Technical => Drivetrain Tech => Topic started by: 88cat on January 22, 2005, 11:59:06 PM
Title: 8.8 rear end quad shocks
Post by: 88cat on January 22, 2005, 11:59:06 PM
Hey guys i just got a 8.8 rear out of a mustang and it had quad shocks, so my question is should I install them? Will the quad shocks give me more power to the ground and maybe better handling or should I remove them from the diff thanks guys lmk.
Title: Re: 8.8 rear end quad shocks
Post by: dominator on January 23, 2005, 01:21:32 AM
They will help with wheel hop, if you've got all the bracket to bolt them up, use them definetley.
Post by: cougarcragar on January 23, 2005, 03:24:46 AM
Do you have the brackets on the frame rails? I thought the XR7s only got those?
Post by: EricCoolCats on January 23, 2005, 09:43:33 AM
You cannot use Mustang frame brackets...you must use T-Bird/Cougar brackets. Otherwise, yes, install them if you can. They really help keep the rear end behaving.
Post by: 88cat on January 23, 2005, 01:01:21 PM
Well I dont have the Cougar frame brackets but will look for them in a jy thanks guys for your help.
Post by: vinnietbird on January 26, 2005, 07:58:23 AM
I've got them on my T-Bird and they seem to help a little.Better than before I put the locker in.The quads keep the rear end from bouncing around so much.I installed new quadshocks,as the used ones were VERY used.
