those wheels, They look nice!
Post by: daminc on April 15, 2010, 06:31:29 PM
Quote from: Kitz Kat;318415
Nope, that's your handy work.;)
Post by: Kitz Kat on April 15, 2010, 06:59:09 PM
I always did like them, like you said they aren't that hard to keep clean. Every Sunday that was sunny they got cleaned. I got the spare yet in my trunk, you get it for free. whenever we hook up.
Post by: daminc on April 15, 2010, 08:11:10 PM
yippee...I forgot you had 5
Post by: daminc on April 16, 2010, 07:31:08 AM
More painting this weekend.... with more pics to follow.
Post by: Davemutt on April 17, 2010, 11:10:40 AM
Just getting caught up on this thread and I don't have much to add to what everyone else said except:
:jerry::jerry::jerry:
It really is beautiful. You do amazing work and its great so see so much effort being put into one of these cars.
Post by: daminc on April 17, 2010, 12:12:02 PM
Got it sealed... Just waiting it out to paint later tonight... More as it happens.
Post by: mercury-man on April 17, 2010, 05:24:34 PM
Happy Birthday Jerry today !!! :D
Post by: daminc on April 17, 2010, 08:04:39 PM
Painted the rest of the car today. (http://i784.photobucket.com/albums/yy121/daminc-pics/87%20cougar%20paint/P4170003.jpg)
Post by: vinnietbird on April 17, 2010, 10:50:38 PM
Beautiful....just beautiful.You've got to be a proud daddy.
Post by: cougarman on April 17, 2010, 10:51:06 PM
Looks absolutely amazing!!!:bowdown::bowdown:
Post by: 50tbrd88 on April 17, 2010, 11:08:21 PM
Black is always a good choice.
Post by: flylear45 on April 18, 2010, 01:04:02 AM
Nice, nice. Very flat and deep. Gotta hand it to you on this labor of love.
Post by: Watchdevil on April 18, 2010, 01:48:54 AM
Oh sweet Geezus! I am in heaven! I want pretty black paint too!
Post by: Kitz Kat on April 18, 2010, 07:26:23 AM
Great job, happy Bday to.
Post by: 1Bad88tbird on April 18, 2010, 09:04:13 AM
Happy Birthday Jerry, it's mine today too!
Post by: daminc on April 18, 2010, 05:20:09 PM
Thanks for the Birthday wishes on here, and on Facebook.
so I decided to put the car back together by myself...... I also found another handy use for this tool. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/87%20cougar%20paint/IMG_6904.jpg)
So as not to bore anyone with all 60 pics from today.... Here's the final product at the end of the day. (http://i784.photobucket.com/albums/yy121/daminc-pics/87%20cougar%20paint/P4180001.jpg)
Post by: hypostang on April 18, 2010, 05:28:32 PM
That is one pretty and shiny cat !!!!
Kudos to you :D
Post by: 50tbrd88 on April 18, 2010, 07:23:21 PM
She's gonna be a beauty queen! Congrats on all of your hard work coming to fruition man!
Post by: dominator on April 18, 2010, 08:47:10 PM
Happy birthday jerry. Now that's lookin nice,gonna have to come up one weekend so we can paint the top of my SC that nice shiny black lol.
Post by: daminc on April 18, 2010, 09:06:28 PM
Quote from: dominator;318808
We can do that......
Post by: Beau on April 18, 2010, 09:24:06 PM
Beautimous! You did really good :bowdown::D
Post by: daminc on April 18, 2010, 10:16:58 PM
Thanks for all the compliments guys. It was all worth the wait. Still need to spray the bumper covers, and sand and buff the car to that special mirror finish that I'm looking for. Motor is in the shop being finished as we speak. everything still needs to be installed on the car.... fuel lines /tank... brake lines/ brakes.... entire interior needs to be cleaned and installed.... Exterior trim/ mouldings... mirrors... door glass and trim..... turbines/tires.... and the list goes on, and on. should be ready to drive by next spring. oh yea, I still have to finish the motor after I get it back, and connect up the transmission and floor shifter.... Talk about building a car from the wheels up. lol..... At least the tough part is way past me now
Post by: daminc on April 18, 2010, 10:19:02 PM
I think I'll be able to finally get my car on the banner in another month. :D
Post by: ZondaC12 on April 18, 2010, 10:27:53 PM
Hahaha I'm sure E-man would put it up for YOU no matter what. :D
Anyway Im a broken record but that looks awesome you can sure lay down paint you haven't even buffed it and it looks like a typical new car right off the lot if you ask me.
Even with the granny-spokes it still looks....good :o Maybe the paint is blinding me to the granny-spokes LOL. Bliiiiiinded by the liiight. Or lack thereof lol. Cause its BLACK. Not....white...so y'know there's less...light 'n' stuff...kinda more..blinded by the darkness really. But that doesn't really rhyme with "runner in the night". Some things are not meant to be known.
Post by: daminc on April 18, 2010, 10:32:58 PM
LOL, I had to put the spokes back on. Just didn't seem right with out them. They'll be on there until next spring. maybe I should clean those tires up....(or paint them black)
Post by: 1WLD BRD on April 18, 2010, 10:45:28 PM
looks good Jerry, cant wait to see it cut and polished...
Post by: Kitz Kat on April 19, 2010, 03:58:30 PM
At least tape the whitewalls before you paint them.
Post by: daminc on April 19, 2010, 07:03:43 PM
I'll just paint new ones on too. lol
Here's the last of the showing off the car pics.... I'm pretty sure my camera is whipped, and probably full of over spray at this point.. lol I took the car out for a little sun today. (http://i784.photobucket.com/albums/yy121/daminc-pics/IMG_6944.jpg)
Not really sure when there will be another update. I just have everything to put back on, and probably not worth taking pics every step of the way until it's finished.. So it looks as though the project will be coming to an end when it's back together. The motor install will probably be the last part of this projects update.. It's been a blast posting every few days or every week, so take care everyone, and I'll see you back here when either the car is put back together, or when I have news about the motor... ( I'll still be here, just not updating this thread like I was)
Jerry
Post by: 1Bad88tbird on April 20, 2010, 12:16:33 AM
The paint looks great! Nice reflection! It's going to be strange not getting anymore updates though.
Post by: baxo on April 20, 2010, 12:21:18 AM
it's still hard to believe what an amazing accomplishment this has been! I gotta come and see this paint job in person!
Post by: Cougar8775 on April 20, 2010, 12:50:26 AM
looks good! hey i can polish up those tail lights for ya.
Post by: maandy on April 20, 2010, 05:49:23 AM
So good to see that project on the finish line. My eyes can rest if I watch your car. So have a nice time putting it together!
Post by: EricCoolCats on April 20, 2010, 08:44:28 AM
I miss the white...sniff...
Post by: ZondaC12 on April 20, 2010, 10:48:37 AM
Quote from: Kitz Kat;318887
YES come on now don't start cutting corners!
Post by: 1WLD BRD on April 20, 2010, 02:21:49 PM
I bet the neighbours cant believe it is the same car.... Cant wait to see that in person.
Post by: Kitz Kat on April 20, 2010, 04:38:16 PM
Since your this far, have you figured tire size and stuff yet?
Post by: Kitz Kat on April 20, 2010, 05:56:21 PM
Yo bubba! I was looking at your pics again ,It's so shiny it shows you need a new driveway,it shows all the cracks.
Post by: Chooglin on April 20, 2010, 08:48:38 PM
Very nice,you did some real nice work with that car.:bowdown:
Post by: daminc on April 20, 2010, 08:52:45 PM
Quote from: EricCoolCats;318971
Oh Eric, white is so 1980s.. lol
Quote from: Kitz Kat;319007
You mean there are diff sizes I can put on those turbines? What size should I put on?
Quote from: 1WLD BRD;319000
The cars been in the garage since 2003. I don't think anyone knows I even own it. lol
Quote from: Cougar8775;318950
They really aren't bad, just really scummy after the last 2 years
Quote from: Chooglin;319030
Thanks, I couldn't have kept the project going if it wasn't for the support of the people on this forum
Post by: daddybair7 on April 20, 2010, 10:45:31 PM
Wow just Wow Jerry u really r the man. Every cat out there is wanting to be owned by u so they can look the same way:bowdown:
Post by: 88CougarGT on April 20, 2010, 11:31:12 PM
Wow. I'm really inspired man.:bowdown:
I'm still looking for my next project and that paint job is freaking amazing. Makes me wish I had tried harder/done things correctly when I painted my cat. It was my first paint job though. Thanks for documenting the work. I can't wait to see the vert go through the same process.;)
Some day I will corner you and pick your brain on how you did such an excellent job. You should be super proud.
Post by: Watchdevil on April 21, 2010, 12:19:09 AM
Quote from: 88CougarGT;319071
Yeah I am certainly most inspired as well. Makes me wanna make sure I do my body and paint restoration thoroughly, especially the engine compartment and the sheetmetal under the fenders. I don't wanna just slap a coat of paint on and have what you can't see all nasty.
Post by: Kitz Kat on April 22, 2010, 06:55:28 PM
I ran 235-60's cooper cobras, It would be nice to go 245 but not sure how the turbines would of worked with them.
Post by: fordmanx10 on April 22, 2010, 07:17:29 PM
hey kitz dont be given all my secrets away bad enough it already looks like mine i might have to drive up their and key it if it looks any more like mine lol
Post by: Kitz Kat on April 22, 2010, 07:25:05 PM
But, his is a V8,lol, well not yet.
Post by: daminc on April 22, 2010, 07:34:12 PM
Quote from: Kitz Kat;319326
Still at the machine shop..... I told him I'm in no hurry. It's going to be nice, that's all I'm saying right now. Everybody will have to wait patiently till I post about the new motor. And I'll just say this as a teaser..... I didn't skimp on the rebuild to go with the P heads. :D
Post by: vinnietbird on April 25, 2010, 10:58:48 AM
Hey Jerry,any new stuff going on?
Post by: daminc on April 25, 2010, 06:03:33 PM
Sorry, there won't be much going on for quite a while. I have to paint the bumper covers and misc items like mirrors, side moulding, that piece of door window aluminum between the windows... Little stuff like that... I'm guessing the motor should be done anytime now. I think I talked with him on the 9th this month, and he was ordering everything for the rebuild. He said it would be about 3 weeks for him to get everything done. I still need an oil pan, but I'll probably bolt the old one on temporarily to get it home without damaging anything underneath. I'll worry about that after I get it back on the stand. He's also painting it for me while he has it. Can't complain about that. lol
So todays update is....... No update today folks. Sorry, maybe next weekend.
Post by: Beau on April 25, 2010, 06:10:09 PM
No news is good news..i guess? lol
Post by: vinnietbird on April 25, 2010, 09:39:45 PM
I'll have the flywheel and block plate out this week Jerry.My fault,I've been pretty distracted.Do you have flywheel bolts?If so,good,if not,I MAY have some.
Post by: daminc on April 25, 2010, 10:06:47 PM
yes, I'm pretty sure I have a load of them now. lol
Post by: vinnietbird on April 25, 2010, 10:21:58 PM
10-4
Post by: daminc on April 25, 2010, 10:58:16 PM
I posted a few teasers that will be in my motor rebuild on Vinnies thread. http://www.foxtbirdcougarforums.com/showthread.php?t=27952&page=5 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=27952&page=5")
Post by: daminc on May 03, 2010, 06:35:52 PM
Here you go Vinnie. New stuff (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_6955.jpg)
Post by: vinnietbird on May 03, 2010, 06:40:39 PM
Sweet.Is it ready to go or does it need anything?Do you have a cooler?I love my 5 speed,but,there are times when I wish I would've kept the AOD.Shifting doesn't bother me,but constant shifting (in this town,no choice) does bother me.
Post by: daminc on May 03, 2010, 06:43:10 PM
I do have a cooler from the bird. Going to probably need a diff torque converter I would imagine.
Post by: dominator on May 03, 2010, 08:17:26 PM
Ahh the SC aod, good choice. Should be good for ya in stock form. You can use the convertor but it will be better with a higher stall.
Post by: daminc on May 07, 2010, 08:14:28 PM
Couple more new parts trickled in today. (http://i233.photobucket.com/albums/ee79/daminc/new%20car%20parts/IMG_6966.jpg)
Post by: Cougar8775 on May 07, 2010, 08:43:14 PM
what!! no chrome? come on with your plans you should have had a chrome pan or even polished.
Post by: daminc on May 07, 2010, 08:49:29 PM
it's shiny... lol
Thats obviously the black part of my black and silver scheme. ;)
Post by: vinnietbird on May 08, 2010, 08:55:46 AM
Nice pan.That's what mine looked like when I got it.I like Ford parts. Does yours have 3 drain plugs?Mine only has the front and side rear. I installed the rails down each side of the pan.Do you have those?
Post by: daminc on May 08, 2010, 09:13:09 AM
I think it might be for a low oil sensor? didn't really notice that until you said something.
Post by: vinnietbird on May 08, 2010, 09:15:32 AM
Duh !!! Man,I need to wake up (stayed up too late).Yes,low oil level sensor.Right.I have one and should remembered that.I'm going to wash and wax the car and get some fresh air..
Post by: daminc on May 08, 2010, 09:17:08 AM
I was just guessing... lol.... I guess it goes both ways
Post by: thunderjet302 on May 08, 2010, 02:06:11 PM
Quote from: Cougar8775;321064
Try keeping a chrome oil pan clean ;)
I have a Ford blue pan like the rest of the block and heads.
Just a FYI. Don't use the low oil level sensor. The things leak from the sensor as they age. I just pulled mine and put a plug in its place. The engine doesn't mark its territory with Mobile1 any more :D
Post by: daminc on May 09, 2010, 02:19:54 PM
Yea, I figure what's there to see down there. No sense in overdoing something you never see. and black fits into my color scheme anyway.. The AOD will stay silver to match other parts I have.
Not sure about the oil sensor though. I may connect it and see what happens when I get bored someday. but at least I have the option. Wasn't a bad score for $37. it's really heavy steel too.
Post by: vinnietbird on May 09, 2010, 07:40:49 PM
My oil level sender has been great,even with the other engine.
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on May 12, 2010, 08:33:06 PM
While I had a couple hrs today, I decided to build this for all the parts that need to be cleaned up and repainted. I used all s so far.
needs a few more parts before I can test it out, I think I actually have everything I need to finish it too.
Post by: hypostang on May 12, 2010, 08:35:17 PM
niiiiiiccccceeeeee!!!!
Post by: HAVI on May 12, 2010, 11:47:20 PM
Nice! I've wanted to do the DIY Tptools kit one myself....some day.
Post by: 1Bad88tbird on May 13, 2010, 08:09:46 PM
That's one of the benifits I have at work. I can blast whatever I want on my own time.
Post by: daminc on May 18, 2010, 07:44:49 AM
I've been blasting some stuff, it needs some tweaking, but it's working great, I installed an exhaust vent out the back of the shop for it now. It's totally dust free inside the shop area.
Should be ready to spray the bumpers and side trim by this weekend if everything goes well......
On another side note of useless info..... Today is my anniversary of joining here in 2007. Remember how un-cool it was around here before me. lol J/K :rollin:
I also decided to keep all the chrome and not black it out on the car. I will be painting the mirrors black, the same as the body though.
Post by: ZondaC12 on May 18, 2010, 09:38:33 AM
Jerry you have NO idea how lame it was around here.
Post by: jkirchman on May 19, 2010, 12:40:06 PM
Keeping the chrome will be a nice touch I think.
Post by: daminc on May 22, 2010, 08:39:01 PM
puttin stuff back together... (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6974.jpg)
Post by: fluke on May 22, 2010, 08:50:26 PM
Gotta love a red and black combo! :)
Post by: daminc on May 22, 2010, 08:56:01 PM
New door handles will be here on wednesday.. Then I can put the glass and the doors back together. Should also have more pics tomorrow.
Post by: Watchdevil on May 23, 2010, 12:07:02 AM
Quote from: fluke;322896
Oh yeah it's just great!
Post by: daminc on May 23, 2010, 05:48:57 PM
put more stuff back together today trunk... Yes, that's still the original spare under the cover. :D (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6986.jpg)
sill trim. just noticed that the ford emblems are still attached. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6988.jpg)
Blacked out the trim around the front and back windows (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6990.jpg)
I'll tackle this next. it's still not bolted in (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6989.jpg)
And everything is sanded and ready for painting, but I wasn't sure if it was going to rain, so I didn't want to push the 87 outside without door glass yet. If it's nice tomorrow, I'll push it out and paint the bumpers and other stuff. If not, the door handles and glass will be in by next weekend, so the car will be sealed, and it won't matter if it rains or not. That's all for today
Post by: Watchdevil on May 23, 2010, 10:53:53 PM
Quote from: daminc;322970
Ah the dual automatic shifter! Love it! ;):rollin:
Post by: Kitz Kat on May 24, 2010, 08:32:25 AM
I take it you figured the the seat wires out, since it's in?
Post by: vinnietbird on May 24, 2010, 08:42:00 AM
Yo Jeddy....Nice work.Glad to see more progress.I'm home alone with the youngest for 3 days and hope to get a little work done as well.Maybe the dual power seats.......maybe not.LOL.Keep it up.The light at the end of the tunnel is getting bigger......for this car.
Post by: daminc on May 24, 2010, 02:50:17 PM
Nope, it's still the manual seat on that side. I'm putting the dual power in the vert I think. Along with all the auto light package stuff. There's more of a chance the vert will be out past dark anyway. the power seat will be better for longer cruising in that car too.. (I think.....)
Post by: daminc on May 27, 2010, 08:10:01 PM
Went to the machine shop today.. the pistons were on back order, but they just got them yesterday. (they were actually made last friday). I dropped off the oil pan, timing cover, and balancer today with some misc other parts so they can put the motor back together... they were turning the crankshaft today, and machining the block next week so they can get the bearings and the rest of the parts for the rebuild... He said it will be done in about 2 weeks from today. I don't have any pics, but the pistons were pretty shagy looking. He showed me how they float on the I-beam connecting rods when connected. I'm still not sure what that really means, but it was kinda cool to see what's going into the motor, and how it works, and connects together..
Also got my chrome door handles installed. So now I can put the rest of the doors back together so the car is waterproof again. That's all I got today..........
Post by: vinnietbird on May 27, 2010, 08:30:46 PM
Rain or shine,I'm hitting the yard next week for your parts (and mione).Gayle is sick and I was taking care of here and housely cs and such.I will get your package to you next week.Even if it's just the flywheel and block plate.You'll need them. Where are the pics of the door handles mounted to the car? I have a few parts on the way that I bought on Ebay.Now the waiting game...I live that.
Post by: daminc on May 27, 2010, 09:09:02 PM
It's still no rush Vinnie. I still have to clean, and buy some stuff in the engine accessory department..... Paint more stuff, install the fuel, and brake lines. and maybe install a new steering rack, or at the very least, replace the old lines on it.
Post by: vinnietbird on May 27, 2010, 09:31:57 PM
Replace the rack now.Don't install the old one after all of the work that's been done.They don't cost too much.Get the Sport rack.Better steering like the Turbo Coupe.The Sports and TC's had them (as did the XR-7).It's a lot easier to install with no engine in the car.Replace the outer tie rods as well........just my two cents (actually it was more like 7 cents).
Post by: daminc on May 27, 2010, 09:39:40 PM
I'll probably replace it. the tie rods I have to see about. they were replaced the year I put it away,, but it's been sitting since 03. I'll have to feel that one out before it gets to move on it's own..
I'll be spraying the bumpers and mirrors and things this weekend for sure. The weather will be nice, so I can roll the car out and spray everything.
did I mention that the pistons were pretty shagy looking.. lol
Post by: daminc on May 27, 2010, 09:47:30 PM
Vinnie, is that a 3 turn, or a 2.5 turn rack
Post by: vinnietbird on May 27, 2010, 10:06:30 PM
2.5 I believe Sir.
Post by: Cougar8775 on May 27, 2010, 11:03:14 PM
cool and do i see a california duster lol. i figured you would get one.
Post by: fluke on May 28, 2010, 12:15:31 AM
Quote from: Cougar8775;323458
Got one in each vehicle and have been using them for years. I love the things. :D
Post by: daminc on May 28, 2010, 08:05:13 PM
new handle....Bad pic of it. Way to much glare for this old camera. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_6999.jpg)
lock is back on the trunk again. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_7000.jpg)
Post by: daminc on May 28, 2010, 08:54:55 PM
We also got a big one for the floors in the house
Post by: Cougar8775 on May 28, 2010, 10:40:56 PM
nice. Hey you know not to use those plastic keys! But hey it won't scratch the paint.
Post by: Watchdevil on May 29, 2010, 12:44:19 AM
I am still foaming at the mouth over this car! I wonder if I will ever see mine look as good and be sound mechanically?
Post by: daminc on May 29, 2010, 08:08:01 AM
Quote from: Cougar8775;323526
What plastic keys are you talking about? I didn't know they had them.
Post by: Watchdevil on May 29, 2010, 11:39:10 PM
Quote from: daminc;323558
He is talking about the plastic emergency key that is in the trunk lock in the picture!
Post by: daminc on May 30, 2010, 12:34:44 AM
That was a real trunk key in the lock. it had a plastic tag on it. I didn't know they had plastic emergency keys.
Post by: Watchdevil on May 30, 2010, 01:33:58 AM
Quote from: daminc;323623
I should have recognized that plastic tag. I used to cut key that had the blanks attached to them.
There were some dealers and car manufacturers that offered credit card or plastic emergency keys that fit in your wallet.
Post by: daminc on May 30, 2010, 08:15:57 AM
Oh that's cool.
Painting the rest of my stuff today. Pics to follow later tonight.
Post by: Cougar8775 on May 30, 2010, 10:19:53 AM
Oooohhh i can't wait! (rocking in chair with excitemet!)
Post by: daminc on May 30, 2010, 12:56:34 PM
The deed is done. pics in about 2 hrs after it's touchable.
Post by: daminc on May 30, 2010, 04:21:18 PM
Today's pics... I just set them there until tomorrow when they get bolted on. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_7012.jpg)
Side trim that connects to the bumpers. I did both fronts in case I change my mind about the cornering lamps. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_7005.jpg)
And finally... the mirrors. The last part that needed to be painted. I went with the body color instead of the matte black look that was originally on these mirrors. Maybe one day I'll find a perfect set of chrome mirrors. But I really wanted them to match the paint right now. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_7006.jpg)
So there it is...... The car is totally painted, and ready to get put back together. Of course I'll have pics of it back together... Don't you worry
Post by: vinnietbird on May 30, 2010, 04:28:10 PM
Black is beautiful. I can see myself in it.LOL.
Post by: Whiteboy on May 31, 2010, 12:40:51 AM
das' peeertty
Post by: Watchdevil on May 31, 2010, 03:56:46 AM
It's so beautiful I am going to cry!!!!
Post by: Kitz Kat on May 31, 2010, 07:01:43 AM
Looks like my basp00get, shipping boxes and parts everywhere. You need to put the wheels on soon to make it right,oh yeh and a drive train. Looking good.
Post by: vinnietbird on May 31, 2010, 08:08:29 AM
Jerry,I said it once before about "Project Eevolution"..... It's an Evolution Rrrrrrrrevolution.......... Maybe that's bring back some old Saturday morning memories again.LOL.
Great work,Man. I'm amazed at the car now,as opposed to the beginning.How's the wife feeling about it?Is she excited? Gayle doesn't get too excited,but,she is a little giddy about the a/c going into the Sport. What's on the list for today?.
Post by: daminc on May 31, 2010, 09:08:57 AM
She didn't expect it to look that perfect after all the welding I did on it. She's into the hotrod/muscle car thing, and I made it look very 80s muscle car.. She said she would drive it if I took it to the track, which I agreed because I would like to see it run without actually being in it.
I'm bolting the rest of the car together today (i think)
And here's the blast from your past again. lol (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/lancebanner.jpg)
Post by: vinnietbird on May 31, 2010, 09:30:35 AM
Hey,that's my 3rd grade school pic.LOL.
I'd like to see the Sport go down the track,but,it'll have to be on video because I don't think I can take it if someone else were to drive it.Gayle will NOT drive it. She tried once,and she dumped the clutch and the car ended up sideways in the street,curb to curb.She turned it off,gave me the keys and said "YOU move it". That was funny.LOL.
Post by: CoogarXR on May 31, 2010, 10:05:33 AM
230 pages later and it's starting to look like a cougar again! We're all proud of your persistance.
Post by: BEARMAX on May 31, 2010, 11:32:16 AM
very nice jerry cnt wait to see what u do with the vert u shure u dnt wana sell it back i have cash
Post by: 50tbrd88 on May 31, 2010, 01:47:51 PM
Post by: daminc on May 31, 2010, 04:25:35 PM
Quote from: BEARMAX;323753
Sorry Bear, not right now. I'm going to drive it for a while. Maybe I'll let it go after I'm done with the restoration. unless you have a rust free 67 Cougar Vert for trade.;)
Post by: hypostang on May 31, 2010, 04:31:26 PM
Quote from: daminc;323810
Did anyone actually make a 67 cougar vert ? I have never seen a 67 or 68 but I would love to see it done
Post by: daminc on May 31, 2010, 04:38:20 PM
There are some around http://www.cardomain.com/ride/3177675 (http://"http://www.cardomain.com/ride/3177675")
I still have to put the doors back together, and it still needs to be cut and buffed. I'll probably do that this winter. The headlights could use a little buffin too, they're still my originals but not really in bad shape after a quick cleaning. I got another pair of headlights that I'll put in this winter also. New chrome moulding will be going on and also... don't forget the turbines that will be on too. I'm going with a black antenna I think. I also put the license plate on that will eventually be on the car when it gets registered. That's the plate that was originally on the car back then.
That's all for today. doors will be finished next
Post by: T-BirdX3 on May 31, 2010, 06:33:04 PM
Thats one sharp Kitty!
Post by: 50tbrd88 on May 31, 2010, 07:15:06 PM
Man that black looks miles deep...and it looks like she launches great too! lol...j/k
Post by: CoogarXR on May 31, 2010, 10:16:40 PM
The pic with the vert nose-to-nose looks like they should be slurping spaghetti together...
Post by: fluke on May 31, 2010, 10:20:54 PM
Gangsta! :D lol .. kidding kidding.. I love it! That's some deep shine!
Post by: Chooglin on June 01, 2010, 04:05:03 PM
wow,what a shine :bowdown:
Post by: massCougarxr7 on June 01, 2010, 04:38:48 PM
she looks puuuurfect...........trunklid cameout very nice......
Post by: Haystack on June 01, 2010, 11:43:40 PM
That looks good buddy. I can't believe how dark that black really is. The taillights actually look like there bright enough to hurt your eyes.
When you start motor work, your taking that whole front end off right?
Post by: daminc on June 02, 2010, 07:35:22 AM
That's not a factory Ford black that I used. It actually reminds me of the black that Chrysler uses. Believe it or not, all blacks are not the same. I never liked the black that Ford used. I got a brand new black Ford Ranger that doesn't look as black as my Cougar.
And yes..... I'm taking the front end off to put the motor in. I only have a few bolts in it right now to kinda keep it in place.I also redid everything on the front end so I can use all new nuts,and bolts too. I got a deal on a couple hundred grade 8 nuts and bolts. lol. Seeing that the motor won't be going in for a while, I felt the safest place for all the front end parts were back on the car, so that's why it's together before the motor went in. Plus I really wanted to see it back together after the 2 years it was apart.
Post by: thunderjet302 on June 02, 2010, 02:08:10 PM
Looking good :D
I think someone stole your gas tank.
Post by: BEARMAX on June 02, 2010, 07:27:10 PM
funny u mention that i am looking at one the old man just died and im trying to get his wife sell it to me but im trying to not be to pushy .;)
but this one is a 68.blue n white
Post by: daminc on June 02, 2010, 09:11:12 PM
Quote from: BEARMAX;324062
I like 68s as much as 67s. :D
Post by: daminc on June 12, 2010, 07:33:44 PM
I guess it's time to get back to this project. picked it up yesterday (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6120002.jpg)
Post by: Cougar8775 on June 12, 2010, 08:18:57 PM
ooohhhh shiney new parts! Now that would look better in the car... Oh wait that would look good in my car lol.
Post by: jrad235 on June 12, 2010, 08:55:38 PM
Now where are the acrylic valve covers? You can't put something as pretty as that underneath aluminum!
Post by: daminc on June 13, 2010, 02:17:31 PM
I'm actually looking for some satiny looking aluminum covers with fins... Preferably with no logos or names on them. This should be fun. lol
Post by: andrew beedle on June 14, 2010, 03:53:03 PM
I run the same roller rockers. I picked up a set last year after I broke one of the factory stamped rockers when I was getting into the boost alot. :burnout:
Post by: V8Demon on June 14, 2010, 04:00:50 PM
What springs are those?
Post by: vinnietbird on June 14, 2010, 04:16:46 PM
I want to touch that engine....alone....in private..........
Post by: shorangerbird on June 14, 2010, 04:29:56 PM
Quote from: daminc;325264
-werent the '85 Mustang 5.0 covers like this, IIRC? or i may just be daydreamin'. course they may not clear the rockers though......:mullet:
Post by: hypostang on June 14, 2010, 04:37:42 PM
Quote from: shorangerbird;325390
Sorta ,,, they were finned and said "Power By Ford" they also had an opening on both covers unlike the 86 up where one is totally closed
Post by: Chooglin on June 14, 2010, 05:05:35 PM
Quote from: vinnietbird;325388
Hmmmmmmmmmmm.........:hick:
Post by: vinnietbird on June 14, 2010, 06:25:54 PM
Oh,sorry,did I say that out loud? .....ummmmm....If it means anything,I felt the same way about my engine.LOL.
Post by: daminc on June 14, 2010, 07:06:16 PM
Quote from: V8Demon;325387
I'm kinda Un-knowledgeable about these kinds of things.... All I can tell you is they are Trick flow.... As for the rest of the parts in the motor...... All I can tell you is, the guy at the machine shop talked with me about what I was going to do with the car, and then he talked to the guys with Summit Racing, who then put together an entire rebuild package for me. which saved me about $1000 compared to me buying. everything separately on my own.I will have a list of parts as soon as I decipher the product codes from the sales slip.
