Technical => Engine Tech => Topic started by: Tbird232ci on January 17, 2005, 04:39:46 PM
Title: accessory brackets
Post by: Tbird232ci on January 17, 2005, 04:39:46 PM
ive been sitting around thinking about the 5.0 swap again, and running the things i need through my mind, and one was accessory brackets
around here, anything 5.0 related in the junkyard is hard to come by...but on the other hand, there are unlimited amounts of 3.8L mn12's in junkyards
would using these brackets be possible? i couldnt see them being different between a 5.0 and 3.8 mn12, meaning theyd most likely bolt up to a 5.0, but the question arises if they would be clear everything fine, the mn12's and fox's have different engine compartment clearances
Title: Re: accessory brackets
Post by: CougarCoupe88 on January 17, 2005, 04:54:07 PM
hey if my car goes bye bye i have most of the bracets just not the alt. but is ez to come by round me  so i'll let you have them for cheep bc they will just be  taking up space.
Post by: Tbird232ci on January 17, 2005, 05:18:23 PM
brackets for a 5.0? or a 3.8?
Post by: CougarCoupe88 on January 17, 2005, 08:06:27 PM
5.0
Post by: Tbird232ci on January 17, 2005, 09:17:11 PM
ill definatly keep it in mind, i do like the mn12 bracketry, so id like to use it if possible, but if it wont work, youll hear from me
Post by: CougarCoupe88 on January 17, 2005, 10:56:07 PM
ok or if my car does come out ok . i can find em around here so. let me know
