Technical => Engine Tech => Topic started by: the_intimidator03 on January 10, 2005, 05:47:40 AM
Title: 3.8 engine bog
Post by: the_intimidator03 on January 10, 2005, 05:47:40 AM
can anyone tell me what could cause my 84 cougar 3.8 to bog when gas pedal is punched for fast excelleration... it happens at 15 mph or less.  when i launch from the stop light the car tends to bog when i push the gas pedal.. as in moves forwards a little and then bogs then i gotta back out of the gas n go a lil more gently on it and it goes fine.  also when i coast to a stop or when idling the CEL comes on while in gear and usually goes away if i put it in nuetral or park and the idles go up just slightly(from no load) could it be my idle is too low? or a vacuum leak?
Title: Re: 3.8 engine bog
Post by: lowcat on January 10, 2005, 09:15:19 AM
Mine does the same thing. When I pulled the codes I found that I need to replace some egr stuff. Hopefully once I do that, I won't have this problem anymore. Try pulling the codes and see what you get.
Post by: the_intimidator03 on January 18, 2005, 10:56:45 AM
update... CEL comes on ONLY after its warmed up. any other ideas... n i outta go check couple things out lol
Post by: cougarman on January 18, 2005, 12:09:24 PM
Only way to know for sure is to pull the codes. :grinno:
Post by: Ifixyawata on January 18, 2005, 12:17:48 PM
On an '84 car, though?  The only function of the engine light in a '84 is to warn of low oil pressure of high coolant temp.
Post by: cougarman on January 18, 2005, 12:37:45 PM
:dunno: didn't eec4 start in '84?? :dunno:  :dunno:
Post by: Ifixyawata on January 18, 2005, 01:12:05 PM
I'm not sure about the nomenclature, but I know pulling codes on an '84 car usually involves a test light hooked up somewhere under the hood.
Post by: softtouch on January 18, 2005, 03:11:49 PM
You have a RED ENGINE light but no AMBER CHECK ENGINE light.
It indicates low oil pressure or overheating.
Post by: Ifixyawata on January 18, 2005, 03:16:16 PM
Quote from: Ifixyawata
Just as I said.
Post by: Sconic on January 19, 2005, 09:01:08 AM
possibly an O2 sensor. Mine had that problem for a while stopped when i replaced it. Also change the fuel filter.
Post by: lowcat on January 19, 2005, 12:15:45 PM
That is how I pulled the codes on my 87 3.8. I believe Masterblaster has a very good diagram on how to do this.
Post by: the_intimidator03 on January 20, 2005, 01:13:58 AM
well i got the codes pulled and they said my TPS is bad and my egr or solinoid is possibly bad had 3 codes but i dont remember the number on it. and as far as that check engine light goes its ONLY when it warms up and is in gear and stopped. well anyone know how much TPS runs and how hard it is to install? and egr n solinoid while were at it thanks for your help
Post by: the_intimidator03 on January 20, 2005, 01:15:20 AM
oh btw the plug ins for the codes are under the washer resivoire on my 84 3.8 2 plugs a small one n a large one
Post by: Ifixyawata on January 20, 2005, 11:10:40 AM
The reason the light only comes on when the car is warm and idling in gear is because it's coming on due to a low oil pressure reading.  Either you actually have low oil pressure or the sending switch is defective, allowing it to read lower than it really is.  Get a guage if you want to be sure.
Post by: jcassity on January 20, 2005, 04:45:40 PM
hesitation symptoms (i dont have this problem anymore but fought it for several years)
remove fuel injector screens and or replace them
remove the cfi and egr base plate and chip away at the carbon
check tps for a smooth voltage on the green wire to ground,, should be less than a volt with the key on. move linkage and watch the voltage increase to about 4.6vdc. its best to use an buttstuffog meter (needle) for this test.
Gut the cat on the intermediate pipe.
Post by: the_intimidator03 on January 20, 2005, 10:40:47 PM
alright. how much would a basic oil pressure gauge run and how hard to install? just curious i havnt really done much int hat aspect... hell im just tryin to get my speakers going in my car lol. thanks for all ya help