All I know right now, is the block is .030 over, and decked with forged pistons and I-beam connecting rods. More info to follow later tonight.
Post by: thunderjet302 on June 14, 2010, 08:10:43 PM
Does it have that Comp Cams 35-308-8 roller cam in it? If so you've got the same engine that is in my T-bird;)
Post by: Cougar8775 on June 14, 2010, 08:18:30 PM
hey jerry i got an idea.. Ill come up we can install it in my car and put my turbo on it and i can test it out for ya to see how much boost she can handle. LOL!
Post by: daminc on June 14, 2010, 08:44:54 PM
door glass and trim is back on. Still needs some cleaning, but at least it's back together again (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/P6140007.jpg)
Post by: thunderjet302 on June 15, 2010, 02:17:51 PM
That should work. As long as the trans is ok I'd throw a Bauman shift kit in and instal a trans cooler. It should last for a few years like that;)
Post by: daminc on June 15, 2010, 02:40:41 PM
The car already has a cooler... And I'm not sure if I'm going to put a shift kit in it. These things happen as they happen sometimes, and I wouldn't even know where to start with something like that.. You motor building guys need to move closer to me.. lol
Post by: daminc on June 16, 2010, 07:45:54 AM
For those who didn't see the mock up in the photochops thread.... Here's an idea of what it will look like. Talked with my friend about tires yesterday... Does anyone have a size suggestion for these turbines? Should I run the same size front and back? same width front and back? give me your input. (http://i233.photobucket.com/albums/ee79/daminc/Stuff%20I%20dont%20know%20where%20to%20put/BlackCougar.jpg)
Post by: hypostang on June 16, 2010, 01:01:21 PM
On 15X7 turbines I think 235- 60- 15 look and fit nice:D
Post by: hwy73 on June 16, 2010, 03:24:59 PM
My 88 XR-7 was equipped from the factory with 225/60 x 15 BSW on the Turbine wheels.
Post by: Kitz Kat on June 16, 2010, 03:34:59 PM
Quote from: hypostang;325649
I ran the cooper cobra on them, in that size. I would of liked to have run 245's,but I wasn't sure how they would of been on 7" wheels.
Post by: daminc on June 16, 2010, 07:09:53 PM
next question.... white letters on the tires or not ?
Keep them coming.... Here's a couple pics of what I've been doing.
Almost to where I like the way it's looking. A little more work and it will be done. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6160001.jpg)
This will be next on my list of bead blasting. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6160006.jpg)
Followed by these (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6160011.jpg)
And my next problem.... Whereto put these. I've never owned parts that came with stickers before. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6160010.jpg)
Another shot of my new motor sleeping in it's copuppies. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6160009.jpg)
Post by: daminc on June 17, 2010, 11:50:50 AM
Paul, that was pretty much what I was thinking when I asked about sizes. I like the looks of that
Post by: Davemutt on June 17, 2010, 12:07:22 PM
IMO blackwalls with no white letters is a cleaner look. I like white letter tires on cars from the '60s and '70s but I don't think they work as well on newer cars.
Post by: 1WLD BRD on June 18, 2010, 02:49:11 PM
Pauls car looks good, and I think the turbines with that size tire will be perfect on yours Jerry. I would go 225/60 on the front though.
Post by: Kitz Kat on June 18, 2010, 04:22:31 PM
But aren't Paul's 8" wheels? 255 may be pushing it on a turbine. But maybe not. You may be fine here's a link to tire rack, under the specs it should be ok. http://www.tirerack.com/tires/TireSearchResults.jsp?skipOver=true&width=255%2F&ratio=60&diameter=15&x=21&y=1
Post by: hypostang on June 18, 2010, 04:50:30 PM
I had 255 s on a set of turbines and to me they did not look quite right , but they were also on a 86 stang convertible not a bird or cat:hick:
Post by: 88turbo on June 18, 2010, 10:05:15 PM
those stickers go on the neighbor kids honda so they can look fast :rollin:
Post by: 1WLD BRD on June 18, 2010, 10:14:45 PM
Quote from: hypostang;325907
I had 275/60/15's on a stock set of 7" wide 10 hole rims. looked good. Wouldnt want that for cornering but looked tough and was pretty decent traction in a straight line.:D
Post by: daminc on June 18, 2010, 11:01:59 PM
wow, 275 is huge. That's like a truck tire..
Im pondering 225s for the front and 255s for the rears.... anyone know the actual size difference between them?
Post by: daminc on June 18, 2010, 11:12:33 PM
never mind, I found my tire size calc.
Post by: V8Demon on June 19, 2010, 08:25:40 AM
Those rims in the picture I posted are stock 15 X 7 Ford 10 holes.
Post by: 1WLD BRD on June 19, 2010, 09:04:57 AM
I got an old pic some place of it. looked like a drag car... I liked the look.
Post by: Kitz Kat on June 19, 2010, 04:51:30 PM
use 235 up front. but keep the turbines not chrome or else.
Post by: Watchdevil on June 20, 2010, 03:43:32 AM
I agree you have to have the right size tires or turbines just do not look right.
Post by: EricCoolCats on June 20, 2010, 09:56:51 AM
Also, be sure the sidewalls are stiff or else you'll get a nasty swaying. Trust me on this.
Post by: daminc on June 20, 2010, 11:05:13 PM
For Fathers day, I got a new camera... here's some random pics I took with it.
The stickers are now on my tool cabinet (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0014.jpg)
After my bead basting... (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0017.jpg)
Found this while cleaning. The few parts of my car that had no rust. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0019.jpg)
So I mounted on my wall as a souvenir. (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0021.jpg)
I found that if I catch the light just right, the vert looks awesome. lol... well, minus the missing side moulding and a few rust spots. ;) (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0009.jpg)
and a couple random pics outside. (http://i784.photobucket.com/albums/yy121/daminc-pics/Fathers%20Day%202010/IMG_0011.jpg)
These are actually the front tires... The rear tires are on back order till August. These are the 235s. I had to see what it would look like on one side at least. ;) The rears are ordered.... I'm going with 255s , ,and also decided to go with the white letters. I'm trying to give the entire car that "Muscle Car" look. I think the white letters go pretty good with the entire look of the car... What do you guys think? If I get bored with them, I can always flip them around to black walls...:D
Post by: hypostang on June 23, 2010, 07:17:16 PM
I like it , personally I am a fan of the same size tires on all 4 for rotational purposes , But big and little is bad a** looking :D
Post by: vinnietbird on June 23, 2010, 07:40:43 PM
Beautiful.....just beautiful (I only shed a few tears.......O.K.,I cried tears of joy).
Post by: ProTouring442 on June 23, 2010, 07:57:21 PM
Very nice!! I so miss driving my Turbo Coupe! :(
Shiny Side Up! Bill
Post by: Haystack on June 23, 2010, 09:22:01 PM
Looks good. I wonder how it would look with some polished 10 holes or drag style wheels? That car looks perfect, now get the motor in there so there isn't 6" of wheel gap.
Post by: Chooglin on June 23, 2010, 09:34:34 PM
I really like the looks of that...............very nice !!!!
Post by: Cougar8775 on June 23, 2010, 11:14:01 PM
looks like i should of come up to have my brid in those pics. LOL. But ! i like the way the turbines look on it. I wonder what my tc would look like with turbines.
Post by: thunderjet302 on June 24, 2010, 01:20:43 AM
I like it. I used to have white letters on 8 hole wheels on my T-bird. (http://i198.photobucket.com/albums/aa33/thunderjet302/Northerly%20Island%20Oct%2022%20Tbird/Pic181.jpg)
Now with the Snowflakes I run black walls. (http://i198.photobucket.com/albums/aa33/thunderjet302/new%20wheels/Pic001.jpg)
My almost 23 year old factory paint is not as nice as the paint on your Cougar. Sorry if it's not shiny enough;)
Post by: Cougar8775 on June 24, 2010, 10:03:39 AM
hey thunderjet302 whats the color code for that gray? I may paint the top half of my tbirf that color. But below the trim line it will be black.
Post by: Watchdevil on June 24, 2010, 11:23:34 AM
Quote from: daminc;326290
Hows this.... no wire wheels................... (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0026.jpg)
:bowdown::bowdown::bowdown::bowdown::bowdown: I need a bucket to catch my drool! Those turbines rock on that Kitty!
Post by: thunderjet302 on June 24, 2010, 01:24:02 PM
Quote from: Cougar8775;326358
It's 91 Smoke Metallic. My paint code is 9Z Silver Metallic/91 Smoke Metallic Tu-Tone.
Post by: Kitz Kat on June 25, 2010, 02:13:15 PM
That looks like shiznit!!LOL. I think I supplied about a 1/3 of the parts on it. Looking good Jerry.
Post by: FLSTCI71 on June 25, 2010, 02:36:43 PM
On a bird, I like the turbines, 10 holes and snowflakes. On a Cougar, I like the turbines and 10 holes. However, I am thinking on Jerry's car, I would like snowflakes too!
Post by: 50tbrd88 on June 25, 2010, 03:44:36 PM
The turbines and white letters look great.
Post by: Kitz Kat on June 25, 2010, 05:16:18 PM
Quote from: FLSTCI71;326443
I have a set of snow flakes to, if he want's to swap out every week or two.
Post by: daminc on June 25, 2010, 06:38:49 PM
I'm good kitz. Someone should photoshop some snowflakes on to see what it will look like
Post by: Cougar8775 on June 26, 2010, 05:47:48 AM
Well i supplyed the most important part... The SC trans! lol
Post by: daminc on June 26, 2010, 08:34:03 AM
There's a lot of people here who contributed to this project in one way or another. Only 1 drivable bird was sacrificed to aid in the rebuilding...... These guys are responsible for the big ticket rust free items on the car, like doors, hoods, trunk lids, quarter panels, rear ends, etc.... If it wasn't for Mike (FLSTCI71) and the rust free quarter panels, the car would have been stripped, and sped 2 years ago. Cougar8775 FLSTCI71 Haystack Kitz Kat vinnietbird
And for the hands-on help... because he only lives 20 mins away baxo
If I left anyone out, give me a pm....I got a ton of parts in 2 years and it's early today... lol Also, if I got any parts from you... Even a light bulb, send me a pm, and I will add you to the list of credits that's going to be on the 1st page of the project thread.
So we're actually getting closer to the end of this project. All that's left to do is the motor/AOD....brakes/ lines, and fuel tank/ lines, and exhaust. everything should be done before winter except for the exhaust. I plan on that for the winter months, along with the little ods-n-ends.
I may be putting the tank and lines in this weekend. stay tuned for a report ..........
Post by: daminc on June 26, 2010, 05:51:08 PM
Got the tank all ready to install Needed to do more building to put it in. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0040.jpg)
then I took it back out so I can put 1 last coat of paint under my car. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0045.jpg)
Time to find my gaskets, locking rings, fuel lines and senders..... Should have it in tomorrow... ;) Quads are next on the install list
Post by: daminc on July 02, 2010, 05:16:16 PM
Todays update.... Got the tank in and everything connected to it. started running the fuel lines along the frame, but I'm going to put another coat of paint underneath the rest of the car so I didn't go crazy fastening anything yet.... Pics to follow in a little bit.
I also repainted everything in the rear end area of the car before I installed the tank. Looks new again. I still want to spray the inside of the frame, but I'm waiting until I get everything bolted back on it first..
Post by: daminc on July 02, 2010, 07:49:32 PM
Pics of this weeks update.... (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0051.jpg)
pics of my modded pump upgrade. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0053.jpg)
finish painting of the back end before the tank goes in (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0056.jpg)
My little space between the frame for the fuel filter. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0069.jpg)
and the filter bracket (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0070.jpg)
tank bolted in (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0073.jpg)
I think I need to replace this section... Anyone know what to use to splice a new section of hard line to the existing lines???? (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0072.jpg)
That's my update for the week. more painting underneath, and brake lines are up next... oh yea... I almost forgot..... The car is so stiff with the frame underneath it.... 1 jackstand under 1 side will hold up the entire back end of the car. I'll try to get a pic of that... but it won't be from underneath it. that's for sure.. ;)
Post by: Watchdevil on July 02, 2010, 10:14:00 PM
I like seeing that you had the tank down. It makes me dread less that eventually I will need to drop the tank and change out the sending unit for one that works opposite. It will give me a good chance to inspect the fuel pump and lines inside the tank as well.
Post by: daminc on July 02, 2010, 10:50:04 PM
My advantage is that everything was pretty clean going back in. My hands were actually still clean when I got done. Never seen that happen before working on a car. lol
Post by: Cougar8775 on July 02, 2010, 11:06:03 PM
on those sub frame connectors it almost looks like the rear sub frame should of had the end of the connector boxed in... or had a plate that went from the connector you made to the rest of the frame. But im going to have to come up with a sub frame connector for my project:evilgrin:
Post by: daminc on July 03, 2010, 01:30:49 AM
there is a plate that goes from mine to the frame It's pretty much like this when it was finished. I got a good pic somewhere after it was welded in (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Pass%20side%20rebuild/frame%20rails%20and%20connectors/IMG_4003.jpg)
Post by: vinnietbird on July 03, 2010, 06:50:17 AM
Quote from: Watchdevil;327125
If you make sure the tank is almost empty,you'll be surprised at how easy it is to drop and re-install.
Jerry,everything looks great.It is nice to be able to work on something under the car and come out still relatively clean.I also enjoy that feeling with the Sport.
Post by: Thunder Chicken on July 03, 2010, 07:26:58 AM
For connecting new hard line to old hard line I'd just go with compression fittings.
Post by: daminc on July 03, 2010, 07:48:47 AM
Is there a connector to splice the plastic lines to the hard lines? Or a replacement section that goes to the plastic lines to the motor?
Post by: daminc on July 03, 2010, 08:06:49 AM
Wait...... I think I found a Doorman connector that has a barbed insert for the nylon end, and a threaded compression end for steel. 4 of those, and some stainless lines should fix me up.
Post by: daminc on July 03, 2010, 06:27:52 PM
last coat of paint under the car... (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0091.jpg)
Here you go John... This is where the frame is welded to the connector. Needs some painting touch up still. I'm going to have to take it to my friends garage on a Saturday and borrow his lift to get to some of these hard to reach places. Unfortunately, I need to drive it there to do it. So it'll have to wait a little bit. I'll probably shoot the insides of the frames while I have it there. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0088.jpg)
header clearance on the P-heads. this side should make it ok (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0078.jpg)
This side is going to be a little different. I'm going to cut the 4th tube and move it above the rest of the tubes. There won't be any smog pipes along this side to interfere with doing this.... It's always something. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0077.jpg)
Post by: Cougar8775 on July 03, 2010, 11:27:59 PM
ahh i see now what ya did. I should get the drawings from ya to use on mine. Cuz lets just say she will be getting alot more HP and toque thrown at her. And that 4 banger will be gone.
Post by: daminc on July 04, 2010, 11:04:24 AM
Quote from: Cougar8775;327220
yell when you need it. I'll send it over to you
Post by: Cougar8775 on July 04, 2010, 11:17:40 AM
thanks. Its gonna be fall before i need it. I got to get another core support. cuz when i got the front apart again and found how bad it is. the pass side part of the core support was cut and welded back in and it pushed in to the center of the support bout an inch or so. But the 4 banger is out ad the 351W will be going in. So i have to stiffen the whole car up first.
Oh and what have you done to me!?!?!?!? Now im drinking molson canadians later today. Got my fridge full of it. And going to enjoy some fireworks too. But you have a good 4th! And everyone here!
Post by: thunderjet302 on July 06, 2010, 05:37:17 PM
Quote from: daminc;327192
A quick mock-up of the motor. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0080.jpg)
The FRPP GT40P headers that I have make plug changes sooo easy;).
Oh and don't forget a fuel pump block off plate for your timing cover.
Post by: vinnietbird on July 06, 2010, 05:48:56 PM
I found aluminum finned valve covers with no wording.Just like these,but only fins. Pull the vacuum port on the lower front above the driver side valve cover,tap the hole and plug it.It won't be used. Oh,don't forget to remove the front mold line on the upper.LOL.
Post by: daminc on July 06, 2010, 09:50:59 PM
Quote from: vinnietbird;327489
I was going to get a set too, but I couldn't pass these up for the price. Yes Vin... I'll remove the lines next chance I get. lol
Post by: daminc on July 06, 2010, 10:20:48 PM
Guys, There's probably a bunch of things I need to plug, cover and omit.. When I actually get to the putting together stage, I'll ask what needs to go piece by piece. Because I haven't got a clue what you guys a re talking about. Remember me?....I'm clueless about motors... lol
Post by: vinnietbird on July 07, 2010, 11:46:15 PM
On the upper intake,you may need to cut a small little notch in the back side of the lip that the intake plate sits on for the "salt and pepper" shakers to hang from.Check a stock intake,and you'll see what I mean.I polished my intake and added the FPV emblem,and was just about to bolt it down when I realized I forgot to do that on this intake.I broke out the Dremel and handled it asap.How's everything else coming along?Anything I can do?
Post by: daminc on July 07, 2010, 11:58:11 PM
Vinnie, if you were a few thousand miles closer, you'd be putting this thing together for me. :D
Post by: vinnietbird on July 08, 2010, 12:00:41 AM
That would make me happy.It sure felt good to install the roller rockers on mine tonight.I needed that.....therapy.
Post by: daminc on July 15, 2010, 09:56:27 PM
A couple random pics while I was working on the car One of my favorites. I like the look of the lower part of the doors without the moulding and chip guard. still needs sanding and buffing. I got some orange peel behind the rear wheel well (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0089.jpg)
another under shot with the tank frame in the background (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0090.jpg)
might be the last time outside. It keeps getting heavier every time I put more stuff back on. I almost couldn't push it back in the garage after the tank got bolted back on. lol I also washed the glass inside and out (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0100.jpg)
still my original grille, and a lot of dust on a black car (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0101.jpg)
Post by: Watchdevil on July 16, 2010, 03:07:46 AM
Lookin' Fine!
Post by: vinnietbird on July 16, 2010, 07:12:28 AM
I agree,I think it looks a lot better without the center trim om the doors.It's nice to just step back and look at it isn't it?
Post by: daminc on July 16, 2010, 07:16:06 AM
Quote from: vinnietbird;328424
It sure is nice. Especially after 2 years of rebuilding it. I may just mount it on a large piece of wood and hang it over the fireplace. lol
Post by: thunderjet302 on July 16, 2010, 01:41:30 PM
Quote from: daminc;328388
My T-bird has that chip guard. I've seen some cars with it and some without it. Does anyone know how many cars had it or if it was an option?
Post by: jcassity on July 17, 2010, 08:17:22 AM
Quote from: thunderjet302;328449
I think there are more cars with it than without.
are you dropping in some trim inside the molding?
good work on this cat, your a dying breed and they're not replacing you.
Post by: daminc on July 17, 2010, 08:30:44 AM
Quote from: jcassity;328532
I am. Just have to find the correct 7/16 chrome that's close enough to match the original shape. looks like a winter job to me after its buffed.;)
Post by: Cougar8775 on July 17, 2010, 09:10:45 AM
i know you can get some chrome trim at the parts store. it comes in different sizes and its in a roll. but i don't know if thats what you want.
Post by: daminc on July 17, 2010, 03:45:07 PM
yea, I was looking at some chrome trim profiles, and they all seem to be half oval. I'm in no hurry. I'll keep looking.
Post by: Watchdevil on July 18, 2010, 03:06:50 AM
Quote from: Cougar8775;328536
Chrome trim at the parts stores is not always the best. I have used this stuff on a couple of cars, including my former Ford Escape and around the grille on my current Mustang. That stuff crinkles and seperates after a short period of time. With my new Mustang I have to replace it every few months so it looks right. I would certainly try a high quality supplier off the internet.
Even the chrome trim that was OE supplied on 1996-97 Cougar bumpers was not high quality as the thin chrome foil started lifting and crinkling already brand new out of the package.
Anyway, when it comes exterior refinishing time on my Bird I have to consider what I want to use for protection and accent because I think plain just looks too bare and base stripper model looking because the bodysides are rather slab sided, unlike my Mustang which has sculpted contours. The grooved lower body side lines on the 83-85 cars make it look like something is missing. Also thin standard moldings like those OE on the same year Cougars seem to look base model to me.
However ic's black kitty looks really clean and nice without the molding and I think it is because the lower bodyside lines were simplified for the 87-88 models.
I have seen nice aftermarket moldings recently which are body color paintable but has a chrome strip running exactly middle and centered. Of course there are the chrome inserts available that are top set as well.
Post by: daminc on July 19, 2010, 09:27:46 PM
I'm thinking about covering the chrome strips with a brushed aluminum vinyl covering. It would match the wheels and other parts I painted. if that doesn't look right, then I'll use a chrome vinyl to recover the old chrome. I really like the shape of the original chrome strips that were on the car.
Post by: Watchdevil on July 20, 2010, 12:46:47 AM
Quote from: daminc;328871
It's worth a try to see how it looks.
My challenge will be how to balance the earlier rear bumper cover strip with the newer front bumper cover installed. I am wondering how far off and different the 1987-88 rear bumper cover is compared to the 83-86 one. I may experiment with one to see if it can possibly be trimmed, modified or adapted in some way. The 87-88 body side moldings do seem to hold up better over time than the 83-86 ones. Which reminds me I shoud have grabbed the plastic front fender to bumper cover moldings on a TC I seen. I wish they were made of plastic like this all around.
Post by: ProTouring442 on July 20, 2010, 08:10:53 AM
Use 3M DiNoc and it won't peel.
Shiny Side Up! Bill
Post by: jcassity on July 20, 2010, 09:09:24 AM
thats basically what i did to my 20th, i used vinal electrical tape though but used "sunburst" gold spray.
its in the body / appearance section.
no one i know of has found the correct molding yet. i've found much molding out there but nothing like ours. not sure what its called but it sure as heck isnt any of that half round stuff.
Post by: vinnietbird on July 20, 2010, 07:41:51 PM
I used what I had from Aerobird Motorsports (way back when).It was really good stuff.It had the right shape to it.
Post by: daminc on July 20, 2010, 07:45:53 PM
Yes, the shape is the key. ours are more rectangle.
Post by: vinnietbird on July 20, 2010, 07:56:50 PM
I'm doing some searching.....Mine is 7/16 wide.I'm checking some on Ebay right now.Stay tuned.
Post by: daminc on July 20, 2010, 08:19:08 PM
I can get you a pic later of just the chrome strip 7/16 x 3/8 I think
Post by: daminc on July 31, 2010, 10:58:50 PM
more putting back together. finally found my door locks after 2 months of searching. lol
had to do a little fine tuning to get them in. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0200.jpg)
then I had to seal the edges so they don't rust (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0203.jpg)
then to open the door panel copuppies. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0204.jpg)
yeah, I know... these ratty old things. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0205.jpg)
a little radiant foil first. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0206.jpg)
and... back together (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0208.jpg)
also found all my books and info in the map pocket (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0212.jpg)
also found the tag that was on my windshield. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0209.jpg)
Post by: vinnietbird on July 31, 2010, 11:03:55 PM
Beautiful.The red and black look great together. I am surprised you didn't get a set of the red Sport style seats,though. I have a question...what kind of tweaking did you have to do for the outer door handles? I'm about to install new ones on the Sport.....again.
Post by: daminc on July 31, 2010, 11:11:36 PM
I actually had to drill new holes because they were to high for these handles. also a little reaming in the slot along side the handle. nothing to serious.
as for the seats. it's tough to find anything that's even close to the condition of my seats. they're also very comfortable and feel like they did when the car was new.
Post by: vinnietbird on July 31, 2010, 11:28:59 PM
High holes....that's what the problem is. I didn't think of that.That's what I've had the issue with on these handles.NOW I can approach it from a better vantage point.THANKS. Looking good,Jerry.Build a room in the house and just keep the Cougar in there for display.I'm ordering the passenger side handle right now.I have the DS handle in the garage waiting.
Post by: daminc on July 31, 2010, 11:37:46 PM
actually I had 1 handle from China that the hole was in the wrong spot for the pass door. And the drivers handle was from Taiwan, which bolted right in perfect. the drivers handle package had an inch of dust on it though when it came. lol
Post by: Watchdevil on August 01, 2010, 01:25:13 AM
Looking great there and I have enjoyed seeing the progress the entire way through!
Post by: sarjxxx on August 01, 2010, 01:46:49 AM
Oh, my, goodness.
I've glanced at the first few pages of this thread before, but never got around to reading 240+, now I just skipped to the end, this is the first I've seen of the nearly finished? product. Holy shnikeys. Your car is great looking and I can't believe it has "evolved" from what it was. Awesome. Just awesome.
Post by: daminc on August 01, 2010, 11:58:08 AM
Quote from: sarjxxx;330209
Oh, my, goodness.
Then you probably missed the fun part where I replaced the front frame rails and rad support. ;)
Post by: daminc on August 01, 2010, 12:00:58 PM
I think I'm going to make a video slideshow of the work done start to finish, so new people don't have to actually read 250 pages unless they want details of what I did during the project.
Post by: daminc on August 01, 2010, 12:03:43 PM
Quote from: Watchdevil;330203
Thanks, It's kinda sad that it's coming to the very end. But I've had a lot of free time now to do the things I've been wanting to do in the last 2 years.
Post by: Watchdevil on August 02, 2010, 12:07:25 AM
Quote from: daminc;330236
If I ever near the end of my resto it might be sad too and I may have to find another project to work on! Funny thing is that I have worked on my car so much the past several months that I don't know what to do with the down time I have when I have to hold back until I can afford to do more. I wish that I had more skills than I do. A lot of mechanical stuff is going to have to be farmed out. I cannot rebuild or mod an engine although I can certainly replace anything that bolts on externally. I also don't have the tools and facilities to do a lot of stuff that I know I can do if I had those resources. Sometimes I feel like a complete wimp when I see what some of you guys can actually do for yourselves!
Post by: daminc on August 04, 2010, 08:28:40 PM
got almost all my accessories and brackets cleaned up and painted for my motor. Pics to come this weekend. Header tubes for the re-route are on the way... This is going to be awesome. lol
Post by: daminc on August 05, 2010, 10:26:40 PM
A few pics of what I've been working on.
new chrome trim (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0242.jpg)
got my tubes to re-route the one tube in the way of my plugs. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0246.jpg)
blacked out the chromed badges and emblems. gives it that evil Marauder look. (Looks a lot better in person) I stuck them on temporarily to see what they would look like. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0244.jpg)
Post by: ProTouring442 on August 06, 2010, 08:01:22 AM
Lookin' good!
Shiny Side Up! Bill
Post by: Cougar8775 on August 06, 2010, 08:50:49 AM
is that orange peel i see?
Post by: jkirchman on August 06, 2010, 10:47:01 AM
What did you finally decide on using for the chrome strip? I'd like to replace mine when I have the car painted.
Post by: daminc on August 06, 2010, 03:57:45 PM
Quote from: Cougar8775;330955
yep :D
Post by: daminc on August 06, 2010, 03:59:48 PM
Quote from: jkirchman;330965
Found some old stock moulding....The box was very dusty and had a 1992 date on it.
Post by: HAVI on August 06, 2010, 06:01:24 PM
Quote from: daminc;330988
See what happens when the garage gets cleaned?
Post by: daminc on August 06, 2010, 06:13:52 PM
Started to figure out where everything bolts back on today. This is really tough seeing that when I took everything off, it was covered in a thick layer of gunk. Nothing really looks the same as when it came off. lol
I'm liking this color combo so far (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0255.jpg)
Post by: vinnietbird on August 07, 2010, 11:34:29 PM
NICE !!!! You're getting there. Um,I'm going to go ahead and assume you KNOW,that the water pump isn't on yet.....riiiiiiight? LOL.
I spent a lot of my day looking at brackets as well.
Post by: daminc on August 08, 2010, 07:09:47 AM
water pump?.... Where does that go?
lol
Nothing is really bolted on. just looking for where they go. I'll have my new pump on Tues.
Post by: vinnietbird on August 08, 2010, 08:09:21 AM
I ordered my Good Year belt from eBay and got for almost $20.00 cheaper than the parts store. If the parts stores around here could get Good Year belts......which they can't. The Gator Back belts don't tend to get cracks in them like others do due to their "tread design". Your dash piece is going out tomorrow.
Post by: daminc on August 08, 2010, 08:14:19 AM
Send me a link to the belts if they have more
Post by: vinnietbird on August 08, 2010, 08:26:22 AM
Here you go. He had quick shipping,and the belt came in a little box.Perfect part.
Post by: daminc on August 08, 2010, 01:23:20 PM
Thanks for the link........
Did some remodeling yesterday. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0260.jpg)
tried to get the mig into all the spots and make a nice weld, but it was almost impossible with the other tubes in the way. did the best I could. I'll have to do a little more cleaning up before I'm finished. But now there's a ton of room for the plugs. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0265.jpg)
put a silver coat on the covers. they started turning dark already. also have more painting plans for them. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0264.jpg)
Post by: vinnietbird on August 08, 2010, 03:21:35 PM
The valve covers look great. Is ther room for the new header tube to fit next to the inner fender?
Post by: daminc on August 08, 2010, 05:16:06 PM
Quote from: vinnietbird;331174
I'm hopin
Post by: vinnietbird on August 08, 2010, 05:21:44 PM
I never really looked at the distance between my headers and the inner fenders.They fit,so,I was happy. If it's too tight of a fit,just cut a hole in the inner fender for clearance.LOL.
By the way,I was looking at the wood grain dash panel.It looks to be in nice shape (a little dirty),but there are two tiny holes drilled into the base of it.I think,from what I can tell,the shifter panel will cover it.Just to let you know.
Post by: daminc on August 08, 2010, 05:26:01 PM
If they show, I'll tell everybody they're drainage holes.
Post by: daminc on August 08, 2010, 05:31:17 PM
As for the pipe clearance... It might be in Gods hands at this point. If it doesn't fit. then I'll figure it out. I'm like that. It's never really a problem. Even when everybody says it is...
Post by: vinnietbird on August 08, 2010, 05:43:37 PM
I agree. I've gotten so deep that failure just isn't an option. There's always a way if you think about it enough.
