Technical => Electrical Tech => Topic started by: Drewstang on November 12, 2007, 09:02:53 PM
Title: CFI to SEFI ver.238412412873412783
Post by: Drewstang on November 12, 2007, 09:02:53 PM
Okay, since I've tried searching with no good results, whats the easiest way to swap out CFI for SEFI? Are there differences between a T-bird and Cougar SEFI harness and a 86-89 Mustang EFI harness? Has anyone used the Ford Motorsport EFI harness? Thanks in advance.
Post by: Beau on November 12, 2007, 09:16:36 PM
Quote from: Drewstang;187302
Easiest way would be to find an '87-'88 Bird/Cougar harness, and eec, and other necessary engine parts...OR HO parts and matching eec.
I've not had any experience with the Motorsport harness.
Post by: Drewstang on November 12, 2007, 09:22:57 PM
I'd like to have Mass Air, and I know this wasn't used on most 86-88 T-birds. I could do the conversion, but I'd like to just drop in the harness and EEC and go. Can someone take a good engine bay pic where the CFI harness meets the dash harness, and where the EEC harness meets the body harness on the pass side kick panel? I think with good pics, I'll be able to tell which harness will work. I've worked with the 89 Mass Air harness and EEC in older Mustangs, and I've also helped convert a few street rods and one turbo 66 Fairlane to SEFI using the FMS harness.
Post by: Chuck W on November 13, 2007, 10:31:39 AM
The EEC harness will come out on it's own.  Unplug it from the ECU, unbolt the ground wire and push it through and that should be it.
Post by: EricCoolCats on November 13, 2007, 11:01:47 AM
Most people that have used a Mustang EEC harness have run into problems somewhere along the line...having to switch pins, some smaller harnesses are different, etc. The same would probably be true of the Motorsport wiring kit as it's based upon the Mustang harness. If you got a shop manual for the Mustang EEC and also the Cougar/T-Bird EEC, you can easily repin it so that it would work with your car (i.e. turn on the fuel pump). The '89 Mustang mass air harness would theoretically be the one to get (pre-airbag) but just don't ask Vinnietbird about that one. ;)
The only true "plug-and-play" solution is the 1986-88 Cougar/T-Bird 5.0 harness, preferably from your particular model year. This gets you SEFI and speed density. From there you can purchase a small 4-wire mass air hookup kit for around $30 US and attach that to the new SEFI harness. Very simple, efficient, really not much in the way of swapping wires (you will have to for mass air but it's only two, plus piggyback two wires, nothing scary). For that matter you could mate the mass air wiring in with the Cougar/T-Bird 5.0 wiring outside of the car, install it, and then you don't have to worry about running a separate harness. Just be careful, as another member here had an issue with doing that, and the engine didn't run right...it was tracked down to the wiring, although we felt is was simply a bad harness to begin with.
Also be aware that the actual shape of the holes where the EEC harness comes through seems to be different, depending on the harness and model year. Some are rectangular, some are oval. You may have to massage some metal.
Post by: Drewstang on November 13, 2007, 02:38:47 PM
Quote from: Chuck W;187392
Thanks EFI bot. That didn't answer the original question did it?
I'm asking which harness to use to switch to SEFI, not how to get the old one out.
Eric- Thanks for the info. I guess I need to find a 86 SEFI harness. If anyone happens to have one, please let me know.
Post by: Chuck W on November 13, 2007, 02:48:18 PM
Quote from: Drewstang;187403
You're welcome smartass bot.
Post by: Drewstang on November 13, 2007, 04:47:01 PM
Don't call me a smartass when reading owns you.
Post by: Chuck W on November 13, 2007, 05:06:05 PM
Nevermind, you're not worth my time.
Post by: Drewstang on November 13, 2007, 08:00:49 PM
I would like to know what your problem is. Maybe you can spare some of your busy time to explain it.
Post by: jcassity on November 29, 2007, 12:02:56 AM
hey bluegrass,, why you messin with chuck, hes a good guy.  You do need to know that no,, none noda,, no a single tbird/coug from the years you indicated came with MAF.  Just fyi.
Eric is dead on and for all your upgrades, try like heck to stick with the wirng that came in these cars.  This will reduce the future complications especially when it comes time for the full electronic cluster.
yours truely, former area code 606 resident.
Post by: Drewstang on November 29, 2007, 08:58:47 AM
I saw the Boyd County comment and I won't hold it against you.:D
Post by: CougarSE on November 30, 2007, 08:02:54 PM
Ok guys this is the end all to this question....
86 sefi harness.....
83, 84 and 85  v8 cars used the same connector for the dash interface as the 86.  In 87 ford was switching to weatherproof connectors.
This is not to say that the 86 harness will drop in.. But it is by far the easiest harness to use.
Post by: Drewstang on December 08, 2007, 09:11:53 PM
I will put together a detailed swap thread when I get the harnesses soon.
Post by: igiveup on December 09, 2007, 11:55:05 AM
Hello
  One thing to remember is to match your cam to your computer.
mustang computers need a H.O. cam.  T-bird/cougar computers need a  S.O. cam.  They have different firing orders.  Mixing cams will confuse the computer.  A bit off topic but good to know.  I have been there and it causes a lot of headaches.
igiveup
Post by: Drewstang on December 09, 2007, 01:30:36 PM
Thats a very good point I did not think of. I'm going to be using a 94-95 5.0 HO so I guess I need to track down a 86 GT/ LX 5.0 ECU.
Post by: Beau on December 09, 2007, 01:51:57 PM
Quote from: Drewstang;191846
No, you'll need a Mass Air EEC to run an engine newer than 89.
An 86 was still Speed Density.
Unless of course you change your engine back to SD, that is.
Post by: Drewstang on December 09, 2007, 10:27:46 PM
Yeah, I was going to run SD until I got the money to do the MAF conversion with Mustang A9P ECU.
So, to be 100% clear I can run the 94-95 HO with the 86 T-bird ECU so long as it stays speed density correct?
Post by: cougarman on December 09, 2007, 10:36:52 PM
sure can, i might have a  87-88 mustang ecu, i will check for ya
Post by: Drewstang on December 09, 2007, 10:52:33 PM
Quote from: cougarman;191974
Did you get my PM and payment?
Post by: cougarman on December 10, 2007, 09:03:44 AM
sure did on friday, will go out today!  did you want me to see if i had the h.o. computer and swap it for the s.o.?
Post by: Drewstang on December 10, 2007, 08:28:15 PM
Quote from: cougarman;192032
Cool, yeah I'll need an HO ECU. Thanks again.