Post by: daminc on August 12, 2010, 07:46:25 PM
Here's a dry fit of the center console. Nothings screwed down yet. (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0297.jpg)
got another cover for around the shifter. this one seems to be painted.
still have to remove the column shift, and a bunch of work before I can finish putting it together Guess I need another plate for the bottom space of the dash. I guess I need to blank out the gear selector on the old cluster. I feel like I'm working in reverse on this car. lol
Post by: vinnietbird on August 12, 2010, 07:51:21 PM
There was a plug that covers the dash gear selector. I had one in my other Bird. I see what you mean about the wood grain. Hopefully I have the other panel for you.Stay tuned.
Post by: daminc on August 12, 2010, 08:14:52 PM
What's weird is, My car was always garage kept. Not sure when the fading occurred. then again, It might have never looked like the lower part
Post by: daminc on August 15, 2010, 03:54:22 PM
A couple pics for the weekend. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0303.jpg)
Just for you Vinnie. I did both sides. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0302.jpg)
Other news..... I measured the clearance of the header to tower area.. I should have an inch of clearance at the tightest point.. (if everything goes well)
Post by: hypostang on August 15, 2010, 03:59:29 PM
That sure is purty , but why is there not a 3G alternator ?
Post by: daminc on August 15, 2010, 04:11:26 PM
Quote from: hypostang;332023
Don't know of any reason why I would need one. If this one dies, then maybe....
Post by: hypostang on August 15, 2010, 04:18:50 PM
Fair enough, I changed mine as a preventive measure due to the threat of fire.
Post by: vinnietbird on August 15, 2010, 04:39:35 PM
Thanks a LOT for tending to that mold line.....Now,c'mon and admit it....it made a world of difference and only took a couple of minutes....c'mon......say it.
The engine is looking great.You didn't use the studs for the a/c bracket that are water pump bolts/studs. I used those,but I'm not installing the steel bracket that bolts to the water pump studs and top of the compressor.It stays off. Again,VERY nice,and thanks again for removing the lines.That was really bothering me. I don't know why.
Post by: daminc on August 15, 2010, 05:08:31 PM
Yea, Ok... it looks a lot better now. lol
Nothing is bolted on. It's all temporarily sitting there with just a couple bolts. there's a ton of bolts, brackets and studs to go on. I'll get everything painted up first, then it'll get put together after I get the rest of the stuff painted.. I'm pretty much done as of this weekend. Maybe everything will get bolted on for good next weekend.. We'll see. I still have to paint the dipstick tube and a few minor things though.. Now you can get a decent night's sleep, Vinnie.
Post by: vinnietbird on August 15, 2010, 05:13:52 PM
No kidding.Every time I pop the Sport's hood and look at my intake,I think to myself...."did Jerry fix that mold line problem yet?".LOL.If you need anything,let me know. I'll do my best for you.
Post by: daminc on August 16, 2010, 08:11:34 AM
You'll also notice that I removed the bracket from the side of the intake, and ground out the mold lines there too. You'll never have to worry again when you open your hood. lol It's all good now
Post by: Watchdevil on August 17, 2010, 04:05:10 AM
Quote from: daminc;331629
Just paint black over it...
Post by: Kitz Kat on August 17, 2010, 05:02:58 AM
vroom vroom,looking good.
Post by: daminc on August 17, 2010, 07:17:53 AM
Quote from: Watchdevil;332249
If I paint it, the color won't match. Better to make a cover plate using the same type of material
Post by: thunderjet302 on August 17, 2010, 09:27:13 AM
I still have the column shifter plus an AOD with an epoxy modded valve body. I can do full manual shifting with a column shifter. It's fun:hick:
Post by: daminc on August 17, 2010, 06:04:59 PM
I thought about keeping the column shifter, But I looked at the overly rusted linkage, and just decided to can it all. Doesn't mater now, because I still have it in the vert,
Post by: daminc on August 17, 2010, 06:07:17 PM
started adding the second dark silver color...... It's going to look great..... I don't even care if it runs now.. lol (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0311.jpg)
Post by: vinnietbird on August 17, 2010, 06:22:46 PM
Finish putting it all together and just set it in the corner of the living room to look at.....it IS art....I wanted to do that with my GT40P engine but the boss....I mean my loving Gayle said "NO !!!" ( I think she meant it).
Post by: tbirdsps on August 17, 2010, 07:00:21 PM
I can't imagine a bit of road grime on that engine. It is art. Get a dirty 'ole 302 to install.:D
Post by: vinnietbird on August 17, 2010, 07:04:42 PM
I have just started to accept the fact that I can't keep my engine as clean as I'd like,but,it sure is fun to drive.
Post by: daminc on September 02, 2010, 06:55:25 PM
Things are still happening.. Just a little slower. Got my back tires today. here's some pics and comparison shots of the 2 diff sizes (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0349.jpg)
And also for your viewing pleasure. (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/IMG_0350.jpg)
Post by: vinnietbird on September 02, 2010, 07:02:55 PM
Nice tires.I have 17's on my car,but,I ALWAYS liked the turbines and ten holes.With the right tires,the 15's can look REALLY nice. I see you got mail quicker than I though.Nice. Are you leaving the dip stick handle yellow? It sure beats welding up the other one.LOL.
Nice to see an update as well.
Post by: EricCoolCats on September 02, 2010, 07:11:40 PM
That's thinkin' with your dipstick, Jimmy! ;)
Post by: daminc on September 02, 2010, 08:36:46 PM
Vinnie, maybe porno red for the dipstick ends, to match my wires... Ya never know what will happen.
Post by: 50tbrd88 on September 02, 2010, 08:41:47 PM
Trade you my cobra's for your turbines!! lol. You've done a nice job with your tire sizes. As I always say, white letters are also a good combo with turbines.
Post by: vinnietbird on September 02, 2010, 08:51:22 PM
Quote from: daminc;334537
Red may just work. Why not? I think yellow was applied to them so they were easier to find for those who didn't know the engine at shops or owners who had no business under the hoods.
Post by: daminc on September 05, 2010, 05:08:40 PM
Ok, had to do some fixin..... I busted a line on the rack and had to remove it because.... of course it was the one you can't get to when it's installed. Don't know if I should replace the lines, or replace the entire rack.
It's really nice to work on clean stuff under there. Still weird to not see rust. ;) (http://i784.photobucket.com/albums/yy121/daminc-pics/puttin%20it%20back%20together/IMG_0357.jpg)
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on September 18, 2010, 09:56:56 PM
I'm still here. Just took a little longer to get back to the steering rack. new lines all made, and rack installed. Did you know that you can't buy those lines on the rack? lol
After removing the old lines from the special threaded ends. I re-bent some new ones, and away we go. I guess I could straighten them a little more. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0365.jpg)
and I had to roll the car out today to get to the storage area above, so I took some pics of the new tires and the blacked out badges and stuff. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0367.jpg)
And ewww! Gunkie (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0375.jpg)
Post by: vinnietbird on September 18, 2010, 10:25:24 PM
You did get a new PCV screen didn't you? LOL. Nice lines you made as well. My rack came with new ones installed. The Cougar is looking great.Nice to see an update.It's been a while. How's the engine coming along? I've been wondering the status of the old girl.
Post by: daminc on September 18, 2010, 10:56:50 PM
Engine is still not together. Been working 7 days a week for the last month or so. I did move it to the other side of the shop to start bolting it together. Brake lines are next while I'm still in the bending and flanging mode. lol (hopefully tomorrow)
Post by: Kitz Kat on September 19, 2010, 07:05:00 AM
I was wondering to,been a while since an update.
Post by: vinnietbird on September 19, 2010, 08:06:58 AM
Whether it's bending lines or bolting the engine together,it doesn't matter. Progress is progress.
Post by: daminc on September 19, 2010, 04:45:53 PM
Oh well, no brake lines today. I worked, then had to cut the grass, and close the pool for the year. Tomorrows another day. I thought about working on it for 2 hrs while I was cutting the grass. Does that count for anything. lol
Post by: daminc on September 25, 2010, 06:47:19 PM
almost done with the motor... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0391.jpg)
Post by: vinnietbird on September 26, 2010, 12:02:07 AM
Very Nice Jeddy !!! That will look great in the Cougar's engine bay.I'm proud for you. Be cautious about the black a/c bracket.They have been known to make ugly contact with the TC hood scoop.I left mine off with no problems what so ever. I've also seen people remove some of the metal from the top of the bracket. Hopefully you won't have any issues,but,just something to watch for. I am surprised you didn't go with a 3G alternator.
Post by: Kitz Kat on September 26, 2010, 04:37:26 AM
Your keeping the air pump on? Looking good Jerry. Like Vinnie said watch that ac bracket it will hit especially with chucks's mounts,I shaved the top of mine down.
Post by: daminc on September 26, 2010, 07:50:36 AM
Well, the bracket is on for now. I'll see what happens as I go. What do I need a 3g for? Kitz, the air pump goes nowhere
Post by: jcassity on September 26, 2010, 10:18:17 AM
if your tie rod ends are really floppy or easy to move, adjust the inners now.
there are two types of inner knuckles in coupld different way.
one type goes like this....
loosen dust cover clamp and slide dust cover outward locate allen set screw on the outside of inner knuckle and loosen remove knuckle from rack by using a cresent look inside knuckle and there will be a small hole in the center inspect hole and if its hex shaped, then find an allen to fit it. Rotate allen wrench ccw a few turns this means you are rotatinga disc in the inside of the knuckle remove allen wrench and then inject grease up into the ball joint through the allen hole. rotate inner ajustment disc until your ball joint now is snuggly attach assembly back on rack/pinion until snug only tighten allen screw down to lock it in place. get alignment after both sides done.
the other type goes like this....... get dust cover slipped off and to the side locate what appears to be an allen screw, discover its actually a hammered in roll pin. get a screw to thread into the roll pin then slap hammer it out remove inner tie rod from rack look into the knuckle of the inner tie rod and discover a plastic disc in the center with a tiny hole. if disc in the center is a plastic one then add grease inside knuckle install inner tie rod and the grease will purge through the hole and out into the knuckle. keep tightening the inner until the knuckle doesnt flop around too easy but is snug. add a new roll pin to the outside of the nuckle locking it in place.
the only reason i posted this is because the rack is a pita if you dont repair or do some pm while its out.
also, for the future, you can lob off part of the control arm pan head portion of the bolt so it can be easily taken out later. see what i did in the pic below.
Post by: daminc on September 26, 2010, 10:39:03 AM
all the front end parts were new the year I took the car off the road. I just replaced the lines on the rack last week, so everything should almost be new in the front now.
Post by: vinnietbird on September 26, 2010, 01:30:59 PM
The 3G is a great alternator. The stock one barely can handle the load.With the 3G,I can have the heater on,all of the lights (and fog lights) stereo,defroster,and no dimming head lights at all.Plenty of juice when the car needs it.It's a 30 minute to an hour job from start to finish.One of those " I wish I'd done this years ago" kind of jobs.
Post by: daminc on September 26, 2010, 02:04:33 PM
there's no way I'll ever have all that stuff running at once. I'll probably never drive it at night anyway anymore. the defroster will probably never be turned on again either. lol I have used the lights 2x on the vert so far, only because they have to turn them on to inspect it. lol... My power needs are simple nowadays.
Post by: hypostang on September 26, 2010, 02:37:29 PM
Not to mention the risk of fire with the 2G is eliminated, but it is not a necessary upgrade .:D
Post by: daminc on September 26, 2010, 03:12:28 PM
Quote from: hypostang;336784
LOL, if I was worried about fire, I would have replaced my ignition switch years ago... It's still all original.. :D
Post by: hypostang on September 26, 2010, 04:41:01 PM
Quote from: daminc;336788
lol, if i was worried about fire, i would have replaced my ignition switch years ago... It's still all original.. :d
doh !!!!!
Post by: vinnietbird on September 26, 2010, 08:29:42 PM
Quote from: daminc;336777
Well,then you're good.LOL. I think I still have my new 2G in the garage somewhere from when I did my 3G upgrade.
Post by: 1Bad88tbird on September 26, 2010, 09:09:59 PM
What car does the 3g come from? I've never done the swap either.
Post by: vinnietbird on September 26, 2010, 09:21:33 PM
I got mine from a 3.0 Ford Taurus engine.Super cheap and still rocking after 4 years or so.I polished mine due to boredom.
Post by: 1Bad88tbird on September 26, 2010, 09:32:31 PM
Does it matter what year? The last time I was at the jy there was quite a few there. Haha, you just like shiny stuff.
Post by: vinnietbird on September 26, 2010, 09:35:52 PM
Any 3.0 Taurus I've seen had them,and they all have been correct.
Post by: 1Bad88tbird on September 26, 2010, 09:40:45 PM
Sweet, as always thanks for the info!
Post by: vinnietbird on September 26, 2010, 09:46:49 PM
Jay,I have no secrets.........except the stuff I don't want to tell anyone due to secrecy reasons.LOL.
Hey Jerry,Are you using 1.6 or 1.7 roller rockers? I was thinking you said 1.7,but couldn't remember. I've got two sets of 1.7's coming to me.Crane Gold and Cobra rockers.One set is going on the sport,the other set and my 1.6's are going to new homes. That should pay for the window tint when I sell them.I REALLY want to get that done asap.
Post by: daminc on September 26, 2010, 10:16:56 PM
Quote from: vinnietbird;336872
here you go... never to see the light of day again (http://i784.photobucket.com/albums/yy121/daminc-pics/new%20motor/P6120004.jpg)
Post by: vinnietbird on September 26, 2010, 10:45:51 PM
Nice. We really need "see through" valve covers.LOL. Mine are currently polished aluminum,and too nice to cover up.I am unsure which 1.7's I'll use.The Cobras are brand new,and the Crane Golds are also nice.Oh well,one stays,one goes.
Aaaaaanyway....back on the Cougar topic...odd question,but what steering wheel are you going to be using? I was wondering when I was looking at my spares. I like the TC wheel over the Sport's stocker due to the thicker wheel. I didn't know if you were swapping, or keeping the stocker installed, or maybe going aftermarket. If I could find the "right" wheel, I'd go after market. I can't seem to find one I like enough.
Post by: daminc on September 26, 2010, 10:48:59 PM
I'm keeping my stock leather wheel
Post by: vinnietbird on September 26, 2010, 10:57:33 PM
10-4 on the leather wheel. I'm probably going to swap mine out after I get the seats re-covered,then hopefully I can get one that matches the seats and interior as a whole and looks like it belongs,not an after thought.I want the Sport to look great when I'm finished.I did the wash,claybar,and wax for the Sport followed by an interior cleaning after work today. I swear,the Sport runs stronger after I detail her.I still have to do the engine,but I'll get to that.
Post by: daminc on September 26, 2010, 11:10:13 PM
what exactly is a clay bar?
Post by: turbo_88_XR7 on September 26, 2010, 11:36:11 PM
Quote from: daminc;336880
alright, i'm jealous.. my steel rockers look like compared to those.. and i'll be seeing mine more often than you'll see yours :(
Post by: vinnietbird on September 27, 2010, 06:48:04 AM
Quote from: turbo_88_XR7;336892
I can fix that problem for you if you have some cash.
Jerry,look at the detail section of your local parts store,there,among the washes and waxes,is a clay bar kit.It's by Maguires. It comes with two clay bars,a small bottle of wax,and a detail spray.You clean the car to remove the dirt,dry it,then,panel by panel,spray the detail spray onto the car and rub the clay bar over it (the spray acts as a lubricant for the bar).It removes bug ,residue that washing often can leave behind,swirl marks,and cleans down to the paint and/or clear coat,but totally safe for the paint.Then,I use Mother's,or Maguires Premium wax.It's awesome.Gayle's black Maxima looked wet even though it was dry when I was done with it.Awesome product.
Post by: daminc on September 27, 2010, 07:34:27 AM
I'll give it a try on the Lincoln this winter.. Always looking for a warm project while the snow is flying outside.
Post by: daminc on September 27, 2010, 07:45:35 AM
I didn't know mine would look like that until I picked it up... the guy from the shop actually stopped over a couple weeks ago to see if it was running yet.... of course it wasn't , but he liked what I had done to it so far, and was impressed by the Cougar it was going into.
Well, there's a few minor things to put on it still.... I should have those done this week.... Going to do some welding on the headers too. the drivers side header has holes in it that I found after blasting it. if it's to perforated and thin from rust, then I'm going to have to get a set of P headers and s the project I already started..
The AOD is next... Painting, filter, gasket, maybe new pan. I'll see what it looks like after it's off... Still need a torque converter though.. Thinking in the 2400 range. Anyone got one they want to let go of?
Post by: Bob on September 27, 2010, 09:16:35 AM
Looks good, The rocker on the #2 cyl looks like its not centered on the valve from the picture :D
Post by: Cougar8775 on September 27, 2010, 09:26:30 AM
hey jerry when i got the trans i put a new filter in it along with pan gasket. all you got to do is repaint the pan and its good to go!
Post by: daminc on September 27, 2010, 01:09:20 PM
Quote from: Cougar8775;336916
Oh, cool. Thanks.
I may need a hand putting it in. Sheila's dad had shoulder surgery, and is out of commission for quite a while.
Post by: vinnietbird on September 27, 2010, 04:21:21 PM
Rent a transmission jack, or get the tranny jack that fits on your floor jack. Makes the job a LOT easier,and makes it where one person can do the job fairly easy.
Post by: daminc on September 27, 2010, 06:09:03 PM
It's all going in at once Vin...
Post by: thunderjet302 on September 27, 2010, 06:17:39 PM
Are you running 19lb injectors on your engine? You have the same engine I do (down to the cam) and I run 24lb injectors......
Post by: daminc on September 27, 2010, 06:29:03 PM
Quote from: thunderjet302;336962
For right now I am. I couldn't pass up the price. and I had diff plans 2 years ago for the ....Well, for everything. lol
Post by: vinnietbird on September 27, 2010, 10:50:15 PM
If it's all going in at once (The best way......that's how I did it),an adjustable engine lift is nice.Goes on the engine hoist,and by simply turning a crank,the engine tranny combo tilts to fit your needs as it's going in. I wish I was close so i could help.
Post by: daminc on September 27, 2010, 10:54:50 PM
Don't worry, I'll take a ton of pics. It'll be like your there.
Post by: daminc on September 27, 2010, 10:59:37 PM
Just thinking about it....2529 posts, 253 pages, and 59,000+ views.... No wonder I'm so tired
Post by: vinnietbird on September 27, 2010, 11:17:27 PM
I only contributed a tiny fraction of those,and I'm also tired....LOL. The pics will help me a lot.
Post by: Cougar8775 on September 28, 2010, 07:35:54 AM
well let me know and ill give ya a hand with it. But let me know what day and all so i can get the time off and cash together. Or even my wife to get time off to go.
Post by: thunderjet302 on September 28, 2010, 04:41:02 PM
Quote from: daminc;336963
You *should* be ok with 19s for awhile. I ran 19s for a year but switched to 24s because the 19s were getting close to 100% duty cycle at WOT.
Post by: turbo_88_XR7 on September 28, 2010, 04:44:06 PM
Quote from: daminc;336991
it's like a small novel.. hahah
Post by: daminc on September 28, 2010, 05:26:43 PM
Quote from: thunderjet302;337047
This is going to get me running, so I can do what I need to finish the car and make it drivable and get it inspected. Then all the upgrades can come as they come.;)
Post by: vinnietbird on September 28, 2010, 05:27:44 PM
I'll get 24's and a new Mass Air meter one day.For now,no fundage for the poor girl,so,I'm making it up to her with love and cleaning.......and some more love.
Post by: daminc on September 28, 2010, 05:32:15 PM
Quote from: Cougar8775;337015
It wouldn't be till at least the middle of October. I'm going away in 2 weeks for a while. :D
Post by: Cougar8775 on September 29, 2010, 07:22:57 AM
is this the annual mass trip?
Post by: daminc on September 29, 2010, 07:47:50 AM
Quote from: Cougar8775;337127
No, we're going to the mts (Lake Placid region), and Long Island to visit some relatives, and friends this time around
Post by: vinnietbird on September 29, 2010, 07:57:03 AM
I saw the movie Lake Placid......stay away from the water...There are Ginormous alligators there that WILL kill and eat you.
Post by: daminc on September 29, 2010, 08:19:27 AM
I'd worry about Betty White more then an alligator. She's psycho nuts... lol
Post by: vinnietbird on September 29, 2010, 08:32:19 AM
She may be nuts,but she's HOT. What a honey !!!!
Post by: daminc on September 29, 2010, 05:22:54 PM
LOL, your a nut
Post by: vinnietbird on September 29, 2010, 05:30:04 PM
Not necessarily by choice............And as long as Gayle is happy,I'm good.
On another note...I got a mint dash for the Sport today. I'll have to dye it,but I have no issues with that.I got a few more parts as well.They only had one Fox out there.
Post by: Watchdevil on September 30, 2010, 12:48:47 AM
Quote from: vinnietbird;337192
A mint dash? I would figure that would match your mint green... ;):rollin:
Post by: daminc on September 30, 2010, 07:30:39 AM
Quote from: Watchdevil;337262
LOL, I can't believe I missed that one
Post by: vinnietbird on September 30, 2010, 10:17:43 AM
HEY !!! My car is NOT mint green....it's "Green Effect"......more metal flake celery color,thank you very much.LOL
Post by: daminc on September 30, 2010, 01:44:52 PM
Went to the local shop where they make custom and performance torque converters today. met a bunch of cool guys who made me a converter, pretty much while I waited (took an hour or so)...They put it in the box for me while it was still warm........ And that's the last piece I need to put the engine in the car....
Post by: vinnietbird on September 30, 2010, 01:50:39 PM
Sweet !!! Now the assembly wheels are turning,aren't they? LOL. Get busy. It's a good time to replace the front and rear tranny seal before assembly. Cheap and easy to do,takes a couple of minutes as a "just in case". Glad to hear those guys were good folks. From what I read about them,they seemed to be good,knowledgeable people.
Post by: daminc on September 30, 2010, 01:56:29 PM
Yep, they are a small local shop that started to sell on the net and ebay. They do almost all custom, and performance stuff. and of course your daily driver rebuilds.
He said they will be starting to make AODE converters soon.
Post by: daminc on September 30, 2010, 04:38:52 PM
Here it is....... made just 3 hrs ago. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0402.jpg)
Post by: turbo_88_XR7 on September 30, 2010, 05:12:40 PM
Quote from: daminc;337332
:banana: how much did it run?
Post by: FLSTCI71 on September 30, 2010, 05:13:46 PM
That's cool. Too bad no one will see it after you're done. Maybe you should write "Jerry was here" on it before you install it.
Post by: vinnietbird on September 30, 2010, 05:23:51 PM
Awesome !!! The red cap even has a nipple.That's got to be a good sign.
Post by: turbo_88_XR7 on September 30, 2010, 06:31:37 PM
Quote from: A very wise man
if it has tits or wheels, it's going to give you trouble
:ies: :D
Post by: vinnietbird on September 30, 2010, 08:14:26 PM
Generally the "good" kind of trouble......
Post by: daminc on September 30, 2010, 09:02:36 PM
Quote from: turbo_88_XR7;337343
It hasn't run yet...:rollin:
Post by: daminc on September 30, 2010, 09:03:55 PM
Quote from: vinnietbird;337350
There's 4 more on the other side. ;)
Post by: turbo_88_XR7 on September 30, 2010, 09:05:58 PM
Quote from: daminc;337385
:flip: i meant wallet dent size :giggle:
Post by: turbo_88_XR7 on September 30, 2010, 09:07:55 PM
Quote from: vinnietbird;337376
unless it's a dodge :rollin:
Post by: daminc on September 30, 2010, 09:09:21 PM
$200 size dent
Post by: turbo_88_XR7 on September 30, 2010, 09:11:53 PM
wow, that's not bad for a custom converter at all! do they do lock-ups and any stall you would like?
Post by: daminc on September 30, 2010, 09:19:31 PM
here's the website. they also have an ebay store He's been building them for 35 years for all the racing locals ...and the one I have http://stores.bdrtorqueconverters.com/-strse-72/ford-aod-torque-converter/Detail.bok (http://"http://stores.bdrtorqueconverters.com/-strse-72/ford-aod-torque-converter/Detail.bok")
Post by: turbo_88_XR7 on September 30, 2010, 09:20:13 PM
WIN! thanks for the link
EDIT: HOLY SH*T his C6 converters are expensive, just as much as TCI and B&M.. back to the TCI :D
Post by: daminc on September 30, 2010, 09:31:13 PM
I went with him because he's a local builder. If there's a problem, he's 15 min away from me. just like the motor I had rebuilt. he's 10 min away and will help me if I have a problem with anything. also my mechanic said to call him when I get ready to start it up for the first time. He would come over and give me a hand..I find good people that will help a person out, just like I do for people
Post by: daminc on September 30, 2010, 09:32:32 PM
Quote from: turbo_88_XR7;337396
try the ebay store. everything is cheaper there.
Post by: turbo_88_XR7 on September 30, 2010, 09:44:09 PM
don't see anything on their site for an ebay store and i searched for bdr on ebay itself, but wound up with a bunch of stuff that's unrelated
Post by: turbo_88_XR7 on September 30, 2010, 09:47:54 PM
i got it.. eBay search = fail
Post by: daminc on September 30, 2010, 09:49:33 PM
Post by: daminc on September 30, 2010, 09:50:47 PM
hows that price
Post by: turbo_88_XR7 on September 30, 2010, 09:51:30 PM
already found it.. lol thanks.. much better prices :D
Post by: daminc on September 30, 2010, 10:13:17 PM
if you email them or call them, they will make anything you want
Post by: turbo_88_XR7 on September 30, 2010, 11:48:00 PM
they actually have what i'm looking for on eBay for the capri.. 32-3500 stall
Post by: Cougar8775 on October 01, 2010, 07:29:41 AM
hey jerry there is no reason why when we stab her in there that we can't get it fired up that day.
Post by: daminc on October 01, 2010, 07:44:58 AM
not as long as I have everything else to finish it. still no fuel lines in the engine bay. and the computer needs to be repinned for mass air, headers still need to be finished. I got a ton of work before I can turn the key still. but putting it in will make all that happen a lot easier. have to find my coolant stuff too, redo trans lines etc.....
Post by: The Shredder on October 02, 2010, 12:20:46 AM
Jerry, I'm relatively new to this forum and recently stumbled on this project thread.
Just so you know, I have been COMPLETELY unproductive the last 3 days at work because I have read your ENTIRE catalog of this project. It IS like a novel and I couldn't put it down! I love it. And the last chapter hasn't even been written yet!
I am amazed at your skill and determination to complete this project. Your cougar looks fantastic. But your labor of love for this car is nothing short of inspiring!
Just two quick things... - A helpful thing when installing the engine and trans together is to jack up the back of the car (on jackstands of course), so that the angle of entry for the assembly is not so severe. I can't wait to see that beautiful engine in the beautiful engine bay (and car). - On your rear hard brakes lines running along your axles to the caliper soft lines... You might need to bend them down right next to the fitting in the bracket to clear the axle snubbers. From the factory, those lines did a tight "S" to avoid contact with the snubbers during suspension compression.
AMAZING!
Now I can get back to work!!!!!!
Jon
Post by: daminc on October 02, 2010, 04:54:11 PM
For those who just caught ... here's another chapter... Got this baby all painted up today. Before and after pics.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0403.jpg)
and the rear calipers to match the fronts... Gotta have porno red somewhere.. lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0409.jpg)
Post by: vinnietbird on October 02, 2010, 08:52:24 PM
Jerry,you need to go back and smooth the molding lines on the tranny. Other than that,looking great.LOL.
Post by: daminc on October 02, 2010, 08:55:55 PM
Quote from: vinnietbird;337661
No freakin way.... lol
Post by: vinnietbird on October 02, 2010, 09:01:14 PM
C'mon....just like the intake.
Post by: daminc on October 02, 2010, 09:08:02 PM
It would seriously take a month to get rid of those lines. They're like speed bumps...lol
Post by: vinnietbird on October 02, 2010, 09:09:52 PM
Then I guess you better get started.LOL.
Post by: daminc on October 02, 2010, 09:10:56 PM
I'll do it the next time I take it out.. I promise
Post by: thunderjet302 on October 02, 2010, 09:11:12 PM
I spent a week detailing the underside of my T-bird then realized that no one can see it unless they are on the ground.;)
Post by: daminc on October 02, 2010, 09:19:31 PM
Quote from: thunderjet302;337674
Bingo... ;)
Post by: vinnietbird on October 02, 2010, 09:21:07 PM
Quote from: daminc;337673
I will hope you don't have to regret making that promise.
Post by: daminc on October 02, 2010, 09:28:26 PM
If I have to do it, I will, I don't break my promises..
Post by: vinnietbird on October 02, 2010, 09:31:46 PM
Will you polish it as well?
Post by: daminc on October 02, 2010, 09:33:15 PM
we never said anything about polishing now.
Post by: vinnietbird on October 02, 2010, 09:37:52 PM
I thought I'd try to sneak that one in there.LOL. When are you bolting the tranny to the engine?
Post by: hcor on October 02, 2010, 09:45:35 PM
engine oil dip stick is yellow, trans should be porno red. Awesome job!
Post by: daminc on October 02, 2010, 09:59:30 PM
Quote from: vinnietbird;337683
When I figure out what I did with the bolts..lol My lift plate is on the way too
Post by: vinnietbird on October 03, 2010, 06:47:59 AM
Bolts are easy. As stated previously by a member,it really helps to lift the rear of the car. Better angle of attack.I put small spares on the front as well to lower the Sport.Made it a breeze.
Post by: Kitz Kat on October 03, 2010, 07:43:38 AM
Jerry your using a floor shifter aren't you?
Post by: daminc on October 03, 2010, 08:06:13 AM
Quote from: Kitz Kat;337730
Yes I am
Post by: Kitz Kat on October 03, 2010, 08:10:20 AM
Don't you need to flip the shifter arm on that one? I can't remember how mine was.
Post by: daminc on October 03, 2010, 08:45:42 AM
Quote from: Kitz Kat;337732
I still have to see about that. let you know later today after I look at my old AOD (thinking the bolts are also with it). if they match, it needs to be flipped. ;)
Post by: HAVI on October 03, 2010, 09:10:49 AM
I have one of each kind, I can take a look if needed.
Post by: daminc on October 03, 2010, 09:15:07 AM
It says on Coolcats, that the arm needs to be pointing down for floor shifter, and the column shift will points sideways.... looks like I'm good to go for that..
Post by: Kitz Kat on October 03, 2010, 10:27:34 AM
I'll look at mine to it's at work.It might be right I can't remember.
Post by: daminc on October 03, 2010, 10:54:33 AM
just looked at my old aod. It's flipped up...... opposite of the new one
Post by: Thunder Chicken on October 03, 2010, 10:56:40 AM
Ok, Jerry, come clean. Where did you hide the flux capacitor? Or was the wrinkle in the space-time continuum untintentional?
Post by: daminc on October 03, 2010, 02:34:08 PM
Lol.. I hate when that happens.....We like to call that "folding space" I got this new medical grade sealed keyboard last year, and I still can't get the hang of the keys. lol
Post by: daminc on October 03, 2010, 02:47:04 PM
the aod from the column shift 3.8 (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0412.jpg)
and I think this is the last of the parts..... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0413.jpg)
I'm going to twist up some brake lines next..... and it will be time to put that baby in. But that won't happen until at least the 23rd of this month I'm going away for a bit first. If I have time I'll do the brake lines before I leave.
Post by: hypostang on October 03, 2010, 03:09:33 PM
Quote from: Thunder Chicken;337745
What is really amazing is October 25th is the day that Marty McFly went back in time , wow :D
Post by: daminc on October 03, 2010, 03:24:35 PM
and, I didn't type 25 when I updated
Post by: Kitz Kat on October 05, 2010, 02:18:55 PM
I looked at my shifter and it's down. so yours is right.
Post by: daminc on October 05, 2010, 05:49:45 PM
Quote from: Kitz Kat;338139
Finally..... Something I didn't have to re-do, repair, or rebuild.. ;)
Post by: daminc on October 07, 2010, 07:00:07 PM
So I figured I could bolt the AOD to the motor today..... First I had to modify the lift plate..... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0415.jpg)
then after I got the motor off the stand, I realized that I was missing a bolt because the last person that put the C6 in the car, didn't put all the bolts in the flexplate. So now this is what I have until saturday when i have more time....... still parts everywhere and no closer to putting it in.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0418.jpg)
Post by: vinnietbird on October 07, 2010, 07:59:06 PM
Closer by the day.Everything is looking great. A couple of questions....are you using the high torque mini starter? You are using the correct bolts for the flexplate.right?
Post by: daminc on October 07, 2010, 08:19:16 PM
Probably going with the mini starter.... the bolts came out of the motor, so I hope they're the right ones... the bolts from the 3.8 were smaller. what bolts belong on the flexplate? do these look wrong? I won't use them if they are..
Post by: vinnietbird on October 07, 2010, 08:30:08 PM
Those bolts don't look anything like the one's I have.They may work fine,I can't say. I ordered new bolts from Ford.had them the next day for $14.00 for the set.I may have an extra set if you need them.
Post by: daminc on October 07, 2010, 08:32:22 PM
did your bolts have the slots in them too..
Post by: vinnietbird on October 07, 2010, 08:34:46 PM
Yes Sir. Do the ones in the pic you posted? It didn't look like it,but,I can't tell a lot. I personally have only seen one style,so,like I said,I honestly have no idea what else may work.I never was faced with it.
Post by: daminc on October 07, 2010, 08:44:17 PM
the bolts from the 3.8 were like that. I tried them first because they looked right. But the bolts were smaller diam. These bolts are what came out of the plate with the C6. since 1 was missing when I took it apart, I'm guessing they probably aren't the right bolts. I'm guessing that they should work. Any theory on this would help, before I bolt things together.. maybe they are old school? the motor come out of a pickup and the C6 came out of an older van...
Post by: vinnietbird on October 07, 2010, 08:49:27 PM
I'm hoping someone else will chime in.Now I'm really curious.I didn't mean to get any confusion started.LOL.
Post by: hypostang on October 07, 2010, 09:00:21 PM
Every flexplate I ever removed had the slotted bolt heads .
Post by: daminc on October 07, 2010, 09:17:03 PM
Maybe I should just buy some and not worry about it. http://www.jegs.com/i/ARP/070/100-2901/10002/-1?parentProductId=744956 (http://"http://www.jegs.com/i/ARP/070/100-2901/10002/-1?parentProductId=744956")
Post by: daminc on October 07, 2010, 09:19:14 PM
Those might not be the exact bolts, but you get the idea.
Post by: vinnietbird on October 07, 2010, 09:28:31 PM
Get them as a "just in case".
Post by: daminc on October 07, 2010, 09:32:45 PM
Almost all the bolts on the motor are arp now. I think i'll get them and be done with it. I'll look for a starter too while I'm shopping for parts
Post by: vinnietbird on October 07, 2010, 09:37:29 PM
We put a 5.0 in my friend's '67 Stang and installed this starter,from this company,two years ago,and it's still working perfectly.He was on a budget and this fit within the cost allowance.....
Post by: daminc on October 07, 2010, 09:40:33 PM
thnx for the link
Post by: vinnietbird on October 07, 2010, 09:53:21 PM
No problem.Hope it helps a little.
Post by: daminc on October 17, 2010, 02:47:35 PM
Flexplate bolts on the way...Mini starter on the way... engine leveler bought, and in the shop.... everything is going as planned so far. I'm hoping for a progress report by Wednesday... Stay tuned this week.
Post by: vinnietbird on October 17, 2010, 04:24:07 PM
Did you get the starter I was talking about? I'm ordering one for the Sport around the first of November.
Post by: daminc on October 17, 2010, 05:50:37 PM
Quote from: vinnietbird;339792
Yes, I ordered that one. Thanks again for the link
Post by: vinnietbird on October 17, 2010, 06:06:51 PM
You're welcome. I got to thinking about it,and I could use another one,and for the price,it's a great deal.
Post by: Watchdevil on October 17, 2010, 07:27:58 PM
Quote from: daminc;339803
I've got my mini-starter on as well!
Post by: hypostang on October 17, 2010, 08:14:04 PM
Quote from: Watchdevil;339820
What is the benefit of a mini starter other than space?
Post by: daminc on October 17, 2010, 08:36:07 PM
weight, torque. all around good looks..lol
Post by: vinnietbird on October 18, 2010, 06:45:58 AM
Quote from: hypostang;339829
Like Jerry stated,weight is a big deal...it's half the weight,and twice as powerful. It does sound like a Mopar starter,but you get used to it after a while (took me a couple of months).LOL. Also,it saves a LOT of space to make it easier to get to exhaust if you need to on the passenger side.The only difference in hook up is you move the starter wire over one on the solenoid,and add one wire from the starter,to the original position of the first starter wire.Takes a minute..
Post by: daminc on October 18, 2010, 09:11:11 AM
and I figured that if I put the old one back in...It would stop working within a week. lol
Post by: vinnietbird on October 18, 2010, 04:39:12 PM
At this point,there's no reason to bolt on old used parts to a basically new engine.
Post by: daminc on November 05, 2010, 06:06:57 PM
Things that happened while we were on intermission.... If you are my friends on Facebook, then you already know about this (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0424.jpg)
Post by: daminc on November 05, 2010, 06:21:02 PM
This thread should give our new host a little use
Post by: daminc on November 05, 2010, 06:37:37 PM
Look Vinnie, no mold lines and cut out the fins where the bracket was on the side of the intake... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0470.jpg)
Post by: daminc on November 05, 2010, 06:38:48 PM
And the car is still high in the front.....Oy (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0467.jpg)
Post by: vinnietbird on November 05, 2010, 06:40:56 PM
I saw those on facebook....still great. Making some serious progress. I was off today and did nothing. I should have taken advantage of the nice weather.Oh well,maybe next Wednesday on my next day off. Keep it up Jerry.
Post by: vinnietbird on November 05, 2010, 06:44:26 PM
the intake looks awesome.I did the same thing,no mold lines,and cut fins.......I did add an FPV logo to mine,though. I think I'm going to paint Ford blue in the recessed areas and re-apply the FPV. That way,the intake will match the engine a little better. I'll do it next week if the weather permits. On the vacuum tube coming from the front of the upper intake,I cut mine off a lot. That vacuum went to the passenger side on mine.
Post by: hypostang on November 05, 2010, 07:20:11 PM
It's looking better all the time :D
The front end should settle down after you drive it a couple of miles .
Post by: 50tbrd88 on November 05, 2010, 07:55:06 PM
Jerry I bought a set of CHE adjustable lower control arms for my 'bird to get rid of the squat on the rear end. They raised it up nicely for me.
Your car is coming together beautifully!
Post by: daminc on November 05, 2010, 09:02:10 PM
Quote from: hypostang;340695
I don't think it's gonna...I was standing on the rad support jumping up and down, and it wasn't even moving....I'm about 215, and it was like jumping on the concrete floor.
Post by: daminc on November 05, 2010, 09:05:17 PM
Quote from: 50tbrd88;340701
thanks, the back looks squatty compared to the back because the tires are huge and the front is up
Post by: hypostang on November 05, 2010, 10:19:57 PM
Quote from: daminc;340707
I'll be surprised if it doesn't come down at least some, every time I have ever R&Rd an engine the car sat real high until it was driven a mile or so . Something about the geometry resetting or something.
l however, have been wrong many times in my life ;)
Post by: thunderjet302 on November 05, 2010, 11:54:12 PM
That engine really wants some 24lb injectors....
Post by: Kitz Kat on November 07, 2010, 05:18:53 AM
Your still missing some weight up front, battery rad etc. With them springs it should settle a little lower. I also thought mine would to but it didn't.
Post by: daminc on November 07, 2010, 08:06:30 AM
I hope so... because my 200 lbs didn't budge it
Post by: daminc on November 07, 2010, 08:07:47 AM
Quote from: Kitz Kat;340810
yours is still high too?
Post by: Kitz Kat on November 07, 2010, 08:26:36 AM
With the moog springs in I think it is, I have the mach 1's I didn't put in yet, Can't find my spring compressor. Kidding don't need it for that.
Post by: Kitz Kat on November 23, 2010, 05:09:28 PM
What's up no new news. You had to have done something!
Post by: vinnietbird on November 23, 2010, 05:12:16 PM
True,it has been a long time.Surely you opened the hood,closed a door,twisted a screw tight.......walked by it.......something.
Post by: daminc on November 23, 2010, 06:10:26 PM
Nothing new...... I did walk past it the other day..... I got it on rollers pushed into the end of the garage with no door (Where I had the vert last year). The vert is in the bay where the 87 was all summer.... Nothing going to happen until after the 1st of the year... there's a ton of dust on it too. lol I don't have any time to even look at it until Jan, I also need a diff set of headers. The others won't fit on either side. Also need an intake spacer and a ton of other things to finish.. I got the motor in, and that's all I was worried about this year.. I also haven't been on here much since we upgraded.... I may do some body work on the vert, seeing that I have everything I need for that, and it won't cost anything..... and find parts for the 87 in the meantime. I'm not really fond of working on motors, so the vert has more interest to me at the moment anyway... it happens when it happens... I really need to make friends with someone close to me to finish the motor stuff on the 87....lol
Post by: The Shredder on November 23, 2010, 11:27:49 PM
Too bad we are not closer! I like motor stuff, but not interested in body work. Symbiotic relationship we could have. :)
Post by: daminc on December 04, 2010, 05:49:53 PM
New grille for the Cougar. All evil looking now (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0661.jpg)
Post by: 1Bad88tbird on December 04, 2010, 09:24:40 PM
It kinda looks like a Marader (spelling?). Looks good!
Post by: vinnietbird on December 04, 2010, 09:36:46 PM
A little bit sinister. .Mr. Vader,your car is almost ready.
Post by: fluke on December 04, 2010, 09:52:25 PM
Love it! Looks great!
Post by: daminc on December 04, 2010, 10:10:28 PM
I still have my original grille if I want to go back. It's still in real good condition. I actually got the idea from a Grand National
Post by: daminc on December 04, 2010, 10:20:17 PM
Here's what I've been modeling my car after......The car I couldn't afford back in 87 (http://i1046.photobucket.com/albums/b463/daminc-pics2/misc%20stuff/BabettesWE4.jpg)
Post by: 1Bad88tbird on December 04, 2010, 10:41:49 PM
My Boss has one, it's such a nice car and he doesn't have any interest in it. It just sits. We told him to put his gulf clubs in it so he'd at least drive it to the course, but he doesn't. I'm sure he's sell it but he hasn't tryed to yet.
Post by: daminc on December 04, 2010, 10:45:53 PM
I see there's one sitting outside at the shop down the road from me. no plates on it either.
Post by: 1Bad88tbird on December 04, 2010, 11:12:15 PM
I'd really like to take my boss's for a ride. He's had some work done to it and a computer chip put in. I guess he got on it pretty good once and it scared him pretty bad.
Post by: jcassity on December 05, 2010, 10:51:54 PM
Quote from: daminc;340812
im interested in how to fix this to. just put new shocks on the rear thinking that was the problem and its not. I dont wanna put adjustable parts up front so i am going to focus on the rear end and add a bracket inside the factory brackets to raise the orientation of my rear shocks.
the squat thing looks like on my car,, and i dont think you will settle with it on yours either.
Post by: Haystack on December 05, 2010, 11:06:30 PM
I was planning on doing shocks on my car too. The rear sits way low. I also have tools I cart around in the back. It gets pretty bad sometimes.
Post by: daminc on December 05, 2010, 11:27:02 PM
I'm going to put air shocks in. I got them in the vert, and they are working great to keep the rear high enough so that I don't rub the wheel wells with the tires. I won't know how the front is until everything is together, and I actually drive it for a bit
Post by: Haystack on December 05, 2010, 11:30:05 PM
I would like to get air shocks. I have some sn-95 springs for the car too. Just trying to figure out what the best thing to do with my car at this point is.
Post by: daminc on December 05, 2010, 11:33:13 PM
I think Vinnie has those and air shocks in his, If I remember correctly.
Post by: daminc on December 05, 2010, 11:36:47 PM
Actually, I may have them in mine...Vinnie sent me some springs, and when I put the car back together with the new tubular parts, the rear dropped about 1 1/2" from the original springs.
Post by: daminc on December 05, 2010, 11:46:29 PM
perfect example... stock rear, and springs (http://i233.photobucket.com/albums/ee79/daminc/Cougar%20Outside/IMG_3649.jpg)
and immediately after the entire rear end swap... (http://i233.photobucket.com/albums/ee79/daminc/rear%20end/MVI_5035.jpg)
Post by: Haystack on December 06, 2010, 12:00:49 AM
Yeah, I want to get some CHE adjustable lowers eventually for mine.
Post by: daminc on December 06, 2010, 07:26:58 AM
I now see that I should have got the adjustable lowers
Post by: jcassity on December 11, 2010, 12:23:43 AM
my 87 is identical to yours (or was i should say), and it also sits and always has sat higher than my 20th. i think having quad shocks in the rear will make it more tricky for me to adapt the profile so the installed new shocks are placed at a higher point. I dont think i need to adapt the horizontal shocks, just the ones that pass through the trunk.
Post by: daminc on December 11, 2010, 08:13:08 AM
I thought about an adapter plate for mine... Not sure how I would bolt it on so there's no movement between the rear and the shock without welding.. Air shocks seem to be an easier solution right now.
Post by: 1Bad88tbird on December 11, 2010, 10:14:16 AM
I had the Ford Motorsports handling kit for the T-Bird and the rear on mine sagged for quite some time. This summer I decided to try to level it so I got the SN95 Mustang rear coils for it and it went even lower. Then I got a set of Fox body Mustang rear coils for it, they brought it up but not quit to the hight of the Motorsport coils. I was thinking of going with air shocks but decided to try a set of factory rears from an 87-88 cougar at the jy. To my suprise they leveled it. So now I'm thinking the front Motorsports coils weren't lowering coils at all. It sits level now and I'm happy with it even though it does sit higher than I'd prefer. I like my wheels I have now but they're 14s and I'd like to go with 17s someday. But they're not on my must have list at the moment.
Post by: vinnietbird on December 11, 2010, 04:48:02 PM
I have air shocks on the Sport. Reason.....When I'd carry a heavier load,like groceries,I'll air up the rear so it'll sit level with a months worth of stuff,then when I unload,I just let a little air from the shocks. The doa great job. I have the schrader valve on the tail light panel....When I open the trunk,it's right on the back driver side area outside the trunk seal so it's hidden from view ,yet super easy to access.
Post by: daminc on January 07, 2011, 03:42:32 PM
got my headers... now I can start putting everything back on the motor. No problem getting to these plugs now.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0835.jpg)
My favorite part is the tag on them...lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0837.jpg)
Post by: hypostang on January 07, 2011, 03:45:34 PM
Those are pretty , do they need a special h-pipe
Post by: Kitz Kat on January 07, 2011, 04:00:12 PM
Why did you give up on your header project?, The new ones are nice though. Oh yeh I wish I could of used those vc covers,you got them looking nice.
Post by: daminc on January 07, 2011, 04:03:40 PM
they wouldn't clear the frame on either side... Going to try and use them on the vert
Post by: daminc on January 07, 2011, 04:06:01 PM
I wouldn't think that they would need a special h pipe... And these things weigh a freakin ton..... bet the front of the car went down some....lol
Post by: Kitz Kat on January 07, 2011, 04:19:38 PM
Hey Jerry I thinking, I know it's scary, but once your front end goes down with more weight your ass end is going to raise a little. It may just work out right.
Post by: daminc on January 07, 2011, 04:30:52 PM
I'm hoping the same. I didn't realize stainless headers would weigh so much..
Post by: cougar1car on January 08, 2011, 11:40:03 PM
Quote from: daminc;344390
Post by: cougar1car on January 08, 2011, 11:41:26 PM
The grill looks awesome... Wanted to know how it'd look before I tried it... Looks just like i thought it would...
Post by: daminc on January 09, 2011, 07:31:14 AM
Yes, I painted to match the black around the widows, and the badging.
Post by: cougar1car on January 09, 2011, 03:03:08 PM
Any particular paint??
Post by: daminc on January 09, 2011, 04:44:00 PM
well, since I used a black that's a little diff from what ford uses, I found that rustolium satin matched quite well with the paint on the car.
Post by: daminc on January 09, 2011, 07:03:39 PM
The trim around the windows, between the door glass and 1/4 windows, the badging, the pillar cougars, along with the front window trim and the wipers. The trim at the base of the windshield, and screens under the wipers are all done with rustolium satin black (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0367.jpg)
Also many things under the hood.... Rad supports, wiper motor, all pullies, and buck tag (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0470.jpg)
Post by: vinnietbird on January 09, 2011, 07:04:43 PM
Sweet !!!All that black is looking sinister. I deep exhaust system will really set off the whole tone of the car.
Post by: daminc on January 09, 2011, 07:07:19 PM
I also used it on many bolts on the car too...It matches the rubber around the side windows perfectly in sheen and color...
Post by: daminc on January 09, 2011, 07:08:37 PM
Quote from: vinnietbird;349004
Well I got the headers...it's a start
Post by: vinnietbird on January 09, 2011, 07:34:15 PM
Are you using and H or an X pipe? Cats or no cats? Any idea on lers? What about the tails? That's enough questions.LOL.
I'm going back to the Warlock lers when I get the funds. They had a great tone,but no drone. Not overwhelming when driving,but really get the point across,and,I can uncap them for some serious loudness.
Post by: Bruce M on January 09, 2011, 08:45:31 PM
Your car is just beautiful. Can you do mine next? I'll give you my soul.
Post by: daminc on January 09, 2011, 10:24:11 PM
Quote from: vinnietbird;349012
Still up in the air about the X or H pipe. I can go without the cats starting next year. I won't have a problem this year as it doesn't get emission tested anyway up here. but will be legal starting next year. I'm also thinking about the Warlocks too. I really don't want to hear the car when cruising around. that would be annoying to me.. as for tails.... probably not. If I do, they will be satin black so they don't stick out like a sore thumb.. They will probably just turn down un-noticed like a stock tail pipe....( and painted satin black)
Post by: daminc on January 09, 2011, 10:26:40 PM
Quote from: Bruce M;349024
Thank you.....The vert is next...sorry
Post by: Beau on January 10, 2011, 03:12:30 PM
Quote from: daminc;348943
lol
Looks good!
Post by: sarjxxx on January 12, 2011, 07:44:10 PM
Quote from: daminc;344458
......except that would require you to put a v6 back in it:evilgrin:
Post by: thunderjet302 on January 12, 2011, 07:51:07 PM
Quote from: sarjxxx;349475
Pop go the head gaskets ;).
I though he was going to supercharge the 5.0 that's in the car.
Post by: daminc on January 12, 2011, 07:57:01 PM
shhhhhhhhh
Post by: sarjxxx on January 12, 2011, 08:21:11 PM
Quote from: vinnietbird;336775
my stock one could handle all that stuff and a subwoofer....
till now that its gone bad and drains my battery and wont even charge it when running....:rolleyes:
Post by: daminc on January 14, 2011, 09:04:13 AM
I'm mot a power user...and the defroster and lights will probably never be switched on again.. the only time I used the lights on the vert in 2 years, is when I have it inspected every year...lol
Post by: thunderjet302 on January 14, 2011, 02:47:35 PM
You don't use the lights? Even I drive my T-bird at night.
I still run a stock alternator. I have an aftermarket head unit but the rest of the electronics are stock. I have no problem with the power even with the head lights and A/C on. Plus a 3G doesn't look stock. Not that the rest of my engine bay is stock....
Post by: hypostang on January 14, 2011, 03:47:43 PM
I put a 3g in my car only because I have seen the 2g melted wire carnage before . Preventive measures :)
Post by: Kitz Kat on January 14, 2011, 04:23:14 PM
2g's been on cars for years, They work for stock. I wouldn't of changed mine if I wasn't running a elect. fan.
Post by: vinnietbird on January 14, 2011, 04:27:30 PM
I did it because I had got 3 free ones. The electric fan came along a lot later.....like 3 years later. I'm happy with the 3G. As I said though,I run the stereo,heater,defroster,lights,fog lights......
Post by: Kitz Kat on January 14, 2011, 04:54:06 PM
Actually Vinnie, I put it in before to,only because it was another upgrade. ic can do that anytime, We need to see this thing on the road, with video!!
Post by: vinnietbird on January 14, 2011, 05:04:35 PM
I can second that.
P.S.....Kitz....my replacement valve covers are in route to me....you know what that means !!!
Post by: 88turbo on January 14, 2011, 05:09:11 PM
Quote from: vinnietbird;349716
I can second that.
that you get to pull your intake again??? lol
Post by: Kitz Kat on January 14, 2011, 05:27:19 PM
Need to see under them anyway. That's Why ic got the covers he has now. I wish I could of used them.
Post by: vinnietbird on January 14, 2011, 05:31:15 PM
No,my current chromed aluminum covers go to Kitz. My intake will be staying for quite a while....or until I decide to polish and mod another Explorer intake.
Jerry,Most of the final assembly on the engine is done,correct? How's the wiring for it so far?
Post by: daminc on January 14, 2011, 05:47:20 PM
Quote from: thunderjet302;349696
Nope....If it's not bright and sunny, they don't leave the garage... I've used the wipers once on the vert so far.. because it was raining a bit when I took it for inspection
Post by: daminc on January 14, 2011, 05:54:08 PM
Quote from: vinnietbird;349728
The intake needs to be bolted on, and I need to find replacement fuel lines of under the hood... Nothings wired yet, And the headers are just hand tight for fitment right now. I still have to bolt the aod X-member on too (after I find some long ass bolts) so basically.....I haven't touched it since the motor got bolted in... which is just finger tight too. lol
Post by: vinnietbird on January 14, 2011, 06:00:30 PM
HEY !!! Get with Loaded87IROC. He posted pics of some 5.0 cars. He has access to the fuel lines (he's in Nevada).
Post by: daminc on January 14, 2011, 06:04:02 PM
Quote from: vinnietbird;349736
10-4
Post by: thunderjet302 on January 15, 2011, 01:58:40 PM
Quote from: daminc;349731
I love driving mine on a nice summer night. That 'vert would be a great summer night crusier.
I actually used the wipers on mine for the first time in 4 years last summer. I was amazed they still worked :hick:
Post by: daminc on January 18, 2011, 02:59:25 PM
No night cruising here with the top down..... To many sandflies...I'd have to wear goggles...lol
Post by: daminc on January 18, 2011, 03:01:24 PM
got my Christmas present today... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0894.jpg)
Post by: Chooglin on January 18, 2011, 05:11:32 PM
That is sweet!!!!!!
Post by: vinnietbird on January 18, 2011, 05:30:56 PM
Sweet !!! I want one. I have an Explorer intake in the garage I'm thinking about trying to polish similar to yours.....without copying. I like that on your engine.....I say that with tears in my eyes.
Post by: daminc on January 18, 2011, 05:32:24 PM
is it to shiny compared to the rest?
Post by: vinnietbird on January 18, 2011, 05:49:48 PM
To be honest... I think if that's the only polished part under the hood, with a polished plate on top of it (as it is now), I think it's well balanced with the black and silver,and polished upper in the middle. If you leave the valve covers silver,but polished the fins and top of the lettering, that would also look great,and be easy to do.
Post by: daminc on January 18, 2011, 05:54:35 PM
I was thinking about making the fins and ford logos black... what you guys think?
Post by: sarjxxx on January 18, 2011, 06:24:06 PM
thats the most disgusting thing I've ever seen.:barf:
Post by: vinnietbird on January 19, 2011, 07:01:38 AM
I'm saying black in the low areas,polished on the high areas. My own opinion. You have to follow your own path on this though.
Post by: Kitz Kat on January 19, 2011, 03:03:01 PM
Polish the Tb and spacer,It will look like one big air cleaner. I like the idea about polishing the tops on the vc's to. Or you can rattle can fake chrome on the whole top end!lol.
Post by: vinnietbird on January 19, 2011, 04:18:11 PM
You can polish the top of the fins in less than an hour for both valve covers.
Post by: daminc on March 03, 2011, 04:52:35 PM
got the fuel lines today. That long search is now over.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1057.jpg)
Post by: sarjxxx on March 03, 2011, 06:32:49 PM
AHA now the cougar will roar
Post by: vinnietbird on March 03, 2011, 07:35:00 PM
So, you should be able to actually start the car by.....say....tomorrow at supper time?
Post by: daminc on March 03, 2011, 08:02:12 PM
That's right Vinnie..... I SHOULD, but I don't think it will happen... Have to take Sheila to the Dr tomorrow
Post by: 1Bad88tbird on March 03, 2011, 08:55:27 PM
Sweet! I'm glad you where able to get the final piece to the puzzle.
Post by: daminc on March 03, 2011, 09:30:36 PM
Quote from: 1Bad88tbird;354470
Thanks
Post by: flylear45 on March 03, 2011, 09:56:33 PM
I like the intake and valve covers. A little splash of black on the VC's would be nice.
Fuel lines look great! Can't wait to see you are driving it again. Awesome resto project.
Post by: jcassity on March 04, 2011, 12:55:23 AM
we are almost at 302 pages...would be nice to end on a good note to match the cubic inch.
I really have a hard time looking at the original car and knowing there isnt much of a sign if any it use to be white. This is a killer resto project, none better.
Post by: vinnietbird on March 04, 2011, 06:53:29 AM
Jerry, what lers are you using?
Post by: daminc on March 04, 2011, 07:32:28 AM
Quote from: jcassity;354488
we can stretch it to page 306 then... the only way to find white now, would be to be to remove the front side kick panels,
Post by: daminc on March 04, 2011, 07:38:54 AM
Quote from: vinnietbird;354494
not really sure yet. I want it quiet though.... Thinking maybe warlocks.... they're quiet until romped on. I saw a nice 2 piece H-pipe too, with no cats.
Post by: vinnietbird on March 04, 2011, 04:59:37 PM
Warlocks are what I'm going to put on the car. i loved them on the other Bird.....unless I change my mind, but I don't change my mind very often.
Post by: hypostang on March 04, 2011, 05:33:47 PM
Quote from: vinnietbird;354518
this is the funniest thing I have read in weeks
Post by: vinnietbird on March 04, 2011, 06:07:22 PM
Quote from: hypostang;354523
What's that supposed to mean? LOL.
Post by: 1Bad88tbird on March 04, 2011, 08:15:18 PM
^ haha that is a good one! lol!!
Post by: vinnietbird on March 05, 2011, 01:51:28 AM
Jerry,I have to question some of the members you allow in this house.LOL.
Post by: daminc on March 05, 2011, 07:02:01 AM
Quote from: vinnietbird;354560
What are you going to ask them?..... :rollin:
Post by: 1Bad88tbird on March 05, 2011, 07:46:33 AM
You guys are great! lol!!
Post by: sarjxxx on March 05, 2011, 10:34:53 PM
A house divided cannot stand. Unless its a single wide.:dunno:
Post by: vinnietbird on March 06, 2011, 08:16:49 AM
Quote from: daminc;354565
It's about a homicide.....they're killing me.
Post by: vinnietbird on March 06, 2011, 08:18:36 AM
Any progress planned for the Cougar today? I want to get my valve covers on, and get the Sport washed and waxed. I guess I'm going to have to take a couple of vacation days so I can get something finished. Time is hard to come by.
Post by: daminc on March 06, 2011, 09:21:05 AM
Nope, still takin care of Sheila after surgery.
Post by: daminc on March 14, 2011, 06:19:00 PM
More stuff came today... Gotta love an open box sale at BBK.... almost half price for this.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1105.jpg)
Post by: sarjxxx on March 14, 2011, 08:28:42 PM
shweet
Post by: vinnietbird on March 14, 2011, 09:42:31 PM
Very nice !!! Now, just a few more exhaust pieces, some fasteners, and you're set !!! I remember when I got the new X-Pipe. I had to look at it for a while. I love new parts. Even new "used" parts. I cut the pegs for mounting off of my X-Pipe. Trying to get them in that bracket was always more trouble than I felt like dealing with. Never had an issue with them gone. I still have to get new lers, but spent the ler money on a new wheel and two new front tires for the Sport.LOL. Oh well, that's the way it goes.
Post by: daminc on March 14, 2011, 10:15:19 PM
hey, can I paint these pipes with high heat paint? ore will it burn off still
Post by: sarjxxx on March 14, 2011, 10:26:53 PM
If you do it right (cook it like you're supposed to) it should be fine. I've heard of people painting headers with not having problems so you're H pipe should be ok.
Post by: vinnietbird on March 15, 2011, 06:53:20 AM
I'd bet the paint will burn of eventually. My X-Pipe still looks good after about 4 or 5 years. No rust.BUT, with the small amount of driving you'll do, the paint may work. I'd use the best high heat stuff you can find though.
Post by: thunderjet302 on March 15, 2011, 11:08:14 PM
As long as the car isn't driven in snow/salt it should be fine. My 2.5" H-pipe is 4 years old and looks like new.
Post by: daminc on March 16, 2011, 12:11:15 AM
Yea, your probably right.... It won't even get wet often
Post by: 50tbrd88 on March 16, 2011, 10:48:34 AM
Quote from: daminc;355392
Post by: thewestie on April 08, 2011, 09:08:24 PM
Are those cougar/t bird specific?
Post by: daminc on April 08, 2011, 09:11:20 PM
No, mustang... I'll take care of the length problem
Post by: thewestie on April 08, 2011, 09:55:32 PM
I was looking at mine today and the bends are a mess wish I went with a mandrel set now yours look real smooth
Post by: daminc on April 08, 2011, 10:59:34 PM
I guess OE pipes are made that way....
Post by: thewestie on April 08, 2011, 11:13:53 PM
Ive got a set of 2 1/2 custom bent at a ler shop tail pipes with no way other than cut them to remove them.
Post by: daminc on April 09, 2011, 08:00:31 AM
you probably don't need to extend yours though..
Post by: vinnietbird on April 09, 2011, 08:04:37 AM
Those look a lot like mine when I got them, except Mine weren't angle cut. I liked that since I was adding the tips anyway. Nice pipes. Now, to install it all.
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on April 09, 2011, 08:16:07 AM
need some lers now and extension pipes I guess
Post by: daminc on April 09, 2011, 08:17:46 AM
will start putting it together after I epoxy the vert
Post by: vinnietbird on April 09, 2011, 08:39:50 AM
Check the pipes fitment. I had to extend mine at the ler end. Great other than that, and it wasn't a big deal. I still need lers as well, but spent the Sport's funds this week, so, waiting until they build back up. I have plenty to keep me busy for now, but the roar, holy . It does sound great, but after a while, it can wear on me. I wish I could record sound. I'll try to see what Gayle can do. I think her new Ipod Touch can do that. I'll see what happens.
Did you already get the Ford Racing headers? I couldn't remember if you did, or if you were going to.
Post by: daminc on April 09, 2011, 08:58:33 AM
Yes I got the stainless P headers around Christmas time
Post by: vinnietbird on April 09, 2011, 09:11:59 AM
Those are pretty.
Oh !!! Looking at those pics reminds me. I have to get my ChuckW mounts installed. One more thing to add to the list. I need a more time off.
Post by: daminc on April 09, 2011, 09:50:31 AM
They are pretty... wonder what color they'll turn after I run it...I'm hoping for blue myself... lol
Post by: vinnietbird on April 09, 2011, 10:13:01 AM
Mine have a blueish tint to them up near the head. It's not like you really have a choice of what they're gonna do, though. LOL.
Post by: daminc on April 09, 2011, 10:36:03 AM
I hear some just get black instead of blue....I won't have that...lol
Post by: vinnietbird on April 09, 2011, 12:31:13 PM
I have the cure....don't ever start the engine.
Post by: daminc on April 09, 2011, 06:09:07 PM
so far, it's worked great Vinnie
Post by: vinnietbird on April 09, 2011, 06:19:35 PM
Just put the engine on a really nicely detailed stand, then put the engine/stand assembly in the living room and make a lamp out of it.
Post by: daminc on April 10, 2011, 10:31:08 AM
I don't think it will flow with our Victorian theme..... but I can ask Sheila if I can.... we do need a lamp.
Post by: vinnietbird on April 10, 2011, 04:38:18 PM
Use it as a juicer then.....fruit into the intake, juice out the exhaust.
Post by: sarjxxx on April 11, 2011, 10:21:48 PM
Quote from: vinnietbird;357646
I think you're on to something here. Man this is better than the engine grill thing you see on SPEED channel.:giggle:
"[SIZE="3"]ARE YOU SICK OF YOUR WIFE NOT LETTING YOU KEEP YOUR HARD WORK AND TALENT IN THE KITCHEN? THEN GET HER THE V8 JUICER!!!" With 8 cylinders capable of holding over 5 quarts of liquid each!!! Just open the patented "Throttle Body" hopper, and toss in your fresh fruit......... [/SIZE]
"[SIZE="1"]V8 Juicer is not affiliated with V8 Vegetable Juice or its subsidiaries of distributors in any way[/SIZE]"
All ridiculousness aside, Jerry it is nice to see that thing will be running soon and those stainless headers look great. Do you think it will be up and running in time for Thundercat day this year?
Post by: daminc on April 11, 2011, 10:27:28 PM
what's thundercat day?
Post by: sarjxxx on April 11, 2011, 10:35:55 PM
Quote from: daminc;357781
Remember our CATjam replacement last year that Gumby and FastCat put together? Thunder/Cat Dyno Day? I have heard there will be another one this year..... I plan on going....
[thread]27395[/thread]
Post by: daminc on April 11, 2011, 10:53:03 PM
to far for me... I don't know if it will ever make it to Catjam either... I would have to trailer it if I brought it anyway
Post by: hypostang on April 11, 2011, 10:57:53 PM
Quote from: daminc;357789
Why would you have to trailer it ?
Post by: daminc on April 11, 2011, 11:05:10 PM
I'm not driving a 24 year old car 300 miles one way anywhere
Post by: hypostang on April 11, 2011, 11:10:56 PM
But everything on your car is brand new though , dont be scared :)
Post by: daminc on April 11, 2011, 11:14:44 PM
No thanks. same goes for the vert.. I'm fine driving down in the Lincoln. looks like a few special people will only get to see them...lol
Post by: vinnietbird on April 11, 2011, 11:33:27 PM
I would drive the Sport anywhere, anytime, but, with the big black Maxima in the driveway, that's the car we take on trips.
Post by: EFFalcon on April 12, 2011, 12:39:15 AM
Just spent the last ~2 hours skimming through this thread.
This has to be the most informative build thread i've seen on here, its given me so many things to consider when i'm looking for a tbird locally.
seriously impressed!
Post by: thunderjet302 on April 12, 2011, 12:39:53 AM
Quote from: daminc;357570
If you didn't get the Jet-Hot coated ones (I didn't) then they will turn dark gray and have a bit of surface rust, just like mine. (http://i198.photobucket.com/albums/aa33/thunderjet302/clean%20T-bird/DSCN1914.jpg)
Post by: daminc on April 12, 2011, 07:40:36 AM
Quote from: EFFalcon;357803
thanks, my favorite part of doing this whole project, is when it got painted..... looks so much better in person when compared to the pics...
Post by: daminc on April 12, 2011, 07:42:40 AM
Quote from: thunderjet302;357804
yea, I'm prepared for that already too. that seems to be the way they go... either blue, or they look burnt.
Post by: vinnietbird on April 12, 2011, 08:34:42 AM
Jerry, you're going to have A/C aren't you? I have the Sport's working great now, but I have one problem....I've gone A/C delete so long, I forget it works and get pretty warm in the car before I realize "Hey !!! I have A/C !!!". What parts are you still needing (other than injectors...I'm working on that).
Post by: daminc on April 12, 2011, 08:56:37 AM
Yes. AC is a must in a black car...I will know in a week or 2 if I need anything.. possibly an intake spacer is all I might need. I haven't put anything together, so I'm not sure what I'm missing yet.. Just collecting what I can to make it go faster when I get to it
Post by: daminc on June 12, 2011, 10:22:23 PM
well, after the py start on Saturday. Today went a lot smoother except for the arthritis, due to the weather being cold and damp... Random pics as I'm working on the brakes, and the rear brake lines.
thinking I need to paint the brackets for the brakes....but what color?
Post by: daminc on June 12, 2011, 10:30:06 PM
I realized that the door jambs are my favorite part of my rebuild....I don't know why... but they are pretty crisp looking. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1438.jpg)
Post by: vinnietbird on June 13, 2011, 08:18:29 AM
Beautiful........and the jambs really do look crispy. I love looking at your update pics, It helps me stay motivated to get the Sport back into her fighting shape.
Post by: daminc on June 13, 2011, 09:15:27 AM
as an update from the other thread on Friday...I did get the calipers moving after some soaking, found the bolts, and upper brake line. Probably finishing the hard brake line, and moving on to the trans crossmember later today..
Post by: vinnietbird on June 13, 2011, 09:25:39 AM
The crossmember will be easy stuff. I'm going to go out and do some mods to my throttle body and play with that to eliminate the whistling. Then, may bump the timing up to 14 where it was.
Post by: daminc on June 13, 2011, 10:01:20 AM
hopefully the bolts won't give me a problem.
Post by: vinnietbird on June 13, 2011, 10:13:05 AM
For the crossmember? If they are bad, let me know and I'll grab you some.
Post by: lakenheath24 on June 13, 2011, 01:23:56 PM
Dude,that is sick. Really sick. I wish I had 1/10th your skill at bodywork. I've kinda lost motivation to work on mine. It's been 95 degrees, IN THE GARAGE! Lookin at stuff like this though, makes we wanna get started back.
Post by: daminc on June 13, 2011, 05:44:58 PM
lol....My garage is air conditioned too.... Had to rub that in..lol Thanks, it just takes some research, practice and a lot of patience to get it done.
Vinnie, I don't have any bolts, so I'll be heading to Fastenall to get something to bolt it in.. Had to cut the old ones because of rust. If I can't find anything, I'll let you know. but I should find something I can use over there. What grade bolts are in there anyway?
Post by: vinnietbird on June 13, 2011, 05:48:29 PM
Grade 8 should be fine for the tranny crossmember. Just a bolt and nuts. Maybe a couple of lock washers or just lock nuts. The factory bolts have a champfered end like the motor mount bolts, but a regular bolt will work just fine.
Post by: daminc on June 13, 2011, 07:58:21 PM
that's what I figured too
Post by: vinnietbird on June 13, 2011, 08:08:06 PM
Easy stuf my friend. If you need anything, you know I'll do my best. I'm going to send info and pics when the Sport's water cooler gets here, and then you can go from there. FYI...I'll be hitting the yard again Saturday. I'll check on the Ranger stuff. What year was that again? 2007?
Post by: daminc on June 13, 2011, 08:19:42 PM
05 2.3 automatic
Post by: vinnietbird on June 13, 2011, 08:30:18 PM
Sweet. I'll add that to the list of info.
Post by: daminc on June 14, 2011, 09:19:29 PM
got the crossmember installed today....had to order brake pads for the rear.....Apparently you can't just go into the store, and buy a set of brake pads for a 24 year old car... lol. Hope to finish the brakes and lines tomorrow. Then onto the headers and exhaust...
Post by: daminc on June 16, 2011, 07:58:09 PM
brakes are all done ...Brake lines are finished.. need to bleed the lines.... Headers are bolted on.. H-pipe is next on the install.... That's my update for today.
Post by: vinnietbird on June 16, 2011, 08:06:00 PM
Wow......that's good progress. I'm at a standstill til the radiator gets here. I want to see pics of the headers installed. Those were nice pieces.
Post by: daminc on June 16, 2011, 08:10:49 PM
I left the camera out in the shop.... Pics of everything tomorrow..... And I got the belts and stuff yesterday, Vin.. Thanks
Post by: daminc on June 16, 2011, 08:15:48 PM
I would have bled the brakes, but now I see I have a stubborn bleeder on the front Pass side. amazing how this stuff seizes up even after you have things working...(2 years ago) lol I'll finish the rest of the underneath work before I get to the front caliper. I only have 2 jack stands, and they're in use in the back of the car right now.
Post by: vinnietbird on June 16, 2011, 10:54:13 PM
I'll be waiting to see the progress. I think you'll have good luck with those belts.
Post by: daminc on June 17, 2011, 07:41:09 PM
some pics of what's been happening. Brakes are all on, and headers are bolted on too. now for the fun part of making the H-pipe fit... looks like I need a little modification of the pipe hangers... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1468.jpg)
This one's a good shot of the frame (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1476.jpg)
Post by: vinnietbird on June 18, 2011, 12:03:05 AM
That's purdy. Getting closer and closer to twisting the key and pushing the gas pedal.
Post by: sarjxxx on June 18, 2011, 12:21:42 AM
Quote from: vinnietbird;361656
Well heck he could go out and do that now. Prolly nothing will happen but ya know...lol.
Looking awesome Jerry. I am going to have to see that thing in person one of these days for sure.
Post by: 1Bad88tbird on June 18, 2011, 12:26:21 AM
I hope when you do start it for the first time you video it for all of us. There are alot of us who are fans of this thread and would like to see it I'm sure.
Post by: daminc on June 18, 2011, 08:09:55 AM
I probably won't. I'm sure it's gonna take at least 10 times to get it to run.... lol
I'll video after I get it to run
Post by: vinnietbird on June 18, 2011, 09:13:11 AM
What's on the list of things to do today Jerry? I was going to replace the radiator, but it won't be here til Monday (that figures on my one weekend off). I may do some good cleaning on the Sport. After the hail damage, I lost all interest. I still have to get the hood and get busy on the body. Too busy lately. Do you have the rest of the exhaust pieces already for the Cougar?
Post by: daminc on June 18, 2011, 10:24:21 AM
I'm gonna mess with that H-pipe, and probably get side tracked with something else under there too... shifter, aod wiring and lines.... that sort of stuff... pics later
Post by: daminc on June 18, 2011, 04:39:51 PM
got the H-pipe bolted in.. O2 sensors in... eyeballing what I need between the tail pipes and the H-pipe now.... apparently quite a bit....lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1478.jpg)
Post by: vinnietbird on June 18, 2011, 05:49:54 PM
Woo-Hoo !!! PIPES !!! Have you decided on lers yet? I want the Warlocks, but in reality, I don't think the extra cash for the cutouts works for me.....I'd probably never use them. I may go with a quality set of turbo lers for a mellow sound, but great air flow.
Post by: daminc on June 19, 2011, 08:47:59 AM
Maybe Magnaflo's I like the non rumbling sound the have. but they still sound mean in a non cop head turning way....
Post by: vinnietbird on June 19, 2011, 09:14:37 AM
I'm still looking around. I really don't want "Loud", I want "intimidating"......Mildly scary, but low.....in a Darth vader kind of way. Low key, but it gets the point across well.LOL.
Post by: daminc on June 19, 2011, 09:35:24 PM
well.again I got side tracked, but stuff is still getting finished.
Bolted the floor shifter down today, and got side tracked removing the column shifter.... I decided to remove the entire thing instead of just removing only the shifter. bit of a pain, but i had fun. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1484.jpg)
I was sittin there , and I was playing with the floor shifter... Come to realize it's much more comfortable when it's on the angle in the pics... lot easier on the hand and wrist...so I bolted it like that on purpose... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1489.jpg)
(http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1491.jpg) And yes, that's still my original dash.... maybe I'll finally hook up the mass air and put the computer in... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1492.jpg)
Post by: vinnietbird on June 19, 2011, 10:06:00 PM
Jerry, why is the shifter crooked? I can understand it may be a good grip, but it still looks crooked. Sup wit dat?
Post by: daminc on June 20, 2011, 07:59:25 AM
Don't worry Vinnie... after I find a boot for it, and connect the gear selector to the dash, no one will ever know.... It's all part of the plan. Don't let it keep you up at night.... better yet, find me a boot for it....lol
Post by: vinnietbird on June 20, 2011, 04:24:42 PM
Boot? What boot? Liek a 5 speed style boot? If so, I got mine from Ebay from a company in England. VERY nice quality leather, and cheaper than anyone else....even from England.
And when you said "don't let it keep you up at night".....I don't care about stuff like that..........yes I do.
Post by: vinnietbird on June 20, 2011, 04:27:06 PM
I just had a bad-ass idea !!! Remove the shifter panel that surrounds the shifter, remove the shifter's gear selector indicator, and install the stock TC style 5 speed shifter panel with the 5 speed boot. Huh???? Good thinking right there !!!!
Post by: daminc on June 20, 2011, 04:45:01 PM
I had the same idea as I was putting it together.... it could work
Post by: vinnietbird on June 20, 2011, 05:00:02 PM
Yes it could work, and can be done easily with simple replacement parts.
Post by: daminc on June 20, 2011, 05:19:00 PM
I think it will.. now if I can only find a shifter cover to replace the auto cover.......... Hmmmmm
Post by: vinnietbird on June 20, 2011, 05:25:27 PM
I'd bet Hcor has what you need.
Post by: daminc on June 20, 2011, 05:38:08 PM
good Idea
Post by: randynten on June 20, 2011, 08:35:07 PM
I hear that, I put my shorty headers and x-pipe on this weekend and it was not a simple bolt-on. lol. I beat, banded, made a small dent here and there, got out the grinder and torch but got it on. My lers will be here tomorrow, I just ordered the summit turbos. Oh, I like the 5-speed boot idea, I did that on a firebird once.
Post by: daminc on June 20, 2011, 08:42:41 PM
Glad I didn't have to go through all that... I just heated and bent the hangers in about 1/2"... and it bolted right up...now I have to fill in the 52" between the H- and tail pipes.... lol
Post by: daminc on June 20, 2011, 08:46:58 PM
I also used the pipe hanger from the SC... it was still on the AOD and it seemed to work fine. I don't know if they're the same as the stock version
Post by: daminc on June 20, 2011, 10:21:02 PM
hmmmm. I'm thinking I could just use the AOD shifter cover and a boot... mainly because the shifter is off centered to start with. I could mod it to work with a boot maybe
Post by: vinnietbird on June 20, 2011, 10:28:54 PM
Cutting a hole to fit the boot would be easy. One the factory 5 speed panels, there are pins molded into the plastic on the bottom that the boot slips on to, then little metal clips hold the boot to the panel. Either way, It wouldn't be hard to figure it out. BUT, on the 5 speed panel, it rolls down into the boot....meaning, the hole for the shifter has a concave roll to it...if that makes sense.
Post by: daminc on June 20, 2011, 10:32:07 PM
you got a pic of one?
Post by: vinnietbird on June 20, 2011, 10:38:44 PM
Here's mine. You can see how the edges of the shifter boot hole roll down. A finished look.
Post by: sarjxxx on June 21, 2011, 04:12:43 PM
jerry I got a 5 spd shifter panel if you need it... yours for the cost of shipping.
...which shouldn be much.
Also, I might be able to get you a 5 spd boot from the local yard but I don't remember for sure or not just how much stuff was left on that console.....
edit: actually I'm headed up there right now so I'll take a look for you when I get there
re-edit: ok now I'm not but I'm going tomorrow so let me know what you would like me to look for and I will for you
Post by: vinnietbird on June 21, 2011, 04:56:25 PM
The older 5 speed Taurus SHO share the same shifter boot.
Post by: daminc on June 21, 2011, 05:48:59 PM
Quote from: sarjxxx;361909
that would be awesome
Post by: flylear45 on June 21, 2011, 05:54:59 PM
When I tried to use a manual boot on an automatic shifter I found that there wasn't enough give in the boot to allow the range of front to back motion, so I went with another plan.
Just FYI.
Post by: sarjxxx on June 21, 2011, 06:07:36 PM
Quote from: daminc;361921
um, wait what would? I said a lot of stuff
Post by: daminc on June 21, 2011, 06:34:54 PM
Quote from: flylear45;361922
Just FYI.
that's what I feared. that's why I figured I'd make one with the aod cover
Post by: daminc on June 21, 2011, 06:37:59 PM
Quote from: sarjxxx;361923
hold on....I might be having to make one again
Post by: daminc on June 21, 2011, 06:39:56 PM
Flylear, what did you end up doing... If I may ask
Post by: vinnietbird on June 21, 2011, 08:44:55 PM
Jerry, if you can lower the shifter a little, you should be fine with the 5 speed panel and boot. Also, there are other shifter boots you can substitute to fit that are a little taller (giving more movement for shifting), and you still have that look that's "right".
Post by: daminc on June 21, 2011, 09:16:31 PM
any lower will need some mods of the car. the one side is on the hump now... I could cut it, and make a box to drop it in to lower it
Post by: flylear45 on June 21, 2011, 09:31:30 PM
I was playing with it here:http://www.foxtbirdcougarforums.com/showthread.php?24179-1988-TC-single-Holset-turbo-5.0-4R70W&p=350496#post350496
Maybe I wasn't into it enough to make it work, but it wasn't getting it for me.
Post by: vinnietbird on June 21, 2011, 09:36:43 PM
I think with a slightly larger/longer boot, it can look factory.
Post by: vinnietbird on June 21, 2011, 09:40:29 PM
I'm wondering if the actual shifter itself, the vertical part, could be shortened a little. I don't see why not. I need to snag a Stang piece as a test mule and se what can be done. That would help, and look cool.
Post by: dustytheredneck on June 22, 2011, 12:02:35 AM
since I joined and over this past month I have been reading this entire tread (a 143 pages later and 90% of it on my phone) and I am amazed what this car looks like and the amount of work into the car from what the project started from..... WOW!!!! ...... I thank you sir for posting your progress and allowing me (and everyone else) to read about this experience I could only wish to complete someday
Once again, Thank you, awesome job on everything, and maybe someday I could be privileged to see the car in person some day
Post by: hcor on June 22, 2011, 01:09:55 AM
I'll get you hooked up. let me go through the ones I have for you,
Post by: daminc on June 22, 2011, 07:30:16 AM
Quote from: dustytheredneck;361953
Everyone here should actually be thanked..... If it wasn't for this place, I would have never found entire panels, and parts to do the job.. most of the people here helped in one way or another to get it this far.. and you never know, one day you may find yourself in Buffalo, NY.... or who knows, It may actually make it to a future Catjam.....
Post by: daminc on June 22, 2011, 08:34:00 AM
I'm also thinking about shortening the shifter height. hopefully without destroying the only one I have...lol
Post by: vinnietbird on June 22, 2011, 04:34:53 PM
Let me see if I can get one from the Fox Stang at the yard and I can take pics and see what they're made of so you don't do damage that can't be repaired. Next Wednesday.
Post by: daminc on June 22, 2011, 06:03:56 PM
Ok I took the top off the shifter... I measure 2 -1/4" of travel on the shifter, park to 1st (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1525.jpg)
so in theory... I could actually move the entire shifter in any location to make it fit into 5 speed cover opening.. all I need is 2-1/4" top to bottom on the cover opening.. Who want's to be a pal and measure their cover for me?
as far as using the original shifter the way it is, I don't see why it wouldn't look good with the boot...
Post by: vinnietbird on June 22, 2011, 06:12:49 PM
What cover are you talking about that needs measured?
Post by: vinnietbird on June 22, 2011, 06:23:04 PM
The hole in the 5 speed bezel is appr. 5 1/4 inch from front to back, and 4 1/4 inch wide. From the dash side, the hole is appr. 1 3/4 inch from the dash side of the bezel, and 15/16 of an inch from the ashtray panel.
Post by: daminc on June 22, 2011, 06:42:28 PM
that's the one.... It has to work.. there's more then enough room for it.... I'm goin for it Sparky
Post by: vinnietbird on June 22, 2011, 06:44:50 PM
Excellent. Keep me posted on your progress with it. I'm really curious about the end result. I'm assuming you want the boot up near the shifter handle, like a 5 speed. Keep it looking stock-ish, or at least it looks like it belongs that way.
Post by: daminc on June 22, 2011, 07:19:35 PM
yep.... I'm hoping it looks stock when done
Post by: daminc on June 22, 2011, 09:35:02 PM
Just FYI.
back to this comment... does anyone know anything about diff size boots.. I saw somewhere about there being short and long boot. Thinking maybe the long will "give more" for the aod shifter... or.. will I have to have one made.. or maybe an after market generic might be a possibility.....
Any thoughts out there?
Post by: vinnietbird on June 22, 2011, 09:41:13 PM
Post by: thunderjet302 on June 22, 2011, 09:42:31 PM
Just a though but perhaps you could make a boot with leather or vinyl from a fabric store? Then you could make it large enough to fit the shifter in the stock position.
Post by: flylear45 on June 22, 2011, 09:44:50 PM
I truly gave up pretty quick on the boot because my wife didn't like the look. I asked her opinion and felt like I wanted to honor it. Maybe with more perseverance you could make it work. Mine came from a TC 5 speed. YMMV
Post by: daminc on June 22, 2011, 09:45:54 PM
that bmw boot looks like it has more material to it
Post by: daminc on June 22, 2011, 09:48:55 PM
Quote from: thunderjet302;362048
I do have matching red vinyl ... thinking that would look a little odd though.
Post by: vinnietbird on June 22, 2011, 09:54:17 PM
Post by: vinnietbird on June 22, 2011, 09:59:13 PM
I think making a red boot would be great....just don't use it.LOL.
Post by: daminc on June 22, 2011, 10:00:33 PM
might have something with the Ram boot.... I can't see anything from a Fiero being big enough to fit anything but ...... maybe a Fiero or the pink Barbie Vette
Post by: daminc on June 22, 2011, 10:01:08 PM
Quote from: vinnietbird;362058
I'll make you one too...lol
Post by: sarjxxx on June 22, 2011, 10:01:11 PM
If you want to make one, there is a vinyl fabric you can get at the crafts store, I think the one I went to was Michael's. Its black and the texture is kinda similar to the dash grain. Its pretty flexible too. Its what I used to cover my subs when I built the boxes. It looks very nice. Just a thought.
Post by: vinnietbird on June 22, 2011, 10:02:31 PM
This is an S-10 boot. Looks good, and from a truck, I'd bet a little taller.
Also, this is where I got my shifter boot. If you ask, they can probably add a few inches to the boot you like if you send them a message. They were very nice people when I got mine. Great quality and nice, soft leather. Not vinyl like stuff, and after almost 3 years, mine still looks new.
Post by: daminc on June 22, 2011, 10:03:06 PM
yes. Michael's does have a selection of "pleather" good idea
Post by: daminc on June 22, 2011, 10:05:41 PM
Post by: vinnietbird on June 22, 2011, 10:12:33 PM
First,, as far as making a boot for my Sport, but......um.....This is a good time to put an AOD back in.LOL.LOL.
Contact the place I told you about sweet product, and very well made.
Post by: daminc on June 22, 2011, 10:19:06 PM
I'm not going to worry about it to much right now... gotta finish bolting things together... The car will still run without a boot... tomorrows another day to work on it.. I'll finish up some stuff underneath and do some wiring....
Post by: daminc on June 23, 2011, 07:05:09 PM
todays progress report... Bolted the shifter bracket to the AOD... I must have lost the nut, bolt and washers to attach the cable to the gear selector.... not a big deal... connected the spedo cable and the neutral start wiring...... little steps. It's taking longer to find the stuff then install it..lol
So I decided to pull out the stuff that need to get installed.... thinking this will save some time.... maybe not....lol I got a few things ready for tomorrow and the weekend. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1529.jpg)
Post by: vinnietbird on June 23, 2011, 08:09:22 PM
Is that little bracket on the canister the one I sent....forever ago?
Post by: daminc on June 23, 2011, 09:08:07 PM
lol, yes it is... I painted it real nice too
Post by: daminc on June 24, 2011, 06:16:32 PM
todays stuff... removed the fender and started with the fuel lines for a bit.. doing a dry fit first.
Post by: vinnietbird on June 24, 2011, 07:26:12 PM
Do you have the little bracket that holds the fuel lines to the passenger side head?
Post by: daminc on June 24, 2011, 08:13:41 PM
the metal clips?
Post by: daminc on June 24, 2011, 08:15:15 PM
oh wait... to the head?
Post by: daminc on June 24, 2011, 08:31:13 PM
looking at the old pics... I don't think there was a bracket... you got a pic of what I need? it might also be somewhere in this pile of parts I got... lol
Post by: daminc on June 25, 2011, 10:44:28 AM
found the little bracket... It never got bolted to the head when the motor got put back together....Not sure I want to take that bolt out to do it..... looking for alternative method to connect bracket.... that is all
Post by: Kitz Kat on June 25, 2011, 02:07:50 PM
Probably goes to a bellhousing bolt. It's not bolted to the head bolts. Maybe on the back of the head? I don't have any of that bolted to my junk.
Post by: Kitz Kat on June 25, 2011, 02:09:26 PM
Lookin Good.
Post by: daminc on June 25, 2011, 02:44:04 PM
def bolts to the front head bolt.... I just clipped them together with it...seems to be fine with out bolting it down, So far
Post by: vinnietbird on June 25, 2011, 04:16:26 PM
I've had that issue too. The front lower passenger side head bolt should have a stud on top. I just pulled my bolt and swapped in the studded bolt. No issues. I'm sure you won't have any issues as it is. I just wanted the fuel line retainer clippy thing just because.
Post by: daminc on June 25, 2011, 07:51:02 PM
yea, I'm not pulling those expensive head bolts out for a silly bracket.....anyway.... did some more stuff
here's the little fuel line bracket, all nice and painted (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1532.jpg)
Now I have some good questions...... where does this flippin orange wire go to? (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1533.jpg)
did they make fuel lines that didn't go all the way to the tank? I put the replacement lines in, and there are connectors on these that are not on my other set... my other lines go all the way to the tank with the connectors near the back for the filter. these stop at the filter with 2 connectors.... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1534.jpg)
A view of the brake and fuel lines installed.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1536.jpg)
got this installed today (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1537.jpg)
installed the wiring for the injectors... Radiator, misc parts.. also installed the condenser while the front is apart. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1538.jpg)
Next questions... Where does this white vac line go to? (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1545.jpg)
Question #34 the lines that are connected to the steering rack from the pump...... do they still swivel after the nuts are tightened? or are they supposed to be tight and not move at all?...mine still move after tightening...
Question C.... Why don't I remember taking half of this stuff off?..... lol
Question #4 I need new transmission lines.... should I use hard lines or flexible lines? .... I'm also connecting it to a cooler. I'm thinking flex would be easier..
Post by: vinnietbird on June 25, 2011, 08:16:02 PM
The orange wire on my harness is also "cut" like that...it was on the other Bird I had as well. i think that's from the factory
I used flexible hose for my tranny lines when I had the Aod. Easy to route, and I too had a cooler. Never had an issue in all the years I had it that way. No leaks no worries.
Once the lines are connected to the rack and the pump, yes, they still swivel.
Post by: vinnietbird on June 25, 2011, 08:18:02 PM
.......oh, and you'd only have to swap one head bolt, not all of them. If you don't want to wast it, drill a hole through the expensive bolt and hang it from the mirror.
Post by: daminc on June 25, 2011, 08:35:37 PM
Thanks for the answers.... I'll pass on the bolt swapping. I like my shiny ARP's
Did you use the standard multi-use hose? or did you use stainless braided hose?
Post by: vinnietbird on June 25, 2011, 08:40:00 PM
No stainless braided hose. Down there, it'll get filthy anyway. I used some Good-Year hose for hydraulic type fluid. Easy to clean, easy to install, VERY durable and strong. Over the years I used it, the hose never cracked or gave me any problems at all.
Post by: Beau on June 25, 2011, 08:55:17 PM
Lookin' good Jeddy!
Post by: daminc on June 25, 2011, 09:42:19 PM
Quote from: ThunderbirdSport302;362237
Lookin' good Jeddy!
Thanks...
Post by: daminc on June 26, 2011, 06:42:35 PM
More stuff installed (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1547.jpg)
Post by: vinnietbird on June 26, 2011, 07:41:03 PM
Didn't you do the Mass Air upgrade?
Post by: daminc on June 26, 2011, 07:51:13 PM
it's half done
Post by: vinnietbird on June 26, 2011, 07:57:31 PM
What air intake setup are you going with? Aftermarket or stock Mustang tubes?
Post by: daminc on June 26, 2011, 08:01:56 PM
I have no idea what that even means...lol
Post by: vinnietbird on June 26, 2011, 09:06:43 PM
The intake tubes are different for Mass Air. The tube that goes from the air box to the throttle body. The CAI I have places the filter inside the fender, and has a chrome tube, then the mass air meter, then another chrome tube to the t-body. The stock style has two rubber tubes from the air box with the Mass air meter in the middle.
Post by: daminc on June 26, 2011, 09:12:05 PM
then I will be making my own..... Evolution Style
Post by: vinnietbird on June 26, 2011, 09:15:51 PM
Sweet. There are couplers on Ebay (I just bought one) pretty cheap, they come with nice stainless clamps, and in a multitude of sizes. I got mine in blue of course. Get your Mass Air meter first then make the tubing to match. With 24# injectors you'll need an after market Mass Air meter to tell the computer you have 24's. The computer will be looking for 19# injectors. There are good deals on nice used meters all over Corral. I got mine pretty cheap with injectors. If you need any help there, let me know and I'll give you all the info I can Jerry.
Post by: daminc on June 26, 2011, 09:19:35 PM
yea, I wanted to make the ram air too, like we talked about
Post by: vinnietbird on June 27, 2011, 06:26:42 AM
The ram air part......I forgot about that.
Post by: sarjxxx on June 28, 2011, 04:17:11 PM
Quote from: daminc;362308
Pretty much useless, but they're still really cool, so..... DO IT!!
I had one on mine for awhile, it was cool but it served absolutely no other purpose.
Post by: daminc on June 28, 2011, 04:36:06 PM
if anything, it will be a cold air source in front of the car.. I'll cost nothing to make, so it's a win-win situation until I get a supercharger
Post by: vinnietbird on June 28, 2011, 05:07:13 PM
I think it'll make a small difference. maybe not something you can feel , but a positive difference, plus, you can say "It has Ram Air".
Post by: daminc on June 28, 2011, 05:11:42 PM
my thoughts exactly it'll maybe help keep things cooler
Post by: vinnietbird on June 28, 2011, 05:27:20 PM
Cooler is better. If I had my &@*%$@# new radiator, the Sport might be cooler. .......I don't want to talk about it.
Post by: sarjxxx on June 28, 2011, 06:41:28 PM
Quote from: daminc;362425
Yep. That was the second biggest reason I did it to mine.
How do you plan to deal with the sudden and unforseen rainshower that wants to fill your combustion chambers with lovely liquid rust?
Post by: DVP on June 28, 2011, 06:49:05 PM
Just caught up on 75 pages... Its looking great. I want to see it done but I am really happy to see that you are doing everything right now and not rushing to get it together. Is that the same intake I sold you? Looks 100x better, just blasted. This thread always make me think, "Now why havent I touched my car again?"
Post by: daminc on June 28, 2011, 07:24:42 PM
No, it's Vinnie's old intake..... my wife bought me a Christmas present
Post by: daminc on June 28, 2011, 07:25:42 PM
Quote from: sarjxxx;362446
lol..... watch and learn........
Post by: daminc on July 03, 2011, 01:34:00 PM
getting the intake ready for install.....
Got a free T-body...had to change the arm over to make it work... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1562.jpg)
Post by: vinnietbird on July 03, 2011, 08:39:17 PM
Nice work. On my throttle bodies, I take the leading edge, where the air enters the throttle body, and roll the edge like a trumpet and smooth it really nice. I doubt it help a lot for air flow, but in my mind it adds tons of power.LOL. Just one of those things I like to do.
Post by: daminc on July 03, 2011, 10:21:30 PM
Well if it adds a ton of power, then I'll do it.....lol I think I'm going to order some flowtech afterburner lers, and my mid pipes tomorrow.... Pulled out my driveshaft.... going to clean it up tomorrow after I finish getting the intake ready.... things are coming together.... I may be starting this baby soon
Post by: sarjxxx on July 03, 2011, 11:34:23 PM
well afterburners will add quite a bit of power too lol
Post by: vinnietbird on July 04, 2011, 08:42:21 AM
I'm still looking for replacement lers. can't make my mind up, so I'm waiting until I do. Any idea how loud the afterburner lers are? I'm not really familiar with them.
Post by: daminc on July 04, 2011, 08:55:45 AM
Quote from: vinnietbird;362778
Kinda like this http://www.youtube.com/watch?v=XC2bOXivdis (http://"http://www.youtube.com/watch?v=XC2bOXivdis")
Post by: vinnietbird on July 04, 2011, 09:46:39 AM
I had to listen twice. The Thunderbird sounds a lot like that now. That sounds pretty mean. The Sport does sound kind of sinister, and I like it, especially the looks it gets when I start it, or roll up next to someone, but, it can get annoying on a long drive for me.6 of one, half a dozen of the other. That's why I'm in no hurry to swap the Flows yet. Gotta be "just right". I'm looking. I'll wait to hear them on your car....then maybe I'll copy you. LOL.
Post by: daminc on July 04, 2011, 11:52:59 AM
I thought about going quieter, but I'm only going around the corner with it..... the vert will get a less noisy ler when it's done... it goes farther
Post by: vinnietbird on July 04, 2011, 12:52:40 PM
I love the sound of the Sport, just after 45 minutes or an hour it bugs me. On the other hand, I don't drive for that long at a time that often in the Sport. On long trips we take the Maxima. As I stated, like yesterday, I had a "kid" (probably early 20's) pull up next to me with his girlfriend and he was revving his engine...The Sport was sitting at idle, and I looked over when I saw he was trying to get my attention, and I revved the Sport and things then got loud (I'd guess he had stock lers from the sound of it...nice little tone, but,stock tone)..., and his girl started laughing at him. He looked disturbed at her, and when the light turned green he took off, and I hit the gas and he saw the tail lights til the next light from a distance.LOL. He didn't look amused at her still laughing when we came to the next stop, at which time I was laughing too. Good times. he was in a mid 90's Mustang GT. I didn't give the Sport all she had. I guess I didn't need to. Felt good. I really don't do that often, but I like to do that when the time is just right......like when an idiot is trying to show off for his girlfriend. Gives them something to talk about later.LOL.
Post by: daminc on July 06, 2011, 10:14:40 PM
Got another box of goodies today. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1570.jpg)
Going to toss the old DS in till I find a better one. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1571.jpg)
got the cover.... now I need a boot that will work..... I may try and move the shifter to center it. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1568.jpg)
Do you have an x, or h pipe? and do you have cats on it too?
Post by: daminc on July 06, 2011, 10:42:15 PM
Quote from: vinnietbird;362956
It wouldn't be too hard to move the shifter a little.....it wouldn't take much at all.
my thoughts exactly... I'm thinking a stock type of boot will work then
Post by: thunderjet302 on July 06, 2011, 11:22:18 PM
Quote from: daminc;362957
2.5" mandrel bent exhaust with a H-pipe, no cats. It's a kit for a Mustang. With these lers it sounds like a motor boat at idle. This might be a bit more helpful.
Post by: daminc on July 07, 2011, 07:31:50 AM
Well then I'm guessing my car will sound exactly like yours, seein that we have almost the same identical parts in our cars....... And I wasn't even trying to copy you.... It's crazy how that just happened.
Post by: thunderjet302 on July 07, 2011, 04:51:38 PM
Quote from: daminc;362971
I know. Once you got that cam I thought you were copying my engine ;). I didn't copy the ammount of rust you had though.
Post by: vinnietbird on July 07, 2011, 04:55:23 PM
I suppose I had better find a different kind of ler. I can't be having the Sport sound like you two guys.
Post by: daminc on July 07, 2011, 06:41:25 PM
yours will sound diff with the X-pipe, Vinnie... no need to worry...lol
Post by: daminc on July 07, 2011, 06:47:54 PM
Quote from: thunderjet302;362984
it's really funny, because I research for months before I buy something... and after I do end up buying something, you say you already have it and I never once looked at what you had.....lol. At least we have diff TB's... I actually put a 70mm on instead of the 65 I was planning
Post by: vinnietbird on July 07, 2011, 07:04:06 PM
I'm looking around. Unsure right now. I tend to.......you're not going to believe this....I tend to change my mind sometimes.
Post by: sarjxxx on July 07, 2011, 08:36:59 PM
only 50 bucks a pop too, I'm considering one of these for until I can get my hands on a 50 series like I want....
Post by: daminc on July 07, 2011, 09:34:53 PM
I was a little surprised at the price myself
Post by: daminc on July 08, 2011, 09:04:27 PM
I got a question........... should I try to get the car running before I connect the mass air? would it cut down my chance of chasing a potential running, or idling problem after everything that I redid to it..... Or would it not really matter after going as far as I went.
Post by: thewestie on July 08, 2011, 09:15:19 PM
The I wanna hear it run side of me says fire it up but the I'm sick of my, ill get to it later side says I can wait and do it rite :)
Post by: vinnietbird on July 09, 2011, 01:03:28 AM
Do the Mass Air and get it all together first. With the cam, and Mass Air computer, it'll probably run bad without the Mass Air. Just do it all the first time so you don't have to go back and do it again.
My own opinion.
Post by: cougarman on July 09, 2011, 01:41:48 AM
Quote from: vinnietbird;363070
My own opinion.
That's what I did. ^ ^
Post by: daminc on July 09, 2011, 07:21:43 AM
ah yes.... the guy at the shop said it won't stay running without mass air...... sorry, It's been a while
I'll probably put the intake on tomorrow, wire the computer, and put the mid pipes, and lers on. I think that will make it a very fun day.
Post by: vinnietbird on July 09, 2011, 08:19:14 AM
Excitement !!! So close. Take your time with the Mass Air wiring. It's easy, but very important it's done right. I'll be in touch later. Boneyard time. I'm hoping for good things......not expecting any, but hopeful.
Post by: daminc on July 09, 2011, 09:01:17 AM
oh yea... do it right the first time..... after tomorrow, I think I'm down to installing a bunch of hoses and vac lines... Still have to splice the fuel lines (have to borrow the kit from a friend next week), and extend the wires to the O2 sensors
Post by: vinnietbird on July 11, 2011, 08:45:44 AM
they have some new vacuum line stuff at the local Autozone in case yours are brittle and they have a LOT of different vacuum hose ends and elbows to get them just right with the Explorer intake.The only vacuum lines I don't have anymore are from the smog equipment. The rest are still intact.
Post by: daminc on July 11, 2011, 02:47:42 PM
I'll see what Napa has first. I have to leave the Island to go to autozone. if the lines from the 3.8 are the right size and length, I'll try to use some of those first,
New pics later....
Post by: vinnietbird on July 11, 2011, 04:20:35 PM
Well, NAPA is fine, too. Autozone is about 6 blocks from me, so that's my first choice..LOL. Jerry, do you need a brand new red door handle cup for the door panel? I don't remember which side it is, but it's NOS and I'll pass it to you if you'd like it. I have NOS gray ones for my car.
Post by: daminc on July 11, 2011, 06:41:28 PM
did some dry fitting to see what I need to finish so far, my exhaust is below my brace that we were discussing in the other post (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1578.jpg)
then put a few more thing in today, to see what else I need.... Apparently a bunch of hose clamps to start with.. lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1580.jpg)
Post by: vinnietbird on July 11, 2011, 06:50:01 PM
Nice work !!! What's the hose on top of the upper intake? Everything is looking rather Sweet !!!
Speaking of "Sweet", Jerry. You may appreciate this...I have a CD of "The Sweet" (a group from the early 70's). I've been listening to it all day while I was working on the Sport. Old tunes.
Post by: daminc on July 11, 2011, 06:54:43 PM
there's a bunch of hoses I didn't connect yet... not sure where most of them go right now...lol. I need to lose a few I think, because of the smog pump not being connected.. I also need to install the right throttle cable. the V6 cable is still attached
Post by: vinnietbird on July 11, 2011, 07:04:50 PM
Got it. If I can help, let me know. I'm glad to see the old girl as far along as it is now.
Post by: daminc on July 11, 2011, 07:32:02 PM
I kinda like my fancy intake plate.... needs to be polished though
Post by: vinnietbird on July 13, 2011, 09:52:34 PM
Hey Jerry......I see 19# injectors on the engine....Are you going to 24's later on?
Post by: daminc on July 13, 2011, 10:24:18 PM
I'm gonna have to wait with the 24s... need some other things before I get another mass air sensor... need a million small ticket items. I'll swap them next round when I swap to the full digi dash, and other assorted goodies that I want to do. I'm really dying to get it running now.... I'm sure I'll be swapping and polishing things after I get it going.... otherwise it wouldn't be a project car to play with.
Post by: vinnietbird on July 13, 2011, 10:42:15 PM
You are the only guy, other than myself that wants full digi gauges. I don't like the buttstuffog gauges, but, I'm also not going to attempt to swap them out.
Post by: daminc on July 13, 2011, 10:54:33 PM
I figure I'm half way there already..... I already put the sender in the tank for it too. so my gauge is going to work backwards for a bit
Post by: vinnietbird on July 13, 2011, 11:09:43 PM
I'd try it if I can find an '87 that has everything. I'm looking for another T-bird now...to drive.
Post by: ZondaC12 on July 14, 2011, 07:48:11 AM
I love the full digi dash on the red car. Always have. Can't wait to have it back, along with the kickass Premium Sound LOL. (To me it really sounds good tho haha) I like the fancy super-tough band clamps on the H-pipe jerry good call :D
Post by: daminc on July 14, 2011, 09:19:24 AM
Thanks. I wanted something that I could take apart when I decided to change things down there
Post by: vinnietbird on July 14, 2011, 04:32:12 PM
I wanted to change things down there, but Gayle said she was very happy with the way I am.LOL.LOL.
Post by: thunderjet302 on July 14, 2011, 04:55:07 PM
Quote from: daminc;363079
It'll run fine. I ran mine on SD for about a year. I went to MAF for the bigger injectors and better idle control (ie now it will idle at 850 rpms where as with SD I had to have it idle at 1050 in park). If mine ran on SD your engine should too.
Post by: daminc on July 14, 2011, 05:32:27 PM
your a nut Vinnie..... lol
either way, mass air or not....I guess I'm covered then.....we'll see what this weekend brings.. Should be winding up the misc stuff.....
Post by: ZondaC12 on July 14, 2011, 07:39:01 PM
HAHAHAHA you friggin' jackass. Nice vinnie, nice. Glad to hear that everyone in the relationship is satisfied. Really. It's a good thing, comforting news. Praise be to Allah!.....wait.
Post by: vinnietbird on July 14, 2011, 08:30:18 PM
Jerry, you have a Mass Air meter to use don't you? Good for the 19's?
Post by: daminc on July 14, 2011, 09:03:22 PM
Quote from: vinnietbird;363454
yep, it's sittin on the air filter box in the last engine pic.... I'm good to go
Post by: daminc on July 14, 2011, 09:05:52 PM
Quote from: vinnietbird;363398
you need a cougar this time ;)
Post by: vinnietbird on July 14, 2011, 09:07:55 PM
I see it now. I'm sending you the NOS door handle cup tomorrow. It's red like your interior. You may be able to use it.
Post by: daminc on July 14, 2011, 09:13:12 PM
which side is it? I forgot to reply the other day about that. I think the drivers is a little cracked and the pass side is still in 1 piece, if you can believe that
Post by: vinnietbird on July 14, 2011, 09:16:45 PM
Not sure which side it is...either way, you'll be able to replace the driver side or have a spare for the future.LOL. These are crazy hard to find. I have a pair of gray ones stashed away as a "just in case"..
Post by: daminc on July 14, 2011, 09:17:52 PM
sounds like a plan, thanks
Post by: vinnietbird on July 14, 2011, 09:24:41 PM
No problem. It's been a while since I sent anything to you.....gotta keep in practice.
Post by: daminc on July 14, 2011, 09:31:04 PM
LOL... don't let me stop you from sending stuff...
Post by: vinnietbird on July 14, 2011, 09:38:40 PM
I won't let you stop me.
Post by: daminc on July 15, 2011, 09:12:48 PM
I've been creating today....we'll see if it works when I'm done (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1594.jpg)
Post by: daminc on July 22, 2011, 06:21:00 PM
ok, I think I got it figured out with everyones help yesterday..... How's this? (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1621.jpg)
borrowed a fuel line repair kit from my friend at the auto shop... spliced the fuel lines this morning..... also needed a new connector for the fuel filter, seeing the line was in bad condition at the connector (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1618.jpg)
got my lines for the AOD... new U-joints, new neg battery cable hose clamps. 2-1/2 exhaust pipe extensions for under the car.... misc other things...... hope to maybe start it on sunday or monday....fingers crossed
also need to extend the wires for my O2 sensors and re-pin the computer.... it's all coming together.........
Post by: daminc on July 22, 2011, 06:24:24 PM
I noticed it's getting quite crowded under the hood again..... I'm also going to put the stock fan on for right now.... until I get it going
Post by: vinnietbird on July 22, 2011, 06:30:54 PM
Pull the intake plate, hang the salt and pepper shakers below it. Didn't I have a slot there for that? I did on my last one before that. If not, cut one. Just a notch from the edge under the plate to hang that wiring assembly from.
Looking good !!! Assembly is going well.
Are the water lines from the lower intake and water pipes that go through the intake spacer capped off?
Post by: daminc on July 22, 2011, 07:07:09 PM
it popped off the other day when I was fiddling around, I gotta put it back on..the intake plate isn't crewed on yet I capped the water lines.... the intake hose is just looped around the intake and going nowhere.... I didn't have any cool caps like you.. lol
Post by: vinnietbird on July 22, 2011, 08:22:11 PM
I got my caps at Lowes. They are with the fasteners, all different sizes and colors, and super cheap for a small bag.
Post by: The Shredder on July 23, 2011, 08:56:21 AM
It's looking great Jerry! The race is on for the first start. I'm holding my breath.
Post by: vinnietbird on July 23, 2011, 05:48:03 PM
Jerry, how's it going today? Any progress? Did you drive the car around the block? LOL.
Post by: daminc on July 23, 2011, 06:43:56 PM
got the u-joints replaced, and half the exhaust bolted down..... more fun tomorrow....
Post by: daminc on July 24, 2011, 02:57:50 PM
I just joined the ranks of everyone who took their crossmember off to install their exhaust.. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1622.jpg)
a few random under car pics..... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1623.jpg)
Post by: vinnietbird on July 24, 2011, 04:25:32 PM
Sweeeeet !!! You'll never miss the little cross member thingy. You guys are just working away, and here I sit (I did have to work at the job though). I need some Sport time. I think tomorrow will be a good day for that.
Post by: daminc on July 24, 2011, 10:04:40 PM
I do feel a little bad about removing the cross member thingy...it's one of the few pieces of metal on my car that actually survived from day 1
Post by: daminc on July 24, 2011, 10:10:44 PM
I'm down to a few thing to finish up..........Battery cable, AOD lines, Shifter relocation, computer re-pin, o2 sensor wires....... and I think that's about it.....I'm getting very scared now. Never thought I would see this day come..
Post by: daminc on July 24, 2011, 10:14:07 PM
Just realized I'm on page 300.........I'll try to finish the project on page 302
Post by: hwy73 on July 24, 2011, 10:33:59 PM
QUOTE=daminc;363971]I do feel a little bad about removing the cross member thingy...it's one of the few pieces of metal on my car that actually survived from day 1[/QUOTE]
That's going to cost you 0.1 seconds in the corners. Car is now junk. (j/k) ;);)
Your work is amazing, car looks great.
But we all know black Cougars are the quickest! :popcorn::popcorn:
Post by: sarjxxx on July 24, 2011, 10:52:44 PM
Post by: vinnietbird on July 25, 2011, 12:06:34 AM
Take the little cross member thing and build a little shadow box for it and hang it on the wall.
Post by: daminc on July 25, 2011, 08:19:17 AM
I'll just hang it on the wall with the small section of quarter panel that didn't have rust either...lol
Post by: vinnietbird on July 25, 2011, 08:49:20 AM
You can name it "once upon a time................"
Post by: daminc on July 26, 2011, 06:38:35 PM
a little more done, and even closer to the finish.... installed rad hoses, throttle cable cruise cable, HORNS........ hood release, trans cooler, misc other small ticket items.... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1644.jpg)
I assume this is for the light under the hood (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1641.jpg)
Post by: The Shredder on July 26, 2011, 07:15:24 PM
Jerry, the last picture is the connector to the hood lamp. Some hoods had them, some didn't. In the second to last picture, that plugs into your EGR position valve sensor (EVP) on the back of the EGR valve - you can see the connector on the back of the EGR in your picture.
I'm not 100% sure on the other ones, but it looks like A/C related.
Post by: daminc on July 26, 2011, 07:54:05 PM
Quote from: The Shredder;364089
Thanks, I couldn't see the plug under there...I also have a hood light
Post by: hwy73 on July 26, 2011, 08:01:08 PM
In the third picture, I believe that pigtail is for the sensor for the temp gauge on the digital dash. The buttstuffog gauges uses a one-pin connector there, but the double is also apparently present, as it is on my car with buttstuffog.
Post by: sarjxxx on July 26, 2011, 08:04:40 PM
Quote from: hwy73;364092
In the first picture, I believe that pigtail is for the sensor for the temp gauge on the digital dash. The buttstuffog gauges uses a one-pin connector there, but the double is also apparently present, as it is on my car with buttstuffog.
I agree. I have base cluster and that plug is connected to thin air in mine e/c as well.
Post by: daminc on July 26, 2011, 08:17:12 PM
I had a feeling it was for that..... the next pic after that one will finish the connector questions
Post by: thunderjet302 on July 27, 2011, 12:03:47 AM
I can check mine tomorrow and see where they connect if you want.
Post by: vinnietbird on July 27, 2011, 07:09:16 AM
Jerry, is your hood latch bracket bent? It looks curved to me. maybe it's the picture. Exactly which plug are you needing to know about now? There's a couple on the Sport that have no place to be, just hanging there.
Post by: daminc on July 27, 2011, 07:22:06 AM
it would be the connector in the 4th pic I posted yesterday... down under the battery area with all the fusible links and connectors...
My bracket always had a bit of a curve to it since the car was new...... never understood why... I'll try to straighten it when I put the front back on for good... I'm thinking the car was welded together a bit wrong when the car was built....I remember things were a bit off when I was replacing parts and panels, and a ton of factory shims on one side of the fenders, and nothing on the other side.....
Post by: hwy73 on July 27, 2011, 09:53:10 AM
How many wires are in it? Does it go out to the driver's side inner fender? The 88 EVTM shows a pigtail to test the ws/washer pump in that mess.
We're all jumping on this I guess because the finish line is in sight, and it's like we are helping to "get it going" from afar !
Post by: daminc on July 27, 2011, 03:26:42 PM
3 wire... Is in the same place where all the other connectors plug into the other harnesses.... looks like it goes into the firewall in the big harness under the wiper motor (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_1645.jpg)
Post by: hwy73 on July 27, 2011, 04:37:29 PM
From the 88 EVTM....
Post by: daminc on July 27, 2011, 04:50:06 PM
I got that pic in my 87 book....still can't figure out if it's supposed to go to something or not
Post by: vinnietbird on July 27, 2011, 04:50:10 PM
I don't have that round plug on the Sport. That flat one with two holes is there, though.....doing nothing just like yours.
Post by: daminc on July 27, 2011, 04:51:42 PM
unless it goes to the cornering lamp relays that I haven't installed yet.....
Post by: daminc on July 27, 2011, 04:54:03 PM
I did pull the harness out of the bird that has cornering lamps and all the bells and whistles lighting package.....
Post by: vinnietbird on July 27, 2011, 04:57:09 PM
Could be. Mine doesn't have those lights.
Post by: Kitz Kat on July 27, 2011, 05:01:55 PM
F the extras fire the bitch up!!!
Post by: hwy73 on July 27, 2011, 05:02:40 PM
Maybe it is cornering lamps, in the drawing I posted, is it the connector that has what looks like a cap on it?... Next to connector C317 ?
Post by: hwy73 on July 27, 2011, 05:04:55 PM
From my car, don't know if it helps...
Post by: daminc on July 27, 2011, 05:06:11 PM
Quote from: Kitz Kat;364153
lol.....
Post by: hwy73 on July 27, 2011, 05:07:19 PM
2 more, my car has cornering lights, so if that is it, its plugged in
Post by: daminc on July 27, 2011, 05:08:13 PM
Quote from: hwy73;364155
I'll look for the rest of the stuff for the cornering lamps tomorrow... could be the connector
Post by: hwy73 on July 27, 2011, 05:30:30 PM
According to the book, C189 is the cornering lights, which should have BR/W + P/Y. It is gray, 2 pin, flat. Jerry, in your picture I believe it's there at the center-right, hooked up. So I think the round plug you are holding is something else, dam!
Post by: thunderjet302 on July 27, 2011, 06:33:15 PM
Quote from: daminc;364085
That first one is for the digital temp sensor. I looked on mine today. When I get home from work tonight I'll pull the ignition coil cover off and see if that plug is on my T-bird. My car has every option but the sunroof so if it goes to something it'll be plugged in on my car.
Post by: daminc on July 27, 2011, 09:38:15 PM
awesome, thanks
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: thunderjet302 on July 27, 2011, 09:50:32 PM
I'm 95% certain that mystery plug by the coil is for the low oil level sensor.
Post by: daminc on July 27, 2011, 10:00:56 PM
I'm looking it up in the book now...
Post by: daminc on July 27, 2011, 10:35:46 PM
well, I just went through the entire evtm...I can't find ANYTHING that plugs into ANY 3 terminal connector in that location of the car.. the low oil sensor has only 2 wires according to the book, and the relay is behind the dash
Post by: daminc on July 27, 2011, 10:43:42 PM
Vinnie... you still got that low oil sensor around that you pulled out? if you do, what does the plug look like
Post by: daminc on July 31, 2011, 05:23:41 PM
todays progress.... Plugs in, AOD lines on..... Fan on (temporarily) AOD bolted to X-member... AOD x-member bolted down
I think I'm down to computer, extending the O2 sensor wires, and I have to move the shifter to the center of the console now....and toss the battery in, and wire the starter...... not all in that order...lol
Post by: vinnietbird on July 31, 2011, 10:26:03 PM
Jerry, I'm surprised you didn't flip the tranny cooler the other way and route the hoses down the passenger side. Glad to see you're down to just a few things. Man, I wish I was there.
Post by: daminc on July 31, 2011, 10:52:27 PM
actually...I was looking there and there was more room on the drivers side to get it past everything .. so that's where it went...yep a few things left.... I'll try to do them during the week after work. Hated to have to put the old fan on, but it's temp....and no I don't have a shroud for it...lol I will be careful
Post by: vinnietbird on July 31, 2011, 11:02:59 PM
I'm proud for you. It's been a looooong road you and the Cougar have traveled.
Post by: daminc on July 31, 2011, 11:33:06 PM
Many miles, and it's only moved 10 feet in 2 1/2 years
Post by: vinnietbird on July 31, 2011, 11:46:44 PM
That'll change soon enough.LOL.
Post by: flylear45 on August 01, 2011, 08:16:39 AM
Almost there, almost there!
Post by: daminc on August 15, 2011, 10:11:21 PM
OK, had to take care of some stuff the last couple of weeks..... back to the car this weekend....
Post by: vinnietbird on August 15, 2011, 10:42:19 PM
Hey, after all this time, what's a few more days? Nothing to it.
I'm hoping to get some Sport time next week. Got a little today, but I want more.
Post by: Kitz Kat on September 01, 2011, 07:24:32 AM
Whats up! To busy to work on it?
Post by: daminc on September 01, 2011, 07:49:36 AM
Quote from: Kitz Kat;366537
Unfortunately... going to try for the long weekend starting tomorrow....I can't believe how close it is too, It's really killing me here
Post by: vinnietbird on September 01, 2011, 08:52:13 AM
Good luck Jerry. If you do anything at all, at least that's something. I'm keeping my fingers crossed for you....well, mentally anyway. I need my hands for work.
Post by: daminc on September 01, 2011, 01:04:35 PM
I suppose I could be out there instead of typing this...lol I'm going out there now...I blew a flex brake line last week.....installing the new one and bleeding brakes in a bit
Post by: vinnietbird on September 01, 2011, 02:06:24 PM
I took Gayle to lunch....other than that, nothing. Just don't feel like another day in the over 104 degree weather. Maybe this weekend after work. Gonna re-clock the drive shaft,change the front brakes.and install my O2 sensors. All of that MIGHT take an hour or hour and a half at the most. Just not today,. Good luck on the Cougar.
Post by: daminc on September 24, 2011, 06:58:09 PM
finally had a few hrs to catch up on some stuff I got front brakes.. will fix the rear brake problem as I finish things.
got the shifter moved again...and bolted down. I think this will work out with the boot. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0110.jpg)
started the wiring for mass air, will probably finish that tomorrow. (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0115.jpg)
after the computer wiring.. the starter needs to be wired, the radiator filled, and the battery put in..... and I think I can turn the key.
oh yea... I blew out my gerbil balls.....dammit
Post by: 1BadBird on September 24, 2011, 07:23:21 PM
Poor Gerbil ......... lol
Post by: thunderjet302 on September 25, 2011, 09:46:44 PM
I see you're using an A9L computer. I think there is an issue with the neutral safety switch wiring between an auto and manual trans car where the A9L can get fried. I'll see if I can find the info. I could be wrong though.
Post by: daminc on October 04, 2011, 06:07:22 PM
Mass air wiring done...... starter wires, and battery..... that's all that's left
Post by: flylear45 on October 04, 2011, 07:50:25 PM
Woot!:D
Post by: DVP on October 05, 2011, 10:37:59 AM
I just wanted to add I still think you are crazy.
Post by: daminc on October 05, 2011, 01:39:25 PM
Quote from: DVP;369241
why is that?
Post by: daminc on October 06, 2011, 09:00:00 PM
ok, starter is wired, and battery is charging.... fire extinguisher is in close reach...lol I won't be able to get to it until Saturday...I'll put the battery in, and if there's no fire, I'll see if I have interior lights, and probably do a keyon test first..... Then it's in Gods hands if it sees all the sensors, and the fuel pump primes......phew...what a head rush... lol
Post by: thewestie on October 06, 2011, 09:08:23 PM
Go for it.....
Post by: 1Bad88tbird on October 06, 2011, 09:39:54 PM
Finally, the moment we've all been waiting for. lol! Good luck I hope it fires on the first try.
Post by: vinnietbird on October 06, 2011, 11:05:57 PM
Jerry, you need this on video.
Post by: flylear45 on October 07, 2011, 06:13:23 AM
Good luck Jerry!
Post by: daminc on October 07, 2011, 07:46:33 AM
Quote from: vinnietbird;369415
hopefully it won't be a video of me putting out the fire....lol Yes, I'm charging the cam.. it might not be the first turn of the key, but it will be recorded after all systems a are a go....oh yea, I need to fill the radiator too before I forget... wouldn't that suck to forget doing that
Post by: thunderjet302 on October 07, 2011, 12:27:48 PM
Before you start it run a KOEO test. That way you'll know of any major problems before you fire it :).
Post by: daminc on October 07, 2011, 01:49:01 PM
Quote from: thunderjet302;369443
I'm already way ahead of you......
Post by: Kitz Kat on October 07, 2011, 02:17:53 PM
I was going to question using the 9AL also. Here is some info on it. http://www.foxtbirdcougarforums.com/showthread.php?31025-Fix-for-poor-idle-rich-mixture-and-poor-performance-after-HO-T-5-mass-air-swap&highlight=A9L
Post by: daminc on October 07, 2011, 04:49:44 PM
you know me... livin life on the edge. It's all a spin of the wheel right now. actually getting it to start will be my big problem right now...
I do remember that thread though..
Post by: daminc on October 07, 2011, 06:39:20 PM
Look at me go..... (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0144.jpg)
Post by: vinnietbird on October 07, 2011, 07:25:25 PM
Wow......awesome. Just awesome. I miss that intake. I'm going to polish another upper soon and do some visual mods. Not like yours. It's the only one. I'll do something a little different. After I got rid of the Explorer upper, I've never been happy. Not even with the "almighty" highly loved, GT-40 tubular intake. Maybe this Cobra will make me happy (GO COBRA !!!). I hope to hear great things by the end of tomorrow about the Cougar starting up. I work til 3:00 then I'll be checking in here to see.........or you could just text me.
Post by: daminc on October 08, 2011, 12:25:08 AM
Hopefully I'll have good new to report....
Post by: vinnietbird on October 08, 2011, 06:47:14 AM
I hope so too. Can't wait to hear it run !!!!!
Post by: Kitz Kat on October 08, 2011, 08:24:13 AM
Don't forget to crank it a bit without the coil wire on,get some oil moving.
Post by: daminc on October 08, 2011, 08:47:17 AM
Quote from: Kitz Kat;369498
Yes, I will... also have to dbl check some things before I turn the key...
Post by: daminc on October 08, 2011, 08:50:26 AM
[SIZE="4"]Does anyone have the plastic piece for the shifter linkage, where it bolts to the lever on the AOD ?[/SIZE]
Post by: daminc on October 08, 2011, 09:48:12 AM
Ok everyone...I'm heading out there. This may be the end of an era...lol
Post by: flylear45 on October 08, 2011, 09:57:39 AM
Quote from: daminc;369506
It will be the beginning of the NEW era!
Post by: The Shredder on October 08, 2011, 02:59:32 PM
And????? Holding my breath!
Post by: thewestie on October 08, 2011, 05:08:34 PM
Post by: 88turbo on October 08, 2011, 05:23:54 PM
we cant wait any longer!!!!
Post by: vinnietbird on October 08, 2011, 05:29:59 PM
Aaaaaah yes, the dramatic pause......................................
Post by: mercury-man on October 08, 2011, 05:38:28 PM
:jerry: :jerry: :jerry:.....
Post by: daminc on October 08, 2011, 08:20:42 PM
I need a battery with more balls to turn the new motor over... I was hoping to use the one out of the parts bird until i bought a new one.....buuuuuut....... I'll be shopping for a new one on Monday I guess... lol hold on a little longer guys.
Radiator is filled, and a bunch of misc stuff is out of the way
Post by: daminc on October 08, 2011, 08:21:14 PM
Quote from: mercury-man;369539
I know you been waiting to use that, Dan...lol
Post by: Kitz Kat on October 09, 2011, 04:34:12 AM
Quote from: daminc;369503
Do you mean the round grommet thing? if so they can be had most times in the help section in the parts store.
Post by: daminc on October 09, 2011, 07:54:30 AM
Quote from: Kitz Kat;369596
I thinks so, ,but not knowing what goes there, I'm a little lost about what I need as a replacement
Post by: Kitz Kat on October 09, 2011, 07:58:22 AM
Looks like this? https://www.dormanproducts.com/catalog/motormite/152-158TFinal.pdf#Page=5
Post by: daminc on October 09, 2011, 08:36:46 AM
is it the 14041 bushing kit I need
Post by: Kitz Kat on October 09, 2011, 08:48:24 AM
It probably has what you need in it.
Post by: daminc on October 09, 2011, 09:26:02 AM
thanks, I'll give it a go
Post by: vinnietbird on October 09, 2011, 07:37:17 PM
What about the pice that goes into the bushing? I can't find one yet,Jerry.
Post by: daminc on October 09, 2011, 08:14:00 PM
I'm looking too... the linkage kit is $3.99
Post by: HAVI on October 09, 2011, 09:38:48 PM
So close!
yet, so far away. LOL
Post by: daminc on October 09, 2011, 11:04:58 PM
oh well....I hear there's another saturday coming up again....
Post by: The Shredder on October 10, 2011, 12:57:56 AM
Come on!!! Steal the battery from the other cougar!!!! Let's hear that thing purrrrrrrrr.
Post by: vinnietbird on October 10, 2011, 07:06:16 AM
Beau may have the part that the cable hooks to. He went to a 5 speed.
Post by: daminc on October 10, 2011, 07:55:20 AM
Quote from: The Shredder;369662
It barely turns the motor over in the vert..... It'll never start the 87
Post by: 6 Fingered Man on October 11, 2011, 01:05:35 AM
Wow, well that was 3.5 hrs of my life well spent.
Read a lot, skimmed a lot, but i saw every pic and every page of the thread.. Now that im caught up i cant wait to see it finish. What a project.
Post by: daminc on October 11, 2011, 07:40:18 AM
Quote from: 6 Fingered Man;369798
Thank you, I cant wait to see the finish either.
Post by: Kitz Kat on October 16, 2011, 07:25:36 AM
Another Saturday passed.
Post by: flylear45 on October 16, 2011, 07:45:48 AM
Quote from: Kitz Kat;370248
Having any luck? :popcorn:
Post by: daminc on October 16, 2011, 09:24:33 AM
No, haven't touched it... been busy again...... Stupid work maybe something tomorrow
Post by: Kitz Kat on October 18, 2011, 03:48:59 PM
I'm tired of hearing your excuses, don't be scared! Fire that kitty up!
Post by: daminc on October 18, 2011, 05:29:06 PM
looks like another couple weeks till I get a chance to get it going..... still haven't even got a battery for it
Post by: Kitz Kat on October 18, 2011, 05:55:26 PM
You want me to take road trip with my kitty to make love with yours?, need a few hundred miles on mine before snow. I'll bring my buddy Mike, with the car and house that looks like yours. Then we will fire your kitty up, Friday sound good? If your not home leave the key under the mat, we will start without you!!
Post by: daminc on October 18, 2011, 06:28:18 PM
lol....
Post by: vinnietbird on October 18, 2011, 07:26:08 PM
Jerry, your trans. lever piece is on the way.
Post by: daminc on October 18, 2011, 09:03:50 PM
Yay........
Post by: Kitz Kat on October 20, 2011, 03:55:22 PM
I'm leaving in about an hour or two, Don't get to alarmed if you here my car in your driveway around midnight.
Post by: daminc on October 20, 2011, 05:53:07 PM
lol...ok
Post by: flylear45 on October 20, 2011, 08:58:40 PM
Don't make me come over there Jerry! By next Monday it'll have a turbo and Megasquirt!
Post by: daminc on October 20, 2011, 09:02:13 PM
for me?...bring it over Monday...lol
Post by: ZondaC12 on October 20, 2011, 10:30:36 PM
This is a lot of harassment. They're testing you Jerry. They're hoping you'll crack under pressure. DON'T BUY INTO THEIR GAMES
Post by: daminc on October 24, 2011, 01:20:40 PM
here ya go.... it's a little sideways, but it's not about the camera work, is it
This is 2nd start... I started it about a min earlier, and said to myself.....I need this on video...lol http://www.youtube.com/watch?v=dWSoubHjXIE (http://"http://www.youtube.com/watch?v=dWSoubHjXIE")
Post by: stangman_1987 on October 24, 2011, 01:35:19 PM
She sounds AMAZING!
Post by: EricCoolCats on October 24, 2011, 01:36:05 PM
Ahhhh....lopey idle, gotta love it. Congrats!
Post by: mercury-man on October 24, 2011, 02:03:16 PM
Well worth the wait man...HUH !!!
Post by: vinnietbird on October 24, 2011, 02:31:06 PM
nice work Jerry. How far til the actual test drive?
Post by: flylear45 on October 24, 2011, 02:43:06 PM
Woohoo!
Sounds great for the first start. Amazing, really.
Congratulations!
Post by: daminc on October 24, 2011, 02:44:48 PM
Quote from: vinnietbird;370936
Won't get put on the road til spring... Still have a bunch of things to do yet before it's road ready. But it actually runs... I really didn't expect it to start right up like that... Lol
Post by: Thunder Chicken on October 24, 2011, 02:55:29 PM
sounds good!
Post by: Kitz Kat on October 24, 2011, 03:23:56 PM
Congrats,I guess I can quit harassing you now.
Post by: vinnietbird on October 24, 2011, 03:58:03 PM
Quote from: Kitz Kat;370941
Why stop now?
Post by: Shadow on October 24, 2011, 04:00:47 PM
purrs like a kitten lol sounds good!
Post by: Chooglin on October 24, 2011, 05:55:41 PM
Sounds real good..............thanks for sharing this whole thing with us !!!!! why is there not a garage full of people for this occasion ?...........alll by yourself
Post by: vinnietbird on October 24, 2011, 07:10:13 PM
I think all alone with the car is the right way. It's been a personal journey. Gotta get the first sounds of that baby's love all to yourself.
Post by: daminc on October 24, 2011, 08:16:16 PM
Yea, I was all alone... My wife isn't even in town this week to hear it run for the first time... She's been waiting too. So I did the next best thing... I called a friend, and let him listen to it over the phone...lol
Post by: cougarman on October 24, 2011, 08:27:36 PM
Sounds great, congrats!!
Post by: thewestie on October 24, 2011, 09:24:21 PM
Awesome thanks. You can sleep well tonight
Post by: HAVI on October 24, 2011, 09:37:48 PM
What took you so long? :D
Post by: daminc on October 24, 2011, 09:41:33 PM
Quote from: HAVI;371001
very funny...lol
Post by: daminc on October 24, 2011, 09:56:05 PM
I did more work on it today after work.. I reinstalled the gas tank.. come to find out that my pump seized up in the 4 years it was sitting around.. So I got another one on Friday and installed it yesterday. still wasn't firing yesterday, so this morning I traced the lines front to back, and found that it was kinked right next to the fuel filter. Dropped the filter down which un-kinked the line, gave it a try, and the rest is on video.
Also installed my air shocks while I was under there. New battery is ready to go in tomorrow, and my AOD linkage should also be connected by tomorrow evening.....
More info as things happen. Looks like I'm really in the home stretch now. Glad everyone enjoyed the video Thanks for being a part of PROJECT EVOLUTION.
I'll make another video after it's together and moves... even if it's just in the driveway until spring
Post by: ZondaC12 on October 25, 2011, 12:20:55 AM
Yeeeea the weathermen are talking about spots of snow here and there....OMG a dusting of snow get the trucks out there DUMP that stuff!!!!
Oh yeah and congrats on starting your car or...something. I was getting so angry about salt I forgot what was even going on here. I am the keymaster are you the gatekeeper?
Post by: 1Bad88tbird on October 25, 2011, 12:46:37 AM
Woo Hoo!!!!!! Way to go Jerry!!! It's been a long time comming and I'm sure you loved every second of it sitting there ideling. Congrats, job well done!!
Post by: 5.0 tbird on October 25, 2011, 12:53:38 AM
Congrats, there's a light at the end of the tunnel now!
Post by: daminc on October 25, 2011, 07:23:26 PM
Another video .... this time I have all the van lines connected.... lol just a video of it idling, and a view of the car after the air shocks were installed. http://www.youtube.com/watch?v=gzKuhqHyqpw (http://"http://www.youtube.com/watch?v=gzKuhqHyqpw")
Post by: vinnietbird on October 25, 2011, 07:28:02 PM
I don't know. Seems a little...um...noisy. LOL. I think mine may be a little louder though...for now. The Cat sounds awesome. Congrats to you and the Cougar. I remember when our youngest used to call my Bird the "Giddy Giddy" car. That's what it sounded like....Giddy giddy giddy giddy giddy (in a deep burble). So, when are ya moving to Oklahoma? Black cars are fun in the summer time.
Post by: daminc on October 25, 2011, 07:32:48 PM
so far, it's way louder then I wanted it to be.....oh well..... I know what lers are NOT going on the vert...lol
Post by: The Shredder on October 25, 2011, 07:53:18 PM
Congratulations Jerry! It does seem to idle well. How does it rev? What lers are you running?
Mine is a little loud for my tastes, but will stay that way until I get the turbo on it. :)
Post by: Shadow on October 25, 2011, 07:56:00 PM
i like the exhaust note.. it probably just seems louder since it's in the garage and echoing off the walls.. once you back it out, she'll be a tad quieter
Post by: daminc on October 25, 2011, 08:24:26 PM
Quote from: The Shredder;371125
I have flowtech afterburners... I saw this video and said.... I want this sound... I guess I got pretty close http://www.youtube.com/watch?v=XC2bOXivdis&feature=results_main&playnext=1&list=PLABB6E20EE825CF20 (http://"http://www.youtube.com/watch?v=XC2bOXivdis&feature=results_main&playnext=1&list=PLABB6E20EE825CF20")
Post by: ZondaC12 on October 25, 2011, 09:58:53 PM
Sounds EXACTLY like it oughta sound. IMO, all blacked out cougar, or even with the bare metal finish trim, and turbines = white letter tires are a must lol. Especially with turbines. This is what these cars shoulda been! Tired a mantra as it is, it's the truth. Way too badass looking with the right combination to not have that kind of power.
Post by: sarjxxx on October 25, 2011, 10:46:38 PM
Pretty cool Jerry:D
I'm sure you're excited but you know I think it seems to be that most of us seem to be more excited than you are:rollin:
Post by: flylear45 on October 26, 2011, 04:26:52 AM
Yep, sounds a lot like the Mustang video. It'll probably be fine out on the road.
Definitely sounds potent.
Post by: daminc on October 26, 2011, 10:26:29 AM
I hope so... it's really loud behind it...lol glad that's not where I sit to drive....
Post by: daminc on October 29, 2011, 06:19:56 PM
power steering pump seized up..... got the bolts soaking to replace it... if I can't get it off. I may need to find another pump, pulley and (or)bracket for the car.... Buffalo weather is not kind on car bolts...
Post by: vinnietbird on October 29, 2011, 06:57:16 PM
pulleys are fairly cheap at Autozone. I PM'd about the pump, and the bracket should be fine, if you have to, snap the heads off the bolts with a socket and 1/2 inch breaker bar and pull the pump.
Post by: daminc on October 29, 2011, 07:06:20 PM
I can't get the pulley loose either...lol
Post by: vinnietbird on October 29, 2011, 07:18:25 PM
Is it a steel pulley or plastic?
Post by: daminc on October 29, 2011, 07:32:18 PM
Mmmmm..... I don't know.... I didn't bother to check..... I think aluminum
Post by: 4eyed'Cougar on October 30, 2011, 10:17:51 PM
HOLY SH*T MAN. I just read all 315 pages in the last 2 days and this is the most amazing build i have ever seen, congrats man. !!! AMAZING CAR.
Post by: thunderjet302 on October 30, 2011, 10:20:42 PM
Quote from: daminc;371134
Your car sounds exactly like mine. Probably because you have the same engine combo, headers, exhaust pipe size, and lers ;).
Congrats on getting it started.
Post by: daminc on October 30, 2011, 10:48:36 PM
thanks, it felt good to hear it run that good right off the start... figured it was going to be a long battle to even keep it running.
Post by: daminc on November 05, 2011, 05:46:34 PM
Power steering pump swapped today... Gotta love the whine of an 80s Merc steering ...lol
Post by: flylear45 on November 05, 2011, 07:03:56 PM
Quote from: daminc;372048
I was shocked at how quiet the Explorer pump is compared to the old whine of the Tbird pump.
Try a little Lucas PS fluid additive. It really, truly does some good.
Post by: daminc on November 05, 2011, 07:57:16 PM
Thanks, I'll give it a try...
Post by: vinnietbird on November 05, 2011, 08:24:57 PM
I use the tranny fluid and Lucas in mine. No whine......just electrical issues.LOL.
Post by: daminc on November 05, 2011, 08:32:42 PM
Quote from: vinnietbird;372070
I don't want electrical issues, I'll keep the whine....lol
Post by: vinnietbird on November 05, 2011, 08:58:00 PM
I'm whining because of electrical issues.
Post by: daminc on November 05, 2011, 10:51:47 PM
I don't seem to have those...... yet
Post by: Shadow on November 05, 2011, 10:59:38 PM
jerry.. knock on wood.. fast! lol
Post by: ZondaC12 on November 06, 2011, 01:26:23 AM
Quote from: vinnietbird;372083
LMAO after the two posts prior and then that comment I just lost it.
Post by: 1Bad88tbird on November 06, 2011, 07:43:12 AM
Nice way to start the morning, with some comic relief. lol!! Good morning guys!!
Post by: Thunder Chicken on November 06, 2011, 08:02:15 AM
Oh come on, an 80's Ford without PS whine isn't really an 80's Ford...
Post by: ZondaC12 on November 06, 2011, 09:26:58 AM
Exactly it's just something you come to know and love, or maybe not love. But any innocent bystander that happens to hop in wondering what's wrong just gets the not-so-reassuring "oh it's supposed to do that" lol
Post by: vinnietbird on November 06, 2011, 04:56:32 PM
The Sport's doesn't whine. Maybe she's not a real Ford....Hmmmmmmm
Post by: Shadow on November 06, 2011, 05:01:57 PM
did you use the exploder pump on yours?
Post by: vinnietbird on November 06, 2011, 08:29:04 PM
Me? No. I used an Autozone unit. Tranny fluid and Lucas. No issues at all.
Post by: thunderjet302 on November 07, 2011, 01:10:17 AM
Quote from: Thunder Chicken;372129
What whine? Maybe I just don't hear it because I'm used to it....
Post by: Haystack on November 07, 2011, 01:24:27 AM
This thread should turn into the lounge.
All joking aside, I would really like to see all of damiac's pictures and posts archived in their own thread.
Post by: daminc on November 07, 2011, 07:26:10 AM
Quote from: thunderjet302;372200
LOL... It's really noticeable when you don't hear it for 2 years
Post by: daminc on November 07, 2011, 07:34:38 AM
Quote from: Haystack;372202
I believe there's a way, and software to do that... I was going to try that after I got the car to move out of the garage on it's own power. I think then, the project will officially come to and end. I was thinking about posting a copy on Daminski.com also. this way if photobucket ever messes up my pics...I'll have another copy on the site and also burned to disk.
Post by: daminc on November 07, 2011, 07:39:47 AM
BTW.... [SIZE="5"]Looking for a TV cable for my aod[/SIZE]... The 3.8 was diff, and the bird had a C6 in it.
Post by: vinnietbird on November 07, 2011, 08:21:45 AM
Post by: Kitz Kat on November 10, 2011, 03:07:13 PM
You could use lokar set up if you can't find one.
Post by: 347Thunder on November 10, 2011, 04:33:08 PM
Quote from: daminc;372213
I think I might have one i'll take a look
Post by: daminc on November 10, 2011, 10:47:36 PM
Quote from: 347Thunder;372485
let me know if you have one
Post by: 347Thunder on November 11, 2011, 10:47:09 AM
I found two, one is from a mustang floor shifter and the other was from my car. The boot is ripped on the one from my car but it works fine($40 shipped your choice!!), if you don't want these I can get you one from the junk yard if its still there. (http://i174.photobucket.com/albums/w92/03grinnie/T-bird/IMAG0539.jpg)
Post by: daminc on November 11, 2011, 04:35:55 PM
Quote from: 347Thunder;372531
PM sent..
Post by: Kitz Kat on November 11, 2011, 05:20:35 PM
Hey Jerry hook a rope to it. I know you can make it work.lol
Post by: vinnietbird on November 11, 2011, 05:28:55 PM
I got a box from you today. I'll ship it back asap for you.
Post by: Kitz Kat on November 11, 2011, 05:49:19 PM
Fill us in.No secrets.
Post by: daminc on November 11, 2011, 06:16:46 PM
Quote from: Kitz Kat;372582
I could do some sort of MacGyver thing if I had to..... lol
Post by: daminc on November 11, 2011, 06:18:01 PM
Quote from: vinnietbird;372585
cool.... no rush
Post by: daminc on February 25, 2012, 04:45:25 PM
installed my TV cable today, and had to make a part (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_0414.jpg)
Post by: daminc on February 25, 2012, 04:48:40 PM
Very, very close to backing it out of the garage.... maybe next weekend. Weather permitting
Post by: beast50 on February 28, 2012, 04:52:37 AM
aha! brilliant way to replace that pesky grommet.
Post by: daminc on February 28, 2012, 08:02:18 AM
They actually sell that part I made. I thought $10 was to much for it, and needed it that moment. So I figured why not
Post by: ZondaC12 on February 28, 2012, 08:59:54 AM
Quote from: daminc;382280
LOL I like the attitude. Nice. Been there done that, love being able to say "Nope I'm not spending SQUAT on this, I'll pull it out of thin air!" You must be itching to drive it...
Post by: daminc on February 28, 2012, 09:13:07 AM
Quote from: ZondaC12;382282
Maybe a little
Post by: ZondaC12 on February 28, 2012, 11:12:22 AM
Well that's good. Wouldn't want ya all antsy.
Post by: daminc on March 02, 2012, 08:16:27 PM
Well, I backed the car out of the garage today..... Had it idling in the drive way, put it in drive to put it back in, and it dies. tried for almost 20 min to get it restarted. I believe I have either a fuel pressure or delivery problem. as soon as I depressurized the fuel rail, I turned the key, pump primed, and it started right up...
At least I got to sweep out the garage, and pull it back in. Have to solder the leak in the radiator, or swap it with my other. put new O-rings on the high pressure line of the PS pump. added more fluid to the AOD, and need to recheck in the morning.
I still can't believe it moved .... lol
Still need to fix the shifter, although I can still put it into gear by manually pushing the tab down with my other hand. need to check on my brakes again and fluid and lines. pedal goes pretty much to the floor, but the brakes are still stopping the car in the driveway. Weather permitting, I'll get some new pics tomorrow outside, without having to push it out there. Need to finish putting the front fenders, and front and back lights on, hood, and misc little things.
That's today's update
Post by: vinnietbird on March 02, 2012, 08:22:04 PM
Glad to hear you made some progress. Was that the little clip from the t-body shaft I sent? I got a little done today. Have to adjust the idle tomorrow.
Post by: daminc on March 02, 2012, 08:25:17 PM
yes it was Vinnie... I welded it right to that bolt... Sorry I didn't get back to you yesterday, I just saw your text this afternoon. I must have shut the vol down on my phone
Post by: vinnietbird on March 02, 2012, 08:43:23 PM
No problem, got it all together today. Still have to "fine tune" the idle, but that's not a big deal.............I hope.LOL.
Post by: Clayton on March 02, 2012, 09:41:17 PM
No video of the beast running? If I missed it Im sorry.
Feels good don't it?
Post by: daminc on March 02, 2012, 09:49:20 PM
Posted it a while back here it is again for those who might have missed it http://www.youtube.com/watch?v=gzKuhqHyqpw (http://"http://www.youtube.com/watch?v=gzKuhqHyqpw")
and the first start http://www.youtube.com/watch?v=dWSoubHjXIE&feature=related (http://"http://www.youtube.com/watch?v=dWSoubHjXIE&feature=related")
Post by: Bruce M on March 02, 2012, 10:59:27 PM
Nice, sounds good! Are those mustang tail pipe? I like how they dont stick out past the rear bumper. I'd like to get GT tail pipes and tuck them up where they cant be seen. Very nice Cougar.
Post by: daminc on March 02, 2012, 11:36:47 PM
They are GT tail pipes.. I like the angle cut on them I will most likely paint them black That's as high as I could get them. They won't fit between the tank and the trunk wells... not enough room
Post by: Shadow on March 03, 2012, 03:32:41 AM
i commend you, sir.. 4 years and 2 months since you started? i'd have sold it or shipped it off to the syard 3 years ago LOL i'm impatient, can you tell?
Post by: daminc on March 03, 2012, 12:24:06 PM
got 2 videos .. this one is when I pulled it out today http://www.youtube.com/watch?v=BKFfkAzDLx0&feature=plcp&context=C331dc40UDOEgsToPDskLjNArYKLiMkQwcXMeYWB-T (http://"http://www.youtube.com/watch?v=BKFfkAzDLx0&feature=plcp&context=C331dc40UDOEgsToPDskLjNArYKLiMkQwcXMeYWB-T")
And yes, that is my original dash.... lol
Post by: daminc on March 03, 2012, 12:29:10 PM
another video with a walk around of everything http://www.youtube.com/watch?v=PhjYl75oZkM&feature=context&context=C331dc40UDOEgsToPDskLjNArYKLiMkQwcXMeYWB-T (http://"http://www.youtube.com/watch?v=PhjYl75oZkM&feature=context&context=C331dc40UDOEgsToPDskLjNArYKLiMkQwcXMeYWB-T")
that is still my original interior, I only added the center console
Post by: daminc on March 03, 2012, 12:40:02 PM
and apparently....... if you just breath on the gas pedal........ This Happens.. lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0426.jpg)
Guess I can now finish putting it back together, without the fear of having to take the front end apart again to fix something.
I haven't drove it since 2003. Backing it out of the garage, it felt like driving a tank... Much as I remember it. so far, no squeaks, clunks, grinding. rubbing, or anything like that. I think I did pretty good for someone who was just going to do some body work 4 years ago and repaint it.... lol
Post by: mercury-man on March 03, 2012, 01:41:28 PM
Jerry , That Cougar of yours would look awesome over in Ohio for our gathering in July bud. :headbang:
p.s. but I know you will not come off your little island with it....:evilgrin:
Post by: thewestie on March 03, 2012, 04:43:45 PM
Looks fantastic Im happy for you that it is on the way to being on the road :)
Post by: sarjxxx on March 03, 2012, 08:09:38 PM
Its kind of cool to be able to look at your car, and with the exception of the engine bay, basically be able to see what my car will look like when it is finally finished as well. I imagine your pretty psyched about finally getting it to move. I know I was and mine didn't sit for nearly as long as yours lol.
Post by: daminc on March 03, 2012, 08:42:48 PM
Thanks Guys.... Dan, if it ends up at Catjam, it will be on a trailer, cuz if it breaks down in Youngstown, Eric will be stuck with it, because I'm taking his truck to get back home....lol
Post by: daminc on March 03, 2012, 08:54:36 PM
A few new pics as I was putting the rest back together today
window moulding back on...I used silicone to seal it this time... the last time it wasn't grabbing the clips right, so I said forget it this time around. Also installed the bottom plate and the wiper washer spritzers, along with the rubber around the hood hinges. (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0430.jpg)
engine bay all tidied up (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0431.jpg)
cleaned up the wiring mess in the passenger side,, and put the panels back on. (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0432.jpg)
installed the back moulding.... Kitz sent me some nice clips taped to a Christmas card for Christmas. Best present ever (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0434.jpg)
installed all the rubber in the door jambs. still have to put the top and bottom pieces on the door it's self (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0435.jpg)
Post by: 1Bad88tbird on March 03, 2012, 10:35:17 PM
It's nice to see it getting all buttoned up. It's been a long time comming! Great job Jerry!!
Post by: hypostang on March 03, 2012, 11:58:33 PM
Looking good man ...but for the love of all things holy will you please paint that ler on the side of your A/C compressor , that rusty cylinder is killing me ;)
Post by: Shadow on March 04, 2012, 01:24:38 AM
Quote from: hypostang;382915
i didn't even notice until you said something.. now it sticks out like a sore thumb! lmao
Post by: Kitz Kat on March 04, 2012, 05:57:44 AM
Looking good. Glad the trac loc works for you,it should it looked great inside when I looked at it.
Post by: daminc on March 04, 2012, 07:33:17 AM
lol... it's getting replaced with the other line for summer. that's why I didn't do anything with it
Post by: vinnietbird on March 04, 2012, 07:41:52 AM
I went back and checked out the videos. Very cool. It sounded like the Sport before I swapped lers a few weeks ago. It's a happy sound.
Post by: daminc on March 04, 2012, 07:52:52 AM
it shouldn't be to loud inside either... I had the window open when I backed it out.
Post by: vinnietbird on March 04, 2012, 08:13:26 AM
I have come to believe that my Sport is noisier than it should be because of the carpet. It's thinner than stock, and not as insulated. I'm getting the Raven carpet from Graham. Much heavier and thicker.
Post by: daminc on March 04, 2012, 08:20:06 AM
I put the heavy sound deadener in, and the nice felt backing was still on the carpet. A little heavy, but I want it quiet. Down the road, the SC will overcome the extra weight. ;)
Post by: vinnietbird on March 04, 2012, 08:39:26 AM
That's my thoughts exactly. Hopefully after I'm settled into the new job, I'm looking towards a supercharger for the Sport. Gotta get a few other things done first though.May be this time next year. Still, I'm happy for now. I just need a new intake and valve covers.LOL.
Post by: Chooglin on March 04, 2012, 08:46:55 AM
You have really done an amazing job on the Cougar Damic.It would be nice to have half your talent, to take on a project like you have. the car also sounds real healthy..............looking forward to seeing what you do with the vert.
Post by: vinnietbird on March 04, 2012, 08:49:14 AM
Jerry, ....ever thought of getting an old Cougar (Fox body), ...one that is stripped for the most part, and grafting the front and rear together (remove the cabin part)for a trailer for the current cars. Just something cool for the shows.
Post by: EFFalcon on March 04, 2012, 04:49:03 PM
Hahahahah... top idea :P
Post by: daminc on March 04, 2012, 05:12:10 PM
Sounds like to much work for a trailer... lol
I swear..... this is the last time I'm putting this hood on. I need a helper.... I'm getting to old to keep doing this by myself. (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0436.jpg)
and my first outdoor pics, where I didn't have to push it outside.... lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0446.jpg)
THIS is what I just CAN'T get anyone around here to understand why I don't make the scoops a functional ram air on the Sport's TC hood.....................
Post by: daminc on March 04, 2012, 06:24:11 PM
I was looking at the clearance with the scoops..... I think I can actually make them work.... my engine clears the scoops and the bracket..... I got some ideas a brewin.. lol
Post by: Thunder Chicken on March 04, 2012, 06:28:04 PM
God, it's hard to believe that's the same car as this (http://"http://www.foxtbirdcougarforums.com/showthread.php?17304-Project-Evolution-****Update-today...-New-pics****-Sunday-March-4-2012&p=193087#post193087")
Post by: daminc on March 04, 2012, 06:29:50 PM
here's another head on shot (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0443.jpg)
and a down shot (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0444.jpg)
Post by: daminc on March 04, 2012, 06:31:36 PM
Quote from: Thunder Chicken;382989
I can't remember what the car used to actually look like unless I look at the pics
Post by: daminc on March 04, 2012, 06:33:53 PM
Post by: vinnietbird on March 04, 2012, 06:39:57 PM
Don't forget the distributor in the middle between the scoops. If you can make it work, make one for me.
Post by: daminc on March 04, 2012, 06:50:16 PM
Quote from: vinnietbird;382997
If I can make it work.... I can have them molded for us... I know a guy. he said anything I need, just make a pattern, and he'll make it
I'll play with it when I play with the radiator cover, and battery cover, and all my wiring covers
Post by: thunderjet302 on March 04, 2012, 09:29:06 PM
It looks great :). Maybe I missed it but how did you get the front end back down? It sits really nice now.
Post by: daminc on March 04, 2012, 09:57:57 PM
I put air shocks in the back... the front never went down
Post by: vinnietbird on March 04, 2012, 10:50:36 PM
Keep me posted on those things.
Post by: vinnietbird on March 04, 2012, 10:51:54 PM
With the ram air, it would have to go to an air box, then to the t-body. ....and keep water out of the filter. Hmmmm.....yes, I could use one.
Post by: sarjxxx on March 04, 2012, 10:54:48 PM
Now if you just get some headlights on it it'll look all done:D
Post by: daminc on March 04, 2012, 11:26:41 PM
Quote from: vinnietbird;383033
I will study the design from the TC.. I still have the plastic part from the underside of the hood
Post by: vinnietbird on March 04, 2012, 11:32:56 PM
Even if just the passenger side scoop would suck in air maybe.....depending on available space due to the distributor and all. The a/c compressor bracket that bolts to the front of it, I left off. Just have the 4 big bolts at the bottom holding mine on. Been fine for quite a while, which may help in needed space.
Post by: daminc on March 04, 2012, 11:40:40 PM
looking at the pic...if I shortened the tube going to the TB and flipped the airbox over, it just might be in the right place to connect up to the scoops behind the upper rad hose.
I'll play with that tomorrow and see where things end up, and take some pics and measurements with the hood closed
Post by: vinnietbird on March 04, 2012, 11:47:42 PM
Sweet. I'm in.
Post by: daminc on March 04, 2012, 11:51:41 PM
stay tuned for tomorrows new episode of ..."Project Evolution"
Post by: beast50 on March 05, 2012, 04:27:19 AM
:bowdown::mercury::cougarsmily::headbang:....I could not say it any better
Post by: Long's88 on March 08, 2012, 06:53:44 PM
No headlights?? Gonna be hard to drive at night
Post by: daminc on March 08, 2012, 07:30:02 PM
I have night blindness anyway...I don't drive in the dark anymore
Post by: vinnietbird on March 08, 2012, 08:34:25 PM
Problem solved.
Post by: thunderjet302 on March 08, 2012, 11:46:23 PM
Quote from: daminc;382804
You know I started my T-bird today because I had to move it to my parents garage so I could clean out mine. It sounds exactly like your Cougar ;).
Post by: daminc on March 09, 2012, 07:28:09 AM
Quote from: thunderjet302;383420
and it should. It's almost identical under the hood... What lers are you using?
Post by: thunderjet302 on March 09, 2012, 09:22:32 AM
Quote from: daminc;383437
I've got Flowtech Afterburners, which I believe you're also running.
You really need to get the Cougar on the street and drive it. I forgot how fun mine is to drive since it's been in the garage since the last week of October. The streets were clear last night (no salt or water, I wouldn't have had it out if there was any) and since it was cold (about 36*) the car had problems getting traction above 1/2 throttle. I could fish tail down the street, which was kinda fun. I think you'll really like the engine you have once you start driving it. It will only be more fun once you add a blower. When you do get a blower I strongly recommend a Kenne Bell. Instant boost and instant torque at low rpms would make your Cougar really fun ;).
Post by: massCougarxr7 on March 10, 2012, 07:25:17 PM
ifwords could only describe everything i want to say right now...... holy mother of god.... it loooks great daminc
Post by: sarjxxx on March 10, 2012, 10:00:46 PM
Jerry I'm sure you mentioned it somewhere in this epic tale of epicness but I don't think I will be able to search it out... What paint did you use? Factory black or another?
Post by: daminc on March 10, 2012, 10:22:12 PM
Quote from: sarjxxx;383544
It's not factory... I believe it's a Chrysler black. Straight urethane, no clearcoat I never liked Ford black. even my Ranger looks boring... It just doesn't pop
Post by: sarjxxx on March 10, 2012, 10:24:15 PM
Quote from: daminc;383545
agreed. I was wondering what you used to get it so deep. Now I know:)
Post by: daminc on March 10, 2012, 10:25:01 PM
And the epic tale will soon be over. Like we're coming to the series finale
Post by: Shadow on March 10, 2012, 10:32:30 PM
more like skipping a season or 2! projects are never truely finished, even if you think they are lol
Post by: daminc on March 10, 2012, 10:34:45 PM
Quote from: Shadow;383551
This one will be.... it will sit in an auto-cocpuppies in the garage forever
Post by: Shadow on March 10, 2012, 10:37:05 PM
LOL where's the fun in that?
Post by: sarjxxx on March 10, 2012, 11:13:51 PM
I think we will get the failed 6 episode spin-off series next time when he does the supercharger lol (not that the supercharger will fail, just that it's to short to make a whole show:p) oh god I watch to much tv
Post by: Shadow on March 10, 2012, 11:15:01 PM
nice pun lol
Post by: 1BadBird on March 12, 2012, 02:18:16 PM
Quote from: daminc;383553
LOL, like all those unfinished projects in Stacey David's "Gearz" shop
Post by: Shadow on March 12, 2012, 03:28:25 PM
Quote from: 1BadBird;383759
they haunt me everytime i watch the show.. lol especially the big willys on iroks! :( but i don't think jerry could do that to his cougar lol
Post by: daminc on March 16, 2012, 08:38:27 PM
Update......
Swapped the radiator with my original yesterday.... no leaks now.. Bolted the header to the bumper, and put the front lights in today, still have to get some bulbs and put a few more bolts in the fenders, and put the inner fenders back on.
Noticing problems with the aod not going into gear randomly.... think I need to change the filter... I hope.
Car is mostly running real good. has some querky episodes once in a while... I'll have to check for codes and recheck the timing and idle. Does it mostly when the motor is started and not warmed up... Still using the original sensors from the parts bird....which I think also had the same problem I remember
Got an idea on how to replace the rod in the shifter... Hope it works
Need to tighten the exhaust pipes better, and re position the drivers side hanger
Also need to fix the drivers window that fell off the track.... I will update tomorrow, with some pics of the entire car back together... hope it doesn't rain
Post by: daminc on March 17, 2012, 05:54:36 PM
some higher res pics of my car.
fixed my window. forgot to tighten the glass tracks when I put the door back together (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_1808.jpg)
and some random shots of the car all pretty much put together (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_1809.jpg)
never had a car that was so clean underneath (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_1815.jpg)
still have to turn my ler and tighten the clamps (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_1816.jpg)
After re-reading the first page or two, you were taking an hours count. Did you ever come up with a final hours count?
No, I totally gave up counting after cutting most of the panels off, and upgrading a bunch of stuff.. I also spent 7 grand more then I was originally planning when I decided to "just do a little body work" .... lol
Post by: cougar1car on March 19, 2012, 09:02:49 AM
Looks great man... Very nice work..
Post by: daminc on April 21, 2012, 04:08:12 PM
first car wash (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_0652.jpg)
Post by: Shadow on April 21, 2012, 06:20:00 PM
so is it done done?
Post by: daminc on April 21, 2012, 06:24:12 PM
no, just wet
Post by: daminc on October 24, 2012, 08:38:59 AM
So after several years... my car is back in it's original parking place... The same spot where it disintegrated to almost nothing... I got the stuff for my 24# injector upgrade, which will probably happen tomorrow or Friday along with all the light bulbs.... I installed the hood scoops finally, along with the hood latch last week...
looks like registration will be very soon now... finally
here's the official before and after pic look the inspection and registration stickers on the windshield are still the same.... from 2003....lol
when it goes for inspection at my friends shop. I will get some good pics of all the work I did to it underneath when it's on the lift
and after... the shop has also gotten much bigger since then too....:hick: (http://i233.photobucket.com/albums/ee79/daminc/IMG_1606.jpg)
Post by: 1Bad88tbird on October 24, 2012, 09:36:54 AM
You'd never that was the same car. Are you going to replace the side molding?
Post by: daminc on October 24, 2012, 10:07:12 AM
no..... no side moulding, I never liked it
wow, did this project get a lot of views.....
Post by: daminc on October 24, 2012, 10:09:01 AM
Quote from: 1Bad88tbird;401154
it really isn't the same car...only a handful of metal is original to it.
Post by: 1Bad88tbird on October 24, 2012, 10:27:06 AM
This is true!
Post by: Bob on October 24, 2012, 10:29:23 AM
Quote from: daminc;401156
LOL, I was just thinking that. It must be linked all over the net :) Good Job! Looks great!
Post by: 83TB on October 24, 2012, 01:25:36 PM
Looks good, man the under side looks good too!!
Post by: 84TBirdTurbo42 on October 24, 2012, 05:30:25 PM
Quote from: daminc;193592
This is my way of relaxing and doing something fun. If it takes me 5 years or more to do it, that doesn't bother me
congrats jerry! it did take just as long as you said! but awesome job!
Post by: daminc on October 24, 2012, 07:34:48 PM
Ok.. I'm ahead of schedule... thinking about it... I'm going to wait until after I register, and have the car inspected before I change the injectors.... just in case something goes wrong, and it delays me... so as far as I can see.... it's ready.... everything seems to be working... I just have to get the wipers to go back down to park
Post by: flylear45 on October 24, 2012, 08:30:29 PM
Check your ground wire coming off the wiper motor. It did that to me when my ground was bad.
Post by: daminc on October 24, 2012, 08:42:56 PM
its been going bad since about 1994..... it would randomly not park and squeal..... I'll check the ground, and do the motor clean, and see if that does anything. I have another motor if it doesn't want to work anymore... it served me well through the years
Post by: EricCoolCats on October 24, 2012, 09:41:37 PM
Jerry, I don't know how deep you want to get into the whole wiper thing but here's some info that may help with your current motor assembly: http://www.coolcats.net/help/wipers.html
Personally I find it much easier to just replace the motor but that's just me. ;)
Post by: daminc on October 24, 2012, 10:01:07 PM
Thanks Eric.. I'm gonna fiddle with it... I went this far.. what have I got to lose
Post by: Fordracer08 on October 24, 2012, 10:06:31 PM
The Cougar looks great! I really like the black paint. What size tires are you running on it?
Post by: MY83T on October 24, 2012, 10:16:48 PM
Quote from: flylear45;401186
+1 had the same issue and fixed by cleaning the ground wire.....
Post by: daminc on October 24, 2012, 10:36:08 PM
Quote from: Fordracer08;401197
235s on the front 255s on the rear
Post by: jcassity on October 25, 2012, 01:02:48 AM
Quote from: daminc;384366
no worries there man, because once upon a time i said......................
"I honestly dont think you could exceed the cost of a new car buy installing new *stock* parts everywhere in your coug our tbird. Its just plain impossible. You could revamp the entire drivetrain/engine/suspenstion and still come out ahead"
Post by: daminc on October 26, 2012, 11:54:37 PM
Quote from: jcassity;401219
Your exactly right...as long as you don't have to pay for labor too..
Post by: daminc on November 12, 2012, 05:45:24 PM
update.....The wipers park again... I cleaned the ground wire, and bolted it back down... It's always something simple... isn't it?...
I guess I need new wipers now. (http://i233.photobucket.com/albums/ee79/daminc/IMG_1781.jpg)
Post by: flylear45 on November 13, 2012, 08:08:18 PM
Post by: daminc on January 07, 2013, 06:59:41 PM
Post by: CoogarXR on January 07, 2013, 07:04:42 PM
I think I see a little rust starting along the...
Just kidding, looks great :)
Post by: 1WLD BRD on January 07, 2013, 07:20:10 PM
this car stuns me everytime I see it. one of these days I have to check it out in person
Post by: Haystack on January 08, 2013, 02:17:44 AM
Trunk lid sure looks good ;).
Post by: Chooglin on January 08, 2013, 04:05:03 PM
shagy, that's all I can say.
Post by: daminc on February 19, 2013, 09:05:56 PM
Guess this car was meant to be in the snow.... lol (http://i1046.photobucket.com/albums/b463/daminc-pics2/DSC_8180_zpsbdf141b4.jpg)
Post by: MY83T on February 19, 2013, 10:34:19 PM
looks amazing Jerry!
Post by: STANG8U on February 19, 2013, 10:35:48 PM
Man this thread has a lot of pages lol
Clean car !
Post by: Kitz Kat on February 20, 2013, 05:05:19 AM
I bet there there is no firehawk tracks going out the driveway. What's hanging down in the front of the last pic?,looks like red wires. We got twins now Jerry, except the wheel and tires.
Post by: STANG8U on February 20, 2013, 12:34:56 PM
Yea I saw that to
Post by: daminc on February 20, 2013, 03:37:46 PM
I pulled the cooler off the aod temporarily. Its the extra slack in the lines
Post by: daminc on February 20, 2013, 03:39:19 PM
Quote from: Kitz Kat;409714
There's never any firehawk tracks leaving the driveway...lol
Post by: Drewstang on March 17, 2013, 11:50:02 AM
At 40 posts per page, I've read thru the last 83 pages on the edge of my seat. Great job saving this car, most would have walked away and let it go to the s yard. I'm also taking notes for my next project and I don't feel as reserved to get a 4 eye bird in rough condition.
Post by: daminc on May 07, 2013, 07:39:43 AM
not much of an update... but the shifter area is now done (http://i1046.photobucket.com/albums/b463/daminc-pics2/putting%20it%20back%20together/IMG_2318_zpsdeb56fcb.jpg)
Post by: thunderjet302 on May 07, 2013, 04:00:30 PM
Quote from: daminc;414612
Looks good. You have a gear indicator on the dash correct? What do the other two switches in in the Turbo Coupe antenna plate do ;)? I have one I'm thinking about installing myself. I'm trying to figure out what to make the other switches control.
Post by: daminc on May 07, 2013, 07:50:12 PM
1 I'm thinking of making an ignition cutoff switch....so obvious no one will ever think to flick the switch to start the car.. I'm also connecting the shifter to the dash gear selector.. needed my boot to see how much room I have to put the old console selector plate on under with some mods to connect to the dash with a cable.
the other switches..... I'm not sure,,, I remember wanting them for some reason 4 years ago.... lol
Post by: EricCoolCats on May 07, 2013, 08:34:12 PM
If it helps, Jerry...I know that GM G-bodies had a long cable from the floor shifter to the dash gear indicator. You can definitely fab something up.
See here: http://www.opgi.com/monte-carlo/1986/interior-accessories/dash-accessories/L240713/ http://www.opgi.com/monte-carlo/1986/interior-accessories/console/99L0126/
Post by: daminc on May 07, 2013, 08:37:44 PM
Thanks Eric..the Monte is what I had in mind when I thought about doing this
Post by: massCougarxr7 on May 18, 2013, 09:51:31 PM
Dude!!!!!!! Thing looks mint!!!! How ya been!
Post by: daminc on June 17, 2013, 11:20:16 PM
I've been good... Been working on another project
Post by: daminc on July 12, 2014, 12:57:07 PM
project complete....... here it is getting inspected
Post by: V8Demon on July 12, 2014, 01:46:39 PM
Get in and drive!
Post by: daminc on July 12, 2014, 01:53:08 PM
The wife and I cruised around the Island today... A nice 20 min drive.... The car still rides like a tank...but boy does it have a lot of get up and go now.
Post by: thunderjet302 on July 12, 2014, 09:57:55 PM
Drive,drive, drive the heck out of it.
And do burnouts. Lots of glorious burnouts. With the cam you have an the converter (I have the same stall and cam ;)) you should be able to push the throttle half way down from a stop and lay rubber for 30-40 feet and make the car go sideways. Mine will. It is fun :).
Post by: 1Bad88tbird on July 13, 2014, 01:53:35 AM
Nice to see you're enjoying it after all that hard work!
Post by: sarjxxx on July 13, 2014, 02:54:14 PM
Quote from: daminc;435851
Words I never thought I'd see. Hell yeah now enjoy it Jerry!
Post by: daminc on July 13, 2014, 04:45:26 PM
of course this means I can strip down the vert, now that I have another car to drive....
After driving my 87 again after 10 years, I've noticed how inferior the earlier cars were constructed... The vert feels like I'm driving a tin can in comparison, or almost like I remember my moms 82 Chevette feeling like when I drove it
Post by: V8Demon on July 13, 2014, 08:48:13 PM
The early ones are VERY close in fell to a fox Mustang. Everything has to be spot on or else you'll notice.
Post by: bodyman on July 13, 2014, 09:32:48 PM
I have looked at portions of this thread here and there, but last night and this morning I started at the beginning and went to the finish. I did skim over some of the Vinnie and company comedy, but WOW, what a trip. The workmanship and effort put into this car, to quote many, is crazy.
daminc
Just wondering if you think this may have anything to do with the sub frame connectors, jacking bars, welded seams, umpteen coats of paint top and bottom of the floors, sound deadening on the floor etc.? That and the fact the convert is lacking the structure of the roof. I have a friend with a 87 bird, and my brother has the 84 cougar, I never noticed much of a difference, but can't say I really paid much attention either.
Post by: vinnietbird on July 13, 2014, 10:24:11 PM
I said it a o long time ago, but EVERY time I READ "Project Evolution", I HEAR in my head....Project Evolution Revolution. LOL. YOU know what I mean. LOL.
Post by: EricCoolCats on July 13, 2014, 10:49:44 PM
Quote from: daminc;435906
Yep. I've been saying this for years also. And Jerry, you put in more bracing than normal so you should have noticed a huge difference. Every spring when I take my convertible out for the first spin of the year, I just cringe at all the rattles and the horrid ride quality LOL. But I still wouldn't trade it for anything.
Post by: daminc on July 14, 2014, 07:24:47 AM
I'm not sure if it is all the bracing or not, but I remember it driving like a tank compared to many cars years ago.. After driving the vert, I pretty much now know how I need to rebuild certain parts of that car....I hate not being able to latch the roof because I'm parked on an un-eaven surface.. I think the weight, and size difference between the 2 models of cougars have a lot to do with how it feels when you drive it.....the parts bird also didnt have the same feel as my cougar. Could be the roof length thats doing it too. there's a lot of metal there
Post by: daminc on July 14, 2014, 07:58:35 AM
after having my entire car apart and then putting it back together..... I am surprised that it doesnt rattle, squeak, shimmy, or shake..... the steering wheel doesnt even shake, or vibrate at 60mph
Post by: thunderjet302 on July 15, 2014, 05:36:16 PM
Quote from: daminc;435934
You know even my Mark VII, probably the stiffest Fox-platform car from the factory, lacks in comparison to my Thunderbird. The Thunderbird has subframe connectors and a Maximum Motorsports strut tower bar. Those two things made a noticeable difference in chassis rigidity.
Post by: Aerocoupe on July 18, 2014, 02:43:57 PM
The first mod anyone with a Fox car should do is subframe connectors. I took my '83 to a body shop with a frame machine and had them check it prior to welding them in so it would not be permanently out of whack. With just the Global West units welded in it was like night and day but when I welded up the Griggs uppers subframes and tied them into the lowers there was again improvement. I noticed zero difference with the 6 point roll cage but I feel safer. However a person goes about installing subframe connectors (bought or hand built) it is hands down the best mod for these cars but please do not bolt them in weld, weld, weld them in!!
And so I am not totally off topic here, this is one hell of a build thread! One of the most detailed I've seen and the results were worth all the effort man.
Darren
Post by: daminc on July 29, 2014, 08:10:27 AM
Quote from: EricCoolCats;435927
I'm going to try to fix that problem first.... I'm also tired of the door glass rubbing on the top frame depending how its parked... I see a lot of welding coming my way this winter... my goal is to be able to jack it up in the center like this car, and not have it bend in half.
keep an eye out this fall, for the next project http://www.foxtbirdcougarforums.com/showthread.php?23805-Evolution-II-misc-stuff-July-26-2012 (http://"http://www.foxtbirdcougarforums.com/showthread.php?23805-Evolution-II-misc-stuff-July-26-2012")
Post by: daminc on October 18, 2014, 12:14:51 AM
This is for everyone that doesn't believe that my car ever leaves the garage.. :D
Post by: GigShooTer69 on December 01, 2014, 12:02:49 PM
That's a beautiful car
Post by: thunderjet302 on December 01, 2014, 09:06:08 PM
What's that red thick gauge wire in front of the driver's side wheel?
Post by: daminc on December 01, 2014, 10:41:57 PM
Quote from: thunderjet302;441226
thats the transmission line....I remove the cooler temporarily and it dropped down a bit . the lines are going to be replaces with hard lines this summer
Title: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: thunderjet302 on December 02, 2014, 05:53:20 PM
Quote from: daminc;441236
Ah I was wondering what that was. As a FYI you can buy the lines: http://www.latemodelrestoration.com/item/LRS-MUT1021SC/84-93-Mustang-Stainless-Automatic-Transmission-Cooler-Lines
Car looks great :).
Post by: daminc on December 02, 2014, 10:00:55 PM
are the lines from a Supercoupe AOD in the same location?
Post by: thunderjet302 on December 02, 2014, 10:25:58 PM
Quote from: daminc;441276
Yes. The Super Coupe AOD has the same case as the AOD in a Fox Thunderbird/Cougar/Mustang. It just has better guts.
Post by: daminc on May 09, 2015, 06:56:29 PM
new stuff (http://i1046.photobucket.com/albums/b463/daminc-pics2/winding%20down%20the%20entire%20project/IMG_3763_zpsi0qftbfz.jpg)
Post by: Ramos617 on May 09, 2015, 07:21:24 PM
Nice
Post by: vinnietbird on May 10, 2015, 06:48:23 PM
One piece closer, Jerry. Keep the pics coming. I need a new booster and MC as well....and proportioning valve....and the larger Fox Body Stang front breaks....and SN-95 rear discs re-drilled for 4 lug.....LOL.
Post by: daminc on May 10, 2015, 08:40:54 PM
think I was in need of a new MC anyway
Post by: daminc on August 07, 2015, 07:18:03 PM
wasnt sure if I ever posted pics of the underside of the car..here are some while it was up on the lift for inspection
Post by: Haystack on August 07, 2015, 07:49:07 PM
Inspection guys notice anything was done, outside of the jacking rails?
Post by: vinnietbird on August 07, 2015, 07:51:44 PM
Awesome chassis work, Jerry. Road Warrior style. LOL. I need some subframe connectors and 4 jacking points. Hmmmmm......I'll start getting that worked out.
Post by: daminc on August 07, 2015, 08:15:06 PM
Quote from: Haystack;450417
he's a friend, he saw it in the making
Post by: vinnietbird on August 08, 2015, 09:25:29 AM
So what's next on the agenda? Applying time to the vert?
Post by: daminc on August 08, 2015, 10:33:39 AM
yes, the vert is in a rust bath, and the pass side paint is stripped off right now
Post by: Beau on August 08, 2015, 11:49:29 AM
The BattleCat!
Post by: daminc on August 08, 2015, 04:20:46 PM
I meant the drivers side paint is stripped off of the vert... :hick:
Post by: Kitz Kat on August 09, 2015, 08:21:08 AM
I remember that tank frame.
Post by: daminc on August 09, 2015, 10:09:46 AM
Quote from: Kitz Kat;450475
and it works very well. the spaces around the doors and fenders never changed when it was on the lift using the outer rails
Post by: daminc on July 21, 2017, 02:16:00 PM
looks like all my pics are disappearing from my photobucket account :mad:
Post by: sarjxxx on July 21, 2017, 03:52:37 PM
I got an email from them today saying that I would have to upgrade my account because 3rd party image hosting is no longer supported under free accounts...
However, they did say that the pictures wouldn't be deleted, just wouldn't remain posted up on forums/websites/etc
Post by: Beau on July 21, 2017, 07:19:08 PM
Yeah, PB is teh shagin' suck. On my gun forums, people are pissed off too. Imgur is also against 3rd party.
However, I can still make posts and link my pictures as before and they work..
Post by: thunderjet302 on July 21, 2017, 07:27:57 PM
Unfortunately the Photobucket thing has been going on over the last couple weeks. They can suck it. I'm not paying them.
Post by: Thunder Chicken on July 21, 2017, 10:20:13 PM
It's not bad enough that they have suddenly and without warning decided to do this, but their hosting isn't even cheap. Hell, it's not even reasonable! I would bet that a dedicated web host such as Godaddy would have cheaper options, complete with your own domain name. Godaddy used to host this forum until we got too big for our britches... This will probably make photobucket go the way of cardomain, myspace, etc...
Post by: Haystack on July 22, 2017, 03:35:13 AM
Quote from: ThunderbirdSport302;461887
Mine worked fine till yesterday. Save what ya can and get off of there. Im locked out of mine. I can veiw some pictures but cant "download" any. Got an email two days ago saying it was suspended due to violation of a policy change some time last year with a link to my t-5 swap thread (which was what 4 years ago?) As the reason my account was locked.
Post by: sarjxxx on June 03, 2018, 02:58:42 PM
So, it looks like photobucket turned everyone's photos back on... That's a relief!
Post by: daminc on August 31, 2018, 12:59:08 PM
pics are still up....I knew I could out stubborn them..... lol
Title: Re: Project Evolution *** Project Complete **** Wednesday July 9, 2014
Post by: daminc on May 09, 2019, 10:13:31 AM
I was notified by photobucket that they will be deleting 100s of pics from my accounts by june. I imagine many of the pics on this thread will be gone.... Looks like an end of an era.... Anybody interested in this thread can click the print with pictures, and save as a PDF to your computer..... The file size is 437mb.
Thanks for all your support Jerry :cougarsmily:
Post by: mcb82gt on May 09, 2019, 12:13:38 PM
7 years of work, WOW!
I also have a black Cougar with turbines. Your car is beautiful. I also rock the white letter tires.
What size are the Firehawk tires and can you still buy them? All I can find is cooper cobras and BFG
Post by: HAVI on May 10, 2019, 08:38:03 PM
I got the same photobucket notice. I'll be downloading your pdf. Thanks!
Post by: Aerocoupe on May 10, 2019, 09:07:54 PM
I didn’t get the notice but I pay $25/yr for the service. Got rid of all the adds and it’s not as herky jerky. So maybe mine are okay?
Post by: Beau on May 11, 2019, 01:20:18 PM
I've stopped using PhotoSuckit, imgur is the shiznit, now.
Post by: Tbird232ci on May 13, 2019, 01:42:12 AM
I've been using Flikr. I have heard they are going to go the same way as Photobucket at some point. My next route will be doing my own domain and server.
Post by: V8Demon on November 05, 2019, 05:19:20 PM
No shiznit? They give a 1TB max for free accounts as of now.... It's a shame as uploading to them was near lossless with regards to photo quality.
